<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst]Admin 5.0.28 Fehlercode]]></title><description><![CDATA[<p dir="auto">Hallo, bei der Aktualisierung von Adaptern wird immer folgender Detailtext angezeigt (Beispiel vis-icontwo):</p>
<pre><code>$ ./iobroker upgrade vis-icontwo
Update vis-icontwo from @0.67.0 to @0.68.0
NPM version: 6.14.12
npm install iobroker.vis-icontwo@0.68.0 --loglevel error --prefix "/opt/iobroker" (System call)
node-aead-crypto not needed on this system, since all ciphers are natively supported
Package pixman-1 was not found in the pkg-config search path.
Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.4.83-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.22.1
gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.&lt;anonymous&gt; (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
node-pre-gyp ERR! System Linux 5.4.83-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.22.1node-pre-gyp ERR! node-pre-gyp -v v0.15.0node-pre-gyp ERR! not ok
upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
Adapter "system.adapter.vis.0" restarted.
upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css   (usw)
</code></pre>
<p dir="auto">Aktualisierungen laufen durch, Status der Instanzen anschl. grün..</p>
<p dir="auto">Raspi PI 4; NodeJS 12.22.1   NPM 6.14.12</p>
<p dir="auto">Dies zur Info für die weitere Entwicklung des Adapters, falls noch nicht bekannt.</p>
]]></description><link>https://forum.iobroker.net/topic/45155/gelöst-admin-5-0-28-fehlercode</link><generator>RSS for Node</generator><lastBuildDate>Sun, 24 May 2026 23:37:27 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/45155.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 May 2021 17:36:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 17:55:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a><br />
Nö, würde ich nicht machen.</p>
]]></description><link>https://forum.iobroker.net/post/632415</link><guid isPermaLink="true">https://forum.iobroker.net/post/632415</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 21 May 2021 17:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 17:54:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Macht es denn Sinn, Grafana neu zu installieren um alles sauber zu haben?</p>
]]></description><link>https://forum.iobroker.net/post/632414</link><guid isPermaLink="true">https://forum.iobroker.net/post/632414</guid><dc:creator><![CDATA[heinhan]]></dc:creator><pubDate>Fri, 21 May 2021 17:54:09 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 17:30:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a><br />
Das sieht für den Moment gut aus. Mit dem grafana-Repo musst du ggf. mal aufpassen, wenn das kommende Release 'bullseye' stable wird und du auf buster bleibst. Kann dann Probleme geben, wenn grafana gegen bullseye gebaut wird und das anders läuft als unter buster.</p>
]]></description><link>https://forum.iobroker.net/post/632410</link><guid isPermaLink="true">https://forum.iobroker.net/post/632410</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 21 May 2021 17:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 17:27:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Hier das Output:</p>
<pre><code>pi@raspberrypi:~ $ sudo apt update
OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
OK:2 http://archive.raspberrypi.org/debian buster InRelease
OK:3 https://packages.grafana.com/oss/deb stable InRelease
OK:4 https://deb.nodesource.com/node_12.x buster InRelease
Alle Pakete sind aktuell.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/632409</link><guid isPermaLink="true">https://forum.iobroker.net/post/632409</guid><dc:creator><![CDATA[heinhan]]></dc:creator><pubDate>Fri, 21 May 2021 17:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 16:56:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a><br />
Okay.<br />
Wie sieht jetzt der Output auf</p>
<pre><code>sudo apt update
</code></pre>
<p dir="auto">aus?</p>
]]></description><link>https://forum.iobroker.net/post/632398</link><guid isPermaLink="true">https://forum.iobroker.net/post/632398</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 21 May 2021 16:56:10 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Fri, 21 May 2021 16:53:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Nochmals ein Dankeschön für die Bereitstellung der Dateien.<br />
Jetzt läuft mein Raspi unter  Kernel: Linux 5.10.17-v7l+  ohne Probleme.</p>
<p dir="auto">Ich hatte mich schon gewundert, warum in den letzten Wochen/Monate keine Updates für das Betriebssystem durchgeführt wurden. (137 wurden jetzt Dank Deiner Hilfe aktualisiert)</p>
<p dir="auto">Damit sollt das Problem erledigt sein.</p>
]]></description><link>https://forum.iobroker.net/post/632396</link><guid isPermaLink="true">https://forum.iobroker.net/post/632396</guid><dc:creator><![CDATA[heinhan]]></dc:creator><pubDate>Fri, 21 May 2021 16:53:01 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Thu, 20 May 2021 17:03:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a> Du fährst ja auch einen gefährlichen Mix aus Jessie und Buster. Das kann nicht stabil funktionieren.</p>
<p dir="auto">Schau in die<br />
/etc/apt/sources.list<br />
oder<br />
/etc/apt/sources.list.d/raspi.list<br />
rein. Da dürfte noch eine Zeile mit Jessie aktiv sein.</p>
<p dir="auto">Richtig sehen die Dateien so aus:</p>
<pre><code>echad@chet:~ $ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ buster main
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspberrypi.org/debian/ buster main
</code></pre>
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
</code></pre>
]]></description><link>https://forum.iobroker.net/post/631875</link><guid isPermaLink="true">https://forum.iobroker.net/post/631875</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 20 May 2021 17:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Thu, 20 May 2021 16:32:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/631476">Admin 5.0.28 Fehlercode</a>:</p>
<blockquote>
<p dir="auto">sudo apt dist-upgrade</p>
</blockquote>
<p dir="auto">Leider führen die obigen Befehle nicht zur Aktualisierung des Kernels:</p>
<pre><code>pi@raspberrypi:~ $ hostnamectl
   Static hostname: raspberrypi
         Icon name: computer
        Machine ID: ceadb6676c5441cfaa0ce6c152c7e0fc
           Boot ID: ddf1f5c05a6647399a7903fb24a4c93e
  Operating System: Raspbian GNU/Linux 10 (buster)
            Kernel: Linux 5.4.83-v7l+
      Architecture: arm
OK:1 http://mirrordirector.raspbian.org/raspbian jessie InRelease
pi@raspberrypi:~ $ sudo apt dist-upgrade
Paketaktualisierung (Upgrade) wird berechnet... Fertig
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
</code></pre>
<p dir="auto">Gibt es noch einen andere Möglichkeit der Aktualisierung ?</p>
]]></description><link>https://forum.iobroker.net/post/631866</link><guid isPermaLink="true">https://forum.iobroker.net/post/631866</guid><dc:creator><![CDATA[heinhan]]></dc:creator><pubDate>Thu, 20 May 2021 16:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Thu, 20 May 2021 06:04:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a></p>
sudo reboot
</code></pre>
<p dir="auto">Aktueller Kernel bei Raspberry OS ist 5.10.17.</p>
]]></description><link>https://forum.iobroker.net/post/631476</link><guid isPermaLink="true">https://forum.iobroker.net/post/631476</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 20 May 2021 06:04:44 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Thu, 20 May 2021 05:51:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/631357">Admin 5.0.28 Fehlercode</a>:</p>
<blockquote>
<p dir="auto">Du meinst die Meldungen zu pixman und canvas?<br />
Hat mit dem admin nix zu tun.</p>
<pre><code>iobroker stop
iobroker fix
iobroker start
</code></pre>
<p dir="auto">sollte das fehlende Zeug nachinstallieren.</p>
<p dir="auto">Dein System auch aktuell halten. Du hast da einen alten Kernel laufen.</p>
</blockquote>
<p dir="auto">Noch eine Frage zum System aktuell halten. Das geht doch über update &amp; upgrade oder?  Das mache ich fast täglich. Kann es sein das ein neuer Kernel noch nicht freigegeben ist?</p>
]]></description><link>https://forum.iobroker.net/post/631474</link><guid isPermaLink="true">https://forum.iobroker.net/post/631474</guid><dc:creator><![CDATA[heinhan]]></dc:creator><pubDate>Thu, 20 May 2021 05:51:51 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Admin 5.0.28 Fehlercode on Wed, 19 May 2021 17:42:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heinhan" aria-label="Profile: heinhan">@<bdi>heinhan</bdi></a></p>
iobroker fix
iobroker start
</code></pre>
]]></description><link>https://forum.iobroker.net/post/631357</link><guid isPermaLink="true">https://forum.iobroker.net/post/631357</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 19 May 2021 17:42:34 GMT</pubDate></item></channel></rss>
