  4. Probleme nach Javascript & js-controller update
    6.4k
23 Beiträge 2 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • S SCHNittER
    seit dem Javascript und js-controller Update laufen nicht mehr alle Adapter korrekt und ich kann auch keine neuen Adapter mehr installieren. Im LOG tauchen folgende Meldungen auf:
    instance system.adapter.cloud.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Caught by controller[0]: }
    Caught by controller[0]: ]
    Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.cloud/main.js'
    Caught by controller[0]: '/opt/iobroker/node_modules/request/index.js',
    Caught by controller[0]: '/opt/iobroker/node_modules/request/request.js',
    Caught by controller[0]: requireStack: [
    Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
    Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/request/request.js:17:16)
    Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.cloud/main.js
    Caught by controller[0]: - /opt/iobroker/node_modules/request/index.js
    Caught by controller[0]: - /opt/iobroker/node_modules/request/request.js
    Caught by controller[0]: Require stack:
    Caught by controller[0]: Error: Cannot find module 'isstream'
    Caught by controller[0]: ^
    Caught by controller[0]: throw err;
    Caught by controller[0]: internal/modules/cjs/loader.js:818
    Ich bin noch relativ neu und versuche mich gerade noch zurecht zu finden. Kann mir jemand sagen wie ich das Problem lösen kann?
    Gruss Jens
    @schnitter Zunächst bitte den Konsolenoutput in CodeTage setzen, das man das auch lesen kann. Danke.
    • S SCHNittER
      Gruss Jens
      @schnitter
      cd /opt/iobroker
      npm list isstream
        @schnitter
        cd /opt/iobroker
        npm list isstream
        SCHNittER
        iobroker.inst@2.0.3 /opt/iobroker
        ├─┬ iobroker.admin@5.1.23
        │ └─┬ request@2.88.2
        │   └── UNMET DEPENDENCY isstream@0.1.2
        ├─┬ iobroker.backitup@2.1.13
        │ └─┬ dropbox-v2-api@2.4.45
        │   └─┬ request@2.88.0
        ├─┬ iobroker.js-controller@3.3.15
        │ └─┬ prompt@1.1.0
        │   └─┬ winston@2.4.5
        └─┬ iobroker.vis-icontwo@0.77.0
          └─┬ npm@7.20.6
            └─┬ node-gyp@7.1.2
              └─┬ request@2.88.2
                └── isstream@0.1.2
        npm ERR! missing: isstream@0.1.2, required by request@2.88.2
        npm ERR! missing: isstream@0.1.2, required by request@2.88.0
        npm ERR! missing: isstream@0.1.2, required by winston@2.4.5
        • Thomas BraunT Online
          @schnitter Vermutlich ist nodeJS falsch installiert.
          Jedenfalls ist npm@7 gerade für Anfänger die falsche Wahl. Schau in meiner Signatur wie man das ggf. wieder gerade zieht
            SCHNittER
            schrieb am zuletzt editiert von SCHNittER
            • S SCHNittER
              SCHNittER
              laut InfoScreen: NPM: 6.14.14
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              /usr/bin/nodejs
              v12.22.5
              /usr/bin/node
              v12.22.5
              /usr/bin/npm
              6.14.14
              nodejs:
                Installiert:           12.22.5-1nodesource1
                Installationskandidat: 12.22.5-1nodesource1
                Versionstabelle:
               *** 12.22.5-1nodesource1 100
              pi@raspberrypi:/ $
              • S SCHNittER
                /usr/bin/nodejs
                v12.22.5
                /usr/bin/node
                v12.22.5
                /usr/bin/npm
                6.14.14
                nodejs:
                  Versionstabelle:
                pi@raspberrypi:/ $
                @schnitter
                Dir fehlt das Repository für nodesource.
                curl -fsSL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                sudo apt update
                sudo apt upgrade
                Das hat aber mit deinem Problem nichts zu tun.
                • S SCHNittER
                  /usr/bin/nodejs
                  v12.22.5
                  /usr/bin/node
                  v12.22.5
                  /usr/bin/npm
                  6.14.14
                  nodejs:
                    Versionstabelle:
                  pi@raspberrypi:/ $
                  @schnitter
                  iobroker stop
                  iobroker update
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iobroker start
                    @schnitter
                    iobroker stop
                    iobroker update
                    cd /opt/iobroker
                    iobroker start
                    SCHNittER
                    @thomas-braun vielen Dank, jetzt scheint alles wieder zu funktionieren.
                    Kann ich das abschließend auf Konsolenebene noch einmal testen, da er mE Fehlermeldungen brachte?
                    • S SCHNittER
                      @schnitter
                      Da mal reinschauen, ob alles sauber ist:
                      iobroker update
                      iobroker status
                      iobroker list instances
                        @schnitter
                        iobroker update
                        iobroker status
                        SCHNittER
                        @thomas-braun sieht alles soweit gut aus, nur das Repository kann er nicht hinzufügen
                        E: Listenverzeichnis /var/lib/apt/lists/partial fehlt. - Acquire (117: Die Struktur muss bereinigt werden)
                        Error executing command, exiting
                        • S SCHNittER
                          @schnitter
                          sudo apt update
                            @schnitter
                            sudo apt update
                            SCHNittER
                            sudo apt update
                            pi@raspberrypi:/opt/iobroker $ sudo apt upgrade
                            Paketaktualisierung (Upgrade) wird berechnet... Fertig
                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            • S SCHNittER
                              sudo apt update
                              @schnitter sagte in Probleme nach Javascript & js-controller update:
                              sudo mkdir -p /var/lib/apt/lists/partial
                              sudo apt update
                                sudo apt update
                                SCHNittER
                                @thomas-braun er kann das Verzeichnis nicht anlegen, weil die Struktur bereinigt werden muss?
                                mkdir: das Verzeichnis „/var/lib/apt/lists/partial“ kann nicht angelegt werden: Die Struktur muss bereinigt werden
                                • S SCHNittER
                                  @schnitter
                                  Was liegt denn drin?
                                  ls -la /var/lib/apt/lists/
                                    @schnitter
                                    SCHNittER
                                    @thomas-braun said in Probleme nach Javascript & js-controller update:
                                    nix, "insgesamt: 0"
                                    • S SCHNittER
                                      nix, "insgesamt: 0"
                                      @schnitter
                                      Bitte genaue Rückmeldungen aus der Konsole.
                                      Inkl. login prompt.
                                      Ungefähr so:
                                      echad@chet:/opt/iobroker $ ls -la /var/lib/apt/lists/
                                      insgesamt 68380
                                      drwxr-xr-x 4 root root     4096 24. Aug 13:17 .
                                      drwxr-xr-x 5 root root     4096 23. Aug 02:28 ..
                                      -rw-r--r-- 1 root root    23502 24. Aug 12:46 archive.raspberrypi.org_debian_dists_bullseye_InRelease
                                      -rw-r--r-- 1 root root   411309 24. Aug 12:45 archive.raspberrypi.org_debian_dists_bullseye_main_binary-armhf_Packages
                                      drwxr-xr-x 2 _apt root     4096  4. Mär 23:47 auxfiles
                                      -rw-r--r-- 1 root root     4586 11. Aug 20:17 deb.nodesource.com_node%5f12.x_dists_bullseye_InRelease
                                      -rw-r--r-- 1 root root     1229 11. Aug 20:17 deb.nodesource.com_node%5f12.x_dists_bullseye_main_binary-armhf_Packages
                                      -rw-r--r-- 1 root root     4586 11. Aug 20:12 deb.nodesource.com_node%5f14.x_dists_bullseye_InRelease
                                      -rw-r--r-- 1 root root     1230 11. Aug 20:12 deb.nodesource.com_node%5f14.x_dists_bullseye_main_binary-armhf_Packages
                                      -rw-r--r-- 1 root root     4586 19. Aug 14:16 deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease
                                      -rw-r--r-- 1 root root     1228 19. Aug 14:16 deb.nodesource.com_node%5f16.x_dists_bullseye_main_binary-armhf_Packages
                                      -rw-r----- 1 root root        0  5. Mär 00:11 lock
                                      -rw-r--r-- 1 root root    12110 19. Aug 21:20 packages.grafana.com_oss_deb_dists_stable_InRelease
                                      -rw-r--r-- 1 root root   112092 19. Aug 21:20 packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages
                                      drwx------ 2 _apt root     4096 24. Aug 14:43 partial
                                      Versuch mal ein
                                      sudo apt-get clean
                                        @schnitter
                                        Inkl. login prompt.
                                        Ungefähr so:
                                        insgesamt 68380
                                        Versuch mal ein
                                        sudo apt-get clean
                                        SCHNittER
                                        pi@raspberrypi:/opt/iobroker $ sudo apt-get clean
                                        pi@raspberrypi:/opt/iobroker $ ls -la /var/lib/apt/lists/
                                        insgesamt 0
                                        • S SCHNittER
                                          insgesamt 0
                                          @schnitter
                                          Wie schafft man das? In einem 'leeren' Verzeichnis liegen mindestens die beiden Dateien/Verzeichnisse . und ..
                                          echad@chet:/opt/iobroker $ mkdir test
                                          echad@chet:/opt/iobroker $ ls -la test/
                                          insgesamt 8
                                          drwxrwxr-x+ 2 echad    echad    4096 24. Aug 15:36 .
                                          drwxrwxr-x+ 7 iobroker iobroker 4096 24. Aug 15:36 ..
                                          sudo mkdir /var/lib/apt/lists/
                                          Ist eine Ebene höher noch alles okay?
                                          ls -la /var/lib/apt
