  4. Weboberfläche admin geht nicht
    6.4k
34 Beiträge 5 Kommentatoren 4.2k Aufrufe 4 Beobachtet
  • NashraN Nashra
    @glasfaser sagte in Weboberfläche admin geht nicht:
    @nashra
    Gehe mal die anderen Befehle durch , die im Thread vorher erwähnt sind .
    Meinst Du die von dem Link im anderen Thread
    GlasfaserG Offline
    GlasfaserG Offline
    @nashra
    Ja , im anderen Thread
    • NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      schrieb am zuletzt editiert von Nashra
      Befehle ausgeführt...
      jack@ioBroker:/opt/iobroker$ npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
      [sudo] password for jack:
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.admin@5.1.25
      removed 108 packages and updated 1 package in 10.902s
      126 packages are looking for funding
        run `npm fund` for details
      jack@ioBroker:/opt/iobroker/node_modules/iobroker.admin$ npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      audited 819 packages in 2.864s
      53 packages are looking for funding
      found 67 vulnerabilities (3 moderate, 64 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      jack@ioBroker:/opt/iobroker/node_modules/iobroker.admin$ npm run prepublish
      npm ERR! missing script: prepublish
      npm ERR!
      npm ERR! Did you mean this?
      npm ERR!     prepublishOnly
      npm ERR!     /home/iobroker/.npm/_logs/2021-10-04T11_42_35_720Z-debug.log
      Nix
      Gruß Ralf
      • NashraN Nashra
        Moin, nach einem Backup komme ich nicht mehr auf die Weboberfläche.
        Selbst ein add admin.1 bringt auch den Fehler wie bei admin.0
        This adapter cannot be installed directly from github.
        You must install it from npm.
        Write for that "npm install iobroker.admin" in according directory.
        node: 12.22.6
        npm: 6.14.15
        Habe auch schon gestöbert und das ein oder andere probiert aber
        bekomme es einfach nicht zum laufen.
        EDIT: IoBroker läuft und auch die VIS wird angezeigt.
        GlasfaserG Offline
        GlasfaserG Offline
        @nashra sagte in Weboberfläche admin geht nicht:
        ........ kommt die selbe Fehlermeldung
        Eventuell reiner Zufall , bevor man noch mehr experimentiert , dann lieber das :
        Ich werde heute Nachmittag den Container löschen, Debian 11 installieren und es dann
        über die Backups neu versuchen (habe ja genug davon).
        • NashraN Offline
          NashraN Offline
          Nashra
          Genau, werde gleich alles platt machen, Debian 11 drauf und dann iob, Backup rein (habe ich ja genug von)
          und dann schauen wir mal
          Gruß Ralf
          • NashraN Offline
            NashraN Offline
            Nashra
            So, Proxmox-Container neu mit Debian 11. ioB neu installiert, Backup eingespielt
            und jetzt gibt es Probleme mit den Adaptern: javascript, Web und Alexa.
            host.ioBroker
            		2021-10-04 19:09:14.454	error	startInstance system.adapter.javascript.0: required adapter "admin" has wrong version. Installed "4.2.1", required ">=5.1.9"!
            host.ioBroker
            		2021-10-04 19:10:10.731	error	startInstance system.adapter.web.0: required adapter "admin" has wrong version. Installed "4.2.1", required ">=5.1.0"!
            alexa2.0
            	7467	2021-10-04 19:15:08.337	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 50s
            alexa2.0
            	7467	2021-10-04 19:14:22.800	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 45s
            alexa2.0
            	7467	2021-10-04 19:13:42.360	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 40s
            alexa2.0
            	7467	2021-10-04 19:13:06.918	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 35s
            alexa2.0
            	7467	2021-10-04 19:12:36.474	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 30s
            alexa2.0
            	7467	2021-10-04 19:12:11.033	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 25s
            alexa2.0
            	7467	2021-10-04 19:11:50.592	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
            alexa2.0
            	7467	2021-10-04 19:11:35.153	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
            Was ist denn da jetzt los 😵
            Gruß Ralf
            G HomoranH 2 Antworten Letzte Antwort
            • NashraN Nashra
              host.ioBroker
              host.ioBroker
              alexa2.0
              alexa2.0
              alexa2.0
              alexa2.0
              alexa2.0
              alexa2.0
              alexa2.0
              alexa2.0
              guergen
              @nashra Steht doch da.. admin updaten!
              Alexa hat im Moment probleme; mal mehr, mal weniger!
              • NashraN Nashra
                host.ioBroker
                host.ioBroker
                alexa2.0
                alexa2.0
                alexa2.0
                alexa2.0
                alexa2.0
                alexa2.0
                alexa2.0
                alexa2.0
                @guergen sagte in Weboberfläche admin geht nicht:
                oder wenigstens einen upload machen, am besten iobroker upload all
                • G guergen
                  NashraN Offline
                  NashraN Offline
                  Nashra
                  ok, nur das hatte ich noch nie mit Alexa deswegen war ich etwas verwundert
                  @homoran sagte in Weboberfläche admin geht nicht:
                  hatte ich gemacht und was soll ich da noch updaten
                  Gruß Ralf
                  • NashraN Nashra
                    hatte ich gemacht
                    was?
                    upgrade oder upload
                      hatte ich gemacht
                      was?
                      upgrade oder upload
                      NashraN Offline
                      NashraN Offline
                      Nashra
                      hatte ich gemacht
                      was?
                      upgrade oder upload
                      Beides
                      Gruß Ralf
                      • NashraN Nashra
                        hatte ich gemacht
                        was?
                        upgrade oder upload
                        Beides
                        Beides
                        was sagt
                        iobroker update -i
                        iobroker list adapters
                          Beides
                          was sagt
                          iobroker update -i
                          NashraN Offline
                          NashraN Offline
                          Nashra
                          Beides
                          was sagt
                          iobroker update -i
                          alles schon probiert und schon mehrmals neu gestartet gestern, auch Container, aber jetzt kommst....
                          gestern Abend vergessen iob wieder zustarten, heute Mittag habe ich es erst bemerkt
                          und dachte starte ich eben alles nochmal komplett und was passiert...
                          javascript, web läuft 😁 😈
                          Aber jetzt mal ganz ehrlich, woran könnte das jetzt gelegen haben?
                          Ein Frischling mit iob könnte hier mächtig ins schleudern kommen.
                          Trotzdem Danke an Euch für die Hilfe 👍
                          Gruß Ralf
                          • NashraN Nashra
                            Beides
                            was sagt
                            iobroker update -i
                            und wo ist die Ausgabe der Befehle?
                              NashraN Offline
                              NashraN Offline
                              Nashra
                              Läuft doch aber da Du es bist 😁
                              jack@ioBroker:~$ iob list instances
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                              + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                system.adapter.birthdays.0              : birthdays             : ioBroker                                 - disabled
                                system.adapter.calendar.0               : calendar              : ioBroker                                 - disabled, port: 8095
                                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: ioBroker                                 - disabled
                                system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
                                system.adapter.devices.0                : devices               : ioBroker                                 - disabled
                                system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
                                system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                              + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                                system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                                system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                                system.adapter.fontui.0                 : fontui                : ioBroker                                 - disabled
                                system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBroker                                 - disabled
                              + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                                system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                                system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                                system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                                system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                                system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                              + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                              + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                              + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
                              + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                              + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                              + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
                              + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                                system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                              + system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
                                system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
                              + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                              + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                                system.adapter.proxmox.0                : proxmox               : ioBroker                                 - disabled, port: 8006
                                system.adapter.proxmox.1                : proxmox               : ioBroker                                 - disabled, port: 8006
                                system.adapter.rtspStream.0             : rtspStream            : ioBroker                                 - disabled, port: 7447
                              + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                              + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                                system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                              + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                system.adapter.unifi-protect.0          : unifi-protect         : ioBroker                                 - disabled
                                system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
                              + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
                                system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                                system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                                system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                                system.adapter.web-speedy.0             : web-speedy            : ioBroker                                 - disabled
                              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
                              + instance is alive
                              jack@ioBroker:~$
                              Gruß Ralf
                              • NashraN Nashra
                                + instance is alive
                                jack@ioBroker:~$
                                das ist aber nicht der Zustand als es klemmte, oder?
                                Daraus kann man jetzt nicht zurückblickend etwas sagen
                                (und es ist der einzige Befehl von dem ich nichts wollte 😂 )
                                • NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  Das war die Liste bevor ich alles neu aufgesetzt habe
                                  und gestern Abend hatte ich keinen Bock mehr und vergessen zu diesem Zeitpunkt die Ausgaben
                                  hier zu posten. Aber die war so wie die vorhin, hatte da nur noch nicht alle Adapter aktiviert.
                                  Läuft, Ende, jetzt noch ein Backup und TV gucken :-)
                                  Gruß Ralf
                                  • NashraN Nashra
                                    die Ausgaben
                                    hier zu posten
                                    das hilft jetzt wirklich nicht mehr das gestrige Problem nachzuvollziehen.
                                    die gestrigen Ausgaben von
                                    was sagt
                                    iobroker update -i
                                    hätten da eher etwa gesagt.
                                    ist somit nicht mehr zu beantworten.
                                    kann alles mögliche gewesen sein, bis hin zum Netzwerk
