  5. MAX! Cube Blockly Abwesenheit
    6.7k
867 Beiträge 4 Kommentatoren 251.2k Aufrufe 2 Beobachtet
  • mickymM mickym
    @marko1974 wie hast Du es genau geschrieben?
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    #305
    @mickym kann ich nochwas tun?
    • Marko1974M Marko1974
      @mickym ECO
        "common": {
          "name": "ECO",
          "desc": "Manuell erzeugt",
          "role": "state",
          "type": "number",
          "read": true,
          "write": true,
          "def": 0
        "type": "state",
        "user": "system.user.admin",
        "ts": 1636847431239,
        "_id": "0_userdata.0.Heizung.Kinderzimmer.ECO",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      mickymM Offline
      mickymM Offline
      mickym
      #306
      @marko1974 So der Hauptflow ist fertig - nun musst Du noch bissi Feinarbeiten machen:
      Hier der Import:
             "id": "c2c0c34f.6e2ed",
             "type": "subflow",
             "name": "MAX Auto Badezimmer",
             "info": "# MAX Wochenprofil erstellen",
             "category": "MAX Auto Profil",
             "in": [
                     "x": 40,
                     "y": 260,
                     "wires": [
                             "id": "adc559a.6d1fea8"
             "out": [
                     "x": 1240,
                     "y": 260,
                     "wires": [
                             "id": "78e83c34.8e26f4",
                             "port": 0
                             "id": "b43a5b2f.5ba228",
                             "port": 0
                             "id": "c381b0fb.0c407",
                             "port": 0
                             "id": "d7602741.e08ec8",
                             "port": 0
                             "id": "67e1f0e6.98f84",
                             "port": 0
                             "id": "324ef3e0.d9ac1c",
                             "port": 0
                             "id": "2c0b8bd8.778e14",
                             "port": 0
                             "id": "5b0e8515.b3b32c",
                             "port": 0
                             "id": "50a57933.3a77b8",
                             "port": 0
                             "id": "92ee1669.329f78",
                             "port": 0
             "env": [],
             "meta": {},
             "color": "#FFAAAA",
             "outputLabels": [
                 "AUTO Temperatur"
             "icon": "font-awesome/fa-thermometer-2"
             "id": "2961f12d.901f7e",
             "type": "switch",
             "z": "c2c0c34f.6e2ed",
             "name": "Automatik <Template>- Zeitprofil Mo - Fr",
             "property": "payload.time",
             "propertyType": "msg",
             "rules": [
                     "t": "btwn",
                     "v": "00:00",
                     "vt": "str",
                     "v2": "08:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "08:00",
                     "vt": "str",
                     "v2": "09:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "09:00",
                     "vt": "str",
                     "v2": "22:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "22:00",
                     "vt": "str",
                     "v2": "23:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "23:00",
                     "vt": "str",
                     "v2": "24:00",
                     "v2t": "str"
             "checkall": "false",
             "repair": false,
             "outputs": 5,
             "x": 780,
             "y": 160,
             "wires": [
                     "78e83c34.8e26f4"
                     "b43a5b2f.5ba228"
                     "c381b0fb.0c407"
                     "d7602741.e08ec8"
                     "67e1f0e6.98f84"
             "id": "adc559a.6d1fea8",
             "type": "change",
             "name": "Change $moment",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "{\"weekday\":\"\",\"time\":\"\"}",
                     "tot": "json"
                     "t": "set",
                     "p": "payload.weekday",
                     "pt": "msg",
                     "to": "$moment().locale(\"de\").tz('Europe/Berlin').format('dddd')",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "payload.time",
                     "pt": "msg",
                     "to": "$moment().locale(\"de\").tz('Europe/Berlin').format('HH:mm')",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 190,
             "y": 260,
             "wires": [
                     "fd8206e3.66bbf8"
             "type": "change",
             "name": "22 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "22",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 120,
             "wires": [
             "type": "change",
             "name": "17°C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 160,
             "wires": [
             "type": "change",
             "name": "22 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "22",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 200,
             "wires": [
             "type": "change",
             "name": "17 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 240,
             "wires": [
             "id": "a03bd421.d47bd8",
             "type": "switch",
             "name": "Automatik <Template> - Zeitprofil Sa + So",
             "rules": [
                     "t": "btwn",
                     "v": "00:00",
                     "vt": "str",
                     "v2": "08:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "08:00",
                     "vt": "str",
                     "v2": "09:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "09:00",
                     "vt": "str",
                     "v2": "22:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "22:00",
                     "vt": "str",
                     "v2": "23:00",
                     "v2t": "str"
                     "t": "btwn",
                     "v": "23:00",
                     "vt": "str",
                     "v2": "24:00",
                     "v2t": "str"
             "repair": false,
             "outputs": 5,
             "x": 780,
             "y": 380,
             "wires": [
                     "324ef3e0.d9ac1c"
                     "2c0b8bd8.778e14"
                     "5b0e8515.b3b32c"
                     "92ee1669.329f78"
                     "50a57933.3a77b8"
             "type": "change",
             "name": "22 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "22",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 340,
             "wires": [
             "id": "fd8206e3.66bbf8",
             "type": "switch",
             "name": "Selektiere Wochentage",
             "property": "payload.weekday",
             "rules": [
                     "t": "regex",
                     "v": "Montag|Dienstag|Mittwoch|Donnerstag|Freitag",
                     "vt": "str",
                     "case": true
                     "t": "regex",
                     "v": "Samstag|Sonntag",
                     "vt": "str",
                     "case": true
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 430,
             "y": 260,
             "wires": [
                     "2961f12d.901f7e"
                     "a03bd421.d47bd8"
             "type": "change",
             "name": "17 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 380,
             "wires": [
             "type": "change",
             "name": "22 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "22",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 420,
             "wires": [
             "type": "change",
             "name": "17 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 460,
             "wires": [
             "type": "change",
             "name": "17 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 300,
             "wires": [
             "type": "change",
             "name": "17 °C",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "17",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1070,
             "y": 80,
             "wires": [
             "id": "1965b6bc.47ee19",
             "type": "inject",
             "z": "6f3801b9.ba4b6",
             "name": "Trigger alle Minuten",
             "props": [
                     "p": "ts",
                     "v": "",
                     "vt": "date"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 490,
             "y": 1940,
             "wires": [
                     "4ad77e6.fb2298"
             "id": "f5d5a81d.0d79c8",
             "type": "change",
             "name": "Wohnzimmer",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Wohnzimmer",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 910,
             "y": 1920,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "5715f8a9.9e36d8",
             "type": "change",
             "name": "Schlafzimmer",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Schlafzimmer",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 900,
             "y": 1880,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "27e3cf0b.1fb9c",
             "type": "change",
             "name": "Kinderzimmer",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Kinderzimmer",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 900,
             "y": 1840,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "30c3ea81.3b06b6",
             "type": "change",
             "name": "Flur",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Flur",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 930,
             "y": 1960,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "b87ebd5f.04a7d",
             "type": "change",
             "name": "Küche",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Küche",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 930,
             "y": 2000,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "4e2c598d.d467e8",
             "type": "change",
             "name": "Badezimmer",
             "rules": [
                     "t": "set",
                     "p": "room",
                     "pt": "msg",
                     "to": "Badezimmer",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 910,
             "y": 2040,
             "wires": [
                     "9d89290d.3f4f48"
             "id": "4ad77e6.fb2298",
             "type": "switch",
             "name": "Ein / Aus",
             "property": "gHeizungssteuerung",
             "propertyType": "global",
             "rules": [
                     "t": "true"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 680,
             "y": 1940,
             "wires": [
                     "27e3cf0b.1fb9c",
                     "5715f8a9.9e36d8",
                     "f5d5a81d.0d79c8",
                     "30c3ea81.3b06b6",
                     "b87ebd5f.04a7d",
                     "4e2c598d.d467e8"
             "id": "f62fe74f.2ea798",
             "type": "inject",
             "name": "Aktiviere Heizungssteuerung",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": true,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "true",
             "payloadType": "bool",
             "x": 560,
             "y": 1380,
             "wires": [
                     "a06e7e01.fa763"
             "id": "a06e7e01.fa763",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "gHeizungssteuerung",
                     "pt": "global",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 870,
             "y": 1380,
             "wires": [
             "id": "9d89290d.3f4f48",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Heizung.\" & room & \".mode\"",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1200,
             "y": 1840,
             "wires": [
                     "f07d0a47.5ea388"
             "id": "1940726b.23d83e",
             "type": "debug",
             "name": "",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "targetType": "full",
             "statusVal": "",
             "statusType": "auto",
             "x": 1670,
             "y": 2000,
             "wires": []
             "id": "f07d0a47.5ea388",
             "type": "ioBroker get",
             "name": "get mode",
             "topic": "",
             "attrname": "mode",
             "payloadType": "value",
             "x": 1370,
             "y": 1840,
             "wires": [
                     "31374dbc.8ee562"
             "id": "863eaba3.56b088",
             "name": "get desiredTemperature",
             "topic": "",
             "attrname": "desiredTemperature",
             "x": 1410,
             "y": 1920,
             "wires": [
                     "6b0d1558.1cdc8c"
             "id": "31374dbc.8ee562",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Heizung.\" & room & \".setpoint\"",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1200,
             "y": 1920,
             "wires": [
                     "863eaba3.56b088"
             "id": "b1a9ca76.52ad48",
             "type": "switch",
             "name": "Heizungen",
             "property": "room",
             "rules": [
                     "t": "eq",
                     "v": "Kinderzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Schlafzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Wohnzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Flur",
                     "vt": "str"
                     "t": "eq",
                     "v": "Küche",
                     "vt": "str"
                     "t": "eq",
                     "v": "Badezimmer",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 6,
             "x": 1690,
             "y": 1920,
             "wires": [
                     "58a0f8f3.c56118"
                     "e21babd2.9960c8"
                     "c28be01e.ad1f"
                     "cfe521df.1b0fb"
                     "be5cdd66.a5d76"
                     "d95d6d51.eff4c"
             "id": "58a0f8f3.c56118",
             "type": "switch",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1940,
             "y": 1480,
             "wires": [
                     "581dbaad.9c9f34"
                     "d912a77.1dadd58"
                     "1afe73e2.fdb6ac"
                     "14999008.d8eab"
             "id": "e21babd2.9960c8",
             "type": "switch",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1940,
             "y": 1660,
             "wires": [
                     "e66376fc.0697e8"
                     "a1a54233.2e25"
                     "4b729ec6.a7567"
                     "d0e7d874.8ffc18"
             "id": "c28be01e.ad1f",
             "type": "switch",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1930,
             "y": 1820,
             "wires": [
                     "882eac91.a4c63"
                     "22fe10a1.4179a"
                     "f054e171.d9388"
                     "30ec57c5.5cb298"
             "id": "cfe521df.1b0fb",
             "type": "switch",
             "name": "Flur",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1910,
             "y": 1980,
             "wires": [
                     "6a4e1335.624edc"
                     "696a4cf4.0926f4"
                     "e8aa246e.263ee8"
                     "18820133.6bd0df"
             "id": "be5cdd66.a5d76",
             "type": "switch",
             "name": "Küche",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1930,
             "y": 2160,
             "wires": [
                     "220c1f0.70a44e2"
                     "6e94704e.ff4bc"
                     "d6ca8495.917f78"
                     "23535d36.f89882"
             "id": "d95d6d51.eff4c",
             "type": "switch",
             "property": "mode",
             "rules": [
                     "t": "eq",
                     "v": "AUTO",
                     "vt": "str"
                     "t": "eq",
                     "v": "HEAT",
                     "vt": "str"
                     "t": "eq",
                     "v": "OFF",
                     "vt": "str"
                     "t": "eq",
                     "v": "ECO",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 1930,
             "y": 2340,
             "wires": [
                     "8f1b3f56.520fe"
                     "5cd3bef0.e41f8"
                     "9703563a.10fbe8"
                     "d0ae36e3.0d6d68"
             "id": "8f1b3f56.520fe",
             "type": "subflow:c2c0c34f.6e2ed",
             "name": "",
             "x": 2190,
             "y": 2280,
             "wires": [
                     "8c12a45.58c5958"
             "id": "5cd3bef0.e41f8",
             "type": "change",
             "name": "HEAT = setpoint",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "desiredTemperature",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 2320,
             "wires": [
                     "8c12a45.58c5958"
             "id": "9703563a.10fbe8",
             "type": "change",
             "name": "OFF = 4.5",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 2360,
             "wires": [
                     "8c12a45.58c5958"
             "id": "6b0d1558.1cdc8c",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Heizung.\" & room & \".ECO\"",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1200,
             "y": 2000,
             "wires": [
                     "cad52ae9.b3a468"
             "id": "cad52ae9.b3a468",
             "name": "get ecoTemperature",
             "topic": "",
             "attrname": "ecoTemperature",
             "x": 1400,
             "y": 2000,
             "wires": [
                     "b1a9ca76.52ad48",
                     "1940726b.23d83e"
             "id": "d0ae36e3.0d6d68",
             "type": "change",
             "name": "ECO = ECO",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "ecoTemperature",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 2400,
             "wires": [
                     "8c12a45.58c5958"
             "id": "6e94704e.ff4bc",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 2140,
             "wires": [
                     "420c8f3.1d09f7"
             "id": "d6ca8495.917f78",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 2180,
             "wires": [
                     "420c8f3.1d09f7"
             "id": "23535d36.f89882",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 2220,
             "wires": [
                     "420c8f3.1d09f7"
             "id": "220c1f0.70a44e2",
             "name": "",
             "x": 2190,
             "y": 2100,
             "wires": [
                     "420c8f3.1d09f7"
             "id": "696a4cf4.0926f4",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 1960,
             "wires": [
                     "cab0fe28.59eef"
             "id": "e8aa246e.263ee8",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 2000,
             "wires": [
                     "cab0fe28.59eef"
             "id": "18820133.6bd0df",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 2040,
             "wires": [
                     "cab0fe28.59eef"
             "id": "6a4e1335.624edc",
             "name": "",
             "x": 2190,
             "y": 1920,
             "wires": [
                     "cab0fe28.59eef"
             "id": "22fe10a1.4179a",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 1800,
             "wires": [
                     "195630dc.b07aff"
             "id": "f054e171.d9388",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 1840,
             "wires": [
                     "195630dc.b07aff"
             "id": "30ec57c5.5cb298",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 1880,
             "wires": [
                     "195630dc.b07aff"
             "id": "882eac91.a4c63",
             "name": "",
             "x": 2190,
             "y": 1760,
             "wires": [
                     "195630dc.b07aff"
             "id": "a1a54233.2e25",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 1640,
             "wires": [
                     "7cb96adf.df8ef4"
             "id": "4b729ec6.a7567",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 1680,
             "wires": [
                     "7cb96adf.df8ef4"
             "id": "d0e7d874.8ffc18",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 1720,
             "wires": [
                     "7cb96adf.df8ef4"
             "id": "e66376fc.0697e8",
             "name": "",
             "x": 2190,
             "y": 1600,
             "wires": [
                     "7cb96adf.df8ef4"
             "id": "d912a77.1dadd58",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2160,
             "y": 1460,
             "wires": [
                     "7da482f0.8e833c"
             "id": "1afe73e2.fdb6ac",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "4.5",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2140,
             "y": 1500,
             "wires": [
                     "7da482f0.8e833c"
             "id": "14999008.d8eab",
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2150,
             "y": 1540,
             "wires": [
                     "7da482f0.8e833c"
             "id": "581dbaad.9c9f34",
             "name": "",
             "x": 2190,
             "y": 1420,
             "wires": [
                     "7da482f0.8e833c"
             "id": "544cd832.3d5cb8",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "x": 2610,
             "y": 2380,
             "wires": []
             "id": "8c12a45.58c5958",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "property": "payload",
             "x": 2440,
             "y": 2360,
             "wires": [
                     "6ce146dd.f3bdd8",
                     "544cd832.3d5cb8"
             "id": "6ce146dd.f3bdd8",
             "type": "ioBroker out",
             "d": true,
             "topic": "",
             "ack": "false",
             "autoCreate": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2610,
             "y": 2340,
             "wires": []
             "id": "ef09f468.27d118",
             "type": "debug",
             "name": "Küche",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2590,
             "y": 2180,
             "wires": []
             "id": "420c8f3.1d09f7",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "x": 2440,
             "y": 2160,
             "wires": [
                     "66692b1b.1a5af4",
                     "ef09f468.27d118"
             "id": "66692b1b.1a5af4",
             "d": true,
             "name": "Küche",
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2590,
             "y": 2140,
             "wires": []
             "id": "b8cbf5b5.4b82c8",
             "type": "debug",
             "name": "Flur",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2590,
             "y": 2000,
             "wires": []
             "id": "cab0fe28.59eef",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "x": 2440,
             "y": 1980,
             "wires": [
                     "d749214a.8cde9",
                     "b8cbf5b5.4b82c8"
             "id": "d749214a.8cde9",
             "d": true,
             "name": "Flur",
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2590,
             "y": 1960,
             "wires": []
             "id": "a3fbc37c.6029e",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2610,
             "y": 1840,
             "wires": []
             "id": "195630dc.b07aff",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "x": 2440,
             "y": 1820,
             "wires": [
                     "f46f75.b28e9088",
                     "a3fbc37c.6029e"
             "id": "f46f75.b28e9088",
             "d": true,
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2610,
             "y": 1800,
             "wires": []
             "id": "13e32815.6f13a8",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2620,
             "y": 1700,
             "wires": []
             "id": "7cb96adf.df8ef4",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "x": 2440,
             "y": 1680,
             "wires": [
                     "ea6ed90a.7eea08",
                     "13e32815.6f13a8"
             "id": "ea6ed90a.7eea08",
             "d": true,
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2620,
             "y": 1660,
             "wires": []
             "id": "efcc4af2.479898",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 2620,
             "y": 1500,
             "wires": []
             "id": "7da482f0.8e833c",
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": true,
             "x": 2440,
             "y": 1480,
             "wires": [
                     "c1f9faa7.60fd18",
                     "efcc4af2.479898"
             "id": "c1f9faa7.60fd18",
             "d": true,
             "topic": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2620,
             "y": 1460,
             "wires": []
      So und keine Angst es läuft nach dem Deploy noch nichts los.
      Marko1974M 1 Antwort Letzte Antwort
      • mickymM mickym
        Hier der Import:
               "type": "subflow",
               "in": [
                       "x": 40,
                       "y": 260,
                       "wires": [
               "out": [
                       "x": 1240,
                       "y": 260,
                       "wires": [
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
                               "port": 0
               "env": [],
               "meta": {},
               "color": "#FFAAAA",
               "outputLabels": [
                   "AUTO Temperatur"
               "type": "switch",
               "rules": [
                       "t": "btwn",
                       "v": "00:00",
                       "vt": "str",
                       "v2": "08:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "08:00",
                       "vt": "str",
                       "v2": "09:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "09:00",
                       "vt": "str",
                       "v2": "22:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "22:00",
                       "vt": "str",
                       "v2": "23:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "23:00",
                       "vt": "str",
                       "v2": "24:00",
                       "v2t": "str"
               "repair": false,
               "outputs": 5,
               "x": 780,
               "y": 160,
               "wires": [
                       "78e83c34.8e26f4"
                       "b43a5b2f.5ba228"
                       "c381b0fb.0c407"
                       "d7602741.e08ec8"
                       "67e1f0e6.98f84"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "json"
                       "t": "set",
                       "pt": "msg",
                       "tot": "jsonata"
                       "t": "set",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 190,
               "y": 260,
               "wires": [
                       "fd8206e3.66bbf8"
               "type": "change",
               "name": "22 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "22",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 120,
               "wires": [
               "type": "change",
               "name": "17°C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 160,
               "wires": [
               "type": "change",
               "name": "22 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "22",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 200,
               "wires": [
               "type": "change",
               "name": "17 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 240,
               "wires": [
               "type": "switch",
               "rules": [
                       "t": "btwn",
                       "v": "00:00",
                       "vt": "str",
                       "v2": "08:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "08:00",
                       "vt": "str",
                       "v2": "09:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "09:00",
                       "vt": "str",
                       "v2": "22:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "22:00",
                       "vt": "str",
                       "v2": "23:00",
                       "v2t": "str"
                       "t": "btwn",
                       "v": "23:00",
                       "vt": "str",
                       "v2": "24:00",
                       "v2t": "str"
               "repair": false,
               "outputs": 5,
               "x": 780,
               "y": 380,
               "wires": [
                       "324ef3e0.d9ac1c"
                       "2c0b8bd8.778e14"
                       "5b0e8515.b3b32c"
                       "92ee1669.329f78"
                       "50a57933.3a77b8"
               "type": "change",
               "name": "22 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "22",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 340,
               "wires": [
               "type": "switch",
               "rules": [
                       "t": "regex",
                       "vt": "str",
                       "case": true
                       "t": "regex",
                       "vt": "str",
                       "case": true
               "checkall": "true",
               "repair": false,
               "outputs": 2,
               "x": 430,
               "y": 260,
               "wires": [
                       "2961f12d.901f7e"
                       "a03bd421.d47bd8"
               "type": "change",
               "name": "17 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 380,
               "wires": [
               "type": "change",
               "name": "22 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "22",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 420,
               "wires": [
               "type": "change",
               "name": "17 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 460,
               "wires": [
               "type": "change",
               "name": "17 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 300,
               "wires": [
               "type": "change",
               "name": "17 °C",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "17",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1070,
               "y": 80,
               "wires": [
               "type": "inject",
               "props": [
                       "p": "ts",
                       "v": "",
                       "vt": "date"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 490,
               "y": 1940,
               "wires": [
                       "4ad77e6.fb2298"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "to": "Wohnzimmer",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 910,
               "y": 1920,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 900,
               "y": 1880,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 900,
               "y": 1840,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "change",
               "name": "Flur",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "to": "Flur",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 930,
               "y": 1960,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "change",
               "name": "Küche",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "to": "Küche",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 930,
               "y": 2000,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "room",
                       "pt": "msg",
                       "to": "Badezimmer",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 910,
               "y": 2040,
               "wires": [
                       "9d89290d.3f4f48"
               "type": "switch",
               "rules": [
                       "t": "true"
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 680,
               "y": 1940,
               "wires": [
                       "27e3cf0b.1fb9c",
                       "5715f8a9.9e36d8",
                       "f5d5a81d.0d79c8",
                       "30c3ea81.3b06b6",
                       "b87ebd5f.04a7d",
                       "4e2c598d.d467e8"
               "type": "inject",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": true,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "true",
               "x": 560,
               "y": 1380,
               "wires": [
                       "a06e7e01.fa763"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "pt": "global",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 870,
               "y": 1380,
               "wires": [
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1200,
               "y": 1840,
               "wires": [
                       "f07d0a47.5ea388"
               "type": "debug",
               "name": "",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "true",
               "statusVal": "",
               "x": 1670,
               "y": 2000,
               "wires": []
               "name": "get mode",
               "topic": "",
               "attrname": "mode",
               "x": 1370,
               "y": 1840,
               "wires": [
                       "31374dbc.8ee562"
               "topic": "",
               "x": 1410,
               "y": 1920,
               "wires": [
                       "6b0d1558.1cdc8c"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1200,
               "y": 1920,
               "wires": [
                       "863eaba3.56b088"
               "type": "switch",
               "property": "room",
               "rules": [
                       "t": "eq",
                       "vt": "str"
                       "t": "eq",
                       "vt": "str"
                       "t": "eq",
                       "v": "Wohnzimmer",
                       "vt": "str"
                       "t": "eq",
                       "v": "Flur",
                       "vt": "str"
                       "t": "eq",
                       "v": "Küche",
                       "vt": "str"
                       "t": "eq",
                       "v": "Badezimmer",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 6,
               "x": 1690,
               "y": 1920,
               "wires": [
                       "58a0f8f3.c56118"
                       "e21babd2.9960c8"
                       "c28be01e.ad1f"
                       "cfe521df.1b0fb"
                       "be5cdd66.a5d76"
                       "d95d6d51.eff4c"
               "type": "switch",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1940,
               "y": 1480,
               "wires": [
                       "581dbaad.9c9f34"
                       "d912a77.1dadd58"
                       "1afe73e2.fdb6ac"
                       "14999008.d8eab"
               "type": "switch",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1940,
               "y": 1660,
               "wires": [
                       "e66376fc.0697e8"
                       "a1a54233.2e25"
                       "4b729ec6.a7567"
                       "d0e7d874.8ffc18"
               "type": "switch",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1930,
               "y": 1820,
               "wires": [
                       "882eac91.a4c63"
                       "22fe10a1.4179a"
                       "f054e171.d9388"
                       "30ec57c5.5cb298"
               "type": "switch",
               "name": "Flur",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1910,
               "y": 1980,
               "wires": [
                       "6a4e1335.624edc"
                       "696a4cf4.0926f4"
                       "e8aa246e.263ee8"
                       "18820133.6bd0df"
               "type": "switch",
               "name": "Küche",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1930,
               "y": 2160,
               "wires": [
                       "220c1f0.70a44e2"
                       "6e94704e.ff4bc"
                       "d6ca8495.917f78"
                       "23535d36.f89882"
               "type": "switch",
               "property": "mode",
               "rules": [
                       "t": "eq",
                       "v": "AUTO",
                       "vt": "str"
                       "t": "eq",
                       "v": "HEAT",
                       "vt": "str"
                       "t": "eq",
                       "v": "OFF",
                       "vt": "str"
                       "t": "eq",
                       "v": "ECO",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 4,
               "x": 1930,
               "y": 2340,
               "wires": [
                       "8f1b3f56.520fe"
                       "5cd3bef0.e41f8"
                       "9703563a.10fbe8"
                       "d0ae36e3.0d6d68"
               "name": "",
               "x": 2190,
               "y": 2280,
               "wires": [
                       "8c12a45.58c5958"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 2320,
               "wires": [
                       "8c12a45.58c5958"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 2360,
               "wires": [
                       "8c12a45.58c5958"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1200,
               "y": 2000,
               "wires": [
                       "cad52ae9.b3a468"
               "topic": "",
               "x": 1400,
               "y": 2000,
               "wires": [
                       "b1a9ca76.52ad48",
                       "1940726b.23d83e"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 2400,
               "wires": [
                       "8c12a45.58c5958"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 2140,
               "wires": [
                       "420c8f3.1d09f7"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 2180,
               "wires": [
                       "420c8f3.1d09f7"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 2220,
               "wires": [
                       "420c8f3.1d09f7"
               "name": "",
               "x": 2190,
               "y": 2100,
               "wires": [
                       "420c8f3.1d09f7"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 1960,
               "wires": [
                       "cab0fe28.59eef"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 2000,
               "wires": [
                       "cab0fe28.59eef"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 2040,
               "wires": [
                       "cab0fe28.59eef"
               "name": "",
               "x": 2190,
               "y": 1920,
               "wires": [
                       "cab0fe28.59eef"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 1800,
               "wires": [
                       "195630dc.b07aff"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 1840,
               "wires": [
                       "195630dc.b07aff"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 1880,
               "wires": [
                       "195630dc.b07aff"
               "name": "",
               "x": 2190,
               "y": 1760,
               "wires": [
                       "195630dc.b07aff"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 1640,
               "wires": [
                       "7cb96adf.df8ef4"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 1680,
               "wires": [
                       "7cb96adf.df8ef4"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 1720,
               "wires": [
                       "7cb96adf.df8ef4"
               "name": "",
               "x": 2190,
               "y": 1600,
               "wires": [
                       "7cb96adf.df8ef4"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2160,
               "y": 1460,
               "wires": [
                       "7da482f0.8e833c"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "4.5",
                       "tot": "num"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2140,
               "y": 1500,
               "wires": [
                       "7da482f0.8e833c"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2150,
               "y": 1540,
               "wires": [
                       "7da482f0.8e833c"
               "name": "",
               "x": 2190,
               "y": 1420,
               "wires": [
                       "7da482f0.8e833c"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2610,
               "y": 2380,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 2360,
               "wires": [
                       "6ce146dd.f3bdd8",
                       "544cd832.3d5cb8"
               "d": true,
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2610,
               "y": 2340,
               "wires": []
               "type": "debug",
               "name": "Küche",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2590,
               "y": 2180,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 2160,
               "wires": [
                       "66692b1b.1a5af4",
                       "ef09f468.27d118"
               "d": true,
               "name": "Küche",
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2590,
               "y": 2140,
               "wires": []
               "type": "debug",
               "name": "Flur",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2590,
               "y": 2000,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 1980,
               "wires": [
                       "d749214a.8cde9",
                       "b8cbf5b5.4b82c8"
               "d": true,
               "name": "Flur",
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2590,
               "y": 1960,
               "wires": []
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2610,
               "y": 1840,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 1820,
               "wires": [
                       "f46f75.b28e9088",
                       "a3fbc37c.6029e"
               "d": true,
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2610,
               "y": 1800,
               "wires": []
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2620,
               "y": 1700,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 1680,
               "wires": [
                       "ea6ed90a.7eea08",
                       "13e32815.6f13a8"
               "d": true,
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2620,
               "y": 1660,
               "wires": []
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2620,
               "y": 1500,
               "wires": []
               "type": "rbe",
               "name": "",
               "func": "rbe",
               "gap": "",
               "start": "",
               "inout": "out",
               "septopics": true,
               "x": 2440,
               "y": 1480,
               "wires": [
                       "c1f9faa7.60fd18",
                       "efcc4af2.479898"
               "d": true,
               "topic": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2620,
               "y": 1460,
               "wires": []
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        #307
        @mickym Wahnsinn.... Das hätte ich natürlich viel schneller hinbekommen :-)
        Ich hab ja jetzt sogar AUS und ECO .... also den jetzt als neuen flow?
        • mickymM Offline
          mickymM Offline
          mickym
          #308
          @marko1974 Ob als neuen Flow - oder auf der gleichen Seite ist egal. Auf der gleichen Seite hat es ja auch noch Platz. Vielleicht nutzt Du Node Red ja noch für was anderes.
          • mickymM mickym
            Marko1974M Offline
            Marko1974M Offline
            Marko1974
            #309
            @mickym Type error: J_def is undefined
              mickymM Offline
              mickymM Offline
              mickym
              #310
              @marko1974 sagte in MAX! Cube Blockly Abwesenheit:
              So dann musst Du noch die AUTO Nodes gegen die korrekten aus dem Zimmern zuordnen - ich habe nur eine genommen, sonst hättest Du lauter Duplicate drin.
              In den deaktivierten iobroker Out Nodes kommen die setpoints zu den Thermostaten im MaxCube Adapter.
              Dann probierst Du erst mal aus, ob die richtige Temperatur rauskommt, wenn Du den Trigger benutzt.
                mickymM Offline
                mickymM Offline
                mickym
                #311
                @marko1974 OK - dann bekommst den Flow als Datei - Augenblick:
                MAXCubeSteuerung.json
                • mickymM mickym
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #312
                  @mickym gleiche fehlermeldung
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #313
                    @marko1974 Nein - das muss gehen - über Datei funktioniert es. Du darfst nicht über den Text importieren - sondern musst die Seite wieder im Dateisystem abspeichern und dann die DAtei im Import angeben.
                    Das Problem ist wenn Du den Flow als Text in das rosa Fenster kopierst.
                    • mickymM mickym
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      #314
                      @mickym Leider nein....Auf import und dann aus Datei importieren.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #315
                        Sorry ich hab das bei mir gerade 2 mal gemacht
                        Marko1974M 2 Antworten Letzte Antwort
                        • mickymM mickym
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          schrieb am zuletzt editiert von Marko1974
                          #316
                          @mickym Ich habe keine Text da reinkopiert. Bin auf neuen Flow erstelllen, Importieren, Aus Datei....Datei ausgewählt....Fehlermeldung
                          • mickymM mickym
                            Marko1974M Offline
                            Marko1974M Offline
                            Marko1974
                            #317
                            @mickym said in MAX! Cube Blockly Abwesenheit:
                            So mache ich das schon die ganze Zeit....
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #318
                              @marko1974 Hmmm -
                              • mickymM mickym
                                @marko1974 Hmmm -
                                Marko1974M Offline
                                Marko1974M Offline
                                Marko1974
                                #319
                                @mickym Ja ich sehe das schon....aber eine Datei importieren kann ich eigentlich schon :-) ... Oder fehlt was bei mir??
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #320
                                  @marko1974 Ich hab vielleicht noch eine Idee - wobei es als Datei wenn Du ohne markieren - den Text einfach mit Speichern unter als Datei kopiert hättest. Wie speicherst Du denn die Datei im lokalen Dateisystem?
                                  • mickymM mickym
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    #321
                                    @mickym Na rechte Maustaste, Ziel speichern unter - und dann habe ich sie als Json gespeichert.
                                    Hab auch schon die Datei aufgemacht und reinkopiert....
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #322
                                      @marko1974 Ich versuche gerade mal ein Kopie ohne 3 Nodes zur Verfügung zu stellen - Augenblick
                                             "type": "subflow",
                                             "in": [
                                                     "x": 40,
                                                     "y": 260,
                                                     "wires": [
                                             "out": [
                                                     "x": 1240,
                                                     "y": 260,
                                                     "wires": [
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                                             "port": 0
                                             "env": [],
                                             "meta": {},
                                             "color": "#FFAAAA",
                                             "outputLabels": [
                                                 "AUTO Temperatur"
                                             "type": "switch",
                                             "rules": [
                                                     "t": "btwn",
                                                     "v": "00:00",
                                                     "vt": "str",
                                                     "v2": "08:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "08:00",
                                                     "vt": "str",
                                                     "v2": "09:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "09:00",
                                                     "vt": "str",
                                                     "v2": "22:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "22:00",
                                                     "vt": "str",
                                                     "v2": "23:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "23:00",
                                                     "vt": "str",
                                                     "v2": "24:00",
                                                     "v2t": "str"
                                             "repair": false,
                                             "outputs": 5,
                                             "x": 780,
                                             "y": 160,
                                             "wires": [
                                                     "78e83c34.8e26f4"
                                                     "b43a5b2f.5ba228"
                                                     "c381b0fb.0c407"
                                                     "d7602741.e08ec8"
                                                     "67e1f0e6.98f84"
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "json"
                                                     "t": "set",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                                     "t": "set",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 190,
                                             "y": 260,
                                             "wires": [
                                                     "fd8206e3.66bbf8"
                                             "type": "change",
                                             "name": "22 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "22",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 120,
                                             "wires": [
                                             "type": "change",
                                             "name": "17°C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 160,
                                             "wires": [
                                             "type": "change",
                                             "name": "22 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "22",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 200,
                                             "wires": [
                                             "type": "change",
                                             "name": "17 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 240,
                                             "wires": [
                                             "type": "switch",
                                             "rules": [
                                                     "t": "btwn",
                                                     "v": "00:00",
                                                     "vt": "str",
                                                     "v2": "08:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "08:00",
                                                     "vt": "str",
                                                     "v2": "09:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "09:00",
                                                     "vt": "str",
                                                     "v2": "22:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "22:00",
                                                     "vt": "str",
                                                     "v2": "23:00",
                                                     "v2t": "str"
                                                     "t": "btwn",
                                                     "v": "23:00",
                                                     "vt": "str",
                                                     "v2": "24:00",
                                                     "v2t": "str"
                                             "repair": false,
                                             "outputs": 5,
                                             "x": 780,
                                             "y": 380,
                                             "wires": [
                                                     "324ef3e0.d9ac1c"
                                                     "2c0b8bd8.778e14"
                                                     "5b0e8515.b3b32c"
                                                     "92ee1669.329f78"
                                                     "50a57933.3a77b8"
                                             "type": "change",
                                             "name": "22 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "22",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 340,
                                             "wires": [
                                             "type": "switch",
                                             "rules": [
                                                     "t": "regex",
                                                     "vt": "str",
                                                     "case": true
                                                     "t": "regex",
                                                     "vt": "str",
                                                     "case": true
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 2,
                                             "x": 430,
                                             "y": 260,
                                             "wires": [
                                                     "2961f12d.901f7e"
                                                     "a03bd421.d47bd8"
                                             "type": "change",
                                             "name": "17 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 380,
                                             "wires": [
                                             "type": "change",
                                             "name": "22 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "22",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 420,
                                             "wires": [
                                             "type": "change",
                                             "name": "17 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 460,
                                             "wires": [
                                             "type": "change",
                                             "name": "17 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 300,
                                             "wires": [
                                             "type": "change",
                                             "name": "17 °C",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "17",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1070,
                                             "y": 80,
                                             "wires": [
                                             "id": "8d07f0f.462691",
                                             "type": "inject",
                                             "z": "2fbfe79e.7af108",
                                             "props": [
                                                     "p": "ts",
                                                     "v": "",
                                                     "vt": "date"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "x": 230,
                                             "y": 640,
                                             "wires": [
                                                     "ba9950a5.49288"
                                             "id": "7cb2eeb8.3e183",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "to": "Wohnzimmer",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 650,
                                             "y": 620,
                                             "wires": [
                                             "id": "a8d50db9.c6774",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 640,
                                             "y": 580,
                                             "wires": [
                                             "id": "bf4c2ed6.98035",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 640,
                                             "y": 540,
                                             "wires": [
                                             "id": "c4e28fa7.326bc",
                                             "type": "change",
                                             "name": "Flur",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "to": "Flur",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 670,
                                             "y": 660,
                                             "wires": [
                                             "id": "658a283c.e3df28",
                                             "type": "change",
                                             "name": "Küche",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "to": "Küche",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 670,
                                             "y": 700,
                                             "wires": [
                                             "id": "8d92ec5a.66a3e",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "room",
                                                     "pt": "msg",
                                                     "to": "Badezimmer",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 650,
                                             "y": 740,
                                             "wires": [
                                             "id": "ba9950a5.49288",
                                             "type": "switch",
                                             "rules": [
                                                     "t": "true"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 1,
                                             "x": 420,
                                             "y": 640,
                                             "wires": [
                                                     "bf4c2ed6.98035",
                                                     "a8d50db9.c6774",
                                                     "7cb2eeb8.3e183",
                                                     "c4e28fa7.326bc",
                                                     "658a283c.e3df28",
                                                     "8d92ec5a.66a3e"
                                             "id": "a6332322.cad5c",
                                             "type": "inject",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": true,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "true",
                                             "x": 300,
                                             "y": 80,
                                             "wires": [
                                                     "e64a03f5.dab21"
                                             "id": "e64a03f5.dab21",
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "pt": "global",
                                                     "to": "payload",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 610,
                                             "y": 80,
                                             "wires": [
                                             "id": "62b671f6.c2aaf",
                                             "type": "debug",
                                             "name": "",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "complete": "true",
                                             "statusVal": "",
                                             "x": 1410,
                                             "y": 700,
                                             "wires": []
                                             "id": "29540e68.f0aa92",
                                             "name": "get mode",
                                             "topic": "",
                                             "attrname": "mode",
                                             "x": 1110,
                                             "y": 540,
                                             "wires": [
                                             "id": "c51fcd1e.360f2",
                                             "topic": "",
                                             "x": 1150,
                                             "y": 620,
                                             "wires": [
                                             "id": "cb21ff74.eb4a9",
                                             "type": "switch",
                                             "property": "room",
                                             "rules": [
                                                     "t": "eq",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Wohnzimmer",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Flur",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Küche",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Badezimmer",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 6,
                                             "x": 1430,
                                             "y": 620,
                                             "wires": [
                                                     "e5a3e935.e886d8"
                                                     "972d9173.c7f3"
                                                     "ed377f3f.8544b"
                                                     "5d6d4c4f.91d114"
                                                     "38ccb111.f4e7fe"
                                                     "21e8fc89.707d14"
                                             "id": "e5a3e935.e886d8",
                                             "type": "switch",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1680,
                                             "y": 180,
                                             "wires": [
                                                     "d54c49bb.c74768"
                                                     "c184fb01.ebcca8"
                                                     "6529e1ae.5cd9"
                                                     "6dabe592.9faefc"
                                             "id": "972d9173.c7f3",
                                             "type": "switch",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1680,
                                             "y": 360,
                                             "wires": [
                                                     "724c420d.7bb4dc"
                                                     "c03eaf47.47cf8"
                                                     "472549e6.0d4678"
                                                     "331e3168.d80a6e"
                                             "id": "ed377f3f.8544b",
                                             "type": "switch",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1670,
                                             "y": 520,
                                             "wires": [
                                                     "75b189b0.a21ce8"
                                                     "8699996.589d768"
                                                     "53fd717d.05821"
                                                     "7459aba.9b79754"
                                             "id": "5d6d4c4f.91d114",
                                             "type": "switch",
                                             "name": "Flur",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1650,
                                             "y": 680,
                                             "wires": [
                                                     "e5b821c6.408a"
                                                     "43795266.f0f97c"
                                                     "21ca5905.e8f226"
                                                     "27615a8c.7d6016"
                                             "id": "38ccb111.f4e7fe",
                                             "type": "switch",
                                             "name": "Küche",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1670,
                                             "y": 860,
                                             "wires": [
                                                     "e0360495.4282d8"
                                                     "6192c71e.e14868"
                                                     "3af25a08.425dd6"
                                                     "90555796.db7908"
                                             "id": "21e8fc89.707d14",
                                             "type": "switch",
                                             "property": "mode",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "AUTO",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "HEAT",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "OFF",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "ECO",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 4,
                                             "x": 1670,
                                             "y": 1040,
                                             "wires": [
                                                     "855f7739.710cf8"
                                                     "f0fac0a8.a938"
                                                     "be472598.070aa8"
                                                     "58de29bc.e3d6c8"
                                             "id": "855f7739.710cf8",
                                             "name": "",
                                             "x": 1930,
                                             "y": 980,
                                             "wires": [
                                                     "bb798b95.27ffe8"
                                             "id": "f0fac0a8.a938",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 1020,
                                             "wires": [
                                                     "bb798b95.27ffe8"
                                             "id": "be472598.070aa8",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 1060,
                                             "wires": [
                                                     "bb798b95.27ffe8"
                                             "id": "b66df471.5836c8",
                                             "topic": "",
                                             "x": 1140,
                                             "y": 700,
                                             "wires": [
                                                     "cb21ff74.eb4a9",
                                                     "62b671f6.c2aaf"
                                             "id": "58de29bc.e3d6c8",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 1100,
                                             "wires": [
                                                     "bb798b95.27ffe8"
                                             "id": "6192c71e.e14868",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 840,
                                             "wires": [
                                                     "9be24893.3fb948"
                                             "id": "3af25a08.425dd6",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 880,
                                             "wires": [
                                                     "9be24893.3fb948"
                                             "id": "90555796.db7908",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 920,
                                             "wires": [
                                                     "9be24893.3fb948"
                                             "id": "e0360495.4282d8",
                                             "name": "",
                                             "x": 1930,
                                             "y": 800,
                                             "wires": [
                                                     "9be24893.3fb948"
                                             "id": "43795266.f0f97c",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 660,
                                             "wires": [
                                                     "fa3e96a8.7edc38"
                                             "id": "21ca5905.e8f226",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 700,
                                             "wires": [
                                                     "fa3e96a8.7edc38"
                                             "id": "27615a8c.7d6016",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 740,
                                             "wires": [
                                                     "fa3e96a8.7edc38"
                                             "id": "e5b821c6.408a",
                                             "name": "",
                                             "x": 1930,
                                             "y": 620,
                                             "wires": [
                                                     "fa3e96a8.7edc38"
                                             "id": "8699996.589d768",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 500,
                                             "wires": [
                                                     "43619702.eb9618"
                                             "id": "53fd717d.05821",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 540,
                                             "wires": [
                                                     "43619702.eb9618"
                                             "id": "7459aba.9b79754",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 580,
                                             "wires": [
                                                     "43619702.eb9618"
                                             "id": "75b189b0.a21ce8",
                                             "name": "",
                                             "x": 1930,
                                             "y": 460,
                                             "wires": [
                                                     "43619702.eb9618"
                                             "id": "c03eaf47.47cf8",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 340,
                                             "wires": [
                                                     "4d667db0.e6ae24"
                                             "id": "472549e6.0d4678",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 380,
                                             "wires": [
                                                     "4d667db0.e6ae24"
                                             "id": "331e3168.d80a6e",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 420,
                                             "wires": [
                                                     "4d667db0.e6ae24"
                                             "id": "724c420d.7bb4dc",
                                             "name": "",
                                             "x": 1930,
                                             "y": 300,
                                             "wires": [
                                                     "4d667db0.e6ae24"
                                             "id": "c184fb01.ebcca8",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1900,
                                             "y": 160,
                                             "wires": [
                                                     "bbbcbe24.a8ad3"
                                             "id": "6529e1ae.5cd9",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "4.5",
                                                     "tot": "num"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1880,
                                             "y": 200,
                                             "wires": [
                                                     "bbbcbe24.a8ad3"
                                             "id": "6dabe592.9faefc",
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1890,
                                             "y": 240,
                                             "wires": [
                                                     "bbbcbe24.a8ad3"
                                             "id": "d54c49bb.c74768",
                                             "name": "",
                                             "x": 1930,
                                             "y": 120,
                                             "wires": [
                                                     "bbbcbe24.a8ad3"
                                             "id": "a4444639.a32858",
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2350,
                                             "y": 1080,
                                             "wires": []
                                             "id": "bb798b95.27ffe8",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 1060,
                                             "wires": [
                                                     "6d76bee5.29833",
                                                     "a4444639.a32858"
                                             "id": "6d76bee5.29833",
                                             "d": true,
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2350,
                                             "y": 1040,
                                             "wires": []
                                             "id": "bff952d4.2c202",
                                             "type": "debug",
                                             "name": "Küche",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2330,
                                             "y": 880,
                                             "wires": []
                                             "id": "9be24893.3fb948",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 860,
                                             "wires": [
                                                     "680cda98.c79904",
                                                     "bff952d4.2c202"
                                             "id": "680cda98.c79904",
                                             "d": true,
                                             "name": "Küche",
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2330,
                                             "y": 840,
                                             "wires": []
                                             "id": "c60e966b.faec78",
                                             "type": "debug",
                                             "name": "Flur",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2330,
                                             "y": 700,
                                             "wires": []
                                             "id": "fa3e96a8.7edc38",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 680,
                                             "wires": [
                                                     "f0a0c599.311628",
                                                     "c60e966b.faec78"
                                             "id": "f0a0c599.311628",
                                             "d": true,
                                             "name": "Flur",
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2330,
                                             "y": 660,
                                             "wires": []
                                             "id": "32d64871.5d6618",
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2350,
                                             "y": 540,
                                             "wires": []
                                             "id": "43619702.eb9618",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 520,
                                             "wires": [
                                                     "18ba5ed3.02b871",
                                                     "32d64871.5d6618"
                                             "id": "18ba5ed3.02b871",
                                             "d": true,
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2350,
                                             "y": 500,
                                             "wires": []
                                             "id": "8dc663ac.ad48c",
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2360,
                                             "y": 400,
                                             "wires": []
                                             "id": "4d667db0.e6ae24",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 380,
                                             "wires": [
                                                     "3b64abf8.4e46a4",
                                                     "8dc663ac.ad48c"
                                             "id": "3b64abf8.4e46a4",
                                             "d": true,
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2360,
                                             "y": 360,
                                             "wires": []
                                             "id": "92ea75ca.3e4688",
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 2360,
                                             "y": 200,
                                             "wires": []
                                             "id": "bbbcbe24.a8ad3",
                                             "type": "rbe",
                                             "name": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "start": "",
                                             "inout": "out",
                                             "septopics": true,
                                             "x": 2180,
                                             "y": 180,
                                             "wires": [
                                                     "45b23eda.84112",
                                                     "92ea75ca.3e4688"
                                             "id": "45b23eda.84112",
                                             "d": true,
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 2360,
                                             "y": 160,
                                             "wires": []
                                      Schau mal on das geht
                                      • mickymM mickym
                                               "type": "subflow",
                                               "in": [
                                                       "x": 40,
                                                       "y": 260,
                                                       "wires": [
                                               "out": [
                                                       "x": 1240,
                                                       "y": 260,
                                                       "wires": [
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                                               "port": 0
                                               "env": [],
                                               "meta": {},
                                               "color": "#FFAAAA",
                                               "outputLabels": [
                                                   "AUTO Temperatur"
                                               "type": "switch",
                                               "rules": [
                                                       "t": "btwn",
                                                       "v": "00:00",
                                                       "vt": "str",
                                                       "v2": "08:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "08:00",
                                                       "vt": "str",
                                                       "v2": "09:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "09:00",
                                                       "vt": "str",
                                                       "v2": "22:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "22:00",
                                                       "vt": "str",
                                                       "v2": "23:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "23:00",
                                                       "vt": "str",
                                                       "v2": "24:00",
                                                       "v2t": "str"
                                               "repair": false,
                                               "outputs": 5,
                                               "x": 780,
                                               "y": 160,
                                               "wires": [
                                                       "78e83c34.8e26f4"
                                                       "b43a5b2f.5ba228"
                                                       "c381b0fb.0c407"
                                                       "d7602741.e08ec8"
                                                       "67e1f0e6.98f84"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "json"
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 190,
                                               "y": 260,
                                               "wires": [
                                                       "fd8206e3.66bbf8"
                                               "type": "change",
                                               "name": "22 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "22",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 120,
                                               "wires": [
                                               "type": "change",
                                               "name": "17°C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 160,
                                               "wires": [
                                               "type": "change",
                                               "name": "22 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "22",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 200,
                                               "wires": [
                                               "type": "change",
                                               "name": "17 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 240,
                                               "wires": [
                                               "type": "switch",
                                               "rules": [
                                                       "t": "btwn",
                                                       "v": "00:00",
                                                       "vt": "str",
                                                       "v2": "08:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "08:00",
                                                       "vt": "str",
                                                       "v2": "09:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "09:00",
                                                       "vt": "str",
                                                       "v2": "22:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "22:00",
                                                       "vt": "str",
                                                       "v2": "23:00",
                                                       "v2t": "str"
                                                       "t": "btwn",
                                                       "v": "23:00",
                                                       "vt": "str",
                                                       "v2": "24:00",
                                                       "v2t": "str"
                                               "repair": false,
                                               "outputs": 5,
                                               "x": 780,
                                               "y": 380,
                                               "wires": [
                                                       "324ef3e0.d9ac1c"
                                                       "2c0b8bd8.778e14"
                                                       "5b0e8515.b3b32c"
                                                       "92ee1669.329f78"
                                                       "50a57933.3a77b8"
                                               "type": "change",
                                               "name": "22 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "22",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 340,
                                               "wires": [
                                               "type": "switch",
                                               "rules": [
                                                       "t": "regex",
                                                       "vt": "str",
                                                       "case": true
                                                       "t": "regex",
                                                       "vt": "str",
                                                       "case": true
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 2,
                                               "x": 430,
                                               "y": 260,
                                               "wires": [
                                                       "2961f12d.901f7e"
                                                       "a03bd421.d47bd8"
                                               "id": "5b0e8515.b3b32c",
                                               "type": "change",
                                               "z": "c2c0c34f.6e2ed",
                                               "name": "17 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 380,
                                               "wires": [
                                               "id": "92ee1669.329f78",
                                               "type": "change",
                                               "name": "22 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "22",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 420,
                                               "wires": [
                                               "id": "50a57933.3a77b8",
                                               "type": "change",
                                               "name": "17 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 460,
                                               "wires": [
                                               "id": "324ef3e0.d9ac1c",
                                               "type": "change",
                                               "name": "17 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 300,
                                               "wires": [
                                               "id": "78e83c34.8e26f4",
                                               "type": "change",
                                               "name": "17 °C",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "17",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 80,
                                               "wires": [
                                               "type": "inject",
                                               "props": [
                                                       "p": "ts",
                                                       "v": "",
                                                       "vt": "date"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "x": 230,
                                               "y": 640,
                                               "wires": [
                                                       "ba9950a5.49288"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "to": "Wohnzimmer",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 650,
                                               "y": 620,
                                               "wires": [
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 640,
                                               "y": 580,
                                               "wires": [
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 640,
                                               "y": 540,
                                               "wires": [
                                               "type": "change",
                                               "name": "Flur",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "to": "Flur",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 670,
                                               "y": 660,
                                               "wires": [
                                               "type": "change",
                                               "name": "Küche",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "to": "Küche",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 670,
                                               "y": 700,
                                               "wires": [
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "room",
                                                       "pt": "msg",
                                                       "to": "Badezimmer",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 650,
                                               "y": 740,
                                               "wires": [
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 420,
                                               "y": 640,
                                               "wires": [
                                                       "bf4c2ed6.98035",
                                                       "a8d50db9.c6774",
                                                       "7cb2eeb8.3e183",
                                                       "c4e28fa7.326bc",
                                                       "658a283c.e3df28",
                                                       "8d92ec5a.66a3e"
                                               "type": "inject",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": true,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "true",
                                               "x": 300,
                                               "y": 80,
                                               "wires": [
                                                       "e64a03f5.dab21"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "pt": "global",
                                                       "to": "payload",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 610,
                                               "y": 80,
                                               "wires": [
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "complete": "true",
                                               "statusVal": "",
                                               "x": 1410,
                                               "y": 700,
                                               "wires": []
                                               "name": "get mode",
                                               "topic": "",
                                               "attrname": "mode",
                                               "x": 1110,
                                               "y": 540,
                                               "wires": [
                                               "topic": "",
                                               "x": 1150,
                                               "y": 620,
                                               "wires": [
                                               "type": "switch",
                                               "property": "room",
                                               "propertyType": "msg",
                                               "rules": [
                                                       "t": "eq",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Wohnzimmer",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Flur",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Küche",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Badezimmer",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 6,
                                               "x": 1430,
                                               "y": 620,
                                               "wires": [
                                                       "e5a3e935.e886d8"
                                                       "972d9173.c7f3"
                                                       "ed377f3f.8544b"
                                                       "5d6d4c4f.91d114"
                                                       "38ccb111.f4e7fe"
                                                       "21e8fc89.707d14"
                                               "type": "switch",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1680,
                                               "y": 180,
                                               "wires": [
                                                       "d54c49bb.c74768"
                                                       "c184fb01.ebcca8"
                                                       "6529e1ae.5cd9"
                                                       "6dabe592.9faefc"
                                               "type": "switch",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1680,
                                               "y": 360,
                                               "wires": [
                                                       "724c420d.7bb4dc"
                                                       "c03eaf47.47cf8"
                                                       "472549e6.0d4678"
                                                       "331e3168.d80a6e"
                                               "type": "switch",
                                               "name": "Wohnzimmer",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1670,
                                               "y": 520,
                                               "wires": [
                                                       "75b189b0.a21ce8"
                                                       "8699996.589d768"
                                                       "53fd717d.05821"
                                                       "7459aba.9b79754"
                                               "type": "switch",
                                               "name": "Flur",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1650,
                                               "y": 680,
                                               "wires": [
                                                       "e5b821c6.408a"
                                                       "43795266.f0f97c"
                                                       "21ca5905.e8f226"
                                                       "27615a8c.7d6016"
                                               "type": "switch",
                                               "name": "Küche",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1670,
                                               "y": 860,
                                               "wires": [
                                                       "e0360495.4282d8"
                                                       "6192c71e.e14868"
                                                       "3af25a08.425dd6"
                                                       "90555796.db7908"
                                               "type": "switch",
                                               "property": "mode",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "AUTO",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "HEAT",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "OFF",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "ECO",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 4,
                                               "x": 1670,
                                               "y": 1040,
                                               "wires": [
                                                       "855f7739.710cf8"
                                                       "f0fac0a8.a938"
                                                       "be472598.070aa8"
                                                       "58de29bc.e3d6c8"
                                               "name": "",
                                               "x": 1930,
                                               "y": 980,
                                               "wires": [
                                                       "bb798b95.27ffe8"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 1020,
                                               "wires": [
                                                       "bb798b95.27ffe8"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 1060,
                                               "wires": [
                                                       "bb798b95.27ffe8"
                                               "topic": "",
                                               "x": 1140,
                                               "y": 700,
                                               "wires": [
                                                       "cb21ff74.eb4a9",
                                                       "62b671f6.c2aaf"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 1100,
                                               "wires": [
                                                       "bb798b95.27ffe8"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 840,
                                               "wires": [
                                                       "9be24893.3fb948"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 880,
                                               "wires": [
                                                       "9be24893.3fb948"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 920,
                                               "wires": [
                                                       "9be24893.3fb948"
                                               "name": "",
                                               "x": 1930,
                                               "y": 800,
                                               "wires": [
                                                       "9be24893.3fb948"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 660,
                                               "wires": [
                                                       "fa3e96a8.7edc38"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 700,
                                               "wires": [
                                                       "fa3e96a8.7edc38"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 740,
                                               "wires": [
                                                       "fa3e96a8.7edc38"
                                               "name": "",
                                               "x": 1930,
                                               "y": 620,
                                               "wires": [
                                                       "fa3e96a8.7edc38"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 500,
                                               "wires": [
                                                       "43619702.eb9618"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 540,
                                               "wires": [
                                                       "43619702.eb9618"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 580,
                                               "wires": [
                                                       "43619702.eb9618"
                                               "name": "",
                                               "x": 1930,
                                               "y": 460,
                                               "wires": [
                                                       "43619702.eb9618"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 340,
                                               "wires": [
                                                       "4d667db0.e6ae24"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 380,
                                               "wires": [
                                                       "4d667db0.e6ae24"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 420,
                                               "wires": [
                                                       "4d667db0.e6ae24"
                                               "name": "",
                                               "x": 1930,
                                               "y": 300,
                                               "wires": [
                                                       "4d667db0.e6ae24"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1900,
                                               "y": 160,
                                               "wires": [
                                                       "bbbcbe24.a8ad3"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1880,
                                               "y": 200,
                                               "wires": [
                                                       "bbbcbe24.a8ad3"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1890,
                                               "y": 240,
                                               "wires": [
                                                       "bbbcbe24.a8ad3"
                                               "name": "",
                                               "x": 1930,
                                               "y": 120,
                                               "wires": [
                                                       "bbbcbe24.a8ad3"
                                               "type": "debug",
                                               "name": "Badezimmer",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "statusType": "auto",
                                               "x": 2350,
                                               "y": 1080,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 1060,
                                               "wires": [
                                                       "6d76bee5.29833",
                                                       "a4444639.a32858"
                                               "d": true,
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2350,
                                               "y": 1040,
                                               "wires": []
                                               "type": "debug",
                                               "name": "Küche",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2330,
                                               "y": 880,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 860,
                                               "wires": [
                                                       "680cda98.c79904",
                                                       "bff952d4.2c202"
                                               "d": true,
                                               "name": "Küche",
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2330,
                                               "y": 840,
                                               "wires": []
                                               "type": "debug",
                                               "name": "Flur",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2330,
                                               "y": 700,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 680,
                                               "wires": [
                                                       "f0a0c599.311628",
                                                       "c60e966b.faec78"
                                               "d": true,
                                               "name": "Flur",
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2330,
                                               "y": 660,
                                               "wires": []
                                               "type": "debug",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2350,
                                               "y": 540,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 520,
                                               "wires": [
                                                       "18ba5ed3.02b871",
                                                       "32d64871.5d6618"
                                               "d": true,
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2350,
                                               "y": 500,
                                               "wires": []
                                               "type": "debug",
                                               "name": "Schlafzimmer",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2360,
                                               "y": 400,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 380,
                                               "wires": [
                                                       "3b64abf8.4e46a4",
                                                       "8dc663ac.ad48c"
                                               "d": true,
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2360,
                                               "y": 360,
                                               "wires": []
                                               "type": "debug",
                                               "name": "Kinderzimmer",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 2360,
                                               "y": 200,
                                               "wires": []
                                               "type": "rbe",
                                               "name": "",
                                               "func": "rbe",
                                               "gap": "",
                                               "start": "",
                                               "inout": "out",
                                               "septopics": true,
                                               "x": 2180,
                                               "y": 180,
                                               "wires": [
                                                       "45b23eda.84112",
                                                       "92ea75ca.3e4688"
                                               "d": true,
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 2360,
                                               "y": 160,
                                               "wires": []
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        #323
                                        @mickym Gleiche Fehlermeldung -.-
                                        J._def is undefined
                                        Die anderen .json konnte ich ja auch problemlos importieren und habe das auch als Datei gemacht
                                        • Marko1974M Marko1974
                                          J._def is undefined
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #324
                                          @marko1974 Kannst Du mal den Browser schließen und Cache löschen .
                                          Schau mal ob Du irgendein anderen Flow hier aus dem Thread importieren kannst - nicht dass da irgendwo der Wurm drin ist.
                                          Gut da verpacke ich das mal in kleine Teile und Du sagst ob s geht oder nicht.
