  4. Test Adapter BMW/Mini v4.x.x
    6.6k
1.1k Beiträge 103 Kommentatoren 376.3k Aufrufe 89 Beobachtet
  • L lessthanmore
    @tombox
    bmw.0
    2021-08-04 17:21:44.595	error	Start relogin in 1min
    bmw.0
    2021-08-04 17:21:44.595	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
    bmw.0
    2021-08-04 17:21:44.595	error	Error: Request failed with status code 400
    bmw.0
    2021-08-04 17:21:44.595	error	refresh token failed
    bmw.0
    2021-08-04 17:21:14.425	info	lastTrip receive 401 error. Refresh Token in 30 seconds
    bmw.0
    2021-08-04 17:21:14.419	info	status receive 401 error. Refresh Token in 30 seconds
    bmw.0
    2021-08-04 17:21:14.389	info	serviceExecutionHistory receive 401 error. Refresh Token in 30 seconds
    bmw.0
    2021-08-04 17:21:14.387	info	chargingprofile receive 401 error. Refresh Token in 30 seconds
    bmw.0
    2021-08-04 17:21:14.384	info	allTrips receive 401 error. Refresh Token in 30 seconds
    bmw.0
    2021-08-04 16:56:22.331	error	Error: Request failed with status code 404
    tombox
    @lessthanmore Hatte ich vorhin auch. Ich würde es zur Zeit auf BMW schieben. Sonst sollte der token refresh jede Stunde ohne Problem laufen. Die Meldung kann aber auch auftreten wenn man sich parallel in den account einloggt
    L 1 Antwort Letzte Antwort
    • L lessthanmore
      @tombox
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      lobomauL Offline
      lobomauL Offline
      lobomau
      @tombox manchmal kam nochmal folgender Fehler. Bin up-to-date gewesen.
      2021-08-04 17:12:03.909 - error: bmw.0 (4322) refresh token failed
      2021-08-04 17:12:03.910 - error: bmw.0 (4322) Error: Request failed with status code 400
      2021-08-04 17:12:03.910 - error: bmw.0 (4322) {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
      2021-08-04 17:12:03.911 - error: bmw.0 (4322) Start relogin in 1min
      @lessthanmore sagte in Test Adapter BMW v2.0.0:
      Ja, habe es gemerkt. Die App geht momentan auch nicht sauber.
      Ich bin jetzt mal wieder zurück zum Script, da mir im Adapter die verbleibende Ladezeit als DP fehlt. Oder hab ich die übersehen?
      /edit: Heute ist nicht mein Tag. Hab die DP gefunden^^
      Die verbleibende Zeit hatte ich zuerst auch gesucht. Die wird scheinbar erst angelegt wenn man das erste Mal lädt.
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • T tombox
        lessthanmore
        @tombox Also bis jetzt kommt es pünktlich jede Stunde.
        • L lessthanmore
          tombox
          @lessthanmore @lobomau
          War noch ein Fehler bei mir nach Neuinstallation sollte es jetzt passen. Danke für euer Feedback
          • H HoTi
            @tombox
            Kann ich leider erst morgen Testen. Aber ist mit dem Adapter dann möglich mehrere Autos aus zu lesen? Ich habe ein 5er der geht immer aber unter diesem Account ist auch mein MINI SE der wäre mir noch fast wichtiger aber den habe ich noch nicht geschafft auszulesen.
            tombox
            @hoti Hast du schon checken können wie es mit mehreren Fahrzeugen im Account ist?
            • T tombox
              lessthanmore
              schrieb am zuletzt editiert von lessthanmore
              @tombox Kannst du bitte mal prüfen, ob du im Adapter die verbleibende Ladezeit auf 0 setzen kannst, sobald der Akku vollständig geladen (mit Script funktioniert das).
              Momentan bleibt die Ladezeit beim letzten Wert "stehen" und wird nachdem der Akku voll ist nicht wieder aktualisiert (bei mir im Beispiel gerade 6 Minuten).
              DP:
              bmw.0.WBxxx.status.chargingTimeRemaining
              Also wenn
              bmw.0.WBxxx.status.chargingStatus
              ist gleich "FINISHED_FULLY_CHARGED", dann 0.
              Oder macht das gar keinen Sinn was ich hier schreibe? :-D
              lobomauL T 2 Antworten Letzte Antwort
              • L lessthanmore
                DP:
                Also wenn
                lobomauL Offline
                lobomauL Offline
                lobomau
                @lessthanmore doch, macht Sinn. Meiner Meinung nach soll nur ein Wert bei chargingTimeRemaining angezeigt werden, wenn chargingStatus = CHARGING ist, also nicht nur wenn vollgeladen diesen nicht mehr anzeigen. Ich hatte gesehen, dass eine Zeit angezeigt wurde obwohl gerade nicht mehr geladen wurde.
                Ich lade selten ganz voll, deswegen weiß ich gar nicht was dann passiert.
                • Slave: Pi4
                • lobomauL lobomau
                  lessthanmore
                  @lobomau Hab "nur" einen PHEV, aber wie gesagt, die Zeit bleibt auf dem letzten Wert bevor er dann aktualisiert auf "vollständig geladen".
                  Im Script von Strobelix geht die Zeit dann auf 0 min.
                  • L lessthanmore
                    tombox
                    @lessthanmore kann ich noch anpassen ist aber eigentlich eine Fehler bmw
                    • T tombox
                      lessthanmore
                      @tombox Nur wenn es keine Umstände macht. Alternativ würde ich das sonst uber zusätzliche DP und ein Blockly machen so wie ich es momentan auch schon für die Übersetzung mache.
                      • L lessthanmore
                        DP:
                        Also wenn
                        tombox
                        @lessthanmore Ich habe mal die Zeile eingefügt bin mir aber nicht sicher ob es immer wieder durch bmw überschrieben wird muss du mal neuinstallieren und schauen wie es sich verhält
                        lobomauL 2 Antworten Letzte Antwort
                        • T tombox
                          lobomauL Offline
                          lobomauL Offline
                          lobomau
                          @tombox Update hab ich eingespielt. Muss ich morgen mal beobachten wie es sich beim und nach dem Laden verhält. Nur durch Update ändert sich der Wert erstmal nicht (hier 0,3 Std.)
                          Aber Wert lässt manuell auf Null setzen. Also mit einem Script wie @lessthanmore schrieb würde auch gehen.
                          • Slave: Pi4
                          • lobomauL lobomau
                            tombox
                            @lobomau wenn ich den screen sehe ist mir noch was aufgefallen. installier nochmal und probier nochmal
                            • T tombox
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              @tombox kann ich machen. Aber Wert habe ich eben schon manuell auf Null gesetzt. Kann erst aktiv morgen testen.
                              • Slave: Pi4
                              • T tombox
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                @tombox hab ich gemacht. Muss ich wahrscheinlich den alten Datenpunkt löschen? Hat der neue einen neuen Namen? Der wird bestimmt erst angelegt wenn man lädt!?
                                bmw.0
                                2021-08-05 21:48:13.600	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:13.599	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:10.364	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:10.363	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:07.340	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:07.339	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                bmw.0
                                2021-08-05 21:48:04.468	warn	State "bmw.0.info.status.chargingTimeRemaining" has no existing object, this might lead to an error in future versions
                                • Slave: Pi4
                                • lobomauL lobomau
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  bmw.0
                                  tombox
                                  @lobomau komisch das er nicht bei dir ist erstelle ihn jetzt vorher
                                  • T tombox
                                    lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    @tombox ich lösche den Adapter nochmal und installiere neu. Meine CPU ist um 20% gestiegen und alle träge. Die Meldungen im log machen ihm zu schaffen...
                                    • Slave: Pi4
                                    • lobomauL lobomau
                                      tombox
                                      @lobomau Bitte nochmal updaten
                                      • L Offline
                                        lessthanmore
                                        Also bei mir sieht es jetzt gut aus. DP ist bereits vorhanden. Kann aber erst morgen prüfen, wie es sich während und nach dem Laden verhält.
                                        Hab ich jetzt zu früh das Update installiert bzw. noch eine "alte" Version?
                                        • L lessthanmore
                                          tombox
                                          @lessthanmore Lieber nochmal installieren sonst ist die cpu last zu hoch
