<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(gelöst) Alexa Adapter rot]]></title><description><![CDATA[<pre><code>2021-11-16 00:04:26.002  - [32minfo[39m: host.raspberrypi4-iob instance system.adapter.alexa2.0 started with pid 24276
2021-11-16 00:04:26.530  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
2021-11-16 00:04:26.530  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   throw err;
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   ^
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: Require stack:
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
2021-11-16 00:04:26.531  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.alexa2/main.js:1:16)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
2021-11-16 00:04:26.532  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
2021-11-16 00:04:26.533  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
2021-11-16 00:04:26.533  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
2021-11-16 00:04:26.533  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
2021-11-16 00:04:26.533  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: }
2021-11-16 00:04:26.533  - [31merror[39m: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2021-11-16 00:04:26.533  - [32minfo[39m: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
</code></pre>
<p dir="auto"><img src="/assets/uploads/files/1637060181951-27fad870-9a12-4a06-9062-a1df0117b5d0-image.png" alt="27fad870-9a12-4a06-9062-a1df0117b5d0-image.png" class=" img-fluid img-markdown" /><br />
Error: Cannot find module 'alexa-remote2'<br />
code: 'MODULE_NOT_FOUND',<br />
requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]</p>
<p dir="auto">eine Version drunter ,reboot usw. hilft nicht<br />
backitup auf Tage wo es noch funktioniert hat hilft auch nicht !!!</p>
]]></description><link>https://forum.iobroker.net/topic/49416/gelöst-alexa-adapter-rot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 20:31:19 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/49416.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Nov 2021 10:56:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 22:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/706066">Alexa Adapter rot</a>:</p>
<blockquote>
<p dir="auto">iobroker add alexa2</p>
</blockquote>
<p dir="auto">Das wahr die Lösung (+  You can try to get the cookie manually by opening <a href="http://192.168.178/" rel="nofollow ugc">http://192.168.178/</a> with your browser.)<br />
super danke</p>
]]></description><link>https://forum.iobroker.net/post/706112</link><guid isPermaLink="true">https://forum.iobroker.net/post/706112</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Thu, 18 Nov 2021 22:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:48:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a> Zunächst reicht das.<br />
Am besten über die Konsole, da gibt es ggf. bessere Meldungen.</p>
<pre><code>iobroker del alexa2
iobroker update
iobroker add alexa2
</code></pre>
<p dir="auto">Auf einem einfach System ohne Multihost usw.</p>
]]></description><link>https://forum.iobroker.net/post/706066</link><guid isPermaLink="true">https://forum.iobroker.net/post/706066</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:37:07 GMT]]></title><description><![CDATA[<p dir="auto">nur alexa adapter löschen<br />
<img src="/assets/uploads/files/1637267689703-7aa02cad-181b-42ba-855a-9c891345c83f-image.png" alt="7aa02cad-181b-42ba-855a-9c891345c83f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">das reicht oder gibst da noch Restbestände ?</p>
]]></description><link>https://forum.iobroker.net/post/706058</link><guid isPermaLink="true">https://forum.iobroker.net/post/706058</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:37:07 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:31:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a><br />
Installier den Adapter nochmal neu.</p>
]]></description><link>https://forum.iobroker.net/post/706054</link><guid isPermaLink="true">https://forum.iobroker.net/post/706054</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:31:14 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:30:42 GMT]]></title><description><![CDATA[<pre><code>2021-11-18 01:05:33.862  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: internal/modules/cjs/loader.js:818
2021-11-18 01:05:33.863  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   throw err;
2021-11-18 01:05:33.863  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   ^
2021-11-18 01:05:33.864  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module 'alexa-remote2'
2021-11-18 01:05:33.864  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: Require stack:
2021-11-18 01:05:33.865  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
2021-11-18 01:05:33.865  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
2021-11-18 01:05:33.866  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
2021-11-18 01:05:33.866  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
2021-11-18 01:05:33.867  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
2021-11-18 01:05:33.867  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.alexa2/main.js:9:15)
2021-11-18 01:05:33.868  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
2021-11-18 01:05:33.868  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
2021-11-18 01:05:33.869  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
2021-11-18 01:05:33.869  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
2021-11-18 01:05:33.870  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
2021-11-18 01:05:33.871  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
2021-11-18 01:05:33.871  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.alexa2/main.js' ]
2021-11-18 01:05:33.872  - [31merror[39m: host.raspberrypi4-iob Caught by controller[0]: }
2021-11-18 01:05:33.873  - [31merror[39m: host.raspberrypi4-iob instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2021-11-18 01:05:33.874  - [32minfo[39m: host.raspberrypi4-iob Restart adapter system.adapter.alexa2.0 because enabled
</code></pre>
]]></description><link>https://forum.iobroker.net/post/706053</link><guid isPermaLink="true">https://forum.iobroker.net/post/706053</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:27:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a> Am Adapter ist ja auch noch gar nichts gemacht worden.<br />
In der Konsole wird jetzt was gemeldet, wenn die Instanz neugestartet wird?</p>
]]></description><link>https://forum.iobroker.net/post/706049</link><guid isPermaLink="true">https://forum.iobroker.net/post/706049</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Thu, 18 Nov 2021 20:20:22 GMT]]></title><description><![CDATA[<p dir="auto">hallo<br />
bis jetzt alle Tipps von oben gemacht aber Adapter bleibt rot .<br />
Vielleicht Cookie löschen und neu oder alexa  Adapter löschen ?<br />
komisch nur das schalten mit alexa funktioniert Lampen, Abfragen, Sauger usw.</p>
]]></description><link>https://forum.iobroker.net/post/706047</link><guid isPermaLink="true">https://forum.iobroker.net/post/706047</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:20:22 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 13:27:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a> sagte in <a href="/post/704774">Alexa Adapter rot</a>:</p>
<blockquote>
<p dir="auto">Aktualisierung für 137 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,        um sie anzuzeigen.</p>
</blockquote>
<p dir="auto">nodeJS passt, allerdings solltest du dein Betriebssystem auch aktuell halten.</p>
<pre><code>iobroker stop
sudo apt dist-upgrade
sudo reboot
</code></pre>
]]></description><link>https://forum.iobroker.net/post/704779</link><guid isPermaLink="true">https://forum.iobroker.net/post/704779</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 16 Nov 2021 13:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 13:10:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/704771">Alexa Adapter rot</a>:</p>
<blockquote>
<p dir="auto">which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; sudo apt update &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs</p>
</blockquote>
<pre><code>pi@raspberrypi4-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
pi@raspberrypi4-iob:~ $ which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v        &amp;&amp; sudo apt update &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v12.22.7
v12.22.7
6.14.15
Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
OK:3 https://deb.nodesource.com/node_12.x buster InRelease
OK:4 https://repos.influxdata.com/debian buster InRelease
Es wurden 15,0 kB in 1 s geholt (10,2 kB/s).
OK:3 https://repos.influxdata.com/debian buster InRelease
OK:4 https://deb.nodesource.com/node_12.x buster InRelease
nodejs:
  Installiert:           12.22.7-deb-1nodesource1
  Installationskandidat: 12.22.7-deb-1nodesource1
  Versionstabelle:
 *** 12.22.7-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u1 500
code_text
</code></pre>
]]></description><link>https://forum.iobroker.net/post/704774</link><guid isPermaLink="true">https://forum.iobroker.net/post/704774</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Tue, 16 Nov 2021 13:10:05 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 12:53:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a></p>
<p dir="auto">Bitte nix kürzen, vollständige Ein- wie Ausgaben posten.</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs
</code></pre>
]]></description><link>https://forum.iobroker.net/post/704771</link><guid isPermaLink="true">https://forum.iobroker.net/post/704771</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 16 Nov 2021 12:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 12:49:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfrieseunterwegs" aria-label="Profile: ostfrieseunterwegs">@<bdi>ostfrieseunterwegs</bdi></a> said in <a href="/post/704744">Alexa Adapter rot</a>:</p>
<blockquote>
</blockquote>
<pre><code>pi@raspberrypi4-iob:~ $ which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; sudo apt update &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
/usr/bin/node
/usr/bin/npm
iobroker list instances
: admin
  system.adapter.alexa2.0                 : alexa2                : raspberrypi4
iobroker list adapters
system.adapter.alexa2                  : alexa2         - v3.11.2
pi@raspberrypi4-iob:~ $ iobroker status
</code></pre>
<p dir="auto">leider immer noch rot</p>
]]></description><link>https://forum.iobroker.net/post/704767</link><guid isPermaLink="true">https://forum.iobroker.net/post/704767</guid><dc:creator><![CDATA[arnold]]></dc:creator><pubDate>Tue, 16 Nov 2021 12:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 12:07:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfrieseunterwegs" aria-label="Profile: ostfrieseunterwegs">@<bdi>ostfrieseunterwegs</bdi></a><br />
Weil im zweiten Durchlauf nur die zuvor bereits aktualisierten Repos kompakt angezeigt werden.</p>
]]></description><link>https://forum.iobroker.net/post/704748</link><guid isPermaLink="true">https://forum.iobroker.net/post/704748</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 16 Nov 2021 12:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 12:01:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/704719">Alexa Adapter rot</a>:</p>
<blockquote>
<p dir="auto">Und weil es so grundlegend ist:</p>
<pre><code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; sudo apt update &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
</blockquote>
<p dir="auto">OT: Warum machst Du zwei mal nacheinander <em><strong>apt update</strong></em> ?</p>
]]></description><link>https://forum.iobroker.net/post/704744</link><guid isPermaLink="true">https://forum.iobroker.net/post/704744</guid><dc:creator><![CDATA[OstfrieseUnterwegs]]></dc:creator><pubDate>Tue, 16 Nov 2021 12:01:39 GMT</pubDate></item><item><title><![CDATA[Reply to (gelöst) Alexa Adapter rot on Tue, 16 Nov 2021 11:20:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arnold" aria-label="Profile: arnold">@<bdi>arnold</bdi></a></p>
<pre><code>dmesg -T | grep -i ext4
iobroker update -i
iobroker status
iobroker stop
iobroker fix
iobroker start
</code></pre>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/704719</link><guid isPermaLink="true">https://forum.iobroker.net/post/704719</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 16 Nov 2021 11:20:40 GMT</pubDate></item></channel></rss>
