  4. Adapter WM-Bus / Kampstrup Multical 21
    6.4k
153 Beiträge 12 Kommentatoren 32.4k Aufrufe 13 Beobachtet
  • W WolfgangFB
    @wolfgangfb
    Nach diversen Neustarts läuft der IO-Broker (zum Glück) wieder).
    Was mich stutzig macht ist:
    pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ mosquitto
    1626002431: mosquitto version 2.0.11 starting
    1626002431: Using default config.
    1626002431: Starting in local only mode. Connections will only be possible from clients running on this machine.
    1626002431: Create a configuration file which defines a listener to allow remote access.
    1626002431: For more details see https://mosquitto.org/documentation/authentication-methods/
    1626002431: Opening ipv4 listen socket on port 1883.
    1626002431: Error: Address already in use
    1626002431: Opening ipv6 listen socket on port 1883.
    Das klingt für mich als ob ein anderer Dienst auf dem gleichen Rechner auf Port 1883 etwas macht.
    pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ netstat -a | grep 1883
    tcp        0      0 localhost:1883          0.0.0.0:*               LISTEN
    tcp6       0      0 localhost:1883          [::]:*                  LISTEN
    außerdem sieht für mich
    sudo systemctl start wmbusmeters
    more /var/log/wmbusmeters/wmbusmeters.log
    [2021-07-11_13:27:40] Started config im871a[00100776] on /dev/ttyUSB0 listening on none
    (im871a) on /dev/ttyUSB0
    (serial) EVENT thread interrupted
    (im871a) get config
    (im871a) got device id 00000000
    [2021-07-11_13:27:51] Not the expected dongle (dongle said 00000000, you said 00100776!
    (wmbus) deleted im871a
    No wmbus device detected, waiting for a device to be plugged in.
    (shell) exec (capture output) "/bin/pidof"
    (shell) arg "wmbusmetersd"
    (shell) output: >>>5672
    (shell) return code 0
    (shell) 5728 exited
    (shell) arg "wmbusmeters"
    (shell) output: >>><<<
    (shell) return code 1
    (shell) 5729 exited
    (serial) registered regular callback HOT_PLUG_DETECTOR(0) every 2 seconds
    (wmbusmeters) waiting for telegrams
    (serial) waiting for stop
    (serial) TIMER thread interrupted
    [2021-07-11_13:27:53] (memory) rss 2924544 peak 2.78 MiB
    (lookup) with file "/dev/ttyUSB0"
    [2021-07-11_13:28:37] Expected im871a on /dev/ttyUSB0 but found unknown instead, ignoring it!
    (verbose) ignoring device auto
    nicht gut aus. (ich verstehe das so, dass der Dongle garnicht erkannt wird)
    matze-dev
    @wolfgangfb Hallo Wolfgang, in der Tat, da sieht nicht so gut aus. Was sagt das Logfile, in das die Werte geschrieben werden? "cat /var/log/wmbusmeters/wmbusmeters.log" - sind die Werte darin OK?
    W 1 Antwort Letzte Antwort
    • M matze-dev
      W Offline
      W Offline
      WolfgangFB
      @matze-dev
      (Ab dem Zeitpunkt, wo der wmbusmaster neu gestartet worden ist)
      (im871a) get config
      (shell) 5728 exited
      (shell) 5729 exited
      • W WolfgangFB
        @matze-dev
        (im871a) get config
        (shell) 5728 exited
        (shell) 5729 exited
        W Offline
        W Offline
        WolfgangFB
        @wolfgangfb
        Ich dachte ich probiere das ganze nochmal parallel auf einer jungfräulichen SD Karte.
        Also mit Imager ein neues Image gezogen, auf die SD Karte geschrieben.
        Läuft soweit.
        pi@raspberrypi:~ $ lsb_release -a
        No LSB modules are available.
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ sudo apt-get install mosquitto
        ist auch ohne Fehlermeldung durchgelaufen.
        Jetzt zur Frage, wie ich den wmbusmeters richtig installiere und konfiguriere (ich möchte mir das für mich idiotensicher aufschreiben weil ich das bestimmt noch öfter brauche und beim letzten mal etliche Versuche gebraucht habe.
        Ich habe es mal mit der Anleitung von
        https://snapcraft.io/install/wmbusmeters/raspbian
        probiert
        sudo apt update
        sudo apt install snapd
        pi@raspberrypi:~ $ sudo snap install core
        2021-07-11T20:43:45+02:00 INFO Waiting for restart...
        core 16-2.51.1 from Canonical✓ installed
        Channel latest/stable for core is closed; temporarily forwarding to stable.
        pi@raspberrypi:~ $ sudo snap install wmbusmeters
        wmbusmeters 1.3.0 from Fredrik Öhrström (oehrstroem) installed
        pi@raspberrypi:~ $
        Dummerweise gibt es aber jetzt kein Verzeichnis /etc/wmbusmeters
        Also: An dieser Stelle der erste Stolperstein. Wie installiere ich den wmbusmeters richtig?
        Soll der als daemon oder als service laufen?
        • W WolfgangFB
          @wolfgangfb
          Läuft soweit.
          Release:        10
          Codename:       buster
          pi@raspberrypi:~ $
          probiert
          sudo apt update
          pi@raspberrypi:~ $
          @wolfgangfb Warum hantierst du da mit snap rum, wenn du mosquitto doch schon via apt installiert hast? Jetzt hast du das doppelt installiert, fürchte ich.
            W Offline
            W Offline
            WolfgangFB
            schrieb am zuletzt editiert von WolfgangFB
            Ich habe nach einer idiotensicheren Möglichkeit den busmeter zu installieren gesucht und google lieferte mir
            https://snapcraft.io/install/wmbusmeters/raspbian#install
            Die Anleitung habe ich so verstanden, dass man damit ein Werkzeug zum installieren von busmeters installiert (snap) und dann mit dem Befehl
            zum gewünschten Erfolg kommt.
            Für mich klang/klingt das so, als ob snap etwas ähnliches wie apt-get ist War wohl nichts, aber: wie geht es richtig?
            Ist snap etwas das automatisch mosquitto installiert oder warum habe ich das jetzt doppelt?
            Die Github Seite, auf die matze-dev verweist
            https://github.com/weetmuts/wmbusmeters
            gibt auch den "snap" als Installationsmöglichkeit an.
            • W WolfgangFB
              @wolfgangfb
              Was denkst du passiert wenn man install angibt und das ganze ohne Fehlermeldung durchläuft?
              snap ist eine andere Methode Pakete zu installieren.
              Wird gerne für Entwicklerversionen verwendet, das ganze läuft dann in einer Art Sandbox ab. Auf dem Raspberry würde ich aber immer die vorgesehene Methode via apt bevorzugen. Viele Paketmanager verderben das System. Insbesondere wenn da auf Verdacht irgendwie irgendwas ins System gedübelt wird.
                @wolfgangfb
                W Offline
                W Offline
                WolfgangFB
                @thomas-braun said in Adapter WM-Bus / Kampstrup Multical 21:
                @wolfgangfb
                Ich denke, dass man damit mosquitto installiert
                ich habe auch auf Verdacht
                sudo apt-get install wmbusmeters
                probiert,das hat aber nicht funktioniert, ich weiß aber immer noch nicht, was
                mit einer doppelten Installation von mosquitto zu tun hat (es geht einmal um mosquitto, das ich installieren konnte und einmal um wmbusmeter das ich bisher nicht installieren konnte)
                Thomas BraunT M 2 Antworten Letzte Antwort
                • W WolfgangFB
                  @wolfgangfb
                  @wolfgangfb Ah, sorry, da hatte ich nicht genau gelesen.
                  Ich würde wmbusmeters dann ganz klassisch per Installations-Dreisatz selber bauen.
                  • W WolfgangFB
                    @wolfgangfb
                    matze-dev
                    schrieb am zuletzt editiert von matze-dev
                    @wolfgangfb
                    wmbusmeters habe ich aus den Sourcen installiert:
                    cd ~
                    wget https://github.com/weetmuts/wmbusmeters/archive/master.zip
                    alternativ geht auch der Download
                    wget https://github.com/weetmuts/wmbusmeters/archive/refs/heads/master.zip
                    unzip master.zip
                    cd wmbusmeters-master/
                    sudo make DEBUG=true // geht auch alternativ "sudo make"
                    sudo make install
                    Viel Glück
                    W 2 Antworten Letzte Antwort
                    • M matze-dev
                      @wolfgangfb
                      cd ~
                      unzip master.zip
                      sudo make install
                      Viel Glück
                      W Offline
                      W Offline
                      WolfgangFB
                      @matze-dev
                      Danke für die Hilfe. Klappt aber leider noch nicht ganz
                      pi@raspberrypi4:~/wmbusmeters-master $ sudo make DEBUG=true
                      [viel erfolgreiches gelöscht]
                      g++ -O0 -ggdb -fsanitize=address -fno-omit-frame-pointer -fprofile-arcs -ftest-coverage -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild_debug src/rtlsdr.cc -c -E > build_debug/rtlsdr.o.src
                      src/rtlsdr.cc:24:9: fatal error: rtl-sdr.h: Datei oder Verzeichnis nicht gefunden
                       #include<rtl-sdr.h>
                      compilation terminated.
                      make: *** [Makefile:104: build_debug/rtlsdr.o] Fehler 1
                      • W WolfgangFB
                        @matze-dev
                         #include<rtl-sdr.h>
                        @wolfgangfb
                        Da fehlt das Paket librtlsdr-dev
                          @wolfgangfb
                          W Offline
                          W Offline
                          WolfgangFB
                          Wo bekomme ich das her?
                          • W WolfgangFB
                            @wolfgangfb
                            Wie die meisten Pakete auch:
                            sudo apt install <Paketname>
                            sudo apt install librtlsdr-dev
                            also. Kann aber sein dass da auch noch anderes fehlt.
                              @wolfgangfb
                              W Offline
                              W Offline
                              WolfgangFB
                              Danke!
                              Das sind aber genau die Punkte, an denen ich immer hängen bleibe. Für Leute, die das 1000 mal gemacht haben, ist das klar, mir hilft die Zeile mit dem Befehl aber enorm.
                              • W WolfgangFB
                                Danke!
                                @wolfgangfb
                                librtlsdr-dev habe ich noch nie installiert. 😆
                                  @wolfgangfb
                                  W Offline
                                  W Offline
                                  WolfgangFB
                                  OK, nächstes Paket das fehlt:
                                  g++ -O0 -ggdb -fsanitize=address -fno-omit-frame-pointer -fprofile-arcs -ftest-coverage -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild_debug src/admin.cc -c -E > build_debug/admin.o.src
                                  In file included from src/admin.cc:26:
                                  src/ui.h:22:9: fatal error: curses.h: Datei oder Verzeichnis nicht gefunden
                                   #include<curses.h>
                                  Woher hast Du beim ersten mal gewusst, dass da librtlsdr-dev fehlt und was fehlt diesmal?
                                  • W WolfgangFB
                                     #include<curses.h>
                                    @wolfgangfb
                                    libncurses-dev
                                    Kann man hier nachschauen:
                                    https://www.debian.org/distrib/packages
                                      @wolfgangfb
                                      libncurses-dev
                                      W Offline
                                      W Offline
                                      WolfgangFB
                                      Danke!
                                      • M matze-dev
                                        @wolfgangfb
                                        cd ~
                                        unzip master.zip
                                        sudo make install
                                        Viel Glück
                                        W Offline
                                        W Offline
                                        WolfgangFB
                                        @matze-dev
                                        So, ich denke wmbusmeters läuft jetzt (sieht zumindest grün aus).
                                        pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ systemctl status wmbusmeters
                                        ● wmbusmeters.service - "wmbusmeters service"
                                           Loaded: loaded (/lib/systemd/system/wmbusmeters.service; disabled; vendor preset: enabled)
                                           Active: active (running) since Tue 2021-07-13 23:12:55 CEST; 3s ago
                                             Docs: https://github.com/weetmuts/wmbusmeters
                                                   man:wmbusmeters(1)
                                          Process: 12466 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
                                          Process: 12467 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
                                          Process: 12468 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                          Process: 12469 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                          Process: 12470 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
                                         Main PID: 12471 (wmbusmetersd)
                                            Tasks: 3 (limit: 4915)
                                           CGroup: /system.slice/wmbusmeters.service
                                                   └─12471 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
                                        Jul 13 23:12:55 raspberrypi4 systemd[1]: Starting "wmbusmeters service"...
                                        Jul 13 23:12:55 raspberrypi4 wmbusmetersd[12470]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                                        Jul 13 23:12:55 raspberrypi4 systemd[1]: Started "wmbusmeters service".
                                        was mich stört ist
                                        pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ more /var/log/wmbusmeters/wmbusmeters.log
                                        (wmbusmeters) logging started 2021-07-13 22:40:08 using _
                                        (wmbusmeters) logging started 2021-07-13 23:12:55 using _
                                        [2021-07-13_23:12:56] Started config im871a[00100776] on /dev/ttyUSB0 listening on none
                                        [2021-07-13_23:12:56] Warning! Desired link modes none cannot be set for device /dev/ttyUSB0:im871a[00100776]
                                        [2021-07-13_23:12:58] (memory) rss 2048000 peak 1.95 MiB
                                        pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ lsusb
                                        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                        Bus 001 Device 006: ID 0458:0007 KYE Systems Corp. (Mouse Systems)
                                        Bus 001 Device 005: ID 046d:c534 Logitech, Inc. Unifying Receiver
                                        Bus 001 Device 004: ID 0451:16a8 Texas Instruments, Inc.
                                        Bus 001 Device 003: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                                        Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                                        pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ ls -l /dev/serial/by-id
                                        insgesamt 0
                                        lrwxrwxrwx 1 root root 13 Jun 16 14:34 usb-Silicon_Labs_WiMOD_iM871A-usb_00919907-if00-port0 -> ../../ttyUSB0
                                        lrwxrwxrwx 1 root root 13 Jun 16 14:34 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CD40626-if00 -> ../../ttyACM0
                                        mosquitto scheint prinzipiell auch zu laufen:
                                        pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ mosquitto
                                        1626210924: mosquitto version 1.5.7 starting
                                        1626210924: Using default config.
                                        1626210924: Opening ipv4 listen socket on port 1883.
                                        1626210924: Error: Address already in use
                                        Aber was ist mit dem Error "Address already in use"? gemeint?
                                        Im IO-Broker bleibt der mqtt Adapter rot (im Logfile steht nichts)
                                        • W WolfgangFB
                                          @matze-dev
                                                     man:wmbusmeters(1)
                                          was mich stört ist
                                          insgesamt 0
                                          matze-dev
                                          @wolfgangfb: das ist korrekt - die "Fehlermeldung" kommt bei mir auch. Ist aber das "falsche" Kommando, weil der wmbusmeters-Treiber laut Konfig-Zeile das Programm /usr/local/bin/mosquitto_pub aufruft - wenn das bei Dir auch so in der /etc/wmbusmeters.conf steht.
                                          Du siehst den Erfolg nur in den Logfiles, wenn da was steht, passt es!
