  4. Asterisk bringt "Error while dialing (2). Error: {}"
    6.4k
116 Beiträge 10 Kommentatoren 20.1k Aufrufe 11 Beobachtet
    @andiber
    Was stand jetzt als Rückmeldung im Terminal?
    andiber
    @thomas-braun Gar nichts, beide Befehle sind ohne Fehlermeldung durchgelaufen, es endete jeweils mit der normalen Eigabeaufforderung.
    • A andiber
      @andiber
      Dann mal ein
      sudo apt install --reinstall asterisk
      V 1 Antwort Letzte Antwort
        @andiber
        Dann mal ein
        V Offline
        V Offline
        varg
        schrieb am zuletzt editiert von varg
        Installation anhand dieser Anleitung Git
        Befehle ergeben:
        pi@pio4gb:/ $ sudo dpkg-reconfigure --priority=low asterisk-voicemail
        /usr/sbin/dpkg-reconfigure: asterisk-voicemail is broken or not fully installed
        /usr/sbin/dpkg-reconfigure: asterisk is broken or not fully installed
        pi@pio4gb:/ $ ^C
        Installation sieht immer noch so aus:
        i@pio4gb:/ $ sudo apt install asterisk
        Reading package lists... Done
        Building dependency tree
        The following additional packages will be installed:
          asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
          asterisk-modules asterisk-moh-opsound-gsm asterisk-voicemail freetds-common
          libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0
          libmariadb3 libneon27-gnutls libodbc1 libpq5 libradcli4 libresample1
          libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5
          libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
        Suggested packages:
          asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus
          asterisk-vpb libmyodbc odbc-postgresql tdsodbc unixodbc-bin
          snmp-mibs-downloader
        The following NEW packages will be installed:
          asterisk asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
        0 upgraded, 31 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/18.6 MB of archives.
        After this operation, 39.2 MB of additional disk space will be used.
        Do you want to continue? [Y/n] Y
        Extracting templates from packages: 100%
        Selecting previously unselected package asterisk-config.
        (Reading database ... 50667 files and directories currently installed.)
        Preparing to unpack .../00-asterisk-config_1%3a16.2.1~dfsg-1+deb10u2_all.deb ...
        Unpacking asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
        Selecting previously unselected package asterisk-core-sounds-en-gsm.
        Preparing to unpack .../01-asterisk-core-sounds-en-gsm_1.6.1-1_all.deb ...
        Unpacking asterisk-core-sounds-en-gsm (1.6.1-1) ...
        Selecting previously unselected package asterisk-core-sounds-en.
        Preparing to unpack .../02-asterisk-core-sounds-en_1.6.1-1_all.deb ...
        Unpacking asterisk-core-sounds-en (1.6.1-1) ...
        Selecting previously unselected package libgpgme11:armhf.
        Preparing to unpack .../03-libgpgme11_1.12.0-6_armhf.deb ...
        Unpacking libgpgme11:armhf (1.12.0-6) ...
        Selecting previously unselected package libgmime-3.0-0:armhf.
        Preparing to unpack .../04-libgmime-3.0-0_3.2.1-1_armhf.deb ...
        Unpacking libgmime-3.0-0:armhf (3.2.1-1) ...
        Selecting previously unselected package libical3:armhf.
        Preparing to unpack .../05-libical3_3.0.4-3_armhf.deb ...
        Unpacking libical3:armhf (3.0.4-3) ...
        Selecting previously unselected package libiksemel3:armhf.
        Preparing to unpack .../06-libiksemel3_1.4-3+b1_armhf.deb ...
        Unpacking libiksemel3:armhf (1.4-3+b1) ...
        Selecting previously unselected package liblua5.1-0:armhf.
        Preparing to unpack .../07-liblua5.1-0_5.1.5-8.1+b1_armhf.deb ...
        Unpacking liblua5.1-0:armhf (5.1.5-8.1+b1) ...
        Selecting previously unselected package libneon27-gnutls:armhf.
        Preparing to unpack .../08-libneon27-gnutls_0.30.2-3_armhf.deb ...
        Unpacking libneon27-gnutls:armhf (0.30.2-3) ...
        Selecting previously unselected package libodbc1:armhf.
        Preparing to unpack .../09-libodbc1_2.3.6-0.1_armhf.deb ...
        Unpacking libodbc1:armhf (2.3.6-0.1) ...
        Selecting previously unselected package libpq5:armhf.
        Preparing to unpack .../10-libpq5_11.12-0+deb10u1_armhf.deb ...
        Unpacking libpq5:armhf (11.12-0+deb10u1) ...
        Selecting previously unselected package libradcli4.
        Preparing to unpack .../11-libradcli4_1.2.6-4_armhf.deb ...
        Unpacking libradcli4 (1.2.6-4) ...
        Selecting previously unselected package libresample1.
        Preparing to unpack .../12-libresample1_0.1.3-4_armhf.deb ...
        Unpacking libresample1 (0.1.3-4) ...
        Selecting previously unselected package mysql-common.
        Preparing to unpack .../13-mysql-common_5.8+1.0.5_all.deb ...
        Unpacking mysql-common (5.8+1.0.5) ...
        Selecting previously unselected package mariadb-common.
        Preparing to unpack .../14-mariadb-common_1%3a10.3.27-0+deb10u1_all.deb ...
        Unpacking mariadb-common (1:10.3.27-0+deb10u1) ...
        Selecting previously unselected package libmariadb3:armhf.
        Preparing to unpack .../15-libmariadb3_1%3a10.3.27-0+deb10u1_armhf.deb ...
        Unpacking libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
        Selecting previously unselected package libsnmp-base.
        Preparing to unpack .../16-libsnmp-base_5.7.3+dfsg-5+deb10u2_all.deb ...
        Unpacking libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
        Selecting previously unselected package libsnmp30:armhf.
        Preparing to unpack .../17-libsnmp30_5.7.3+dfsg-5+deb10u2_armhf.deb ...
        Unpacking libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
        Selecting previously unselected package libspandsp2:armhf.
        Preparing to unpack .../18-libspandsp2_0.0.6+dfsg-2_armhf.deb ...
        Unpacking libspandsp2:armhf (0.0.6+dfsg-2) ...
        Selecting previously unselected package libspeexdsp1:armhf.
        Preparing to unpack .../19-libspeexdsp1_1.2~rc1.2-1+b2_armhf.deb ...
        Unpacking libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
        Selecting previously unselected package libsrtp2-1:armhf.
        Preparing to unpack .../20-libsrtp2-1_2.2.0-1_armhf.deb ...
        Unpacking libsrtp2-1:armhf (2.2.0-1) ...
        Selecting previously unselected package freetds-common.
        Preparing to unpack .../21-freetds-common_1.00.104-1+deb10u1_all.deb ...
        Unpacking freetds-common (1.00.104-1+deb10u1) ...
        Selecting previously unselected package libsybdb5:armhf.
        Preparing to unpack .../22-libsybdb5_1.00.104-1+deb10u1_armhf.deb ...
        Unpacking libsybdb5:armhf (1.00.104-1+deb10u1) ...
        Selecting previously unselected package libunbound8:armhf.
        Preparing to unpack .../23-libunbound8_1.9.0-2+deb10u2_armhf.deb ...
        Unpacking libunbound8:armhf (1.9.0-2+deb10u2) ...
        Selecting previously unselected package asterisk-modules.
        Preparing to unpack .../24-asterisk-modules_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
        Unpacking asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
        Selecting previously unselected package libjansson4:armhf.
        Preparing to unpack .../25-libjansson4_2.12-1_armhf.deb ...
        Unpacking libjansson4:armhf (2.12-1) ...
        Selecting previously unselected package liburiparser1:armhf.
        Preparing to unpack .../26-liburiparser1_0.9.1-1_armhf.deb ...
        Unpacking liburiparser1:armhf (0.9.1-1) ...
        Selecting previously unselected package libxslt1.1:armhf.
        Preparing to unpack .../27-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ...
        Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
        Selecting previously unselected package asterisk.
        Preparing to unpack .../28-asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
        Unpacking asterisk (1:16.2.1~dfsg-1+deb10u2) ...
        Selecting previously unselected package asterisk-voicemail.
        Preparing to unpack .../29-asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
        Unpacking asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
        Selecting previously unselected package asterisk-moh-opsound-gsm.
        Preparing to unpack .../30-asterisk-moh-opsound-gsm_2.03-1_all.deb ...
        Unpacking asterisk-moh-opsound-gsm (2.03-1) ...
        Setting up mysql-common (5.8+1.0.5) ...
        update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
        Setting up asterisk-core-sounds-en-gsm (1.6.1-1) ...
        Setting up libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
        Setting up libsrtp2-1:armhf (2.2.0-1) ...
        Setting up libpq5:armhf (11.12-0+deb10u1) ...
        Setting up libgpgme11:armhf (1.12.0-6) ...
        Setting up libspandsp2:armhf (0.0.6+dfsg-2) ...
        Setting up libjansson4:armhf (2.12-1) ...
        Setting up mariadb-common (1:10.3.27-0+deb10u1) ...
        update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
        Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
        Setting up libradcli4 (1.2.6-4) ...
        Setting up asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
        Setting up libneon27-gnutls:armhf (0.30.2-3) ...
        Setting up libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
        Setting up libodbc1:armhf (2.3.6-0.1) ...
        Setting up asterisk-core-sounds-en (1.6.1-1) ...
        update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en (asterisk-prompt-en) in auto mode
        update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en_US (asterisk-prompt-en-us) in auto mode
        Setting up libiksemel3:armhf (1.4-3+b1) ...
        Setting up liburiparser1:armhf (0.9.1-1) ...
        Setting up asterisk-moh-opsound-gsm (2.03-1) ...
        Setting up libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
        Setting up liblua5.1-0:armhf (5.1.5-8.1+b1) ...
        Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
        Setting up libical3:armhf (3.0.4-3) ...
        Setting up libresample1 (0.1.3-4) ...
        Setting up freetds-common (1.00.104-1+deb10u1) ...
        Setting up libgmime-3.0-0:armhf (3.2.1-1) ...
        Setting up libsybdb5:armhf (1.00.104-1+deb10u1) ...
        Setting up libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
        Setting up asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
        Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
        Adding system user for Asterisk
        Adding user `asterisk' to group `dialout' ...
        Adding user asterisk to group dialout
        Done.
        Adding user `asterisk' to group `audio' ...
        Adding user asterisk to group audio
        Done.
        Created symlink /etc/systemd/system/multi-user.target.wants/asterisk.service → /lib/systemd/system/asterisk.service.
        Job for asterisk.service failed because the control process exited with error code.
        See "systemctl status asterisk.service" and "journalctl -xe" for details.
        invoke-rc.d: initscript asterisk, action "start" failed.
        ● asterisk.service - Asterisk PBX
           Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:22:33 CEST; 40ms ago
             Docs: man:asterisk(8)
          Process: 31195 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
         Main PID: 31195 (code=exited, status=1/FAILURE)
        dpkg: error processing package asterisk (--configure):
         installed asterisk package post-installation script subprocess returned error exit status 1
        dpkg: dependency problems prevent configuration of asterisk-voicemail:
         asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
          Package asterisk is not configured yet.
        dpkg: error processing package asterisk-voicemail (--configure):
         dependency problems - leaving unconfigured
        Processing triggers for systemd (241-7~deb10u7+rpi1) ...
        Processing triggers for man-db (2.8.5-2) ...
        Processing triggers for libc-bin (2.28-10+rpi1) ...
        Errors were encountered while processing:
         asterisk
         asterisk-voicemail
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        Reinstall gibt dies aus:
        pi@pio4gb:/ $ sudo apt install --reinstall asterisk
        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
        2 not fully installed or removed.
        After this operation, 0 B of additional disk space will be used.
        E: Internal Error, No file name for asterisk:armhf
        pi@pio4gb:/ $
        im installationsordner unter /etc/asterisk waren früher immer zahlreich dateien vorhanden. Nach den letzten Versuchen tut sich da aber nichts mehr
        • V varg
          Befehle ergeben:
          pi@pio4gb:/ $ ^C
          Suggested packages:
          Done.
          Done.
           asterisk
           asterisk-voicemail
          pi@pio4gb:/ $
          @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
          Irgendwie ist dein System krumm.
          cd ~
          sudo apt update
          sudo apt dist-upgrade
            cd ~
            sudo apt update
            V Offline
            V Offline
            varg
            @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
            pi@pio4gb:~ $ sudo apt update
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
            Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
            Fetched 15.0 kB in 1s (13.9 kB/s)
            All packages are up to date.
            pi@pio4gb:~ $ sudo apt dist-upgrade
            Calculating upgrade... Done
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            See "systemctl status asterisk.service" and "journalctl -xe" for details....]
               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:31:53 CEST; 46ms ago
              Process: 3229 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
             Main PID: 3229 (code=exited, status=1/FAILURE)
             asterisk
             asterisk-voicemail
            pi@pio4gb:~ $
            • V varg
               asterisk
               asterisk-voicemail
              pi@pio4gb:~ $
              @varg
              sudo apt remove asterisk asterisk-voicemail --purge
                @varg
                V Offline
                V Offline
                varg
                pi@pio4gb:~ $ sudo apt remove asterisk asterisk-voicemail --purge
                The following packages were automatically installed and are no longer required:
                  asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm asterisk-modules asterisk-moh-opsound-gsm freetds-common libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0 libmariadb3 libneon27-gnutls libodbc1
                  libpq5 libradcli4 libresample1 libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5 libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
                Use 'sudo apt autoremove' to remove them.
                The following packages will be REMOVED:
                  asterisk* asterisk-voicemail*
                0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
                After this operation, 7,841 kB disk space will be freed.
                (Reading database ... 52306 files and directories currently installed.)
                Removing asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                Removing asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                (Reading database ... 52072 files and directories currently installed.)
                Purging configuration files for asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                pi@pio4gb:~ $
                • V varg
                  pi@pio4gb:~ $
                  @varg
                  sudo apt update
                  sudo apt upgrade
                  Wenn sauber dann
                    @varg
                    sudo apt update
                    sudo apt upgrade
                    Wenn sauber dann
                    V Offline
                    V Offline
                    varg
                    sudo apt upgrade
                    pi@pio4gb:~ $ sudo apt upgrade
                    pi@pio4gb:~ $
                    trotzdem "sudo apt install asterisk" ?
                    • V varg
                      sudo apt upgrade
                      pi@pio4gb:~ $
                      @varg
                      Ja, das ist sauber. Versuch jetzt mal
                        @varg
                        V Offline
                        V Offline
                        varg
                        @Thomas-Braun
                        pi@pio4gb:~ $ sudo apt install asterisk
                          asterisk-voicemail
                        Suggested packages:
                          asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus asterisk-vpb
                        0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 0 B/3,127 kB of archives.
                        After this operation, 7,841 kB of additional disk space will be used.
                        (Reading database ... 52068 files and directories currently installed.)
                        Preparing to unpack .../asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                        Preparing to unpack .../asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                        Done.
                        Done.
                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:40:40 CEST; 44ms ago
                          Process: 5501 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                         Main PID: 5501 (code=exited, status=1/FAILURE)
                         asterisk
                         asterisk-voicemail
                        pi@pio4gb:~ $
                        • V varg
                          @Thomas-Braun
                            asterisk-voicemail
                          Suggested packages:
                          Done.
                          Done.
                           asterisk
                           asterisk-voicemail
                          pi@pio4gb:~ $
                          Komisch.
                          sudo apt install -f
                          sudo dpkg --configure -a
                            Komisch.
                            sudo apt install -f
                            V Offline
                            V Offline
                            varg
                            pi@pio4gb:~ $ sudo dpkg --configure -a
                               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
                              Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                             Main PID: 7376 (code=exited, status=1/FAILURE)
                            Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
                             asterisk
                             asterisk-voicemail
                            pi@pio4gb:~ $
                            • V varg
                               asterisk
                               asterisk-voicemail
                              pi@pio4gb:~ $
                              @varg
                              sudo apt install -f
                              V 2 Antworten Letzte Antwort
                                @varg
                                sudo apt install -f
                                V Offline
                                V Offline
                                varg
                                pi@pio4gb:~ $ sudo apt install -f
                                   Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:02 CEST; 21ms ago
                                  Process: 8065 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                 Main PID: 8065 (code=exited, status=1/FAILURE)
                                 asterisk
                                 asterisk-voicemail
                                   Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:16 CEST; 49ms ago
                                  Process: 8398 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                 Main PID: 8398 (code=exited, status=1/FAILURE)
                                 asterisk
                                 asterisk-voicemail
                                pi@pio4gb:~ $
                                  @varg
                                  sudo apt install -f
                                  V Offline
                                  V Offline
                                  varg
                                  hatte ganz zuvor mit folgenden Befehlen versucht asterisk komplett zu löschen, vielleicht hats ja auch damit zu tun
                                  sudo apt-get remove  asterisk
                                  Following command is used to remove the asterisk package along with its dependencies:
                                  sudo apt-get remove --auto-remove asterisk
                                  This will remove asterisk and all its dependent packages which is no longer needed in the system.
                                  Completely removing asterisk with all configuration files:
                                  Following command should be used with care as it deletes all the configuration files and data:
                                  sudo apt-get purge asterisk
                                  or you can use following command also:
                                  sudo apt-get purge --auto-remove asterisk
                                  habe noch nen pi4 hier rumliegen, werde mal bei gelegenheit versuchen es da zu installieren
                                  • V varg
                                    @varg
                                    Hast du die alle verwendet?
                                    Schau mal was das macht:
                                    sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2
                                    oder auch
                                    sudo dpkg --configure -D 777 asterisk
                                      @varg
                                      oder auch
                                      V Offline
                                      V Offline
                                      varg
                                      ja alle commands reingeprügelt
                                      pi@pio4gb:~ $ sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2        + set -e
                                      + getent passwd asterisk
                                      + groups asterisk
                                      + grep -w -q -v dialout
                                      + groups asterisk
                                      + grep -w -q -v audio
                                      + find /var/log/asterisk /var/lib/asterisk -type d
                                      + read dir
                                      + dpkg-statoverride --list /var/log/asterisk
                                      + chown asterisk: /var/log/asterisk
                                      + read dir
                                      + dpkg-statoverride --list /var/log/asterisk/cdr-custom
                                      + chown asterisk: /var/log/asterisk/cdr-custom
                                      + read dir
                                      + dpkg-statoverride --list /var/log/asterisk/cdr-csv
                                      + chown asterisk: /var/log/asterisk/cdr-csv
                                      + read dir
                                      + dpkg-statoverride --list /var/lib/asterisk
                                      + chown asterisk: /var/lib/asterisk
                                      + read dir
                                      + dpkg-statoverride --list /var/lib/asterisk/moh
                                      + chown asterisk: /var/lib/asterisk/moh
                                      + read dir
                                      + dpkg-statoverride --list /var/lib/asterisk/sounds
                                      + chown asterisk: /var/lib/asterisk/sounds
                                      + read dir
                                      + dpkg-statoverride --list /var/lib/asterisk/sounds/custom
                                      + chown asterisk: /var/lib/asterisk/sounds/custom
                                      + read dir
                                      + dpkg-statoverride --list /var/lib/asterisk/priv-callerintros
                                      + chown asterisk: /var/lib/asterisk/priv-callerintros
                                      + read dir
                                      + dpkg-statoverride --list /etc/asterisk
                                      + chown asterisk: /etc/asterisk
                                      + find /var/spool/asterisk -type d
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk
                                      + chown asterisk: /var/spool/asterisk
                                      + chmod 750 /var/spool/asterisk
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/monitor
                                      + chown asterisk: /var/spool/asterisk/monitor
                                      + chmod 750 /var/spool/asterisk/monitor
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/tmp
                                      + chown asterisk: /var/spool/asterisk/tmp
                                      + chmod 750 /var/spool/asterisk/tmp
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/dictate
                                      + chown asterisk: /var/spool/asterisk/dictate
                                      + chmod 750 /var/spool/asterisk/dictate
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/outgoing
                                      + chown asterisk: /var/spool/asterisk/outgoing
                                      + chmod 750 /var/spool/asterisk/outgoing
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/meetme
                                      + chown asterisk: /var/spool/asterisk/meetme
                                      + chmod 750 /var/spool/asterisk/meetme
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/voicemail
                                      + chown asterisk: /var/spool/asterisk/voicemail
                                      + chmod 750 /var/spool/asterisk/voicemail
                                      + read dir
                                      + dpkg-statoverride --list /var/spool/asterisk/system
                                      + chown asterisk: /var/spool/asterisk/system
                                      + chmod 750 /var/spool/asterisk/system
                                      + read dir
                                      + [ ! -e /usr/local/share/asterisk/sounds ]
                                      + set +e
                                      + dpkg-query -W -f=${Package}\t${Provides}\n
                                      + sed -nr s/(.*)\tasterisk-config-custom|(asterisk-config)(\t.*)?/\1\2/p
                                      + ASTERISK_CONFIG=asterisk-config
                                      + dpkg-query -W -f=${Conffiles}\n asterisk-config
                                      + sed -nr -e s; (/etc/asterisk/.*) [0-9a-f]*;\1;p
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/acl.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/adsi.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/agents.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/alarmreceiver.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/alsa.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/amd.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/app_mysql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/app_skel.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/ari.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/ast_debug_tools.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/asterisk.adsi
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/asterisk.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/calendar.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/ccss.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_adaptive_odbc.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_beanstalkd.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_custom.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_manager.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_mysql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_odbc.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_pgsql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_sqlite3_custom.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_syslog.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cdr_tds.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_beanstalkd.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_custom.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_odbc.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_pgsql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_sqlite3_custom.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cel_tds.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/chan_dahdi.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/chan_mobile.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cli.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cli_aliases.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/cli_permissions.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/codecs.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/confbridge.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/config_test.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/console.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/dbsep.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/dnsmgr.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/dsp.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/enum.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/extconfig.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/extensions.ael
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/extensions.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/extensions.lua
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/extensions_minivm.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/features.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/festival.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/followme.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/func_odbc.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/hep.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/http.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/iax.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/iaxprov.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/indications.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/logger.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/manager.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/manager.d/README.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/meetme.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/minivm.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/misdn.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/modules.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/motif.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/musiconhold.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/muted.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/ooh323.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/osp.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/oss.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/phone.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/phoneprov.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/pjproject.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/pjsip.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/pjsip_notify.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/pjsip_wizard.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/queuerules.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/queues.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_config_mysql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_config_sqlite.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_config_sqlite3.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_corosync.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_curl.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_fax.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_ldap.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_odbc.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_parking.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_pgsql.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_pktccops.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_snmp.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/res_stun_monitor.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/resolver_unbound.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/rtp.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/say.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/sip.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/sip_notify.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/sla.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/smdi.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/sorcery.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/ss7.timers
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/stasis.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/statsd.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/telcordia-1.adsi
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/test_sorcery.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/udptl.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/users.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/voicemail.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/vpb.conf
                                      + read conffile
                                      + chown asterisk: /etc/asterisk/xmpp.conf
                                      + read conffile
                                      + + read STAT
                                      dpkg-statoverride --quiet --list /etc/asterisk/*
                                      + set -e
                                      + [ configure = configure ]
                                      + deb-systemd-helper unmask asterisk.service
                                      /usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
                                      + true
                                      + deb-systemd-helper --quiet was-enabled asterisk.service
                                      + deb-systemd-helper update-state asterisk.service
                                      + true
                                      + [ -x /etc/init.d/asterisk ]
                                      + update-rc.d asterisk defaults
                                      + [ -n 1:16.2.1~dfsg-1+deb10u2 ]
                                      + _dh_action=restart
                                      + invoke-rc.d asterisk restart
                                      invoke-rc.d: initscript asterisk, action "restart" failed.
                                         Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:58:51 CEST; 48ms ago
                                        Process: 14893 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                       Main PID: 14893 (code=exited, status=1/FAILURE)
                                      + exit 1
                                      pi@pio4gb:~ $
                                      pi@pio4gb:~ $ sudo dpkg --configure -D 777 asterisk
                                      D000001: ensure_diversions: new, (re)loading
                                      D000001: process queue pkg asterisk:armhf queue.len 0 progress 1, try 1
                                      D000040: checking dependencies of asterisk:armhf (- <none>)
                                      D000400:   checking group ...
                                      D000400:     checking possibility  -> adduser
                                      D000400:       checking non-provided pkg adduser:all
                                      D000400:       is installed, ok and found
                                      D000400:     found 3
                                      D000400:   found 3 matched 0 possfixbytrig -
                                      D000400:     checking possibility  -> asterisk-config
                                      D000400:       checking non-provided pkg asterisk-config:all
                                      D000400:     found 3
                                      D000400:     checking possibility  -> asterisk-core-sounds-en
                                      D000400:       checking non-provided pkg asterisk-core-sounds-en:all
                                      D000400:     found 3
                                      D000400:     checking possibility  -> asterisk-modules
                                      D000400:       checking non-provided pkg asterisk-modules:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> lsb-base
                                      D000400:       checking non-provided pkg lsb-base:all
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libc6
                                      D000400:       checking non-provided pkg libc6:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libcap2
                                      D000400:       checking non-provided pkg libcap2:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libedit2
                                      D000400:       checking non-provided pkg libedit2:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libgcc1
                                      D000400:       checking non-provided pkg libgcc1:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libjansson4
                                      D000400:       checking non-provided pkg libjansson4:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libpopt0
                                      D000400:       checking non-provided pkg libpopt0:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libsqlite3-0
                                      D000400:       checking non-provided pkg libsqlite3-0:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libssl1.1
                                      D000400:       checking non-provided pkg libssl1.1:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libsystemd0
                                      D000400:       checking non-provided pkg libsystemd0:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> liburiparser1
                                      D000400:       checking non-provided pkg liburiparser1:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libuuid1
                                      D000400:       checking non-provided pkg libuuid1:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libxml2
                                      D000400:       checking non-provided pkg libxml2:armhf
                                      D000400:     found 3
                                      D000400:     checking possibility  -> libxslt1.1
                                      D000400:       checking non-provided pkg libxslt1.1:armhf
                                      D000400:     found 3
                                      D000040: ok 2 msgs >><<
                                      D000040:     checking Breaks
                                      D000400:      checking virtbroken asterisk-1fb7f5c06d7a2052e38d021b3d8ca151
                                      D000002: fork/exec /var/lib/dpkg/info/asterisk.postinst ( configure  )
                                         Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:59:56 CEST; 23ms ago
                                        Process: 15558 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                       Main PID: 15558 (code=exited, status=1/FAILURE)
                                      D000001: ensure_diversions: same, skipping
                                      D000040: checking dependencies of libc-bin:armhf (- <none>)
                                      D000400:     found 3
                                      D000400:     found 3
                                      D000002: fork/exec /var/lib/dpkg/info/libc-bin.postinst ( triggered ldconfig )
                                       asterisk
                                      pi@pio4gb:~ $
                                      • V varg
                                        + groups asterisk
                                        + groups asterisk
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + read dir
                                        + set +e
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + read conffile
                                        + + read STAT
                                        + set -e
                                        + true
                                        + true
                                        + exit 1
                                        pi@pio4gb:~ $
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000400:     found 3
                                         asterisk
                                        pi@pio4gb:~ $
                                        @varg
                                        ls -l /var/lib/dpkg/info | grep -i asterisk
                                        • V varg
                                          + groups asterisk
                                          + groups asterisk
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + read dir
                                          + set +e
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + read conffile
                                          + + read STAT
                                          + set -e
                                          + true
                                          + true
                                          + exit 1
                                          pi@pio4gb:~ $
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000400:     found 3
                                           asterisk
                                          pi@pio4gb:~ $
                                          @varg
                                          sudo mv /var/lib/dpkg/info/asterisk* /tmp
                                          Dann
                                          sudo apt update
