  4. Admin :8081 Ladezeit: (fast) unendlich!
70 Beiträge 6 Kommentatoren 7.7k Aufrufe 4 Beobachtet
    @rotamint
    cupsd ist vermutlich auch überflüssig? Dient der Raspberry als Druckerserver?
    Wenn nein:
    sudo systemctl stop cupsd
    sudo apt remove cups
    rotamint
    pi@ioBroker:~ $ sudo systemctl stop cupsd
    Failed to stop cupsd.service: Unit cupsd.service not loaded.
    pi@ioBroker:~ $ sudo ss -tunlp
    Netid       State        Recv-Q        Send-Q               Local Address:Port                Peer Address:Port
    udp         UNCONN       0             0                          0.0.0.0:39357                    0.0.0.0:*           users:(("io.milight-smar",pid=3408,fd=26))
    udp         UNCONN       0             0                          0.0.0.0:68                       0.0.0.0:*           users:(("dhclient",pid=507,fd=7))
    udp         UNCONN       0             0                          0.0.0.0:631                      0.0.0.0:*           users:(("cups-browsed",pid=4024,fd=7))
    udp         UNCONN       0             0                          0.0.0.0:5353                     0.0.0.0:*           users:(("avahi-daemon",pid=327,fd=12))
    udp         UNCONN       0             0                          0.0.0.0:37139                    0.0.0.0:*           users:(("avahi-daemon",pid=327,fd=14))
    udp         UNCONN       0             0                          0.0.0.0:44377                    0.0.0.0:*           users:(("io.milight-smar",pid=3418,fd=26))
    udp         UNCONN       0             0                                *:37998                          *:*           users:(("avahi-daemon",pid=327,fd=15))
    udp         UNCONN       0             0                                *:5353                           *:*           users:(("avahi-daemon",pid=327,fd=13))
    tcp         LISTEN       0             511                    192.168.1.9:12001                    0.0.0.0:*           users:(("io.hm-rpc.0",pid=2910,fd=27))
    tcp         LISTEN       0             511                      127.0.0.1:9000                     0.0.0.0:*           users:(("iobroker.js-con",pid=2784,fd=24))
    tcp         LISTEN       0             511                      127.0.0.1:9001                     0.0.0.0:*           users:(("iobroker.js-con",pid=2784,fd=19))
    tcp         LISTEN       0             128                        0.0.0.0:22                       0.0.0.0:*           users:(("sshd",pid=635,fd=3))
    tcp         LISTEN       0             5                        127.0.0.1:631                      0.0.0.0:*           users:(("cupsd",pid=4023,fd=7))
    tcp         LISTEN       0             511                        0.0.0.0:1883                     0.0.0.0:*           users:(("io.sonoff.0",pid=2966,fd=26))
    tcp         LISTEN       0             511                              *:4400                           *:*           users:(("io.milight-smar",pid=3418,fd=28))
    tcp         LISTEN       0             511                              *:8081                           *:*           users:(("io.admin.0",pid=4316,fd=27))
    tcp         LISTEN       0             128                           [::]:22                          [::]:*           users:(("sshd",pid=635,fd=4))
    tcp         LISTEN       0             5                            [::1]:631                         [::]:*           users:(("cupsd",pid=4023,fd=6))
    tcp         LISTEN       0             511                              *:8087                           *:*           users:(("io.simple-api.0",pid=2951,fd=26))
    pi@ioBroker:~ $
    • R rotamint
      pi@ioBroker:~ $
      @rotamint Dann schmeiß den cups raus.
      Mein Edit bzgl. ble hast du gesehen?
      R 1 Antwort Letzte Antwort
        @rotamint
        Ja, stell das auf ALLE 0.0.0.0. zurück.
        Ich sehe gerade, du hast den ble-Adapter an Bord. Schau mal wie viele Objekte der mitschleift. Das kann (wenn man das nicht anders einstellt) leicht in die Hunderttausende gehen. Dann geht im ioBroker nix mehr, auf der kleinen Hardware eines Pis.
        rotamint
        Den Ansatz hatte der user in dem o. g. Link auch, anscheinend war es bei ihm auch die Lösung? Ich habe aber nicht verstanden, wie ich das herausfinden kann...
          rotamint
          pi@ioBroker:~ $ sudo remove cups
          sudo: remove: Befehl nicht gefunden
          pi@ioBroker:~ $
          Danke Thomas für den Hinweis mit BLE. Aber ... Wie kann ich das rausfinden, ob das der Übeltäter ist?
          • R rotamint
            haselchenH Offline
            haselchenH Offline
            haselchen
            @rotamint
            Einstellung im BLE Adapter
            Und dann nachschauen in den Objekten, ob da Geräte sind, die Du gar nicht haben wolltest. Und dann löschen die Ordner.
            • R rotamint
              pi@ioBroker:~ $
              @rotamint
              Oder in den Objekten schauen:
                @rotamint
                rotamint
                @thomas-braun @haselchen
                Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                • R rotamint
                  @rotamint
                  Okay, das passt. Dann ist das nicht die Bremse.
                  • R rotamint
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @rotamint
                    Hält sich von den Geräten her im Rahmen.
                    Aber die Teile funken alle 5 bis 10sek.
                    Eventuell macht es die Masse. Quasi Kleinvieh macht auch Traffic :)
                    Aber ich denke daran sollte es nicht liegen.
                    • R rotamint
                      pi@ioBroker:~ $
                      @rotamint sagte in Admin :8081 Ladezeit: (fast) unendlich!:
                      sudo remove cups
                      Muss
                      heißen.
                      • haselchenH haselchen
                        @rotamint
                        rotamint
                        @haselchen Habe die Einstellungen von Dir übernommen, RSSI-Update war 60000 und der Haken darunter war gesetzt. Reboot. Und dann bin ich gespannt was dann passiert...
                        • R rotamint
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @rotamint
                          Ich/ Wir auch :)
                            @rotamint
                            Ich/ Wir auch :)
                            rotamint
                            schrieb am zuletzt editiert von rotamint
                            @haselchen @Thomas-Braun
                            Unverändert 😧
                            Edit... Unverändert wäre falsch. Aber die Ladezeit ist 63 Sekunden. Liegt das im "normalen Rahmen"? Bilde mir ein, dass es deutlich schneller war...
                            • R rotamint
                              Unverändert 😧
                              @rotamint
                              Dann schau mal per
                              htop
                              was da los ist.
                              free -ht --mega
                              könnte auch Hinweise geben.
                                @rotamint
                                Dann schau mal per
                                htop
                                was da los ist.
                                free -ht --mega
                                rotamint
                                @thomas-braun said in Admin :8081 Ladezeit: (fast) unendlich!:
                                free -ht --mega
                                HTOP während ich versuche, die Seite zu öffnen?
                                • R rotamint
                                  free -ht --mega
                                  @rotamint
                                  Ja, schau mal was sich da tut. Meist sieht man da einen Prozess der aus dem Ruder läuft. Entweder weil der CPU oder RAM frisst.
                                  Kann aber auch an der I/O-Last hängen. Und/oder Dateisystem.
                                    @rotamint
                                    rotamint
                                    pi@ioBroker:~ $ free -ht --mega
                                    Mem:           1,9G        857M        646M         16M        361M        1,0G
                                    Swap:           99M          0B         99M
                                    Total:         2,0G        857M        746M
                                    pi@ioBroker:~ $
                                    • R rotamint
                                      Swap:           99M          0B         99M
                                      pi@ioBroker:~ $
                                      @rotamint
                                      RAM ist kein Thema. Aber der js-controller mit dem admin zusammen schnupfen deine CPU weg.
                                      Die Erklärung zu dem java-Zeuch bist du auch noch Schuldig geblieben, oder?
                                        @rotamint
                                        rotamint
                                        @rotamint
                                        Sag' mir was ich Dir dazu sagen soll... Ich weiss es nicht... Habe auf dem PI den ioBroker und PIVCCU3 laufen. Sonst nichts...
                                        haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                                        • R rotamint
                                          @rotamint
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @rotamint
                                          Hm, okay dann scheint das zur CCU3 zu gehören.
                                          Ich bin trotzdem persönlich der Meinung beides zu trennen.
                                          Iobroker -> eigene Hardware
                                          Raspimatic -> eigene Hardware
                                          Auch im Hinblick auf Systemcrashes.
