  4. zWave2 update
    6.5k
zWave2 update
11 Beiträge 4 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • Lenny.CBL Online
    Lenny.CBL Online
    Lenny.CB
    Moin zusammen,
    gibt es wieder Probleme mit serialport?
    Oder ist wieder mit meinem System was im Argen?
    $ iobroker upgrade zwave2@1.10.4
    Update zwave2 from @1.10.2 to @1.10.4
    NPM version: 6.14.12
    npm install iobroker.zwave2@1.10.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
    In file included from ../node_modules/nan/nan.h:58,
    from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/10.24.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/10.24.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
    In file included from /home/iobroker/.cache/node-gyp/10.24.1/include/node/node.h:63, from ../node_modules/nan/nan.h:58, from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.24.1/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../node_modules/nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    from ../node_modules/nan/nan.h:58, from ../src/serialport.h:13, from ../src/serialport_unix.cpp:2:/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.24.1/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    from ../node_modules/nan/nan.h:58, from ../src/poller.cpp:1:/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.24.1/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.24.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
    Update "system.adapter.zwave2.0"
    upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/words.js words.js application/javascript
    upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
    upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
    upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
    upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
    upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
    upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
    Adapter "zwave2" updated
    Process exited with code 0
    • Lenny.CBL Lenny.CB
      Moin zusammen,
      @lenny-cb
      Welche Version von nodeJS läuft?
        @lenny-cb
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @thomas-braun Sieht nach 10.24.1 aus.
        Lenny.CBL 1 Antwort Letzte Antwort
        • AlCalzoneA AlCalzone
          Lenny.CBL Online
          Lenny.CBL Online
          Lenny.CB
          @alcalzone sagte in zWave2 update:
          jupp, so ist es.
            jupp, so ist es.
            @lenny-cb
            Dann würde ich schon Mal auf was aktuelles wie node12 oder 14 springen und dann weiterschauen.
              @lenny-cb
              Lenny.CBL Online
              Lenny.CBL Online
              Lenny.CB
              @thomas-braun sagte in zWave2 update:
              @lenny-cb
              hätte eigentlich gedacht, dass ich das schon mal gemacht habe.
              Vielleicht musste ich wieder zurück wegen einem Fehler. Werd mal das Update machen.
              • Lenny.CBL Online
                Lenny.CBL Online
                Lenny.CB
                @lenny-cb
                jetzt weis ich wieder warum ich noch auf dem alten Stand war. Nutze ja aktuell noch zwave statt zwave2
                Nach dem node-Update startet der Adapter nicht mehr.
                zwave.0
                2021-08-18 11:37:23.256	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zwave.0
                2021-08-18 11:37:23.254	info	terminating
                zwave.0
                2021-08-18 11:37:23.243	error	The module '/opt/iobroker/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                zwave.0
                2021-08-18 11:37:23.242	error	Error: The module '/opt/iobroker/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Object.<anonymous> (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19) at Module._compile (internal/modules/cjs/loader.js:999:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                zwave.0
                2021-08-18 11:37:23.239	error	uncaught exception: The module '/opt/iobroker/node_modules/openzwave-shared/build/Release/openzwave_shared.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                Thomas BraunT Lenny.CBL 2 Antworten Letzte Antwort
                  @lenny-cb
                  zwave.0
                  zwave.0
                  zwave.0
                  zwave.0
                  zwave.0
                  @lenny-cb
                  Der wird ja soweit ich weiß auch schon länger nicht mehr weiterentwickelt.
                  iobroker rebuild zwave
                  mal probieren. Kann aber sein das der Code nicht mehr baut. Wechsel auf zwave2.
                  Edit: Aber im Eröffnungsposting bist du doch mit zwave2 unterwegs?
                    @lenny-cb
                    zwave.0
                    zwave.0
                    zwave.0
                    zwave.0
                    zwave.0
                    Lenny.CBL Online
                    Lenny.CBL Online
                    Lenny.CB
                    hier noch das Log von "iobroker rebuild zwave --install"
                    schaut erst einmal komisch aus, Adapter wird aber grün. mal beobachten.
                    root@odroidC2:~# iobroker rebuild zwave --install
                    npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.zwave"
                    In file included from ../src/openzwave.hpp:27,
                                     from ../src/callbacks.cc:18:
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node_object_wrap.h:85:78:   required from here
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/v8.h:10226:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':
                    /opt/iobroker/node_modules/iobroker.zwave/node_modules/nan/nan_object_wrap.h:65:61:   required from here
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/v8.h:10226:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                    In file included from /opt/iobroker/node_modules/iobroker.zwave/node_modules/nan/nan.h:58,
                                     from ../src/openzwave.hpp:28,
                                     from ../src/openzwave.cc:18:
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                    /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro 'NODE_MODULE_X'
                    ../src/openzwave.cc:336:1: note: in expansion of macro 'NODE_MODULE'
                     NODE_MODULE(openzwave_shared, OZW::init)
                                     from ../src/openzwave-config.cc:18:
                                     from ../src/openzwave-driver.cc:18:
                                     from ../src/openzwave-groups.cc:18:
                                     from ../src/openzwave-management.cc:17:
                                     from ../src/openzwave-network.cc:18:
                                     from ../src/openzwave-nodes.cc:18:
                                     from ../src/openzwave-polling.cc:18:
                                     from ../src/openzwave-scenes.cc:18:
                                     from ../src/openzwave-values.cc:18:
                                     from ../src/utils.cc:18:
                    Rebuild zwave done
                      @lenny-cb
                      FredFF Online
                      FredFF Online
                      FredF
                      Most Active Forum Testing
                      Wechsel auf zwave2.
                      @Lenny-CB Kann ich nur empfehlen
                        Rebuild zwave done
                        @lenny-cb
                        root@odroidC2
                        Arrrrrrrrgh!
