  4. Asterisk bringt "Error while dialing (2). Error: {}"
    6.4k
116 Beiträge 10 Kommentatoren 20.1k Aufrufe 11 Beobachtet
  • V varg
    pi@pio4gb:~ $ apt policy asterisk-voicemail asterisk
    asterisk-voicemail:
      Installed: 1:16.2.1~dfsg-1+deb10u2
      Candidate: 1:16.2.1~dfsg-1+deb10u2
      Version table:
     *** 1:16.2.1~dfsg-1+deb10u2 500
    asterisk:
      Version table:
    Installationsversuch:
    Created symlink /etc/systemd/system/multi-user.target.wants/asterisk.service → /lib/systemd/system/asterisk.service.
    Job for asterisk.service failed because the control process exited with error code.
    See "systemctl status asterisk.service" and "journalctl -xe" for details.
    invoke-rc.d: initscript asterisk, action "start" failed.
    ● asterisk.service - Asterisk PBX
       Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 10:40:21 CEST; 39ms ago
         Docs: man:asterisk(8)
      Process: 27969 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
     Main PID: 27969 (code=exited, status=1/FAILURE)
    dpkg: error processing package asterisk (--configure):
     installed asterisk package post-installation script subprocess returned error exit status 1
    dpkg: dependency problems prevent configuration of asterisk-voicemail:
     asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
      Package asterisk is not configured yet.
    dpkg: error processing package asterisk-voicemail (--configure):
     dependency problems - leaving unconfigured
    Processing triggers for systemd (241-7~deb10u7+rpi1) ...
    Processing triggers for man-db (2.8.5-2) ...
    Processing triggers for libc-bin (2.28-10+rpi1) ...
    Errors were encountered while processing:
     asterisk
     asterisk-voicemail
    @varg
    sudo dpkg-reconfigure --priority=low asterisk-voicemail
    bzw.
      @varg
      bzw.
      andiber
      @thomas-braun Kurze Nachfrage eines Unwissenden, die beiden geposteten Befehle führen die zur Lösung des Problems? Leider ist von Dir keine Erklärung hierzu gegeben. Falls es das war, danke ich schonmal vorab ganz herzlich!!!!
      • A andiber
        @andiber
        Das weiß ich nicht. Aber es klemmt da irgendwo in der dpkg-Datenbank.
        Möglich das man das mit einem reconfigure in den Griff bekommt.
        A 2 Antworten Letzte Antwort
          @andiber
          andiber
          Danke für die Info, ich werde es mal versuchen. Jetzt weiß ich wenigstens was dieser Befehl bewirken soll.
            @andiber
            andiber
            @thomas-braun So ausprobiert, keine dieser Befehle bewirkte eine Änderung. Asterisk bleibt stumm.
            asterisk.0
            2021-06-06 12:28:30.471 error Error while dialing (2). Error: {}
            Aber trotzdem vielen Dank, hätte ja auch klappen können.
            • A andiber
              asterisk.0
              @andiber
              Was stand jetzt als Rückmeldung im Terminal?
                @andiber
                andiber
                @thomas-braun Gar nichts, beide Befehle sind ohne Fehlermeldung durchgelaufen, es endete jeweils mit der normalen Eigabeaufforderung.
                • A andiber
                  @andiber
                  Dann mal ein
                  sudo apt install --reinstall asterisk
                  V 1 Antwort Letzte Antwort
                    @andiber
                    Dann mal ein
                    V Offline
                    V Offline
                    varg
                    schrieb am zuletzt editiert von varg
                    Installation anhand dieser Anleitung Git
                    Befehle ergeben:
                    pi@pio4gb:/ $ sudo dpkg-reconfigure --priority=low asterisk-voicemail
                    /usr/sbin/dpkg-reconfigure: asterisk-voicemail is broken or not fully installed
                    /usr/sbin/dpkg-reconfigure: asterisk is broken or not fully installed
                    pi@pio4gb:/ $ ^C
                    Installation sieht immer noch so aus:
                    i@pio4gb:/ $ sudo apt install asterisk
                    Reading package lists... Done
                    Building dependency tree
                    The following additional packages will be installed:
                      asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
                      asterisk-modules asterisk-moh-opsound-gsm asterisk-voicemail freetds-common
                      libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0
                      libmariadb3 libneon27-gnutls libodbc1 libpq5 libradcli4 libresample1
                      libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5
                      libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
                    Suggested packages:
                      asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus
                      asterisk-vpb libmyodbc odbc-postgresql tdsodbc unixodbc-bin
                      snmp-mibs-downloader
                    The following NEW packages will be installed:
                      asterisk asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
                    0 upgraded, 31 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 0 B/18.6 MB of archives.
                    After this operation, 39.2 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] Y
                    Extracting templates from packages: 100%
                    Selecting previously unselected package asterisk-config.
                    (Reading database ... 50667 files and directories currently installed.)
                    Preparing to unpack .../00-asterisk-config_1%3a16.2.1~dfsg-1+deb10u2_all.deb ...
                    Unpacking asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
                    Selecting previously unselected package asterisk-core-sounds-en-gsm.
                    Preparing to unpack .../01-asterisk-core-sounds-en-gsm_1.6.1-1_all.deb ...
                    Unpacking asterisk-core-sounds-en-gsm (1.6.1-1) ...
                    Selecting previously unselected package asterisk-core-sounds-en.
                    Preparing to unpack .../02-asterisk-core-sounds-en_1.6.1-1_all.deb ...
                    Unpacking asterisk-core-sounds-en (1.6.1-1) ...
                    Selecting previously unselected package libgpgme11:armhf.
                    Preparing to unpack .../03-libgpgme11_1.12.0-6_armhf.deb ...
                    Unpacking libgpgme11:armhf (1.12.0-6) ...
                    Selecting previously unselected package libgmime-3.0-0:armhf.
                    Preparing to unpack .../04-libgmime-3.0-0_3.2.1-1_armhf.deb ...
                    Unpacking libgmime-3.0-0:armhf (3.2.1-1) ...
                    Selecting previously unselected package libical3:armhf.
                    Preparing to unpack .../05-libical3_3.0.4-3_armhf.deb ...
                    Unpacking libical3:armhf (3.0.4-3) ...
                    Selecting previously unselected package libiksemel3:armhf.
                    Preparing to unpack .../06-libiksemel3_1.4-3+b1_armhf.deb ...
                    Unpacking libiksemel3:armhf (1.4-3+b1) ...
                    Selecting previously unselected package liblua5.1-0:armhf.
                    Preparing to unpack .../07-liblua5.1-0_5.1.5-8.1+b1_armhf.deb ...
                    Unpacking liblua5.1-0:armhf (5.1.5-8.1+b1) ...
                    Selecting previously unselected package libneon27-gnutls:armhf.
                    Preparing to unpack .../08-libneon27-gnutls_0.30.2-3_armhf.deb ...
                    Unpacking libneon27-gnutls:armhf (0.30.2-3) ...
                    Selecting previously unselected package libodbc1:armhf.
                    Preparing to unpack .../09-libodbc1_2.3.6-0.1_armhf.deb ...
                    Unpacking libodbc1:armhf (2.3.6-0.1) ...
                    Selecting previously unselected package libpq5:armhf.
                    Preparing to unpack .../10-libpq5_11.12-0+deb10u1_armhf.deb ...
                    Unpacking libpq5:armhf (11.12-0+deb10u1) ...
                    Selecting previously unselected package libradcli4.
                    Preparing to unpack .../11-libradcli4_1.2.6-4_armhf.deb ...
                    Unpacking libradcli4 (1.2.6-4) ...
                    Selecting previously unselected package libresample1.
                    Preparing to unpack .../12-libresample1_0.1.3-4_armhf.deb ...
                    Unpacking libresample1 (0.1.3-4) ...
                    Selecting previously unselected package mysql-common.
                    Preparing to unpack .../13-mysql-common_5.8+1.0.5_all.deb ...
                    Unpacking mysql-common (5.8+1.0.5) ...
                    Selecting previously unselected package mariadb-common.
                    Preparing to unpack .../14-mariadb-common_1%3a10.3.27-0+deb10u1_all.deb ...
                    Unpacking mariadb-common (1:10.3.27-0+deb10u1) ...
                    Selecting previously unselected package libmariadb3:armhf.
                    Preparing to unpack .../15-libmariadb3_1%3a10.3.27-0+deb10u1_armhf.deb ...
                    Unpacking libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
                    Selecting previously unselected package libsnmp-base.
                    Preparing to unpack .../16-libsnmp-base_5.7.3+dfsg-5+deb10u2_all.deb ...
                    Unpacking libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
                    Selecting previously unselected package libsnmp30:armhf.
                    Preparing to unpack .../17-libsnmp30_5.7.3+dfsg-5+deb10u2_armhf.deb ...
                    Unpacking libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
                    Selecting previously unselected package libspandsp2:armhf.
                    Preparing to unpack .../18-libspandsp2_0.0.6+dfsg-2_armhf.deb ...
                    Unpacking libspandsp2:armhf (0.0.6+dfsg-2) ...
                    Selecting previously unselected package libspeexdsp1:armhf.
                    Preparing to unpack .../19-libspeexdsp1_1.2~rc1.2-1+b2_armhf.deb ...
                    Unpacking libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
                    Selecting previously unselected package libsrtp2-1:armhf.
                    Preparing to unpack .../20-libsrtp2-1_2.2.0-1_armhf.deb ...
                    Unpacking libsrtp2-1:armhf (2.2.0-1) ...
                    Selecting previously unselected package freetds-common.
                    Preparing to unpack .../21-freetds-common_1.00.104-1+deb10u1_all.deb ...
                    Unpacking freetds-common (1.00.104-1+deb10u1) ...
                    Selecting previously unselected package libsybdb5:armhf.
                    Preparing to unpack .../22-libsybdb5_1.00.104-1+deb10u1_armhf.deb ...
                    Unpacking libsybdb5:armhf (1.00.104-1+deb10u1) ...
                    Selecting previously unselected package libunbound8:armhf.
                    Preparing to unpack .../23-libunbound8_1.9.0-2+deb10u2_armhf.deb ...
                    Unpacking libunbound8:armhf (1.9.0-2+deb10u2) ...
                    Selecting previously unselected package asterisk-modules.
                    Preparing to unpack .../24-asterisk-modules_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                    Unpacking asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
                    Selecting previously unselected package libjansson4:armhf.
                    Preparing to unpack .../25-libjansson4_2.12-1_armhf.deb ...
                    Unpacking libjansson4:armhf (2.12-1) ...
                    Selecting previously unselected package liburiparser1:armhf.
                    Preparing to unpack .../26-liburiparser1_0.9.1-1_armhf.deb ...
                    Unpacking liburiparser1:armhf (0.9.1-1) ...
                    Selecting previously unselected package libxslt1.1:armhf.
                    Preparing to unpack .../27-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ...
                    Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
                    Selecting previously unselected package asterisk.
                    Preparing to unpack .../28-asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                    Unpacking asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                    Selecting previously unselected package asterisk-voicemail.
                    Preparing to unpack .../29-asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                    Unpacking asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                    Selecting previously unselected package asterisk-moh-opsound-gsm.
                    Preparing to unpack .../30-asterisk-moh-opsound-gsm_2.03-1_all.deb ...
                    Unpacking asterisk-moh-opsound-gsm (2.03-1) ...
                    Setting up mysql-common (5.8+1.0.5) ...
                    update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
                    Setting up asterisk-core-sounds-en-gsm (1.6.1-1) ...
                    Setting up libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
                    Setting up libsrtp2-1:armhf (2.2.0-1) ...
                    Setting up libpq5:armhf (11.12-0+deb10u1) ...
                    Setting up libgpgme11:armhf (1.12.0-6) ...
                    Setting up libspandsp2:armhf (0.0.6+dfsg-2) ...
                    Setting up libjansson4:armhf (2.12-1) ...
                    Setting up mariadb-common (1:10.3.27-0+deb10u1) ...
                    update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
                    Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
                    Setting up libradcli4 (1.2.6-4) ...
                    Setting up asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
                    Setting up libneon27-gnutls:armhf (0.30.2-3) ...
                    Setting up libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
                    Setting up libodbc1:armhf (2.3.6-0.1) ...
                    Setting up asterisk-core-sounds-en (1.6.1-1) ...
                    update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en (asterisk-prompt-en) in auto mode
                    update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en_US (asterisk-prompt-en-us) in auto mode
                    Setting up libiksemel3:armhf (1.4-3+b1) ...
                    Setting up liburiparser1:armhf (0.9.1-1) ...
                    Setting up asterisk-moh-opsound-gsm (2.03-1) ...
                    Setting up libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
                    Setting up liblua5.1-0:armhf (5.1.5-8.1+b1) ...
                    Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
                    Setting up libical3:armhf (3.0.4-3) ...
                    Setting up libresample1 (0.1.3-4) ...
                    Setting up freetds-common (1.00.104-1+deb10u1) ...
                    Setting up libgmime-3.0-0:armhf (3.2.1-1) ...
                    Setting up libsybdb5:armhf (1.00.104-1+deb10u1) ...
                    Setting up libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
                    Setting up asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
                    Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                    Adding system user for Asterisk
                    Adding user `asterisk' to group `dialout' ...
                    Adding user asterisk to group dialout
                    Done.
                    Adding user `asterisk' to group `audio' ...
                    Adding user asterisk to group audio
                    Done.
                       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:22:33 CEST; 40ms ago
                      Process: 31195 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                     Main PID: 31195 (code=exited, status=1/FAILURE)
                     asterisk
                     asterisk-voicemail
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                    Reinstall gibt dies aus:
                    pi@pio4gb:/ $ sudo apt install --reinstall asterisk
                    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                    2 not fully installed or removed.
                    After this operation, 0 B of additional disk space will be used.
                    E: Internal Error, No file name for asterisk:armhf
                    pi@pio4gb:/ $
                    im installationsordner unter /etc/asterisk waren früher immer zahlreich dateien vorhanden. Nach den letzten Versuchen tut sich da aber nichts mehr
                    • V varg
                      Befehle ergeben:
                      pi@pio4gb:/ $ ^C
                      Suggested packages:
                      Done.
                      Done.
                       asterisk
                       asterisk-voicemail
                      pi@pio4gb:/ $
                      @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                      Irgendwie ist dein System krumm.
                      cd ~
                      sudo apt update
                      sudo apt dist-upgrade
                        cd ~
                        sudo apt update
                        V Offline
                        V Offline
                        varg
                        @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
                        pi@pio4gb:~ $ sudo apt update
                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                        Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                        Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                        Fetched 15.0 kB in 1s (13.9 kB/s)
                        All packages are up to date.
                        pi@pio4gb:~ $ sudo apt dist-upgrade
                        Calculating upgrade... Done
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        See "systemctl status asterisk.service" and "journalctl -xe" for details....]
                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:31:53 CEST; 46ms ago
                          Process: 3229 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                         Main PID: 3229 (code=exited, status=1/FAILURE)
                         asterisk
                         asterisk-voicemail
                        pi@pio4gb:~ $
                        • V varg
                           asterisk
                           asterisk-voicemail
                          pi@pio4gb:~ $
                          @varg
                          sudo apt remove asterisk asterisk-voicemail --purge
                            @varg
                            V Offline
                            V Offline
                            varg
                            pi@pio4gb:~ $ sudo apt remove asterisk asterisk-voicemail --purge
                            The following packages were automatically installed and are no longer required:
                              asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm asterisk-modules asterisk-moh-opsound-gsm freetds-common libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0 libmariadb3 libneon27-gnutls libodbc1
                              libpq5 libradcli4 libresample1 libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5 libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
                            Use 'sudo apt autoremove' to remove them.
                            The following packages will be REMOVED:
                              asterisk* asterisk-voicemail*
                            0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
                            After this operation, 7,841 kB disk space will be freed.
                            (Reading database ... 52306 files and directories currently installed.)
                            Removing asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                            Removing asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                            (Reading database ... 52072 files and directories currently installed.)
                            Purging configuration files for asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                            pi@pio4gb:~ $
                            • V varg
                              pi@pio4gb:~ $
                              @varg
                              sudo apt update
                              sudo apt upgrade
                              Wenn sauber dann
                                @varg
                                sudo apt update
                                sudo apt upgrade
                                Wenn sauber dann
                                V Offline
                                V Offline
                                varg
                                sudo apt upgrade
                                pi@pio4gb:~ $ sudo apt upgrade
                                pi@pio4gb:~ $
                                trotzdem "sudo apt install asterisk" ?
                                • V varg
                                  sudo apt upgrade
                                  pi@pio4gb:~ $
                                  @varg
                                  Ja, das ist sauber. Versuch jetzt mal
                                    @varg
                                    V Offline
                                    V Offline
                                    varg
                                    @Thomas-Braun
                                    pi@pio4gb:~ $ sudo apt install asterisk
                                      asterisk-voicemail
                                    Suggested packages:
                                      asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus asterisk-vpb
                                    0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                    Need to get 0 B/3,127 kB of archives.
                                    After this operation, 7,841 kB of additional disk space will be used.
                                    (Reading database ... 52068 files and directories currently installed.)
                                    Preparing to unpack .../asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                                    Preparing to unpack .../asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                                    Done.
                                    Done.
                                       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:40:40 CEST; 44ms ago
                                      Process: 5501 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                     Main PID: 5501 (code=exited, status=1/FAILURE)
                                     asterisk
                                     asterisk-voicemail
                                    pi@pio4gb:~ $
                                    • V varg
                                      @Thomas-Braun
                                        asterisk-voicemail
                                      Suggested packages:
                                      Done.
                                      Done.
                                       asterisk
                                       asterisk-voicemail
                                      pi@pio4gb:~ $
                                      Komisch.
                                      sudo apt install -f
                                      sudo dpkg --configure -a
                                        Komisch.
                                        sudo apt install -f
                                        V Offline
                                        V Offline
                                        varg
                                        pi@pio4gb:~ $ sudo dpkg --configure -a
                                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
                                          Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                         Main PID: 7376 (code=exited, status=1/FAILURE)
                                        Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
                                         asterisk
                                         asterisk-voicemail
                                        pi@pio4gb:~ $
                                        • V varg
                                           asterisk
                                           asterisk-voicemail
                                          pi@pio4gb:~ $
                                          @varg
                                          sudo apt install -f
                                          V 2 Antworten Letzte Antwort
