  4. [gelöst] Nach iobroker Update kein Start mehr möglich
4 Beiträge 3 Kommentatoren 468 Aufrufe 2 Beobachtet
  • W Offline
    W Offline
    WurstDLX
    schrieb am zuletzt editiert von WurstDLX
    ich habe ein Problem, nachdem ich bei den Adaptern eine Meldung hatte "js-controller>=3.2 benötigt" (bei web und node-red). Ich habe ein update gemacht:
    iobroker stop
    iobroker update
    iobroker upgrade self
    iobroker start
    und iobroker startet nicht mehr. Die Logs zeigen dreimal das hier:
    2021-05-26 22:29:50.680  - info: host.RaspberryPi4 iobroker _restart
    2021-05-26 22:29:50.723  - error: host.RaspberryPi4 Could not create notifications object: DB closed
    2021-05-26 22:29:50.726  - error: host.RaspberryPi4 Cannot find view "system" for search "instance" : Connection is closed.
    2021-05-26 22:29:50.727  - error: host.RaspberryPi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-05-26 22:29:50.775  - info: host.RaspberryPi4 terminated
    2021-05-26 22:29:51.339  - info: host.RaspberryPi4 iobroker Starting node restart.js
    2021-05-26 22:29:51.586  - info: host.RaspberryPi4 received SIGTERM
    2021-05-26 22:29:51.590  - warn: host.RaspberryPi4 get state error: Connection is closed.
    2021-05-26 22:29:51.590  - info: host.RaspberryPi4 terminated
    2021-05-26 22:29:51.635  - info: host.RaspberryPi4 iobroker exit null
    2021-05-26 22:29:53.014  - info: host.RaspberryPi4 iobroker.js-controller version 3.3.11 js-controller starting
    2021-05-26 22:29:53.020  - info: host.RaspberryPi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-05-26 22:29:53.021  - info: host.RaspberryPi4 hostname: RaspberryPi4, node: v10.24.1
    2021-05-26 22:29:53.021  - info: host.RaspberryPi4 ip addresses: 192.168.178.64 fd00::e879:1aba:8312:d66a 2001:a61:3b52:7e01:e820:c776:7a22:bf31 fe80::839a:1a77:187c:958d 192.168.178.65 fd00::ea9a:a078:75bc:6f9d 2001:a61:3b52:7e01:7b68:8a8e:132e:f365 fe80::4be4:db28:d3ec:3e6b
    2021-05-26 22:29:53.907  - info: host.RaspberryPi4 connected to Objects and States
    2021-05-26 22:29:53.943  - info: host.RaspberryPi4 added notifications configuration of host
    2021-05-26 22:29:53.960  - error: host.RaspberryPi4 uncaught exception: Cannot read property 'alloc' of undefined
    2021-05-26 22:29:53.961  - error: host.RaspberryPi4 TypeError: Cannot read property 'alloc' of undefined
        at readUntilEnd (/opt/iobroker/node_modules/pidusage/lib/procfile.js:27:18)
        at /opt/iobroker/node_modules/pidusage/lib/procfile.js:68:5
        at FSReqWrap.args [as oncomplete] (fs.js:140:20)
    2021-05-26 22:29:53.970  - info: host.RaspberryPi4 iobroker _restart
    2021-05-26 22:29:54.013  - error: host.RaspberryPi4 Could not create notifications object: DB closed
    2021-05-26 22:29:54.016  - error: host.RaspberryPi4 Cannot find view "system" for search "instance" : Connection is closed.
    2021-05-26 22:29:54.018  - error: host.RaspberryPi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-05-26 22:29:54.065  - info: host.RaspberryPi4 terminated
    2021-05-26 22:29:54.626  - info: host.RaspberryPi4 iobroker Starting node restart.js
    2021-05-26 22:29:54.874  - info: host.RaspberryPi4 received SIGTERM
    2021-05-26 22:29:54.878  - warn: host.RaspberryPi4 get state error: Connection is closed.
    2021-05-26 22:29:54.878  - info: host.RaspberryPi4 terminated
    2021-05-26 22:29:54.923  - info: host.RaspberryPi4 iobroker exit null
    Dann habe ich
    ip a
    durchgeführt, da ich dachte es sind zuviele IP Adressen im Spiel. Die Instanz List zeigt dann:
     iobroker list instances
      system.adapter.admin.0                  : admin                 : RaspberryPi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.discovery.0              : discovery             : RaspberryPi4                             -  enabled
      system.adapter.dwd.0                    : dwd                   : RaspberryPi4                             -  enabled
      system.adapter.flot.0                   : flot                  : RaspberryPi4                             - disabled
      system.adapter.fritzbox.0               : fritzbox              : RaspberryPi4                             -  enabled
      system.adapter.harmony.0                : harmony               : RaspberryPi4                             -  enabled
      system.adapter.history.0                : history               : RaspberryPi4                             -  enabled
      system.adapter.hue.0                    : hue                   : RaspberryPi4                             -  enabled, port: 443
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RaspberryPi4                             -  enabled
      system.adapter.info.0                   : info                  : RaspberryPi4                             -  enabled
      system.adapter.javascript.0             : javascript            : RaspberryPi4                             -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : RaspberryPi4                             -  enabled, port: 54321
      system.adapter.ping.0                   : ping                  : RaspberryPi4                             -  enabled
      system.adapter.rpi2.0                   : rpi2                  : RaspberryPi4                             -  enabled
      system.adapter.shelly.0                 : shelly                : RaspberryPi4                             -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : RaspberryPi4                             -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : RaspberryPi4                             -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.vis-bars.0               : vis-bars              : RaspberryPi4                             - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : RaspberryPi4                             - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RaspberryPi4                             - disabled
      system.adapter.vis-history.0            : vis-history           : RaspberryPi4                             - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RaspberryPi4                             - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : RaspberryPi4                             - disabled
      system.adapter.vis-metro.0              : vis-metro             : RaspberryPi4                             - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : RaspberryPi4                             - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : RaspberryPi4                             - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : RaspberryPi4                             - disabled
      system.adapter.vis-weather.0            : vis-weather           : RaspberryPi4                             - disabled
      system.adapter.vis.0                    : vis                   : RaspberryPi4                             -  enabled
      system.adapter.web.0                    : web                   : RaspberryPi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : RaspberryPi4                             -  enabled, port: /dev/ttyACM0
      system.adapter.zwave.0                  : zwave                 : RaspberryPi4                             - disabled
    + instance is alive
    Die Abfrage nach nodejs zeigt:
     which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v10.24.1
    v10.24.1
    6.14.12
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:3 https://deb.nodesource.com/node_10.x buster InRelease
    Alle Pakete sind aktuell.
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 https://deb.nodesource.com/node_10.x buster InRelease
    OK:3 http://archive.raspberrypi.org/debian buster InRelease
    nodejs:
      Installiert:           10.24.1-1nodesource1
      Installationskandidat: 10.24.1-1nodesource1
      Versionstabelle:
     *** 10.24.1-1nodesource1 500
            500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    Dann habe ich vor lauter Probierei noch ein apt update gemacht und den Raspberry geupdatet. Seitdem zeigt er bei den Status das hier:
     iobroker status
     States database error: connect ECONNREFUSED 127.0.0.1:9000
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    Ich habe keine Ahnung mehr was ich noch machen könnte.
    Wäre einer bitte so nett und kann mir helfen?
    Das ganze lief stabil auf einem RPi4, Raspbian 10 (Buster).
    crunchipC HomoranH 2 Antworten Letzte Antwort
    • W WurstDLX
      iobroker stop
      iobroker update
      iobroker start
      Dann habe ich
      ip a
      + instance is alive
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v10.24.1
      v10.24.1
      6.14.12
      nodejs:
        Versionstabelle:
       iobroker status
      crunchipC Offline
      crunchipC Offline
      @wurstdlx sagte in Nach iobroker Update kein Start mehr möglich:
      ist zwar nicht ganz das selbe, aber lese mal HIER
      • W WurstDLX
        iobroker stop
        iobroker update
        iobroker start
        Dann habe ich
        ip a
        + instance is alive
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v10.24.1
        v10.24.1
        6.14.12
        nodejs:
          Versionstabelle:
         iobroker status
        States database error: connect ECONNREFUSED 127.0.0.1:9000 Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        da läuft bereits eine ioBroker installation und blockiert die Ports
        W 1 Antwort Letzte Antwort
          W Offline
          W Offline
          WurstDLX
          @homoran Hab diesen Fehler nicht beheben können :(. Wusste nicht wie, da er, dass auch nicht mehr gesagt hat und der obige log sich immer wieder weiderholte (endlos).
          Da der iobroker backup Befehl noch funktionierte, habe ich neu aufgesetzt und das Backup eingespielt. Aktuell sieht es so aus, als ob das funktioniert. Es ist noch alles da (Skripte, views und Adapter).
          Danke trotzdem!
