  4. influxdb Fehler connect ECONNREFUSED
    6.4k
influx-db
31 Beiträge 6 Kommentatoren 4.2k Aufrufe 6 Beobachtet
  • AphofisA Offline
    AphofisA Offline
    Aphofis
    schrieb am zuletzt editiert von Aphofis
    Seid der neuen JS-Controller stable Version läuft meine influxdb nicht mehr.
    Das System sagt
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: activating (start) since Tue 2021-09-21 02:02:54 CEST; 9s ago
         Docs: https://docs.influxdata.com/influxdb/
    Cntrl PID: 21403 (influxd-systemd)
        Tasks: 13 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               ├─21403 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
               ├─21404 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
               └─21711 sleep 1
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.584992Z lvl=info msg="Opened shard" log_id=0WiQS0Zl000 service=store trace_id=0WiQS0_l000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.591726Z lvl=info msg="Opened file" log_id=0WiQS0Zl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/32/000000001-000000001.tsm id=0 duration=7.60
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.600099Z lvl=info msg="Opened file" log_id=0WiQS0Zl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/40/000000001-000000001.tsm id=0 duration=0.53
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.600429Z lvl=info msg="Opened file" log_id=0WiQS0Zl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/40/000000002-000000001.tsm id=1 duration=0.83
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.603619Z lvl=info msg="Opened shard" log_id=0WiQS0Zl000 service=store trace_id=0WiQS0_l000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.639247Z lvl=info msg="Opened shard" log_id=0WiQS0Zl000 service=store trace_id=0WiQS0_l000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/3
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.644581Z lvl=info msg="Opened file" log_id=0WiQS0Zl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/48/000000001-000000001.tsm id=0 duration=2.47
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.645464Z lvl=info msg="Reading file" log_id=0WiQS0Zl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/48/_00002.wal size=63512
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.680886Z lvl=info msg="Opened shard" log_id=0WiQS0Zl000 service=store trace_id=0WiQS0_l000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/4
    Sep 21 02:02:54 AquaPi influxd-systemd-start.sh[21403]: ts=2021-09-21T00:02:54.728210Z lvl=info msg="Opened shard" log_id=0WiQS0Zl000 service=store trace_id=0WiQS0_l000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/4
    ioBroker Protokolle Meldet alle paar sekunden
     influxdb.0          2021-09-21 02:06:59.877	         error	  Error: connect ECONNREFUSED 127.0.0.1:8086
    Meine Log Datei AquaPi_Log.txt
    Wo kann der Fehler liegen !?
    AsgothianA hylamayn.deH T 3 Antworten Letzte Antwort
    • AphofisA Aphofis
      Das System sagt
                 └─21711 sleep 1
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @aphofis
      • Welche Influx db version hast du installiert
      • Welche Version des Influx adapters hast du installiert
      • Passen die Kennwörter / Ports ?
      • Ist der Port 8086 oder wird der vom ioBroker genutzt ?
      A.
      AphofisA 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @aphofis
        A.
        AphofisA Offline
        AphofisA Offline
        Aphofis
        @asgothian
        InfluxDB habe ich v1.8.9 (git: 1.8 d9b56321d579) installiert und vor dem JS-Controller Update ging die Datenbank noch
        In ioBroker habe ich v1.9.5 installiert
        Kennwörter und Ports habe ich nicht geändert.
        8086 prüfe ich mal aber wie gesagt vor dem Update lief alles einwandfrei
        Grafana sagt
        Network Error: Bad Gateway(502)
        • AphofisA Aphofis
          @asgothian
          Grafana sagt
          AphofisA Offline
          AphofisA Offline
          Aphofis
          Das sagt das System dazu:
          pi@AquaPi:~ $ systemctl status influxdb.service
             Active: activating (start) since Tue 2021-09-21 17:16:39 CEST; 10s ago
          Cntrl PID: 21096 (influxd-systemd)
                     ├─21096 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                     ├─21097 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                     └─21560 sleep 1
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.672409Z lvl=info msg="Opened file" log_id=0WjEjHkl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/32/000000001-000000001.tsm id=0 duration=0.46
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.676008Z lvl=info msg="Opened file" log_id=0WjEjHkl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/40/000000002-000000001.tsm id=1 duration=1.19
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.676996Z lvl=info msg="Opened file" log_id=0WjEjHkl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/40/000000001-000000001.tsm id=0 duration=2.14
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.700146Z lvl=info msg="Opened shard" log_id=0WjEjHkl000 service=store trace_id=0WjEjHlG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/3
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.709636Z lvl=info msg="Opened file" log_id=0WjEjHkl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/48/000000001-000000001.tsm id=0 duration=3.10
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.713708Z lvl=info msg="Opened shard" log_id=0WjEjHkl000 service=store trace_id=0WjEjHlG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.713989Z lvl=info msg="Reading file" log_id=0WjEjHkl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/48/_00002.wal size=63512
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.715343Z lvl=info msg="Opened shard" log_id=0WjEjHkl000 service=store trace_id=0WjEjHlG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/4
          Sep 21 17:16:39 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:39.762959Z lvl=info msg="Opened shard" log_id=0WjEjHkl000 service=store trace_id=0WjEjHlG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/4
          Sep 21 17:16:48 AquaPi influxd-systemd-start.sh[21096]: ts=2021-09-21T15:16:48.789027Z lvl=info msg="Reading file" log_id=0WjEjHkl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/47/_00002.wal size=10487991
          • AphofisA Aphofis
            Das System sagt
                       └─21711 sleep 1
            hylamayn.deH Offline
            hylamayn.de
            @aphofis Hi !
            ich würde mich da gerne anhängen. Ich habe Iobroker vor kurzem neu eingerichtet und für eine kurze Zeit schien alles zu klappen. Seit ein paar Tagen kann ich InfluxDB nicht mehr starten. Fehlermeldungen und Log ziemlich 1:1 wie bei Aphofis.
            Es gibt im Netz Unmengen von Meldungen zu diesem Thema. Hauptproblem scheint etwas mit der Rechtevergabe zu sein.
            Da ich relativ wenig von Linux und Iobroker verstehe kann ich nur die Tipps in den diversen Google-Fundstellen nachmachen und das führte bisher zu nichts.
            Startpunkt ist wohl das komplette Deinstallieren von Influx, einschließlich der Config Datei(en). Da geht es schon los: was gibt es da alles? Wie kriegt man Influx wirklich vollständig weg?
            Dann das Problem mit den Benutzern. Beim Installieren von Grafana/InfluxDB/IObroker wird man ja aufgefordert, diverse Benutzer zu kreieren. Neben "admin" gibt es da bei mir einen "influxDB" und auf dem Pi, auf dem alles installiert ist bin ich als "pi" unterwegs. Könnte das Teil des Problems sein? Vielleicht fehlt just der User bei mir, der die nötigen Rechte hat?
            Vielleicht könnte mal jemand, der was versteht von der Sache mich an die Hand nehmen und mir mal genau erklären, wie man InfluxDB neu aufsetzt ohne irgendwelche dunklen Linux-Probleme zu erzeugen? Er oder sie würde sich sehr verdient machen, glaube ich. Denn betroffen scheinen echt viele zu sein ...
            Grüße,
            Christoph
            • AphofisA Aphofis
              Das System sagt
                         └─21711 sleep 1
              T Nicht stören
              T Nicht stören
              tritor
              @aphofis
              hi,
              ich habe es hiermit hinbekommen: https://forum.iobroker.net/topic/46916/influx-db-abgelehnt/60?_=1632432206027
              Nur aus irgendwelchen Gründen mußte ich bei meiner InfluxDB-Installation (läuft in einer LXC unter Proxmox) Curl neu installieren.
              sudo apt update
              sudo apt -y install curl
              Danach ging es bei mir wieder.
              Einen Versuch ist es Wert.
              Gernot
              Host: i9 server Proxmox , Debian 13.4 for ioBroker
              ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
              Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
              Grafana 13.0.1 / InfluxDB 2.8.0
              • AphofisA Offline
                AphofisA Offline
                Aphofis
                @hylamayn-de
                Gut, das ich schon mal nicht alleine bin.
                Ich hatte versucht influxdb neu zu installieren nur habe ich anscheinend eine defekte Paketquelle und weiß nicht genau wie ich diese in
                /etc/apt/sources.list.d/influxdb.list
                reparieren kann.
                pi@AquaPi:~ $ sudo apt-get update
                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                OK:2 https://repos.influxdata.com/debian buster InRelease
                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                OK:4 https://archive.raspbian.org/raspbian buster InRelease
                Ign:5 https://dl.yarnpkg.co m/debian InRelease
                Fehl:6 https://dl.yarnpkg.co m/debian Release
                  Redirection from https to 'http://ww25.dl.yarnpkg.co/dists/m/debian/Release?subid1=20210924-0338-51a4-b0d7-70899cc09fbb' is forbidden [IP: 103.224.212.219 443]
                E: Das Depot »https://dl.yarnpkg.co m/debian Release« enthält keine Release-Datei.
                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                pi@AquaPi:~ $
                • AphofisA Aphofis
                  @hylamayn-de
                  reparieren kann.
                  pi@AquaPi:~ $
                  @aphofis
                  Bist du Sicher, dass du yarn benötigst?
                  Ich würde die Quelle komplett stilllegen.
                    @aphofis
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    Nö das weiß ich nicht aber wie stilllegen weiß ich auch nicht
                    • AphofisA Aphofis
                      @aphofis
                      In
                      wird es vermutlich eine Datei geben, die yarn.list oder so ähnlich heißt. In der die entsprechenden Zeilen per hash/Gartenzaun auskommentieren.
                      Oder die Datei komplett löschen.
                        @aphofis
                        In
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        Das gibt der Status aus! also influxdb ist installiert aber kann nicht gestartet werden
                           Active: failed (Result: exit-code) since Fri 2021-09-24 07:25:49 CEST; 1min 17s ago
                          Process: 8162 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                        Sep 24 07:25:49 AquaPi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                        Sep 24 07:25:49 AquaPi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                        Sep 24 07:25:49 AquaPi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                        Sep 24 07:25:49 AquaPi systemd[1]: influxdb.service: Start request repeated too quickly.
                        Sep 24 07:25:49 AquaPi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                        Sep 24 07:25:49 AquaPi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                        Das komische ist, in /usr/lib/ gibt es keinen Ordner influxdb
                        • AphofisA Aphofis
                          @aphofis
                          Da muss noch was in der start-Datei geändert werden. Ist mehrfach hier im Forum verewigt.
                          • AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            So ich habe jetzt folgendes gemacht
                            alle verzeichnisse gelöscht
                            sudo rm -rv /var/lib/influxdb/data
                            sudo rm -rv /var/lib/influxdb/meta
                            sudo rm -rv /var/lib/influxdb/wal
                            Dann noch mal influxdb deinstalliert
                            sudo apt-get purge influxdb
                            dann noch mal
                            sudo apt update
                            Dann die normale influxdb Instalationsroutine durchgegangen
                            Jetzt startet influxdb normal ohne Fehler und die Ordner & Dateien sind auch am richtigen Fleck.
                            abrfage gibt jetzt korrekt aus:
                            pi@AquaPi:~ $ sudo influx
                            Connected to http://localhost:8086 version 1.8.9
                            InfluxDB shell version: 1.8.9
                            • hylamayn.deH hylamayn.de
                              @aphofis Hi !
                              Grüße,
                              Christoph
                              AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              @hylamayn-de
                              Hast du daten in der influxdb da du ja vor kurzem erst aufgesetzt hattest denle ich mal eher nicht.
                              Hast du das mal gemacht, was ich unten schrieb!?
                              https://forum.iobroker.net/post/680656
                              Kannst ja mal ne Info geben, wenns geklappt hat.
                              hylamayn.deH 1 Antwort Letzte Antwort
                              • AphofisA Aphofis
                                @hylamayn-de
                                hylamayn.de
                                @aphofis @hylamayn-de
                                Ooookay ... läuft bei mir. Ich weiss aber leider nicht genau wieso ...
                                Ich habe die Influx-Instanz in IOBroker gelöscht, Influx auf dem Pi deinstalliert, mit 'apt-get purge' alles gelöscht von influx (soweit das ging). Den Rest habe ich händisch gelöscht (z.B. die Pfade '/etc/influxdb' und '/var/lib/influxdb/'). Ja. Meine Datenbank ist damit weg, aber wie erwähnt habe ich das Ganze erst seit ein paar Tagen installiert und viel geht bisher ohnehin nicht ...). Danach zuerst Influx auf dem Pi und dann den Adapter im IOBroker neu installiert. Orientiert habe ich mich dabei streng an der Anleitung auf "verdrahtet.info".
                                An den Benutzer-Rechten, die ich oben erwähnt hatte, habe ich nach der Neuinstallation nichts geändert.
                                Mal schauen, wie lange das junge Glück anhält ;)
                                Achja. Eine Sache war, dass ich die Config-Datei beim Neu-Installieren nicht angepasst hatte ;)
                                Heute scheint zwar die Datenbank zu laufen, aber Grafana kriegt trotzdem nur wenig Daten. Unklar.
                                Naja. Ist bekannt. Wer sein Heim automatisiert hat immer alle Hände voll zu tun ;)
                                Grüße,
                                Christoph
                                • AphofisA Offline
                                  AphofisA Offline
                                  Aphofis
                                  @hylamayn-de
                                  Da hast du wohl Recht!
                                  Ich steuere mein Heim nur Minimal bei mir ist es eher ein 1000 Liter Meerwasser Aquarium
                                  Was meine volle Aufmerksamkeit hat und alles an Steuerung ist selbst gebaut und Blockly Steuerung hatte ich hier aus dem Forum tonnenweise Hilfe.
                                  Dann mach mal lieber die config einstellungen, wenn du schon sagst strikt.......
                                  • AphofisA Aphofis
                                    @hylamayn-de
                                    hylamayn.de
                                    @aphofis ... and again. Ich hatte das schon so im Urin. ;)
                                    Es geht wieder nicht und dieses Mal hilft auch die Neuinstallation mir nicht weiter.
                                    [gibt es eigentlich einen Plan B? Eine andere Datenbank, die im Handling etwas stabiler läuft?]
                                    pi@IOBroker:~ $ influx
                                    Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
                                    Please check your connection settings and ensure 'influxd' is running.
                                    und weiter:
                                    pi@IOBroker:~ $ sudo service influxdb start
                                    Job for influxdb.service failed because the control process exited with error code.
                                    See "systemctl status influxdb.service" and "journalctl -xe" for details.
                                    und ,,,
                                    pi@IOBroker:~ $ systemctl status influxdb.service
                                      Active: activating (start) since Sun 2021-09-26 16:34:00 CEST; 7s ago
                                    Cntrl PID: 12046 (influxd-systemd)
                                       Tasks: 11 (limit: 4915)
                                              ├─12046 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                              ├─12047 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                              └─12179 sleep 1
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.764879Z lvl=info msg="Using data dir" log_id=0WpdHIjl000 service=store path=/var/lib/influxdb/data
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.764974Z lvl=info msg="Compaction settings" log_id=0WpdHIjl000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.765038Z lvl=info msg="Open store (start)" log_id=0WpdHIjl000 service=store trace_id=0WpdHIkG000 op_name=tsdb_open op_event=start
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.776611Z lvl=info msg="Opened file" log_id=0WpdHIjl000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/1/000000001-000000001.tsm id=0 duration=1.981ms
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.778900Z lvl=info msg="Reading file" log_id=0WpdHIjl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/3/_00001.wal size=10489004
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.784070Z lvl=info msg="Reading file" log_id=0WpdHIjl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/2/_00001.wal size=5207161
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:00.817961Z lvl=info msg="Opened shard" log_id=0WpdHIjl000 service=store trace_id=0WpdHIkG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/1 duration=49.299ms
                                    Sep 26 16:34:00 IOBroker influxd-systemd-start.sh[12046]: Merging with configuration at: /etc/influxdb/influxdb.conf
                                    Sep 26 16:34:01 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:01.737329Z lvl=info msg="Opened shard" log_id=0WpdHIjl000 service=store trace_id=0WpdHIkG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2 duration=955.505ms
                                    Sep 26 16:34:04 IOBroker influxd-systemd-start.sh[12046]: ts=2021-09-26T14:34:04.672945Z lvl=info msg="Reading file" log_id=0WpdHIjl000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/3/_00002.wal size=10489063
                                    und schließlich:
                                    pi@IOBroker:~ $ journalctl -xe
                                    -- Subject: A start job for unit influxdb.service has failed
                                    -- Defined-By: systemd
                                    -- Support: https://www.debian.org/support
                                    -- A start job for unit influxdb.service has finished with a failure.
                                    -- The job identifier is 341174 and the job result is failed.
                                    Sep 26 16:38:51 IOBroker systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                    Sep 26 16:38:51 IOBroker systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5343.
                                    -- Subject: Automatic restarting of a unit has been scheduled
                                    -- Automatic restarting of the unit influxdb.service has been scheduled, as the result for
                                    -- the configured Restart= setting for the unit.
                                    Sep 26 16:38:51 IOBroker systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                    -- Subject: A stop job for unit influxdb.service has finished
                                    -- A stop job for unit influxdb.service has finished.
                                    -- The job identifier is 341231 and the job result is done.
                                    Sep 26 16:38:51 IOBroker systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
                                    -- Subject: A start job for unit influxdb.service has begun execution
                                    -- A start job for unit influxdb.service has begun execution.
                                    -- The job identifier is 341231.
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: Merging with configuration at: /etc/influxdb/influxdb.conf
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.505570Z lvl=info msg="InfluxDB starting" log_id=0WpdZ2SG000 version=1.8.9 branch=1.8 commit=d9b56321d579
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.505631Z lvl=info msg="Go runtime" log_id=0WpdZ2SG000 version=go1.13.8 maxprocs=4
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.506928Z lvl=info msg="Using data dir" log_id=0WpdZ2SG000 service=store path=/var/lib/influxdb/data
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.507027Z lvl=info msg="Compaction settings" log_id=0WpdZ2SG000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.507080Z lvl=info msg="Open store (start)" log_id=0WpdZ2SG000 service=store trace_id=0WpdZ2Sl000 op_name=tsdb_open op_event=start
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.522209Z lvl=info msg="Reading file" log_id=0WpdZ2SG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/3/_00001.wal size=10489004
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.541613Z lvl=info msg="Reading file" log_id=0WpdZ2SG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/2/_00001.wal size=5207161
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.545150Z lvl=info msg="Opened file" log_id=0WpdZ2SG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/_internal/monitor/1/000000001-000000001.tsm id=0 duration=8.599ms
                                    Sep 26 16:38:51 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:51.563236Z lvl=info msg="Opened shard" log_id=0WpdZ2SG000 service=store trace_id=0WpdZ2Sl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/_internal/monitor/1 duration=49.654ms
                                    Sep 26 16:38:52 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:52.430473Z lvl=info msg="Opened shard" log_id=0WpdZ2SG000 service=store trace_id=0WpdZ2Sl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/2 duration=890.105ms
                                    Sep 26 16:38:55 IOBroker influxd-systemd-start.sh[17013]: ts=2021-09-26T14:38:55.410994Z lvl=info msg="Reading file" log_id=0WpdZ2SG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/3/_00002.wal size=10489063
                                    Mich schreit da nichts an, aber ich hab auch keine Ahnung :)
                                    1000 l Meerwasser. Wow. Was hältst du dir da? Ach, hast du ja geschrieben. Blocklys ... ;)
                                    Guppys hätte ich gekannt.
                                    hylamayn.deH AphofisA 2 Antworten Letzte Antwort
                                      und weiter:
                                      und ,,,
                                                └─12179 sleep 1
                                      und schließlich:
                                      hylamayn.de
                                      @hylamayn-de
                                      ... außer natürlich
                                      Die Ports habe ich mal ausgelesen. 8086 taucht da gerade gar nicht auf:
                                      pi@IOBroker:~ $ sudo netstat -lptn
                                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      359/deCONZ
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      784/sshd
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      23728/influxd
                                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1911/node-red
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      2399/io.sonoff.0
                                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      359/deCONZ
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1606/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1606/iobroker.js-co
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1753/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      2997/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      784/sshd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      771/grafana-server
                                      Ich sehe aber InfluxDB mit Port 8088 verbunden. Ist das das Problem?
                                      In der influx-config hatte ich (wieder) was falsch, ich hatte nur den Port und nicht die Adresse eingetragen, mit der Influx bindet.
                                      Das zu korrigieren hat aber auch nichts gebracht. Und dann das hier (nach einem Reboot):
                                       influxd
                                       8888888           .d888 888                   8888888b.  888888b.
                                         888            d88P"  888                   888  "Y88b 888  "88b
                                         888            888    888                   888    888 888  .88P
                                         888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                                         888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                                         888   888  888 888    888 888  888   X88K   888    888 888    888
                                         888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
                                       8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
                                      2021-09-26T16:03:20.027925Z     info    InfluxDB starting       {"log_id": "0WpiOPMl000", "version": "1.8.9", "branch": "1.8", "commit": "d9b56321d579"}
                                      2021-09-26T16:03:20.028041Z     info    Go runtime      {"log_id": "0WpiOPMl000", "version": "go1.13.8", "maxprocs": 4}
                                      run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
                                      Wenn ich das richtig sehe, spekuliert Influx auf den Port 8088, der schon belegt ist. Wo, ausser in " /etc/influxdb/influxdb.conf" kann ich denn den Port für Influx einstellen?
                                      Help, pleeeease ... ;)
                                      Christoph
                                        @hylamayn-de
                                        ... außer natürlich
                                         influxd
                                        Christoph
                                        hylamayn.de
                                        @hylamayn-de
                                        ich verstehe das nicht ... ich hab wieder alles neu installiert, die zwei Influx-Verzeichnisse, von denen ich weiss, gelöscht
                                        ('/var/lib/influxdb/' und '/etc/influxdb/'), alles neu installiert und die IOBroker Datenbank angelegt. Again. Noch nicht die Config-Datei geändert (also z.B. Binding-Port und -Adresse für HTTP angepasst). Und jetzt geht es wieder:
                                        pi@IOBroker:~ $ sudo influx
                                        Irgenwie hasse ich es, wenn es das macht mit mir... ;)
                                        Warum geht es/geht es nicht?? Auf eine Datenbank muss man sich verlssen können ;)
                                        Christoph
                                        Thomas BraunT JLegJ 2 Antworten Letzte Antwort
                                          @hylamayn-de
                                          Christoph
                                          @hylamayn-de Welche Version läuft?
                                          Ich vermute 1.8.
                                          Wenn du die 1.6. aus dem hauseigenen Debian-Repo einsetzt?
