<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Einstellungen Zigbee Adapter ändern]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich habe mir eben den ZigBee-Adapter in v. 1.6.1 installiert.</p>
<p dir="auto">Leider darf ich die Erweiterte und kurze Pan ID nicht ändern.</p>
<p dir="auto">Wenn ich von den default Einstellungen weg gehe bleibt der Adapter gelb und im Log kommt:</p>
<pre><code>zigbee.0
2021-10-20 19:26:53.662	error	Error herdsman start
zigbee.0
2021-10-20 19:26:53.662	error	Failed to start Zigbee
zigbee.0
2021-10-20 19:26:53.661	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
zigbee.0
2021-10-20 19:26:43.406	error	Error herdsman start
zigbee.0
2021-10-20 19:26:43.405	error	Failed to start Zigbee
zigbee.0
2021-10-20 19:26:43.404	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
zigbee.0
2021-10-20 19:26:43.245	error	Re-commissioning your network will require re-pairing of all devices!
zigbee.0
2021-10-20 19:26:43.244	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
zigbee.0
2021-10-20 19:26:43.244	error	Please update configuration to prevent further issues.
zigbee.0
2021-10-20 19:26:43.244	error	- Channel List: configured=11, adapter=11
zigbee.0
2021-10-20 19:26:43.243	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
zigbee.0
2021-10-20 19:26:43.242	error	- Extended PAN ID: configured=dedddddddddddddd, adapter=00124b0024c275a8
zigbee.0
2021-10-20 19:26:43.242	error	- PAN ID: configured=6755, adapter=6754
zigbee.0
2021-10-20 19:26:43.241	error	Configuration is not consistent with adapter state/backup!
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/48645/einstellungen-zigbee-adapter-ändern</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 22:51:20 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48645.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Oct 2021 17:27:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Einstellungen Zigbee Adapter ändern on Wed, 20 Oct 2021 18:12:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Wer lesen kann, ist klar im Vorteil.... Danke.</p>
]]></description><link>https://forum.iobroker.net/post/691241</link><guid isPermaLink="true">https://forum.iobroker.net/post/691241</guid><dc:creator><![CDATA[David G.]]></dc:creator><pubDate>Wed, 20 Oct 2021 18:12:11 GMT</pubDate></item><item><title><![CDATA[Reply to Einstellungen Zigbee Adapter ändern on Wed, 20 Oct 2021 17:47:49 GMT]]></title><description><![CDATA[<p dir="auto">@david-g Nein, das sind hex-Werte.</p>
]]></description><link>https://forum.iobroker.net/post/691219</link><guid isPermaLink="true">https://forum.iobroker.net/post/691219</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 20 Oct 2021 17:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Einstellungen Zigbee Adapter ändern on Wed, 20 Oct 2021 17:41:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Und was bedeutet das?<br />
Dachte von der Beschreibung her, dass man bei der bei der kurzen 0-9 eingeben darf und bei der lagen a-z und 0-9.</p>
<p dir="auto">Hab auch die Datei die im Log steht mal gelöscht. Geht aber trotzdem nicht. Hab noch keine Geräte angelernt.</p>
]]></description><link>https://forum.iobroker.net/post/691212</link><guid isPermaLink="true">https://forum.iobroker.net/post/691212</guid><dc:creator><![CDATA[David G.]]></dc:creator><pubDate>Wed, 20 Oct 2021 17:41:58 GMT</pubDate></item><item><title><![CDATA[Reply to Einstellungen Zigbee Adapter ändern on Wed, 20 Oct 2021 17:35:33 GMT]]></title><description><![CDATA[<p dir="auto">@david-g<br />
Die genannten Einstellungen müssen konsistent sein.</p>
]]></description><link>https://forum.iobroker.net/post/691207</link><guid isPermaLink="true">https://forum.iobroker.net/post/691207</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 20 Oct 2021 17:35:33 GMT</pubDate></item></channel></rss>
