  4. Zigbee Adapter startet nicht
    6.5k
43 Beiträge 3 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    Mein CC2531 Zigbee lässt sich nicht mehr starten, der Adapter geht kurz auf gelb (verbunden mit Host und Lebenszeichen ja, verbunden mit Zigbee nein), dann auf rot.
    In den Logs kommt:
    zigbee.0	2021-08-28 21:50:51.869	warn	(26419) Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0	2021-08-28 21:50:51.867	info	(26419) terminating
    zigbee.0	2021-08-28 21:50:51.860	error	(26419) Device 0x60a423fffed222f6 "TS0044" not described in statesMapping.
    zigbee.0	2021-08-28 21:50:51.858	error	(26419) Device 0x60a423fffed222f6 "TS0044" not described in statesMapping.
    zigbee.0	2021-08-28 21:50:51.634	info	(26419) Zigbee: disabling joining new devices.
    zigbee.0	2021-08-28 21:50:51.628	info	(26419) cleaned everything up...
    zigbee.0	2021-08-28 21:50:51.626	info	(26419) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0	2021-08-28 21:50:51.512	error	(26419) Cannot read property 'map' of undefined
    zigbee.0	2021-08-28 21:50:51.511	error	at processImmediate (internal/timers.js:463:21)
    zigbee.0	2021-08-28 21:50:51.511	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:125:31)
    zigbee.0	2021-08-28 21:50:51.511	error	at StatesController.getExcludeExposes (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:352:23)
    zigbee.0	2021-08-28 21:50:51.511	error	at Object.fillStatesWithExposes (/opt/iobroker/node_modules/iobroker.zigbee/lib/devices.js:2799:5)
    zigbee.0	2021-08-28 21:50:51.511	error	at applyExposes (/opt/iobroker/node_modules/iobroker.zigbee/lib/exposes.js:597:31)
    zigbee.0	2021-08-28 21:50:51.511	error	at createFromExposes (/opt/iobroker/node_modules/iobroker.zigbee/lib/exposes.js:498:33)
    zigbee.0	2021-08-28 21:50:51.511	error	at genState (/opt/iobroker/node_modules/iobroker.zigbee/lib/exposes.js:66:39)
    zigbee.0	2021-08-28 21:50:51.511	error	(26419) TypeError: Cannot read property 'map' of undefined
    zigbee.0	2021-08-28 21:50:51.510	error	(26419) unhandled promise rejection: Cannot read property 'map' of undefined
    zigbee.0	2021-08-28 21:50:51.509	error	(26419) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-08-28 21:50:51.144	info	(26419) Starting Zigbee npm ...
    zigbee.0	2021-08-28 21:50:51.044	info	(26419) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.2, js-controller: 3.2.16
    Meine Konfiguration:
    wolfgang@raspberrypi4:~ $ iobroker -v
    3.2.16
    wolfgang@raspberrypi4:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.22.2
    /usr/bin/node
    v12.22.2
    /usr/bin/npm
    6.14.13
    nodejs:
      Installiert:           12.22.2-1nodesource1
      Installationskandidat: 12.22.2-1nodesource1
      Versionstabelle:
     *** 12.22.2-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    w
    • W WolfgangFB
      In den Logs kommt:
      3.2.16
      /usr/bin/nodejs
      v12.22.2
      /usr/bin/node
      v12.22.2
      /usr/bin/npm
      6.14.13
      nodejs:
        Versionstabelle:
      w
      Thomas BraunT Offline
      @wolfgangfb
      iobroker -v
      3.2.16
      Aktualisieren. NodeJS ebenfalls.
      Und den Rest vom Fest auch. Ist vermutlich auf einem ähnlichen alten Stand.
      • W Offline
        W Offline
        WolfgangFB
        Ich bin ehrlich gesagt überfordert.
        Ich habe versucht, IO-Broker auf den aktuellen Stand zu bringen und habe im Forum folgendes gefunden und gemacht:
        iobroker stop
        iobroker update
        iobroker update self
        iobroker upgrade
        iobroker start
        Ergebnis: Hat ewig gedauert, die Oberfläche sieht anders aus, aber die Version ist immer noch 3.2.16. Dafür sind alle ESP-Home Nodes weg :-(
        Also bei den Hosts (Rote Markierung) auf den Button "Aktualisiere auf 3.3.15" geklickt und den Hinweis gefunden, dass man beim Update des js-controllers von 1 auf 2 bitte den Forenbeitrag
        https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-f%C3%BCr-alle-im-stable
        lesen soll.
        Dort kommt ein Thread aus dem Jahre 2019 mit ca. 500 Posts.
        Ganz wichtig scheint zu sein, dass ich bei Multihost (hier vorhanden) zuerst die Slaves aktualisieren soll.
        Nachdem ich die Oberfläche erneut aufgerufen habe wird mir komischerweise 3.2.16 als aktuelle Version angezeigt. Der einzige Hinweis der kommt, ist, dass Zigbee in einer Endlos Boot Schleife ist und beendet worden ist.
        So, aber wie ich jetzt mein System aktualisiere bzw. noide-js und npm auf die aktuelle Version bringe (ohne noch mehr außer meinen ESP-Home Nodes zu verlieren) kapiere ich nicht.
        Warum gibt es nicht einfach einen Button "Bringe alles auf den neuesten Stand"?
        Wo finde ich eine Anleitung für "Dummies" die kürzer als 500 Seiten ist, mit der ich gefahrlos mein System aktualisieren kann?
        • W WolfgangFB
          iobroker stop
          iobroker update
          iobroker upgrade
          iobroker start
          lesen soll.
          @wolfgangfb
          Also 'Großbaustelle'.
          Ich kann dir hier nicht alles in die Tasten diktieren.
          So grundsätzlich würde ich immer zuerst den Slave aktualisieren, danach den Master.
          Auf jedem System:
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Dann nodeJS prüfen, ggf. updaten, siehe Anleitung in meiner Signatur.
          Und dann zuerst wieder den ioBroker-Slave aktualisieren, Befehlskette so:
          iobroker stop
          iobroker update
          iobroker upgrade
          iobroker upgrade self
          iobroker start
          Dann als Abschluss den ioBroker-Master.
          • W Offline
            W Offline
            WolfgangFB
            Hi
            Ich bin jetzt noch mehr verunsichert. Ich habe auf beiden Raspberrys die angegeben full upgrade Prozedur durchgeführt.
            Ergebnis: Auf beiden ist
            pi@raspberrypi4:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.22.5
            /usr/bin/node
            v12.22.5
            /usr/bin/npm
            6.14.14
            nodejs:
              Installiert:           12.22.5-1nodesource1
              Installationskandidat: 12.22.5-1nodesource1
              Versionstabelle:
             *** 12.22.5-1nodesource1 500
            Laut Deiner Anleitung node-js zu aktulisieren ist
            HINWEIS:
            Das derzeitig empfohlene nodeJS-Paket ist Node 12 inklusive npm 6 (Stand 23.04.2021)
            (Auch wenn in der Anleitung oft die 14 vorkommt, die hatte ich gerade zum Testen aktiv). Niemals ungerade Versionsnummern verwenden, das sind ausschließlich Versionen für Entwickler und haben in einem stabilen System nichts zu suchen.
            Demnach sind die System auf dem aktuellen Stand.
            Zigbee ist auf 1.4.4 und das ist laut meinem Admin Adapter der aktuell verfügbare Stand
            Auf einem dritten Raspberry mit Node-js 15.8.0 (ungerade, also nicht empfohlen) läuft der gleiche Zigbee Adapter mit Version 1.4.4.
            Fragen: Wo bekom,me ich höhere (stable) Versionen von iobroker als 3.2.16 her? Wo bekomme ich eine höhere Version des Zigbee Adapters her?
            Ich denke an der Version 1.4.4 liegt es nicht, denn im dritten Pi läuft die ja.
            • W WolfgangFB
              Hi
              /usr/bin/nodejs
              v12.22.5
              /usr/bin/node
              v12.22.5
              /usr/bin/npm
              6.14.14
              nodejs:
                Versionstabelle:
              HINWEIS:
              @wolfgangfb
              Ich kann nicht genau entziffern was da aus einer Anleitung kopiert ist und was von dir ist.
              Node12 ist im Moment jedenfalls die empfohlene Version. Würde ich auf allen Systeme gleich halten, insbesondere die node15 ist Murks.
              iobroker update -i
              liefert?
              Aktuelle Versionen sind:
              zigbee
              github:	1.6.1
              latest:	1.6.0 for 19 days
              stable:	1.5.6 for 92 days
              • W Offline
                W Offline
                WolfgangFB
                schrieb am zuletzt editiert von WolfgangFB
                Das was ich unter "HINWEIS" habe, ist aus der Anleitung aus Deiner Signatur zitiert.
                Was mich jetzt verwirrt ist folgendes:
                Wenn ich den Admin Adapter auf der neuen Version eingestellt habe erscheint bei den Adapter unter Zigbee "Installiert: 1.4.4 (3~) Verfügbar 1.4.4
                Stelle ich den Admin Adapter auf die alte Benutzeroberfläche um steht da plötzlich
                Installiert 3 1.6. Verfügbar 1.5.6
                Wenn ich iobroker update -i ausführe kommt:
                (raspberrypi4 ist der Master, node-js 12.22.5)
                pi@raspberrypi4:~ $ iobroker update -i
                hash unchanged, use cached sources
                update done
                Adapter    "admin"         : 5.1.23   , installed 5.1.25
                Adapter    "zigbee"        : 1.5.6    , installed 1.6.0
                (raspberrypi202 ist der Slave, auf dem der Zigbee Adapter läuft, grün wird, hier ist node-js 15.8.0)
                pi@raspberrypi202:~ $ iobroker update -i
                hash changed or no sources cached => force download of new sources
                update done
                Adapter    "admin"         : 5.1.23   , installed 5.1.14 [Updateable]
                Adapter    "zigbee"        : 1.5.6    , installed 1.4.4 [Updateable]
                raspberrypi204 ist ein zweiter Slave, auf dem der Zigbee Adapter auch nicht startet)
                pi@raspberrypi204:~ $ iobroker update -i
                update done
                Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
                Ausgerechnet die Installation mit dem "Murks" node15 ist die einzige, be der Zigbee läuft. Wie die 1.6.0 auf den Master kommt weiß ich nicht mehr genau, ich glaube für die ESP-Home Geschichte war ich eine Zeit lang bei Beta Versionen in den Verwahrungsorten)
                • W WolfgangFB
                  update done
                  update done
                  update done
                  @wolfgangfb
                  Und jetzt auf den Systemen mit Updateable
                  iobroker upgrade
                  ausführen.
                  Ich würde vielleicht noch jeweils ein
                  iobroker upload all
                  hinterherwerfen.
                  W 1 Antwort Letzte Antwort
                    @wolfgangfb
                    iobroker upgrade
                    ausführen.
                    iobroker upload all
                    hinterherwerfen.
                    W Offline
                    W Offline
                    WolfgangFB
                    mit
                    iobroker stop
                    davor oder nicht?
                    • W WolfgangFB
                      mit
                      iobroker stop
                      davor oder nicht?
                      @wolfgangfb
                      Sollte egal sein. Schaden kann es aber nicht.
                        @wolfgangfb
                        W Offline
                        W Offline
                        WolfgangFB
                        pi@raspberrypi202:~ $ iobroker stop
                        pi@raspberrypi202:~ $ iobroker upgrade
                        [jede Menge gelöscht]
                        pi@raspberrypi204:~ $ iobroker upload all
                        pi@raspberrypi202:~ $ iobroker start
                        update done
                        Adapter    "admin"         : 5.1.23   , installed 5.1.23
                        Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
                        und
                        pi@raspberrypi204:~ $ iobroker stop
                        pi@raspberrypi204:~ $ iobroker upgrade
                        pi@raspberrypi204:~ $ iobroker start
                        update done
                        Ergebnis: Die beiden Zigbee Adapter, die vorher nichte liefen, laufen immer noch nicht, und der auf dem 202er, der vorher lief, geht jetzt auch nicht mehr :-(
                        Die beiden ersten sind "gelb", Verbunden mit Host: true, Lebenszeichen: true, verbunden mit Zigbee: false.
                        der, der vorher noch ging, ist "Verbunden mit Host": false, Lebenszeichen: false Verbunden mit Zigbee: true (wie auch immer das kommen kann).
                        • W WolfgangFB
                          update done
                          und
                          update done
                          @wolfgangfb
                          Zumindest sollten jetzt die Versionen aktuell sein.
                          Das krumme node@15 hast du auch auf node@12 gebracht?
                            @wolfgangfb
                            W Offline
                            W Offline
                            WolfgangFB
                            Nein, stand zum einen nicht in Deinem Posting, zum zweiten weiß ich nicht, wie das geht. Kannst Du mir kurz verraten, wie?
                            • W WolfgangFB
                              @wolfgangfb
                              Steht in meiner Signatur.
                                @wolfgangfb
                                W Offline
                                W Offline
                                WolfgangFB
                                OK, ich habe es gefunden, jetzt läuft auf allen 3 die gleiche node-js Version 12.22.5 und Zigbee läuft immer noch nicht (genau wie davor, 2 gelb, einer rot)
                                • W WolfgangFB
                                  @wolfgangfb
                                  Meldungen im log?
                                  Eine Instanz nach der nächsten...
                                  • W Offline
                                    W Offline
                                    WolfgangFB
                                    Ist das sinnvoll mit
                                    pi@raspberrypi4:/opt/iobroker/log $ more iobroker.current.log | grep zigbee
                                    oder welche Methode nimmt man, um aus der Logdatei Adaptermeldungen zu filtern?
                                    pi@raspberrypi4:/opt/iobroker/log $ tail -f /opt/iobroker/log/iobroker.current.log
                                    2021-08-29 22:56:53.569  - info: host.raspberrypi4 "system.adapter.zigbee.0" enabled
                                    2021-08-29 22:56:53.585  - warn: zigbee.0 (17489) Got terminate signal. Checking desired PID: 0 vs own PID 17489
                                    2021-08-29 22:56:53.639  - info: host.raspberrypi4 instance system.adapter.zigbee.0 started with pid 18770
                                    2021-08-29 22:56:53.587  - info: zigbee.0 (17489) cleaned everything up...
                                    2021-08-29 22:56:53.595  - info: zigbee.0 (17489) Zigbee: disabling joining new devices.
                                    2021-08-29 22:56:53.825  - warn: zigbee.0 (17489) Failed to stop zigbee during startup
                                    2021-08-29 22:56:53.826  - info: zigbee.0 (17489) terminating
                                    2021-08-29 22:56:53.828  - info: zigbee.0 (17489) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-08-29 22:56:53.866  - warn: zigbee.0 (17489) Got terminate signal. Checking desired PID: 18770 vs own PID 17489
                                    2021-08-29 22:56:57.147  - error: zigbee.0 (18770) zigbee.0 already running
                                    2021-08-29 22:56:57.150  - warn: zigbee.0 (18770) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                    2021-08-29 22:56:57.778  - error: host.raspberrypi4 instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                    2021-08-29 22:56:57.779  - info: host.raspberrypi4 Restart adapter system.adapter.zigbee.0 because enabled
                                    pi@raspberrypi4:/opt/iobroker/log $```
                                    • W WolfgangFB
                                      @wolfgangfb
                                      oder
                                      iobroker logs --watch
                                      beobachten, Adapter z. B. neustarten.
                                        @wolfgangfb
                                        Meldungen im log?
                                        W Offline
                                        W Offline
                                        WolfgangFB
                                        2021-08-29 22:44:53.186  - error: host.raspberrypi202 instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2021-08-29 22:44:53.187  - info: host.raspberrypi202 Restart adapter system.adapter.zigbee.2 because enabled
                                        2021-08-29 22:45:23.256  - info: host.raspberrypi202 instance system.adapter.zigbee.2 started with pid 3012
                                        2021-08-29 22:45:25.367  - error: host.raspberrypi202 Caught by controller[0]: internal/modules/cjs/loader.js:818
                                        2021-08-29 22:45:25.369  - error: host.raspberrypi202 Caught by controller[0]:   throw err;
                                        2021-08-29 22:45:25.369  - error: host.raspberrypi202 Caught by controller[0]:   ^
                                        2021-08-29 22:45:25.370  - error: host.raspberrypi202 Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
                                        2021-08-29 22:45:25.371  - error: host.raspberrypi202 Caught by controller[0]: Require stack:
                                        2021-08-29 22:45:25.371  - error: host.raspberrypi202 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
                                        2021-08-29 22:45:25.372  - error: host.raspberrypi202 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                        2021-08-29 22:45:25.373  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                                        2021-08-29 22:45:25.373  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                                        2021-08-29 22:45:25.374  - error: host.raspberrypi202 Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19)
                                        2021-08-29 22:45:25.375  - error: host.raspberrypi202 Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:74:18)
                                        2021-08-29 22:45:25.375  - error: host.raspberrypi202 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
                                        2021-08-29 22:45:25.376  - error: host.raspberrypi202 Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:999:30)
                                        2021-08-29 22:45:25.376  - error: host.raspberrypi202 Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                        2021-08-29 22:45:25.377  - error: host.raspberrypi202 Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:863:32)
                                        2021-08-29 22:45:25.378  - error: host.raspberrypi202 Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                        2021-08-29 22:45:25.378  - error: host.raspberrypi202 Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:887:19) {
                                        2021-08-29 22:45:25.379  - error: host.raspberrypi202 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                        2021-08-29 22:45:25.380  - error: host.raspberrypi202 Caught by controller[0]:   requireStack: [
                                        2021-08-29 22:45:25.380  - error: host.raspberrypi202 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
                                        2021-08-29 22:45:25.381  - error: host.raspberrypi202 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                                        2021-08-29 22:45:25.382  - error: host.raspberrypi202 Caught by controller[0]:   ]
                                        2021-08-29 22:45:25.382  - error: host.raspberrypi202 Caught by controller[0]: }
                                        2021-08-29 22:45:25.383  - error: host.raspberrypi202 instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2021-08-29 22:45:25.384  - info: host.raspberrypi202 Restart adapter system.adapter.zigbee.2 because enabled
                                        ^C
                                        pi@raspberrypi202:/opt/iobroker/log $
                                        • W WolfgangFB
                                          ^C
                                          @wolfgangfb
                                          Nicht mit more und grep da hantieren. Da fehlen Zeilen.
                                          E 1 Antwort Letzte Antwort
