  4. (gelöst) Alexa Adapter rot
    6.3k
15 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • A Online
    A Online
    arnold
    schrieb am zuletzt editiert von arnold
    2021-11-16 00:04:26.002  - info: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 24276
    2021-11-16 00:04:26.530  - error: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
    2021-11-16 00:04:26.530  - error: host.raspberrypi4-iob Caught by controller[0]:   throw err;
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:   ^
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: Require stack:
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    2021-11-16 00:04:26.531  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:1:16)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-11-16 00:04:26.532  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob Caught by controller[0]: }
    2021-11-16 00:04:26.533  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-11-16 00:04:26.533  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
    eine Version drunter ,reboot usw. hilft nicht
    backitup auf Tage wo es noch funktioniert hat hilft auch nicht !!!
    • A arnold
      @arnold
      dmesg -T | grep -i ext4
      iobroker update -i
      iobroker status
      iobroker list adapters
      iobroker list instances
      iobroker stop
      iobroker fix
      iobroker start
      Und weil es so grundlegend ist:
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      OstfrieseUnterwegsO 1 Antwort Letzte Antwort
        @arnold
        iobroker update -i
        iobroker status
        iobroker stop
        iobroker fix
        iobroker start
        OstfrieseUnterwegsO Offline
        OstfrieseUnterwegs
        @thomas-braun sagte in Alexa Adapter rot:
        OT: Warum machst Du zwei mal nacheinander apt update ?
        Thomas BraunT A 2 Antworten Letzte Antwort
        • OstfrieseUnterwegsO OstfrieseUnterwegs
          @ostfrieseunterwegs
          Weil im zweiten Durchlauf nur die zuvor bereits aktualisierten Repos kompakt angezeigt werden.
            A Online
            A Online
            arnold
            @ostfrieseunterwegs said in Alexa Adapter rot:
            pi@raspberrypi4-iob:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/node
            /usr/bin/npm
            : admin
              system.adapter.alexa2.0                 : alexa2                : raspberrypi4
            system.adapter.alexa2                  : alexa2         - v3.11.2
            pi@raspberrypi4-iob:~ $ iobroker status
            leider immer noch rot
            • A arnold
              /usr/bin/node
              /usr/bin/npm
              : admin
              @arnold
              Bitte nix kürzen, vollständige Ein- wie Ausgaben posten.
                @arnold
                A Online
                A Online
                arnold
                @thomas-braun said in Alexa Adapter rot:
                pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.7
                v12.22.7
                6.14.15
                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                OK:4 https://repos.influxdata.com/debian buster InRelease
                Es wurden 15,0 kB in 1 s geholt (10,2 kB/s).
                Aktualisierung für 137 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,        um sie anzuzeigen.
                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:3 https://repos.influxdata.com/debian buster InRelease
                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                nodejs:
                  Installiert:           12.22.7-deb-1nodesource1
                  Installationskandidat: 12.22.7-deb-1nodesource1
                  Versionstabelle:
                 *** 12.22.7-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u1 500
                code_text
                • Thomas BraunT Online
                  @arnold sagte in Alexa Adapter rot:
                  nodeJS passt, allerdings solltest du dein Betriebssystem auch aktuell halten.
                  iobroker stop
                  sudo apt dist-upgrade
                  sudo reboot
                  • A Online
                    A Online
                    arnold
                    hallo
                    bis jetzt alle Tipps von oben gemacht aber Adapter bleibt rot .
                    Vielleicht Cookie löschen und neu oder alexa Adapter löschen ?
                    komisch nur das schalten mit alexa funktioniert Lampen, Abfragen, Sauger usw.
                    • A arnold
                      hallo
                      @arnold Am Adapter ist ja auch noch gar nichts gemacht worden.
                      In der Konsole wird jetzt was gemeldet, wenn die Instanz neugestartet wird?
                      • A Online
                        A Online
                        arnold
                        2021-11-18 01:05:33.862  - error: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
                        2021-11-18 01:05:33.863  - error: host.raspberrypi4-iob Caught by controller[0]:   throw err;
                        2021-11-18 01:05:33.863  - error: host.raspberrypi4-iob Caught by controller[0]:   ^
                        2021-11-18 01:05:33.864  - error: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
                        2021-11-18 01:05:33.864  - error: host.raspberrypi4-iob Caught by controller[0]: Require stack:
                        2021-11-18 01:05:33.865  - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                        2021-11-18 01:05:33.865  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                        2021-11-18 01:05:33.866  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                        2021-11-18 01:05:33.866  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
                        2021-11-18 01:05:33.867  - error: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
                        2021-11-18 01:05:33.867  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/main.js:9:15)
                        2021-11-18 01:05:33.868  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
                        2021-11-18 01:05:33.868  - error: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                        2021-11-18 01:05:33.869  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
                        2021-11-18 01:05:33.869  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                        2021-11-18 01:05:33.870  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
                        2021-11-18 01:05:33.871  - error: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2021-11-18 01:05:33.871  - error: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
                        2021-11-18 01:05:33.872  - error: host.raspberrypi4-iob Caught by controller[0]: }
                        2021-11-18 01:05:33.873  - error: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-11-18 01:05:33.874  - info: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
                        • A arnold
                          @arnold
                          Installier den Adapter nochmal neu.
                          • A Online
                            A Online
                            arnold
                            nur alexa adapter löschen
                            das reicht oder gibst da noch Restbestände ?
                            • A arnold
                              @arnold Zunächst reicht das.
                              Am besten über die Konsole, da gibt es ggf. bessere Meldungen.
                              iobroker del alexa2
                              iobroker update
                              iobroker add alexa2
                              Auf einem einfach System ohne Multihost usw.
                              • A Online
                                A Online
                                arnold
                                iobroker add alexa2
                                Das wahr die Lösung (+ You can try to get the cookie manually by opening http://192.168.178/ with your browser.)
                                super danke
