  4. [gelöst]Admin 5.0.28 Fehlercode
adapter admin 5.0.28
12 Beiträge 2 Kommentatoren 854 Aufrufe 2 Beobachtet
  • heinhanH Offline
    heinhanH Offline
    heinhan
    schrieb am zuletzt editiert von heinhan
    Hallo, bei der Aktualisierung von Adaptern wird immer folgender Detailtext angezeigt (Beispiel vis-icontwo):
    $ ./iobroker upgrade vis-icontwo
    Update vis-icontwo from @0.67.0 to @0.68.0
    NPM version: 6.14.12
    npm install iobroker.vis-icontwo@0.68.0 --loglevel error --prefix "/opt/iobroker" (System call)
    node-aead-crypto not needed on this system, since all ciphers are natively supported
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.4.83-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.22.1
    gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.83-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.22.1node-pre-gyp ERR! node-pre-gyp -v v0.15.0node-pre-gyp ERR! not ok
    upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
    Adapter "system.adapter.vis.0" restarted.
    upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css   (usw)
    Aktualisierungen laufen durch, Status der Instanzen anschl. grün..
    Raspi PI 4; NodeJS 12.22.1 NPM 6.14.12
    Dies zur Info für die weitere Entwicklung des Adapters, falls noch nicht bekannt.
    • heinhanH heinhan
      @heinhan
      Du meinst die Meldungen zu pixman und canvas?
      Hat mit dem admin nix zu tun.
      iobroker stop
      iobroker fix
      iobroker start
      sollte das fehlende Zeug nachinstallieren.
      Dein System auch aktuell halten. Du hast da einen alten Kernel laufen.
      heinhanH 1 Antwort Letzte Antwort
        @heinhan
        iobroker stop
        iobroker fix
        iobroker start
        heinhanH Offline
        heinhanH Offline
        heinhan
        @thomas-braun sagte in Admin 5.0.28 Fehlercode:
        @heinhan
        iobroker stop
        iobroker fix
        iobroker start
        Noch eine Frage zum System aktuell halten. Das geht doch über update & upgrade oder? Das mache ich fast täglich. Kann es sein das ein neuer Kernel noch nicht freigegeben ist?
        • heinhanH heinhan
          @heinhan
          iobroker stop
          iobroker fix
          iobroker start
          @heinhan
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
          Aktueller Kernel bei Raspberry OS ist 5.10.17.
            @heinhan
            sudo apt update
            sudo reboot
            heinhanH Offline
            heinhanH Offline
            heinhan
            Leider führen die obigen Befehle nicht zur Aktualisierung des Kernels:
            pi@raspberrypi:~ $ hostnamectl
               Static hostname: raspberrypi
                     Icon name: computer
                    Machine ID: ceadb6676c5441cfaa0ce6c152c7e0fc
                       Boot ID: ddf1f5c05a6647399a7903fb24a4c93e
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.4.83-v7l+
                  Architecture: arm
            pi@raspberrypi:~ $ sudo apt update
            OK:1 http://mirrordirector.raspbian.org/raspbian jessie InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://packages.grafana.com/oss/deb stable InRelease
            OK:4 https://deb.nodesource.com/node_12.x buster InRelease
            Alle Pakete sind aktuell.
            pi@raspberrypi:~ $ sudo apt dist-upgrade
            Paketaktualisierung (Upgrade) wird berechnet... Fertig
            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            Gibt es noch einen andere Möglichkeit der Aktualisierung ?
            • heinhanH heinhan
                       Icon name: computer
                    Architecture: arm
              @heinhan Du fährst ja auch einen gefährlichen Mix aus Jessie und Buster. Das kann nicht stabil funktionieren.
              Schau in die
              /etc/apt/sources.list
              oder
              /etc/apt/sources.list.d/raspi.list
              rein. Da dürfte noch eine Zeile mit Jessie aktiv sein.
              Richtig sehen die Dateien so aus:
              echad@chet:~ $ cat /etc/apt/sources.list.d/raspi.list
              deb http://archive.raspberrypi.org/debian/ buster main
              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
              #deb-src http://archive.raspberrypi.org/debian/ buster main
              deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
              #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                Schau in die
                oder
                heinhanH Offline
                heinhanH Offline
                heinhan
                @thomas-braun Nochmals ein Dankeschön für die Bereitstellung der Dateien.
                Jetzt läuft mein Raspi unter Kernel: Linux 5.10.17-v7l+ ohne Probleme.
                Ich hatte mich schon gewundert, warum in den letzten Wochen/Monate keine Updates für das Betriebssystem durchgeführt wurden. (137 wurden jetzt Dank Deiner Hilfe aktualisiert)
                Damit sollt das Problem erledigt sein.
                • heinhanH heinhan
                  @heinhan
                  Okay.
                  Wie sieht jetzt der Output auf
                  sudo apt update
                  aus?
                    @heinhan
                    Okay.
                    sudo apt update
                    aus?
                    heinhanH Offline
                    heinhanH Offline
                    heinhan
                    @thomas-braun Hier das Output:
                    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:2 http://archive.raspberrypi.org/debian buster InRelease
                    • heinhanH heinhan
                      @heinhan
                      Das sieht für den Moment gut aus. Mit dem grafana-Repo musst du ggf. mal aufpassen, wenn das kommende Release 'bullseye' stable wird und du auf buster bleibst. Kann dann Probleme geben, wenn grafana gegen bullseye gebaut wird und das anders läuft als unter buster.
                        @heinhan
                        heinhanH Offline
                        heinhanH Offline
                        heinhan
                        @thomas-braun Macht es denn Sinn, Grafana neu zu installieren um alles sauber zu haben?
                        • heinhanH heinhan
                          @heinhan
                          Nö, würde ich nicht machen.
