  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
    @chris-d-0
    cd /opt/iobroker
    iobroker stop
    sudo -H -u iobroker npm install iobroker.js-controller
    Chris-D 0
    #76
    @thomas-braun said in Rega Fehler:
    cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
    > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.14
    > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
    > node lib/checkVersions.js
    > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    The following notifications happened during sync:
    - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
    > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
    > node scripts/postinstall
    Greenlock and ACME.js v3 are on the way!
    Watch for updates at https://indiegogo.com/at/greenlock
    > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
    > node lib/install.js
    │ Manual installation of ioBroker is no longer supported  │
    │ on Linux, OSX and FreeBSD!                              │
    │ Please refer to the documentation on how to install it! │
    │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 100
    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
    npm ERR! Exit status 100
    npm ERR!
    npm ERR! Failed at the iobroker@2.0.3 postinstall script.
    npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_29_16_679Z-debug.log
    • C Chris-D 0
      > node lib/install.js
      npm ERR! errno 100
      npm ERR!
      #77
      @chris-d-0 hattest du mal npm 7 drauf? Da ist ein Mischmasch bei dir.
      Thomas BraunT C 2 Antworten Letzte Antwort
      • apollon77A apollon77
        #78
        @apollon77
        Offenbar.
        ist jedenfalls ein starker Indikator für npm7.
          @apollon77
          Offenbar.
          #79
          @thomas-braun package-lock.json löschen
            #80
            @homoran Keine Ahnung was man da machen kann. Musste das auf meinem System noch nie gerade biegen. Aber da sind ja auch die Versionssprünge nie so groß. Da am Ball bleiben zahlt sich halt aus.
              #81
              @thomas-braun sagte in Rega Fehler:
              das kann ein weiteres Problem sein.
              bin nicht mehr am PC.
              die package-lock.json sollte IMHO direkt in /opt/iobroker liegen.
              Nach löschen wird sie neu gebaut, dann in der richtigen Version wenn jetzt wieder npm v6 läuft
              C 1 Antwort Letzte Antwort
                Chris-D 0
                #82
                @apollon77 ja genau hatte ich
                  Chris-D 0
                  schrieb am zuletzt editiert von Chris-D 0
                  #83
                  @homoran dann wäre die Frage wie das geht?
                  • C Chris-D 0
                    Chris-D 0
                    #84
                    hat noch jemand eine Idee? der IoBroker geht jetzt nicht mehr. Vorher, bis auf den Rega Adapter, schon.
                    • C Chris-D 0
                      #85
                      @chris-d-0
                      iobroker stop
                      sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
                      iobroker start
                        @chris-d-0
                        iobroker stop
                        iobroker start
                        Chris-D 0
                        #86
                        @thomas-braun nicht viel passt
                        pi@raspberrypi:~ $ iobroker stop
                        pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
                        pi@raspberrypi:~ $ iobroker start
                        • C Chris-D 0
                          #87
                          @chris-d-0
                          'Nicht viel passiert' ist gut. Keine Rückmeldung = alles wurde ausgeführt.
                          iobroker status
                            @chris-d-0
                            iobroker status
                            Chris-D 0
                            #88
                            @thomas-braun sehr gut
                            pi@raspberrypi:~ $ iobroker status
                            At least one iobroker host is running.
                            Objects type: file
                            States  type: file
                            ABer IP Adresse kann nicht angezeigt werden
                            • C Chris-D 0
                              Objects type: file
                              States  type: file
                              #89
                              @chris-d-0
                              iobroker list adapters
                              iobroker list instances
                                @chris-d-0
                                Chris-D 0
                                #90
                                pi@raspberrypi:~ $ iobroker list instances
                                  system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0              : backitup              -  enabled
                                + system.adapter.discovery.0             : discovery             -  enabled
                                + system.adapter.echarts.0               : echarts               -  enabled
                                  system.adapter.email.0                 : email                 - disabled
                                  system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
                                  system.adapter.fritzdect.0             : fritzdect             - disabled
                                  system.adapter.habpanel.0              : habpanel              -  enabled
                                + system.adapter.history.0               : history               -  enabled
                                + system.adapter.hm-rega.0               : hm-rega               -  enabled
                                + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                                + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
                                  system.adapter.ical.0                  : ical                  -  enabled
                                + system.adapter.info.0                  : info                  -  enabled
                                + system.adapter.iot.0                   : iot                   -  enabled
                                + system.adapter.javascript.0            : javascript            -  enabled
                                  system.adapter.material.0              : material              -  enabled
                                  system.adapter.mobile.0                : mobile                - disabled
                                  system.adapter.openweathermap.0        : openweathermap        -  enabled
                                + system.adapter.ping.0                  : ping                  -  enabled
                                + system.adapter.samsung.0               : samsung               -  enabled
                                + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.sonos.0                 : sonos                 -  enabled
                                  system.adapter.synology.0              : synology              - disabled, port: 5000
                                + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.tr-064.0                : tr-064                -  enabled
                                + system.adapter.tr-064.1                : tr-064                -  enabled
                                  system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
                                  system.adapter.vis.0                   : vis                   - disabled
                                  system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                • C Chris-D 0
                                  + instance is alive
                                  #91
                                  @chris-d-0
                                  iobroker start admin
                                  iobroker start web
                                    @chris-d-0
                                    iobroker start web
                                    Chris-D 0
                                    #92
                                    iobroker start admin iobroker start web
                                    pi@raspberrypi:~ $ iobroker start admin
                                    pi@raspberrypi:~ $ iobroker start web
                                    pi@raspberrypi:~ $
                                    keine Verbesserung
                                    • C Chris-D 0
                                      pi@raspberrypi:~ $
                                      keine Verbesserung
                                      #93
                                      @chris-d-0
                                      • C Chris-D 0
                                        pi@raspberrypi:~ $
                                        keine Verbesserung
                                        #94
                                        @chris-d-0
                                        iobroker stop
                                        sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
                                        iobroker start
                                          @chris-d-0
                                          iobroker stop
                                          iobroker start
                                          Chris-D 0
                                          #95
                                          pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
                                          + instance is alive
