  4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
    6.3k
citroencorsacorsa-eopelpeugeotpsae208
334 Beiträge 44 Kommentatoren 86.2k Aufrufe 43 Beobachtet
  • M mane444
    @tombox Hi, läuft seit 6 Std ohne Probleme.
    Super !👍
    mane444
    @mane444 Hi bei mir hatte der Adapter heute Nacht auch wieder einen Hänger. Hab dann heute Mittag den Adapter neu gestartet nun kommen die Werte wieder.
    psa.0
    2021-07-05 04:00:02.855	warn	OldAPI Login failed
    psa.0
    2021-07-05 04:00:02.854	warn	Login old api failed
    psa.0
    2021-07-05 04:00:02.853	warn	Error: getaddrinfo ENOTFOUND id-dcr.citroen.com
    psa.0
    2021-07-05 04:00:02.840	error	Login failed
    psa.0
    2021-07-05 04:00:02.839	error	Login failed
    psa.0
    2021-07-05 04:00:02.838	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
    psa.0
    2021-07-05 03:59:52.715	info	starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
    host.buanet-iobroker1
    2021-07-05 03:59:50.380	info	instance system.adapter.psa.0 started with pid 31308
    2021-07-05 03:59:20.276	info	Restart adapter system.adapter.psa.0 because enabled
    2021-07-05 03:59:20.197	error	instance system.adapter.psa.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    psa.0
    2021-07-05 03:59:19.423	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    psa.0
    2021-07-05 03:59:19.420	info	terminating
    psa.0
    2021-07-05 03:59:19.420	warn	Clear yet terminated interval 527
    psa.0
    2021-07-05 03:59:19.419	warn	Clear yet terminated interval undefined
    psa.0
    2021-07-05 03:59:19.419	warn	Clear yet terminated interval 597
    psa.0
    2021-07-05 03:59:19.412	error	Cannot read property 'status' of undefined
    psa.0
    2021-07-05 03:59:19.411	error	TypeError: Cannot read property 'status' of undefined at /opt/iobroker/node_modules/iobroker.psa/main.js:392:40 at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    psa.0
    2021-07-05 03:59:19.410	error	unhandled promise rejection: Cannot read property 'status' of undefined
    psa.0
    2021-07-05 03:59:19.410	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    psa.0
    2021-07-05 03:59:18.796	error	Refresh token failed
    psa.0
    2021-07-05 03:59:18.796	error	Refreshtoken failed
    psa.0
    2021-07-05 03:59:18.795	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
    • M MasterAndi0815
      Hallo tombox,
      musste leider feststellen, dass die Daten nicht mehr aktualisiert wurden.
      Habe den Adapter deinstalliert und die aktuelle Version wieder installiert.
      Aber es kommt ein Login Fehler, obwohl die Anmeldedaten stimmen.
      Vorher kommt aber ein Zertifikatsfehler, der mich vermuten lässt, dass die Peugeot Webseite aufgerufen wird und nicht die Citroen Seite, obwohl ich in der Instanz Citroen ausgewählt habe.
      psa.0	2021-07-05 13:55:31.161	error	(15382) Login failed
      psa.0	2021-07-05 13:55:31.161	error	(15382) {"error":"invalid_grant","error_description":"The provided access grant is invalid, expired, or revoked."}
      psa.0	2021-07-05 13:55:31.160	error	(15382) Login failed
      psa.0	2021-07-05 13:55:31.160	error	(15382) Error: Request failed with status code 400
      psa.0	2021-07-05 13:55:31.065	warn	(15382) OldAPI Login failed
      psa.0	2021-07-05 13:55:31.064	warn	(15382) Login old api failed
      psa.0	2021-07-05 13:55:31.064	warn	(15382) Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate's altnames: Host: id-dcr.peugeot.com. is not in the cert's altnames: DNS:*.citroen.com
      psa.0	2021-07-05 13:55:30.908	info	(15382) starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.2, js-controller: 3.2.16
      MasterAndi0815
      schrieb am zuletzt editiert von MasterAndi0815
      @masterandi0815
      Jetzt wollte ich zum Test mich in der App auf dem iPhone einmal neu anmelden, leider klappt das auch nicht. Beim Passwort vergessen wird nicht mal meine E-Mail Adresse akzeptiert.
      Wie es aussieht hat PSA/Stellantis gerade eine anderes Problem.
      Werde es gleich noch mal unter Android probieren. -> Unter Android dasselbe Problem.
      Zum Glück ist der Account auf dem iPhone meiner Frau noch angemeldet.
      H 1 Antwort Letzte Antwort
      • M MasterAndi0815
        Hallo tombox,
        tombox
        @masterandi0815 installier nochmal neu und probiere nochmal
        • M MasterAndi0815
          @masterandi0815
          H Online
          H Online
          holgerwolf
          @masterandi0815 Das Problem hatte ich letzte Woche auch. Ging garnix mehr. Useraccount kannte die App nicht, deshalb konnte man die auch nicht zurücksetzen.
          Ich musste den Zugang komplett neu einrichten. Und hänge jetzt wohl auch auf nem anderen Server. Jedenfalls bekommt Tronity keine GPS Daten mehr. Das ging bei mir im Gegensatz zu vielen anderen die letzten Wochen noch.
          Ich tippe mal, PSA baut um und schaltet nach und nach die alte API ab,
          • H holgerwolf
            MasterAndi0815
            @holgerwolf
            Habe jetzt auch den Account unter derselben E-Mail Adresse neu angelegt und unseren e-C4 neu verbunden.
            Witzigerweise kam dann noch eine E-Mail, dass die Remote Dienste gekündigt wurden, da das Auto mit einem neuen Account verbunden wurde.
            Auf jeden Fall funktioniert jetzt auch der Adapter wieder einwandfrei und die Daten werden wieder einwandfrei abgerufen.
              mane444
              Hi, ich hab immer mal wieder Abbrüche der Verbindung. Sobald ich den Adapter neu starte läuft es wieder.
              Gibt's da eine Erklärung?
              Kann man irgendwie die "old API" abschalten, da scheinbar hier das Problem herkommt.
              Auto ist Citroen C4 elektro.
              info.0
              2021-07-24 08:48:56.815	error	Error: connect ETIMEDOUT 185.199.111.133:443
              psa.0
              2021-07-24 08:46:21.863	error	Login failed
              psa.0
              2021-07-24 08:46:21.862	error	Login failed
              psa.0
              2021-07-24 08:46:21.861	error	Error: getaddrinfo ENOTFOUND idpcvs.citroen.com
              psa.0
              2021-07-24 08:46:21.857	warn	OldAPI Login failed
              psa.0
              2021-07-24 08:46:21.856	warn	Login old api failed
              psa.0
              2021-07-24 08:46:21.855	warn	Error: getaddrinfo ENOTFOUND id-dcr.citroen.com
              • M mane444
                info.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                psa.0
                tombox
                @mane444 Es scheint hier ein Internetproblem zu geben der adapter kann die server nicht erreichen
                • T tombox
                  Hi ich habe ein PSA Adapter erstellt, basierend auf https://developer.groupe-psa.io/webapi/b2c/overview/about/#article
                  Er unterstützt Peugot, Opel, Citroen, DS, Vauxhall mit den jeweiligen My Apps
                  Es werden nur die neuen Modelle wie e208 corsa-e unterstützt
                  Es wird nicht Laden oder Klimatisierung starten unterstützt
                  Zum Installieren:
                  https://github.com/TA2k/ioBroker.psa
                  Unter Adapter das Github Icon klicken:
                  Benutzerdefiniert auswählen und die Url einfügen.
                  Dann unter Adapter den PSA Adapter suchen und ganz rechts auf das Plus klicken.
                  In den Instanzoptionen die jeweiligen Optionen einstellen.
                  mamaretti32
                  @tombox
                  funktioniert prima (mit meinem 208-e)
                  aber kannst du mir erklären warum es mit deiner client_secret / client_ID und meinem PSA-Account funktioniert?
                  Wäre es nicht sinnvoll bei der Instanzeinstellung dafür 2 Felder zu haben, damit man später eigene client_secret / client_ID dort eingeben kann?
                  kann man ID und Secret einfach erzeugen oder läuft das nach wie vor über den PSA_car_controller?
                  thx
                  • M mamaretti32
                    @tombox
                    thx
                    tombox
                    @mamaretti32
                    client id und secret kommen von der app und fest in die app einprogrammiert.
                    Diese ändern sich nicht und deswegen macht es auch kein Sinn dass der Nutzer sie eingibt.
                    • T tombox
                      @mamaretti32
                      mamaretti32
                      @tombox
                      ah ok, demnach würd ich dann mit dem PSA_car_controller die gleiche client id und secret bekommen?
                      mal noch ne andre Frage: meinst du es wär möglich die Klimaanlage zu steuern. wäre ein nettes Feature im Winter, wenn man das automatisieren könnte
                      • M mamaretti32
                        @tombox
                        tombox
                        @mamaretti32 Ja wäre möglich aber dieser SMS Abfrage check ist sehr kompliziert bisher hatte ich da keine Lust drauf
                        • T tombox
                          mamaretti32
                          #66
                          @tombox
                          ist ja auch nicht so wichtig. Hauptsache man kann SOC gut abfragen, und das läuft ja prima.
                          gibt es Erfahrungswerte wie das Update-Intervall am sinnvollsten ist?
                          5 Minuten schien mir rel. schnell. und ab uns zu wurde die Werte nicht aktualisiert.
                          Bin mir nicht sicher ob das an der schlechten Verbindung (Garage) liegt.
                          Es gibt unter status.lastPosition.properties.signalQuality einen Wert 9. Wär mal intressant ob der Wert gut oder schlecht ist
                          T H 2 Antworten Letzte Antwort
                          • M mamaretti32
                            @tombox
                            tombox
                            #67
                            @mamaretti32 Kann ich nicht beantworten ich besitze kein PSA Fahrzeug
                            • M mamaretti32
                              @tombox
                              H Online
                              H Online
                              holgerwolf
                              #68
                              @mamaretti32
                              status.lastPosition.properties.signalQuality ist bei mir auch 9 und ich habe da noch nicht was anderes gesehen.
                              Update Intervall hab ich auf 5 Minuten gelassen.
                              Zur Info, beim Laden wird der SoC nicht aktualisiert.
                              • H holgerwolf
                                @mamaretti32
                                tombox
                                #69
                                @holgerwolf Wird der soc in der app aktualisiert?
                                H M 2 Antworten Letzte Antwort
                                • T tombox
                                  H Online
                                  H Online
                                  holgerwolf
                                  #70
                                  @tombox muss ich beim nächsten laden mal genau beobachten. Denke, aber dass die App es richtig anzeigt (wenn sie mal funzt ;-)
                                  • T tombox
                                    mamaretti32
                                    #71
                                    bei mir ist das so:
                                    SOC wird beim Laden (wie oben erwähnt) nicht aktualisiert.
                                    Wenn man nach ein paar Minuten die App öffnet und auf den "reload-Button" drückt, heißt es (bei mir am iPhone) "Ladevorgang unterbrochen"
                                    SOC bei der App und auch (!) bei iobroker werden aktualisiert.
                                    ich hab als Wallbox den Tinkerforge WARP, die kann ich über MQTT stoppen und starten und der SOC wird auch aktualisiert.
                                    ich vermute das macht die App auch. ich muss das mal beobachten wenn ich mit der App direkt neben dem Auto stehe und auf den "reload-Button" drücke.
                                    zuerst dachte ich man muss erst den SOC auslesen und dann mühsam errechnen wann der gewünschte SOC erreicht ist, um dann abzuschalten.
                                    aber ich denke wenn man über Iobroker die Wallbox alle halbe Stunde oder Stunde mal kurz trennt sollte das auch gehen, oder?
                                    • M mamaretti32
                                      bei mir ist das so:
                                      mamaretti32
                                      #72
                                      was cool wäre wenn man den reload beim Adapter noch zusätzlich per script steuern könnte. damit man zb nach jedem Charger-Stop-Start die Daten vom PSA-Server gleich holen kann und nicht erst auf das Update vom Intervall warten muss.
                                      wenn nicht geladen wird gibt es ja auch kaum einen Grund warum das Interval häufiger abfragt.
                                      • M mamaretti32
                                        tombox
                                        #73
                                        @mamaretti32 Eigentlich müsste man reload button nachbauen.aber dann müsste man die sms authentifizierung erst implementieren
                                        • T tombox
                                          mamaretti32
                                          #74
                                          @tombox
                                          das wär vermutlich das Beste, und wäre natürlich auch super weil man dann andre Dinge steuern könnte.
                                          ich bin gerade auf das gestoßen
                                          https://www.goingelectric.de/forum/viewtopic.php?p=1540760#p1540760
                                          ich habe bis jetzt immer alle 5-10 Minuten überprüft ob sich die Werte ändern.
                                          aber evtl. war das zu kurz und es braucht einfach eine Weile bis der Server die Daten aktualisiert ?!?
                                          oder kann man das definitiv ausschließen das sich der SOC beim Laden ändert?
                                          im Moment ist das Akku voll. werde mal testen wenn er leer ist und über mehrere Stunden beobachten.
