  4. Conbee2 Stick wird nicht vom Zigbee Adapter erkannt
    6.4k
22 Beiträge 4 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • S spooky82
    ok...Zunächst aus dem Terminal:
    root@ioBroker:/# cd dev
    root@ioBroker:/dev# cd serial
    bash: cd: serial: Datei oder Verzeichnis nicht gefunden
    MOD-Edit: Code in code-tags gesetzt!
    Wie gesagt: Der Ordner existiert nicht
    Und das Log:
    	Zeit
    error
    Nachricht
    host.ioBroker
    2021-11-07 18:55:30.851	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    2021-11-07 18:55:30.306	error	Cannot read property 'getEntries' of null
    zigbee.0
    2021-11-07 18:55:30.306	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:95:5)
    zigbee.0
    2021-11-07 18:55:30.305	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    2021-11-07 18:55:30.305	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2021-11-07 18:55:30.298	error	Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXX'
    zigbee.0
    2021-11-07 18:55:30.298	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXX' at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:160:28) at Generator.next (<anonymous>) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71 at new Promise (<anonymous>) at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12) at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:158:45) at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0
    2021-11-07 18:55:30.297	error	unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXX'
    zigbee.0
    2021-11-07 18:55:30.297	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2021-11-07 18:55:10.359	error	Error herdsman start
    zigbee.0
    2021-11-07 18:55:10.359	error	Failed to start Zigbee
    zigbee.0
    2021-11-07 18:55:10.358	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXX'"
    zigbee.0
    2021-11-07 18:55:00.301	error	Error herdsman start
    zigbee.0
    2021-11-07 18:55:00.301	error	Failed to start Zigbee
    Ich kann also garnicht herausfinden, wie mein Device heißt.
    Liegt es evtl daran, dass Deconz Adapter installiert ist?
    @spooky82
    KEIN ROOT-LOGIN!!!!
    Vor allen Dingen nicht wenn man offenbar komplett keine Ahnung vom System hat...
    Verzeichnisse mit absolutem Pfad wechselt man mit
    cd /dev/serial
    Konsolenoutput in CodeTags setzen.
      @spooky82
      KEIN ROOT-LOGIN!!!!
      cd /dev/serial
      spooky82
      @thomas-braun said in Conbee2 Stick wird nicht vom Zigbee Adapter erkannt:
      cd /dev/serial
      Danke für das wertvolle Kommentar.
      Ein Profi in ioBroker bin ich in der Tat nicht.
      Allerdings ändert root nichts an der Tatsache, dass der Ordner /dev/serial nunmal nicht existiert.
      • S spooky82
        cd /dev/serial
        @spooky82 sagte in Conbee2 Stick wird nicht vom Zigbee Adapter erkannt:
        aber das Nutzen von root verbiegt die Rechte
        • S spooky82
          cd /dev/serial
          @spooky82
          Wer die Eier hat, als root herum zu machen sollte halt auch die dafür erforderliche Ahnung haben.
          Als User einloggen!
          Und die Befehle von oben nachreichen!
            spooky82
            Hast du das gemeint? Oder etwas anderes?
            iobroker@ioBroker:~$ cd /dev/serial
            bash: cd: /dev/serial: Datei oder Verzeichnis nicht gefunden
            Und:
            iobroker@ioBroker:~$ systemctl status deconz deconz-gui
            System has not been booted with systemd as init system (PID 1). Can't operate.
            Failed to connect to bus: Der Rechner ist nicht aktiv
            • S spooky82
              Und:
              @spooky82
              Was hast du da für ein OS laufen?
              Als iobroker loggt man sich auch nicht ein, das ist eigentlich ein Systemuser ohne Login.
              Hast du keinen normalen User?
              lsb_release -a
              bringt?
                @spooky82
                lsb_release -a
                bringt?
                spooky82
                schrieb am zuletzt editiert von spooky82
                buanet/ioBroker.docker auf einem NAS
                SSH nutze ich normalerweise auch nicht und habe deshalb auch keinen User
                iobroker@ioBroker:~$ lsb_release -a
                No LSB modules are available.
                Distributor ID: Debian
                Description:    Debian GNU/Linux 10 (buster)
                Release:        10
                Codename:       buster
                • S spooky82
                  Release:        10
                  Codename:       buster
                  @spooky82
                  Du sagst doch der Stick ist im Raspberry eingesteckt?
                  Dann muss du auch auf dem System danach schauen. Bist du jetzt die ganze Zeit auf dem NAS herumgesprungen?
                    @spooky82
                    spooky82
                    @thomas-braun Ja :man-facepalming:
                    das heißt, ich muss den deconz service auf dem Raspi stoppen?
                    • S spooky82
                      @spooky82
                      Logisch...
                        @spooky82
                        Logisch...
                        spooky82
                        @thomas-braun Ok, also um ehrlich zu sein raffe ich das ganze Konstrukt nicht.
                        Der Conbee ist ja nicht direkt am NAS angeschlossen. Ich müsste ja im Adapter (ähnlich wie im Deconz Adapter) zumindest eine IP des entfernten Raspi angeben, oder?
                        Wo und wie mache ich das?
                        • S spooky82
                          @spooky82
                          ZigBee-Adapter-Instanz auf dem Raspberry betreiben (Stichwort Multihost).
                          Dann den Stick wie lokal behandeln, inkl. device link auf dem lokalen System. Die Daten werden dann an den ioBroker auf dem NAS übertragen.
                            @spooky82
                            spooky82
                            @thomas-braun Danke - so ergibt das Sinn.
                            Ich mache mich mal schlau, wie das gehen kann - auf dem Raspi läuft auch noch eine Homebridge.
                            • S spooky82
                              Sollte kein Problem geben. Das rennt ja auch schon mit nodeJS.
