  4. Habt Ihr auch performance Probleme seit Update?
    6.6k
62 Beiträge 7 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • spicerS Offline
    spicerS Offline
    spicer
    schrieb am zuletzt editiert von spicer
    Aber was soll das?
    syslog
    Aug 11 23:05:31 halten2 systemd[1]: Started ioBroker Server.
    Aug 11 23:05:33 halten2 bash[5313]: Error initializing logger: Cannot set property DailyRotateFile of #<Object> which has only a getter
    Aug 11 23:05:33 halten2 bash[5313]: /opt/iobroker/node_modules/iobroker.js-controller/main.js:4555
    Aug 11 23:05:33 halten2 bash[5313]:         logger.activateDateChecker(true, config.log.maxDays);
    Aug 11 23:05:33 halten2 bash[5313]:                ^
    Aug 11 23:05:33 halten2 bash[5313]: TypeError: Cannot read property 'activateDateChecker' of undefined
    Aug 11 23:05:33 halten2 bash[5313]:     at Object.init (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4555:16)
    Aug 11 23:05:33 halten2 bash[5313]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:8:19)
    Aug 11 23:05:33 halten2 bash[5313]:     at Module._compile (node:internal/modules/cjs/loader:1095:14)
    Aug 11 23:05:33 halten2 bash[5313]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1124:10)
    Aug 11 23:05:33 halten2 bash[5313]:     at Module.load (node:internal/modules/cjs/loader:975:32)
    Aug 11 23:05:33 halten2 bash[5313]:     at Function.Module._load (node:internal/modules/cjs/loader:816:12)
    Aug 11 23:05:33 halten2 bash[5313]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:79:12)
    Aug 11 23:05:33 halten2 bash[5313]:     at node:internal/main/run_main_module:17:47
    Aug 11 23:05:33 halten2 systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Aug 11 23:05:33 halten2 systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Aug 11 23:05:34 halten2 systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
    Aug 11 23:05:34 halten2 systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 30.
    Aug 11 23:05:34 halten2 systemd[1]: Stopped ioBroker Server.
    Aug 11 23:05:34 halten2 systemd[1]: Started ioBroker Server.
    Aug 11 23:05:34 halten2 systemd[1]: Started Session 11 of user root.
    Laut syslog sollte ioBroker laufen.
    Und was ist der "activateDateChecker"?
    Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
    (Murphys Gesetz)
    • spicerS spicer
      Aber was soll das?
      syslog
      GlasfaserG Offline
      GlasfaserG Offline
      @spicer sagte in Habt Ihr auch performance Probleme seit Update?:
      Bist du mit root unterwegs !?
      spicerS 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        spicerS Offline
        spicerS Offline
        spicer
        @glasfaser
        Yep. Als User root und im root Verzeichnis.
        Mache den fix gerade als pi.
        Edit:
        Hat nix gebracht :(
        (Murphys Gesetz)
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
        • spicerS spicer
          @glasfaser
          Edit:
          Hat nix gebracht :(
          Dann hilf dir selbst. Es wird sich nicht als root angemeldet.
          • spicerS spicer
            @glasfaser
            Edit:
            Hat nix gebracht :(
            GlasfaserG Offline
            GlasfaserG Offline
            Edit:
            Hat nix gebracht
            Doch ... damit du mit root nicht rumspielst .
            Zeige mal
            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            iobroker version
              Edit:
              Hat nix gebracht
              Zeige mal
              iobroker version
              spicerS Offline
              spicerS Offline
              spicer
              @glasfaser
              pi@halten2:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              /usr/bin/nodejs
              v16.4.1
              /usr/bin/node
              v16.4.1
              /usr/bin/npm
              7.20.5
              nodejs:
                Installiert:           16.4.1-1nodesource1
                Installationskandidat: 16.4.1-1nodesource1
                Versionstabelle:
               *** 16.4.1-1nodesource1 100
                   14.17.5-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                   10.24.0~dfsg-1~deb10u1 500
              pi@halten2:~ $ iobroker version
              3.3.14
              (Murphys Gesetz)
              • GlasfaserG Offline
                GlasfaserG Offline
                @spicer
                Lölll ..... :)
                  spicerS Offline
                  spicerS Offline
                  spicer
                  Auch wenn ich als pi den ioBroker starte zeigt der syslog:
                  Aug 11 23:23:49 halten2 systemd[1]: Started Session 20 of user root.
                  (Murphys Gesetz)
                    @spicer
                    Lölll ..... :)
                    spicerS Offline
                    spicerS Offline
                    spicer
                    @glasfaser sagte in Habt Ihr auch performance Probleme seit Update?:
                    @spicer
                    Lölll ..... :)
                    Was Lölll? Was stimmt nicht?
                    (Murphys Gesetz)
                    • spicerS spicer
                      @spicer
                      Lölll ..... :)
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Was stimmt nicht?
                      Lese mal :
                      https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
                        Was stimmt nicht?
                        Lese mal :
                        spicerS Offline
                        spicerS Offline
                        spicer
                        @glasfaser
                        Ah, Node.js Version sollte 14.x sein?
                        (Murphys Gesetz)
                          GlasfaserG Offline
                          @spicer
                          Ja kannst du nehmen ... aber richtig upgraden .
                          • spicerS spicer
                            @glasfaser
                            @spicer
                            Ist das noch die SD-Karte, die vermutlich im Juli schon 'nen Schuss hatte?
                              @spicer
                              spicerS Offline
                              spicerS Offline
                              spicer
                              Ja. Denkst Du, die hat nen Schuss?
                              (Murphys Gesetz)
                              • spicerS spicer
                                @spicer Ja, vor Wochen schon.
                                Als du dein WLAN verloren hast.
                                  spicerS Offline
                                  spicerS Offline
                                  spicer
                                  Und das wirkt sich so aus?
                                  Kann ich die einfach mit dd kopieren?
                                  (Murphys Gesetz)
                                  Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                                  • spicerS spicer
                                    @spicer
                                    dmesg | grep -i ext4
                                    Zusammen mit dem Herumgehampel als root ist da alles möglich.
                                    • spicerS spicer
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Nö , oder wollst du den Müll mit kopieren .
                                      Setze ihn neu auf mit einem Backup , natürlich auf einer neuen Karte .
                                        spicerS Offline
                                        spicerS Offline
                                        spicer
                                        @glasfaser
                                        Ok. Was ist alles im Backup enthalten?
                                        Alles was im ioBroker war und sonst noch iwelche Sachen?
                                        (Murphys Gesetz)
                                        • spicerS spicer
                                          Wenn dd = dumpster dump ist.
                                          Wenn du damit ein disk dump meinst: Nein.
