  4. Visualisierung des Stromverbrauchs
    2.4k
    4.3k
90 Beiträge 6 Kommentatoren 11.2k Aufrufe 4 Beobachtet
  • KusselinK Kusselin
    @homoran sagte in Visualisierung des Stromverbrauchs:
    @kusselin sagte in Visualisierung des Stromverbrauchs:
    wie das mit diesen Icvons geht!!
    das sind einfach darübergelegte basic number widgets
    und wie macht man das das sich der Pfeil dann auch noch bewegt?
    Hast du diese ´s Bild nicht mehr ist das nicht mehr zu finden bei Dir?
    indem du den Datenpunkt zuordnest?
    • GlasfaserG Glasfaser
      @kusselin
      Hier mal ein Beispiel :
      [{"tpl":"tplCGradialGauge","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","factor":"9.53674E-05","valueOffset":"0","hCount":"1","minorTicks":"4","animation":"true","needle":"true","needleShadow":"true","needleType":"arrow","borders":"true","borderOuterWidth":"1","borderMiddleWidth":"1","borderInnerWidth":"1","borderShadowWidth":"1","valueBox":true,"ticksAngle":"270","startAngle":"45","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"upnp.0.WANDevice_-_FRITZ!Box_6591_Cable_(lgi).WANDevice.WANCommonInterfaceConfig.ByteReceiveRate","title":"DOWNLOAD","minValue":"0","maxValue":"1000","units":"MB","valueInt":"3","valueBoxStroke":"0","valueTextShadow":false,"valueBoxBorderRadius":"0","fontValueSize":"30","fontValueStyle":"normal","fontNumbersWeight":"normal","fontUnitsWeight":"normal","fontValueWeight":"bold","fontNumbersSize":"27","valueText":"","valueDec":"2","colorPlate":"#707070","colorTitle":"#ffffff","colorUnits":"#ffffff","colorNumbers":"#ffffff","colorValueText":"","colorValueBoxBackground":"","colorMajorTicks":"#ffffff","colorMinorTicks":"#ffffff","colorBorderOuter":"#0411cd","colorBorderOuterEnd":"#0411cd","colorBorderMiddle":"Gray","colorBorderShadow":"#000000","colorBorderMiddleEnd":"Gray","colorBorderInner":"Gray","colorBorderInnerEnd":"Gray","colorNeedleCircleOuter":"#2d2afe","colorNeedleCircleInner":"#2d2afe","colorNeedle":"#4cf83a","colorNeedleEnd":"#4cf83a","colorPlateEnd":"#3e3838"},"style":{"left":"612px","top":"51px","width":"150px","height":"155px","z-index":"7","font-family":"Jura-DemiBold"},"widgetSet":"canvas-gauges"}]
      Daten anpassen :
      KusselinK Offline
      KusselinK Offline
      Kusselin
      schrieb am zuletzt editiert von Kusselin
      @glasfaser sagte in Visualisierung des Stromverbrauchs:
      Hab das widget jetzt mal im view waschküche importiert....nach dem importieren sehe ich gar nix.........hier muss ich hja dann auch noch das Bild importieren...oder ware das da im Widget schon inklusive?
      Auf alle fälle passiert da nix :-(
        GlasfaserG Offline
        GlasfaserG Offline
        @kusselin
        Das Widget ( Set ) im allgemeinen ist nicht installiert .
        Das kann man am undefined erkennen
        https://github.com/ioBroker/ioBroker.vis-canvas-gauges
        KusselinK 1 Antwort Letzte Antwort
          @kusselin
          KusselinK Offline
          KusselinK Offline
          Kusselin
          @glasfaser ohjee....hier muss ich über console das gauge isnatllieren...entweder radial oder linear oder komplett richtig?
          dann wenn installiert soweit ich das jetzt geelsen habe muss ich über HTML widget das Widget darstellen....stimmt das so?
          Ich weiss ihr sollt es mir udn müsst mir es ja nocht im einzeln vorkauen...Ihr seid ja so immer da und helft..aber wenn man es nicht kennt udn haben will...tja...dann wirds schwer ;-)
          und den canvas Gauges adapter muss installiert werden...sachen die alle nicht wusste
            GlasfaserG Offline
            GlasfaserG Offline
            @kusselin
            Hier installieren , auf + ( installieren ) :
            Nein , das sind fertige Widgets , die findest du dann links in der VIS Editor Widgets Leiste
              @kusselin
              KusselinK Offline
              KusselinK Offline
              Kusselin
              @glasfaser o.k jetzt wird vieles klarer ...wusste nicht das das nochmals sep. ein Adapter ist......
              aber...wieso soll ich wenn ich jetzt das gauge widget installiert habe noch deines installieren???
                GlasfaserG Offline
                GlasfaserG Offline
                Ich habe gerade keine Ahnung was du meinst ,.
                ..... habe oben nur beschrieben wie der Adapter zu installieren ist .( die Instanz )
                Aber jetzt ist ja alles gut und du kannst das Widget nutzen ;)
                  @kusselin
                  Daten anpassen :
                  KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  @kusselin
                  Daten anpassen :
                  das hier aus deinem spoiler meinte ich
                  • KusselinK Offline
                    KusselinK Offline
                    Kusselin
                    sp die schulstunde ist fast rum...deshalb jetzt noch eine abschliessende Frage :-)
                    will jetzt im Bild unten in der Mitte noch ein html-widget setzen in dem ich die Gesamt Kwh anzeigen lassen will als Zahl....also neh,e ich ein html widget und setze den Datenpunkt total
                    sonoff.0.Waschmaschine.ENERGY_Total
                    aso muss ich das soch unter html im widget reiter mit den gechweiften >Klammern setzen oder`?
                    er zeigt dann aber ncht die kwh an :-( was mach ich wieder nicht richtig?
                      sigi234S Online
                      sigi234S Online
                      @kusselin
                      Den Wert siehst du erst in der Runtime
                      • sigi234S sigi234
                        @kusselin
                        KusselinK Offline
                        KusselinK Offline
                        Kusselin
                        @sigi234 eieiei... danke wird angezeigt... das hab ich jetzt soweit kapiert.. danke Euch allen mal wieder
                          @kusselin
                          Daten anpassen :
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Das war nur eine Widget Vorlage für dich ,
                          ich konnte halt nicht erkennen ob du schon etwas hattest , bzw. du hast ja einen Anfrage an Homoran gestellt .
                          Deshalb habe ich so wie @sigi234 , hier ein Widget für dich gepostet .
                          • KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            homoran hätte ja auch schreiben können ...lade dir den Gauges Adapter runter.. dann wäre das klar gewesen. Das weiß man halt nicht am Anfang ... egal danke Dir Glasfaser!
                              Hätte er!
                              Aber dazu hätte er wissen müssen, dass du das Widget noch nicht hast.
                              Du hattest ja schließlich auch einen Screenshot davon gepostet.
                              Wie soll er dann annehmen, dass du das noch nicht installiert hattest
                                Hätte er!
                                KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                @homoran allahopp wäre das auch geklärt :-)
                                • KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  bins wieder ........habe jetzt in der view-verbrauch das gauges widget udn ein html widget plaziert..........
                                  wenn ich jetzt auf die Index seite gehe udn dort dann die runtime starte udn im menü oben auf Verbrauch klicke dann geht zwar Verbrauch auf aber das widget wird nicht angezeigt so wie im editor....
                                  mensch was mach ich da wieder falsch :-(
                                    was hast du denn überhaupt gemacht?
                                    welches?
                                    KusselinK GlasfaserG 2 Antworten Letzte Antwort
                                      welches?
                                      KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                      @homoran ha ich habe auch meiner view_verbrauch das gauges_widget plaziert...siehe hier:
                                      wenn ich jetzt die runtime aber starte und im material top bar widget auf verbrauch klicke...dann wird dieses nicht angezeigt :-(
                                        welches?
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @Kusselin
                                        Ich denke mal so ...
                                        Eine neue View " view_verbrauch" erstellt
                                        welches?
                                        Das Widget in dieser View erstellt und es wird dann
                                        ... nicht im Runtime beim Wechsel in der TopAppbar nicht angezeigt !?
                                        Nimm dieses Widget und füge es mal testweise in dein view_Müll , was ist dann !?
                                          @Kusselin
                                          welches?
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          @glasfaser na einen neue view habe ich nicht erstellt...ich habe die eigentliche view waschküche in verbrauch umbenannt udn im topbar widget dann das waschküche gegen Verbrauch geändert....
                                          wenn ich das widget in die Müllview impoetiere wirds angezeigt ???
