  4. SONOFF ZigBee 3.0 USB DONGLE PLUS
    6.4k
sonoff zigbee
435 Beiträge 50 Kommentatoren 158.1k Aufrufe 48 Beobachtet
    @hm_krause
    Cannot read property 'getDevice' of undefined
    Warum kann das da nicht gelesen werden frage ich mich.
    Mal den Fixer ausgeführt?
    iobroker stop
    iobroker fix
    iobroker start
    hm_krause
    #84
    das kommt noch vorher:
    zigbee.0
    	2021-10-25 16:54:55.932	info	terminating
    zigbee.0
    	2021-10-25 16:54:55.931	warn	Failed to stop zigbee during startup
    zigbee.0
    	2021-10-25 16:54:55.781	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2021-10-25 16:54:55.767	info	cleaned everything up...
    zigbee.0
    	2021-10-25 16:54:55.753	error	Cannot read property 'getDevice' of undefined
    zigbee.0
    	2021-10-25 16:54:55.751	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
    zigbee.0
    	2021-10-25 16:54:55.722	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
    zigbee.0
    	2021-10-25 16:54:55.721	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2021-10-25 16:54:50.203	info	Installed Version: iobroker.zigbee@1.6.3
    zigbee.0
    	2021-10-25 16:54:50.042	error	Error herdsman start
    zigbee.0
    	2021-10-25 16:54:50.041	error	Failed to start Zigbee
    zigbee.0
    	2021-10-25 16:54:50.040	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open com: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_1469408ef193eb1180efaa5b3d98b6d1-if00-port0'"
    zigbee.0
    	2021-10-25 16:54:49.750	info	Starting Zigbee npm ...
    zigbee.0
    	2021-10-25 16:54:49.647	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.1, js-controller: 3.3.18
    • H hm_krause
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      #85
      @hm_krause sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
      ls -la /dev/serial/by-id/
      H 1 Antwort Letzte Antwort
        hm_krause
        #86
        pi@iobroker:~ $ ls -la /dev/serial/by-id/
        insgesamt 0
        drwxr-xr-x 2 root root 60 Okt 25 16:49 .
        drwxr-xr-x 4 root root 80 Okt 25 16:49 ..
        lrwxrwxrwx 1 root root 13 Okt 25 16:49 usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_1469408ef193eb1180efaa5b3d98b6d1-if00-port0 -> ../../ttyUSB0
        • M m0skit0
          @jleg
          @Thomas-Braun
          jetzt wird es leider für mich zu kompliziert, ich bin Linux Anfänger.
          Aber vlt. kann mir ja einer von euch beiden, mal eine Hilfestellung geben wie ich das von euch vorgeschlagene umsetzen kann.
          Wäre sehr dankbar
          lg
          m0skit0
          JLegJ Offline
          JLegJ Offline
          JLeg
          #87
          @m0skit0 nur für's grobe Prüfen, ob das Problem "nur" an Zugriffsrechten liegt:
          • vorausgesetzt, dein Stick ist derzeit unter /dev/USB1 angeschlossen,
          • zeige mal: 'ls -al /dev/USB1' a) auf dem Proxmox-Node, b) im LXC
          • zeige mal: 'groups iobroker' bzw. prüfe, ob die Gruppe "dialout" enthalten ist
          ich bin nicht ganz sicher, ob deine Fehlermeldung zu fehlenden Zugriffrechten passt (bei einem "permission denied" wär's klarer), aber der Versuch kostet ja nicht viel...
          • H Offline
            hertob81
            #88
            @Jan-1 bzw. an diejenigen, die das Teil schon am laufen haben:
            Wie finde ich heraus, welche (Xiaomi)-Produkte kompatibel sind beziehungsweise, welche Produkte hast Du, @Jan-1 , am laufen?
            Ich habe nämlich diese hier im Einsatz und kann sie nicht einbinden.
            Nun hätte ich gerne gewusst, ob es einfach an den Endgeräten liegt, oder ob ich irgendwas in den Settings falsch eingestellt habe. Wobei ich mich durch den Thread gearbeitet und eigentlich alles laufen sollte.
            MFG Tobias
            • H hertob81
              MFG Tobias
              #89
              @hertob81
              Xiaomi Mijia Thermometer 2 Bluetooth-kompatibel
              Nix Zigbee, die Dinger sprechen Bluetooth.
              • H Offline
                hertob81
                schrieb am zuletzt editiert von hertob81
                #90
                Ah okay, dann ist es klar.... 🙄
                Empfehlungen bzgl. Thermostate und Fensterkontakte in Verbindung mit dem Stick?
                Sowas und sowas ?
                D ? 2 Antworten Letzte Antwort
                • H hertob81
                  Sowas und sowas ?
                  dimaiv
                  #91
                  @hertob81 sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                  Sowas und sowas ?
                  Ja und ja.
                  ioBroker- NUC8i3 / Proxmox / VM
                  Node.js v22.21.0
                  NPM v10.9.4
                  JS controller 7.1.0
                  Admin 7.7.20
                  ZigBee Adapter 3.3.1alpha.0
                  Zigbee LAN Gateway CC2652P
                  Zigbee Firmware 20250321
                  • H hertob81
                    Sowas und sowas ?
                    #92
                    @hertob81 said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                    Wenn das Hermes Tracking stimmt, dann kommt mein Stick heute an und ich kann testen. Habe diesen Sensor mit Dispaly hier stehen.
                    Von der Anzeige erscheint er mir derzeit etwa 1-0,5°C daneben zu liegen, aber laut Zigbee2Mqtt gibt es ja noch irgendwelche Kalibrierungsoptionen, die ich aber erst mit Stick testen kann.
                      hertob81
                      #93
                      @pete0815
                      Okay, über ein Feedback würde ich mich freuen.
                      Kurzes off-topic:
                      Wie zuverlässig funktioniert denn der Lux-Sensor?
                      VG Tobias
                      • H hertob81
                        @pete0815
                        Kurzes off-topic:
                        VG Tobias
                        #94
                        @pete0815
                        Kurzes off-topic:
                        VG Tobias
                        Nuja, mein bisheriger Eindruck. Zum detektieren ob es Hell oder Dunkel ist, reicht es. Wirklich mehr oder zeitkritische Dinge erscheinen mir darüber schwer realisierbar. Man findet einige Hinweise, dass die Helligkeit nicht unbedingt übertragen wird (per Zigbee), aus der Beschreibung von Zigbee2Mqtt gehe ich aber davon aus, dass es funktioniert....mehr nicht.
                        Insofern sollte man allgemein (auch Temp&Humidity) genau überlegen wozu man den Sensor einsetzen kann. Regelungen die öfters Werte benötigen um darauf etwas zu aktivieren/deaktivieren wird sich zeigen.
                        Ich möchte den Sensor als zweiten Raumfühler einsetzen (Neben dem Zigbee Ventilthermostat) um eine Referenz aus dem Raum zu haben. Ob das wirklich hinhaut muß ich erst prüfen, ob das wirklich eine vernünftigen Mehrwert mit dem Ding bringt. Viel schneller sind die Aqaras jedoch auch nicht....mal testen.
                        • H hm_krause
                          insgesamt 0
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #95
                          @hm_krause Bitte sicherstellen das in den Einstellungen der Serielle Port ohne führende oder folgende Leerzeichen angegeben ist. Die Ausgabe im Log könnte auf ein Leerzeichen vor dem ersten / hindeuten. Damit erkennt dann der herdsman den port nicht.
                          A.
                          • AsgothianA Asgothian
                            A.
                            hm_krause
                            #96
                            @asgothian
                            ...leider, auch kein Leerzeichen. Das Teil will einfach nicht laufen.
                            • H hm_krause
                              @asgothian
                              hm_krause
                              #97
                              @hm_krause
                              Als erstes Danke für Eure Hilfe!!!
                              Habe nun den IOBroker komplett neu auf einer anderen SD Karte installiert. Als Adapter nur den Zigbee.
                              Hier konnte ich den Dongle einbinden (mit ttyUSB0) und der Adapter startet.
                              Wieder zurück auf andere Karte (SSD Platte), alle Adapter gestoppt außer den Zigbee und siehe da, er startet.
                              danach alle anderen Adapter gestartet und es läuft, warum auch immer.
                              Nun noch zwei Verständnissfragen:
                              1. Bedeutet die Zahl bei den gepairten Geräten (neben dem Verbindungssymbol) im Zigbee Adapter die Empfansstärke
                                (ist mit dem Dongel kleiner z.B. 75 und mit dem Conbee 2 90)
                              2. Kann ich eien Rapi Zero mit IOBroker als Slave nur mit Zigbee Adapter (hier mit dem Conbee2 Stick) als
                                Reichweitenerweiterung einsetzen.
                              • JLegJ JLeg
                                m0skit0
                                #98
                                @jleg
                                auf dem node habe ich folgende Anzeige:
                                root@server:~# ls -la /dev/ttyUSB0
                                crw-rw-rw- 1 root dialout 188, 0 Oct 27 07:17 /dev/ttyUSB0
                                auf den Container:
                                root@iobroker-Produktiv:~# ls -la /dev/ttyUSB0
                                ls: cannot access '/dev/ttyUSB0': No such file or directory
                                lg m0skit0
                                • H hm_krause
                                  @hm_krause
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #99
                                  Ja. Wobei der Absolute Wert sowieso mit Vorsicht zu geniessen ist.
                                  Meines Wissens nach nein. Mir ist keine Firmware für den Conbee2 bekannt die daraus einen Repeater macht. Als Koordinator kann er dem Netz nicht zusätzlich beitreten. Über die deconz GUI scheint es so zu sein das man den Stick in ein bestehendes Netz mit aufnehmen kann um im Netz zu lauschen - ich gehe aber fest davon aus das das beim Zigbee Adapter so nicht gehen wird.
                                  A.
                                  • M m0skit0
                                    @jleg
                                    auf den Container:
                                    lg m0skit0
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #100
                                    @m0skit0 Hast du den Seriellen Port an den Container weitergereicht ? Das ist im Standard nicht der Fall.
                                    A.
                                      A.
                                      hm_krause
                                      schrieb am zuletzt editiert von hm_krause
                                      #101
                                      @asgothian
                                      alles klar, Danke
                                      Also bleibt mir nur der TRÅDFRI Signalverstärker zur Reichweitenerweiterung?
                                      Oder gibt es andere Empfehlungen
                                        A.
                                        m0skit0
                                        #102
                                        @asgothian
                                        ja den habe ich eingetragen in der config des Containers
                                        • M m0skit0
                                          @asgothian
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #103
                                          @m0skit0 sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                                          @asgothian
                                          Da passt etwas dann nicht. Prüf bitte nochmal das die Einstellungen korrekt sind und verifiziere via ls /dev/tty* auf der Console des Containers das ein Port da ist.
                                          A.
