<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[zigbee Adapter startet nicht mehr nach node 14 update]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">mein zigbee Adapter startet nicht mehr nach dem Update von Node auf die Version 14.<br />
Bin um jede Hilfe dankbar.</p>
<p dir="auto">Die logs bringen mich nicht weiter</p>
<pre><code>2021-07-05 22:48:02.343 - info: host.raspberrypi Restart adapter system.adapter.zigbee.1 because enabled
2021-07-05 22:48:32.375 - info: host.raspberrypi instance system.adapter.zigbee.1 started with pid 1585
2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: throw e;
2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: ^
2021-07-05 22:48:33.063 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:14)
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
2021-07-05 22:48:33.064 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
2021-07-05 22:48:33.065 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
2021-07-05 22:48:33.065 - error: host.raspberrypi instance system.adapter.zigbee.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
2021-07-05 22:48:33.066 - info: host.raspberrypi Restart adapter system.adapter.zigbee.1 because enabled
</code></pre>
<hr />
<p dir="auto"><em><strong><span style="color:#ff0000">Mod-Edit:</span></strong></em> Code in &lt;/&gt; Code-Tag gepackt!</p>
]]></description><link>https://forum.iobroker.net/topic/46225/zigbee-adapter-startet-nicht-mehr-nach-node-14-update</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 05:20:01 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46225.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Jul 2021 20:58:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Tue, 13 Jul 2021 08:26:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Die Befürchtung habe ich allerdings auch.<br />
Da Du hier genau der Richtige fürs gerade ziehen bist, bin ich schon wieder weg. Wollte nur wegen dem Rebuilt nachfragen und das hast beantwortet.</p>
]]></description><link>https://forum.iobroker.net/post/652878</link><guid isPermaLink="true">https://forum.iobroker.net/post/652878</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Tue, 13 Jul 2021 08:26:32 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Tue, 13 Jul 2021 08:24:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan1" aria-label="Profile: jan1">@<bdi>jan1</bdi></a></p>
<p dir="auto">Ja, läuft meist automatisch im Hintergrund. Setzt allerdings ein saubere Grundinstallation voraus. Hier ist aber vermutlich irgendwas irgendwie krumm installiert worden.</p>
]]></description><link>https://forum.iobroker.net/post/652877</link><guid isPermaLink="true">https://forum.iobroker.net/post/652877</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 13 Jul 2021 08:24:32 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Tue, 13 Jul 2021 08:06:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: asgothian">@<bdi>asgothian</bdi></a> sagte in <a href="/post/650326">zigbee Adapter startet nicht mehr nach node 14 update</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilyfox" aria-label="Profile: wilyfox">@<bdi>wilyfox</bdi></a> hast du nach dem update ein “npm rebuild” durchgeführt ?</p>
<p dir="auto">A.</p>
</blockquote>
<p dir="auto">Sollte das mittlerweile nicht automatisch laufen?<br />
Hatte mal die Node 16 getestet, eigentlich keine Probleme damit und kein manuelles rebuild durchgeführt.<br />
Lief selbst mit NPM 7 ohne Fehler.</p>
]]></description><link>https://forum.iobroker.net/post/652872</link><guid isPermaLink="true">https://forum.iobroker.net/post/652872</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Tue, 13 Jul 2021 08:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Tue, 13 Jul 2021 07:44:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilyfox" aria-label="Profile: wilyfox">@<bdi>wilyfox</bdi></a></p>
<pre><code>Error: libnode.so.64: cannot open shared object file: No such file or directory
</code></pre>
<p dir="auto">Das riecht nach 'NodeJS nicht richtig installiert'.<br />
Das Paket aus dem libnode.so.64 kommt sollte gar nicht nicht benötigt werden.</p>
]]></description><link>https://forum.iobroker.net/post/652870</link><guid isPermaLink="true">https://forum.iobroker.net/post/652870</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 13 Jul 2021 07:44:55 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Tue, 06 Jul 2021 04:21:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilyfox" aria-label="Profile: wilyfox">@<bdi>wilyfox</bdi></a> hast du nach dem update ein “npm rebuild” durchgeführt ?</p>
]]></description><link>https://forum.iobroker.net/post/650326</link><guid isPermaLink="true">https://forum.iobroker.net/post/650326</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Tue, 06 Jul 2021 04:21:57 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Mon, 05 Jul 2021 21:21:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilyfox" aria-label="Profile: wilyfox">@<bdi>wilyfox</bdi></a> Du sollst dir das nicht merken, du sollst die verwenden. Editier deinen Post oben.</p>
<p dir="auto">Lies den Link in meiner Signatur bezüglich node.<br />
Ich glaube aber du hast dir da irgendwie 64bit Code auf deinen Raspberry gebügelt. Das geht nicht.</p>
]]></description><link>https://forum.iobroker.net/post/650316</link><guid isPermaLink="true">https://forum.iobroker.net/post/650316</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 05 Jul 2021 21:21:26 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Mon, 05 Jul 2021 21:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> CodeTags werde ich mir merken.</p>
<p dir="auto">Ich denke das die node-Installation funktioniert hat. Kann ich das prüfen?</p>
]]></description><link>https://forum.iobroker.net/post/650314</link><guid isPermaLink="true">https://forum.iobroker.net/post/650314</guid><dc:creator><![CDATA[wilyfox]]></dc:creator><pubDate>Mon, 05 Jul 2021 21:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to zigbee Adapter startet nicht mehr nach node 14 update on Mon, 05 Jul 2021 21:06:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilyfox" aria-label="Profile: wilyfox">@<bdi>wilyfox</bdi></a> Bitte CodeTags für die Auszüge aus dem Log verwenden.</p>
<p dir="auto">Die node-Installation ist senkrecht?</p>
]]></description><link>https://forum.iobroker.net/post/650312</link><guid isPermaLink="true">https://forum.iobroker.net/post/650312</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 05 Jul 2021 21:06:29 GMT</pubDate></item></channel></rss>
