  4. Serialport error bei Adapter updates
    6.7k
39 Beiträge 7 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    an einem meiner Slaves bekomme ich bei jedem Adapter update diese Serialport error:
    In file included from ../src/./serialport.h:6,
    from ../src/serialport.cpp:1:../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’ v8::String::Utf8Value path(info[0]->ToString()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:2810:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’ V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:2810:44: note: candidate expects 1 argument, 0 provided../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’ v8::Local<v8::Object> options = info[1]->ToObject(); ^
    In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:2822:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’ V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject( ^~~~~~~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:2822:44: note: candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(2, argv); ^In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here Call(int argc, v8::Local<v8::Value> argv[]) const { ^~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’ v8::Local<v8::Object> options = info[1]->ToObject(); ^
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(1, argv); ^
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(1, argv); ^In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here Call(int argc, v8::Local<v8::Value> argv[]) const { ^~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(1, argv); ^In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here Call(int argc, v8::Local<v8::Value> argv[]) const { ^~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’ v8::Local<v8::Object> options = info[1]->ToObject(); ^
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(1, argv); ^
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts)); ^In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate expects 3 arguments, 2 provided
    ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr)); ^In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate expects 3 arguments, 2 provided
    ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd)); ^In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate expects 3 arguments, 2 provided../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(2, argv); ^In file included from ../src/./serialport.h:6,
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’ results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate)); ^In file included from /home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:67, from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3670:37: note: candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/v8.h:3673:37: note: candidate expects 3 arguments, 2 provided../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(2, argv); ^In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations] data->callback.Call(1, argv); ^In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../../nan/nan.h:1740:3: note: declared here Call(int argc, v8::Local<v8::Value> argv[]) const { ^~~~
    ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void void init(v8::Handle<v8::Object> target) { ^~~~~~../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’../src/serialport.cpp:460:17: note: suggested alternative: ‘JobHandle’ void init(v8::Handle<v8::Object> target) { ^~~~~~ JobHandle../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token void init(v8::Handle<v8::Object> target) { ^../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope void init(v8::Handle<v8::Object> target) { ^~~~~~
    ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
    void init(v8::Handle<v8::Object> target) { ^~~~~~ tzsetIn file included from ../../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope NODE_MODULE(serialport, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.1/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
    ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
    make: *** [serialport.target.mk:112: Release/obj.target/serialport/src/serialport.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:375:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
    gyp ERR! System Linux 5.10.17-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/smartmeter-obis/node_modules/serialportgyp ERR! node -v v14.17.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    Jemand ne Idee wie ich die ohne neu installation weg bekomme? Serial Port wird für Smartmeter Adapter und Modbus benötigt. Habe ich auf anderen Slaves auch laufen aber ohne diese Meldungen bei Adapter updates.
    Danke und Gruß
    • wendy2702W wendy2702
      Danke und Gruß
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @wendy2702
      Welche Versionen von Nodejs, serial Port und den betroffenen Adaptern hast du auf dem Slave installiert ?
      A.
      wendy2702W 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        @wendy2702
        A.
        wendy2702W Offline
        wendy2702W Offline
        @asgothian schaue ich nach wenn ich wieder am Rechner bin.
          @wendy2702
          A.
          wendy2702W Offline
          wendy2702W Offline
          @asgothian sagte in Serialport error bei Adapter updates:
          @wendy2702
          A.
          Modbus 3.3.1
          Smartmeter 3.2.1
          Node 14.17.1
          Serialport 9.0.6
          • Thomas BraunT Online
            @wendy2702
            cd /opt/iobroker
            npm list serialport
              @wendy2702
              cd /opt/iobroker
              npm list serialport
              wendy2702W Offline
              wendy2702W Offline
              @thomas-braun sagte in Serialport error bei Adapter updates:
              npm list serialport
              pi@pi-iobroker:/opt/iobroker $ npm list serialport
              iobroker.core@0.1.0 /opt/iobroker
              ├─┬ iobroker.modbus@3.3.1
              │ └── serialport@9.0.7
              ├─┬ iobroker.smartmeter@3.2.1
              │ ├── serialport@9.0.7
              │ └─┬ smartmeter-obis@2.3.0
              │   └── serialport@9.0.7  deduped
              └── serialport@9.0.6
              Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                npm list serialport
                @wendy2702
                Schaut bei mir ganz anders aus.
                echad@chet:/opt/iobroker $ npm list serialport
                iobroker.inst@3.0.0 /opt/iobroker
                └─┬ iobroker.zigbee@1.5.6
                  ├─┬ zigbee-herdsman-converters@14.0.162
                  │ └─┬ zigbee-herdsman@0.13.107
                  │   └── serialport@9.0.6
                  └─┬ zigbee-herdsman@0.13.110
                  npm list serialport
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @wendy2702 bist du sicher da diese auf dem Slave liegen ?
                  Die Versionen sollten kompatibel sein.
                  A.
                    @wendy2702
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @thomas-braun sieht doch genau so aus.. nur das @wendy2702 noch ein oberpaket hat..
                    @wendy2702
                    zuerst aber das vom @Asgothian checken.. dass muss natürlich auf dem richtigen host liegen.. das passiert aber meistens wenn man eine instanz zum anderen host rüber schiebt.. dann bleibt eine alte version des serialports auf dem anderen host da und diese stört meistens
                    npm cache clean --force
                    sudo -H -u iobroker  npm cache clean --force
                    sollte es dan nimmer noch mucken.. lösche den aus dem hauptordner
                    rm -r /opt/iobroker/node-modules/serialport
                      wendy2702W Offline
                      Guten Morgen zusammen und Danke für eure Antworten.
                      @Asgothian @arteck : da ich die Abfrage auif dem PI gemacht habe gehe ich davon aus das die auch dort installiert sind.
                      So sieht es auf dem Master aus:
                      mirko@iobroker:/opt/iobroker$ npm list serialport
                      iobroker.inst@2.0.3 /opt/iobroker
                      `-- iobroker.modbus@3.4.7
                        `-- serialport@9.2.0
                      So auf dem zweiten Slave:
                      pi@iobroker-garage-gross:/opt/iobroker $ npm list serialport
                      ├─┬ iobroker.javascript@5.2.7
                      │ └── UNMET DEPENDENCY serialport@^9.2.0
                      └─┬ iobroker.modbus@3.3.1
                      npm ERR! missing: serialport@^9.2.0, required by iobroker.javascript@5.2.7
                      Welcher wie ich gerade sehe auch ein Problem hat welches sich aber bisher noch nicht negativ ausgewirkt hat. Muss ich im Anschluß bearbeiten.
                      • arteckA arteck
                        @wendy2702
                        wendy2702W Offline
                        wendy2702W Offline
                        @arteck sagte in Serialport error bei Adapter updates:
                        @wendy2702
                        Cache clean hat keine Verbesserung gebracht. Dann habe ich das serialport paket mal gelöscht und wenn ich jetzt ein List mache sieht es so aus:
                        ├─┬ iobroker.modbus@3.4.9
                        │ └── serialport@9.2.0
                        └── UNMET DEPENDENCY serialport@^9.0.6
                        npm ERR! missing: serialport@^9.0.6, required by iobroker.core@0.1.0
                        arteckA Thomas BraunT 2 Antworten Letzte Antwort
                          @wendy2702
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @wendy2702 kurz und knapp...
                          es MUSS asf allen Maschienen die gleiche Version installiert sein..
                          die iobroker.modbus installation ist auch nicht gleich.. da gibts auch schon unterschiede...
                          ziehe es bitte komplett auf die gleiche version...
                          am besten direkt aus dem REPO https://github.com/ioBroker/ioBroker.modbus
                          du kannst die nicht gebrauchte instanzen auf dem jeweiligen Host auch löschen... die werden dann nur auf dem Host gelöscht
                            @wendy2702
                            @wendy2702 sagte in Serialport error bei Adapter updates:
                            Mich irritiert
                            als Wurzelverzeichnis.
                            Ich kenne das eigentlich nur in dieser Form:
                            Vermutlich eine sehr alte Installation?
                            • arteckA arteck
                              wendy2702W Offline
                              wendy2702W Offline
                              @arteck Hi,
                              seit wann müssen die gleich sein? Das läuft so schon seit ca. 2017/2018 und die Seriaport Probleme sind erst seit einem der letzten Upgrades gekommen. Weiss nicht ob es iobroker, Node oder Linux upgrade war.
                              Modbus ist nur unterschiedlich weil ich den als einzigen an dem "fehlerhaften" Slave noch upgraden konnte. Die waren vorher alle gleicht.
                              @Thomas-Braun Ja, installation ist wie geschrieben von ca. 2017/2018
                              Denke ich werde den mal neu aufsetzen und versuchen ein Backup zu restoren oder für die paar Adapter die Einstellungen manuell vornehmen.
                              Eine Frage zum Backup restore. Das Backup beinhaltet ja informationen aller drei System (1x Master, 2x Slave). Wie gehe ich also richtiger weise vor?
                              Pi neu installieren und wieder als Slave einbinden, dann auf den Slave das Backup File kopieren und restore?
                              oder
                              Pi neu installieren, Backup File kopieren, restore und er ist danach automatisch ein Slave?
                              oder wie ist der richtige weg?
                                @arteck Hi,
                                oder
                                arteckA Offline
                                arteckA Offline
                                arteck
                                wozu die Arbeit ??? aktualisere bzw. ziehe die vorhandene Installationen richtig glatt..
                                fertig
                                aber musst du wissen
                                • arteckA arteck
                                  fertig
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  So, alle 3 Rechner mit
                                  sudo apt update
                                  sudo apt upgrade
                                  iobroker update
                                  iobroker upgrade
                                  aktualisiert.
                                  Master:
                                  npm list serialport
                                  `-- iobroker.modbus@3.4.9
                                  Slave 1:
                                  └─┬ iobroker.modbus@3.4.9
                                    └── serialport@9.2.0  deduped
                                  Slave 2:
                                  npm list serialport
                                  Kann mir jetzt noch jemand sagen wie ich das auf Slave 2 korrigieren kann ?
                                    sudo apt update
                                    sudo apt upgrade
                                    iobroker update
                                    iobroker upgrade
                                    aktualisiert.
                                    Master:
                                    npm list serialport
                                    Slave 1:
                                    Slave 2:
                                    npm list serialport
                                    iobroker.core@0.1.0
                                    Vermutlich am nachhaltigsten, wenn da von iobroker.core@0.1.0
                                    auf iobroker.inst umgestellt wird. Ich habe aber keinen Schimmer wie man das am besten anfängt.
                                      eventuell @AlCalzone
                                      ich habe mal auf github nachgesehen
                                      https://github.com/ioBroker/adapter-core/blob/master/package.json
                                      und keine dep gefunden für serialport
                                      helfen könnte noch:
                                      npm cache clean
                                      oder package-lock json löschen
                                      fragt mich bitte nicht wie
                                        wendy2702W Offline
                                        npm cache clean schon auf allen drei Systemen laufen lassen. Leider keine Änderung.
                                        Vielleicht hat @AlCalzone oder @apollon77 noch eine Idee.
                                        Danke für eure bisherige Unterstützung.
                                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                          @wendy2702
                                          Vielleicht per
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.js-controller
                                          versuchen.
                                          Zuvor den Master/Slave-Verbund auflösen und danach wieder einrichten?
                                          HomoranH wendy2702W 2 Antworten Letzte Antwort
