  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • T tombox
    @bmueller77 ich kann nur das anzeigen was in der App sichtbar ist
    bmueller77B Offline
    bmueller77B Offline
    bmueller77
    #902
    @tombox Okay, dachte ich mir schon. Dann hoffe ich auf ein baldiges Update der App zu Position und dem Zustand der Türen (offen, geschlossen, verriegelt).
    • E Exile82
      @tombox yes, that might be correct. But I have entered my login credentials, don't know what to do.
      I tried to remove the instance and reinstall 0.30 version.
      When i intentionally enter wrong password, I get this:
      When I enter the correct password, I get this:
      I know I have done this correct, as it worked flawlessy just before I upgraded to .33 version
      rabru
      #903
      @exile82 , I run into the exact same issue with the same error messages, without upgrading it. Since one or two days I lost the connection towards VW-Connect. I removed the complete Adapter and installed it new, but no success. I found it strange, that I can see only v0.30 as the newest version. Not sure if this is related.
      I did yesterday an upgrade from nodejs v10 to v12. Maybe this could have an impact. So I failed back to v10, but still it doesn't work.
      Did you get it working in the meantime?
      • E Exile82
        rabru
        #904
        @exile82 @tombox
        I finally found the following Issue:
        https://github.com/TA2k/ioBroker.vw-connect/issues/119
        A lot of work for nothing. VW is definitely not automation minded.
        • T tombox
          bmueller77B Offline
          bmueller77B Offline
          bmueller77
          #905
          @tombox Welcher Wert steht denn für die Lenkradheizung? Ist für den ID über die App steuerbar aber ich finde in den Objects nicht den passenden Eintrag.
          • bmueller77B bmueller77
            TiDO
            #906
            @tombox
            habe gerade auf 0.0.36 aktualsisiert.
            Nun kommt folgender Fehler:
            vw-connect.0	2021-06-18 09:01:56.504	error	(11256) status update Failed WVWZZZxxxxxx
            vw-connect.0	2021-06-18 09:01:56.503	debug	(11256) error while getting $homeregion/fs-car/bs/dwap/v1/$type/$country/vehicles/$vin/history
            vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/bs/rs/v1/$type/$country/vehicles/$vin/status
            vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/bs/batterycharge/v1/$type/$country/vehicles/$vin/charger
            vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/destinationfeedservice/mydestinations/v1/$type/$country/vehicles/$vin/destinations
            vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/vsr/v1/$type/$country/vehicles/$vin/status
            vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/cf/v1/$type/$country/vehicles/$vin/position
            vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/climatisation/v1/$type/$country/vehicles/$vin/climater
            vw-connect.0	2021-06-18 09:01:56.500	debug	(11256) error while getting $homeregion/fs-car/bs/departuretimer/v1/$type/$country/vehicles/$vin/timer
            vw-connect.0	2021-06-18 09:01:56.500	error	(11256) Error: Invalid URI "undefined/fs-car/bs/dwap/v1/Wc/DE/vehicles/WVWZZZxxxxxx/history"
            vw-connect.0	2021-06-18 09:01:56.499	error	(11256) Error: Invalid URI "undefined/fs-car/bs/rs/v1/Wc/DE/vehicles/WVWZZZxxxxxx/status"
            vw-connect.0	2021-06-18 09:01:56.498	error	(11256) Error: Invalid URI "undefined/fs-car/bs/batterycharge/v1/Wc/DE/vehicles/WVWZZZxxxxxx/charger"
            vw-connect.0	2021-06-18 09:01:56.497	error	(11256) Error: Invalid URI "undefined/fs-car/destinationfeedservice/mydestinations/v1/Wc/DE/vehicles/WVWZZZxxxxxx/destinations"
            vw-connect.0	2021-06-18 09:01:56.496	error	(11256) Error: Invalid URI "undefined/fs-car/bs/vsr/v1/Wc/DE/vehicles/WVWZZZxxxxxx/status"
            vw-connect.0	2021-06-18 09:01:56.495	error	(11256) Error: Invalid URI "undefined/fs-car/bs/cf/v1/Wc/DE/vehicles/WVWZZZxxxxxx/position"
            vw-connect.0	2021-06-18 09:01:56.494	error	(11256) Error: Invalid URI "undefined/fs-car/bs/climatisation/v1/Wc/DE/vehicles/WVWZZZxxxxxx/climater"
            vw-connect.0	2021-06-18 09:01:56.493	error	(11256) Error: Invalid URI "undefined/fs-car/bs/departuretimer/v1/Wc/DE/vehicles/WVWZZZxxxxxx/timer"
            vw-connect.0	2021-06-18 09:01:56.489	error	(11256) get vehicle data Failed
            vw-connect.0	2021-06-18 09:01:56.489	error	(11256) Error: Invalid URI "undefined/fs-car/bs/vsr/v1/Wc/DE/vehicles/WVWZZZxxxxxx/requests"
            vw-connect.0	2021-06-18 09:01:56.488	error	(11256) WVWZZZxxxxxx
            vw-connect.0	2021-06-18 09:01:56.486	error	(11256) Error: Invalid URI "undefined/fs-car/vehicleMgmt/vehicledata/v2/Wc/DE/vehicles/WVWZZZxxxxxx/"
            vw-connect.0	2021-06-18 09:01:56.483	debug	(11256) get home region Failed WVWZZZxxxxxx
            vw-connect.0	2021-06-18 09:01:56.482	error	(11256) 400
            vw-connect.0	2021-06-18 09:01:56.266	debug	(11256) getHomeRegion
            • T TiDO
              @tombox
              tombox
              #907
              @tido Der Fehler für ID Fahrzeuge ist mit 0.0.37 gefixt
              • T tombox
                Sneak-L8
                #908
                @tombox Adapter läuft mit 0.3.37. Bei mir kommen jetzt folgende Warnungen:
                vw-connect.0	2021-06-18 10:18:46.040	warn	(21140) This object will not be created in future versions. Please report this to the developer.
                vw-connect.0	2021-06-18 10:18:46.039	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status03 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                vw-connect.0	2021-06-18 10:18:46.039	warn	(21140) This object will not be created in future versions. Please report this to the developer.
                vw-connect.0	2021-06-18 10:18:46.038	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status02 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                vw-connect.0	2021-06-18 10:18:46.037	warn	(21140) This object will not be created in future versions. Please report this to the developer.
                vw-connect.0	2021-06-18 10:18:46.036	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status01 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                Das sind im Vergleich zu vorher relativ viele Status. Nix großes, aber zur Info...
                • S Sneak-L8
                  tombox
                  #909
                  @sneak-l8 lösche mal die objekte und probiere mit der aktuellen github version nochmal ob der fehler kommt
                  • T tombox
                    Sneak-L8
                    #910
                    @tombox War mein ersten Schritt, hab die WebRadio-State bzw. den Chanel gelöscht und neu gestartet. Gerade nochmal WebRadio gelöscht, von git installiert und neu gestartet. Leider gleiches Problem.
                    • S Sneak-L8
                      tombox
                      #911
                      @sneak-l8 nochmal bitte
                      • T tombox
                        Sneak-L8
                        #912
                        @tombox Jetzt past's, danke!
                          AndreasK
                          schrieb am zuletzt editiert von AndreasK
                          #913
                          Hallo.
                          Ich versuche aktuell den Adapter in Gang zu bekommen.
                          Es funktioniert leider nicht.
                          Ich bekomme im Log immer „No Token received“ ausgeben.
                          Ich habe die Zugangs-Daten der WeConnect App und auch den richtigen S-PIN eingetragen. Mehrfach geprüft.
                          VW ausgewählt, da ich einen Passat habe.
                          Was mache ich falsch?
                          Nutze die Version 0.0.39
                          Andreas
                          flkontaktF T 2 Antworten Letzte Antwort
                          • A AndreasK
                            Hallo.
                            Andreas
                            flkontaktF Online
                            flkontaktF Online
                            flkontakt
                            #914
                            @andreask mal mit VWv2 testen, damit läuft es bei mir, ebenfalls passat01.JPG
                            A T 2 Antworten Letzte Antwort
                            • A AndreasK
                              Hallo.
                              Andreas
                              tombox
                              #915
                              @andreask Du kannst entweder den Adapter in debug setzen und mit den log schicken oder Zugangsdaten damit ich es selber testen kann. Die App funktioniert ohne Probleme?
                              • flkontaktF flkontakt
                                AndreasK
                                #916
                                @flkontakt said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                Super. Funktioniert jetzt. Danke
                                  tombox
                                  #917
                                  @flkontakt welche Baujahre sind eure Autos
                                  flkontaktF 1 Antwort Letzte Antwort
                                  • T tombox
                                    flkontaktF Online
                                    flkontaktF Online
                                    flkontakt
                                    #918
                                    @tombox 2021, CB531Z
                                      Backes
                                      schrieb am zuletzt editiert von Backes
                                      #919
                                      Hallo tombox,
                                      ich hatte auf Github (Github-Issue #86) schonmal als Issue aufgemacht, die Unterstützung für Skoda/Seat/Cupra Wallboxen nachzupflegen. Dabei erwähntest du, dass du Zugangsdaten bräuchtest oder man mit dir hier in Kontakt treten sollte. Da mir meine Zugangsdaten heilig sind, bin ich da doch zwiegespalten. Ansonsten würde ich aber auch selbst gern helfen an der Integration der Powerpass-Schnittstelle (ähnlich WeCharge, allerdings bei Skoda) zu entwickeln. Notfalls könnte man natürlich auch einen Test-Account bei Powerpass erstellen damit man dran kommt.
                                      Ich gehe davon aus, dass im ersten Schritt die Endpunkte zum Backend herausgefunden werden müssten. Wie würdest du dort vorgehen? Reverse-Proxy? MITM und dann mittels Wireshark mitsniffen? Sofern du natürlich noch eine einfachere Variante hast gerne her damit. Dann würde ich mit meiner Wallbox (iV Charger Connect+) und Account durchtesten und Infos liefern bzw. selbst einen Branch machen und einen Pull-Request erstellen.
                                      Beste Grüße
                                      Backes
                                      • B Backes
                                        Hallo tombox,
                                        Beste Grüße
                                        Backes
                                        tombox
                                        #920
                                        @backes Die Github Version unterstützt cupra elli wallbox bitte installieren und testen
                                          Backes
                                          #921
                                          @tombox
                                          2021-07-09 14:50:02.873 - error: vw-connect.0 (4769) Failed in first login step
                                          2021-07-09 14:50:02.877 - error: vw-connect.0 (4769) 500
                                          2021-07-09 14:50:02.879 - error: vw-connect.0 (4769) "\n\n\n\n \n \n \n \n\n\n
                                          \n
                                          \n
                                          Something went wrong
                                          \n
                                          \n Please try again.\n
                                          \n
                                          \n If the problem continues contact support.\n
                                          \n
                                          \n\n
                                          \n Error code: XYZ _PLATZHALTER_XYZ\n
                                          \n\n\n
                                          \n\n\n\n\n\n\n\n\n"
                                          2021-07-09 14:50:02.883 - error: vw-connect.0 (4769) Login Failed
                                          Eintrag im Log bei der Nutzung vom Elli-Cupra Adapter bei Nutzung einer Skoda Wallbox.
                                          Error-Code kann ich dir gern per PN schicken, falls benötigt.
                                          Ich denke jeder Hersteller hat da seine eigenen Anpassungen.
