  4. ZigBee Adapter Verbindung zu CC2531 klappt nicht
    4.8k
15 Beiträge 6 Kommentatoren 1.7k Aufrufe 6 Watching
    sunshineh
    schrieb am zuletzt editiert von sunshineh
    Ich habe das Problem x-Fach gefunden und kann mal versuchen zu schildern, was ich bis jetzt herausgefunden habe:
    Fehlermeldung im ioBroker
    zigbee.0	2021-05-17 06:36:25.145	error	(5697) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
    zigbee.0	2021-05-17 06:36:25.143	error	(5697) Failed to start Zigbee
    zigbee.0	2021-05-17 06:36:24.956	info	(5697) Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.0	2021-05-17 06:36:24.937	info	(5697) Starting Zigbee npm ...
    zigbee.0	2021-05-17 06:36:24.936	info	(5697) Try to reconnect. 1 attempts left
    zigbee.0	2021-05-17 06:36:14.934	error	(5697) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
    zigbee.0	2021-05-17 06:36:14.932	error	(5697) Failed to start Zigbee
    zigbee.0	2021-05-17 06:35:55.308	info	(5697) Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee.0	2021-05-17 06:35:55.016	info	(5697) Starting Zigbee npm ...
    zigbee.0	2021-05-17 06:35:54.909	info	(5697) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    host.MasterWohnhaus	2021-05-17 06:35:52.520	info	instance system.adapter.zigbee.0 started with pid 5697
    host.MasterWohnhaus	2021-05-17 06:35:50.054	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0	2021-05-17 06:35:49.470	error	(4116) Cannot read property 'getEntries' of null
    zigbee.0	2021-05-17 06:35:49.470	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2021-05-17 06:35:49.470	error	at runMicrotasks (<anonymous>)
    zigbee.0	2021-05-17 06:35:49.470	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    zigbee.0	2021-05-17 06:35:49.470	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:367:20)
    zigbee.0	2021-05-17 06:35:49.470	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
    zigbee.0	2021-05-17 06:35:49.470	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    zigbee.0	2021-05-17 06:35:49.470	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:210:49)
    zigbee.0	2021-05-17 06:35:49.470	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    zigbee.0	2021-05-17 06:35:49.470	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
    zigbee.0	2021-05-17 06:35:49.470	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
    zigbee.0	2021-05-17 06:35:49.470	error	(4116) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2021-05-17 06:35:49.468	error	(4116) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-05-17 06:35:49.468	error	(4116) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Wenn ich den Befehl dmesg eingebe, erhalte ich folgendes zum CC2531
    [  411.835642] usb 1-1.3: USB disconnect, device number 3
    [  411.836255] cdc_acm 1-1.3:1.0: failed to set dtr/rts
    [  413.255929] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
    [  413.395412] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, b        cdDevice= 0.09
    [  413.395434] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
    [  413.395453] usb 1-1.3: Product: TI CC2531 USB CDC
    [  413.395471] usb 1-1.3: Manufacturer: Texas Instruments
    [  413.395488] usb 1-1.3: SerialNumber: __0X00124B0018E27250
    [  413.402578] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    [39037.432511] usb 1-1.3: USB disconnect, device number 4
    [39037.432887] cdc_acm 1-1.3:1.0: failed to set dtr/rts
    [39046.088860] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
    [39046.228120] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, b        cdDevice= 0.09
    [39046.228141] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
    [39046.228160] usb 1-1.3: Product: TI CC2531 USB CDC
    [39046.228177] usb 1-1.3: Manufacturer: Texas Instruments
    [39046.228194] usb 1-1.3: SerialNumber: __0X00124B0018E27250
    [39046.241271] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    Auf den Befehl
    sudo ls -l /proc/[0-9]/fd/ |grep /dev/ttyACM0
    Bekomme ich gar keine Rückmeldung.
    Ich habe den Zigbee-Adapter bereits installiert und auch schon die aktuellste Version von Gitbub installiert, was aber nicht geholfen hat.
    Zudem noch folgendes
    sudo ls -l /dev/serial/by-id
    insgesamt 0
    lrwxrwxrwx 1 root root 13 Mai 16 23:51 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E27250-if00 -> ../../ttyACM0
    ls -l /dev/ttyA*
    crw-rw---- 1 root dialout 166,  0 Mai 17 06:36 /dev/ttyACM0
    crw-rw---- 1 root dialout 204, 64 Mai 16 13:00 /dev/ttyAMA0
    J AsgothianA 2 Antworten Letzte Antwort
    • S sunshineh
      Auf den Befehl
      insgesamt 0
      ls -l /dev/ttyA*
      Jan1
      @sunshineh
      Also da hast ja viel gemacht und viel geschrieben. Wobei eigentlich das wichtigste fehlt und auch "die aktuellste Version von Github" erstens ne nichts sagende Aussage ist und zweitens von Git nur nach Anweisung des Entwickler installiert werden sollte ;)
      Poste einfach mal die Einstallung des Adapter, da Der Stick zumindest mal erkannt wird, tippe ich auf falsche Einstellungen.
      • S sunshineh
        Auf den Befehl
        insgesamt 0
        ls -l /dev/ttyA*
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @sunshineh
        • Es fehlt die initiale Fehlermeldung. Die Meldungen die du gepostet hast (Insbesondere die untere von 06:35:49:468) deuten darauf hin das der Zigbee Adapter beendet wird nachdem er nicht sauber starten konnte. Das bedeutet das es davor noch Meldungen geben muss die auf den eigentlichen Fehler hin deuten
        • Die Meldung "resource temporarily unavailable cannot lock port" deutet darauf hin das der serielle Port belegt ist
        • Die Meldung "(Error: SRSP - SYS - ping after 6000ms)" Deutet darauf hin das die Firmware auf dem cc2531 sich nicht meldet.
        Es bleiben daher die Folgenden Ursachen übrig:
        • die Firmware auf dem Stick ist abgestürzt. Lösung dazu: Stick abziehen, 30 sekunden warten, Stick anstecken.
        • Es gibt Störungen auf dem USB Zweig (oft verursacht durch USB3 Geräte, insbesondere Festplatten / SSD's)
        Die Installierte Version des Adapters (1.5.5 bei Dir) ist dabei nicht relevant.
        A.
        • AsgothianA Asgothian
          @sunshineh
          A.
          sunshineh
          OK, wieder Wochenende - ich geh das Thema nochmals an ;-)
          Also das LOG-File bzgl. Zigbee von heute:
          zigbee.0	2021-05-21 06:50:46.794	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
          zigbee.0	2021-05-21 06:50:46.794	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
          zigbee.0	2021-05-21 06:50:46.794	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
          zigbee.0	2021-05-21 06:50:46.794	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
          zigbee.0	2021-05-21 06:50:46.794	error	at new Promise (<anonymous>)
          zigbee.0	2021-05-21 06:50:46.794	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
          zigbee.0	2021-05-21 06:50:46.794	error	at Generator.next (<anonymous>)
          zigbee.0	2021-05-21 06:50:46.794	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
          zigbee.0	2021-05-21 06:50:46.794	error	(1389) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
          zigbee.0	2021-05-21 06:50:46.793	error	(1389) Failed to start Zigbee
          zigbee.0	2021-05-21 06:50:46.576	info	(1389) Installed Version: ioBroker/ioBroker.zigbee#master
          zigbee.0	2021-05-21 06:50:46.549	info	(1389) Starting Zigbee npm ...
          zigbee.0	2021-05-21 06:50:46.547	info	(1389) Try to reconnect. 1 attempts left
          zigbee.0	2021-05-21 06:50:36.545	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
          zigbee.0	2021-05-21 06:50:36.545	error	at Generator.throw (<anonymous>)
          zigbee.0	2021-05-21 06:50:36.545	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:93:31)
          zigbee.0	2021-05-21 06:50:36.545	error	(1389) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
          zigbee.0	2021-05-21 06:50:36.542	error	(1389) Failed to start Zigbee
          zigbee.0	2021-05-21 06:50:16.936	info	(1389) Installed Version: ioBroker/ioBroker.zigbee#master
          zigbee.0	2021-05-21 06:50:16.564	info	(1389) Starting Zigbee npm ...
          zigbee.0	2021-05-21 06:50:16.408	info	(1389) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
          • S sunshineh
            sunshineh
            Sorry, wenn ich nerve. Aber mit dem CC2531 hatte ich bereits mehrfach Probleme - zwischendurch ist es ja auch mal gelaufen - aber so kann ich mich einfach nicht darauf verlassen. Und ich möchte mein System ja nun fest einbauen und nicht mehr dran müssen.
            Welches ist der beste und stabilste ZigBee Stick?? Ich hab hier im Forum mal was von einer verbesserten Version gelesen - finde den Post aber leider nicht mehr.
            Bzw. gibt es auch eine Firmware, mit der der CC2531 für die nächsten Jahre stabil läuft??
            Thomas BraunT V 2 Antworten Letzte Antwort
            • S sunshineh
              @sunshineh
              https://www.zigbee2mqtt.io/information/supported_adapters.html
              • S sunshineh
                V Offline
                V Offline
                vikk88
                @sunshineh Ich habe den hier
                https://forum.iobroker.net/topic/39511/verkaufe-neueste-entwicklung-cc2652p-zigbee-stick
                läuft bei mir seit Dezember ohne Probleme
                • V vikk88
                  sunshineh
                  Danke für die Antworten. Ich hab mir grad bei Ebay den CC2652P Zigbee Stick gekauft und würde mich wahnsinnig freuen, wenn das dann mal ne stabile Angelegenheit wird...
                  Habt Ihr noch einen Tipp, wie ich meine beiden vorhandenen CC2531 wieder zum Laufen bekomme. Haben zwei Raspberry's mit neue aufgespielten ioBroker und bei beiden wird der Adapter nicht grün - bleibt gelb.
                  Einen Debugger für den CC2531 hab ich leider nicht, sonst hätte ich ihn mal geflasht und getestet...
                  • S sunshineh
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @sunshineh
                    Schau mal hier:
                    https://www.smarthomejetzt.de/cc2531-ohne-debugger-mit-raspberry-pi-als-zigbee-usb-stick-flashen/
                    A.
                      @sunshineh
                      Schau mal hier:
                      A.
                      sunshineh
                      Da ist was grundsätzlich bei der Installation falsch. Ich hab ja mein komplettes System neu aufgesetzt und jetzt auch den Zigbee Adapter deinstalliert. Nun habe ich mir einen neuen Stick mit dem CC2652P gekauft und bei der Installation bekomm ich folgende Meldung
                      host.MasterWohnhaus	2021-05-28 11:04:26.664	warn	some hosts are offline
                      zigbee.0	2021-05-28 07:50:18.633	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                      zigbee.0	2021-05-28 07:50:18.633	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                      zigbee.0	2021-05-28 07:50:18.633	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                      zigbee.0	2021-05-28 07:50:18.633	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                      zigbee.0	2021-05-28 07:50:18.633	error	at new Promise (<anonymous>)
                      zigbee.0	2021-05-28 07:50:18.633	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                      zigbee.0	2021-05-28 07:50:18.633	error	at Generator.next (<anonymous>)
                      zigbee.0	2021-05-28 07:50:18.633	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                      zigbee.0	2021-05-28 07:50:18.633	error	(5743) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                      zigbee.0	2021-05-28 07:50:18.632	error	(5743) Failed to start Zigbee
                      zigbee.0	2021-05-28 07:50:18.447	info	(5743) Installed Version: iobroker.zigbee@1.4.4
                      zigbee.0	2021-05-28 07:50:18.389	info	(5743) Starting Zigbee npm ...
                      zigbee.0	2021-05-28 07:50:18.387	info	(5743) Try to reconnect. 1 attempts left
                      zigbee.0	2021-05-28 07:50:08.385	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
                      zigbee.0	2021-05-28 07:50:08.385	error	at Generator.next (<anonymous>)
                      zigbee.0	2021-05-28 07:50:08.385	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:178:37)
                      zigbee.0	2021-05-28 07:50:08.385	error	(5743) TypeError: Cannot read property 'warn' of undefined
                      zigbee.0	2021-05-28 07:50:08.383	error	(5743) Failed to start Zigbee
                      zigbee.0	2021-05-28 07:50:06.773	info	(5743) Installed Version: iobroker.zigbee@1.4.4
                      zigbee.0	2021-05-28 07:50:06.219	info	(5743) Starting Zigbee npm ...
                      zigbee.0	2021-05-28 07:50:06.125	info	(5743) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      host.MasterWohnhaus	2021-05-28 07:50:03.800	info	instance system.adapter.zigbee.0 started with pid 5743
                      host.MasterWohnhaus	2021-05-28 07:50:01.847	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      host.MasterWohnhaus	2021-05-28 07:50:01.771	info	stopInstance system.adapter.zigbee.0 killing pid 5726
                      zigbee.0	2021-05-28 07:50:01.274	info	(5726) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0	2021-05-28 07:50:01.273	info	(5726) terminating
                      zigbee.0	2021-05-28 07:50:00.774	info	(5726) Zigbee: disabling joining new devices.
                      zigbee.0	2021-05-28 07:50:00.770	info	(5726) cleaned everything up...
                      host.MasterWohnhaus	2021-05-28 07:50:00.768	info	stopInstance system.adapter.zigbee.0 send kill signal
                      zigbee.0	2021-05-28 07:50:00.768	info	(5726) Got terminate signal TERMINATE_YOURSELF
                      host.MasterWohnhaus	2021-05-28 07:50:00.761	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      zigbee.0	2021-05-28 07:50:00.718	info	(5726) Zigbee started
                      zigbee.0	2021-05-28 07:50:00.716	info	(5726) Currently no devices.
                      zigbee.0	2021-05-28 07:50:00.706	info	(5726) --> transmitPower : normal
                      zigbee.0	2021-05-28 07:50:00.706	info	(5726) Unable to disable LED, unsupported function.
                      zigbee.0	2021-05-28 07:50:00.696	info	(5726) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210317}}
                      zigbee.0	2021-05-28 07:49:41.057	info	(5726) Installed Version: iobroker.zigbee@1.4.4
                      zigbee.0	2021-05-28 07:49:40.500	info	(5726) Starting Zigbee npm ...
                      zigbee.0	2021-05-28 07:49:40.407	info	(5726) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      host.MasterWohnhaus	2021-05-28 07:49:37.950	info	instance system.adapter.zigbee.0 started with pid 5726
                      host.MasterWohnhaus	2021-05-28 07:49:35.447	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      zigbee.0	2021-05-28 07:49:34.893	info	(5464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0	2021-05-28 07:49:34.890	info	(5464) terminating
                      zigbee.0	2021-05-28 07:49:34.886	warn	(5464) Failed to stop zigbee during startup
                      zigbee.0	2021-05-28 07:49:34.878	info	(5464) cleaned everything up...
                      host.MasterWohnhaus	2021-05-28 07:49:34.876	info	stopInstance system.adapter.zigbee.0 send kill signal
                      zigbee.0	2021-05-28 07:49:34.874	info	(5464) Got terminate signal TERMINATE_YOURSELF
                      host.MasterWohnhaus	2021-05-28 07:49:34.864	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      host.MasterWohnhaus	2021-05-28 07:47:38.022	warn	some hosts are offline
                      host.MasterWohnhaus	2021-05-28 07:47:21.149	warn	some hosts are offline
                      host.MasterWohnhaus	2021-05-28 07:47:16.057	info	iobroker exit 0
                      host.MasterWohnhaus	2021-05-28 07:47:15.018	info	iobroker Adapter "mqtt" updated
                      host.MasterWohnhaus	2021-05-28 07:47:14.960	info	iobroker upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
                      host.MasterWohnhaus	2021-05-28 07:47:14.902	info	iobroker upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
                      host.MasterWohnhaus	2021-05-28 07:47:14.803	info	iobroker upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                      host.MasterWohnhaus	2021-05-28 07:47:14.728	info	iobroker Update "system.adapter.mqtt.0"
                      host.MasterWohnhaus	2021-05-28 07:47:14.683	info	iobroker upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                      host.MasterWohnhaus	2021-05-28 07:46:39.709	info	iobroker gyp ERR! not ok
                      host.MasterWohnhaus	2021-05-28 07:46:39.704	info	iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at Chil
                      host.MasterWohnhaus	2021-05-28 07:46:39.693	info	iobroker gyp ERR! build error
                      host.MasterWohnhaus	2021-05-28 07:46:39.686	info	iobroker make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                      host.MasterWohnhaus	2021-05-28 07:46:38.920	info	iobroker ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/n
                      host.MasterWohnhaus	2021-05-28 07:46:38.915	info	iobroker ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: expected prima
                      host.MasterWohnhaus	2021-05-28 07:46:38.902	info	iobroker ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo
                      host.MasterWohnhaus	2021-05-28 07:46:38.895	info	iobroker ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<
                      host.MasterWohnhaus	2021-05-28 07:45:52.636	info	iobroker npm install iobroker.mqtt@2.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
                      host.MasterWohnhaus	2021-05-28 07:45:52.634	info	iobroker NPM version: 6.14.12
                      host.MasterWohnhaus	2021-05-28 07:45:52.025	info	iobroker Update mqtt from @2.3.5 to @2.4.0
                      host.MasterWohnhaus	2021-05-28 07:45:50.008	info	iobroker upgrade mqtt
                      host.MasterWohnhaus	2021-05-28 07:45:44.113	warn	some hosts are offline
                      host.MasterWohnhaus	2021-05-28 07:45:21.245	warn	some hosts are offline
                      zigbee.0	2021-05-28 07:17:29.699	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      zigbee.0	2021-05-28 07:17:29.699	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:24:58)
                      zigbee.0	2021-05-28 07:17:29.699	error	at Generator.next (<anonymous>)
                      zigbee.0	2021-05-28 07:17:29.699	error	at Function.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:85:27)
                      zigbee.0	2021-05-28 07:17:29.699	error	(5464) Error: No path provided and failed to auto detect path
                      zigbee.0	2021-05-28 07:17:29.698	error	(5464) Failed to start Zigbee
                      zigbee.0	2021-05-28 07:17:29.491	info	(5464) Installed Version: iobroker.zigbee@1.4.4
                      zigbee.0	2021-05-28 07:17:29.455	info	(5464) Starting Zigbee npm ...
                      zigbee.0	2021-05-28 07:17:29.453	info	(5464) Try to reconnect. 1 attempts left
                      zigbee.0	2021-05-28 07:17:19.458	info	(5464) Installed Version: iobroker.zigbee@1.4.4
                      zigbee.0	2021-05-28 07:17:19.451	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      zigbee.0	2021-05-28 07:17:19.451	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:24:58)
                      zigbee.0	2021-05-28 07:17:19.451	error	at Generator.next (<anonymous>)
                      zigbee.0	2021-05-28 07:17:19.451	error	at Function.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/adapter.js:85:27)
                      zigbee.0	2021-05-28 07:17:19.451	error	(5464) Error: No path provided and failed to auto detect path
                      zigbee.0	2021-05-28 07:17:19.450	error	(5464) Failed to start Zigbee
                      zigbee.0	2021-05-28 07:17:18.785	info	(5464) Starting Zigbee npm ...
                      zigbee.0	2021-05-28 07:17:18.673	error	(5464) Serial port not selected! Go to settings page.
                      zigbee.0	2021-05-28 07:17:18.628	info	(5464) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                      host.MasterWohnhaus	2021-05-28 07:17:18.424	warn	some hosts are offline
                      host.MasterWohnhaus	2021-05-28 07:17:15.348	info	instance system.adapter.zigbee.0 started with pid 5464
                      host.MasterWohnhaus	2021-05-28 07:17:13.332	info	iobroker exit 0
                      host.MasterWohnhaus	2021-05-28 07:17:12.290	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0 created
                      host.MasterWohnhaus	2021-05-28 07:17:12.252	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.exclude.all: []
                      host.MasterWohnhaus	2021-05-28 07:17:12.224	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.info.connection: false
                      host.MasterWohnhaus	2021-05-28 07:17:12.195	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.info.pairingMode: false
                      host.MasterWohnhaus	2021-05-28 07:17:12.167	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.info.pairingCountdown: 0
                      host.MasterWohnhaus	2021-05-28 07:17:12.139	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.info.pairingMessage:
                      host.MasterWohnhaus	2021-05-28 07:17:12.111	info	iobroker host.MasterWohnhaus Set default value of zigbee.0.info.groups:
                      host.MasterWohnhaus	2021-05-28 07:17:12.079	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.alive created
                      host.MasterWohnhaus	2021-05-28 07:17:12.050	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.connected created
                      host.MasterWohnhaus	2021-05-28 07:17:12.020	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.compactMode created
                      host.MasterWohnhaus	2021-05-28 07:17:11.990	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.cpu created
                      host.MasterWohnhaus	2021-05-28 07:17:11.960	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.cputime created
                      host.MasterWohnhaus	2021-05-28 07:17:11.931	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.memHeapUsed created
                      host.MasterWohnhaus	2021-05-28 07:17:11.898	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.memHeapTotal created
                      host.MasterWohnhaus	2021-05-28 07:17:11.869	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.memRss created
                      host.MasterWohnhaus	2021-05-28 07:17:11.839	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.uptime created
                      host.MasterWohnhaus	2021-05-28 07:17:11.809	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.inputCount created
                      host.MasterWohnhaus	2021-05-28 07:17:11.779	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.outputCount created
                      host.MasterWohnhaus	2021-05-28 07:17:11.749	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.eventLoopLag created
                      host.MasterWohnhaus	2021-05-28 07:17:11.719	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.sigKill created
                      host.MasterWohnhaus	2021-05-28 07:17:11.690	info	iobroker host.MasterWohnhaus object system.adapter.zigbee.0.logLevel created
                      host.MasterWohnhaus	2021-05-28 07:17:11.659	info	iobroker host.MasterWohnhaus object zigbee.0.exclude created
                      host.MasterWohnhaus	2021-05-28 07:17:11.630	info	iobroker host.MasterWohnhaus object zigbee.0.exclude.all created
                      host.MasterWohnhaus	2021-05-28 07:17:11.601	info	iobroker host.MasterWohnhaus object zigbee.0.info created
                      host.MasterWohnhaus	2021-05-28 07:17:11.572	info	iobroker host.MasterWohnhaus object zigbee.0.info.connection created
                      host.MasterWohnhaus	2021-05-28 07:17:11.542	info	iobroker host.MasterWohnhaus object zigbee.0.info.pairingMode created
                      host.MasterWohnhaus	2021-05-28 07:17:11.513	info	iobroker host.MasterWohnhaus object zigbee.0.info.pairingCountdown created
                      host.MasterWohnhaus	2021-05-28 07:17:11.484	info	iobroker host.MasterWohnhaus object zigbee.0.info.pairingMessage created
                      host.MasterWohnhaus	2021-05-28 07:17:11.455	info	iobroker host.MasterWohnhaus object zigbee.0.info.groups created
                      host.MasterWohnhaus	2021-05-28 07:17:11.444	info	iobroker host.MasterWohnhaus create instance zigbee
                      host.MasterWohnhaus	2021-05-28 07:17:09.374	info	iobroker add zigbee 0 --host MasterWohnhaus
                      Da passt doch was grundsätzlich nicht! Außerdem dauert es immer total lange, bis die Adapterseite lädt.
                      Habt ihr noch nen Tipp für mich?!
                      • K GrünK Offline
                        K GrünK Offline
                        K Grün
                        @sunshineh Hallo, bei mir sah es ähnlich aus. Vorweg , ich bin keine linux bzw iobroker Experte.
                        Ich hatte meiner Erinnerung, nach alles am laufen mit ZIGBEE@1.5.5, plötzlich hatte ich auch diese Probleme mit dem serialport.
                        Da ich den cc2531 nutze und ich schonmal Probleme hatte , habe ich neu geflasht.
                        Hat nix geholfen. Nach etlichen versuchen mit Versionen hin und her , habe ich per Kommandozeile den Zigbeeadapter
                        gelöscht und per Kommandozeile auch wieder neu installiert , allerdings die 1.5.3. Ich hatte dabei Rechteprobleme und konnte nur als sudo su komplett installieren. (speziel etwas mit binding zum serialport)
                        Danach habe ich ein npm rebuild gemacht. Ein Zigbee Backup eingespielt und es lief wieder mit allen Komponenten ohne neues anlernen.
                        Ob das alles so notwendig war weiß ich nicht , auf die 1.5.5 bin ich noch nicht zurückgegangen.
                        Wahrscheinlich schlagen die Experten die Hände über den Kopf zusammen, aber es geht ?????
                        • K GrünK K Grün
                          @k-grün sagte in ZigBee Adapter Verbindung zu CC2531 klappt nicht:
                          Das hört sich schon falsch an.
                          Da würde ich jetzt mal
                          iobroker stop
                          iobroker fix
                          drüber jagen, da hast du vermutlich jetzt erst recht die Rechte verbogen.
                          K GrünK 1 Antwort Letzte Antwort
                            iobroker stop
                            iobroker fix
                            K GrünK Offline
                            K GrünK Offline
                            K Grün
                            @thomas-braun Ja hatte ich danach schon gemacht ;-):confused:
                            • K GrünK K Grün
                              @k-grün
                              Es sollte eigentlich keinerlei Veranlassung auf einem 'senkrechten System' geben per sudo su eine root shell offen zu haben. Wenn du vermeintlich den dicken root-Hammer rausholen musst dann ist das System schon tiefer krumm. Oder du gehst falsch damit um.
                                @k-grün
                                K GrünK Offline
                                K GrünK Offline
                                K Grün
                                @k-grün said in ZigBee Adapter Verbindung zu CC2531 klappt nicht:
                                ....... Vorweg , ich bin keine linux bzw iobroker Experte.
                                ....Ob das alles so notwendig war weiß ich nicht , auf die 1.5.5 bin ich noch nicht zurückgegangen.
                                Wahrscheinlich schlagen die Experten die Hände über den Kopf zusammen, aber es geht ?????....
                                Das kann sein ;-)
                                32.7k
                                82.5k
