  4. PH-Messung
    6.3k
PH-Messung
432 Beiträge 48 Kommentatoren 145.7k Aufrufe 50 Beobachtet
  • cvidalC Offline
    cvidalC Offline
    cvidal
    Forum Testing
    #331
    Ich würde meine Ph Sonde wenn die mal geliefert wird in Leitungswasser reinigen, dann auf 4PH Kalibrieren, wieder mit Leitungswasser reinigen dann mit PH 6.86 kalibrieren und dann in die Messzellen rein und fertig.
    Oder macht ihr da alle son aufwand mit Destilliertem Wasser und was weiß ich was man da alles beachten muss.
    Die Redoxsonde würde ich einfach in irgendeiner Lösung zum gegenprüfen halten und fertig.
    • D dala
      Hi. My german skills are very limited but I belive I have a similar idea as you ask for.
      I have a PH-803w connected and can read values in the accompanied app but that is about it.
      What I would like is to publish this data to my MQTT broker and make use of it in a bigger IoT network. I.e. show it in my control panel for the entire home, or only allow chlorine dosing while the filter pump is running.
      When opening the device there is two pins from the ESP exposed, Rx/Tx, but yet I have not been able to read any data from them that makes sense. Normally those would be the flash program pins and debug logging and use serial interface. But regardless of Baudrate I try on my UART cable it seem only to be random values. More attempts to come, yet only look at it as ASCII, binary data is also a possibility.
      Next way to tackle it is to connect the device over an network bridge (device <-> router <-> bridge <-> internet) with Wireshark or similar to sniff the traffic. At least it will expose the IP ports it used in the cloud communication, but likely the data will be over a secured socket and I'm stuck.
      Feel free to comment my ideas or add new.
      arumpel
      #332
      @dala said in PH-Messung:
      Hi. Since you have already taken the unit apart maybe you or any other can check the wiring from the transformer to the pcb. I just received my controller today and the transformer gets very hot after a few minutes. I measured about 5,5W power consumption while the printing on the backside says 2 Watts.
      The device starts up and everything looks normal but i haven´t yet tested it with the probes.
      I also didn´t manage to register the device in my wifi. the app can´t find it :-( I tried it with holding the wifi button for some seconds until flashing, holding it continiously, not pressing it and just reboot by power cord but the app could never find something but i also skipped the registration process because it says it´s not need.
      Maybe anyone can help me with the first or second problem ;-)
      • H Offline
        Hansemann0
        #333
        Hallo Gemeinde
        Ich habe hier aufmerksam mitgelesen und eifrig nachgebaut. Mein ph-803w ist installiert und misst... wenn ich mit den Daten noch nicht so ganz zufrieden bin, aber ich muss da noch angewöhnen (redox wert Salzwasserpool)
        Ich habe nun versucht die in einem ersten schritt die Werte vom Adapter in mit Blockly aus zu lesen, aber das funktioniert nicht, ich erhalte weder Ph noch Redox wert angezeigt. Da ich noch neu einstiger bin, mit Blockly vermute ich den Fehler ganz klar bei mir und fehlende Logik.
        Würde mir jemand ein kurzes Skript schnipsel zur Verfügung stellen, mit dem ich meinen Adapter testen kann.
        • H Hansemann0
          Hallo Gemeinde
          #334
          @hansemann0 sagte in PH-Messung:
          Ich enke am besten zeig Du doch mal Deine Skript - am besten in nem eigene Thread im "Skriping" Bereich. Dann setzen wir da an und verbessern es
          H 1 Antwort Letzte Antwort
          • apollon77A apollon77
            Hansemann0
            #335
            @apollon77
            https://forum.iobroker.net/topic/46964/blockly-lern-simulator-gesucht/4?_=1628957209160
            StralisS 1 Antwort Letzte Antwort
            • H Hansemann0
              @apollon77
              StralisS Offline
              StralisS Offline
              Stralis
              #336
              @hansemann0 said in PH-Messung:
              @apollon77
              • StralisS Stralis
                @apollon77
                StralisS Offline
                StralisS Offline
                Stralis
                #337
                @stralis
                Hallo, habe mich hier angemeldet weil ich im Poolforum wirklich tolle Visualisierungen euer Poolsteuerungen gesehen habe. Das hat mein Interesse geweckt.
                Betreibe seit diesem Jahr einen PH 803W mit Relais zum Steuern der Pumpen für Chlor und PH. Ganz Old School.
                Ein Raspberry Pi 4 Modell B 4GB lauft seit kurzem bei mir und ich lese mich gerade in das Thema ein. Außer schaltbare Steckdosen hatte ich noch nicht viel mit Smart Home zu tun. Sicherlich kommen bald die ersten Probleme und Fragen.
                cvidalC 1 Antwort Letzte Antwort
                • StralisS Stralis
                  @stralis
                  cvidalC Offline
                  cvidalC Offline
                  cvidal
                  Forum Testing
                  schrieb am zuletzt editiert von cvidal
                  #338
                  So habe jetzt alles seit ca. 3 Wochen am laufen, leider gibt der PH 803 erst nach ca. 30min konstante Werte her, ist das bei euch auch so? Ist aber erstmal egal, Chlor Trigger ich eh erst nach 45min Pumpenlaufzeit.
                  Ich habe aber ein Problem das die Kempa-Pumpen Luft ziehen weil der mitgelieferte Schlauch mit dem Gewicht nicht bis zum Boden im Kanister hängt weil der Schlauch nicht gerade runterhängt, der ist einfach zu Starr. Wie habt ihr das gelöst? Irgendwie muss da mehr Gewicht oder den Schlauch durch ein Leerrohr ziehen?
                  • cvidalC cvidal
                    #339
                    @cvidal Dazu gibts ne längliche Diskussion im PoolShop Forum :-) Hängt wohl von der genutzten Elektrode ab und auch ob es ein Salzelektrolysesystem ist oder nicht und sowas.
                    Bei mir ists so das ich nach ca. 10 Minuten sehe wo ich stehe (weil wenn die ansteigende Kurve dann nicht bei Wert X ist ists einfach zu wenig ... also steuere ich aktuell danach :-)
                    • cvidalC Offline
                      cvidalC Offline
                      cvidal
                      Forum Testing
                      #340
                      Mein Log wird vollgespamt, mein PH803W ist nur Online wenn die Pumpe läuft.
                      Habe keinen PH803 Adapter update gemacht, ich meine vor ein Paar Tagen war das nicht so.
                      Bin ich alleine damit?
                      ph803w.0
                      2021-09-19 20:51:16.370 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:51:03.314 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:50:50.258 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:50:37.202 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:50:24.146 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:50:11.090 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:49:58.034 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:49:44.978 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:49:31.922 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:49:18.866 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:49:05.810 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:48:52.754 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:48:39.698 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:48:26.642 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:48:13.586 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      2021-09-19 20:48:00.530 info PH803W device FqF5Bz2SXzrCoLPSw2W4az Error: Error: connect EHOSTUNREACH 192.168.12.148:12416
                      ph803w.0
                      Gruß Christian
                      • cvidalC cvidal
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        ph803w.0
                        Gruß Christian
                        #341
                        @cvidal ja das ist so. Kannst loglevel hoch stellen auf „warn“. Ansonsten (einmache ich es): nutze den system.adapter.ph803w.0.alive state und starte den Adapter wenn du die Pumpe startest und mach Instanz aus wenn die Pumpe aus geht ;-)) (ich mach das sogar paar Minuten verzögert damit sich die ph803w Werte erstmal kurz stabilisieren.
                          cvidalC Offline
                          cvidalC Offline
                          cvidal
                          Forum Testing
                          #342
                          @apollon77 Stimmt. Adapter Start bei Pumpen Start so werde ich es auch machen. Den system.adapter.ph803w.0.alive state prüfe ich auch schon bevor Chlor gepumpt wird.
                          Gruß Christian
                          • cvidalC cvidal
                            Gruß Christian
                            martinschm
                            #343
                            bin im Powerpool Forum auf den Adapter gestoßen. Mega mal wieder @apollon77 , der Poolaufbau steht bei mir bald bevor und hab mir jetzt wg dem Adapter die 803W gleich gekauft.
                            Welche Sonden verwendet ihr den so?
                            Hab immer wieder von der Gemke Messzelle gelesen, aber müssen es auch die Sensoren von denen sein, oder "reichen" die aus China die dann in die Messzelle passen?
                            ciao
                            Martin
                            • M martinschm
                              ciao
                              Martin
                              #344
                              @martinschm Bei mir gehen die aus China gut ... :-) Vllr hole ich doch für ORP ne Gemke nächstes Jahr - die soll vllt bei Salzwasser mit Chlorinator besser sein ...
                                martinschm
                                #345
                                @apollon77 die du oben verlinkt hast ist ne ORP.
                                Welche hast du für pH?
                                • M martinschm
                                  #346
                                  @martinschm https://www.aliexpress.com/item/1996834576.html?spm=a2g0s.9042311.0.0.33fe4c4d9Wu8D8
                                    daniel_iobroker
                                    #347
                                    @apollon77
                                    Ich habe mir auch den ph / orp Controller geholt und werde diesen dann in Frühjahr verbauen.
                                    Natürlich wollte ich zuerst überprüfen, ob dieser überhaupt funktioniert.
                                    Das Thema mit der App war gleich mal durch, das klappt. Ich sehe die Werte am Handy in der ph803 app.
                                    Wenn ich deinen Adapter nutzen möchte, passiert aber leider nix... Also fast nichts. Im log sehe ich, dass der Adapter startet. Mehr Einträge gibt es leider nicht (Hab schon bei debug auf alles gestellt).
                                    Hab dann gelesen, dass der Controller im gleichen Netzwerk sein muss... Tja, ich glaube da liegt bei mir das Problem.
                                    Ich habe einen Router, dort hängt auch der iobroker Server drann. Adressbereich 192.168.8.x . Dann aufgrund der Entfernung zum Garten, habe ich einen Repeater (den ich LEIDER auf openWRT geflasht habe, da die Herstellersoftware schlecht war). Dieser Repeater selbst hat zwar noch eine IP im Adressbereich 192.168.8.x aber alle Clients, die sich an diesem Repeater anmelden, haben den Adressbereich 192.168.1.x .. Also anderes Subnet? Kann sein, dass daher der Controller nicht gefunden wird? Oder müsste der Adapter selbst mehr Meldungen ins Log schreiben, als nur starting?
                                    • D daniel_iobroker
                                      @apollon77
                                      #348
                                      @daniel_iobroker Das klingt grob danach. Am Ende gäbe es zwei Varianten:
                                      1.) Du schaust in wieweit dein OpenWrt eine Einstellung hat auch UDP Pakete zu routen
                                      2.) Du hängst den iobroker rechner mal "kurz" in das netz das die "registrierung tut" und der adapter das Gerät anlegen kann - weil dann hat er die IP
                                      3.) Du versuchst mal das in https://github.com/Apollon77/ioBroker.ph803w/issues/4#issuecomment-868824727 beschriebene Vorgehen
                                        daniel_iobroker
                                        schrieb am zuletzt editiert von daniel_iobroker
                                        #349
                                        @apollon77
                                        Danke für deine rasche Rückmeldung:
                                        Zu Punkt 1:
                                        Man kann in OpenWRT eigentlich alles einstellen - wenn man weiß, was man tut. Ich kenne mich dort nicht so gut aus. Habe jetzt mal den Port 12416 weitergeleitet. Leider bekomme ich hier noch einen Timeout Fehler vom PH803 Adapter.
                                        Zu Punkt 2: Das geht leider nicht, da der Server direkt am LAN hängt. Das zweite Netz ist nur ein WLAN Repeater
                                        zu Punkt 3:
                                        Das habe ich soeben gemacht. Die anderen Objekte wurde auch gleich angelegt durch den Adapter. Aber im log bekam ich Timeout Fehler => Der Adapter kann sich also nicht mit den PH803 verbinden. Habe ich den richtigen Port weitergeleitet?
                                        Das komische ist ja, dass die App ganz normal am Handy funktioniert, obwohl ich dort auch im anderen Netz (also im 192.168.8.x) unterwegs bin. Also dürfte das Routing im OpenWRT Gerät schon ok sein oder?
                                        • D daniel_iobroker
                                          @apollon77
                                          Zu Punkt 1:
                                          zu Punkt 3:
                                          #350
                                          @daniel_iobroker Zur App: Steht denn da "Cloud" oder steht "Local" dabei? Das Gerät senden ja auch Daten an den Cloud Account und wenn Lokal nicht geht dann liess die App aus der Cloud ... Also von daher kann schon sein das es tut über den Cloud Umweg geht.
                                          Ansonsten ist der Port an sich korrekt 12416 ... Mal mit telnet versucht ?
