  4. Probleme TI Stick und Zigbee nach Neuinstallation
    5.5k
6 Beiträge 2 Kommentatoren 360 Aufrufe 2 Beobachtet
    toki1973
    Hallo, ich habe eine neue VM parallel zur existierenden Proxmox VM aufgebaut und io broker installiert und die Backups iobroker und Zigbee eingespielt.
    Von den Objekten sieht alles soweit gut aus. Nur den TI-Stick bekomme ich nicht in Betrieb genommen. Ich habe in Proxmox wie hier abgebildet installiert:efe3fff7-70f5-4990-b9f0-fd269ec6223c-image.png
    Beim starten des Zigbee Adapter bekomme ich folgendes Log:
    zigbee.0
    2021-11-19 12:13:06.726	error	Error herdsman start
    zigbee.0
    2021-11-19 12:13:06.726	error	Failed to start Zigbee
    zigbee.0
    2021-11-19 12:13:06.725	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-11-19 12:13:06.604	info	Installed Version: iobroker.zigbee@1.6.6
    zigbee.0
    2021-11-19 12:13:06.584	debug	Starting zigbee-herdsman...
    zigbee.0
    2021-11-19 12:13:06.583	info	Starting Zigbee npm ...
    zigbee.0
    2021-11-19 12:13:06.582	info	Try to reconnect. 1 attempts left
    zigbee.0
    2021-11-19 12:12:56.580	error	Error herdsman start
    zigbee.0
    2021-11-19 12:12:56.580	error	Failed to start Zigbee
    zigbee.0
    2021-11-19 12:12:56.579	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2021-11-19 12:12:36.620	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_19-12_12_36.tar.gz success
    zigbee.0
    2021-11-19 12:12:36.613	info	Installed Version: iobroker.zigbee@1.6.6
    zigbee.0
    2021-11-19 12:12:36.072	debug	Starting zigbee-herdsman...
    zigbee.0
    2021-11-19 12:12:36.071	info	Starting Zigbee npm ...
    zigbee.0
    2021-11-19 12:12:36.028	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[15],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM1","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
    zigbee.0
    2021-11-19 12:12:35.995	info	starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.19
    zigbee.0
    2021-11-19 12:12:35.986	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    zigbee.0
    2021-11-19 12:12:35.983	debug	Plugin sentry Initialize Plugin (enabled=true)
    Einstellungen im Adapter sind wie folgt:
    Die alte VM befindet sich im Pause Modus uns sollte somit den Port freigeben.
    Was kann ich denn noch prüfen?
    Danke!
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Danke!
      crunchipC Offline
      crunchipC Offline
      @toki1973 sagte in Probleme TI Stick und Zigbee nach Neuinstallation:
      mach es mit der Geräte ID und nicht per Port
        toki1973
        schrieb am zuletzt editiert von toki1973
        @crunchip Danke für die Rückmeldung. Du meinst in Proxmox mit der Vendor ID. Das hatte ich probiert.
        Ich habe gerade mal einen Cold-boot des NUCs durchgeführt. Nun läuft der Zigbee-Adapter. :)
        Noch eine Frage. Wie kann ich denn der neuen VM die IP der alten VM vergeben, damit ich meine mqqt Endpunkte und alles andere nicht ändern muss? Bei einem Container geht das glaube ich ganz einfach - ich habe aber eine VM.
        • T toki1973
          crunchipC Offline
          crunchipC Offline
          ja, denn der Port kann nach einem Reboot eventuell wechseln, daher immer per Geräte ID einbinden
          kannst/solltest du auf statisch stellen, mittels
          sudo nano /etc/network/interfaces
          auf deiner VM aufrufen
          sieht dann in etwa so aus
          anschliesend ein reboot deiner VM
            toki1973
            @crunchip
            Super und vielen Dank - das hat auch geklappt.
            Nur wenn ich die VIS starte bekomme ich nun diesen Fehler:
            URIError: Failed to decode param '%web_protocol%://192.168.0.193:%web_port%/vis/edit.html'
                at decodeURIComponent (<anonymous>)
                at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
                at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
                at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:574:18)
                at next (/opt/iobroker/node_modules/express/lib/router/index.js:220:15)
                at expressInit (/opt/iobroker/node_modules/express/lib/middleware/init.js:40:5)
                at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:317:13)
                at /opt/iobroker/node_modules/express/lib/router/index.js:284:7
                at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:335:12)
            • T toki1973
              @crunchip
              toki1973
              Der WebServer hatte irgendwein Problem. Nach iobroker upload all läuft er nun wieder
