  4. zigbee funktioniert nicht mehr
    6.4k
80 Beiträge 8 Kommentatoren 10.8k Aufrufe 7 Beobachtet
  • H Habedere
    @asgothian
    Danke für die Rückmeldung.
    Recht viel mehr spuckt das Log allerdings nicht aus.
    	2021-09-23 14:31:32.790	error	Error herdsman start
    zigbee.0
    2021-09-23 14:31:32.789	error	Failed to start Zigbee
    zigbee.0
    2021-09-23 14:31:32.788	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-09-23 14:31:32.546	info	Installed Version: iobroker.zigbee@1.5.6
    zigbee.0
    2021-09-23 14:31:32.497	info	Starting Zigbee npm ...
    zigbee.0
    2021-09-23 14:31:32.492	info	Try to reconnect. 1 attempts left
    zigbee.0
    2021-09-23 14:31:22.487	error	Error herdsman start
    zigbee.0
    2021-09-23 14:31:22.486	error	Failed to start Zigbee
    zigbee.0
    2021-09-23 14:31:22.484	error	Starting zigbee-herdsman problem : "network commissioning failed - panId collision detected (expected=6754, actual=6755)"
    zigbee.0
    2021-09-23 14:31:13.846	info	Installed Version: iobroker.zigbee@1.5.6
    zigbee.0
    2021-09-23 14:31:12.971	info	Starting Zigbee npm ...
    zigbee.0
    2021-09-23 14:31:12.744	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.2, js-controller: 3.2.16
    Es entsteht ein loop.
    Hier noch komplett inkl. Abbruch
    zigbee.0
    2021-09-23 14:31:51.108	error	Cannot read property 'getEntries' of null
    zigbee.0
    2021-09-23 14:31:51.107	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:95:5)
    zigbee.0
    2021-09-23 14:31:51.105	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    2021-09-23 14:31:51.104	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2021-09-23 14:31:51.101	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2021-09-23 14:31:51.100	info	terminating
    zigbee.0
    2021-09-23 14:31:51.098	warn	Failed to stop zigbee during startup
    zigbee.0
    2021-09-23 14:31:51.095	info	Zigbee: disabling joining new devices.
    zigbee.0
    2021-09-23 14:31:51.086	info	cleaned everything up...
    zigbee.0
    2021-09-23 14:31:51.084	info	Got terminate signal TERMINATE_YOURSELF
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #66
    @habedere
    Es muss davor noch einen Versuch geben. Der Adapter versucht üblicherweise 3 mal den Herdsman zu starten.
    Die Meldung
    bedeutet das dieses der 2. Startversuch ist. Die Frage ist was beim 1. Startversuch passiert.
    Bitte schau noch mal genau nach.
    Sorry, ich hab das Log falsch herum gelesen:
    Du hast eine falsche "panID" in deiner Konfiguration:
    Bitte verifiziere das in deiner Konfiguration als panID 6754 steht, nicht 6755. Wenn das bereits der Fall ist must du sicherstellen das es kein "laufendes" zigbee netz gibt. dazu die Router devices (die die sonst immer mit Strom versorgt sind) vom Strom trennen, dann den Adapter starten.
    A.
    Nachtrag: Es reicht sie vom Strom zu trennen. Ein Zurücksetzen ist nicht nötig, genau so wenig wie ein neu anlernen.
    H 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @habedere
      Die Meldung
      A.
      Habedere
      #67
      @asgothian
      Die "panID" steht soweit korrekt drin.
      Laufendes Zigbee-Netz habe ich eigentlich nicht. Habe einen Osram-Plug denn ich mal ausgestekct habe.
      PS: Der Stick reagiert nicht auf Einstellungsänderungen - LED deaktivieren ist eingestellt, leuchtet aber noch.
      • H Habedere
        @asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #68
        @habedere Trag mal 6755 ein und schau mal ob das Besserung bringt.
        A.
        H 2 Antworten Letzte Antwort
          A.
          Habedere
          #69
          @asgothian
          Welch ein Genie :man-bowing:
          Klappt wieder - juhuu :)
          Vielen Dank!!
            A.
            Habedere
            schrieb am zuletzt editiert von Habedere
            #70
            @asgothian
            So ganz bin ich leider nicht übern Berg ;)
            Meine ganzen Devices stehen jetzt wieder in der Liste und der Adapter läuft.
            Allerdings sind alle disconnected.
            Dachte die fangen sich wieder - pustekuchen...
            Jetzt wollte ich einen mal neu binden, dann kommt wie folgt
            zigbee.0
            2021-09-25 11:52:40.355	info	Zigbee: stop joining
            zigbee.0
            2021-09-25 11:51:53.661	warn	Device '0x00158d000271a81e' announced itself
            zigbee.0
            2021-09-25 11:51:39.081	info	Zigbee: allowing new devices to join.
            • H Habedere
              @asgothian
              zigbee.0
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #71
              @habedere Bitte mach den Folgenden Versuch:
              • Zigbee Adapter anhalten
              • Datei /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json umbenennen
              • PanID auf6754
              • Zigbee Adapter starten
              A.
              • H Offline
                Habedere
                #72
                @asgothian sagte in zigbee funktioniert nicht mehr:
                Mit dem Risiko mal wieder meine Unkenntnis unter Beweis zu stellen - die Datei ist leer?!
                sudo nano /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                Da kommt nur eine leere, schwarze Seite...
                Bin ich mit der Funktion falsch dran?
                • H Habedere
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #73
                  @habedere
                  Mach mal
                  ls /opt/iobroker/iobroker-data/zigbee_0
                  Es kann sein das ich mich irgendwo vertippt hab, bzw. das die Datei nicht existiert.
                  A.
                    @habedere
                    Mach mal
                    A.
                    Habedere
                    #74
                    Glaub die gibt es nicht :)
                    pi@ioBroker-RasPi:~ $ ls /opt/iobroker/iobroker-data/zigbee_0
                    backup_2020_11_24-17_25_46.tar.gz  backup_2021_07_02-09_19_01.tar.gz
                    backup_2020_11_27-16_34_27.tar.gz  backup_2021_07_25-14_22_21.tar.gz
                    backup_2020_12_30-13_59_04.tar.gz  backup_2021_07_25-19_30_07.tar.gz
                    backup_2021_01_04-11_06_48.tar.gz  backup_2021_07_25-19_38_29.tar.gz
                    backup_2021_02_11-16_59_57.tar.gz  backup_2021_07_25-19_54_14.tar.gz
                    backup_2021_02_11-18_29_53.tar.gz  backup_2021_09_22-14_48_03.tar.gz
                    backup_2021_02_11-18_49_46.tar.gz  backup_2021_09_22-14_49_40.tar.gz
                    backup_2021_02_11-19_11_14.tar.gz  backup_2021_09_23-14_31_12.tar.gz
                    backup_2021_02_11-20_56_44.tar.gz  backup_2021_09_23-14_46_46.tar.gz
                    backup_2021_02_11-21_52_43.tar.gz  backup_2021_09_24-12_31_35.tar.gz
                    backup_2021_02_26-18_41_31.tar.gz  backup_2021_09_24-18_41_52.tar.gz
                    backup_2021_03_28-10_17_32.tar.gz  backup_2021_09_28-12_08_30.tar.gz
                    backup_2021_03_28-11_34_50.tar.gz  backup_2021_09_28-12_09_19.tar.gz
                    backup_2021_03_28-13_10_58.tar.gz  shepherd.db
                    backup_2021_06_07-06_09_52.tar.gz
                    • H Offline
                      Habedere
                      #75
                      @Asgothian
                      Habe mir mal kurzerhand einen "SONOFF Zigbee 3.0 USB Dongle Plus" organisiert - der ist schon mal angesprungen und je nach panID hat er zumindest den Osram Plug gefunden.
                      Das wars aber schon auch...
                      Jemand nochmal nen Tipp?
                      arteckA J 2 Antworten Letzte Antwort
                      • H Habedere
                        @Asgothian
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #76
                        @habedere sagte in zigbee funktioniert nicht mehr:
                        zu was ????
                        • H Habedere
                          @Asgothian
                          Jan1
                          #77
                          @habedere
                          Wenn Du an der panID spielst, musst wahrscheinlich eh alles neu pairen.
                          Normal alten Stick an , neuen dran und den neuen Link eintragne, warten und schauen. Das meiste sollte ohne weiteres zu tun funktionieren.
                          Hier gibts auch den Thread zu dem Stick
                          • arteckA arteck
                            zu was ????
                            Habedere
                            #78
                            @arteck
                            panID-Problem - siehe Posts darüber...
                            @Jan-1
                            Ja das habe ich fast befürchtet... Glaub ich lösche den Adapter mal und installiere denn neu.
                            Aber bleiben zumindest die Bezeichnungen alle erhalten?
                            Sonst müsste ich alles Skripte etc. umschreiben...
                            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                            • H Habedere
                              @arteck
                              @Jan-1
                              #79
                              Arbeite mit Alias.
                              • H Habedere
                                @arteck
                                @Jan-1
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #80
                                @arteck
                                @Jan-1
                                Die Bezeichnungen sind an die Hardware gekoppelt - die bleiben erhalten. Deine Skripte werden also weiter laufen.
                                Trotzdem ist der Hinweis von @Thomas-Braun korrekt - Alias ist der Weg da raus.
                                A.
