  5. Blockly für Rollladen +Sperre
    2.8k
    4.9k
    4.1k
20 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • Mono990M Mono990
    @kuddel könntest du mir das in einem Beispiel zeigen?
    hier ist meins
    <variables>
    <variable id="W[~p(rzjRofohEAF2v7o">position</variable>
    <variable id="pv(p0MFmpT1lVnbLheY6">status</variable>
    </variables>
    <block type="schedule" id="k^.}M;23Ff]a#]utS#(" x="88" y="138"> <field name="SCHEDULE">*/5 * * * *</field> <statement name="STATEMENT"> <block type="variables_set" id="}2xgQK3cl~Y#SxT4Tyj">
    <field name="VAR" id="W[~p(rzjRofohEAF2v7o">position</field>
    <value name="VALUE">
    <block type="get_value" id="trm_e8Lu{pYoAO~/wV?">
    <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field>
    </block>
    </value>
    <next>
    <block type="variables_set" id="l=r?sZRqG-jyYCmiLq4"> <field name="VAR" id="pv(p0MFmpT1lVnbLheY6">status</field> <value name="VALUE"> <block type="get_value" id="|]5IOX5Y7,X9XsQP-cP">
    <field name="OID">0_userdata.0.Fenster.Kuche_Tur</field>
    </block>
    </value>
    <next>
    <block type="controls_if" id="SQjoUjU
    |]rkeg65pIg7">
    <value name="IF0">
    <block type="logic_operation" id="Zj5a8W}d${x|zb;}|w[">
    <field name="OP">AND</field>
    <value name="A">
    <block type="logic_operation" id="?1b-;_F#%%+E$ZJ#hd1e">
    <value name="A">
    <block type="logic_operation" id="kKGARpx4qGqGWRk5f,C,">
    <field name="OP">OR</field>
    <value name="A">
    <block type="logic_compare" id="Vo(;lUGB-QZN=58BZF!R">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="variables_get" id="^o4YL4G:%o}?[?#T;X|.">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="vYS1pWDgoC
    !n),vnAE"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="KDDZuX8Gitq}W8*j|oaa"> <field name="OP">EQ</field> <value name="A"> <block type="variables_get" id="v^8Lvi.M@@1pPR~TVEyR"> <field name="VAR" id="pv(p0MFmpT1lVnbLheY6">status</field> </block> </value> <value name="B"> <block type="math_number" id="Kv8aB(yvDE[;@|9Mlkna"> <field name="NUM">1</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="vVWJC)%xr!ZZzJUs.6_Q"> <field name="OP">LT</field> <value name="A"> <block type="variables_get" id="b;c4Q;F#6w3G35p5Tp%C"> <field name="VAR" id="W[~p(rzjRofohEAF2v7o">position</field> </block> </value> <value name="B"> <block type="math_number" id="7TeaJv1[Ecnh]1;/3p*">
    <field name="NUM">100</field>
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="time_compare" id="S@^x62l!ez,:wMPinI)E">
    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
    <field name="OPTION">between</field>
    <field name="START_TIME">21:00</field>
    <field name="END_TIME">7:59</field>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="control" id="a0WQEB$![21Wv26rxO,"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="JGjP}F{flmWbJV+g~^kP"> <field name="NUM">0</field> </block> </value> </block> </statement> <value name="IF1"> <block type="logic_operation" id=",,MDUfQm,vx@|74Vf|c["> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="U$kD,BSqr+h!HXU:4{r%"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="YR5^jWdk]d5nby66RsW">
    <value name="A">
    <block type="logic_compare" id="%$OurK#0nm-Suw/n@I}O">
    <value name="A">
    <block type="variables_get" id="j]w;wI#O/wmC,C=hCqk">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="dfO]jqI{@Xo6dBunc|E"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="O(OJn=6#%?{QLY*Ib8|#"> <field name="OP">EQ</field> <value name="A"> <block type="variables_get" id="G7EJ)e3N!l?fPR*Peic2"> <field name="VAR" id="pv(p0MFmpT1lVnbLheY6">status</field> </block> </value> <value name="B"> <block type="math_number" id="3ZjDoPbSlDtJB9+yZ2q4"> <field name="NUM">1</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="OH~M24XmmK9K|E;d
    ti">
    <value name="A">
    <block type="variables_get" id="4mRs]aClX{jA2MNS1(?">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="dN1*WVJ^puu@9``?HI_S">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="time_compare" id="pZ.wWBS/Q_SE6A3Oc)."> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">8:00</field> <field name="END_TIME">9:00</field> </block> </value> </block> </value> <statement name="DO1"> <block type="control" id="Spa~|KK9tj@~OMB!}H2">
    <block type="math_number" id="6tsok9$[He1Ncv~!7Lb
    </block>
    </value>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </xml>
    CinimodC Offline
    CinimodC Offline
    Cinimod
    @mono990
    Sowas etwa:
    Hier der Code:
     <variables>
     </variables>
     <block type="variables_set" id="}2xgQK3cl~Y#SxT4Tyj" x="38" y="187">
         </block>
       </value>
       <next>
             </block>
           </value>
           <next>
             <block type="schedule" id="a,a}fcfqe`*vEvi_qJ61">
               <field name="SCHEDULE">0 21 * * *</field>
                 <block type="controls_if" id="7vnu[;m^AdaTag:CpwUa">
                   <value name="IF0">
                     <block type="logic_operation" id="?evm+)t@K#JO8z_WmUfm" inline="false">
                       <value name="A">
                           <field name="OP">NEQ</field>
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="vYS1pWDgoC!n),vnAE">
                               <field name="NUM">2</field>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
               <next>
                 <block type="schedule" id="^8M(|n|ayd4hKam|IYk|">
                   <field name="SCHEDULE">0 8 * * *</field>
                     <block type="controls_if" id="Zt|Z95wmZv?/fkTFt||7">
                       <value name="IF0">
                         <block type="logic_operation" id="-fzXwLzXNpZR8JOD:C{Y" inline="false">
                           <value name="A">
                             <block type="logic_compare" id=",}Q!hs_J_/#C1]K6VodI">
                               <value name="A">
                                 <block type="variables_get" id="RA@?VHWjZtKNn1,Q@.}V">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="MwvnB5if;Ht?y|yN@3-x">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_compare" id="bUNRlGl`*m{u?FUA1zwI">
                               <value name="A">
                                 <block type="variables_get" id="o7=1pBa?V1P,{[W#APbm">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="HQve/P]r^h*3tg?,).Xt">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                         <block type="control" id="$O#iV.f]s{9R9KfuI0a!">
                             <block type="math_number" id="t*|O3bI@hXcF|]$d@?n}">
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <next>
                     <block type="on_ext" id="*S-*-?Kmj=azHSy?ONjv">
                       <value name="OID0">
                         <shadow type="field_oid" id="ig%Y@m34^U)S,u/a.}vJ">
                         </shadow>
                         <block type="field_oid" id="p2Mts=2:q|fqfG4+vV7x">
                         </block>
                       </value>
                         <block type="controls_if" id="V=v~wkUN?0MtS8{Z}MU;">
                           <value name="IF0">
                             <block type="logic_operation" id=",57UBvJH*0n48c$2oa{@" inline="false">
                               <value name="A">
                                 <block type="time_compare" id="M33;_l5@kPT.n8}H:}Mj">
                                   <field name="OPTION">not between</field>
                                   <field name="START_TIME">08:00</field>
                                   <field name="END_TIME">21:00</field>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_operation" id="%K9}*5[i%D,^nIyR!f3d" inline="false">
                                   <value name="A">
                                     <block type="logic_compare" id="!cwo7SnF%X]M:HRQgM[j">
                                       <value name="A">
                                         <block type="variables_get" id="$X-c*.H$Pc_S+_CO5r6C">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="P7yW;nmQ9C$DQ,$z5OE$">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="fL`QA]6C?5?(wJB~?AX2">
                                       <value name="A">
                                         <block type="on_source" id="i[gNu_+^m[._+(I|)iVg">
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="math_number" id="LW[wCFC,VP?CAWio~f61">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="control" id="!-%XT3uBo~rwxR0sg,^@">
                                 <block type="math_number" id="^WpfM,@ABGl=Wow-]1(P">
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="comment" id="}2FkDn!D$!KcUI3Q|w:[" x="338" y="637">
       <field name="COMMENT">hier Tür status objekt</field>
     </block>
    </xml>
    • CinimodC Cinimod
      @mono990
      Sowas etwa:
      Hier der Code:
       <variables>
       </variables>
           </block>
         </value>
         <next>
               </block>
             </value>
             <next>
                     <value name="IF0">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
                 <next>
                         <value name="IF0">
                             <value name="A">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </statement>
                     <next>
                         <value name="OID0">
                           </shadow>
                           </block>
                         </value>
                             <value name="IF0">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
       </block>
      </xml>
      Kuddel
      @cinimod bist du sicher, dass das so geht?
      Werden Status und die Position so nicht nur in die Variablen geschrieben, wenn Skript oder die Instanz gestartet werden?
      Wenn die Trigger auslösen werden Status und Position aber nicht erneut geprüft würde ich sagen
      CinimodC 2 Antworten Letzte Antwort
      • K Kuddel
        CinimodC Offline
        CinimodC Offline
        Cinimod
        @kuddel
        oh ja da hast du vollkommen recht ... muss ich noch mal überarbeiten
        • K Kuddel
          CinimodC Offline
          CinimodC Offline
          Cinimod
          @Mono990
          hier dann noch mal überarbeietet:
          hier der Code:
          <block xmlns="https://developers.google.com/blockly/xml" type="comment" id="}2FkDn!D$!KcUI3Q|w:[" x="337.1552001953123" y="612.0615478515625">
          </block>
          Mir stellt sich gerade noch die frage ob das Rollo denn nur hoch gehen darf wenn die Tür zu oder gekippt ist ? das würde ich ggf. raus nehmen.
          • CinimodC Cinimod
            @Mono990
            hier der Code:
            </block>
            CinimodC Offline
            CinimodC Offline
            Cinimod
            @cinimod
            hier dann noch mal: Rollo darf immer hoch gehen, unabhängig vom zustand der Tür.
            Code:
             <block type="schedule" id="a,a}fcfqe`*vEvi_qJ61" x="37" y="213">
                   <value name="IF0">
                       <value name="A">
                           <value name="A">
                             <block type="get_value" id="cX?l8j|lnl1q1)j,wXa0">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                           <value name="A">
                             <block type="get_value" id="#{wbxG1/Q:tBM502:Oel">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
               <next>
                       <value name="IF0">
                           <value name="A">
                             <block type="get_value" id="uZs_UpLP.:#Dp7Agq8zQ">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <next>
                       <value name="OID0">
                         </shadow>
                         </block>
                       </value>
                           <value name="IF0">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                       <value name="A">
                                         <block type="get_value" id="X3F8;D+e#Ia}vjQ?ocWd">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
             <block type="comment" id="}2FkDn!D$!KcUI3Q|w:[" x="337" y="563">
             </block>
            </xml>
            Mono990M 1 Antwort Letzte Antwort
            • CinimodC Cinimod
              @cinimod
              Code:
                     <value name="IF0">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
                 <next>
                         <value name="IF0">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </statement>
                     <next>
                         <value name="OID0">
                           </shadow>
                           </block>
                         </value>
                             <value name="IF0">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
               </block>
              </xml>
              Mono990M Offline
              Mono990M Offline
              Mono990
              @cinimod
              Das sieht ja super aus👍 werde es die tage Testen und dann bescheid geben. vielen Dank schon mal
              • Mono990M Mono990
                @cinimod
                CinimodC Offline
                CinimodC Offline
                Cinimod
                @mono990
                gern, viel Erfolg. Wenn das noch nicht klappt einfach melden
                • CinimodC Cinimod
                  @mono990
                  Mono990M Offline
                  Mono990M Offline
                  Mono990
                  @cinimod
                  Das Rollo ging heute abend nicht runter obwohl die Tür zu war.
                  Die ausgewählten objekte sind die richtigen. daran kann es nicht liegen.
                  • Mono990M Mono990
                    @cinimod
                    CinimodC Offline
                    CinimodC Offline
                    Cinimod
                    @mono990
                    ich kann keinen Fehler sehen, magst du deins noch mal her zeigen ?
                    • CinimodC Cinimod
                      @mono990
                      Mono990M Offline
                      Mono990M Offline
                      Mono990
                      @cinimod
                      hier das script
                      <block type="schedule" id="a,a}fcfqe*vEvi_qJ61" x="37" y="213"> <field name="SCHEDULE">0 21 * * *</field> <statement name="STATEMENT"> <block type="controls_if" id="7vnu[;m^AdaTag:CpwUa"> <value name="IF0"> <block type="logic_operation" id="?evm+)t@K#JO8z_WmUfm" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="vVWJC)%xr!ZZzJUs.6_Q"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="cX?l8j|lnl1q1)j,wXa0"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Fenster.Kuche_Tur</field> </block> </value> <value name="B"> <block type="math_number" id="7TeaJv1[Ecnh]1;/3p*"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="Vo(;lUGB-QZN=58BZF!R"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="#{wbxG1/Q:tBM502:Oel"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Fenster.Kuche_Tur</field> </block> </value> <value name="B"> <block type="math_number" id="vYS1pWDgoC!n),vnAE"> <field name="NUM">2</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="a0WQEB$![21Wv26rxO,"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="JGjP}F{flmWbJV+g~^kP"> <field name="NUM">0</field> </block> </value> </block> </statement> </block> </statement> <next> <block type="schedule" id="^8M(|n|ayd4hKam|IYk|"> <field name="SCHEDULE">0 8 * * *</field> <statement name="STATEMENT"> <block type="controls_if" id="Zt|Z95wmZv?/fkTFt||7"> <value name="IF0"> <block type="logic_compare" id=",}Q!hs_J_/#C1]K6VodI"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="uZs_UpLP.:#Dp7Agq8zQ"> <field name="ATTR">val</field> <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field> </block> </value> <value name="B"> <block type="math_number" id="MwvnB5if;Ht?y|yN@3-x"> <field name="NUM">100</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="$O#iV.f]s{9R9KfuI0a!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="t*|O3bI@hXcF|]$d@?n}"> <field name="NUM">100</field> </block> </value> </block> </statement> </block> </statement> <next> <block type="on_ext" id="*S-*-?Kmj=azHSy?ONjv"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="ig%Y@m34^U)S,u/a.}vJ"> <field name="oid">default</field> </shadow> <block type="field_oid" id="p2Mts=2:q|fqfG4+vV7x"> <field name="oid">0_userdata.0.Fenster.Kuche_Tur</field> </block> </value> <statement name="STATEMENT"> <block type="controls_if" id="V=v~wkUN?0MtS8{Z}MU;"> <value name="IF0"> <block type="logic_operation" id=",57UBvJH*0n48c$2oa{@" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="time_compare" id="M33;_l5@kPT.n8}H:}Mj"> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation> <field name="OPTION">not between</field> <field name="START_TIME">08:00</field> <field name="END_TIME">21:00</field> </block> </value> <value name="B"> <block type="logic_operation" id="%K9}*5[i%D,^nIyR!f3d" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="!cwo7SnF%X]M:HRQgM[j"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="X3F8;D+e#Ia}vjQ?ocWd"> <field name="ATTR">val</field> <field name="OID">shelly.0.SHSW-25#483FDA827F5E#1.Shutter.Position</field> </block> </value> <value name="B"> <block type="math_number" id="P7yW;nmQ9C$DQ,$z5OE$"> <field name="NUM">0</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="fLQA]6C?5?(wJB~?AX2">
                      <value name="A">
                      </block>
                      </value>
                      <value name="B">
                      </block>
                      </value>
                      </block>
                      </value>
                      </block>
                      </value>
                      </block>
                      </value>
                      </block>
                      </value>
                      </block>
                      </statement>
                      </block>
                      </statement>
                      </block>
                      </next>
                      </block>
                      </next>
                      </block>
                      <block type="comment" id="}2FkDn!D$!KcUI3Q|w:[" x="388" y="563">
                      </block>
                      </xml>
                      • Mono990M Mono990
                        @cinimod
                        CinimodC Offline
                        CinimodC Offline
                        Cinimod
                        @mono990 sagte in Blockly für Rollladen +Sperre:
                        @cinimod
                        Ganz oben muss "wert von ObjektID Shutter Position" rein
                        • CinimodC Cinimod
                          @cinimod
                          CinimodC Offline
                          CinimodC Offline
                          Cinimod
                          @cinimod
                          oben soll er nur einmal prüfen ob das Rollo nicht schon auf 0 ist, so wie du es hattest wollte er nur schließen wenn die Tür gekippt ist.
                          • CinimodC Cinimod
                            @cinimod
                            Mono990M Offline
                            Mono990M Offline
                            Mono990
                            @cinimod Aso ok habe ich jetzt geändert. mal sehen ob er heute runter geht 😁
                            • Mono990M Mono990
                              CinimodC Offline
                              CinimodC Offline
                              Cinimod
                              @mono990
                              Heute gehts ! 😉
                              • CinimodC Cinimod
                                @mono990
                                Heute gehts ! 😉
                                Mono990M Offline
                                Mono990M Offline
                                Mono990
                                @cinimod ist leider nicht runtergegangen. Brauche ich noch ein Adapter oder so der die aktuelle zeit angibt wonach sich der Zeitplan trigger richten kann?
                                • Mono990M Mono990
                                  CinimodC Offline
                                  CinimodC Offline
                                  Cinimod
                                  @mono990
                                  Vielleicht stimmt deine Systemzeit nicht 🤔
                                  Hast du die Koordinaten richtig ?
                                  Ist das Rollo denn bei 0 unten und bei 100 oben?
                                  Teste doch mal ein neues Script mit dem Zeitplan trigger und nem debug baustein … oder lass dir ne Nachricht schicken zum testen …
                                  • CinimodC Cinimod
                                    @mono990
                                    Mono990M Offline
                                    Mono990M Offline
                                    Mono990
                                    @cinimod die Zeit im iobroker hatte die richtige Zeit angezeigt aber die systemzeit des Raspian hat eine ganz andere zeit angezeigt. ich lasse die systemzeit jetzt mit einem NTP server syncronisieren.
                                    Die ersten Tests waren gut, habe mir nachrichten auf mein Handy schicken lassen über Blockly und Zeitplan.
