  4. IO-Broker mit irrsinnig hohem Speicherverbrauch in Chrome
    6.6k
16 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • W WolfgangFB
    @homoran said in IO-Broker mit irrsinnig hohem Speicherverbrauch in Chrome:
    @wolfgangfb sagte in IO-Broker mit irrsinnig hohem Speicherverbrauch in Chrome:
    Was verstehst Du unter Browserlog?
    F12
    Was soll ich jetzt genau quoten?
    Das stehen seitenweise Logs, hier mal das Ende:
    2VM25 layout.js:1 Uncaught SyntaxError: Identifier 'API_PUBLIC_KEY' has already been declared
    embed:15 [Report Only] Refused to execute inline event handler because it violates the following Content Security Policy directive: "script-src 'report-sample' 'nonce-d1tcwvuJlDYrVi3+mFttkg' 'unsafe-inline' 'strict-dynamic' https: http: 'unsafe-eval'". Note that 'unsafe-inline' is ignored if either a hash or nonce value is present in the source list.
    cdn.jsdelivr.net/codemirror.spell-checker/latest/en_US.aff:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
    cdn.jsdelivr.net/codemirror.spell-checker/latest/en_US.dic:1 Failed to load resource: net::ERR_NAME_NOT_RESOLVED
    3translate.js:24 "offline": {"en": "offline", "de": "offline", "ru": "offline", "pt": "offline", "nl": "offline", "fr": "offline", "es": "offline", "pl": "offline", "it": "offline", "zh-cn": "offline"},
    tab_m.html:1 Failed to decode downloaded font: http://192.168.1.203:8081/adapter/info/lib/fonts/fontawesome-webfont.woff2?v=4.7.0
    tab_m.html:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
    DevTools failed to load source map: Could not load content for http://192.168.1.203:8081/adapter/info/lib/js/showdown.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://192.168.1.203:8081/adapter/info/lib/js/chartist.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://192.168.1.203:8081/adapter/info/lib/js/format-google-calendar.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    admin.js:1489 clear
    adminObjects.js:256 Subscribe: javascript.0.*
    adminObjects.js:256 Subscribe: shelly.0.SHSW-25#1130E6#1.*
    adminObjects.js:256 Subscribe: shelly.0.SHSW-1#E09806960BBC#1.*
    adminObjects.js:256 Subscribe: shelly.0.SHSW-25#112B27#1.*
    adminObjects.js:256 Subscribe: meross.0.1909122166168225186448e1e9037abd.*
    DevTools failed to load source map: Could not load content for http://192.168.1.203:8081/adapter/info/lib/css/bootstrap.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    crunchipC Offline
    crunchipC Offline
    nur die error Meldungen
    W 1 Antwort Letzte Antwort
      W Offline
      W Offline
      WolfgangFB
      @crunchip
      Hier die error Meldungen
      ds18b20.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
      2layout.js:1 Uncaught SyntaxError: Identifier 'API_PUBLIC_KEY' has already been declared
      12jquery-3.2.1.min.js:2 Uncaught Error: Assertion failed
          at Function.error (jquery-3.2.1.min.js:2)
          at t (jquery.fancytree-all.js:9085)
          at jquery.fancytree-all.js:9121
          at D.nodeRender (jquery.fancytree-all.js:9313)
          at D.nodeRender (jquery.fancytree-all.js:183)
          at D._callHook (jquery.fancytree-all.js:2312)
          at F.render (jquery.fancytree-all.js:1609)
          at e.fn.init.state (selectID.js:3878)
          at e.fn.init.e.fn.selectId (selectID.js:4090)
          at Objects.stateChange (adminObjects.js:152)
      2jquery-3.2.1.min.js:2 Uncaught Error: Assertion failed prev. row must have a tr, or be system root
          at D.nodeRender (jquery.fancytree-all.js:9325)
          at j (admin.js:1125)
      24jquery-3.2.1.min.js:2 Uncaught Error: Assertion failed
      16jquery-3.2.1.min.js:2 Uncaught Error: Assertion failed prev. row must have a tr, or be system root
      error @ jquery-3.2.1.min.js:2
      t @ jquery.fancytree-all.js:9085
      nodeRender @ jquery.fancytree-all.js:9325
      (anonymous) @ jquery.fancytree-all.js:183
      _callHook @ jquery.fancytree-all.js:2312
      render @ jquery.fancytree-all.js:1609
      state @ selectID.js:3878
      e.fn.selectId @ selectID.js:4090
      Objects.stateChange @ adminObjects.js:152
      j @ admin.js:1125
      setTimeout (async)
      (anonymous) @ admin.js:2037
      r.emit @ index.js:83
      r.onevent @ index.js:83
      r.onpacket @ index.js:83
      (anonymous) @ index.js:83
      r.ondecoded @ index.js:83
      a.add @ index.js:83
      r.ondata @ index.js:83
      r.onPacket @ index.js:83
      r.onData @ index.js:83
      ws.onmessage @ index.js:83
      • W WolfgangFB
        @crunchip
        j @ admin.js:1125
        setTimeout (async)
        a.add @ index.js:83
        W Offline
        W Offline
        WolfgangFB
        @wolfgangfb
        Nachtrag: Ein Firefox braucht auch 4 GB Ram.
        IO-Broker Objekte sagt:
        Objekte: 50973, Zustände: 30537
        Ist das viel? Zu viel? Normal?
        • W WolfgangFB
          @wolfgangfb
          crunchipC Offline
          crunchipC Offline
          kommt drauf an, was du alles installiert/laufen hast
          ich habe z.b. Objekte: 35756, Zustände: 33726
            W Offline
            W Offline
            WolfgangFB
            @crunchip
            Wie hoch ist Dein Speicherverbrauch im Browser?
            • W WolfgangFB
              @crunchip
              crunchipC Offline
              crunchipC Offline
              @wolfgangfb
              ich surf mit nem pi4(manjaro) in meinem Netzwerk, da sind fast 30 Tabs offen im chrome und nochmal 20 im FF, hab keine Probleme. Schwankt immer mal, das ist so der Durchschnitt
              kontrolliere doch mal, ob sich das bessert, wenn du iobroker mal neu startest
                @wolfgangfb
                W Offline
                W Offline
                WolfgangFB
                @crunchip
                Nach einem Neustart ist es kurzfristig besser, der Speicherbedarf steigt aber kontinuierlich an, im Firefox bin ich schon wieder bei 1.5 GB (vor dem Abschalten waren es 4,6 GB),
                Die Skript Instanz auf dem Firefox ist unbedienbar. Zwischen 2 Tastendrücken vergehen 10 Sekunden und mehr, ehe etwas passiert.
                Der Chrome hält sich noch zurück, steigt aber langsam, aber kontinuierlich.
                Der pi selbst scheint ziemlich gelangweilt, ein top sagt mir, dass die CPU Last bei 7% liegt.
                _ crunchipC 2 Antworten Letzte Antwort
                • W WolfgangFB
                  @crunchip
                  _ Offline
                  _ Offline
                  _Matze_
                  @wolfgangfb
                  Bei mir zum Vergleich bei einem Ubuntu auf Proxmox, auf dem nur iobroker installiert wurde:
                  Objekte: 7718
                  Zustände: 6671
                  Prozesse: 30
                  Anzahl der Adapter: 339
                  Aktive Instanzen: 26
                  Die Prozessorlast im Ubuntu liegt im Mittel bei 5%
                  Der Speicherverbrauch im Ubuntu dauerhaft bei 1,5 GB
                  Chrome mit dem iobroker Tab offen: 600 MB
                  • W WolfgangFB
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    @wolfgangfb
                    • hast du mal das Browserlog betrachtet beim laden des iobroker Tab, nachdem du neu gestartet hattest?
                    • mit was für einen Rechner rufst du iobroker auf?
                      Wenn ich mit meinem Windows Laptop(i7) drauf zugriff, hatte ich auch hin und wieder eine erhöhte Auslastung.
                    • was passiert, wenn du die Seite am Handy aufrufst, läuft es da flüssig?
                      @wolfgangfb
                      W Offline
                      W Offline
                      WolfgangFB
                      @crunchip
                      Ich rufe die Seite mit Firefox unter Win 10 oder Chrome unter Win 7 auf.
                      Beim Start kommt im Fehlerprotokoll (Chrome)
                      ds18b20.png:1 GET http://192.168.1.203:8081/adapter/ds18b20/ds18b20.png 404 (Not Found)
                      Auch auf dem Handy dauert es über 10 Sekunden, bis die Seite aufgebaut ist. Richtig flüssig ist das auch nicht.
                      • W WolfgangFB
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        dann ist scheinbar bei dir etwas andere faul
                        verwendest du die entsprechenden Adapter auch in der aktuellen Version?
