  4. Einstellungen Zigbee Adapter ändern
    6.3k
5 Beiträge 2 Kommentatoren 264 Aufrufe 2 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    ich habe mir eben den ZigBee-Adapter in v. 1.6.1 installiert.
    Leider darf ich die Erweiterte und kurze Pan ID nicht ändern.
    Wenn ich von den default Einstellungen weg gehe bleibt der Adapter gelb und im Log kommt:
    zigbee.0
    2021-10-20 19:26:53.662	error	Error herdsman start
    zigbee.0
    2021-10-20 19:26:53.662	error	Failed to start Zigbee
    zigbee.0
    2021-10-20 19:26:53.661	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-10-20 19:26:43.406	error	Error herdsman start
    zigbee.0
    2021-10-20 19:26:43.405	error	Failed to start Zigbee
    zigbee.0
    2021-10-20 19:26:43.404	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2021-10-20 19:26:43.245	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2021-10-20 19:26:43.244	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2021-10-20 19:26:43.244	error	Please update configuration to prevent further issues.
    zigbee.0
    2021-10-20 19:26:43.244	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2021-10-20 19:26:43.243	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2021-10-20 19:26:43.242	error	- Extended PAN ID: configured=dedddddddddddddd, adapter=00124b0024c275a8
    zigbee.0
    2021-10-20 19:26:43.242	error	- PAN ID: configured=6755, adapter=6754
    zigbee.0
    2021-10-20 19:26:43.241	error	Configuration is not consistent with adapter state/backup!
    • David G.D David G.
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @david-g
      Die genannten Einstellungen müssen konsistent sein.
        @david-g
        David G.D Online
        David G.D Online
        David G.
        Und was bedeutet das?
        Dachte von der Beschreibung her, dass man bei der bei der kurzen 0-9 eingeben darf und bei der lagen a-z und 0-9.
        Hab auch die Datei die im Log steht mal gelöscht. Geht aber trotzdem nicht. Hab noch keine Geräte angelernt.
          @david-g Nein, das sind hex-Werte.
            David G.D Online
            David G.D Online
            David G.
            Wer lesen kann, ist klar im Vorteil.... Danke.
