  4. Backup / Restore von Raspberry Pi auf Synology [gelöst]
    6.7k
46 Beiträge 6 Kommentatoren 5.2k Aufrufe 5 Beobachtet
  • Z ZoXx
    @homoran said in Backup / Restore von Raspberry Pi auf Synology:
    @zoxx Geht doch ;-)
    dann hat backitup auch wirklich noch nichts gemacht.
    Bitte ioBroker neu starten, backitup unter Instanzen im Expertenmodus auf Logstufe debug stellen, dann nochmal den restore anstoßen und das debug log posten
    backitup.0	2021-07-07 12:23:37.169	debug	(629) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
    backitup.0	2021-07-07 12:23:37.125	debug	(629) set chmod for "/opt/iobroker/backups" successfully
    backitup.0	2021-07-07 12:23:32.452	debug	(629) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
    backitup.0	2021-07-07 12:23:30.446	debug	(629) Backup list be read ...
    backitup.0	2021-07-07 12:23:26.827	debug	(629) telegram-instance: telegram.0
    backitup.0	2021-07-07 12:23:25.157	debug	(629) No backup file was found
    backitup.0	2021-07-07 12:23:25.079	info	(629) [iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0	2021-07-07 12:23:24.934	info	(629) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
    backitup.0	2021-07-07 12:23:24.563	debug	(629) Plugin sentry Initialize Plugin (enabled=true)
    backitup.0	2021-07-07 12:23:24.106	debug	(629) statesDB connected
    backitup.0	2021-07-07 12:23:24.105	debug	(629) States connected to redis: 127.0.0.1:9000
    backitup.0	2021-07-07 12:23:24.046	debug	(629) States create User PubSub Client
    backitup.0	2021-07-07 12:23:24.043	debug	(629) States create System PubSub Client
    backitup.0	2021-07-07 12:23:24.030	debug	(629) Redis States: Use Redis connection: 127.0.0.1:9000
    backitup.0	2021-07-07 12:23:24.026	debug	(629) objectDB connected
    backitup.0	2021-07-07 12:23:24.011	debug	(629) Objects connected to redis: 127.0.0.1:9001
    backitup.0	2021-07-07 12:23:23.989	debug	(629) Objects client initialize lua scripts
    backitup.0	2021-07-07 12:23:23.987	debug	(629) Objects create User PubSub Client
    backitup.0	2021-07-07 12:23:23.985	debug	(629) Objects create System PubSub Client
    backitup.0	2021-07-07 12:23:23.981	debug	(629) Objects client ready ... initialize now
    backitup.0	2021-07-07 12:23:23.920	debug	(629) Redis Objects: Use Redis connection: 127.0.0.1:9001
    backitup.0	2021-07-07 12:23:17.437	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.436	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.434	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.429	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.428	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.427	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.426	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.425	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.424	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.414	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.411	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.410	warn	(614) get state error: Connection is closed.
    backitup.0	2021-07-07 12:23:17.394	warn	(614) redis get backitup.0.history.iobrokerLastTime, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.393	warn	(614) redis get backitup.0.history.html, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.392	warn	(614) redis get backitup.0.history.json, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.391	warn	(614) redis get backitup.0.history.iobrokerSuccess, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.390	warn	(614) redis get backitup.0.history.ccuSuccess, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.389	warn	(614) redis get backitup.0.oneClick.ccu, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.388	warn	(614) redis get backitup.0.oneClick.iobroker, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.388	warn	(614) redis get backitup.0.history.ccuLastTime, error - Connection is closed.
    backitup.0	2021-07-07 12:23:17.383	debug	(614) No backup file was found
    backitup.0	2021-07-07 12:23:17.309	info	(614) [iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0	2021-07-07 12:23:17.168	info	(614) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
    backitup.0	2021-07-07 12:23:16.788	info	(614) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    backitup.0	2021-07-07 12:23:16.787	debug	(614) Plugin sentry destroyed
    backitup.0	2021-07-07 12:23:16.772	debug	(614) statesDB connected
    backitup.0	2021-07-07 12:23:16.770	debug	(614) States connected to redis: 127.0.0.1:9000
    backitup.0	2021-07-07 12:23:16.744	debug	(614) States create User PubSub Client
    backitup.0	2021-07-07 12:23:16.742	debug	(614) States create System PubSub Client
    backitup.0	2021-07-07 12:23:16.727	debug	(614) Redis States: Use Redis connection: 127.0.0.1:9000
    backitup.0	2021-07-07 12:23:16.723	debug	(614) objectDB connected
    backitup.0	2021-07-07 12:23:16.704	debug	(614) Objects connected to redis: 127.0.0.1:9001
    backitup.0	2021-07-07 12:23:16.672	debug	(614) Objects client initialize lua scripts
    backitup.0	2021-07-07 12:23:16.670	debug	(614) Objects create User PubSub Client
    backitup.0	2021-07-07 12:23:16.668	debug	(614) Objects create System PubSub Client
    backitup.0	2021-07-07 12:23:16.664	debug	(614) Objects client ready ... initialize now
    backitup.0	2021-07-07 12:23:16.602	debug	(614) Redis Objects: Use Redis connection: 127.0.0.1:9001
    backitup.0	2021-07-07 12:23:08.483	info	(171) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-07-07 12:23:08.480	info	(171) terminating
    backitup.0	2021-07-07 12:23:08.478	info	(171) cleaned everything up...
    backitup.0	2021-07-07 12:23:08.475	info	(171) Got terminate signal TERMINATE_YOURSELF
    @zoxx sagte in Backup / Restore von Raspberry Pi auf Synology:
    was sagt
    iobroker status
    EDIT:
    nee, scheint zu passen
    aber:
    also nochmal zum Anfang!
    @wendy2702 sagte in Backup / Restore von Raspberry Pi auf Synology:
    Und wie genau hast du das restore gemacht?
    Z 1 Antwort Letzte Antwort
      was sagt
      iobroker status
      EDIT:
      aber:
      Z Offline
      Z Offline
      ZoXx
      iobroker status
      Objects type: file
      States  type: file
      • Z ZoXx
        iobroker status
        Objects type: file
        States  type: file
        @zoxx Danke - hab`s gerade editiert
        • Z ZoXx
          iobroker status
          Objects type: file
          States  type: file
          @zoxx lief Redis auf dem RasPi?
          • wendy2702W Offline
            wendy2702W Offline
            @Homoran : sieht so aus.
            Vorher Redis jetzt File. Denke dem fehlt jetzt Redis.
            • wendy2702W wendy2702
              sieht so aus.
              genau!
              @ZoXx
              was sagt denn der RasPi bei iobroker status?
              Z 2 Antworten Letzte Antwort
                sieht so aus.
                genau!
                @ZoXx
                Z Offline
                Z Offline
                ZoXx
                Okay alles klar, Sekunde ich checke es eben.
                  sieht so aus.
                  genau!
                  @ZoXx
                  Z Offline
                  Z Offline
                  ZoXx
                  schrieb am zuletzt editiert von ZoXx
                  @ZoXx
                  Objects type: file
                  States  type: file
                  • Z ZoXx
                    @ZoXx
                    Objects type: file
                    States  type: file
                    @zoxx Danke!
                    Dann muss jetzt ein Docker-kundiger ran warum die Verbindung geschlossen wird
                      @zoxx Danke!
                      Z Offline
                      Z Offline
                      ZoXx
                      @homoran gibt es denn im Forum Docker Spezialisten, welche verlinkt werden können?
                      • Z ZoXx
                        da_WoodyD Offline
                        da_WoodyD Offline
                        @zoxx bin zwar kein dockerianer, aber hast du noch DSM6, oder schon DSM7 auf der syno?
                        bei der neuen 7er spinnt noch einiges rum. z.b. PLEX hat auch probleme damit.
                        • GlasfaserG Offline
                          GlasfaserG Offline
                          Problem ist jedoch, wenn ich ein Backup aus dem Raspberry Pi einspiele.
                          . Jedoch startet zwar der restore, allerdings passiert selbst nach ca. 2 Stunden nichts.
                          Nimm den Fußweg :
                          https://forum.iobroker.net/topic/46155/umzug-von-einem-docker-in-einen-anderen
                          • Z ZoXx
                            aber auf dem Pi hattest du doch mit puTTY gearbeitet, dann muss das hier doch auch gehen.
                            Genau, da läuft das System aber direkt so installiert.
                            kenne mich mit Docker nicht aus
                            Ich bin dort auch Neuling, muss mich in den Docker einloggen und dann schauen, Der meckert aber noch bei Synology immer, wenn ich da rein möchte.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Welches Problem hast du noch , siehe hier ?
                            https://forum.iobroker.net/topic/30656/zugriff-auf-iobroker-nicht-mehr-möglich/12
                            • da_WoodyD da_Woody
                              Z Offline
                              Z Offline
                              ZoXx
                              @da_woody said in Backup / Restore von Raspberry Pi auf Synology:
                              bin auf dem neuen 7er seit letzte Woche. Läuft bisher tatsächlich tadellos.
                              • GlasfaserG Glasfaser
                                Nimm den Fußweg :
                                Z Offline
                                Z Offline
                                ZoXx
                                @glasfaser said in Backup / Restore von Raspberry Pi auf Synology:
                                Nimm den Fußweg :
                                habe es mal so angeschmissen. Ich berichte! :)
                                Problem war eher, dass der Reverse Proxy angepasst werden musste, damit ich überhaupt Zugriff wieder erlange.
                                • Z ZoXx
                                  Nimm den Fußweg :
                                  Z Offline
                                  Z Offline
                                  ZoXx
                                  @da_Woody backup ist durchgelaufen, kann jedoch den Container nicht mehr auflösen.
                                  Folgende Fehlermeldung in Chrome: ERR_EMPTY_RESPONSE
                                  Ich kopiere mal den Log:
                                  2021-07-07 20:07:29.311  - info: host.IoBroker received SIGTERM
                                  2021-07-07 20:07:29.318  - info: admin.0 (110) terminating http server on port 8081
                                  2021-07-07 20:07:29.319  - info: info.0 (152) cleaned everything up...
                                  2021-07-07 20:07:29.332  - info: backitup.0 (629) cleaned everything up...
                                  2021-07-07 20:07:29.331  - info: host.IoBroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                  2021-07-07 20:07:29.332  - info: host.IoBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                  2021-07-07 20:07:29.334  - info: host.IoBroker stopInstance system.adapter.info.0 (force=false, process=true)
                                  2021-07-07 20:07:29.336  - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                  2021-07-07 20:07:29.352  - info: admin.0 (110) Got terminate signal TERMINATE_YOURSELF
                                  2021-07-07 20:07:29.355  - info: info.0 (152) Got terminate signal TERMINATE_YOURSELF
                                  2021-07-07 20:07:29.354  - info: discovery.0 (125) Got terminate signal TERMINATE_YOURSELF
                                  2021-07-07 20:07:29.356  - info: backitup.0 (629) Got terminate signal TERMINATE_YOURSELF
                                  2021-07-07 20:07:29.362  - info: discovery.0 (125) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-07-07 20:07:29.363  - info: host.IoBroker stopInstance system.adapter.admin.0 send kill signal
                                  2021-07-07 20:07:29.364  - info: info.0 (152) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-07-07 20:07:29.365  - info: admin.0 (110) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-07-07 20:07:29.366  - debug: backitup.0 (629) Plugin sentry destroyed
                                  2021-07-07 20:07:29.367  - info: backitup.0 (629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2021-07-07 20:07:29.401  - info: host.IoBroker stopInstance system.adapter.discovery.0 send kill signal
                                  2021-07-07 20:07:29.402  - info: host.IoBroker stopInstance system.adapter.info.0 send kill signal
                                  2021-07-07 20:07:29.403  - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                  2021-07-07 20:07:30.224  - info: host.IoBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-07-07 20:07:30.275  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-07-07 20:07:30.278  - info: host.IoBroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-07-07 20:07:30.279  - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2021-07-07 20:07:30.280  - info: host.IoBroker All instances are stopped.
                                  2021-07-07 20:07:30.374  - info: host.IoBroker terminated
                                  2021-07-07 20:35:29.873  - info: host.98f3f68508a4 iobroker.js-controller version 3.2.16 js-controller starting
                                  2021-07-07 20:35:29.883  - info: host.98f3f68508a4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                  2021-07-07 20:35:29.884  - info: host.98f3f68508a4 hostname: 98f3f68508a4, node: v12.22.1
                                  2021-07-07 20:35:29.886  - info: host.98f3f68508a4 ip addresses: 172.17.0.6
                                  2021-07-07 20:35:30.785  - info: host.98f3f68508a4 connected to Objects and States
                                  2021-07-07 20:35:30.901  - info: host.98f3f68508a4 added notifications configuration of host
                                  2021-07-07 20:35:31.880  - info: host.98f3f68508a4 Delete host system.host.IoBroker
                                  2021-07-07 20:35:31.981  - info: host.98f3f68508a4 28 instances found
                                  2021-07-07 20:35:32.016  - warn: host.98f3f68508a4 does not start any instances on this host
                                  • Z ZoXx
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Mach nochmal :
                                    pkill -u iobroker
                                    iobroker host this
                                    und danach den Container neu starten .
                                    EDIT :
                                    was ist das denn , hast du so ein Netzwerk :
                                    Thomas BraunT Z 2 Antworten Letzte Antwort
                                      Mach nochmal :
                                      pkill -u iobroker
                                      iobroker host this
                                      EDIT :
                                      @glasfaser Extravagant, aber ein zugelassener Private IP-Bereich.
                                        Mach nochmal :
                                        pkill -u iobroker
                                        iobroker host this
                                        EDIT :
                                        Z Offline
                                        Z Offline
                                        ZoXx
        pkill -u iobroker        iobroker host this
                                        Anbei der Log als Screenhot.
                                        EDIT :
                                        Negativ, stammt evtl. vom Docker selbst?
                                        • Z ZoXx
                                          EDIT :
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Was negativ ?
                                          Keine Ahnung was du da hast ,
                                          Welche IP hat denn deine Syn , hast du die gleiche dann für ioBroker , oder hast du was anderes eingestellt .
                                          Nutzt du Host oder Bridge-Modus .
                                          Funktioniert jetzt ioBroker ?
