  4. [[GELÖST]] HM-REGA HM-RPC
    2.3k
    4.3k
6 Beiträge 2 Kommentatoren 1.8k Aufrufe
    muckel
    Hallo IoBroker Spezialisten
    Ich habe seit heute seltsame Abstürze des IoBroker.
    Sagt euch dieses log etwas?
    Danach ist alles eingefrohren. kein zugriff per web oder SSH mehr möglich.
    am raspi 2 leuchtet nur die HDD LED permanent.
    danke im voraus
    lg.
    host.iobroker	2017-02-27 19:26:57.025	info	Restart adapter system.adapter.hm-rega.0 because enabled
    host.iobroker	2017-02-27 19:26:57.024	error	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
    hm-rega.0	2017-02-27 19:26:56.960	info	terminating
    hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    hm-rega.0	2017-02-27 19:26:56.929	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:1353:39)
    hm-rega.0	2017-02-27 19:26:56.929	error	TypeError: Cannot set property 'hm-rpc.0.info' of null
    hm-rega.0	2017-02-27 19:26:56.909	error	uncaught exception: Cannot set property 'hm-rpc.0.info' of null
    • apollon77A Online
      apollon77A Online
      Einmalig oder mehrfach passiert? Läuft es wieder wenn Du alles neu startest?
        muckel
        Hallo Apollon77!
        es passiert immer wieder; aber nur wenn ich meine Skripte laufen habe mit SayIt Ausgabe auf Sonos.
        Das Skript funktioniert aber. Manchmal hängt die Sprachausgabe.
        Dann frisst das System Speicher bis nur noch wenige MB übrig sind und dann hängt er sich auf.
        Diesen Speicherfresser-Prozess kann ich auch nicht mehr stoppen, wenn ich alle Adapter deaktiviere.
        RAM Verbraucht 384 / RAM Frei 520 Normal
        RAM Verbraucht 384 / RAM Frei 9 dann hängt er.
        2 Skripte gleich aufgebaut 1 x Trockner und 1 x Waschmaschine
        Mit Blockly gebaut:
        Hast eine Idee ??? :roll:
        var Intervall;
        on({id: 'hm-rega.0.1422', change: "any"}, function (obj) {
          var value = obj.state.val;
          if (getState("hm-rega.0.1422").val == true) {
            setState("sayit.0.tts.text", "de-DE_CLOUD_Female;70;" + 'Der Trockner ist eingeschaltet');
            console.log("sayIt[de-DE_CLOUD_Female][Volume - 70]: " + 'Der Trockner ist eingeschaltet');
          if (getState("hm-rega.0.1422").val == false) {
            Intervall = setInterval(function () {
              while (!(getState("hm-rpc.0.0001D3C996146A.6.CURRENT").val == 0)) {
                setState("sayit.0.tts.text", "de-DE_CLOUD_Female;70;" + 'Der Trockner ist fertig');
                console.log("sayIt[de-DE_CLOUD_Female][Volume - 70]: " + 'Der Trockner ist fertig');
            }, 600000);
        • apollon77A Online
          apollon77A Online
          Dann update hm-rega mal vom Github… dann ggf hm-rega neu starten und dann sag mal obs noch passiert
            muckel
            Hallo Apollon77
            seit 1.4.4 stürzt er nicht mehr ab! :D
            Thank You!
            • apollon77A Online
              apollon77A Online
              super, schreibst Du bitte noch ein "gelöst" in den Thread titel?! Danke
              Kommt dann offiziell ins npm
