  4. (gelöst) Alexa Adapter rot
    2.0k
15 Beiträge 3 Kommentatoren 1.1k Aufrufe 2 Beobachtet
    arnold
    schrieb am zuletzt editiert von arnold
    2021-11-16 00:04:26.002  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 24276
    2021-11-16 00:04:26.530  - error: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
    2021-11-16 00:04:26.530  - error: host.raspberrypi4-iob Caught by controller[0]:   throw err;
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:   ^
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: Require stack:
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:1:16)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]: }
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-11-16 00:04:26.533  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
    eine Version drunter ,reboot usw. hilft nicht
    backitup auf Tage wo es noch funktioniert hat hilft auch nicht !!!
    • A arnold
      @arnold
      dmesg -T | grep -i ext4
      iobroker update -i
      iobroker status
      iobroker list adapters
      iobroker list instances
      iobroker stop
      iobroker fix
      iobroker start
      Und weil es so grundlegend ist:
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      OstfrieseUnterwegsO 1 Antwort Letzte Antwort
        @arnold
        iobroker update -i
        iobroker status
        iobroker stop
        iobroker fix
        iobroker start
        OstfrieseUnterwegsO Offline
        OstfrieseUnterwegs
        @thomas-braun sagte in Alexa Adapter rot:
        OT: Warum machst Du zwei mal nacheinander apt update ?
        Thomas BraunT A 2 Antworten Letzte Antwort
        • OstfrieseUnterwegsO OstfrieseUnterwegs
          @ostfrieseunterwegs
          Weil im zweiten Durchlauf nur die zuvor bereits aktualisierten Repos kompakt angezeigt werden.
            arnold
            @ostfrieseunterwegs said in Alexa Adapter rot:
            pi@raspberrypi4-iob:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/node
            /usr/bin/npm
            : admin
              system.adapter.alexa2.0                 : alexa2                : raspberrypi4
            system.adapter.alexa2                  : alexa2         - v3.11.2
            pi@raspberrypi4-iob:~ $ iobroker status
            leider immer noch rot
            • A arnold
              /usr/bin/node
              /usr/bin/npm
              : admin
              @arnold
              Bitte nix kürzen, vollständige Ein- wie Ausgaben posten.
                @arnold
                arnold
                @thomas-braun said in Alexa Adapter rot:
                pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.7
                v12.22.7
                6.14.15
                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                OK:4 https://repos.influxdata.com/debian buster InRelease
                Es wurden 15,0 kB in 1 s geholt (10,2 kB/s).
                Aktualisierung für 137 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,        um sie anzuzeigen.
                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:3 https://repos.influxdata.com/debian buster InRelease
                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                nodejs:
                  Installiert:           12.22.7-deb-1nodesource1
                  Installationskandidat: 12.22.7-deb-1nodesource1
                  Versionstabelle:
                 *** 12.22.7-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u1 500
                code_text
                • Thomas BraunT Online
                  @arnold sagte in Alexa Adapter rot:
                  nodeJS passt, allerdings solltest du dein Betriebssystem auch aktuell halten.
                  iobroker stop
                  sudo apt dist-upgrade
                  sudo reboot
                    arnold
                    hallo
                    bis jetzt alle Tipps von oben gemacht aber Adapter bleibt rot .
                    Vielleicht Cookie löschen und neu oder alexa Adapter löschen ?
                    komisch nur das schalten mit alexa funktioniert Lampen, Abfragen, Sauger usw.
                    • A arnold
                      hallo
                      @arnold Am Adapter ist ja auch noch gar nichts gemacht worden.
                      In der Konsole wird jetzt was gemeldet, wenn die Instanz neugestartet wird?
                        arnold
                        2021-11-18 01:05:33.862  - error: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
                        2021-11-18 01:05:33.863  - error: host.raspberrypi4-iob Caught by controller[0]:   throw err;
                        2021-11-18 01:05:33.863  - error: host.raspberrypi4-iob Caught by controller[0]:   ^
                        2021-11-18 01:05:33.864  - error: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
                        2021-11-18 01:05:33.864  - error: host.raspberrypi4-iob Caught by controller[0]: Require stack:
                        2021-11-18 01:05:33.865  - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                        2021-11-18 01:05:33.865  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                        2021-11-18 01:05:33.866  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                        2021-11-18 01:05:33.866  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
                        2021-11-18 01:05:33.867  - error: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
                        2021-11-18 01:05:33.867  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:9:15)
                        2021-11-18 01:05:33.868  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
                        2021-11-18 01:05:33.868  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                        2021-11-18 01:05:33.869  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
                        2021-11-18 01:05:33.869  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                        2021-11-18 01:05:33.870  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
                        2021-11-18 01:05:33.871  - error: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2021-11-18 01:05:33.871  - error: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
                        2021-11-18 01:05:33.872  - error: host.raspberrypi4-iob Caught by controller[0]: }
                        2021-11-18 01:05:33.873  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-11-18 01:05:33.874  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
                        • A arnold
                          @arnold
                          Installier den Adapter nochmal neu.
                            arnold
                            nur alexa adapter löschen
                            das reicht oder gibst da noch Restbestände ?
                            • A arnold
                              @arnold Zunächst reicht das.
                              Am besten über die Konsole, da gibt es ggf. bessere Meldungen.
                              iobroker del alexa2
                              iobroker update
                              iobroker add alexa2
                              Auf einem einfach System ohne Multihost usw.
                                arnold
                                iobroker add alexa2
                                Das wahr die Lösung (+ You can try to get the cookie manually by opening http://192.168.178/ with your browser.)
                                super danke
                                83.1k
