  4. zigbee Adapter startet nicht mehr nach node 14 update
    6.7k
9 Beiträge 4 Kommentatoren 290 Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    wilyfox
    mein zigbee Adapter startet nicht mehr nach dem Update von Node auf die Version 14.
    Bin um jede Hilfe dankbar.
    Die logs bringen mich nicht weiter
    2021-07-05 22:48:02.343 - info: host.raspberrypi Restart adapter system.adapter.zigbee.1 because enabled
    2021-07-05 22:48:32.375 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 1585
    2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
    2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: throw e;
    2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: ^
    2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
    2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
    2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2021-07-05 22:48:33.065 - error: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-07-05 22:48:33.066 - info: host.raspberrypi Restart adapter system.adapter.zigbee.1 because enabled
    Mod-Edit: Code in </> Code-Tag gepackt!
    • W wilyfox
      @wilyfox Bitte CodeTags für die Auszüge aus dem Log verwenden.
      Die node-Installation ist senkrecht?
      W 1 Antwort Letzte Antwort
        W Offline
        W Offline
        wilyfox
        @thomas-braun CodeTags werde ich mir merken.
        Ich denke das die node-Installation funktioniert hat. Kann ich das prüfen?
        Thomas BraunT AsgothianA 3 Antworten Letzte Antwort
        -1
        • W wilyfox
          @wilyfox Du sollst dir das nicht merken, du sollst die verwenden. Editier deinen Post oben.
          Lies den Link in meiner Signatur bezüglich node.
          Ich glaube aber du hast dir da irgendwie 64bit Code auf deinen Raspberry gebügelt. Das geht nicht.
          • W wilyfox
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @wilyfox hast du nach dem update ein “npm rebuild” durchgeführt ?
            A.
            • W wilyfox
              @wilyfox
              Das riecht nach 'NodeJS nicht richtig installiert'.
              Das Paket aus dem libnode.so.64 kommt sollte gar nicht nicht benötigt werden.
              • AsgothianA Asgothian
                A.
                Jan1
                @asgothian sagte in zigbee Adapter startet nicht mehr nach node 14 update:
                A.
                Sollte das mittlerweile nicht automatisch laufen?
                Hatte mal die Node 16 getestet, eigentlich keine Probleme damit und kein manuelles rebuild durchgeführt.
                Lief selbst mit NPM 7 ohne Fehler.
                • J Jan1
                  A.
                  @jan1
                  Ja, läuft meist automatisch im Hintergrund. Setzt allerdings ein saubere Grundinstallation voraus. Hier ist aber vermutlich irgendwas irgendwie krumm installiert worden.
                    @jan1
                    Jan1
                    Die Befürchtung habe ich allerdings auch.
                    Da Du hier genau der Richtige fürs gerade ziehen bist, bin ich schon wieder weg. Wollte nur wegen dem Rebuilt nachfragen und das hast beantwortet.
