  4. Admin v5 jetzt im STABLE!
    6.4k
563 Beiträge 83 Kommentatoren 207.6k Aufrufe 70 Beobachtet
  • B benkedav
    also ich steh gereade auf dem Schlauch. und brauche mal Hilfe.
    Mein Status ist wie folgt:
    Adapter    "admin"         : 5.1.23   , installed 4.2.2 [Updateable]
    Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "hue"           : 3.5.19   , installed 3.5.19
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.8    , installed 5.1.3 [Updateable]
    Controller "js-controller" : 3.3.15   , installed 3.3.15
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "scenes"        : 2.3.6    , installed 2.3.6
    Adapter    "shelly"        : 4.0.7    , installed 4.0.7
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "tradfri"       : 2.7.4    , installed 2.7.4
    Adapter    "web"           : 3.4.7    , installed 3.4.1 [Updateable]
    und hier beißt sich die Katze in den Schwanz.
    Admin will nicht updaten, weil es mindestens Javascript 5.2.x braucht...
    Javascript kann ich nicht updaten, weil es Admin 5 braucht
    Invalid version of "admin". Installed "4.2.2", required ">=5.1.9
    ich kann das Admin upgrade starten und das läuft sogar durch:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @4.2.2 to @5.1.23 now? [(y)es, (n)o]: y
    Update admin from @4.2.2 to @5.1.23
    host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    NPM version: 7.20.5
    npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EBADENGINE
    npm ERR! engine Unsupported engine
    npm ERR! engine Not compatible with your version of node/npm: concentrate@0.2.3
    npm ERR! notsup Not compatible with your version of node/npm: concentrate@0.2.3
    npm ERR! notsup Required: {"node":"~0.10.0"}
    npm ERR! notsup Actual:   {"npm":"7.20.5","node":"v12.22.4"}
    npm ERR!     /home/iobroker/.npm/_logs/2021-08-08T09_37_25_759Z-debug.log
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    Update "system.adapter.admin.0"
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    host.raspberrypi Adapter "system.adapter.admin.0" is started
    hilft aber alles nichts.
    ich habe auch versucht auf zwischenversionen zu gehen also z.B. so
    ./iobroker upgrade javascript@5.2.6
    läuft auch durch und endet mit einem
    Adapter "javascript" updated
    aber trotz allem bleiben Admin und Javascript auf dem alten Stand.
    Wie komme ich denn aus der Nummer raus?
    #108
    @benkedav Also die Updates sehen gut aus ... Mal "Shift reload" im Browser gemacht? Mal ioBroker gestoppt und neu gestartet? Bitte ggf als eigenen Thread, weil hat mit dem Update an sich nichts zu tun. Da ist bei Dir was komisch
    • D dennis.fabri
      JavaScript-Plugin stürzt kurz nach dem Start ab (buanet-docker - JavaScript Version 5.2.8 node: v12.22.2, js-controller: 3.3.15):
      Nachdem ich iobroker heute vollständig auf die aktuellen Versionen gezogen habe, stürzt die JavaScript-Instanz kurz nach dem Start ab. Eine Fehlermeldung dazu konnte ich nicht finden. Die Neustarts im Log wurden hier jeweils manuell getriggert, worauf das Plugin kurz danach wieder "rot" wurde.
      Weitere Experimente kann ich erst einmal nicht machen, weil es eine produktive Instanz ist, die jetzt wieder mit Admin 4 läuft. Ich habe aber vor dem Restore eine vollständige Kopie des Volumes angelegt, so dass ich ggf. zusätzliche Informationen liefern kann.
      Auszug aus der Logdatei:
      2021-08-08 10:47:17.507  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-08-08 10:47:17.739  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 send kill signal
      2021-08-08 10:47:18.741  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 killing pid 19367
      2021-08-08 10:47:21.017  - info: host.sh-iobroker instance system.adapter.javascript.0 started with pid 20885
      2021-08-08 10:47:24.146  - debug: javascript.0 (20885) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-08-08 10:47:24.233  - debug: javascript.0 (20885) Objects client ready ... initialize now
      2021-08-08 10:47:24.234  - debug: javascript.0 (20885) Objects create System PubSub Client
      2021-08-08 10:47:24.235  - debug: javascript.0 (20885) Objects create User PubSub Client
      2021-08-08 10:47:24.236  - debug: javascript.0 (20885) Objects client initialize lua scripts
      2021-08-08 10:47:24.266  - debug: javascript.0 (20885) Objects connected to redis: 127.0.0.1:9001
      2021-08-08 10:47:24.278  - debug: javascript.0 (20885) objectDB connected
      2021-08-08 10:47:24.279  - debug: javascript.0 (20885) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-08-08 10:47:24.303  - debug: javascript.0 (20885) States create System PubSub Client
      2021-08-08 10:47:24.304  - debug: javascript.0 (20885) States create User PubSub Client
      2021-08-08 10:47:24.338  - debug: javascript.0 (20885) States connected to redis: 127.0.0.1:9000
      2021-08-08 10:47:24.338  - debug: javascript.0 (20885) statesDB connected
      2021-08-08 10:47:25.158  - debug: javascript.0 (20885) Plugin sentry Initialize Plugin (enabled=true)
      2021-08-08 10:47:25.670  - info: javascript.0 (20885) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.2, js-controller: 3.3.15
      2021-08-08 10:47:25.772  - debug: javascript.0 (20885) Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/base.d.ts","node_modules/@types/node/ts3.6/base.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts","node_modules/@types/node/wasi.d.ts"]
      2021-08-08 10:47:25.824  - debug: javascript.0 (20885) Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
      2021-08-08 10:47:25.826  - info: javascript.0 (20885) requesting all states
      2021-08-08 10:47:25.827  - info: javascript.0 (20885) requesting all objects
      2021-08-08 10:47:28.455  - info: javascript.0 (20885) received all states
      2021-08-08 10:47:28.530  - info: javascript.0 (20885) received all objects
      2021-08-08 10:47:37.719  - info: javascript.0 (20885) Start javascript script.js.Beleuchtung.Außen.Bewegungsmelder
      2021-08-08 10:47:37.795  - info: javascript.0 (20885) script.js.Beleuchtung.Außen.Bewegungsmelder: registered 3 subscriptions and 1 schedule
      2021-08-08 10:47:37.795  - info: javascript.0 (20885) Start javascript script.js.Beleuchtung.Außen.Haustür
      2021-08-08 10:47:37.799  - info: javascript.0 (20885) script.js.Beleuchtung.Außen.Haustür: registered 0 subscriptions and 2 schedules
      2021-08-08 10:47:37.799  - info: javascript.0 (20885) Start javascript script.js.Beleuchtung.Innen.Flur_EG
      2021-08-08 10:47:37.802  - info: javascript.0 (20885) script.js.Beleuchtung.Innen.Flur_EG: registered 1 subscription and 0 schedules
      2021-08-08 10:47:37.803  - info: javascript.0 (20885) Start javascript script.js.Beleuchtung.Weihnachten.Außen
      2021-08-08 10:47:37.818  - info: javascript.0 (20885) script.js.Beleuchtung.Weihnachten.Außen: registered 0 subscriptions and 2 schedules
      2021-08-08 10:47:37.818  - info: javascript.0 (20885) Start javascript script.js.Beleuchtung.Weihnachten.Innen_Wohnzimmer
      2021-08-08 10:47:37.886  - info: javascript.0 (20885) script.js.Beleuchtung.Weihnachten.Innen_Wohnzimmer: registered 0 subscriptions and 4 schedules
      2021-08-08 10:47:37.887  - info: javascript.0 (20885) Start javascript script.js.Belüftung.Belüftungsstärke
      2021-08-08 10:47:37.902  - info: javascript.0 (20885) script.js.Belüftung.Belüftungsstärke: registered 1 subscription and 0 schedules
      2021-08-08 10:47:37.902  - info: javascript.0 (20885) Start javascript script.js.Belüftung.Zeitsteuerung
      2021-08-08 10:47:37.909  - info: javascript.0 (20885) script.js.Belüftung.Zeitsteuerung: registered 1 subscription and 2 schedules
      2021-08-08 10:47:37.909  - info: javascript.0 (20885) Start javascript script.js.Bewässerung.Füllstand_Zisterne
      2021-08-08 10:47:37.923  - info: javascript.0 (20885) script.js.Bewässerung.Füllstand_Zisterne: registered 1 subscription and 0 schedules
      2021-08-08 10:47:37.923  - info: javascript.0 (20885) Start javascript script.js.Bewässerung.Pumpe_Zisterne
      2021-08-08 10:47:37.943  - info: javascript.0 (20885) script.js.Bewässerung.Pumpe_Zisterne: registered 2 subscriptions and 3 schedules
      2021-08-08 10:47:37.944  - info: javascript.0 (20885) Start javascript script.js.Bewässerung.Variablen
      2021-08-08 10:47:37.947  - info: javascript.0 (20885) script.js.Bewässerung.Variablen: registered 0 subscriptions and 0 schedules
      2021-08-08 10:47:37.947  - info: javascript.0 (20885) Start javascript script.js.Bewässerung.Zeitsteuerung
      2021-08-08 10:47:37.990  - info: javascript.0 (20885) script.js.Bewässerung.Zeitsteuerung: registered 0 subscriptions and 6 schedules
      2021-08-08 10:47:37.990  - info: javascript.0 (20885) Start javascript script.js.Fernbedienung.Fernbedienung_Wohnzimmer
      2021-08-08 10:47:38.014  - info: javascript.0 (20885) script.js.Fernbedienung.Fernbedienung_Wohnzimmer: registered 16 subscriptions and 0 schedules
      2021-08-08 10:47:38.015  - info: javascript.0 (20885) Start javascript script.js.Heizung_&_Warmwasser.Heizung
      2021-08-08 10:47:38.022  - info: javascript.0 (20885) script.js.Heizung_&_Warmwasser.Heizung: registered 0 subscriptions and 2 schedules
      2021-08-08 10:47:38.022  - info: javascript.0 (20885) Start javascript script.js.Heizung_&_Warmwasser.Wasserzirkulation
      2021-08-08 10:47:38.041  - info: javascript.0 (20885) script.js.Heizung_&_Warmwasser.Wasserzirkulation: registered 0 subscriptions and 2 schedules
      2021-08-08 10:47:38.041  - info: javascript.0 (20885) Start javascript script.js.Multimedia.AV-Receiver
      2021-08-08 10:47:38.045  - info: javascript.0 (20885) script.js.Multimedia.AV-Receiver: registered 3 subscriptions and 0 schedules
      2021-08-08 10:47:38.045  - info: javascript.0 (20885) Start javascript script.js.Multimedia.Internetverbindung
      2021-08-08 10:47:38.062  - info: javascript.0 (20885) script.js.Multimedia.Internetverbindung: registered 0 subscriptions and 1 schedule
      2021-08-08 10:47:38.062  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Aktionen
      2021-08-08 10:47:38.066  - info: javascript.0 (20885) script.js.Rolladen.Aktionen: registered 10 subscriptions and 0 schedules
      2021-08-08 10:47:38.066  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Rollade_Anna
      2021-08-08 10:47:38.080  - info: javascript.0 (20885) script.js.Rolladen.Rollade_Anna: registered 0 subscriptions and 1 schedule
      2021-08-08 10:47:38.081  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Schalter_Schlafzimmer
      2021-08-08 10:47:38.094  - info: javascript.0 (20885) script.js.Rolladen.Schalter_Schlafzimmer: registered 4 subscriptions and 0 schedules
      2021-08-08 10:47:38.094  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Sonnenschutz
      2021-08-08 10:47:38.098  - info: javascript.0 (20885) script.js.Rolladen.Sonnenschutz: registered 6 subscriptions and 0 schedules
      2021-08-08 10:47:38.098  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Sonnenschutz_automatisch
      2021-08-08 10:47:38.158  - info: javascript.0 (20885) script.js.Rolladen.Sonnenschutz_automatisch: registered 1 subscription and 6 schedules
      2021-08-08 10:47:38.158  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Variablen
      2021-08-08 10:47:38.186  - info: javascript.0 (20885) script.js.Rolladen.Variablen: registered 0 subscriptions and 3 schedules
      2021-08-08 10:47:38.186  - info: javascript.0 (20885) Start javascript script.js.Rolladen.Zeitsteuerung
      2021-08-08 10:47:38.230  - info: javascript.0 (20885) script.js.Rolladen.Zeitsteuerung: registered 0 subscriptions and 5 schedules
      2021-08-08 10:47:38.231  - info: javascript.0 (20885) Start javascript script.js.Variablen.Frei_&_Urlaub
      2021-08-08 10:47:38.241  - info: javascript.0 (20885) script.js.Variablen.Frei_&_Urlaub: registered 2 subscriptions and 0 schedules
      2021-08-08 10:47:38.242  - info: javascript.0 (20885) Start javascript script.js.Variablen.Variablen
      2021-08-08 10:47:38.245  - info: javascript.0 (20885) script.js.Variablen.Variablen: registered 0 subscriptions and 0 schedules
      2021-08-08 10:47:38.245  - info: javascript.0 (20885) Start javascript script.js.Variablen.Wochenende
      2021-08-08 10:47:38.292  - info: javascript.0 (20885) script.js.Variablen.Wochenende: registered 0 subscriptions and 1 schedule
      2021-08-08 10:47:38.293  - info: javascript.0 (20885) Start javascript script.js.Wetter.Helligkeit
      2021-08-08 10:47:38.296  - info: javascript.0 (20885) script.js.Wetter.Helligkeit: registered 1 subscription and 0 schedules
      2021-08-08 10:47:38.296  - info: javascript.0 (20885) Start javascript script.js.Wetter.IstHeiss
      2021-08-08 10:47:38.313  - info: javascript.0 (20885) script.js.Wetter.IstHeiss: registered 1 subscription and 1 schedule
      2021-08-08 10:47:38.314  - info: javascript.0 (20885) Start javascript script.js.Wetter.IstTrocken
      2021-08-08 10:47:38.320  - info: javascript.0 (20885) script.js.Wetter.IstTrocken: registered 0 subscriptions and 2 schedules
      2021-08-08 10:47:38.320  - info: javascript.0 (20885) Start javascript script.js.Überwachung.Türsensoren
      2021-08-08 10:47:38.324  - info: javascript.0 (20885) script.js.Überwachung.Türsensoren: registered 1 subscription and 0 schedules
      2021-08-08 10:48:40.386  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-08-08 10:48:40.494  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 send kill signal
      2021-08-08 10:48:41.522  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 killing pid 20885
      2021-08-08 10:48:43.756  - info: host.sh-iobroker instance system.adapter.javascript.0 started with pid 22835
      2021-08-08 10:48:45.118  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-08-08 10:48:46.002  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 send kill signal
      2021-08-08 10:48:47.119  - info: host.sh-iobroker stopInstance system.adapter.javascript.0 killing pid 22835
      2021-08-08 10:48:49.723  - warn: host.sh-iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
      2021-08-08 10:48:49.723  - info: host.sh-iobroker instance system.adapter.javascript.0 terminated with code null ()
      2021-08-08 10:48:49.848  - info: host.sh-iobroker instance system.adapter.javascript.0 started with pid 23001
      2021-08-08 10:48:52.861  - debug: javascript.0 (23001) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-08-08 10:48:52.915  - debug: javascript.0 (23001) Objects client ready ... initialize now
      2021-08-08 10:48:52.916  - debug: javascript.0 (23001) Objects create System PubSub Client
      2021-08-08 10:48:52.917  - debug: javascript.0 (23001) Objects create User PubSub Client
      2021-08-08 10:48:52.917  - debug: javascript.0 (23001) Objects client initialize lua scripts
      2021-08-08 10:48:52.961  - debug: javascript.0 (23001) Objects connected to redis: 127.0.0.1:9001
      2021-08-08 10:48:52.969  - debug: javascript.0 (23001) objectDB connected
      2021-08-08 10:48:52.971  - debug: javascript.0 (23001) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-08-08 10:48:52.985  - debug: javascript.0 (23001) States create System PubSub Client
      2021-08-08 10:48:52.986  - debug: javascript.0 (23001) States create User PubSub Client
      2021-08-08 10:48:53.008  - debug: javascript.0 (23001) States connected to redis: 127.0.0.1:9000
      2021-08-08 10:48:53.009  - debug: javascript.0 (23001) statesDB connected
      2021-08-08 10:48:53.624  - debug: javascript.0 (23001) Plugin sentry Initialize Plugin (enabled=true)
      2021-08-08 10:48:54.306  - info: javascript.0 (23001) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.2, js-controller: 3.3.15
      2021-08-08 10:48:54.455  - debug: javascript.0 (23001) Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/base.d.ts","node_modules/@types/node/ts3.6/base.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts","node_modules/@types/node/wasi.d.ts"]
      2021-08-08 10:48:54.497  - debug: javascript.0 (23001) Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
      2021-08-08 10:48:54.498  - info: javascript.0 (23001) requesting all states
      2021-08-08 10:48:54.499  - info: javascript.0 (23001) requesting all objects
      2021-08-08 10:48:57.410  - info: javascript.0 (23001) received all objects
      2021-08-08 10:48:57.610  - info: javascript.0 (23001) received all states
      2021-08-08 10:49:07.263  - info: javascript.0 (23001) Start javascript script.js.Beleuchtung.Außen.Bewegungsmelder
      2021-08-08 10:49:07.360  - error: javascript.0 (23001) The Pattern for "getForeignStates" needs to be an Array or an String. object provided.
      2021-08-08 10:49:07.364  - info: javascript.0 (23001) script.js.Beleuchtung.Außen.Bewegungsmelder: registered 3 subscriptions and 1 schedule
      2021-08-08 10:49:07.364  - info: javascript.0 (23001) Start javascript script.js.Beleuchtung.Außen.Haustür
      2021-08-08 10:49:07.388  - info: javascript.0 (23001) script.js.Beleuchtung.Außen.Haustür: registered 0 subscriptions and 2 schedules
      2021-08-08 10:49:07.388  - info: javascript.0 (23001) Start javascript script.js.Beleuchtung.Innen.Flur_EG
      2021-08-08 10:49:07.391  - error: javascript.0 (23001) The Pattern for "getForeignStates" needs to be an Array or an String. object provided.
      2021-08-08 10:49:07.392  - info: javascript.0 (23001) script.js.Beleuchtung.Innen.Flur_EG: registered 1 subscription and 0 schedules
      2021-08-08 10:49:07.392  - info: javascript.0 (23001) Start javascript script.js.Beleuchtung.Weihnachten.Außen
      2021-08-08 10:49:07.395  - info: javascript.0 (23001) script.js.Beleuchtung.Weihnachten.Außen: registered 0 subscriptions and 2 schedules
      2021-08-08 10:49:07.407  - info: javascript.0 (23001) Start javascript script.js.Beleuchtung.Weihnachten.Innen_Wohnzimmer
      2021-08-08 10:49:07.456  - info: javascript.0 (23001) script.js.Beleuchtung.Weihnachten.Innen_Wohnzimmer: registered 0 subscriptions and 4 schedules
      2021-08-08 10:49:07.457  - info: javascript.0 (23001) Start javascript script.js.Belüftung.Belüftungsstärke
      2021-08-08 10:49:07.477  - info: javascript.0 (23001) script.js.Belüftung.Belüftungsstärke: registered 1 subscription and 0 schedules
      2021-08-08 10:49:07.477  - info: javascript.0 (23001) Start javascript script.js.Belüftung.Zeitsteuerung
      2021-08-08 10:49:07.480  - error: javascript.0 (23001) The Pattern for "getForeignStates" needs to be an Array or an String.
      #109
      @dennis-fabri sagte in Admin v5 jetzt im STABLE!:
      Hast Du mehr log? An sich heisst diese Zeile das die Instanz von dir bzw vom controller gestoppt wurde ... also für mich ist das log erstmal ok ... Um mehr abzuleiten braucht es mehr log. gf einen RestartSchedule gesetzt aus versehen oder so?
      Auch hier: Problem hat mit den Updates augenscheinlich nichts zu tun und ist irgendwas spezielles bei dir
        tklein
        schrieb am zuletzt editiert von tklein
        #110
        --- gelöst----
        wie lange kann ein Admin Update von 4.2.2 auf 5.1.23 dauern? Bei mir habe ich den Spinner seit ca 80 min. :-(
        JS-Controller ist 3.2.16 auf einem Raspi 4 mit Linux (Linux raspberrypi-iob 5.10.17-v7l+ #1421 SMP Thu May 27 14:00:13 BST 2021 armv7l GNU/Linux)
        Was kann ich machen?
        • T tklein
          --- gelöst----
          #111
          @tklein
          iobroker logs --watch
          iobroker stop
          iobroker update
          iobroker upgrade
            @tklein
            iobroker stop
            iobroker update
            iobroker upgrade
            tklein
            #112
            @thomas-braun thx, mit einem neuen tab konnte ich die oberflächge aufrufen.
            • apollon77A apollon77
              nach längerer Entwicklungszeit freuen wir (bzw. vor allem Bluefox natürlich als Haupt-Entwickler) uns Euch die neue Admin Oberfläche vorstellen zu können. Das Stable Repository wird gerade aktualisiert und damit sollte das Update bei allen im Laufe des Abends auftauchen.
              Die Oberfläche ist ein kompletter Neubau und es ist vieles neu (und garantiert für den einen oder anderen gewöhnungsbedürftig), aber auch viel moderner, aufgeräumter und auf Tablets besser bedienbar!
              Wichtig
              Admin5 benötigt mindestens den js-controller 3.2.16.
              Nach der Installation von Admin v5 bitte in Jedem Fall den Browser mit "Shift-Reload" neu laden, da sich sehr viel geändert hat. Es kann sonst zu Fehler kommen.
              Weitere Dinge die idealerweise vor der Installation zu beachten sind folgen weiter unten in diesem Post.
              Feature-Changelog
              • File editor: The new "Files" page in Admin allows you to view and manage the Files stored in the ioBroker storage. You can parse, upload, download and delete Files and Directories. Best use "User Files" for your own assets to use in visualizations.
              • News: Adapter news and information, that were shown by Info Adapter in Admin 4, are now directly integrated into Admin 5
              • Notifications: View and Manage Notifications collected by the ioBroker System if issues like Filesystem errors or low Memory conditions are detected. Allows you to view details of the notifications and the reasons and to acknowledge them once you handled them properly.
              • History entries edit: Allow to manipulate and delete historical data logged by adapters like sql, history or influxdb (if the adapter supports it, only sql for now)
              • Edit Compact-Mode/Tiers/Sentry/Memory limits for instances: Some new settings for Adapter instances that were introduced since js-controller 3.0 are shown and can be changed in Admin now
              • Sort pages/tabs: The pages/tabs on left side can be sorted now via drag&drop
              • Add Camera Tiles in Intro: On the Intro page now also a Camera Image/Stream Tile can be configured and is shown. (Image needs to be unprotected or normal basic auth protected)
              • Host base settings Editor: The settings from iobroker.json from all hosts are now available in an own Editor and can be adjusted there instead of editing the JSON file. On save the js-controller of that host is restarted.
              • New Installation wizard: The Installation wizard on first installation was enhanced to include password and authentication (coming) configuration to allow a more secure initial setup.
              • Rating of adapters: Users can now rate the adapters they use with up to 5 stars and also for each adapter version to give the developer feedback if the version works as expected.
              • More Transparent adapter update: When an Adapter update is available the Admin shows the relevant part of the changelog for review by the user before installing the version. Also pot failing dependencies to other adapters are shown there if relevant.
              • Adapter updates can be ignored/skipped: The new Update dialog also contains the option to ignore a certain update. Admin will then no longer offer it. A manual update via CLI is still possible.
              • Update of selected adapters: When selecting to update multiple adapters the user can choose which adapters he wants to update.
              • Tile view of instances: Instances screen now also have a tile view
              • Changed expert mode behavior: The export mode should not be needed for most users and when activated is only active for the current browser session. If needed to be active forever for Developers or real Pro's that know what they are doing this can be done in Admin settings.
              • Object creation enforces clean structures: To prevent issues Admin5 is now enforcing object structures to be correct. Please create folder objects when you create own states.
              For Developers
              • JsonConfig/JsonCustom: Added an easier way to create adapter configurations by creating a JSON configuration only. The adapter configuration page will be build out of this JSON automatically.
              • Custom attributes in object view: Adapters can now define additional data columns from the adapter objects. These data columns will then be available in the Objects view in Admin and can be enabled.
              Was ist vor der Installation zu beachten
              • Bitte alle Adapter aktualisieren, welche im Changelog beinhalten das Sie für Admin 5 optimiert wurden. Hier funktionieren die Adapter vollständig, es kann nur ggf zu Problemen kommen wenn man Adapter oder Datenpunkte konfigurieren will!
              • Dies betrifft vor allem alle Adapter die Eigene Objekt-Einstellungen unterstützen
                • history
                • influxdb
                • sql
                • lovelace
                • mqtt-client
                • telegram
                • homee
                • iogo
                • minmax
                • sourceanalytix
                • statistics
                • upnp
                • iqontrol - nötige Version (mind. 1.7.3) noch nicht im Stable, ggf auf alte Oberfläche zurückschalten
                • linkeddevices - nötige Version nich nicht verfügbar, ggf auf alte Oberfläche zurückschalten
                • valuetrackingovertime - nötige Version nich nicht verfügbar, ggf auf alte Oberfläche zurückschalten
                • virtualpowermeter - nötige Version nich nicht verfügbar, ggf auf alte Oberfläche zurückschalten
              • Weiterhin benötgien die folgenden Adapter mit den neuesten Versionen Admin 5 als Vorbedingung:
                • JavaScript 5.2.x+
                • s7 1.3.x+
                • web 3.4.7+
                • devices 1.0.x+
                • material 1.0.x+
              Auf die "alte" Oberfläche zurückschalten
              Leider gibt es 4 Adapter, die EIgene Objekt-EIsntellungen unterstützenm die bisher nmoch nicht angepasst im Stable verfügbar sind. Wer daher, z.B. wegen linkeddevices oder iqontrol, kurz auf die alte Oberfläche zurückschalten möchte, kann dies am einfachsten über eine zweite Admin Instanz (auf anderem Port) machen. In den Einstellungen der Admin-Instanz aktiviert man die Einstellung "Alte Benutzeroberfläche". Dann Speichern und Admin wird neu gestartet. Dann im Browser mit "Shift-Reload" die Admin-Seite neu laden und die alte Oberfläche erscheint.
              Wie auf Alte Version 4.2.2 zurück?
              Falls gar nichts mehr mit Admin geht kann mittels iobroker upgrade admin@4.2.2, ausgeführt im ioBroker-Verzeichnis (also /opt/iobroker) ein Downgrade gemacht werden
              Wie Fehler melden?
              Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
              Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Browser-Fehlerkonsole endet, dann dazu am besten direkt ein GitHub-Issue im Admin Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben. Auch gern mit Screenshots arbeiten und diese markieren.
              Ingo
              #113
              @tklein sagte in Admin v5 jetzt im STABLE!:
              das entspricht dann dem:
              @apollon77 sagte in Admin v5 jetzt im STABLE!:
                tklein
                #114
                @homoran ja.
                Hatte ich auch gelesen. Dachte aber, dass es nach dem erfolgreichen Update erfolgen müsste. :-)
                • T tklein
                  @homoran ja.
                  #115
                  genau das war ja dein Zustand ;-)
                    @fa-bio Also an sich sollte das im Browser such über sessions hinweg gespeichert werden - oder arbeitest DU inkognitor oder so?
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    #116
                    @apollon77 hallo nein appollon77 ich habe nur eine Erweiterung im Chrome die heißt die click and clean evtl. macht die alles platt. 😕
                    Iobroker:
                    • Matter over Thread Hilfe
                    nieIPN 1 Antwort Letzte Antwort
                    • FabioF Fabio
                      nieIPN Offline
                      nieIPN Offline
                      nieIP
                      #117
                      Ich bin auf der Suche nach dem Menupunkt im Admin, wo ich "in Echtzeit" die eingehenden Daten von den Adaptern sehen kann und in der obersten Zeile dann ggf. auch Filter eintrage um nur bestimmte Adapter zu beobachten. Im alten Admin hiess das IMHO "Ereignisse" (kann ich jetzt nicht mehr nachsehen)
                      Wo finde ich diese Ansicht jetzt?
                      ChaotC HomoranH apollon77A 3 Antworten Letzte Antwort
                      • nieIPN nieIP
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        #118
                        @nieip sagte in Admin v5 jetzt im STABLE!:
                        Protokolle?
                        crunchipC HomoranH 2 Antworten Letzte Antwort
                        • nieIPN nieIP
                          #119
                          im alten Admin hiess das IMHO "Ereignisse"
                          korrekt
                          doch!
                          wenn du im Admin die React Oberfläche ausschaltest (Instanz - konfigurieren) hast du nach einem Browser-Refresh wieder die alte Oberfläche
                          • ChaotC Chaot
                            Protokolle?
                            crunchipC Offline
                            crunchipC Offline
                            #120
                            @chaot nein, es gab nen Tab Ereignisse, dieser wurde glaub ich, entfernt
                            • ChaotC Chaot
                              Protokolle?
                              #121
                              @chaot sagte in Admin v5 jetzt im STABLE!:
                              Protokolle?
                              nee - ich suche gerade
                              Kaffeesatzleserei:
                              ich könnte mir vorstellen, dass diese Option nicht mehr existiert, weil si doch auch ganz schnell den rechner lahmlegen kann, wenn man nicht filtert
                              nieIPN 2 Antworten Letzte Antwort
                                Protokolle?
                                Kaffeesatzleserei:
                                nieIPN Offline
                                nieIPN Offline
                                nieIP
                                #122
                                @homoran sagte in Admin v5 jetzt im STABLE!:
                                schade.
                                In den Einstellungen für die Datenaufzeichnung bekomme ich auf der Karte "Verlaufsdaten" eine Fehlermeldung bei den Zeitbereichen "diese Woche" und "diese 2 Wochen". Die Startzeit wird nicht aktualisiert.
                                • GoerschG Offline
                                  GoerschG Offline
                                  Goersch
                                  schrieb am zuletzt editiert von Goersch
                                  #123
                                  bin auch gerade auf 5.1.23.
                                  Kleines Problem: auf iPAD (14.7.1) mit Safari wird die Admin-Oberfläche nicht angezeigt (iBroker Symbol dreht fröhlich vor sich hin). Webseitendaten habe ich gelöscht & iPAD neu gestartet - hilft nix.
                                  Unter Windows 10 / Firefox alles OK.
                                  Gruss
                                  Georg
                                  PS.: Mit dem Web-Server bin auf 3.4.7
                                  HomoranH A 2 Antworten Letzte Antwort
                                  • GoerschG Goersch
                                    Gruss
                                    Georg
                                    #124
                                    @goersch sagte in Admin v5 jetzt im STABLE!:
                                    https????
                                    Wenn ja, bist du jetzt mindestens der vierte.
                                    Die Apfelbäcker sehen da wohl etwas als zu unsicher an
                                    GoerschG 2 Antworten Letzte Antwort
                                      https????
                                      GoerschG Offline
                                      GoerschG Offline
                                      Goersch
                                      #125
                                      @homoran : ja, https (of course)
                                        Protokolle?
                                        Kaffeesatzleserei:
                                        nieIPN Offline
                                        nieIPN Offline
                                        nieIP
                                        #126
                                        Ich bin im Bereich "Objekte" und benutze die Filter in der obersten Zeile.
                                        Nicht zutreffende Einträge werden abgedunkelt. Dann muss ich ewig nach unten scrollen um Suchergebniss zu finden.
                                        Wenn ich ein Objekt anklicke und dann die Einstellungen des Objetes oder die History Speicher Einstellungen verändere (egal was, Haupsache ein mal "Speichern"), dann sind danach nur noch die Objekte sichtbar, auf die der Filter zutrifft. Im alten Admin wurden die nicht zutreffenden Objekte sofort ausgeblendet.
                                        HomoranH crunchipC 2 Antworten Letzte Antwort
                                          https????
                                          GoerschG Offline
                                          GoerschG Offline
                                          Goersch
                                          #127
                                          @homoran : Mit http auch auf iPAD OK
