  4. No connection to Database possible ...
    6.5k
54 Beiträge 3 Kommentatoren 7.4k Aufrufe 3 Beobachtet
    @dgr
    Was steht da so in
    dmesg -T
    drin?
    DGR
    pi@PI-AL-01:~ $ dmesg -T
    [Mo Aug 23 15:39:24 2021] Booting Linux on physical CPU 0x0
    [Mo Aug 23 15:39:24 2021] Linux version 5.10.52-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1441 SMP Tue Aug 3 18:11:56 BST 2021
    [Mo Aug 23 15:39:24 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
    [Mo Aug 23 15:39:24 2021] CPU: div instructions available: patching division cod        e
    [Mo Aug 23 15:39:24 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct        ion cache
    [Mo Aug 23 15:39:24 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [Mo Aug 23 15:39:24 2021] random: fast init done
    [Mo Aug 23 15:39:24 2021] Memory policy: Data cache writealloc
    [Mo Aug 23 15:39:24 2021] Reserved memory: created CMA memory pool at 0x00000000        1ac00000, size 320 MiB
    [Mo Aug 23 15:39:24 2021] OF: reserved mem: initialized node linux,cma, compatib        le id shared-dma-pool
    [Mo Aug 23 15:39:24 2021] Zone ranges:
    [Mo Aug 23 15:39:24 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [Mo Aug 23 15:39:24 2021]   Normal   empty
    [Mo Aug 23 15:39:24 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [Mo Aug 23 15:39:24 2021] Movable zone start for each node
    [Mo Aug 23 15:39:24 2021] Early memory node ranges
    [Mo Aug 23 15:39:24 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff        ]
    [Mo Aug 23 15:39:24 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff        ]
    [Mo Aug 23 15:39:24 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000        0fbffffff]
    [Mo Aug 23 15:39:24 2021] On node 0 totalpages: 1012736
    [Mo Aug 23 15:39:24 2021]   DMA zone: 1728 pages used for memmap
    [Mo Aug 23 15:39:24 2021]   DMA zone: 0 pages reserved
    [Mo Aug 23 15:39:24 2021]   DMA zone: 196608 pages, LIFO batch:63
    [Mo Aug 23 15:39:24 2021]   HighMem zone: 816128 pages, LIFO batch:63
    [Mo Aug 23 15:39:24 2021] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u819        20
    [Mo Aug 23 15:39:24 2021] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
    [Mo Aug 23 15:39:24 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Mo Aug 23 15:39:24 2021] Built 1 zonelists, mobility grouping on.  Total pages:        1011008
    [Mo Aug 23 15:39:24 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:        A6:32:4F:8F:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tt        y1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes r        ootwait quiet splash plymouth.ignore-serial-consoles
    [Mo Aug 23 15:39:24 2021] Kernel parameter elevator= does not have any effect an        ymore.
                              Please use sysfs to set IO scheduler for individual de        vices.
    [Mo Aug 23 15:39:24 2021] Dentry cache hash table entries: 131072 (order: 7, 524        288 bytes, linear)
    [Mo Aug 23 15:39:24 2021] Inode-cache hash table entries: 65536 (order: 6, 26214        4 bytes, linear)
    [Mo Aug 23 15:39:24 2021] mem auto-init: stack:off, heap alloc:off, heap free:of        f
    [Mo Aug 23 15:39:24 2021] software IO TLB: mapped [mem 0x0000000014890000-0x0000        000018890000] (64MB)
    [Mo Aug 23 15:39:24 2021] Memory: 3601132K/4050944K available (10240K kernel cod        e, 1364K rwdata, 3188K rodata, 2048K init, 891K bss, 122132K reserved, 327680K c        ma-reserved, 3264512K highmem)
    [Mo Aug 23 15:39:24 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod        es=1
    [Mo Aug 23 15:39:24 2021] ftrace: allocating 34303 entries in 67 pages
    [Mo Aug 23 15:39:24 2021] ftrace: allocated 67 pages with 3 groups
    [Mo Aug 23 15:39:24 2021] rcu: Hierarchical RCU implementation.
    [Mo Aug 23 15:39:24 2021]       Rude variant of Tasks RCU enabled.
    [Mo Aug 23 15:39:24 2021]       Tracing variant of Tasks RCU enabled.
    [Mo Aug 23 15:39:24 2021] rcu: RCU calculated value of scheduler-enlistment dela        y is 10 jiffies.
    [Mo Aug 23 15:39:24 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Mo Aug 23 15:39:24 2021] GIC: Using split EOI/Deactivate mode
    [Mo Aug 23 15:39:24 2021] random: get_random_bytes called from start_kernel+0x3c        8/0x59c with crng_init=1
    [Mo Aug 23 15:39:24 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr        aps every 2147483647500ns
    [Mo Aug 23 15:39:24 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff        fffff, max_idle_ns: 1911260446275 ns
    [Mo Aug 23 15:39:24 2021] bcm2835: system timer (irq = 25)
    [Mo Aug 23 15:39:24 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [Mo Aug 23 15:39:24 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [Mo Aug 23 15:39:24 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps        every 4398046511102ns
    [Mo Aug 23 15:39:24 2021] Switching to timer-based delay loop, resolution 18ns
    [Mo Aug 23 15:39:24 2021] Console: colour dummy device 80x30
    [Mo Aug 23 15:39:24 2021] printk: console [tty1] enabled
    [Mo Aug 23 15:39:24 2021] Calibrating delay loop (skipped), value calculated usi        ng timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [Mo Aug 23 15:39:24 2021] pid_max: default: 32768 minimum: 301
    [Mo Aug 23 15:39:24 2021] LSM: Security Framework initializing
    [Mo Aug 23 15:39:24 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b        ytes, linear)
    [Mo Aug 23 15:39:24 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8        192 bytes, linear)
    [Mo Aug 23 15:39:24 2021] cgroup: Disabling memory control group subsystem
    [Mo Aug 23 15:39:24 2021] CPU: Testing write buffer coherency: ok
    [Mo Aug 23 15:39:24 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Mo Aug 23 15:39:24 2021] Setting up static identity map for 0x200000 - 0x20003c
    [Mo Aug 23 15:39:24 2021] rcu: Hierarchical SRCU implementation.
    [Mo Aug 23 15:39:24 2021] smp: Bringing up secondary CPUs ...
    [Mo Aug 23 15:39:24 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Mo Aug 23 15:39:24 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Mo Aug 23 15:39:24 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Mo Aug 23 15:39:24 2021] smp: Brought up 1 node, 4 CPUs
    [Mo Aug 23 15:39:24 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS)        .
    [Mo Aug 23 15:39:24 2021] CPU: All CPU(s) started in HYP mode.
    [Mo Aug 23 15:39:24 2021] CPU: Virtualization extensions available.
    [Mo Aug 23 15:39:24 2021] devtmpfs: initialized
    [Mo Aug 23 15:39:24 2021] VFP support v0.3: implementor 41 architecture 3 part 4        0 variant 8 rev 0
    [Mo Aug 23 15:39:24 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf        fffffff, max_idle_ns: 19112604462750000 ns
    [Mo Aug 23 15:39:24 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,        linear)
    [Mo Aug 23 15:39:24 2021] pinctrl core: initialized pinctrl subsystem
    [Mo Aug 23 15:39:24 2021] NET: Registered protocol family 16
    [Mo Aug 23 15:39:24 2021] DMA: preallocated 1024 KiB pool for atomic coherent al        locations
    [Mo Aug 23 15:39:24 2021] audit: initializing netlink subsys (disabled)
    [Mo Aug 23 15:39:24 2021] audit: type=2000 audit(0.030:1): state=initialized aud        it_enabled=0 res=1
    [Mo Aug 23 15:39:24 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Mo Aug 23 15:39:24 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
    [Mo Aug 23 15:39:24 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Mo Aug 23 15:39:24 2021] Serial: AMBA PL011 UART driver
    [Mo Aug 23 15:39:24 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [Mo Aug 23 15:39:24 2021] raspberrypi-firmware soc:firmware: Attached to firmwar        e from 2021-08-03T18:14:56, variant start
    [Mo Aug 23 15:39:24 2021] raspberrypi-firmware soc:firmware: Firmware hash is 40        787ee5905644f639a2a0f6e00ae12e517a2211
    [Mo Aug 23 15:39:24 2021] Kprobes globally optimized
    [Mo Aug 23 15:39:24 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac        hans=0x1
    [Mo Aug 23 15:39:24 2021] vgaarb: loaded
    [Mo Aug 23 15:39:24 2021] SCSI subsystem initialized
    [Mo Aug 23 15:39:24 2021] usbcore: registered new interface driver usbfs
    [Mo Aug 23 15:39:24 2021] usbcore: registered new interface driver hub
    [Mo Aug 23 15:39:24 2021] usbcore: registered new device driver usb
    [Mo Aug 23 15:39:24 2021] usb_phy_generic phy: supply vcc not found, using dummy        regulator
    [Mo Aug 23 15:39:24 2021] clocksource: Switched to clocksource arch_sys_counter
    [Mo Aug 23 15:39:25 2021] VFS: Disk quotas dquot_6.6.0
    [Mo Aug 23 15:39:25 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40        96 bytes)
    [Mo Aug 23 15:39:25 2021] FS-Cache: Loaded
    [Mo Aug 23 15:39:25 2021] CacheFiles: Loaded
    [Mo Aug 23 15:39:25 2021] NET: Registered protocol family 2
    [Mo Aug 23 15:39:25 2021] IP idents hash table entries: 16384 (order: 5, 131072        bytes, linear)
    [Mo Aug 23 15:39:25 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde        r: 0, 6144 bytes, linear)
    [Mo Aug 23 15:39:25 2021] TCP established hash table entries: 8192 (order: 3, 32        768 bytes, linear)
    [Mo Aug 23 15:39:25 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt        es, linear)
    [Mo Aug 23 15:39:25 2021] TCP: Hash tables configured (established 8192 bind 819        2)
    [Mo Aug 23 15:39:25 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li        near)
    [Mo Aug 23 15:39:25 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte        s, linear)
    [Mo Aug 23 15:39:25 2021] NET: Registered protocol family 1
    [Mo Aug 23 15:39:25 2021] RPC: Registered named UNIX socket transport module.
    [Mo Aug 23 15:39:25 2021] RPC: Registered udp transport module.
    [Mo Aug 23 15:39:25 2021] RPC: Registered tcp transport module.
    [Mo Aug 23 15:39:25 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu        le.
    [Mo Aug 23 15:39:25 2021] PCI: CLS 0 bytes, default 64
    [Mo Aug 23 15:39:25 2021] Initialise system trusted keyrings
    [Mo Aug 23 15:39:25 2021] workingset: timestamp_bits=14 max_order=20 bucket_orde        r=6
    [Mo Aug 23 15:39:25 2021] zbud: loaded
    [Mo Aug 23 15:39:25 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Mo Aug 23 15:39:25 2021] NFS: Registering the id_resolver key type
    [Mo Aug 23 15:39:25 2021] Key type id_resolver registered
    [Mo Aug 23 15:39:25 2021] Key type id_legacy registered
    [Mo Aug 23 15:39:25 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register        ing...
    [Mo Aug 23 15:39:25 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver        Registering...
    [Mo Aug 23 15:39:25 2021] Key type asymmetric registered
    [Mo Aug 23 15:39:25 2021] Asymmetric key parser 'x509' registered
    [Mo Aug 23 15:39:25 2021] bounce: pool size: 64 pages
    [Mo Aug 23 15:39:25 2021] Block layer SCSI generic (bsg) driver version 0.4 load        ed (major 249)
    [Mo Aug 23 15:39:25 2021] io scheduler mq-deadline registered
    [Mo Aug 23 15:39:25 2021] io scheduler kyber registered
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000        0 ranges:
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb        /pcie@7d500000, using [bus 00-ff]
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f        ffffff -> 0x00c0000000
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bf        ffffff -> 0x0400000000
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS        C)
    [Mo Aug 23 15:39:25 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0        0
    [Mo Aug 23 15:39:25 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [Mo Aug 23 15:39:25 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x        63fffffff] (bus address [0xc0000000-0xffffffff])
    [Mo Aug 23 15:39:25 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [Mo Aug 23 15:39:25 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [Mo Aug 23 15:39:25 2021] PCI: bus0: Fast back to back transfers disabled
    [Mo Aug 23 15:39:25 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [Mo Aug 23 15:39:25 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff        64bit]
    [Mo Aug 23 15:39:25 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
    [Mo Aug 23 15:39:25 2021] PCI: bus1: Fast back to back transfers disabled
    [Mo Aug 23 15:39:25 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6        000fffff]
    [Mo Aug 23 15:39:25 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6        00000fff 64bit]
    [Mo Aug 23 15:39:25 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [Mo Aug 23 15:39:25 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6        000fffff]
    [Mo Aug 23 15:39:25 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [Mo Aug 23 15:39:25 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
    [Mo Aug 23 15:39:25 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable        d
    [Mo Aug 23 15:39:25 2021] bcm2835-aux-uart fe215040.serial: there is not valid m        aps for state default
    [Mo Aug 23 15:39:25 2021] iproc-rng200 fe104000.rng: hwrng registered
    [Mo Aug 23 15:39:25 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_s        ize:0x40000000(1024 MiB)
    [Mo Aug 23 15:39:25 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe        rs at 0xfe200000
    [Mo Aug 23 15:39:25 2021] brd: module loaded
    [Mo Aug 23 15:39:25 2021] loop: module loaded
    [Mo Aug 23 15:39:25 2021] Loading iSCSI transport class v2.0-870.
    [Mo Aug 23 15:39:25 2021] libphy: Fixed MDIO Bus: probed
    [Mo Aug 23 15:39:25 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [Mo Aug 23 15:39:25 2021] libphy: bcmgenet MII bus: probed
    [Mo Aug 23 15:39:25 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver r8152
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver lan78xx
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver smsc95xx
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 1
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi        on 0x100 quirks 0x0000060000000890
    [Mo Aug 23 15:39:25 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu        ct=0002, bcdDevice= 5.10
    [Mo Aug 23 15:39:25 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
    [Mo Aug 23 15:39:25 2021] usb usb1: Product: xHCI Host Controller
    [Mo Aug 23 15:39:25 2021] usb usb1: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
    [Mo Aug 23 15:39:25 2021] usb usb1: SerialNumber: 0000:01:00.0
    [Mo Aug 23 15:39:25 2021] hub 1-0:1.0: USB hub found
    [Mo Aug 23 15:39:25 2021] hub 1-0:1.0: 1 port detected
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 2
    [Mo Aug 23 15:39:25 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee        d
    [Mo Aug 23 15:39:25 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu        ct=0003, bcdDevice= 5.10
    [Mo Aug 23 15:39:25 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
    [Mo Aug 23 15:39:25 2021] usb usb2: Product: xHCI Host Controller
    [Mo Aug 23 15:39:25 2021] usb usb2: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
    [Mo Aug 23 15:39:25 2021] usb usb2: SerialNumber: 0000:01:00.0
    [Mo Aug 23 15:39:25 2021] hub 2-0:1.0: USB hub found
    [Mo Aug 23 15:39:25 2021] hub 2-0:1.0: 4 ports detected
    [Mo Aug 23 15:39:25 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Mo Aug 23 15:39:25 2021] dwc_otg: FIQ enabled
    [Mo Aug 23 15:39:25 2021] dwc_otg: NAK holdoff enabled
    [Mo Aug 23 15:39:25 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Mo Aug 23 15:39:25 2021] Module dwc_common_port init
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver uas
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver usb-storage
    [Mo Aug 23 15:39:25 2021] mousedev: PS/2 mouse device common for all mice
    [Mo Aug 23 15:39:25 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim        er
    [Mo Aug 23 15:39:25 2021] sdhci: Secure Digital Host Controller Interface driver
    [Mo Aug 23 15:39:25 2021] sdhci: Copyright(c) Pierre Ossman
    [Mo Aug 23 15:39:25 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri        ng probe
    [Mo Aug 23 15:39:25 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Mo Aug 23 15:39:25 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Mo Aug 23 15:39:25 2021] hid: raw HID events driver (C) Jiri Kosina
    [Mo Aug 23 15:39:25 2021] usbcore: registered new interface driver usbhid
    [Mo Aug 23 15:39:25 2021] usbhid: USB HID core driver
    [Mo Aug 23 15:39:25 2021] Initializing XFRM netlink socket
    [Mo Aug 23 15:39:25 2021] NET: Registered protocol family 17
    [Mo Aug 23 15:39:25 2021] Key type dns_resolver registered
    [Mo Aug 23 15:39:25 2021] Registering SWP/SWPB emulation handler
    [Mo Aug 23 15:39:25 2021] registered taskstats version 1
    [Mo Aug 23 15:39:25 2021] Loading compiled-in X.509 certificates
    [Mo Aug 23 15:39:25 2021] Key type ._fscrypt registered
    [Mo Aug 23 15:39:25 2021] Key type .fscrypt registered
    [Mo Aug 23 15:39:25 2021] Key type fscrypt-provisioning registered
    [Mo Aug 23 15:39:25 2021] uart-pl011 fe201000.serial: there is not valid maps fo        r state default
    [Mo Aug 23 15:39:25 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl        ed
    [Mo Aug 23 15:39:25 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,        base_baud = 0) is a PL011 rev2
    [Mo Aug 23 15:39:25 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, b        ase_baud = 62500000) is a 16550
    [Mo Aug 23 15:39:25 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do        mains driver
    [Mo Aug 23 15:39:25 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Mo Aug 23 15:39:25 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [Mo Aug 23 15:39:25 2021] of_cfs_init
    [Mo Aug 23 15:39:25 2021] of_cfs_init: OK
    [Mo Aug 23 15:39:25 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Mo Aug 23 15:39:25 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Mo Aug 23 15:39:25 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Mo Aug 23 15:39:25 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm        c2] using ADMA
    [Mo Aug 23 15:39:25 2021] Waiting for root device PARTUUID=5e3da3da-02...
    [Mo Aug 23 15:39:25 2021] mmc1: new high speed SDIO card at address 0001
    [Mo Aug 23 15:39:25 2021] mmc0: new ultra high speed DDR50 SDXC card at address        aaaa
    [Mo Aug 23 15:39:25 2021] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
    [Mo Aug 23 15:39:25 2021]  mmcblk0: p1 p2
    [Mo Aug 23 15:39:25 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered d        ata mode. Opts: (null)
    [Mo Aug 23 15:39:25 2021] VFS: Mounted root (ext4 filesystem) readonly on device        179:2.
    [Mo Aug 23 15:39:25 2021] devtmpfs: mounted
    [Mo Aug 23 15:39:25 2021] Freeing unused kernel memory: 2048K
    [Mo Aug 23 15:39:25 2021] usb 1-1: new high-speed USB device number 2 using xhci        _hcd
    [Mo Aug 23 15:39:25 2021] Run /sbin/init as init process
    [Mo Aug 23 15:39:25 2021]   with arguments:
    [Mo Aug 23 15:39:25 2021]     /sbin/init
    [Mo Aug 23 15:39:25 2021]     splash
    [Mo Aug 23 15:39:25 2021]   with environment:
    [Mo Aug 23 15:39:25 2021]     HOME=/
    [Mo Aug 23 15:39:25 2021]     TERM=linux
    [Mo Aug 23 15:39:25 2021] usb 1-1: New USB device found, idVendor=2109, idProduc        t=3431, bcdDevice= 4.21
    [Mo Aug 23 15:39:25 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser        ialNumber=0
    [Mo Aug 23 15:39:25 2021] usb 1-1: Product: USB2.0 Hub
    [Mo Aug 23 15:39:25 2021] hub 1-1:1.0: USB hub found
    [Mo Aug 23 15:39:25 2021] hub 1-1:1.0: 4 ports detected
    [Mo Aug 23 15:39:26 2021] systemd[1]: System time before build time, advancing c        lock.
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: new full-speed USB device number 3 using xh        ci_hcd
    [Mo Aug 23 15:39:26 2021] NET: Registered protocol family 10
    [Mo Aug 23 15:39:26 2021] Segment Routing with IPv6
    [Mo Aug 23 15:39:26 2021] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN        UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie        rarchy=hybrid)
    [Mo Aug 23 15:39:26 2021] systemd[1]: Detected architecture arm.
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: New USB device found, idVendor=1cf1, idProd        uct=0030, bcdDevice= 1.00
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, S        erialNumber=3
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: Product: ConBee II
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: Manufacturer: dresden elektronik ingenieurt        echnik GmbH
    [Mo Aug 23 15:39:26 2021] usb 1-1.2: SerialNumber: DE2130518
    [Mo Aug 23 15:39:26 2021] systemd[1]: Set hostname to <PI-AL-01>.
    [Mo Aug 23 15:39:26 2021] usb 1-1.3: new high-speed USB device number 4 using xh        ci_hcd
    [Mo Aug 23 15:39:26 2021] usb 1-1.3: New USB device found, idVendor=1908, idProd        uct=0226, bcdDevice= 1.11
    [Mo Aug 23 15:39:26 2021] usb 1-1.3: New USB device strings: Mfr=0, Product=0, S        erialNumber=0
    [Mo Aug 23 15:39:26 2021] usb-storage 1-1.3:1.0: USB Mass Storage device detecte        d
    [Mo Aug 23 15:39:26 2021] scsi host0: usb-storage 1-1.3:1.0
    [Mo Aug 23 15:39:27 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFil        e= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp        .pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
    [Mo Aug 23 15:39:27 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9:        PIDFile= references path below legacy directory /var/run/, updating /var/run/xr        dp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file acco        rdingly.
    [Mo Aug 23 15:39:27 2021] systemd[1]: /etc/systemd/system/teamviewerd.service:8:        PIDFile= references path below legacy directory /var/run/, updating /var/run/te        amviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
    [Mo Aug 23 15:39:27 2021] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFil        e= references path below legacy directory /var/run/, updating /var/run/samba/smb        d.pid → /run/samba/smbd.pid; please update the unit file accordingly.
    [Mo Aug 23 15:39:27 2021] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFil        e= references path below legacy directory /var/run/, updating /var/run/samba/nmb        d.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
    [Mo Aug 23 15:39:27 2021] random: systemd: uninitialized urandom read (16 bytes        read)
    [Mo Aug 23 15:39:27 2021] systemd[1]: Created slice system-getty.slice.
    [Mo Aug 23 15:39:27 2021] systemd[1]: Set up automount Arbitrary Executable File        Formats File System Automount Point.
    [Mo Aug 23 15:39:27 2021] i2c /dev entries driver
    [Mo Aug 23 15:39:27 2021] scsi 0:0:0:0: Direct-Access     Generic  Mass-Storage        1.11 PQ: 0 ANSI: 2
    [Mo Aug 23 15:39:28 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Mo Aug 23 15:39:28 2021] systemd-journald[127]: Received request to flush runti        me journal from PID 1
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] 62333952 512-byte logical blocks: (3        1.9 GB/29.7 GiB)
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] Write Protect is off
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] No Caching mode page found
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [Mo Aug 23 15:39:28 2021]  sda: sda1
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [Mo Aug 23 15:39:28 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [Mo Aug 23 15:39:28 2021] snd_bcm2835: module is from the staging directory, the        quality is unknown, you have been warned.
    [Mo Aug 23 15:39:28 2021] vc_sm_cma: module is from the staging directory, the q        uality is unknown, you have been warned.
    [Mo Aug 23 15:39:28 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive        r
    [Mo Aug 23 15:39:28 2021] [vc_sm_connected_init]: start
    [Mo Aug 23 15:39:28 2021] mc: Linux media interface: v0.10
    [Mo Aug 23 15:39:28 2021] [vc_sm_connected_init]: installed successfully
    [Mo Aug 23 15:39:28 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi        alised: Registers at 0xfeb00000 length 0x00010000
    [Mo Aug 23 15:39:28 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem        initialised: Registers at 0xfeb10000 length 0x00001000
    [Mo Aug 23 15:39:28 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi        alised: Registers at 0xfeb20000 length 0x00010000
    [Mo Aug 23 15:39:28 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial        ised: Registers at 0xfeb30000 length 0x00010000
    [Mo Aug 23 15:39:28 2021] bcm2835_audio bcm2835_audio: card created with 8 chann        els
    [Mo Aug 23 15:39:28 2021] videodev: Linux video capture interface: v2.00
    [Mo Aug 23 15:39:29 2021] bcm2835_mmal_vchiq: module is from the staging directo        ry, the quality is unknown, you have been warned.
    [Mo Aug 23 15:39:29 2021] bcm2835_v4l2: module is from the staging directory, th        e quality is unknown, you have been warned.
    [Mo Aug 23 15:39:29 2021] bcm2835_isp: module is from the staging directory, the        quality is unknown, you have been warned.
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe        red as /dev/video13
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist        ered as /dev/video14
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist        ered as /dev/video15
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register        ed as /dev/video16
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m        edia controller
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
    [Mo Aug 23 15:39:29 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Mo Aug 23 15:39:29 2021] bcm2835_codec: module is from the staging directory, t        he quality is unknown, you have been warned.
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video10
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video11
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video12
    [Mo Aug 23 15:39:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Mo Aug 23 15:39:29 2021] [drm] No displays found. Consider forcing hotplug if H        DMI is attached
    [Mo Aug 23 15:39:29 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_        ops [vc4])
    [Mo Aug 23 15:39:29 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor        1
    [Mo Aug 23 15:39:29 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d        on minor 0
    [Mo Aug 23 15:39:29 2021] cfg80211: Loading compiled-in X.509 certificates for r        egulatory database
    [Mo Aug 23 15:39:29 2021] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    [Mo Aug 23 15:39:29 2021] usbcore: registered new interface driver cdc_acm
    [Mo Aug 23 15:39:29 2021] cdc_acm: USB Abstract Control Model driver for USB mod        ems and ISDN adapters
    [Mo Aug 23 15:39:29 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c        ea7'
    [Mo Aug 23 15:39:29 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [Mo Aug 23 15:39:29 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4        3455-sdio for chip BCM4345/6
    [Mo Aug 23 15:39:29 2021] usbcore: registered new interface driver brcmfmac
    [Mo Aug 23 15:39:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4        3455-sdio for chip BCM4345/6
    [Mo Aug 23 15:39:30 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w        l0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [Mo Aug 23 15:39:32 2021] random: crng init done
    [Mo Aug 23 15:39:32 2021] random: 7 urandom warning(s) missed due to ratelimitin        g
    [Mo Aug 23 15:39:32 2021] 8021q: 802.1Q VLAN Support v1.8
    [Mo Aug 23 15:39:32 2021] uart-pl011 fe201000.serial: no DMA platform data
    [Mo Aug 23 15:39:32 2021] Bluetooth: Core ver 2.22
    [Mo Aug 23 15:39:32 2021] NET: Registered protocol family 31
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI device and connection manager initializ        ed
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI socket layer initialized
    [Mo Aug 23 15:39:32 2021] Bluetooth: L2CAP socket layer initialized
    [Mo Aug 23 15:39:32 2021] Bluetooth: SCO socket layer initialized
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI UART driver ver 2.3
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI UART protocol H4 registered
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere        d
    [Mo Aug 23 15:39:32 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Mo Aug 23 15:39:33 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save en        abled
    [Mo Aug 23 15:39:33 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents        :1 across:102396k SSFS
    [Mo Aug 23 15:39:33 2021] bcmgenet fd580000.ethernet: configuring instance for e        xternal RGMII (RX delay)
    [Mo Aug 23 15:39:33 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [Mo Aug 23 15:39:34 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Mo Aug 23 15:39:34 2021] Bluetooth: BNEP filters: protocol multicast
    [Mo Aug 23 15:39:34 2021] Bluetooth: BNEP socket layer initialized
    [Mo Aug 23 15:39:37 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu        ll - flow control rx/tx
    [Mo Aug 23 15:39:37 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read        y
    [Mo Aug 23 15:39:38 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:38 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes rea        dy
    [Mo Aug 23 15:39:39 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:40 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s        yscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_tim        e_ms instead
    [Mo Aug 23 15:39:40 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:41 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:42 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:43 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:44 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:45 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:46 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:47 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:48 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:49 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:50 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:51 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:52 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:39:53 2021] broken atomic modeset userspace detected, disabling at        omic
    [Mo Aug 23 15:40:02 2021] fuse: init (API version 7.32)
    [Mo Aug 23 15:40:21 2021] Bluetooth: RFCOMM TTY layer initialized
    [Mo Aug 23 15:40:21 2021] Bluetooth: RFCOMM socket layer initialized
    [Mo Aug 23 15:40:21 2021] Bluetooth: RFCOMM ver 1.11
    pi@PI-AL-01:~ $
      @dgr
      Was steht da so in
      dmesg -T
      drin?
      DGR
      @thomas-braun war jetzt aber auch über PuTTY SSH
      • D DGR
        @dgr
        [Mo Aug 23 15:39:27 2021] systemd[1]: /etc/systemd/system/teamviewerd.service:8:PIDFile= references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
        Da läuft ja noch der teamviewer. Ausschalten!
        Geht in
        sudo raspi-config
        1 System Options      Configure system settings
        S5 Boot / Auto Login  Select boot into desktop or to command line
        B1 Console            Text console, requiring user to login
          @dgr
          Geht in
          sudo raspi-config
          DGR
          rm: das Entfernen von '/etc/systemd/system/getty@tty1.service.d/autologin.conf' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          pi@PI-AL-01:~ $
          • D DGR
            pi@PI-AL-01:~ $
            @dgr
            Okay.
            Starte die Kiste jetzt mal durch:
            sudo reboot
              @dgr
              Okay.
              sudo reboot
              DGR
              @thomas-braun erledigt
              • D DGR
                @dgr
                Auf welcher nodeJS-Version bist du da eigentlich unterwegs:
                which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                Läuft das nun?
                iobroker stop
                iobroker update
                iobroker upgrade
                iobroker upgrade self
                iobroker start
                D 2 Antworten Letzte Antwort
                  @dgr
                  Läuft das nun?
                  iobroker stop
                  iobroker update
                  iobroker upgrade
                  iobroker start
                  DGR
                  pi@PI-AL-01:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.17.5
                  v14.17.5
                  6.14.14
                  OK:1 http://phoscon.de/apt/deconz buster InRelease
                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:3 http://archive.raspberrypi.org/debian buster InRelease
                  OK:4 https://linux.teamviewer.com/deb stable InRelease
                  OK:5 https://deb.nodesource.com/node_14.x buster InRelease
                  Alle Pakete sind aktuell.
                  OK:2 http://archive.raspberrypi.org/debian buster InRelease
                  OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                  OK:5 https://linux.teamviewer.com/deb stable InRelease
                  nodejs:
                    Installiert:           14.17.5-1nodesource1
                    Installationskandidat: 14.17.5-1nodesource1
                    Versionstabelle:
                   *** 14.17.5-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u1 500
                  pi@PI-AL-01:~ $
                    @dgr
                    Läuft das nun?
                    iobroker stop
                    iobroker update
                    iobroker upgrade
                    iobroker start
                    DGR
                    pi@PI-AL-01:~ $ iobroker stop
                    pi@PI-AL-01:~ $ iobroker update
                    No connection to databases possible ...
                    pi@PI-AL-01:~ $
                    • D DGR
                      pi@PI-AL-01:~ $
                      @dgr
                      Dann weiß ich auch nicht weiter.
                      who -r
                      liefert jetzt RL3?
                        @dgr
                        who -r
                        liefert jetzt RL3?
                        DGR
                        pi@PI-AL-01:~ $ who -r
                                 Runlevel 3   2021-08-23 18:54
                        pi@PI-AL-01:~ $
                          @dgr
                          who -r
                          liefert jetzt RL3?
                          DGR
                          @thomas-braun Vielleicht ergibt sich später noch eine Lösung. Tut mir leid, dass ich mich so doof angestellt habe.
                          C 1 Antwort Letzte Antwort
                          • D DGR
                            chaos99
                            Ich habe mir heute einen neuen rasbery 4 bestellt , den werde ich nächste Woche fertig machen ,
                            Den cubi werde ich danach mal mit einem alten Backup bespielen und mal schauen ob das Problem weiterhin besteht oder ab welchen Update es nicht mehr geht , werde dann berichten
                            • C chaos99
                              DGR
                              @chaos99 Danke.
                              noch einige Hinweise:
                              Ich kann zwar den iobroker über meine IP wieder starten (nach iobroker start), Adapter, Objekte, Aufzählungen, Protokolle und Benutzer werden angezeigt, aber bei Instanzen kommt "Hostinformationen können nicht gelesen werden ..."
                              Die "JS Skripte" öffnen sich auch nicht mehr (ohne Fehlermeldung), gleiches bei Kommandos, Kalender, Terminal, Info, Hosts (noch markiert mit einer 1 und bei mir als "Wirte" angezeigt/übersetzt) - hier kommt sofort der Hinweis "Langsame Verbindung erkannt! . . . " - dann über "Abbrechen sieht man den Inhalt mit dem noch ausstehenden Update von 3.2.16 auf verfügbar 3.3.15
                              Bei "Übersicht" öffnet sich zwar das Fenster, aber außer dem Hostnamen werden nur 4 leere und blinkende Zeilen angezeigt.
                              Alles läuft extrem langsam. Das kann aber vielleicht auch an meinen Netzwerkeinstellungen liegen. Muß ich noch prüfen.
                              Die Oberfläche sieht auch anders aus.
                              Bevor ich versuchte das Update für den Host zu machen, habe ich etwa 9 Adapter aktualisiert und zuvor als letzten Adapter "WLED" installiert.
                              Thomas BraunT C 2 Antworten Letzte Antwort
                              • D DGR
                                @chaos99 Danke.
                                @dgr
                                Wir hast du eigentlich den Hostname geändert?
                                Man sollte sich da übrigens auf Kleinbuchstaben, die Ziffern 0-9 und den Bindestrich beschränken. Alles andere kann zu komischen Ergebnissen führen.
                                  @dgr
                                  DGR
                                  @thomas-braun ist schon sehr lange her. Wahrscheinlich über die Raspberry-Pi-Konfiguration --> System
                                  • D DGR
                                    @chaos99 Danke.
                                    chaos99
                                    @dgr
                                    Ich habe gerade alles mal ausprobiert , bis auf scrip : endlos ladebalken ,
                                    Funktioniert alles andere ohne erkennbare Probleme auch die Ladezeiten sind normal
                                    D 3 Antworten Letzte Antwort
                                    • C chaos99
                                      @dgr
                                      DGR
                                      @chaos99 und wie mit dem Raspberry verbunden ?
                                      • C chaos99
                                        @dgr
                                        DGR
                                        @chaos99 Seltsam. Plötzlich geht es auch bei mir wieder, auch die Scripte.
                                        • C chaos99
                                          @dgr
                                          DGR
                                          @chaos99 ich habe gleich mal das Update probiert, aber nach wie vor kommt "No connection to database possible ..."
