  4. FullyKioskBrowser, Tablet, ioBroker keine Reaktion
    6.3k
17 Beiträge 3 Kommentatoren 646 Aufrufe 3 Beobachtet
  • Tobias-KriegT Tobias-Krieg
    @thomas-braun Hallo Thomas, ich habe den Adapter (Rebuild) und die Instanz (Neustart) geloggt:
    2021-11-09 12:51:11.247 - info: host.iobroker stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
    2021-11-09 12:51:11.258 - info: host.iobroker stopInstance system.adapter.fullybrowser.0 send kill signal
    2021-11-09 12:51:11.825 - info: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-09 12:51:14.386 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 17846
    2021-11-09 12:51:37.669 - info: host.iobroker stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
    2021-11-09 12:51:37.679 - info: host.iobroker stopInstance system.adapter.fullybrowser.0 send kill signal
    2021-11-09 12:51:38.279 - info: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-09 12:51:40.804 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 17901
    2021-11-09 12:52:34.895 - info: web.0 (13945) <==Disconnect system.user.admin from ::ffff:192.168.178.52 vis.0
    2021-11-09 12:52:35.899 - warn: web.0 (13945) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2021-11-09 12:52:53.095 - info: host.iobroker iobroker rebuild fullybrowser
    2021-11-09 12:52:53.876 - info: host.iobroker iobroker npm rebuild --loglevel error (System call1) in "/opt/iobroker/node_modules/iobroker.fullybrowser"
    2021-11-09 12:52:54.658 - info: host.iobroker iobroker
    2021-11-09 12:52:54.659 - info: host.iobroker iobroker Rebuild fullybrowser done
    2021-11-09 12:52:55.680 - info: host.iobroker iobroker exit 0
    Wirklich schlau werde ich daraus nicht!
    Beste Grüße
    Tobias
    @tobias-krieg sagte in FullyKioskBrowser, Tablet, ioBroker keine Reaktion:
    Das sollte eigentlich nur bei Upgrades von nodeJS oder sowas passieren.
    Ist das denn 'senkrecht' im System?
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    Tobias-KriegT 1 Antwort Letzte Antwort
      Tobias-KriegT Offline
      Tobias-Krieg
      @thomas-braun was genau meinst Du mit "senkrecht" im System?
        @tobias-krieg
        Ob das ordentlich und sauber installiert wurde. Kann man anhand der Ausgaben zur obigen Befehlskette sehen.
        • Tobias-KriegT Offline
          Tobias-Krieg
          @thomas-braun sagte in FullyKioskBrowser, Tablet, ioBroker keine Reaktion:
          Putty gibt folgendes aus:
          /usr/bin/node
          /usr/bin/npm
          Viele Grüße
            /usr/bin/node
            /usr/bin/npm
            Viele Grüße
            @tobias-krieg
            Okay, da fehlt (aus meiner Sicht) noch was:
            Dann nochmal wie oben.
              @tobias-krieg
              Tobias-Krieg
              Okay die Ausgabe zeigt nun mehr:
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.6
              v12.22.6
              6.14.15
              Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
              Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              Get:3 https://deb.nodesource.com/node_12.x buster InRelease [4,584 B]
              Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
              Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
              Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
              Get:7 https://deb.nodesource.com/node_12.x buster/main armhf Packages [777 B]
              Get:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
              Fetched 13.6 MB in 6s (2,144 kB/s)
              Reading package lists... Done
              Building dependency tree
              75 packages can be upgraded. Run 'apt list --upgradable' to see them.
              N: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
              nodejs:
                Installed: 12.22.6-deb-1nodesource1
                Candidate: 12.22.7-deb-1nodesource1
                Version table:
                   12.22.7-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               *** 12.22.6-deb-1nodesource1 100
                   10.24.0~dfsg-1~deb10u1 500
              Gruß Tobias
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.6
                v12.22.6
                6.14.15
                nodejs:
                  Version table:
                Gruß Tobias
                @tobias-krieg
                Grundsätzlich passt das schon, ich würde allerdings die 75 Updates einspielen. Da ist auch eine neue Version von nodeJS dabei.
                Tobias-KriegT 2 Antworten Letzte Antwort
                  @tobias-krieg Bitte mal den vollständigen (Neu)-Start des Adapters loggen. Mit den mageren drei Zeilen kann man nicht viel anfangen.
                  Und lieber statt in Spoiler in CodeTags setzen.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Tobias-Krieg
                  Ausgabe in der Logstufe DEBUG hier einstellen
                    @tobias-krieg
                    Tobias-Krieg
                    @thomas-braun Vielen Dank für den Hinweis. Update mit folgenden Kommando's, richtig:
                    sudo apt-get update
                    sudo apt-get full-upgrade
                    Beste Grüße
                    • GlasfaserG Glasfaser
                      @Tobias-Krieg
                      Tobias-Krieg
                      @glasfaser Hallo Glasfaser, hier die Ausgabe (Debug):
                      fullybrowser.0 2021-11-09 14:25:29.238	warn	updateDeviceERROR 192.168.178.52
                      fullybrowser.0 2021-11-09 14:25:27.228	debug	get Information
                      fullybrowser.0	2021-11-09 14:25:15.217	warn	updateDeviceERROR 192.168.178.52
                      fullybrowser.0	2021-11-09 14:25:13.209	debug	get Information
                      fullybrowser.0	2021-11-09 14:25:01.200	warn	updateDeviceERROR 192.168.178.52
                      fullybrowser.0	2021-11-09 14:25:00.258	debug	get Information
                      fullybrowser.0	2021-11-09 14:25:00.049	warn	Generate State problem 192_168_178_52 {"message":"timeout of 2000ms exceeded","name":"Error","stack":"Error: timeout of 2000ms exceeded\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/axios/lib/adapters/http.js:303:16)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.178.52:2323/?cmd=deviceInfo&type=json&password=060616","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.4"},"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false}},"code":"ECONNABORTED"}
                      fullybrowser.0	2021-11-09 14:24:57.968	info	Start with IP : 192.168.178.52
                      fullybrowser.0	2021-11-09 14:24:57.967	debug	create state
                      fullybrowser.0	2021-11-09 14:24:57.933	info	starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v12.22.7, js-controller: 3.3.18
                      fullybrowser.0	2021-11-09 14:24:57.779	debug	statesDB connected
                      fullybrowser.0	2021-11-09 14:24:57.778	debug	States connected to redis: 127.0.0.1:9000
                      fullybrowser.0	2021-11-09 14:24:57.770	debug	States create User PubSub Client
                      fullybrowser.0	2021-11-09 14:24:57.769	debug	States create System PubSub Client
                      fullybrowser.0	2021-11-09 14:24:57.761	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      fullybrowser.0	2021-11-09 14:24:57.758	debug	objectDB connected
                      fullybrowser.0	2021-11-09 14:24:57.749	debug	Objects connected to redis: 127.0.0.1:9001
                      fullybrowser.0	2021-11-09 14:24:57.726	debug	Objects client initialize lua scripts
                      fullybrowser.0	2021-11-09 14:24:57.725	debug	Objects create User PubSub Client
                      fullybrowser.0	2021-11-09 14:24:57.723	debug	Objects create System PubSub Client
                      fullybrowser.0	2021-11-09 14:24:57.721	debug	Objects client ready ... initialize now
                      fullybrowser.0	2021-11-09 14:24:57.682	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.iobroker	2021-11-09 14:24:56.600	info	instance system.adapter.fullybrowser.0 started with pid 1082
                      host.iobroker	2021-11-09 14:24:54.132	info	instance system.adapter.fullybrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      host.iobroker	2021-11-09 14:24:53.513	info	stopInstance system.adapter.fullybrowser.0 send kill signal
                      host.iobroker	2021-11-09 14:24:53.493	info	stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
                        @tobias-krieg
                        Tobias-Krieg
                        @thomas-braun Habe ein vollständiges Update gemacht...
                        Viele Grüße
                          @Tobias-Krieg
                          Tobias-Krieg
                          Hallo @glasfaser hast Du noch einen Tipp für mich? Die Ausgabe im Debug Mode habe ich Dienstag gepostet.
                          Vielen Dank für Deine Unterstützung.
