  4. Test Adapter Tado v0.3.0-x (PreRelease)
tadotestv0.3.0
67 Beiträge 10 Kommentatoren 9.4k Aufrufe 10 Beobachtet
  • H HGlab
    @k_o_bold
    das klingt gut!
    Kannst du mir bitte ein Log posten auf dem man diese Logik sieht. Nur damit ich sehe ob es so funkt wie ich es mir gedacht habe :-).
    Danke!
    K_o_bold
    @hglab ,
    nach etwas ausgiebigerem Test gibt es wohl doch noch ein Problem...
    Im Vergleich zu vorher kommt jetzt nur noch ein error und der Adapter startet neu.
    tado.0	2021-10-08 07:28:54.247	error	(20483) Issue at setZoneOverlay: 'Error: Request failed with status code 422'. Based on config {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedAp
    tado.0	2021-10-08 07:28:53.357	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '6' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
    tado.0	2021-10-08 07:28:53.356	info	(20483) Temperature changed for room '6' in home '421159' to '22'
    tado.0	2021-10-08 07:28:45.724	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '4' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":5}},"termination":{"typeSkillBasedApp":"MANUAL","durationInS
    tado.0	2021-10-08 07:28:45.724	info	(20483) Temperature changed for room '4' in home '421159' to '5'
    tado.0	2021-10-08 07:28:38.342	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '11' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":18}},"termination":{"typeSkillBasedApp":"TADO_MODE","durati
    tado.0	2021-10-08 07:28:38.342	info	(20483) Temperature changed for room '11' in home '421159' to '18'
    tado.0	2021-10-08 07:28:37.355	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '10' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":21}},"termination":{"typeSkillBasedApp":"TADO_MODE","durati
    tado.0	2021-10-08 07:28:37.354	info	(20483) Temperature changed for room '10' in home '421159' to '21'
    tado.0	2021-10-08 07:28:36.343	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '9' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":19}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
    tado.0	2021-10-08 07:28:36.343	info	(20483) Temperature changed for room '9' in home '421159' to '19'
    tado.0	2021-10-08 07:28:35.340	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '8' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
    tado.0	2021-10-08 07:28:35.340	info	(20483) Temperature changed for room '8' in home '421159' to '22'
    tado.0	2021-10-08 07:28:34.341	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '7' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":21}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
    tado.0	2021-10-08 07:28:34.341	info	(20483) Temperature changed for room '7' in home '421159' to '21'
    tado.0	2021-10-08 07:28:32.373	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '4' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":19}},"termination":{"typeSkillBasedApp":"MANUAL","durationIn
    tado.0	2021-10-08 07:28:32.373	info	(20483) Temperature changed for room '4' in home '421159' to '19'
    tado.0	2021-10-08 07:28:31.344	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '3' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
    tado.0	2021-10-08 07:28:31.343	info	(20483) Temperature changed for room '3' in home '421159' to '22'
    tado.0	2021-10-08 07:28:30.359	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '2' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":18}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
    tado.0	2021-10-08 07:28:30.358	info	(20483) Temperature changed for room '2' in home '421159' to '18'
    scenes.0	2021-10-08 07:28:29.542	info	(1205) State value to set for "scene.0.0_Szene_Heizplan_Tag" has to be type "boolean" but received type "string"
    tado.0	2021-10-08 07:28:29.358	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '1' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":23}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
    tado.0	2021-10-08 07:28:29.357	info	(20483) Temperature changed for room '1' in home '421159' to '23'
    • K K_o_bold
      @hglab , @Globe ,
      ich habe die gleichen error Meldungen.
      Beobachtet habe ich, dass es mit dem Aktualisierungsintervall zu tun haben muss.
      Wenn ich den Aktualisierungsintervall auf 30s habe, dann kommen diese errors sehr häufig.
      Und zwar immer dann, wenn genau zu dem Zeitpunkt des Aktualisierungsintervalls die API angesprochen wird und gleichzeitig ein Thermostat getriggert wird.
      Wenn ich das Aktualisierungsintervall z.B. auf 300 s einstelle, kommen die errors deutlich seltener.
      Beispiel: Aktualisierungsintervall 300 s
      Heute früh um 5 Uhr hat mein Skript alle 9 Thermostate problemlos getriggert.
      Um 5:04 Uhr wurden nochmal 3 Thermostate getriggert, weil das Fenster offen war und dabei sind die errors entstanden.
      Meine 9 Thermostate werden im sekundentakt über ein Skript angesprochen. Hat seither super funktioniert. Ich nutze die aktuellste Adapter Version 0.3.....
      (22244) Request failed with status code 422
      error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      error	at endReadableNT (_stream_readable.js:1241:12)
      error	at IncomingMessage.EventEmitter.emit (domain.js:483:12)
      error	at IncomingMessage.emit (events.js:326:22)
      error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      error	(22244) Error: Request failed with status code 422
      error	(22244) unhandled promise rejection: Request failed with status code 422
      error	(22244) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      @k_o_bold sagte in Test Adapter Tado v0.3.0-x (PreRelease):
      Ist vielleicht auch etwas häufig. Warum spricht man die Heizung sekündlich an?
      H K 2 Antworten Letzte Antwort
        HGlab
        schrieb am zuletzt editiert von HGlab
        Ich denke auch, dass man da an den Scripts was machen sollte. Ich denke das hier wirklich schon der Tado-Server auf DoS schaltet. Im Adapter das zu vermeiden ist natürlich auch irgendwie möglich, aber schon recht kompliziert. Den 2 Calls hintereinander innerhalb von 1 bis 2 Sekunden ist wohl in Ordnung, wenn es dann aber 10 Calls sind mit jeweils einer Sekunde dann nicht mehr...
        Was nun im Adapter abgefangen ist, dass immer nur EIN PUT/POST/DELETE zugleich gemacht werden kann. GET können weiterhin parallel gemacht werden.
        Um nochmals sicher zu gehen! Du nutzt die Insgtallation über:
        DrozmotiX/ioBroker.tado#87d98e9490feee5d2f1bfdd8046c80182e3285fb
        • H HGlab
          K_o_bold
          @hglab ,
          ich habe jetzt eine Verzögerung von 5 s pro Thermostat definiert. ( 5 s Takt ).
          Ich nutze die von dir empfohlene Version und habe sie so wie du im Screenshot dargestellt installiert.
          tado.0	2021-10-08 08:12:26.386	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '7' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":5}},"termination":{"typeSkillBasedApp":"TADO_MODE","duration
          tado.0	2021-10-08 08:12:26.386	info	(20483) Temperature changed for room '7' in home '421159' to '5'
          tado.0	2021-10-08 08:12:25.229	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '11' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":18}},"termination":{"typeSkillBasedApp":"TADO_MODE","durati
          tado.0	2021-10-08 08:12:25.229	info	(20483) Temperature changed for room '11' in home '421159' to '18'
          tado.0	2021-10-08 08:12:20.225	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '10' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":21}},"termination":{"typeSkillBasedApp":"TADO_MODE","durati
          tado.0	2021-10-08 08:12:20.224	info	(20483) Temperature changed for room '10' in home '421159' to '21'
          tado.0	2021-10-08 08:12:15.227	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '9' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":19}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
          tado.0	2021-10-08 08:12:15.227	info	(20483) Temperature changed for room '9' in home '421159' to '19'
          tado.0	2021-10-08 08:12:10.224	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '8' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
          tado.0	2021-10-08 08:12:10.223	info	(20483) Temperature changed for room '8' in home '421159' to '22'
          tado.0	2021-10-08 08:12:05.206	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '7' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":21}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
          tado.0	2021-10-08 08:12:05.206	info	(20483) Temperature changed for room '7' in home '421159' to '21'
          tado.0	2021-10-08 08:12:01.118	error	(20483) Issue at setZoneOverlay: 'Error: Request failed with status code 422'. Based on config {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedAp
          tado.0	2021-10-08 08:12:00.223	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '6' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
          tado.0	2021-10-08 08:12:00.222	info	(20483) Temperature changed for room '6' in home '421159' to '22'
          tado.0	2021-10-08 08:11:56.103	error	(20483) Issue at setZoneOverlay: 'Error: Request failed with status code 422'. Based on config {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":19}},"termination":{"typeSkillBasedAp
          tado.0	2021-10-08 08:11:55.221	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '4' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":19}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
          tado.0	2021-10-08 08:11:55.220	info	(20483) Temperature changed for room '4' in home '421159' to '19'
          tado.0	2021-10-08 08:11:51.102	error	(20483) Issue at setZoneOverlay: 'Error: Request failed with status code 422'. Based on config {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedAp
          tado.0	2021-10-08 08:11:50.216	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '3' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":22}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
          tado.0	2021-10-08 08:11:50.215	info	(20483) Temperature changed for room '3' in home '421159' to '22'
          tado.0	2021-10-08 08:11:45.218	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '2' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":18}},"termination":{"typeSkillBasedApp":"TADO_MODE","duratio
          tado.0	2021-10-08 08:11:45.217	info	(20483) Temperature changed for room '2' in home '421159' to '18'
          scenes.0	2021-10-08 08:11:40.404	info	(1205) State value to set for "scene.0.0_Szene_Heizplan_Tag" has to be type "boolean" but received type "string"
          tado.0	2021-10-08 08:11:40.205	info	(20483) Call API 'ZoneOverlay' for home '421159' and zone '1' with body {"setting":{"type":"HEATING","power":"ON","temperature":{"celsius":23}},"termination":{"typeSkillBasedApp":"NEXT_TIME_BLOCK","d
          tado.0	2021-10-08 08:11:40.205	info	(20483) Temperature changed for room '1' in home '421159' to '23'
          H 1 Antwort Letzte Antwort
            K_o_bold
            @thomas-braun ,
            weil es schon mal funktioniert hat. Ich habe zwei Heizpläne "home" / "away" , diese werden über den Scene Adapter ausgeführt und mit der V 0.2... hat das genau so noch funktioniert.
            • K K_o_bold
              @thomas-braun ,
              Das heißt ja nix. Wenn z.B. tado jetzt ihre Server anders eingestellt hat funktioniert es nicht mehr in der Häufigkeit wie du da anklingelst.
              Wobei ich immer noch nicht die Notwendigkeit für einen Takt im einstelligen Sekundentakt sehe. Ich hab bei mir 30 Sekunden im Adapter drin. Schont dein Netz und die Server bei tado.
                K_o_bold
                @thomas-braun sagte in Test Adapter Tado v0.3.0-x (PreRelease):
                sprichst du jetzt von dem Aktualisierungsintervall im Adapter?
                Da habe ich auch 30 s drin.
                Mag sein, das das sekündliche Beschießen der API mittlerweile grenzwertig ist und der Tado Server hier blockiert, aber selbst mit 5 s. habe ich Probleme ( Siehe mein letzter Post ). Das sollte doch machbar sein, alle 5 Sekunden ein Thermostat zu regeln.
                Über die Notwendigkeit im Sekundentakt die Thermostate zu regeln kann man sich streiten.
                • K K_o_bold
                  @hglab ,
                  HGlab
                  Wenn die Calls einzeln durchgehen jedoch nicht in der Taktung dann kann der Adapter nichts mehr dazu beitragen. Wenn es in der v0.2.x funktioniert hat und jetzt nicht dann hat das keinen kausalen Zusammenhang, denn der REST-Call hat sich nicht verändert.
                  Tado ist sicher sensibler geworden in der externen Verwendung der API. Tado "duldet" die Verwendung der API durch dritte, kann und wird aber dementsprechende Maßnahmen ergreifen, damit ihre Server nicht unnötig beansprucht werden. Und da kann dann schon auch mal ein sinnvoller UseCase betroffen sein.
                  Im Adapter wurden nun zwei Themen optimiert:
                  1. wenn es zu dem Fehler kommt wird er "sauber" angefangen
                  2. wenn Calls parallel abgesetzt werden, dann wird gewartet bis der erste Call durch ist bevor der zweite Call durchgereicht wird; die Calls werden also serialisiert
                  • H HGlab
                    K_o_bold
                    @hglab ,
                    danke für deine Unterstützung.... :-)
                    Da scheint Tado wohl sensibler geworden zu sein...
                    Ich habe meine Skripte nun etwas umgebaut, so dass sich mein Fenster Lüftmodus- Skripte nicht mehr mit meinem Home/away Skript in die Quere kommen. Dadurch wird verhindert, dass mehrere Thermostate kurz nacheinander angesprochen werden.
                    • P Offline
                      pfahlenbauer
                      Moin,
                      Bei mir geht das Tado Ventil zu, wenn das Velux Dachfenster auf ist - und der Tado Zeitplan soll wieder aktiviert werden, wenn das Fenster wieder zu ist. Mein Blockly hat in der letzten Heizperiode hervorragend funktioniert. Jetzt leider nicht mehr.
                      Bei offenem Fenster wird jetzt zwar immer noch der Thermostat auf "off" gestellt , aber "Clear Zone Overlay" scheint nicht mehr zu funktionieren. Hat jemand eine Idee was ich ändern muss?
                      P 1 Antwort Letzte Antwort
                      • P pfahlenbauer
                        Moin,
                        pfahlenbauer
                        @pfahlenbauer
                        Konnte es selber lösen: Ich habe das Objekt geändert von tado.0.xxxxxx.Rooms.1.overlay.clearZoneOverlay auf tado.0.xxxxxx.Rooms.1.overlayClearZone
                        Jetzt geht's wieder.
                        • P pfahlenbauer
                          @pfahlenbauer
                          HGlab
                          @pfahlenbauer
                          als würde es in der Readme stehen ;-)
                          • H HGlab
                            @pfahlenbauer
                            @hglab Kleiner Wink mit dem Zaun @pfahlenbauer
                              HGlab
                              @thomas-braun was für ein Wortspiel 👍
                              • H HGlab
                                Aktuelle Test Version 0.3.0
                                Veröffentlichungsdatum 27.06.2021
                                Github Link https://github.com/DrozmotiX/ioBroker.tado
                                Pre-Release v0.3.0-x
                                This version includes intensive refactoring and breaking changes. Some names/paths of states changed in this version.
                                More details at
                                https://github.com/DrozmotiX/ioBroker.tado/blob/v0.3.0/README.md
                                v0.3.0 will be published in June 2021.
                                Critical breaking changes to be added to readme (feedback welcome!).
                                Breaking changes in v0.3.0
                                Upgrade from 0.2.x to v0.3.0 includes a technical re-factioring with breaking changes (e.g. temperature setting is now located at tado.[x]].[yyyyy]].Rooms.[z].setting.temperature.celsius).
                                Changelog
                                0.3.0-3 (2021-05-23)
                                • implement offset functionality
                                • technical re-factoring of state management !BREAKING CHANGES! (see above)
                                • set minimum refresh time to 30 seconds
                                Can be tested/installed by using
                                Please support with testing and provide feedback. For defects please create a Github issue (https://github.com/DrozmotiX/ioBroker.tado/issues/new?assignees=HGlab01&labels=bug&template=BugReport.md&title=)
                                spooky82
                                Kann mir jemand sagen, ob bei diesem Adapter die Möglichkeit existiert über einen DP die gesamte Tado Anlage auf Automatik zu setzen (und nicht jeden einzelnen Raum separat ansteuern zu müssen)?
                                Dies ist nämlich im Homebridge Plugin möglich und es fehlt mir sehr im ioB.
                                • S spooky82
                                  K_o_bold
                                  @spooky82 ,
                                  ich habe im Datenpunktbaum des Adapters keinen einzelnen Datenpunkt dafür gefunden, aber das kannst du über ein Skript lösen.
                                  • K K_o_bold
                                    @spooky82 ,
                                    spooky82
                                    @k_o_bold Danke. Hast du einen Tipp für mich, wie ich die Anlage in AWAY bzw Home setzen kann?
                                    Irgendwie klappt das Setzen von "tado mode" auf "AWAY" bzw "HOME" nicht...
                                    • S spooky82
                                      K_o_bold
                                      @spooky82 ,
                                      das kann ich dir leider nicht sagen, da ich in der Tado App alles auf manuell gestellt habe und die Anwesenheitserkennung bei mir nicht über die tadoeigene Lösung läuft. Die einzigen Datenpunkte die ich im Adapter verwende, sind die zur Temperaturregelung. Fenster offen Erkennung mache ich z.B. mit Fensterkontakte und fahre entsprechend die Temperatur runter, wenn das Fenster geöffnet wurde.
                                      • K K_o_bold
                                        @spooky82 ,
                                        spooky82
                                        @k_o_bold Hi
                                        Das mache ich auch prinzipiell so - mit der Ausnahme dass ich die Heizpläne von Tado verwende weil sie für uns sehr gut funktionieren.
                                        Bei Homebridge habe ich es eben sehr zu schätzen gewusst, die away/Home Schalter zu nutzen, weil dadurch nicht jeder Raum separat geschaltet werden muss.
                                        • S spooky82
                                          @k_o_bold Hi
                                          HGlab
                                          @spooky82 am besten mal auf Git einen Feature request anlegen.
                                          Ein erster Schritt ist in der 0.3.10 drinnen. Es gibt den State bereits. Derzeit nur lesend
