  4. iobroker manchmal nicht erreichbar
    6.5k
iobroker erreichbarkeitstates.jasonsystem.config
47 Beiträge 4 Kommentatoren 5.3k Aufrufe 2 Beobachtet
  • M mguenther
    pi@raspberrypi4-iob:~ $ dmesg -T
    [Mo Jul 12 09:33:39 2021] Booting Linux on physical CPU 0x0
    [Mo Jul 12 09:33:39 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1421 SMP Thu May 27 14:00:13 BST 2021
    [Mo Jul 12 09:33:39 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [Mo Jul 12 09:33:39 2021] CPU: div instructions available: patching division code
    [Mo Jul 12 09:33:39 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [Mo Jul 12 09:33:39 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
    [Mo Jul 12 09:33:39 2021] Memory policy: Data cache writealloc
    [Mo Jul 12 09:33:39 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [Mo Jul 12 09:33:39 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [Mo Jul 12 09:33:39 2021] Zone ranges:
    [Mo Jul 12 09:33:39 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [Mo Jul 12 09:33:39 2021]   Normal   empty
    [Mo Jul 12 09:33:39 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [Mo Jul 12 09:33:39 2021] Movable zone start for each node
    [Mo Jul 12 09:33:39 2021] Early memory node ranges
    [Mo Jul 12 09:33:39 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
    [Mo Jul 12 09:33:39 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [Mo Jul 12 09:33:39 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [Mo Jul 12 09:33:39 2021] On node 0 totalpages: 1012736
    [Mo Jul 12 09:33:39 2021]   DMA zone: 2304 pages used for memmap
    [Mo Jul 12 09:33:39 2021]   DMA zone: 0 pages reserved
    [Mo Jul 12 09:33:39 2021]   DMA zone: 196608 pages, LIFO batch:63
    [Mo Jul 12 09:33:39 2021]   HighMem zone: 816128 pages, LIFO batch:63
    [Mo Jul 12 09:33:39 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    [Mo Jul 12 09:33:39 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [Mo Jul 12 09:33:39 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Mo Jul 12 09:33:39 2021] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
    [Mo Jul 12 09:33:39 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:5B:A1:E6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=11e25fc3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mo Jul 12 09:33:39 2021] Kernel parameter elevator= does not have any effect anymore.
                              Please use sysfs to set IO scheduler for individual devices.
    [Mo Jul 12 09:33:39 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [Mo Jul 12 09:33:39 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [Mo Jul 12 09:33:39 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [Mo Jul 12 09:33:39 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
    [Mo Jul 12 09:33:39 2021] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
    [Mo Jul 12 09:33:39 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [Mo Jul 12 09:33:39 2021] ftrace: allocating 33942 entries in 67 pages
    [Mo Jul 12 09:33:39 2021] ftrace: allocated 67 pages with 3 groups
    [Mo Jul 12 09:33:39 2021] rcu: Hierarchical RCU implementation.
    [Mo Jul 12 09:33:39 2021]       Rude variant of Tasks RCU enabled.
    [Mo Jul 12 09:33:39 2021]       Tracing variant of Tasks RCU enabled.
    [Mo Jul 12 09:33:39 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [Mo Jul 12 09:33:39 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Mo Jul 12 09:33:39 2021] GIC: Using split EOI/Deactivate mode
    [Mo Jul 12 09:33:39 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
    [Mo Jul 12 09:33:39 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [Mo Jul 12 09:33:39 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [Mo Jul 12 09:33:39 2021] bcm2835: system timer (irq = 25)
    [Mo Jul 12 09:33:39 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [Mo Jul 12 09:33:39 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [Mo Jul 12 09:33:39 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [Mo Jul 12 09:33:39 2021] Switching to timer-based delay loop, resolution 18ns
    [Mo Jul 12 09:33:39 2021] Console: colour dummy device 80x30
    [Mo Jul 12 09:33:39 2021] printk: console [tty1] enabled
    [Mo Jul 12 09:33:39 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [Mo Jul 12 09:33:39 2021] pid_max: default: 32768 minimum: 301
    [Mo Jul 12 09:33:39 2021] LSM: Security Framework initializing
    [Mo Jul 12 09:33:39 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Mo Jul 12 09:33:39 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Mo Jul 12 09:33:39 2021] Disabling memory control group subsystem
    [Mo Jul 12 09:33:39 2021] CPU: Testing write buffer coherency: ok
    [Mo Jul 12 09:33:39 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Mo Jul 12 09:33:39 2021] Setting up static identity map for 0x200000 - 0x20003c
    [Mo Jul 12 09:33:39 2021] rcu: Hierarchical SRCU implementation.
    [Mo Jul 12 09:33:39 2021] smp: Bringing up secondary CPUs ...
    [Mo Jul 12 09:33:39 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Mo Jul 12 09:33:39 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Mo Jul 12 09:33:39 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Mo Jul 12 09:33:39 2021] smp: Brought up 1 node, 4 CPUs
    [Mo Jul 12 09:33:39 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [Mo Jul 12 09:33:39 2021] CPU: All CPU(s) started in HYP mode.
    [Mo Jul 12 09:33:39 2021] CPU: Virtualization extensions available.
    [Mo Jul 12 09:33:39 2021] devtmpfs: initialized
    [Mo Jul 12 09:33:39 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [Mo Jul 12 09:33:39 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Mo Jul 12 09:33:39 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [Mo Jul 12 09:33:39 2021] pinctrl core: initialized pinctrl subsystem
    [Mo Jul 12 09:33:39 2021] NET: Registered protocol family 16
    [Mo Jul 12 09:33:39 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [Mo Jul 12 09:33:39 2021] audit: initializing netlink subsys (disabled)
    [Mo Jul 12 09:33:39 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [Mo Jul 12 09:33:39 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Mo Jul 12 09:33:39 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [Mo Jul 12 09:33:39 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Mo Jul 12 09:33:39 2021] Serial: AMBA PL011 UART driver
    [Mo Jul 12 09:33:39 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [Mo Jul 12 09:33:39 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-05-27T14:02:15, variant start
    [Mo Jul 12 09:33:39 2021] raspberrypi-firmware soc:firmware: Firmware hash is 7d9a298cda813f747b51fe17e1e417e7bf5ca94d
    [Mo Jul 12 09:33:39 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [Mo Jul 12 09:33:39 2021] vgaarb: loaded
    [Mo Jul 12 09:33:39 2021] SCSI subsystem initialized
    [Mo Jul 12 09:33:39 2021] usbcore: registered new interface driver usbfs
    [Mo Jul 12 09:33:39 2021] usbcore: registered new interface driver hub
    [Mo Jul 12 09:33:39 2021] usbcore: registered new device driver usb
    [Mo Jul 12 09:33:39 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [Mo Jul 12 09:33:39 2021] clocksource: Switched to clocksource arch_sys_counter
    [Mo Jul 12 09:33:40 2021] VFS: Disk quotas dquot_6.6.0
    [Mo Jul 12 09:33:40 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [Mo Jul 12 09:33:40 2021] FS-Cache: Loaded
    [Mo Jul 12 09:33:40 2021] CacheFiles: Loaded
    [Mo Jul 12 09:33:40 2021] NET: Registered protocol family 2
    [Mo Jul 12 09:33:40 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [Mo Jul 12 09:33:40 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [Mo Jul 12 09:33:40 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [Mo Jul 12 09:33:40 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [Mo Jul 12 09:33:40 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Mo Jul 12 09:33:40 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Mo Jul 12 09:33:40 2021] NET: Registered protocol family 1
    [Mo Jul 12 09:33:40 2021] RPC: Registered named UNIX socket transport module.
    [Mo Jul 12 09:33:40 2021] RPC: Registered udp transport module.
    [Mo Jul 12 09:33:40 2021] RPC: Registered tcp transport module.
    [Mo Jul 12 09:33:40 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Mo Jul 12 09:33:40 2021] PCI: CLS 0 bytes, default 64
    [Mo Jul 12 09:33:40 2021] Initialise system trusted keyrings
    [Mo Jul 12 09:33:40 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [Mo Jul 12 09:33:40 2021] zbud: loaded
    [Mo Jul 12 09:33:40 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Mo Jul 12 09:33:40 2021] NFS: Registering the id_resolver key type
    [Mo Jul 12 09:33:40 2021] Key type id_resolver registered
    [Mo Jul 12 09:33:40 2021] Key type id_legacy registered
    [Mo Jul 12 09:33:40 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [Mo Jul 12 09:33:40 2021] Key type asymmetric registered
    [Mo Jul 12 09:33:40 2021] Asymmetric key parser 'x509' registered
    [Mo Jul 12 09:33:40 2021] bounce: pool size: 64 pages
    [Mo Jul 12 09:33:40 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [Mo Jul 12 09:33:40 2021] io scheduler mq-deadline registered
    [Mo Jul 12 09:33:40 2021] io scheduler kyber registered
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [Mo Jul 12 09:33:40 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [Mo Jul 12 09:33:40 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [Mo Jul 12 09:33:40 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [Mo Jul 12 09:33:40 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [Mo Jul 12 09:33:40 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [Mo Jul 12 09:33:40 2021] PCI: bus0: Fast back to back transfers disabled
    [Mo Jul 12 09:33:40 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [Mo Jul 12 09:33:40 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [Mo Jul 12 09:33:40 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
    [Mo Jul 12 09:33:40 2021] PCI: bus1: Fast back to back transfers disabled
    [Mo Jul 12 09:33:40 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [Mo Jul 12 09:33:40 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [Mo Jul 12 09:33:40 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [Mo Jul 12 09:33:40 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [Mo Jul 12 09:33:40 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [Mo Jul 12 09:33:40 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
    [Mo Jul 12 09:33:40 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [Mo Jul 12 09:33:40 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
    [Mo Jul 12 09:33:40 2021] iproc-rng200 fe104000.rng: hwrng registered
    [Mo Jul 12 09:33:40 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [Mo Jul 12 09:33:40 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [Mo Jul 12 09:33:40 2021] brd: module loaded
    [Mo Jul 12 09:33:40 2021] loop: module loaded
    [Mo Jul 12 09:33:40 2021] Loading iSCSI transport class v2.0-870.
    [Mo Jul 12 09:33:40 2021] libphy: Fixed MDIO Bus: probed
    [Mo Jul 12 09:33:40 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [Mo Jul 12 09:33:40 2021] libphy: bcmgenet MII bus: probed
    [Mo Jul 12 09:33:40 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver r8152
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver lan78xx
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver smsc95xx
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
    [Mo Jul 12 09:33:40 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [Mo Jul 12 09:33:40 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mo Jul 12 09:33:40 2021] usb usb1: Product: xHCI Host Controller
    [Mo Jul 12 09:33:40 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Mo Jul 12 09:33:40 2021] usb usb1: SerialNumber: 0000:01:00.0
    [Mo Jul 12 09:33:40 2021] hub 1-0:1.0: USB hub found
    [Mo Jul 12 09:33:40 2021] hub 1-0:1.0: 1 port detected
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [Mo Jul 12 09:33:40 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [Mo Jul 12 09:33:40 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [Mo Jul 12 09:33:40 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mo Jul 12 09:33:40 2021] usb usb2: Product: xHCI Host Controller
    [Mo Jul 12 09:33:40 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Mo Jul 12 09:33:40 2021] usb usb2: SerialNumber: 0000:01:00.0
    [Mo Jul 12 09:33:40 2021] hub 2-0:1.0: USB hub found
    [Mo Jul 12 09:33:40 2021] hub 2-0:1.0: 4 ports detected
    [Mo Jul 12 09:33:40 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Mo Jul 12 09:33:40 2021] dwc_otg: FIQ enabled
    [Mo Jul 12 09:33:40 2021] dwc_otg: NAK holdoff enabled
    [Mo Jul 12 09:33:40 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Mo Jul 12 09:33:40 2021] Module dwc_common_port init
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver uas
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver usb-storage
    [Mo Jul 12 09:33:40 2021] mousedev: PS/2 mouse device common for all mice
    [Mo Jul 12 09:33:40 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [Mo Jul 12 09:33:40 2021] sdhci: Secure Digital Host Controller Interface driver
    [Mo Jul 12 09:33:40 2021] sdhci: Copyright(c) Pierre Ossman
    [Mo Jul 12 09:33:40 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [Mo Jul 12 09:33:40 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Mo Jul 12 09:33:40 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Mo Jul 12 09:33:40 2021] hid: raw HID events driver (C) Jiri Kosina
    [Mo Jul 12 09:33:40 2021] usbcore: registered new interface driver usbhid
    [Mo Jul 12 09:33:40 2021] usbhid: USB HID core driver
    [Mo Jul 12 09:33:40 2021] Initializing XFRM netlink socket
    [Mo Jul 12 09:33:40 2021] NET: Registered protocol family 17
    [Mo Jul 12 09:33:40 2021] Key type dns_resolver registered
    [Mo Jul 12 09:33:40 2021] Registering SWP/SWPB emulation handler
    [Mo Jul 12 09:33:40 2021] registered taskstats version 1
    [Mo Jul 12 09:33:40 2021] Loading compiled-in X.509 certificates
    [Mo Jul 12 09:33:40 2021] Key type ._fscrypt registered
    [Mo Jul 12 09:33:40 2021] Key type .fscrypt registered
    [Mo Jul 12 09:33:40 2021] Key type fscrypt-provisioning registered
    [Mo Jul 12 09:33:40 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
    [Mo Jul 12 09:33:40 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [Mo Jul 12 09:33:40 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [Mo Jul 12 09:33:40 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
    [Mo Jul 12 09:33:40 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [Mo Jul 12 09:33:40 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Mo Jul 12 09:33:40 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [Mo Jul 12 09:33:40 2021] of_cfs_init
    [Mo Jul 12 09:33:40 2021] of_cfs_init: OK
    [Mo Jul 12 09:33:40 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Mo Jul 12 09:33:40 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Mo Jul 12 09:33:40 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Mo Jul 12 09:33:40 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [Mo Jul 12 09:33:40 2021] Waiting for root device PARTUUID=11e25fc3-02...
    [Mo Jul 12 09:33:40 2021] random: fast init done
    [Mo Jul 12 09:33:40 2021] mmc1: new high speed SDIO card at address 0001
    [Mo Jul 12 09:33:40 2021] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [Mo Jul 12 09:33:40 2021] mmcblk0: mmc0:aaaa SA16G 14.8 GiB
    [Mo Jul 12 09:33:40 2021]  mmcblk0: p1 p2
    [Mo Jul 12 09:33:40 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [Mo Jul 12 09:33:40 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [Mo Jul 12 09:33:40 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Mo Jul 12 09:33:40 2021] usb 1-1: Product: USB2.0 Hub
    [Mo Jul 12 09:33:40 2021] hub 1-1:1.0: USB hub found
    [Mo Jul 12 09:33:40 2021] hub 1-1:1.0: 4 ports detected
    [Mo Jul 12 09:33:41 2021] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [Mo Jul 12 09:33:41 2021] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
    [Mo Jul 12 09:33:41 2021] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
    [Mo Jul 12 09:33:41 2021] usb 2-1: Product: ASM105x
    [Mo Jul 12 09:33:41 2021] usb 2-1: Manufacturer: ASMedia
    [Mo Jul 12 09:33:41 2021] usb 2-1: SerialNumber: S4CJNJ0MC37950Z
    [Mo Jul 12 09:33:41 2021] scsi host0: uas
    [Mo Jul 12 09:33:41 2021] scsi 0:0:0:0: Direct-Access     ASMedia  ASM105x          0    PQ: 0 ANSI: 6
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] Write Protect is off
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
    [Mo Jul 12 09:33:41 2021]  sda: sda1 sda2
    [Mo Jul 12 09:33:41 2021] sd 0:0:0:0: [sda] Attached SCSI disk
    [Mo Jul 12 09:33:41 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mo Jul 12 09:33:41 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mo Jul 12 09:33:41 2021] devtmpfs: mounted
    [Mo Jul 12 09:33:41 2021] Freeing unused kernel memory: 2048K
    [Mo Jul 12 09:33:41 2021] Run /sbin/init as init process
    [Mo Jul 12 09:33:41 2021]   with arguments:
    [Mo Jul 12 09:33:41 2021]     /sbin/init
    [Mo Jul 12 09:33:41 2021]   with environment:
    [Mo Jul 12 09:33:41 2021]     HOME=/
    [Mo Jul 12 09:33:41 2021]     TERM=linux
    [Mo Jul 12 09:33:41 2021] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
    [Mo Jul 12 09:33:41 2021] systemd[1]: System time before build time, advancing clock.
    [Mo Jul 12 09:33:41 2021] NET: Registered protocol family 10
    [Mo Jul 12 09:33:41 2021] Segment Routing with IPv6
    [Mo Jul 12 09:33:41 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [Mo Jul 12 09:33:41 2021] systemd[1]: Detected architecture arm.
    [Mo Jul 12 09:33:41 2021] systemd[1]: Set hostname to <raspberrypi4-iob>.
    [Mo Jul 12 09:33:42 2021] usb 1-1.2: New USB device found, idVendor=0463, idProduct=ffff, bcdDevice= 1.00
    [Mo Jul 12 09:33:42 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=4
    [Mo Jul 12 09:33:42 2021] usb 1-1.2: Product: Eaton 3S
    [Mo Jul 12 09:33:42 2021] usb 1-1.2: Manufacturer: EATON
    [Mo Jul 12 09:33:42 2021] usb 1-1.2: SerialNumber: Blank
    [Mo Jul 12 09:33:42 2021] systemd[1]: /lib/systemd/system/nut-monitor.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/nut/upsmon.pid → /run/nut/upsmon.pid; please update the unit file accordingly.
    [Mo Jul 12 09:33:42 2021] systemd[1]: /lib/systemd/system/deconz.service:8: Unknown lvalue 'StartLimitIntervalSec' in section 'Service', ignoring
    [Mo Jul 12 09:33:42 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [Mo Jul 12 09:33:42 2021] systemd[1]: Created slice system-getty.slice.
    [Mo Jul 12 09:33:42 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [Mo Jul 12 09:33:42 2021] systemd[1]: Listening on Syslog Socket.
    [Mo Jul 12 09:33:42 2021] systemd[1]: Listening on Journal Socket (/dev/log).
    [Mo Jul 12 09:33:42 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
    [Mo Jul 12 09:33:43 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Mo Jul 12 09:33:43 2021] systemd-journald[109]: Received request to flush runtime journal from PID 1
    [Mo Jul 12 09:33:43 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [Mo Jul 12 09:33:43 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [Mo Jul 12 09:33:43 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [Mo Jul 12 09:33:43 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [Mo Jul 12 09:33:43 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:43 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:44 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [Mo Jul 12 09:33:44 2021] [vc_sm_connected_init]: start
    [Mo Jul 12 09:33:44 2021] [vc_sm_connected_init]: installed successfully
    [Mo Jul 12 09:33:44 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
    [Mo Jul 12 09:33:44 2021] mc: Linux media interface: v0.10
    [Mo Jul 12 09:33:44 2021] videodev: Linux video capture interface: v2.00
    [Mo Jul 12 09:33:44 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:44 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:44 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:44 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [Mo Jul 12 09:33:44 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Mo Jul 12 09:33:44 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [Mo Jul 12 09:33:44 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [Mo Jul 12 09:33:44 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [Mo Jul 12 09:33:44 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Mo Jul 12 09:33:44 2021] input: soc:shutdown_button as /devices/platform/soc/soc:shutdown_button/input/input0
    [Mo Jul 12 09:33:44 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [Mo Jul 12 09:33:44 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
    [Mo Jul 12 09:33:45 2021] hid-generic 0003:0463:FFFF.0001: hiddev96,hidraw0: USB HID v1.10 Device [EATON Eaton 3S] on usb-0000:01:00.0-1.2/input0
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: Product: FT232R USB UART
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: Manufacturer: FTDI
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: SerialNumber: AC01Q9W7
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: Product: FT230X Basic UART
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: Manufacturer: FTDI
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: SerialNumber: DM0105M9
    [Mo Jul 12 09:33:45 2021] usbcore: registered new interface driver usbserial_generic
    [Mo Jul 12 09:33:45 2021] usbserial: USB Serial support registered for generic
    [Mo Jul 12 09:33:45 2021] usbcore: registered new interface driver ftdi_sio
    [Mo Jul 12 09:33:45 2021] usbserial: USB Serial support registered for FTDI USB Serial Device
    [Mo Jul 12 09:33:45 2021] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: Detected FT232RL
    [Mo Jul 12 09:33:45 2021] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
    [Mo Jul 12 09:33:45 2021] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: Detected FT-X
    [Mo Jul 12 09:33:45 2021] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB1
    [Mo Jul 12 09:33:47 2021] uart-pl011 fe201000.serial: no DMA platform data
    [Mo Jul 12 09:33:47 2021] 8021q: 802.1Q VLAN Support v1.8
    [Mo Jul 12 09:33:47 2021] random: crng init done
    [Mo Jul 12 09:33:47 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [Mo Jul 12 09:33:48 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:118780k FS
    [Mo Jul 12 09:33:48 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [Mo Jul 12 09:33:48 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [Mo Jul 12 09:33:48 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [Mo Jul 12 09:33:48 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [Mo Jul 12 09:33:52 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [Mo Jul 12 09:33:52 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [Mo Jul 12 09:33:54 2021] Bluetooth: Core ver 2.22
    [Mo Jul 12 09:33:54 2021] NET: Registered protocol family 31
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI device and connection manager initialized
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI socket layer initialized
    [Mo Jul 12 09:33:54 2021] Bluetooth: L2CAP socket layer initialized
    [Mo Jul 12 09:33:54 2021] Bluetooth: SCO socket layer initialized
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI UART driver ver 2.3
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI UART protocol H4 registered
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [Mo Jul 12 09:33:54 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Mo Jul 12 09:33:54 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Mo Jul 12 09:33:54 2021] Bluetooth: BNEP filters: protocol multicast
    [Mo Jul 12 09:33:54 2021] Bluetooth: BNEP socket layer initialized
    [Mo Jul 12 09:34:13 2021] FS-Cache: Netfs 'cifs' registered for caching
    [Mo Jul 12 09:34:14 2021] Key type cifs.spnego registered
    [Mo Jul 12 09:34:14 2021] Key type cifs.idmap registered
    [Mo Jul 12 09:34:14 2021] CIFS: Attempting to mount //192.168.222.175/iobroker_backup/standard/
    [Mo Jul 12 09:34:14 2021] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    @mguenther
    Soweit nichts auffälliges.
    who -r
    liefert?
    SMB/CIFS würde ich auch auf eine aktuelle Version umstellen.
      @mguenther
      who -r
      liefert?
      mguenther
      pi@raspberrypi4-iob:~ $ who -r
               Runlevel 5   2021-07-12 09:26
      Wie kann ich denn SMB/CIFS auf eine neue Version umstellen?
      Mein Logfile von gestern abend bis heute morgen (da, wo ich die Zwischensteckdose wieder entfernt habe) ist schlappe 76MB groß - vorher hatte ich 100-200K...
      • M mguenther
        @mguenther sagte in iobroker manchmal nicht erreichbar:
        Vermutlich im Backitup-Adapter.
        Wer da bei dir smb/cifs aufruft sehe ich ja nicht.
        Runlevel 5
        Stell das auf RL3 um. Siehe der kleine Linux-Werkzeugkasten aus meiner Signatur.
        Und mit welchen Meldungen ist das File gefüllt? Das wäre interessanter zu wissen als die Dateigröße.
        M 2 Antworten Letzte Antwort
        • M mguenther
          @crunchip
          folgende Meldung hatte ich gestern öfters:
          unifi.0 (17384) fetchSites: Returned data is not in valid format
          crunchipC Abwesend
          crunchipC Abwesend
          https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/292
            mguenther
            @crunchip
            ok... ich muss mich mehr mit github auseinander setzen - ich habe in iobroker den 2FA user eingetragen. Bis gestern ging auch alles und auch jetzt geht alles. Lediglich gestern hatte ich auf einmal diverse Probleme - s.o.
              Runlevel 5
              mguenther
              schrieb am zuletzt editiert von mguenther
              hauptsächlich der Adapter "dasWetter" und da ich davon 3 Instanzen habe (schedule ist extra zeitversetzt) entsprechend viele Einträge
              2021-07-12 00:49:03.873  - info: host.raspberrypi4-iob instance system.adapter.daswetter.1 started with pid 31044
              2021-07-12 00:49:09.684  - error: daswetter.0 (29877) force terminate
              2021-07-12 00:49:09.686  - warn: daswetter.0 (29877) Terminated (UNKNOWN_ERROR): Without reason
              2021-07-12 00:49:11.710  - warn: daswetter.1 (31044) slow connection to states DB. Still waiting ...
              2021-07-12 00:49:13.027  - warn: daswetter.0 (29877) get state error: Connection is closed.
              2021-07-12 00:49:13.029  - error: daswetter.0 (29877) exception in await insertIntoList [Error: DB closed]
              2021-07-12 00:49:13.104  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_1.Tag_value": Connection is closed.
              2021-07-12 00:49:13.106  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_1.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_1.Tag_value": Connection is closed.]
              2021-07-12 00:49:13.109  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_1.Wetterbedingungen_value": Connection is closed.
              2021-07-12 00:49:13.110  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_1.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_1.Wetterbedingungen_value": Connection is closed.]
              2021-07-12 00:49:13.112  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2": Connection is closed.
              2021-07-12 00:49:13.118  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2": Connection is closed.]
              2021-07-12 00:49:13.120  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.121  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Minimale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.123  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.125  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Maximale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.127  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_valueB": Connection is closed.
              2021-07-12 00:49:13.128  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_valueB": Connection is closed.]
              2021-07-12 00:49:13.130  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_value": Connection is closed.
              2021-07-12 00:49:13.132  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_value": Connection is closed.]
              2021-07-12 00:49:13.141  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_idB": Connection is closed.
              2021-07-12 00:49:13.144  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_idB": Connection is closed.]
              2021-07-12 00:49:13.148  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_id": Connection is closed.
              2021-07-12 00:49:13.151  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wind_id": Connection is closed.]
              2021-07-12 00:49:13.156  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.windIconURL": Connection is closed.
              2021-07-12 00:49:13.159  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.windIconURL": Connection is closed.]
              2021-07-12 00:49:13.163  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value2": Connection is closed.
              2021-07-12 00:49:13.166  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value2": Connection is closed.]
              2021-07-12 00:49:13.170  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value": Connection is closed.
              2021-07-12 00:49:13.174  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_value": Connection is closed.]
              2021-07-12 00:49:13.177  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id2": Connection is closed.
              2021-07-12 00:49:13.181  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id2": Connection is closed.]
              2021-07-12 00:49:13.190  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id": Connection is closed.
              2021-07-12 00:49:13.192  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetter_Symbol_id": Connection is closed.]
              2021-07-12 00:49:13.194  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.iconURL": Connection is closed.
              2021-07-12 00:49:13.196  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.iconURL": Connection is closed.]
              2021-07-12 00:49:13.198  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Tag_value": Connection is closed.
              2021-07-12 00:49:13.200  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Tag_value": Connection is closed.]
              2021-07-12 00:49:13.202  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetterbedingungen_value": Connection is closed.
              2021-07-12 00:49:13.205  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_2.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_2.Wetterbedingungen_value": Connection is closed.]
              2021-07-12 00:49:13.207  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3": Connection is closed.
              2021-07-12 00:49:13.209  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3": Connection is closed.]
              2021-07-12 00:49:13.212  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.213  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Minimale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.216  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.218  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Maximale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.220  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_valueB": Connection is closed.
              2021-07-12 00:49:13.222  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_valueB": Connection is closed.]
              2021-07-12 00:49:13.225  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_value": Connection is closed.
              2021-07-12 00:49:13.226  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_value": Connection is closed.]
              2021-07-12 00:49:13.229  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_idB": Connection is closed.
              2021-07-12 00:49:13.230  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_idB": Connection is closed.]
              2021-07-12 00:49:13.235  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_id": Connection is closed.
              2021-07-12 00:49:13.236  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wind_id": Connection is closed.]
              2021-07-12 00:49:13.239  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.windIconURL": Connection is closed.
              2021-07-12 00:49:13.241  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.windIconURL": Connection is closed.]
              2021-07-12 00:49:13.244  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value2": Connection is closed.
              2021-07-12 00:49:13.246  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value2": Connection is closed.]
              2021-07-12 00:49:13.248  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value": Connection is closed.
              2021-07-12 00:49:13.250  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_value": Connection is closed.]
              2021-07-12 00:49:13.252  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id2": Connection is closed.
              2021-07-12 00:49:13.255  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id2": Connection is closed.]
              2021-07-12 00:49:13.258  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id": Connection is closed.
              2021-07-12 00:49:13.259  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetter_Symbol_id": Connection is closed.]
              2021-07-12 00:49:13.262  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.iconURL": Connection is closed.
              2021-07-12 00:49:13.264  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.iconURL": Connection is closed.]
              2021-07-12 00:49:13.267  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Tag_value": Connection is closed.
              2021-07-12 00:49:13.269  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Tag_value": Connection is closed.]
              2021-07-12 00:49:13.271  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetterbedingungen_value": Connection is closed.
              2021-07-12 00:49:13.273  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_3.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_3.Wetterbedingungen_value": Connection is closed.]
              2021-07-12 00:49:13.275  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4": Connection is closed.
              2021-07-12 00:49:13.278  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4": Connection is closed.]
              2021-07-12 00:49:13.281  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.283  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Minimale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.286  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value": Connection is closed.
              2021-07-12 00:49:13.288  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Maximale_Temperatur_value": Connection is closed.]
              2021-07-12 00:49:13.290  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_valueB": Connection is closed.
              2021-07-12 00:49:13.292  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_valueB": Connection is closed.]
              2021-07-12 00:49:13.294  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_value": Connection is closed.
              2021-07-12 00:49:13.296  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_value": Connection is closed.]
              2021-07-12 00:49:13.298  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_idB": Connection is closed.
              2021-07-12 00:49:13.300  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_idB": Connection is closed.]
              2021-07-12 00:49:13.302  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_id": Connection is closed.
              2021-07-12 00:49:13.304  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wind_id": Connection is closed.]
              2021-07-12 00:49:13.307  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.windIconURL": Connection is closed.
              2021-07-12 00:49:13.308  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.windIconURL": Connection is closed.]
              2021-07-12 00:49:13.311  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value2": Connection is closed.
              2021-07-12 00:49:13.313  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value2": Connection is closed.]
              2021-07-12 00:49:13.315  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value": Connection is closed.
              2021-07-12 00:49:13.317  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_value": Connection is closed.]
              2021-07-12 00:49:13.320  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id2": Connection is closed.
              2021-07-12 00:49:13.321  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id2": Connection is closed.]
              2021-07-12 00:49:13.324  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id": Connection is closed.
              2021-07-12 00:49:13.326  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id": Connection is closed.]
              2021-07-12 00:49:13.328  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.iconURL": Connection is closed.
              2021-07-12 00:49:13.329  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.iconURL": Connection is closed.]
              2021-07-12 00:49:13.332  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Tag_value": Connection is closed.
              2021-07-12 00:49:13.334  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Tag_value": Connection is closed.]
              2021-07-12 00:49:13.336  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetterbedingungen_value": Connection is closed.
              2021-07-12 00:49:13.338  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_4.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_4.Wetterbedingungen_value": Connection is closed.]
              2021-07-12 00:49:13.341  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5": Connection is closed.
              2021-07-12 00:49:13.343  - error: daswetter.0 (29877) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5": Connection is closed.]
              2021-07-12 00:49:13.347  - error: daswetter.0 (29877) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Minimale_Temperatur_value": Connection is closed.
              und das eben bis heute früh. Dann habe ich den RP4 wie oben beschrieben heruntergefahren, die Zwischensteckdose entfernt und seit dem läuft es auch wieder. Ich habe nur Befürchtungen, dass meine Vermutung mit der Steckdose falsch ist. Mir war zwar aufgefallen, dass die Problematik mit dem "iobroker status" immer nur unter Last (z.B. eine VIS wurde geladen etc.) auftrat, aber sicher bin ich mir nicht...
                Runlevel 5
                mguenther
                @thomas-braun sagte in iobroker manchmal nicht erreichbar:
                Runlevel 5
                Gelesen und verstanden. Ich kapiere noch nicht, warum bei mir Runlevel 5 eingestellt ist. Ich nutze eigentlich keine Visualiserung o.Ä. - lediglich einen deconz-Stick und den iobroker über die Standard-Ports.
                Ich habe ja eine SSD dran und auch da mache ich nix...
                Wie könnte ich denn wieder auf Runlevel 5 zurückstellen, wenn mein System mit Runlevel 3 nicht mehr laufen sollte?
                sudo raspi-config
                1 System Options       Configure system settings
                S5 Boot / Auto Login   Select boot into desktop or to command line
                B1 Console             Text console, requiring user to login
                Was müsste ich den anstelle von B1 Console wählen?
                • M mguenther
                  Runlevel 5
                  sudo raspi-config
                  Das wird nicht passieren.
                  Falls doch: Stell auf GUI zurück. Im gleichen Menü.
                    mguenther
                    danke - habs umgestellt.
                    kann es sein, dass iobroker schneller läuft? Zumindest meine VIS lädt schneller ein paar Umfänge.
                    Ich habe eben nochmal einen "Stresstest" (ich arbeite in der Automobilbranche :) ) gemacht - keine Fehlermeldung mehr. Wild zwischen den VIS-Seiten hin und her geschaltet, log-File geladen, info Seite geöffnet usw.
                    Gleichzeitig mir mit "iobroker status" alles angeschaut - keine Probleme, auch im Log keine Error Meldungen. Ich beobachte mal weiter...
                    • M mguenther
                      Natürlich. Du hast ja jetzt Ballast aus dem System geworfen. Also mehr PS pro Kilogramm.
                        mguenther
                        Also, großes Dank an die Supporter. Auch wenn ich glaube, dass es tatsächlich an der Spannungsversorgung hing, danke für die Tipps und Hilfestellungen. System läuft wieder wie zuvor, stabil, wenn nicht sogar gefühlt "schneller" :)
                        ich mache hier ein "gelöst" dran
                          mguenther
                          zu früh gefreut... habe ich eben bekommen:
                          2021-07-15 13:27:00.230  - info: host.raspberrypi4-iob instance system.adapter.daswetter.0 started with pid 5775
                          2021-07-15 13:27:07.335  - info: daswetter.0 (5775) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.2, js-controller: 3.2.16
                          2021-07-15 13:27:27.175  - info: unifi.0 (2844) Update done
                          2021-07-15 13:28:07.401  - error: daswetter.0 (5775) force terminate
                          2021-07-15 13:28:07.403  - warn: daswetter.0 (5775) Terminated (UNKNOWN_ERROR): Without reason
                          2021-07-15 13:28:07.925  - warn: daswetter.0 (5775) get state error: Connection is closed.
                          2021-07-15 13:28:07.927  - error: daswetter.0 (5775) exception in await insertIntoList [Error: DB closed]
                          2021-07-15 13:28:07.932  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.pressure_value": Connection is closed.
                          2021-07-15 13:28:07.934  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_3.pressure_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.pressure_value": Connection is closed.]
                          2021-07-15 13:28:07.936  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.clouds_value": Connection is closed.
                          2021-07-15 13:28:07.937  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_3.clouds_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.clouds_value": Connection is closed.]
                          2021-07-15 13:28:07.939  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.snowline_value": Connection is closed.
                          2021-07-15 13:28:07.940  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_3.snowline_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.snowline_value": Connection is closed.]
                          2021-07-15 13:28:07.942  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.windchill_value": Connection is closed.
                          2021-07-15 13:28:07.943  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_3.windchill_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_3.windchill_value": Connection is closed.]
                          2021-07-15 13:28:07.945  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4": Connection is closed.
                          2021-07-15 13:28:07.946  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4": Connection is closed.]
                          2021-07-15 13:28:07.948  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.current": Connection is closed.
                          2021-07-15 13:28:07.949  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.current: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.current": Connection is closed.]
                          2021-07-15 13:28:07.951  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.hour_value": Connection is closed.
                          2021-07-15 13:28:07.952  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4.hour_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.hour_value": Connection is closed.]
                          2021-07-15 13:28:07.954  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.temp_value": Connection is closed.
                          2021-07-15 13:28:07.956  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4.temp_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.temp_value": Connection is closed.]
                          2021-07-15 13:28:07.958  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc2": Connection is closed.
                          2021-07-15 13:28:07.959  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc2": Connection is closed.]
                          2021-07-15 13:28:07.961  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_value2": Connection is closed.
                          2021-07-15 13:28:07.962  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_value2": Connection is closed.]
                          2021-07-15 13:28:07.964  - error: daswetter.0 (5775) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc": Connection is closed.
                          2021-07-15 13:28:07.965  - error: daswetter.0 (5775) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_4.symbol_desc": Connection is closed.]
                          2021-07-15 13:28:07.992  - error: host.raspberrypi4-iob instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                          und kurz danach auch die 2. und dann die 3. Instanz.
                          dann:
                          2021-07-15 19:36:37.128  - info: dwd.1 (22272) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.2, js-controller: 3.2.16
                          2021-07-15 19:37:08.666  - info: dwd.1 (22272) force terminating after 4 minutes
                          2021-07-15 19:37:08.669  - info: dwd.1 (22272) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-07-15 19:37:09.763  - error: dwd.1 (22272) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2021-07-15 19:37:09.764  - error: dwd.1 (22272) unhandled promise rejection: DB closed
                          2021-07-15 19:37:09.770  - error: dwd.1 (22272) Error: DB closed
                              at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
                              at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
                              at Object.onceWrapper (events.js:421:26)
                              at Socket.emit (events.js:314:20)
                              at Socket.EventEmitter.emit (domain.js:483:12)
                              at TCP.<anonymous> (net.js:675:12)
                          2021-07-15 19:37:09.771  - error: dwd.1 (22272) DB closed
                          und auf der Console sagte er mir unter iobroker status "No Connection to database"...
                          ich weiß aber nicht, warum. Quasi aus heiterem Himmel eben...
                          • M mguenther
                            dann:
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @mguenther ich denke, du hast eher ein Netzwerkproblem
                              mguenther
                              @crunchip
                              und wie kommst du da drauf? Ich habe ein Glasfasernetz von Vodafone und der RP4 hängt direkt per LAN an meiner UDM Pro. Ich habe mit keinem Endgerät auch nur irgendein Problem.
                                mguenther
                                @crunchip
                                pi@raspberrypi4-iob:~ $ iobroker status
                                Objects type: file
                                States  type: file
                                Objects type: file
                                States  type: file
                                /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674
                                                res.forEach(aliveState => {
                                TypeError: Cannot read property 'forEach' of undefined
                                    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674:21)
                                    at processImmediate (internal/timers.js:463:21)
                                 Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                iobroker is not running on this host.
                                Objects type: file
                                States  type: file
                                Objects type: file
                                States  type: file
                                das habe ich übrigens eben erhalten. Ich verstehe das einfach nicht.
                                hier mein iobroker Logfile:
                                unifi.0	2021-07-16 00:48:22.765	error	(7580) fetchDevices: Returned data is not in valid format
                                host.raspberrypi4-iob	2021-07-16 00:48:18.413	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                daswetter.0	2021-07-16 00:48:18.284	info	(9082) cleaned everything up...
                                daswetter.0	2021-07-16 00:48:18.185	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextD
                                daswetter.0	2021-07-16 00:48:18.184	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wetterbedingungen_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.182	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1
                                daswetter.0	2021-07-16 00:48:18.181	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Tag_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.180	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:18.174	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.iconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.154	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Loc
                                daswetter.0	2021-07-16 00:48:18.153	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.151	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Lo
                                daswetter.0	2021-07-16 00:48:18.150	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_id2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.148	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.
                                daswetter.0	2021-07-16 00:48:18.147	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.146	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays
                                daswetter.0	2021-07-16 00:48:18.144	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wetter_Symbol_value2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.143	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location
                                daswetter.0	2021-07-16 00:48:18.141	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.windIconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.139	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:18.138	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wind_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.136	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.
                                daswetter.0	2021-07-16 00:48:18.135	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wind_idB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.133	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_
                                daswetter.0	2021-07-16 00:48:18.131	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wind_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.129	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location
                                daswetter.0	2021-07-16 00:48:18.125	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Wind_valueB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.123	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Maximale_Temperatur_value: Cannot check object existence of "daswetter.0.Nex
                                daswetter.0	2021-07-16 00:48:18.121	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Maximale_Temperatur_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.119	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7.Minimale_Temperatur_value: Cannot check object existence of "daswetter.0.Nex
                                daswetter.0	2021-07-16 00:48:18.116	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7.Minimale_Temperatur_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.114	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_7: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7": C
                                daswetter.0	2021-07-16 00:48:18.112	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_7": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.110	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextD
                                daswetter.0	2021-07-16 00:48:18.109	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wetterbedingungen_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.107	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1
                                daswetter.0	2021-07-16 00:48:18.105	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Tag_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.104	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:18.102	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.iconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.100	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Loc
                                daswetter.0	2021-07-16 00:48:18.099	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.097	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Lo
                                daswetter.0	2021-07-16 00:48:18.096	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_id2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.095	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.
                                daswetter.0	2021-07-16 00:48:18.094	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.092	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays
                                daswetter.0	2021-07-16 00:48:18.091	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wetter_Symbol_value2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.089	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location
                                daswetter.0	2021-07-16 00:48:18.082	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.windIconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.080	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:18.079	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wind_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.075	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.
                                daswetter.0	2021-07-16 00:48:18.073	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wind_idB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.048	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_
                                daswetter.0	2021-07-16 00:48:18.042	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wind_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.034	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location
                                daswetter.0	2021-07-16 00:48:18.017	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Wind_valueB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.014	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value: Cannot check object existence of "daswetter.0.Nex
                                daswetter.0	2021-07-16 00:48:18.007	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Maximale_Temperatur_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.005	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value: Cannot check object existence of "daswetter.0.Nex
                                daswetter.0	2021-07-16 00:48:18.003	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6.Minimale_Temperatur_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:18.001	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_6: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6": C
                                daswetter.0	2021-07-16 00:48:17.999	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_6": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.997	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wetterbedingungen_value: Cannot check object existence of "daswetter.0.NextD
                                daswetter.0	2021-07-16 00:48:17.995	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wetterbedingungen_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.993	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Tag_value: Cannot check object existence of "daswetter.0.NextDays.Location_1
                                daswetter.0	2021-07-16 00:48:17.991	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Tag_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.989	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.iconURL: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:17.987	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.iconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.985	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_id: Cannot check object existence of "daswetter.0.NextDays.Loc
                                daswetter.0	2021-07-16 00:48:17.983	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.980	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_id2: Cannot check object existence of "daswetter.0.NextDays.Lo
                                daswetter.0	2021-07-16 00:48:17.978	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_id2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.976	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_value: Cannot check object existence of "daswetter.0.NextDays.
                                daswetter.0	2021-07-16 00:48:17.974	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.972	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_value2: Cannot check object existence of "daswetter.0.NextDays
                                daswetter.0	2021-07-16 00:48:17.971	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wetter_Symbol_value2": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.969	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.windIconURL: Cannot check object existence of "daswetter.0.NextDays.Location
                                daswetter.0	2021-07-16 00:48:17.967	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.windIconURL": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.965	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wind_id: Cannot check object existence of "daswetter.0.NextDays.Location_1.D
                                daswetter.0	2021-07-16 00:48:17.963	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wind_id": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.961	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wind_idB: Cannot check object existence of "daswetter.0.NextDays.Location_1.
                                daswetter.0	2021-07-16 00:48:17.959	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wind_idB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.957	error	(9082) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDays.Location_1.Day_5.Wind_value: Cannot check object existence of "daswetter.0.NextDays.Location_
                                daswetter.0	2021-07-16 00:48:17.955	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wind_value": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.953	error	(9082) exception in await insertIntoList [Error: DB closed]
                                daswetter.0	2021-07-16 00:48:17.950	warn	(9082) get state error: Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.949	warn	(9082) Could not check object existence of state daswetter.0.NextDays.Location_1.Day_5.Wind_valueB: Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wind_valueB": Connection is
                                daswetter.0	2021-07-16 00:48:17.948	error	(9082) Cannot check object existence of "daswetter.0.NextDays.Location_1.Day_5.Wind_valueB": Connection is closed.
                                daswetter.0	2021-07-16 00:48:17.553	error	(9082) exception in await insertIntoList [Error: DB closed]
                                daswetter.0	2021-07-16 00:48:17.551	warn	(9082) get state error: Connection is closed.
                                daswetter.0	2021-07-16 00:48:16.770	warn	(9082) Terminated (UNKNOWN_ERROR): Without reason
                                daswetter.0	2021-07-16 00:48:16.768	error	(9082) force terminate
                                ich habe jetzt erst einmal die Instanzen von dasWetter gestoppt. Alle 3 laufen bei mir normalerweise so:
                                es hilft dann immer nur
                                Objects type: file
                                States  type: file
                                 Cannot read system.config: undefined (OK when migrating or restoring)
                                 Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                                Objects type: file
                                States  type: file
                                pi@raspberrypi4-iob:~ $ iobroker stop
                                pi@raspberrypi4-iob:~ $ iobroker start
                                Objects type: file
                                States  type: file
                                • M mguenther
                                  @crunchip
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @mguenther kann ja z.b. ein Lan Kabel defekt sein.
                                  Oder aber dein Netzteil vllt keine konstanten 5v bringen, oder oder oder...
                                  Kann viele Ursachen haben, war nur eine Vermutung meiner seits mit dem Netzwerk.
                                  • M mguenther
                                    @crunchip
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    Objects type: file
                                    States  type: file
                                    oder die Karte/SSD defekt
                                      mguenther
                                      @crunchip
                                      ich hatte sogar schon mein LAN-Kabel und auch den Port gewechselt - das schließe ich aus. Beim Netzteil werde ich etwas nervöser - ist das Original PI Netzteil für den PI4. Ich habe noch ein 2. Netzteil, ich tausche es einfach mal. Vielleicht hilft das ja schon....
                                        mguenther
                                        das wäre worstcase Szenario...
                                        Ich habe noch eine Synology und hatte schon einmal darüber nachgedacht, iobroker als docker-image laufen zu lassen. Problem ist aber, dass ich einen MODBUS RS485 USB-Stick und einen deconz-USB-Stick an dem RP4 habe. Momentan weiß ich noch nicht, wie ich die unter docker einbinden kann. Noch habe ich Version 6.xxx auf der Synology und da scheint es zu gehen. Bei einem Update auf 7.xxx scheint es Probleme zu geben...
                                        • M mguenther
                                          dann solltest du nicht alleine auf das Netzteil vertrauen.
                                          Nimm lieber einen aktiven HUB
