  4. BackitUP Mount Error, Proxmox LXC mit iobroker
    1.0k
    6.1k
90 Beiträge 7 Kommentatoren 10.7k Aufrufe 7 Beobachtet
    @glasfaser gibt es nicht
    Vielleicht hier?
    @marcel-drzal
    Das Ding kann NFS sprechen?
    Dann würde ich das auch verwenden.
      @glasfaser sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
      /Backup/iobroker
      geht nicht
      6b98491a-9bbd-4ef9-b3d1-a7185e8b8244-grafik.png code_text
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.35/Backup/iobroker /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups
      mount error(1): Operation not permitted
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.iobroker 1907 states saved
      [DEBUG] [iobroker] - host.iobroker 2630 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_13-22_37_17_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker"
      /bin/sh: 1: influxd: not found
      [DEBUG] [grafana] - Start Grafana Backup ...
      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - Created dashboard directory
      [DEBUG] [grafana] - Created dashboards_manually_restore directory
      [DEBUG] [grafana] - Created datasource directory
      [DEBUG] [grafana] - start Grafana request ...
      [DEBUG] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http
      [DEBUG] [grafana] - Grafana is not available!
      [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      [DEBUG] [grafana] - Grafana Backup cannot created ...
      [DEBUG] [grafana] - done
      [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
      [DEBUG] [javascripts] - done
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [pushover] - [iobroker] used pushover-Instance: pushover.0
      [DEBUG] [pushover] - done
      [DEBUG] [pushover] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-22_37_17_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-22_37_22_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de","time":"13. Oktober 2021 um 22:37 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-22_37_17_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-22_37_22_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"13. Oktober 2021 um 22:37 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-22_37_17_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-22_37_22_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/iobroker /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-22_37_21_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"13. Oktober 2021 um 22:37 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
      GlasfaserG Offline
      GlasfaserG Offline
      @marcel-drzal sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
      Zeige mal ein Screenshot von Backitup
      EDIT :
      Alles gut , hat sich erledigt
      • GlasfaserG Glasfaser
        EDIT :
        @glasfaser NFS geht auch nicht
        [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.16","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.16:/Backup/iobroker /opt/iobroker/backups"
        [ERROR] [mount] - [undefined mount.nfs: requested NFS version or transport protocol is not supported
        [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.178.16:/Backup/iobroker /opt/iobroker/backups
        4e018adb-6217-49bd-9fc7-0c7834cd48ff-grafik.png code_text
        Bin erst mal raus, morgen wirder. Danke dir hoffe wir finden es noch.
        Soll ich wieder zurück setzen auf  CIFS?
        Thomas BraunT GlasfaserG F 3 Antworten Letzte Antwort
          "source":"cifs"
          passt ja auch nicht zu NFS. Aber lass mal mit NFS abbrechen an der Stelle, das wird sonst nur konfus.
            GlasfaserG Offline
            GlasfaserG Offline
            192.168.178.16
            Warum wieder diese IP ??
              192.168.178.16
              @glasfaser die andere geht auch nicht
              [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
              [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups"
              [ERROR] [mount] - [undefined mount.nfs: Operation not permitted
              [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups
              [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":{"killed":false,"code":32,"signal":null,"cmd":"sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups"}},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_13-23_14_02_backupiobroker.tar.gz
              [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker"
              [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
              [DEBUG] [pushover] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-23_14_02_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-23_14_07_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":32,"signal":null,"cmd":"sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups"},"influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de","time":"13. Oktober 2021 um 23:14 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-23_14_02_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-23_14_07_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":32,"signal":null,"cmd":"sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups"},"influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"13. Oktober 2021 um 23:14 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_13-23_14_02_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_13-23_14_07_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":32,"signal":null,"cmd":"sudo mount 192.168.178.35:/Backup/iobroker /opt/iobroker/backups"},"influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_13-23_14_06_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"13. Oktober 2021 um 23:14 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
              [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
                Started iobroker ...
                F Online
                F Online
                fastfoot
                schrieb am zuletzt editiert von fastfoot
                @marcel-drzal ich bezweifle dass das funktionieren kann, mir ist es(auf QNAP) noch nicht gelungen. Allerdings bietet Docker doch das Feature des Volume Mapping an, damit kann man das easy umsetzen, wenn man den Backup Ordner woanders haben möchte.
                Im Portainer sieht so ein Setting so aus:
                in BackitUp nutzt man dann ganz normal das iobroker Setting, NAS/Kopieren bleibt unangetastet
                EDIT: sehe gerade dass es sich um LXC handelt, nicht Docker. Dennoch bezweifle ich dass da nfs oder cifs/smb funktioniert
                  GlasfaserG Offline
                  GlasfaserG Offline
                  nfs-mount
                  Was sagt in der ioBroker Konsole :
                  showmount -e 192.168.178.35
                    "source":"cifs"
                    @thomas-braun OK wieder umgestellt
                    3.0 habe ich eingestellt
                    • F fastfoot
                      @fastfoot Bin da nicht so Fitt
                      Docker habe ich nicht
                        @marcel-drzal
                        Und die IP 192.168.178.16 , ist dein ioBroker !
                        @glasfaser Ja
                        192.168.178.35 meine NAS Synology
                          @glasfaser Ja
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @marcel-drzal
                          Wenn nfs richtig eingestellt ist + die Ordner nfs Freigabe ,dann würde die Ausgabe kommen
                          192.168.178.35
                          ... /Backup/iobroker
                            nfs-mount
                            @glasfaser sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
                            GlasfaserG Meister MopperM 2 Antworten Letzte Antwort
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @marcel-drzal
                              Ich habe ioBroker in der Syn Docker .ohne /Volume1/. in der Config von Backitup .... eventuell brauchst du bei dir :
                              /volume1/Backup/iobroker
                                Meister MopperM Online
                                Meister Mopper
                                @marcel-drzal
                                Ist das ein privilegierter oder ein unprivilegierter Container? Bei einem unprivilegierten kannst Du die features cifs und nfs nicht aktivieren.
                                Hier z. B. ein privilegierter Container:
                                Proxmox und HA ...
                                  @marcel-drzal
                                  @meister-mopper
                                  unpriviligiert, alos komme ich so nicht weiter?
                                  a10df284-d761-48dc-afeb-d14740dfe497-grafik.png code_text
                                    @thomas-braun Hier soll das Backup drauf
                                    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/NAS/Backup/iobroker","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
                                    [DEBUG] [mount] - noserverino option: false
                                    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.178.35/NAS/Backup/iobroker /opt/iobroker/backups"
                                    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/NAS/Backup/iobroker /opt/iobroker/backups"
                                    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/NAS/Backup/iobroker /opt/iobroker/backups
                                    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/NAS/Backup/iobroker /opt/iobroker/backups
                                    ist das eine Freigabe?
                                    oder nur ein einfaches Verzeichnis?
                                    so wie es Aussieht sollte die Freigabe das darüberliegende Verzeichnis sein, also müsste der Eintrag so sein, wie @Glasfaser schrieb.
                                    Wenn es damit nicht klappt, bitte die Konfig /Rechte der Freigabe posten
                                    sieht nach Rechteproblemen aus
                                    ? 2 Antworten Letzte Antwort
                                      ich habe ein Grundlegende Sicherheitsfrage, ist ese besser in NFS Backup zu erstellen?
                                      bd1bb2d5-9b65-4ab8-8896-94251e8d3baa-grafik.png code_text
                                        ich habe keine Ahnung von NFS
                                          @meister-mopper
                                          Meister Mopper
                                          @marcel-drzal
                                          Dann sehe ich drei Möglichkeiten
                                          • Backup über FTP
                                          • ioBroker in einem privilegierten Container (Sicherheitsproblem, da der Kernel des Proxmox node zugänglich ist)
                                          • Herstellen eines mountpoints auf dem node und Durchreichen an den Container (@Dutchman hat das bereits gelöst)
                                          Proxmox und HA ...
