  4. WICHTIGE Info für Nutzer des RWE-SmartHome Adapters (Innogy-SmartHome)!
149 Beiträge 24 Kommentatoren 49.7k Aufrufe
  • C
    C
    csamaggi
    #89
    Guten Morgen,
    muss sagen der Adapter läuft echt gut.
    Mal eine Frage ist es eigentlich möglich auch den Batteriestatus der Geräte abzufragen?
    MFG Maggi
    • T
      T
      torstenh
      #90
      Hallo Part,
      hier noch einmal ein log:
      ! host.POETNITZ15 2017-02-22 20:15:41.638 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
      ! host.POETNITZ15 2017-02-22 20:15:41.638 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
      ! innogy-smarthome.0 2017-02-22 20:15:41.576 info cleaned everything up…
      ! Error: 2017-02-22 20:15:41.576 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
      ! Error: 2017-02-22 20:15:41.576 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
      ! Error: 2017-02-22 20:15:41.576 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
      ! Error: 2017-02-22 20:15:41.576 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
      ! Error: 2017-02-22 20:15:41.576 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
      ! Error: 2017-02-22 20:15:41.576 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
      ! Error: 2017-02-22 20:15:41.576 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:84:17)
      ! Error: 2017-02-22 20:15:41.576 error at SmartHome._initialize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:293:12)
      ! Error: 2017-02-22 20:15:41.576 error at new Promise (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:77:14)
      ! Error: 2017-02-22 20:15:41.576 error at Promise._resolveFromExecutor (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:481:18)
      ! Error: 2017-02-22 20:15:41.576 error at Promise.cancellationExecute [as _execute] (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\debuggability.js:321:9)
      ! Error: 2017-02-22 20:15:41.576 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:294:25
      ! Error: 2017-02-22 20:15:41.576 error at Requestor.call (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:42:17)
      ! Error: 2017-02-22 20:15:41.576 error at Requestor.doRequest (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:48:12)
      ! Error: 2017-02-22 20:15:41.576 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:49:22
      ! Error: 2017-02-22 20:15:41.576 error at Object.getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:171:20)
      ! Error: 2017-02-22 20:15:41.576 error at getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:161:13)
      ! Error: 2017-02-22 20:15:41.576 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:51:41
      ! Error: 2017-02-22 20:15:41.576 error at Object.startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:174:20)
      ! Error: 2017-02-22 20:15:41.576 error at startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:55:26)
      ! Error: 2017-02-22 20:15:41.576 error at Server.listen (net.js:1391:5)
      ! Error: 2017-02-22 20:15:41.576 error at listen (net.js:1295:10)
      ! Error: 2017-02-22 20:15:41.576 error at Server._listen2 (net.js:1259:14)
      ! Error: 2017-02-22 20:15:41.576 error at exports._exceptionWithHostPort (util.js:1045:20)
      ! Error: 2017-02-22 20:15:41.576 error at Object.exports._errnoException (util.js:1022:11)
      ! Error: 2017-02-22 20:15:41.576 error listen EADDRINUSE :::3000
      ! uncaught 2017-02-22 20:15:41.576 error exception: listen EADDRINUSE :::3000
      Grüße,
      Torsten
      • P
        P
        PArt
        #91
        Bei dir geht anscheinend die Authorisierung flöten!
        Der Fehler tritt im Moment auf, da der Auth-Service anscheinend mehrfach gestartet ist … Schau ich mir auf jeden Fall noch einmal an.
        Und nein, die Batterie kann man leider nicht auslesen, zumindest nicht, das ich wüsste
        • R
          R
          Rainer08
          #92
          Hallo PArt,
          ich habe aktuell das Problem, dass ich weder über die iobroker-Oberfläche noch über z.B. simple-api Werte auslesen kann.
          Im Log steht nichts (also wirklich leer) und der Adapter zeigt auch grün an.
          Lediglich in der Objekt-Darstellung wird der nicht mehr korrekte Werte rot dargestellt.
          Bsp: Temp. am Heizkörper steht auf 7 Grad und wird auch so angezeigt. Ändere ich die am Thermostat auf 9 Grad, wird in der Objekt-Darstellung der Wert 7 rot gargestellt.
          Ein Zugriff über simple-api liefert 7 Grad.
          Starte ich den Adapter neu, dann geht's wieder.
          Hast du eine Idee?
          • T
            T
            torstenh
            #93
            Hallo PArt,
            hier noch ein log:
            ! Error: 2017-02-27 07:51:27.981 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
            ! Error: 2017-02-27 07:51:27.981 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
            ! Error: 2017-02-27 07:51:27.981 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
            ! Error: 2017-02-27 07:51:27.981 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
            ! Error: 2017-02-27 07:51:27.981 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
            ! Error: 2017-02-27 07:51:27.981 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
            ! Error: 2017-02-27 07:51:27.981 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:84:17)
            ! Error: 2017-02-27 07:51:27.981 error at SmartHome._initialize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:293:12)
            ! Error: 2017-02-27 07:51:27.981 error at new Promise (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:77:14)
            ! Error: 2017-02-27 07:51:27.981 error at Promise._resolveFromExecutor (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:481:18)
            ! Error: 2017-02-27 07:51:27.981 error at Promise.cancellationExecute [as _execute] (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\debuggability.js:321:9)
            ! Error: 2017-02-27 07:51:27.981 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:294:25
            ! Error: 2017-02-27 07:51:27.981 error at Requestor.call (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:42:17)
            ! Error: 2017-02-27 07:51:27.981 error at Requestor.doRequest (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:48:12)
            ! Error: 2017-02-27 07:51:27.981 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:49:22
            ! Error: 2017-02-27 07:51:27.981 error at Object.getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:171:20)
            ! Error: 2017-02-27 07:51:27.981 error at getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:161:13)
            ! Error: 2017-02-27 07:51:27.981 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:51:41
            ! Error: 2017-02-27 07:51:27.981 error at Object.startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:174:20)
            ! Error: 2017-02-27 07:51:27.981 error at startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:55:26)
            ! Error: 2017-02-27 07:51:27.981 error at Server.listen (net.js:1391:5)
            ! Error: 2017-02-27 07:51:27.981 error at listen (net.js:1295:10)
            ! Error: 2017-02-27 07:51:27.981 error at Server._listen2 (net.js:1259:14)
            ! Error: 2017-02-27 07:51:27.981 error at exports._exceptionWithHostPort (util.js:1045:20)
            ! Error: 2017-02-27 07:51:27.981 error at Object.exports._errnoException (util.js:1022:11)
            ! Error: 2017-02-27 07:51:27.981 error listen EADDRINUSE :::3000
            ! uncaught 2017-02-27 07:51:27.981 error exception: listen EADDRINUSE :::3000
            Grüße,
            Torsten
            • P
              P
              PArt
              #94
              Hallo ihr zwei, danke für die Info…
              @Rainer, kannst du den Adapter bitte mal auf Debug stellen?
              Und Thorsten, den Fehler habe ich bis jetzt nur 1x gesehen ... Werde mir aber was einfallen lassen! Bei dir scheint aber die Authorisierung immer wieder flöten zu gehen!
              Sorry, bin gerade etwas beruflich sehr eingespannt und kann deshalb leider nicht so an dem Adapter arbeiten, wie ich das gerne würde
              • R
                R
                Rainer08
                #95
                Hallo PArt,
                ich muss jetzt mal kleinlaut fragen, wie ich den Adapter auf Debug stellen kann?
                • HomoranH
                  #96
                  Hallo Rainer,
                  im Reiter Instanzen, den Expertenmodus wählen und dann in der nun sichtbaren Spalte "Log Stufe" auf debug umschalten.
                  • T
                    T
                    torstenh
                    #97
                    Hallo PArt,
                    ist kein Problem, ich muß michjeden Tag neu anmelden aber das geht schon. Aufgefallen ist mir, das ich den Adapter neu starten muß und wenn ich ihn dann neu gestartet habe klappt die erste Anmeldung nicht. Wenn ich mich dann das zweite mal anmelde geht es wieder für einen Tag.
                    Grüße,
                    Torsten
                    • R
                      R
                      Rainer08
                      #98
                      Moin,
                      hier der Auszug aus dem Log.
                      Bei mir läuft stündlich ein Skript, dass einen Zustand des Innogy-Systems abfragt. Per Szenario wird dieser Zustand innerhalb des Innogy-Systems immer abwechselnd auf true/false gesetzt.
                      Seit 2 Uhr liefert meine Skript einen Fehler, d.h., dass der ausgelesen Wert nicht dem erwarteten entspricht.
                      Nach 1:36 Uhr wird aber auch nichts mehr ins Log geschrieben.
                      Der Adapter steht auf grün.
                      ! admin.0 2017-03-05 10:44:12.300 info Repository received successfully.
                      ! host.raspberrypi 2017-03-05 10:44:11.886 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                      ! admin.0 2017-03-05 10:44:11.749 info Request actual repository…
                      ! host.raspberrypi 2017-03-05 01:42:21.769 info Delete log file iobroker.2017-02-26.log
                      ! inMem 2017-03-05 01:36:19.354 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.PointTemperature val=21, ack=true, ts=1488674179331, q=0, from=system.adapter.innogy-smarthome.0, lc=1488646550554
                      ! inMem 2017-03-05 01:36:19.351 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.Humidity val=47, ack=true, ts=1488674179330, q=0, from=system.adapter.innogy-smarthome.0, lc=1488674179330
                      ! inMem 2017-03-05 01:36:19.349 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.Temperature val=21, ack=true, ts=1488674179329, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672652564
                      ! inMem 2017-03-05 01:36:19.347 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.MoldWarning val=false, ack=true, ts=1488674179328, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582820
                      ! inMem 2017-03-05 01:36:19.345 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.Humidity val=47.5, ack=true, ts=1488674179328, q=0, from=system.adapter.innogy-smarthome.0, lc=1488674179328
                      ! inMem 2017-03-05 01:36:19.341 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.FrostWarning val=false, ack=true, ts=1488674179327, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582819
                      ! inMem 2017-03-05 01:36:19.339 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.Temperature val=21, ack=true, ts=1488674179326, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672652561
                      ! inMem 2017-03-05 01:36:19.335 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.OperationMode val=Auto, ack=true, ts=1488674179324, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582818
                      ! inMem 2017-03-05 01:36:19.326 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.WindowReductionActive val=false, ack=true, ts=1488674179322, q=0, from=system.adapter.innogy-smarthome.0, lc=1488527386179
                      ! inMem 2017-03-05 01:36:19.319 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.PointTemperature val=21, ack=true, ts=1488674179312, q=0, from=system.adapter.innogy-smarthome.0, lc=1488646550543
                      ! inMem 2017-03-05 01:36:19.316 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:36:19.303Z, ack=true, ts=1488674179306, q=0, from=system.adapter.innogy-smarthome.0, lc=1488674179306
                      ! innogy-smarthome.0 2017-03-05 01:36:19.303 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:36:17.9520000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/6c32aea8710f5266de5bab9eb807dc24'},'Properties':[{'name':'Humidity','value':47.5,'lastchanged':'2017-03-05T00:36:17.9180000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:12:39.2710000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:36:17.9990000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/e6988f7bfbc8abc45e480691fa569ff8'},'Properties':[{'name':'Humidity','value':47,'lastchanged':'2017-03-05T00:36:17.9440000Z'}]}]}
                      ! inMem 2017-03-05 01:31:47.154 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.PointTemperature val=22.5, ack=true, ts=1488673907131, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635205938
                      ! inMem 2017-03-05 01:31:47.153 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Humidity val=42, ack=true, ts=1488673907131, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673907131
                      ! inMem 2017-03-05 01:31:47.151 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Temperature val=22.3, ack=true, ts=1488673907130, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276619
                      ! inMem 2017-03-05 01:31:47.150 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.MoldWarning val=false, ack=true, ts=1488673907130, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582853
                      ! inMem 2017-03-05 01:31:47.149 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Humidity val=42, ack=true, ts=1488673907130, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673907130
                      ! inMem 2017-03-05 01:31:47.148 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.FrostWarning val=false, ack=true, ts=1488673907130, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582852
                      ! inMem 2017-03-05 01:31:47.147 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Temperature val=22.3, ack=true, ts=1488673907129, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276616
                      ! inMem 2017-03-05 01:31:47.145 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.OperationMode val=Auto, ack=true, ts=1488673907129, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582849
                      ! inMem 2017-03-05 01:31:47.144 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.WindowReductionActive val=false, ack=true, ts=1488673907128, q=0, from=system.adapter.innogy-smarthome.0, lc=1488528340127
                      ! inMem 2017-03-05 01:31:47.142 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.PointTemperature val=22.5, ack=true, ts=1488673907128, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635210181
                      ! inMem 2017-03-05 01:31:47.127 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:31:47.114Z, ack=true, ts=1488673907123, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673907123
                      ! innogy-smarthome.0 2017-03-05 01:31:47.114 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:31:46.8840000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/328efd49ea3944eb3beee0eb068de246'},'Properties':[{'name':'Humidity','value':42,'lastchanged':'2017-03-05T00:31:46.8500000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:13:02.2090000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:31:46.9300000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/7bf0e30085748948eb98d504f7c7cee4'},'Properties':[{'name':'Humidity','value':42,'lastchanged':'2017-03-05T00:31:46.8760000Z'}]}]}
                      ! inMem 2017-03-05 01:30:24.175 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.Nina.PointTemperature val=12, ack=true, ts=1488673824154, q=0, from=system.adapter.innogy-smarthome.0, lc=1488661213855
                      ! inMem 2017-03-05 01:30:24.173 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.Nina.Humidity val=50, ack=true, ts=1488673824153, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673824153
                      ! inMem 2017-03-05 01:30:24.171 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.Nina.Temperature val=20.2, ack=true, ts=1488673824152, q=0, from=system.adapter.innogy-smarthome.0, lc=1488671290395
                      ! inMem 2017-03-05 01:30:24.168 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.OperationMode val=Auto, ack=true, ts=1488673824152, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582866
                      ! inMem 2017-03-05 01:30:24.166 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.WindowReductionActive val=false, ack=true, ts=1488673824151, q=0, from=system.adapter.innogy-smarthome.0, lc=1488653694967
                      ! inMem 2017-03-05 01:30:24.164 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.PointTemperature val=12, ack=true, ts=1488673824150, q=0, from=system.adapter.innogy-smarthome.0, lc=1488661213851
                      ! inMem 2017-03-05 01:30:24.162 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.FrostWarning val=false, ack=true, ts=1488673824149, q=0, from=system.adapter.innogy-smarthome.0, lc=1485593763604
                      ! inMem 2017-03-05 01:30:24.158 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.Temperature val=20.4, ack=true, ts=1488673824148, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276623
                      ! inMem 2017-03-05 01:30:24.150 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.MoldWarning val=false, ack=true, ts=1488673824143, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582865
                      ! inMem 2017-03-05 01:30:24.141 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.Humidity val=51.5, ack=true, ts=1488673824133, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673824133
                      ! inMem 2017-03-05 01:30:24.136 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:30:24.125Z, ack=true, ts=1488673824127, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673824127
                      ! innogy-smarthome.0 2017-03-05 01:30:24.125 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:30:23.1060000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/5ed33f6cafb9e68da7482e56570979d4'},'Properties':[{'name':'Humidity','value':51.5,'lastchanged':'2017-03-05T00:30:23.0690000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:12:30.0140000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:30:23.1550000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/817677b2b92cc801e099cabf8f441dc1'},'Properties':[{'name':'Humidity','value':50,'lastchanged':'2017-03-05T00:30:23.0980000Z'}]}]}
                      ! inMem 2017-03-05 01:27:26.219 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.PointTemperature val=22.5, ack=true, ts=1488673646191, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635205938
                      ! inMem 2017-03-05 01:27:26.218 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Humidity val=41, ack=true, ts=1488673646191, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673646191
                      ! inMem 2017-03-05 01:27:26.216 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Temperature val=22.3, ack=true, ts=1488673646190, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276619
                      ! inMem 2017-03-05 01:27:26.213 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.MoldWarning val=false, ack=true, ts=1488673646189, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582853
                      ! inMem 2017-03-05 01:27:26.211 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Humidity val=41.5, ack=true, ts=1488673646188, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673646188
                      ! inMem 2017-03-05 01:27:26.210 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.FrostWarning val=false, ack=true, ts=1488673646187, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582852
                      ! inMem 2017-03-05 01:27:26.207 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Temperature val=22.3, ack=true, ts=1488673646187, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276616
                      ! inMem 2017-03-05 01:27:26.205 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.OperationMode val=Auto, ack=true, ts=1488673646186, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582849
                      ! inMem 2017-03-05 01:27:26.203 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.WindowReductionActive val=false, ack=true, ts=1488673646185, q=0, from=system.adapter.innogy-smarthome.0, lc=1488528340127
                      ! inMem 2017-03-05 01:27:26.188 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.PointTemperature val=22.5, ack=true, ts=1488673646183, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635210181
                      ! inMem 2017-03-05 01:27:26.178 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:27:26.167Z, ack=true, ts=1488673646173, q=0, from=system.adapter.innogy-smarthome.0, lc=1488673646173
                      ! innogy-smarthome.0 2017-03-05 01:27:26.166 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:27:24.9060000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/328efd49ea3944eb3beee0eb068de246'},'Properties':[{'name':'Humidity','value':41.5,'lastchanged':'2017-03-05T00:27:24.8720000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:13:02.2090000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:27:25.0780000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/7bf0e30085748948eb98d504f7c7cee4'},'Properties':[{'name':'Humidity','value':41,'lastchanged':'2017-03-05T00:27:24.8980000Z'}]}]}
                      ! inMem 2017-03-05 01:15:42.712 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.MoldWarning val=false, ack=true, ts=1488672942684, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582825
                      ! inMem 2017-03-05 01:15:42.710 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.Humidity val=48.5, ack=true, ts=1488672942683, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672942683
                      ! inMem 2017-03-05 01:15:42.708 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.FrostWarning val=false, ack=true, ts=1488672942682, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582825
                      ! inMem 2017-03-05 01:15:42.706 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.Temperature val=20, ack=true, ts=1488672942681, q=0, from=system.adapter.innogy-smarthome.0, lc=1488671290392
                      ! inMem 2017-03-05 01:15:42.703 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.OperationMode val=Auto, ack=true, ts=1488672942680, q=0, from=system.adapter.innogy-smarthome.0, lc=1485601354016
                      ! inMem 2017-03-05 01:15:42.700 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.WindowReductionActive val=false, ack=true, ts=1488672942679, q=0, from=system.adapter.innogy-smarthome.0, lc=1488653695533
                      ! inMem 2017-03-05 01:15:42.680 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_rechts.PointTemperature val=12, ack=true, ts=1488672942675, q=0, from=system.adapter.innogy-smarthome.0, lc=1488661213857
                      ! inMem 2017-03-05 01:15:42.671 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:15:42.663Z, ack=true, ts=1488672942665, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672942665
                      ! innogy-smarthome.0 2017-03-05 01:15:42.662 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:15:41.8280000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/fedd25498c54d0091569dbedf9e15466'},'Properties':[{'name':'Humidity','value':48.5,'lastchanged':'2017-03-05T00:15:41.7970000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:13:40.4370000Z'}]}]}
                      ! inMem 2017-03-05 01:11:45.534 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.PointTemperature val=22.5, ack=true, ts=1488672705513, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635205938
                      ! inMem 2017-03-05 01:11:45.532 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Humidity val=42, ack=true, ts=1488672705512, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672705512
                      ! inMem 2017-03-05 01:11:45.530 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Temperature val=22.3, ack=true, ts=1488672705511, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276619
                      ! inMem 2017-03-05 01:11:45.527 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.MoldWarning val=false, ack=true, ts=1488672705510, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582853
                      ! inMem 2017-03-05 01:11:45.525 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Humidity val=42, ack=true, ts=1488672705509, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672705509
                      ! inMem 2017-03-05 01:11:45.523 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.FrostWarning val=false, ack=true, ts=1488672705509, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582852
                      ! inMem 2017-03-05 01:11:45.521 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Temperature val=22.3, ack=true, ts=1488672705508, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276616
                      ! inMem 2017-03-05 01:11:45.517 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.OperationMode val=Auto, ack=true, ts=1488672705507, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582849
                      ! inMem 2017-03-05 01:11:45.508 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.WindowReductionActive val=false, ack=true, ts=1488672705505, q=0, from=system.adapter.innogy-smarthome.0, lc=1488528340127
                      ! inMem 2017-03-05 01:11:45.501 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.PointTemperature val=22.5, ack=true, ts=1488672705495, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635210181
                      ! inMem 2017-03-05 01:11:45.498 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:11:45.487Z, ack=true, ts=1488672705489, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672705489
                      ! innogy-smarthome.0 2017-03-05 01:11:45.487 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:11:39.1310000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/328efd49ea3944eb3beee0eb068de246'},'Properties':[{'name':'Humidity','value':42,'lastchanged':'2017-03-05T00:11:39.0970000Z'},{'name':'MoldWarning','value':false,'lastchanged':'2017-02-23T12:13:02.2090000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:11:39.1770000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/7bf0e30085748948eb98d504f7c7cee4'},'Properties':[{'name':'Humidity','value':42,'lastchanged':'2017-03-05T00:11:39.1230000Z'}]}]}
                      ! inMem 2017-03-05 01:10:52.598 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.PointTemperature val=21, ack=true, ts=1488672652566, q=0, from=system.adapter.innogy-smarthome.0, lc=1488646550554
                      ! inMem 2017-03-05 01:10:52.596 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.Humidity val=48, ack=true, ts=1488672652565, q=0, from=system.adapter.innogy-smarthome.0, lc=1488670996832
                      ! inMem 2017-03-05 01:10:52.594 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.Gästebad.Temperature val=21, ack=true, ts=1488672652564, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672652564
                      ! inMem 2017-03-05 01:10:52.591 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.MoldWarning val=false, ack=true, ts=1488672652564, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582820
                      ! inMem 2017-03-05 01:10:52.589 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.Humidity val=48, ack=true, ts=1488672652563, q=0, from=system.adapter.innogy-smarthome.0, lc=1488671299151
                      ! inMem 2017-03-05 01:10:52.587 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.FrostWarning val=false, ack=true, ts=1488672652562, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582819
                      ! inMem 2017-03-05 01:10:52.585 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.Temperature val=21, ack=true, ts=1488672652561, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672652561
                      ! inMem 2017-03-05 01:10:52.581 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.OperationMode val=Auto, ack=true, ts=1488672652560, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582818
                      ! inMem 2017-03-05 01:10:52.561 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.WindowReductionActive val=false, ack=true, ts=1488672652555, q=0, from=system.adapter.innogy-smarthome.0, lc=1488527386179
                      ! inMem 2017-03-05 01:10:52.550 debug message innogy-smarthome.0.* innogy-smarthome.0.Gästebad.GB_Heizung.PointTemperature val=21, ack=true, ts=1488672652543, q=0, from=system.adapter.innogy-smarthome.0, lc=1488646550543
                      ! inMem 2017-03-05 01:10:52.546 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:10:52.535Z, ack=true, ts=1488672652537, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672652537
                      ! innogy-smarthome.0 2017-03-05 01:10:52.535 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:10:45.5140000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/625182c97f3102cd04aa68e64ee18fcb'},'Properties':[{'name':'Temperature','value':21,'lastchanged':'2017-03-05T00:10:45.4780000Z'},{'name':'FrostWarning','value':false,'lastchanged':'2017-02-23T12:12:39.2690000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:10:45.5600000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/f28e0cf80b02105385ea4bbebaf3c0cd'},'Properties':[{'name':'Temperature','value':21,'lastchanged':'2017-03-05T00:10:45.5060000Z'}]}]}
                      ! inMem 2017-03-05 01:04:36.662 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.OperationMode val=Auto, ack=true, ts=1488672276626, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582866
                      ! inMem 2017-03-05 01:04:36.660 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.WindowReductionActive val=false, ack=true, ts=1488672276625, q=0, from=system.adapter.innogy-smarthome.0, lc=1488653694967
                      ! inMem 2017-03-05 01:04:36.659 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.PointTemperature val=12, ack=true, ts=1488672276624, q=0, from=system.adapter.innogy-smarthome.0, lc=1488661213851
                      ! inMem 2017-03-05 01:04:36.658 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.FrostWarning val=false, ack=true, ts=1488672276624, q=0, from=system.adapter.innogy-smarthome.0, lc=1485593763604
                      ! inMem 2017-03-05 01:04:36.656 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.Temperature val=20.4, ack=true, ts=1488672276623, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276623
                      ! inMem 2017-03-05 01:04:36.653 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.MoldWarning val=false, ack=true, ts=1488672276622, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582865
                      ! inMem 2017-03-05 01:04:36.651 debug message innogy-smarthome.0.* innogy-smarthome.0.Nina.NI_HZ_links.Humidity val=51, ack=true, ts=1488672276622, q=0, from=system.adapter.innogy-smarthome.0, lc=1488669098496
                      ! inMem 2017-03-05 01:04:36.649 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.PointTemperature val=22.5, ack=true, ts=1488672276621, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635205938
                      ! inMem 2017-03-05 01:04:36.646 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Humidity val=41, ack=true, ts=1488672276620, q=0, from=system.adapter.innogy-smarthome.0, lc=1488661476783
                      ! inMem 2017-03-05 01:04:36.644 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.Wohnzimmerheizung.Temperature val=22.3, ack=true, ts=1488672276619, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276619
                      ! inMem 2017-03-05 01:04:36.642 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.MoldWarning val=false, ack=true, ts=1488672276619, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582853
                      ! inMem 2017-03-05 01:04:36.640 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Humidity val=41.5, ack=true, ts=1488672276618, q=0, from=system.adapter.innogy-smarthome.0, lc=1488670868315
                      ! inMem 2017-03-05 01:04:36.638 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.FrostWarning val=false, ack=true, ts=1488672276617, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582852
                      ! inMem 2017-03-05 01:04:36.636 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.Temperature val=22.3, ack=true, ts=1488672276616, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276616
                      ! inMem 2017-03-05 01:04:36.631 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.OperationMode val=Auto, ack=true, ts=1488672276615, q=0, from=system.adapter.innogy-smarthome.0, lc=1485100582849
                      ! inMem 2017-03-05 01:04:36.619 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.WindowReductionActive val=false, ack=true, ts=1488672276613, q=0, from=system.adapter.innogy-smarthome.0, lc=1488528340127
                      ! inMem 2017-03-05 01:04:36.607 debug message innogy-smarthome.0.* innogy-smarthome.0.Wohnzimmer.WZ_HZ.PointTemperature val=22.5, ack=true, ts=1488672276600, q=0, from=system.adapter.innogy-smarthome.0, lc=1488635210181
                      ! inMem 2017-03-05 01:04:36.604 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:04:36.590Z, ack=true, ts=1488672276591, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672276591
                      ! innogy-smarthome.0 2017-03-05 01:04:36.589 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:04:18.4750000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/126be0c70e2a04861e92c8406ddf08a7'},'Properties':[{'name':'Temperature','value':22.3,'lastchanged':'2017-03-05T00:04:18.4390000Z'},{'name':'FrostWarning','value':false,'lastchanged':'2017-02-23T12:13:02.2070000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:04:18.5200000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/fadf29cc44d5cfbf5cb9baf2430c8b7a'},'Properties':[{'name':'Temperature','value':22.3,'lastchanged':'2017-03-05T00:04:18.4660000Z'}]},{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:04:27.4680000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/01ac912207dd605e5ee521c461cb81e7'},'Properties':[{'name':'Temperature','value':20.4,'lastchanged':'2017-03-05T00:04:27.4350000Z'},{'name':'FrostWarning','value':false,'lastchanged':'2017-02-23T12:12:30.0320000Z'}]}]}
                      ! inMem 2017-03-05 01:00:06.987 debug message innogy-smarthome.0.* innogy-smarthome.0.Virtual.PI_Toggle.Value val=false, ack=true, ts=1488672006979, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672006979
                      ! inMem 2017-03-05 01:00:06.984 debug message innogy-smarthome.0.* innogy-smarthome.0.info.lastRealTimeEventReceived val=2017-03-05T00:00:06.973Z, ack=true, ts=1488672006975, q=0, from=system.adapter.innogy-smarthome.0, lc=1488672006975
                      ! innogy-smarthome.0 2017-03-05 01:00:06.972 debug DEBUG EVENT {'type':'realtime_update_received','data':[{'type':'device/SHC.RWE/1.0/event/StateChanged','timestamp':'2017-03-05T00:00:00.5290000Z','desc':'/desc/device/SHC.RWE/1.0/event/StateChanged','link':{'value':'/capability/54ff9fa8f0304b3ebb0a507de1cc1254'},'Properties':[{'name':'Value','value':false,'lastchanged':'2017-03-05T00:00:00.5190000Z'}]}]}
                      ! inMem 2017-03-05 00:58:04.771 debug message innogy-smarthome.0.* innogy-smarthome.0.Virtual.BA_Manu.Value val=true, ack=true, ts=1488671884767, q=0, from=system.adapter.innogy-smarthome.0, lc=1488671884767
                      ! inMem 2017-03-05 00:58:04.768 debug message innogy-smarthome.0.* innogy-smarthome.0.Virtual.BA_Manu.Value val=false, ack=true, ts=1488671884764, q=0, from=system.adapter.innogy-smarthome.0, lc=1488671884764
                      • P
                        P
                        PArt
                        #99
                        Hallo Rainer,
                        das ist natürlich eine sehr gute Idee, das baue ich mir auch einmal nach!!
                        Vielleicht kommen wir dem ganzen so auf die schliche … Das Problem ist, in dem Log steht nichts davon, das sich der Adapter trennt ... Ich vermute, das einfach keine Events mehr kommen, da irgend etwas abgelaufen ist! Ich werde mal eine reihe weiterer Debug Events einbauen und sehen, ob ich das auch reproduziert bekomme! Danke für den Input! Vielleicht lassen sich auch so Thorstens abmeldeprobleme lösen!
                        • R
                          R
                          Rainer08
                          #100
                          Bei mir wird zur vollen Stunden der Zustand verändert.
                          Zu geraden Stunden auf "true", zu ungeraden auf "false".
                          Damit ist die Logik in meinem Skript simpel: Akt. Stunde gerade, dann sollte der Zustand auf "true" stehen.
                          Da die Innogy-Basis immer etwas länger braucht, läuft mein Skript immer zwei Minuten nach der vollen Stunde.
                          • T
                            T
                            torstenh
                            #101
                            ich erkläre mal meinen Zustand:
                            Adapter auf gelb, wenn ich mich dann neu anmelde ob mit Neustart des Adapter oder STOP-START des Adapters kommt keine Anmeldung zu stande. Erst wenn ich mich das zweite mal anmelde funktioniert es und der Adapter wird grün.
                            Grüße,
                            Torsten
                            • P
                              P
                              PArt
                              #102
                              Ich habe auf GitHub eine Debugversion erstellt, wäre super, wenn ihr die mal testen könntet. Zusätzlich habe ich ein Problem im Websocket Client gefunden und hoffentlich einen funktionierenden Workaround eingebaut…
                              Das Problem scheint beim Zwangsdisconnect aufzutreten (vermute ich zumindest), den es ja bei einigen Internetprovidern gibt. Da ich so etwas nicht habe, ist mir das noch nie aufgefallen :( Sorry hierfür!
                              Versucht einmal die Version bei euch... Bin gespannt, ob sich Besserung einstellt.
                              Wie gesagt, der Adapter muss von GitHub installiert werden (schwarzes Katzensymbol in der Adapter-Ansicht, dann den innogy Adapter wählen und updaten)
                              • R
                                R
                                Rainer08
                                #103
                                bei mir läuft die akt. Version leider nicht
                                ! Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                                ! raspberrypi 2017-03-05 19:02:10.004 info host.raspberrypi Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! raspberrypi 2017-03-05 19:02:10.003 error host.raspberrypi instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:02:09.772 info innogy-smarthome.0 starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! host.raspberrypi 2017-03-05 19:02:08.321 info instance system.adapter.innogy-smarthome.0 started with pid 24640
                                ! host.raspberrypi 2017-03-05 19:02:01.389 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:02:01.389 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:02:01.376 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:02:01.142 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:02:01.112 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:02:01.052 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:02:00.869 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:02:00.848 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:59.693 info instance system.adapter.innogy-smarthome.0 started with pid 24589
                                ! host.raspberrypi 2017-03-05 19:01:49.372 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:01:49.372 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:01:49.357 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:01:49.140 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:01:49.092 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:49.037 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:01:48.850 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:01:48.829 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:47.682 info instance system.adapter.innogy-smarthome.0 started with pid 24580
                                ! host.raspberrypi 2017-03-05 19:01:38.292 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:01:38.292 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:01:38.277 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:01:38.053 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:01:38.003 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:37.947 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:01:37.768 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:01:37.748 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:36.608 info instance system.adapter.innogy-smarthome.0 started with pid 24571
                                ! host.raspberrypi 2017-03-05 19:01:29.657 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:01:29.656 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.641 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:01:29.412 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:01:29.376 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:29.314 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:01:29.134 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:01:29.113 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:27.932 info instance system.adapter.innogy-smarthome.0 started with pid 24562
                                ! host.raspberrypi 2017-03-05 19:01:17.660 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:01:17.659 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.640 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:01:17.407 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:01:17.376 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:17.317 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:01:17.133 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:01:17.113 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:15.933 info instance system.adapter.innogy-smarthome.0 started with pid 24553
                                ! host.raspberrypi 2017-03-05 19:01:06.574 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:01:06.573 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.558 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:01:06.321 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:01:06.289 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:06.230 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:01:06.052 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:01:06.031 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:01:04.891 info instance system.adapter.innogy-smarthome.0 started with pid 24543
                                ! host.raspberrypi 2017-03-05 19:00:57.897 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:00:57.896 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.881 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:00:57.641 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:00:57.611 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:57.551 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:00:57.373 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:00:57.353 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:00:56.231 info instance system.adapter.innogy-smarthome.0 started with pid 24534
                                ! host.raspberrypi 2017-03-05 19:00:45.914 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:00:45.913 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.898 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:00:45.662 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:00:45.630 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:45.572 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:00:45.391 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:00:45.371 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:00:44.227 info instance system.adapter.innogy-smarthome.0 started with pid 24525
                                ! host.raspberrypi 2017-03-05 19:00:44.209 info object change system.adapter.innogy-smarthome.0
                                ! host.raspberrypi 2017-03-05 19:00:39.474 info object change system.adapter.innogy-smarthome.0
                                ! host.raspberrypi 2017-03-05 19:00:34.856 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:00:34.855 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.842 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:00:34.617 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:00:34.568 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:34.515 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:00:34.335 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:00:34.314 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:00:33.158 info instance system.adapter.innogy-smarthome.0 started with pid 24516
                                ! host.raspberrypi 2017-03-05 19:00:26.211 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:00:26.211 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:00:26.197 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:00:25.975 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:00:25.925 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:25.872 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:00:25.690 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:00:25.670 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:00:24.510 info instance system.adapter.innogy-smarthome.0 started with pid 24507
                                ! host.raspberrypi 2017-03-05 19:00:03.127 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 19:00:03.125 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 19:00:03.110 info terminating
                                ! innogy-smarthome.0 2017-03-05 19:00:02.901 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 19:00:02.843 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:02.786 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 19:00:02.601 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 19:00:02.580 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 19:00:01.318 info instance system.adapter.innogy-smarthome.0 started with pid 24479
                                ! host.raspberrypi 2017-03-05 18:59:54.499 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:59:54.498 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:59:54.485 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:59:54.256 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:59:54.220 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:54.164 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:59:53.977 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:59:53.956 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:59:52.798 info instance system.adapter.innogy-smarthome.0 started with pid 24441
                                ! host.raspberrypi 2017-03-05 18:59:31.283 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:59:31.282 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:59:31.269 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:59:31.030 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:59:30.998 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:30.941 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:59:30.762 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:59:30.741 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:59:29.592 info instance system.adapter.innogy-smarthome.0 started with pid 24432
                                ! host.raspberrypi 2017-03-05 18:59:22.775 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:59:22.774 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.760 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:59:22.523 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:59:22.491 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:22.433 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:59:22.252 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:59:22.232 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:59:21.078 info instance system.adapter.innogy-smarthome.0 started with pid 24423
                                ! host.raspberrypi 2017-03-05 18:58:59.550 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:58:59.549 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.533 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:58:59.293 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:58:59.261 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:59.204 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:58:59.025 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:58:59.005 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:58:57.820 info instance system.adapter.innogy-smarthome.0 started with pid 24414
                                ! host.raspberrypi 2017-03-05 18:58:51.055 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:58:51.055 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:58:51.038 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:58:50.802 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:58:50.771 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:50.714 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:58:50.531 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:58:50.510 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:58:49.326 info instance system.adapter.innogy-smarthome.0 started with pid 24405
                                ! host.raspberrypi 2017-03-05 18:58:49.306 info object change system.adapter.innogy-smarthome.0
                                ! host.raspberrypi 2017-03-05 18:58:46.895 info object change system.adapter.innogy-smarthome.0
                                ! host.raspberrypi 2017-03-05 18:58:27.799 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:58:27.798 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.784 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:58:27.544 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:58:27.511 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:27.454 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:58:27.275 error TypeError: this is not a typed array.
                                ! innogy-smarthome.0 2017-03-05 18:58:27.255 error uncaught exception: this is not a typed array.
                                ! host.raspberrypi 2017-03-05 18:58:26.102 info instance system.adapter.innogy-smarthome.0 started with pid 24396
                                ! host.raspberrypi 2017-03-05 18:57:56.079 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                ! host.raspberrypi 2017-03-05 18:57:56.079 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                ! innogy-smarthome.0 2017-03-05 18:57:56.063 info terminating
                                ! innogy-smarthome.0 2017-03-05 18:57:55.825 info starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v4.3.2
                                ! innogy-smarthome.0 2017-03-05 18:57:55.795 debug statesDB connected
                                ! innogy-smarthome.0 2017-03-05 18:57:55.738 debug objectDB connected
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Module._compile (module.js:409:26)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/WebSocket.js:16:27)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at require (internal/module.js:12:17)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Module.require (module.js:353:17)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Function.Module._load (module.js:300:12)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Module.load (module.js:343:32)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Object.Module._extensions..js (module.js:416:10)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Object. (/opt/iobroker/node_modules/iobroker.innogy-smarthome/node_modules/innogy-smarthome-lib/node_modules/ws/lib/PerMessageDeflate.js:8:24)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error at Function.from (native)
                                ! innogy-smarthome.0 2017-03-05 18:57:55.554 error TypeError: this is not a typed array.
                                • P
                                  P
                                  PArt
                                  #104
                                  Das liegt an deiner Node Version! Aktualisiere diese bitte mal auf mind. 4.5
                                  Die von dir verwendete 4.3er Version ist schon etwas älter
                                  ` > curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
                                  sudo apt-get install -y nodejs oder am besten direkt auf Node 6 > curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                                  sudo apt-get install -y nodejs `
                                  Sollte das alles nicht funktionieren, muss ich die veraltete WebSocket Version verwenden, welche ich eigentlich gerne mit dem nächsten Update ersetzen würde. Welche Distro verwendest du? Mich wundert es eh, das z.B. Rasperian noch nicht die aktuelle Version verwendet. Ich bin aus diesem Grund und vor allem wegen der Performance irgendwann von meinem Raspberry auf einen Gigabyte Brix und Ubuntu Server umgestiegen
                                  • P
                                    P
                                    PArt
                                    #105
                                    Und wieder eine neue Version auf GitHub, die ersten Änderungen scheinen bereits gefruchtet zu haben …
                                    • T
                                      T
                                      torstenh
                                      #106
                                      Hallo PArt,
                                      neue Version installiert. Die Vermutung des Zwangsdisconect liegt sehr nah. Da der disconect des Adapters bei mir immer um die Zeit kam. Hätte ich ja auch mal posten können :roll:
                                      Nach dem Update kam:
                                      ! innogy-smarthome.0 2017-03-06 04:58:01.465 info OPEN
                                      ! innogy-smarthome.0 2017-03-06 04:57:57.316 info starting. Version 0.1.14 in C:/ioBroker/node_modules/iobroker.innogy-smarthome
                                      ! innogy-smarthome.0 2017-03-06 04:57:56.972 error no connection to objects DB
                                      ! host.POETNITZ15 2017-03-06 04:57:43.962 info instance system.adapter.innogy-smarthome.0 started with pid 6108
                                      ! host.POETNITZ15 2017-03-06 04:57:13.917 info Restart adapter system.adapter.innogy-smarthome.0 because enabled
                                      ! host.POETNITZ15 2017-03-06 04:57:13.917 error instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
                                      ! innogy-smarthome.0 2017-03-06 04:57:13.869 info cleaned everything up…
                                      ! Error: 2017-03-06 04:57:13.869 error at Promise._settlePromises (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:700:14)
                                      ! Error: 2017-03-06 04:57:13.869 error at Promise._settlePromiseAt (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\promise.js:582:21)
                                      ! Error: 2017-03-06 04:57:13.869 error at Promise.successAdapter (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\nodeify.js:23:30)
                                      ! Error: 2017-03-06 04:57:13.869 error at tryCatcher (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\simple-oauth2\node_modules\bluebird\js\main\util.js:26:23)
                                      ! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:43:17
                                      ! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\main.js:35:31
                                      ! Error: 2017-03-06 04:57:13.869 error at SmartHome.init (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:84:17)
                                      ! Error: 2017-03-06 04:57:13.869 error at SmartHome._initialize (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:293:12)
                                      ! Error: 2017-03-06 04:57:13.869 error at new Promise (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:77:14)
                                      ! Error: 2017-03-06 04:57:13.869 error at Promise._resolveFromExecutor (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\promise.js:481:18)
                                      ! Error: 2017-03-06 04:57:13.869 error at Promise.cancellationExecute [as _execute] (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\bluebird\js\release\debuggability.js:321:9)
                                      ! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\smarthome\index.js:294:25
                                      ! Error: 2017-03-06 04:57:13.869 error at Requestor.call (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:42:17)
                                      ! Error: 2017-03-06 04:57:13.869 error at Requestor.doRequest (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:48:12)
                                      ! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:49:22
                                      ! Error: 2017-03-06 04:57:13.869 error at Object.getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:171:20)
                                      ! Error: 2017-03-06 04:57:13.869 error at getAuthorizationStatus (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:161:13)
                                      ! Error: 2017-03-06 04:57:13.869 error at C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\requestor\index.js:51:41
                                      ! Error: 2017-03-06 04:57:13.869 error at Object.startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:174:20)
                                      ! Error: 2017-03-06 04:57:13.869 error at startAuthorization (C:\ioBroker\node_modules\iobroker.innogy-smarthome\node_modules\innogy-smarthome-lib\lib\oauth2\index.js:55:26)
                                      ! Error: 2017-03-06 04:57:13.869 error at Server.listen (net.js:1391:5)
                                      ! Error: 2017-03-06 04:57:13.869 error at listen (net.js:1295:10)
                                      ! Error: 2017-03-06 04:57:13.869 error at Server._listen2 (net.js:1259:14)
                                      ! Error: 2017-03-06 04:57:13.869 error at exports._exceptionWithHostPort (util.js:1045:20)
                                      ! Error: 2017-03-06 04:57:13.869 error at Object.exports._errnoException (util.js:1022:11)
                                      ! Error: 2017-03-06 04:57:13.869 error listen EADDRINUSE :::3000
                                      ! uncaught 2017-03-06 04:57:13.869 error exception: listen EADDRINUSE :::3000
                                      ! innogy-smarthome.0 2017-03-06 04:57:13.822 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
                                      ! innogy-smarthome.0 2017-03-06 04:53:44.096 warn Adapter is not configured or needs reauthorization! Please go to the adapter settings and start the authorization
                                      ! host.POETNITZ15 2017-03-06 04:53:23.629 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                      ! iobroker 2017-03-06 04:53:22.662 info exit 0
                                      ! iobroker 2017-03-06 04:53:22.475 info upload [0] innogy-smarthome.admin C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin/index.html index.html text/html
                                      ! iobroker 2017-03-06 04:53:22.335 info upload [1] innogy-smarthome.admin C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin/innogy-smarthome.png innogy-smarthome.png image/png
                                      ! iobroker 2017-03-06 04:53:22.288 info got C:/ioBroker/node_modules/iobroker.innogy-smarthome/admin
                                      ! iobroker 2017-03-06 04:52:09.934 info npm install https://github.com/PArns/ioBroker.innog … all/master --production --prefix "C:/ioBroker" (System call)
                                      ! iobroker 2017-03-06 04:52:09.357 info install https://github.com/PArns/ioBroker.innog ... all/master
                                      ! iobroker 2017-03-06 04:52:06.845 info url "https://github.com/PArns/ioBroker.innog ... all/master" innogy-smarthome
                                      Aber Adapter ist jetzt grün und alles gut! Mal sehen wie es morgen ausschaut!
                                      Grüße,
                                      Torsten
                                      • P
                                        P
                                        PArt
                                        #107
                                        Danke für die Info, bei dir kackt halt immer wieder die Authorisierung ab, kannst du die Kiste mal komplett neu starten?
                                        Wie gesagt, schaue ich mir aber auf jeden Fall noch mal an
                                        • P
                                          P
                                          PArt
                                          #108
                                          Hm, ok bei mir scheint es jetzt auch ein Problem beim Reconnecten zu geben … Hmpf, super das man das so toll debuggen kann!
                                          Jungs, das muss ich mir erst selbst und mit ruhe anschauen ... So ein mist!
                                          84.2k
