  4. Probleme mit Serialport bei zwave2
    6.7k
118 Beiträge 5 Kommentatoren 15.0k Aufrufe 2 Beobachtet
    @esmax666 Und deaktiviere den zwave2-Adapter vorerst mal für die ganze Prozedur.
    Esmax666
    ohne stick und zwave2 pausiert
    pi@raspberrypi:~ $ dmesg -T
    [So Mai 16 17:10:10 2021] Booting Linux on physical CPU 0x0
    [So Mai 16 17:10:10 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
    [So Mai 16 17:10:10 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [So Mai 16 17:10:10 2021] CPU: div instructions available: patching division code
    [So Mai 16 17:10:10 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [So Mai 16 17:10:10 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
    [So Mai 16 17:10:10 2021] Memory policy: Data cache writealloc
    [So Mai 16 17:10:10 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [So Mai 16 17:10:10 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [So Mai 16 17:10:10 2021] Zone ranges:
    [So Mai 16 17:10:10 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [So Mai 16 17:10:10 2021]   Normal   empty
    [So Mai 16 17:10:10 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
    [So Mai 16 17:10:10 2021] Movable zone start for each node
    [So Mai 16 17:10:10 2021] Early memory node ranges
    [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
    [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
    [So Mai 16 17:10:10 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
    [So Mai 16 17:10:10 2021] On node 0 totalpages: 2061056
    [So Mai 16 17:10:10 2021]   DMA zone: 2304 pages used for memmap
    [So Mai 16 17:10:10 2021]   DMA zone: 0 pages reserved
    [So Mai 16 17:10:10 2021]   DMA zone: 196608 pages, LIFO batch:63
    [So Mai 16 17:10:10 2021]   HighMem zone: 1864448 pages, LIFO batch:63
    [So Mai 16 17:10:10 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    [So Mai 16 17:10:10 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [So Mai 16 17:10:10 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [So Mai 16 17:10:10 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
    [So Mai 16 17:10:10 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [So Mai 16 17:10:10 2021] Kernel parameter elevator= does not have any effect anymore.
                              Please use sysfs to set IO scheduler for individual devices.
    [So Mai 16 17:10:10 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [So Mai 16 17:10:10 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [So Mai 16 17:10:10 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [So Mai 16 17:10:10 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
    [So Mai 16 17:10:10 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem)
    [So Mai 16 17:10:10 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [So Mai 16 17:10:10 2021] ftrace: allocating 33942 entries in 67 pages
    [So Mai 16 17:10:10 2021] ftrace: allocated 67 pages with 3 groups
    [So Mai 16 17:10:10 2021] rcu: Hierarchical RCU implementation.
    [So Mai 16 17:10:10 2021]       Rude variant of Tasks RCU enabled.
    [So Mai 16 17:10:10 2021]       Tracing variant of Tasks RCU enabled.
    [So Mai 16 17:10:10 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [So Mai 16 17:10:10 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [So Mai 16 17:10:10 2021] GIC: Using split EOI/Deactivate mode
    [So Mai 16 17:10:10 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
    [So Mai 16 17:10:10 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [So Mai 16 17:10:10 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [So Mai 16 17:10:10 2021] bcm2835: system timer (irq = 25)
    [So Mai 16 17:10:10 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [So Mai 16 17:10:10 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [So Mai 16 17:10:10 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [So Mai 16 17:10:10 2021] Switching to timer-based delay loop, resolution 18ns
    [So Mai 16 17:10:10 2021] Console: colour dummy device 80x30
    [So Mai 16 17:10:10 2021] printk: console [tty1] enabled
    [So Mai 16 17:10:10 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [So Mai 16 17:10:10 2021] pid_max: default: 32768 minimum: 301
    [So Mai 16 17:10:10 2021] LSM: Security Framework initializing
    [So Mai 16 17:10:10 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [So Mai 16 17:10:10 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [So Mai 16 17:10:10 2021] Disabling memory control group subsystem
    [So Mai 16 17:10:10 2021] CPU: Testing write buffer coherency: ok
    [So Mai 16 17:10:10 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [So Mai 16 17:10:10 2021] Setting up static identity map for 0x200000 - 0x20003c
    [So Mai 16 17:10:10 2021] rcu: Hierarchical SRCU implementation.
    [So Mai 16 17:10:10 2021] smp: Bringing up secondary CPUs ...
    [So Mai 16 17:10:10 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [So Mai 16 17:10:10 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [So Mai 16 17:10:10 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [So Mai 16 17:10:10 2021] smp: Brought up 1 node, 4 CPUs
    [So Mai 16 17:10:10 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [So Mai 16 17:10:10 2021] CPU: All CPU(s) started in HYP mode.
    [So Mai 16 17:10:10 2021] CPU: Virtualization extensions available.
    [So Mai 16 17:10:10 2021] devtmpfs: initialized
    [So Mai 16 17:10:10 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [So Mai 16 17:10:10 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [So Mai 16 17:10:10 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [So Mai 16 17:10:10 2021] pinctrl core: initialized pinctrl subsystem
    [So Mai 16 17:10:10 2021] NET: Registered protocol family 16
    [So Mai 16 17:10:10 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [So Mai 16 17:10:10 2021] audit: initializing netlink subsys (disabled)
    [So Mai 16 17:10:10 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [So Mai 16 17:10:10 2021] thermal_sys: Registered thermal governor 'step_wise'
    [So Mai 16 17:10:10 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [So Mai 16 17:10:10 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [So Mai 16 17:10:10 2021] Serial: AMBA PL011 UART driver
    [So Mai 16 17:10:10 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
    [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
    [So Mai 16 17:10:10 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [So Mai 16 17:10:10 2021] vgaarb: loaded
    [So Mai 16 17:10:10 2021] SCSI subsystem initialized
    [So Mai 16 17:10:10 2021] usbcore: registered new interface driver usbfs
    [So Mai 16 17:10:10 2021] usbcore: registered new interface driver hub
    [So Mai 16 17:10:10 2021] usbcore: registered new device driver usb
    [So Mai 16 17:10:10 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [So Mai 16 17:10:10 2021] clocksource: Switched to clocksource arch_sys_counter
    [So Mai 16 17:10:11 2021] VFS: Disk quotas dquot_6.6.0
    [So Mai 16 17:10:11 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [So Mai 16 17:10:11 2021] FS-Cache: Loaded
    [So Mai 16 17:10:11 2021] CacheFiles: Loaded
    [So Mai 16 17:10:11 2021] NET: Registered protocol family 2
    [So Mai 16 17:10:11 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [So Mai 16 17:10:11 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [So Mai 16 17:10:11 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [So Mai 16 17:10:11 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [So Mai 16 17:10:11 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [So Mai 16 17:10:11 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [So Mai 16 17:10:11 2021] NET: Registered protocol family 1
    [So Mai 16 17:10:11 2021] RPC: Registered named UNIX socket transport module.
    [So Mai 16 17:10:11 2021] RPC: Registered udp transport module.
    [So Mai 16 17:10:11 2021] RPC: Registered tcp transport module.
    [So Mai 16 17:10:11 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [So Mai 16 17:10:11 2021] PCI: CLS 0 bytes, default 64
    [So Mai 16 17:10:11 2021] Initialise system trusted keyrings
    [So Mai 16 17:10:11 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
    [So Mai 16 17:10:11 2021] zbud: loaded
    [So Mai 16 17:10:11 2021] FS-Cache: Netfs 'nfs' registered for caching
    [So Mai 16 17:10:11 2021] NFS: Registering the id_resolver key type
    [So Mai 16 17:10:11 2021] Key type id_resolver registered
    [So Mai 16 17:10:11 2021] Key type id_legacy registered
    [So Mai 16 17:10:11 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [So Mai 16 17:10:11 2021] Key type asymmetric registered
    [So Mai 16 17:10:11 2021] Asymmetric key parser 'x509' registered
    [So Mai 16 17:10:11 2021] bounce: pool size: 64 pages
    [So Mai 16 17:10:11 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [So Mai 16 17:10:11 2021] io scheduler mq-deadline registered
    [So Mai 16 17:10:11 2021] io scheduler kyber registered
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [So Mai 16 17:10:11 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [So Mai 16 17:10:11 2021] PCI: bus0: Fast back to back transfers disabled
    [So Mai 16 17:10:11 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [So Mai 16 17:10:11 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [So Mai 16 17:10:11 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
    [So Mai 16 17:10:11 2021] PCI: bus1: Fast back to back transfers disabled
    [So Mai 16 17:10:11 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [So Mai 16 17:10:11 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [So Mai 16 17:10:11 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
    [So Mai 16 17:10:11 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [So Mai 16 17:10:11 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
    [So Mai 16 17:10:11 2021] iproc-rng200 fe104000.rng: hwrng registered
    [So Mai 16 17:10:11 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
    [So Mai 16 17:10:11 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [So Mai 16 17:10:11 2021] brd: module loaded
    [So Mai 16 17:10:11 2021] loop: module loaded
    [So Mai 16 17:10:11 2021] Loading iSCSI transport class v2.0-870.
    [So Mai 16 17:10:11 2021] libphy: Fixed MDIO Bus: probed
    [So Mai 16 17:10:11 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [So Mai 16 17:10:11 2021] libphy: bcmgenet MII bus: probed
    [So Mai 16 17:10:11 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver r8152
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver lan78xx
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver smsc95xx
    [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
    [So Mai 16 17:10:11 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [So Mai 16 17:10:11 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [So Mai 16 17:10:11 2021] usb usb1: Product: xHCI Host Controller
    [So Mai 16 17:10:11 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [So Mai 16 17:10:11 2021] usb usb1: SerialNumber: 0000:01:00.0
    [So Mai 16 17:10:11 2021] hub 1-0:1.0: USB hub found
    [So Mai 16 17:10:11 2021] hub 1-0:1.0: 1 port detected
    [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [So Mai 16 17:10:11 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [So Mai 16 17:10:11 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [So Mai 16 17:10:11 2021] usb usb2: Product: xHCI Host Controller
    [So Mai 16 17:10:11 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [So Mai 16 17:10:11 2021] usb usb2: SerialNumber: 0000:01:00.0
    [So Mai 16 17:10:11 2021] hub 2-0:1.0: USB hub found
    [So Mai 16 17:10:11 2021] hub 2-0:1.0: 4 ports detected
    [So Mai 16 17:10:11 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [So Mai 16 17:10:11 2021] dwc_otg: FIQ enabled
    [So Mai 16 17:10:11 2021] dwc_otg: NAK holdoff enabled
    [So Mai 16 17:10:11 2021] dwc_otg: FIQ split-transaction FSM enabled
    [So Mai 16 17:10:11 2021] Module dwc_common_port init
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver uas
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usb-storage
    [So Mai 16 17:10:11 2021] mousedev: PS/2 mouse device common for all mice
    [So Mai 16 17:10:11 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [So Mai 16 17:10:11 2021] sdhci: Secure Digital Host Controller Interface driver
    [So Mai 16 17:10:11 2021] sdhci: Copyright(c) Pierre Ossman
    [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [So Mai 16 17:10:11 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [So Mai 16 17:10:11 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [So Mai 16 17:10:11 2021] hid: raw HID events driver (C) Jiri Kosina
    [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usbhid
    [So Mai 16 17:10:11 2021] usbhid: USB HID core driver
    [So Mai 16 17:10:11 2021] Initializing XFRM netlink socket
    [So Mai 16 17:10:11 2021] NET: Registered protocol family 17
    [So Mai 16 17:10:11 2021] Key type dns_resolver registered
    [So Mai 16 17:10:11 2021] Registering SWP/SWPB emulation handler
    [So Mai 16 17:10:11 2021] registered taskstats version 1
    [So Mai 16 17:10:11 2021] Loading compiled-in X.509 certificates
    [So Mai 16 17:10:11 2021] Key type ._fscrypt registered
    [So Mai 16 17:10:11 2021] Key type .fscrypt registered
    [So Mai 16 17:10:11 2021] Key type fscrypt-provisioning registered
    [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
    [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [So Mai 16 17:10:11 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [So Mai 16 17:10:11 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
    [So Mai 16 17:10:11 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [So Mai 16 17:10:11 2021] of_cfs_init
    [So Mai 16 17:10:11 2021] of_cfs_init: OK
    [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [So Mai 16 17:10:11 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [So Mai 16 17:10:11 2021] Waiting for root device PARTUUID=c7534f19-02...
    [So Mai 16 17:10:11 2021] random: fast init done
    [So Mai 16 17:10:11 2021] mmc1: new high speed SDIO card at address 0001
    [So Mai 16 17:10:11 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [So Mai 16 17:10:12 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [So Mai 16 17:10:12 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [So Mai 16 17:10:12 2021] usb 1-1: Product: USB2.0 Hub
    [So Mai 16 17:10:12 2021] hub 1-1:1.0: USB hub found
    [So Mai 16 17:10:12 2021] hub 1-1:1.0: 4 ports detected
    [So Mai 16 17:10:12 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [So Mai 16 17:10:12 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
    [So Mai 16 17:10:12 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [So Mai 16 17:10:12 2021] usb 2-2: Product: Ultra
    [So Mai 16 17:10:12 2021] usb 2-2: Manufacturer: SanDisk
    [So Mai 16 17:10:12 2021] usb 2-2: SerialNumber: 4C530000211114109264
    [So Mai 16 17:10:12 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
    [So Mai 16 17:10:12 2021] scsi host0: usb-storage 2-2:1.0
    [So Mai 16 17:10:13 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
    [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB)
    [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write Protect is off
    [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    [So Mai 16 17:10:13 2021]  sda: sda1 sda2
    [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [So Mai 16 17:10:13 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [So Mai 16 17:10:13 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [So Mai 16 17:10:13 2021] devtmpfs: mounted
    [So Mai 16 17:10:13 2021] Freeing unused kernel memory: 2048K
    [So Mai 16 17:10:13 2021] Run /sbin/init as init process
    [So Mai 16 17:10:13 2021]   with arguments:
    [So Mai 16 17:10:13 2021]     /sbin/init
    [So Mai 16 17:10:13 2021]     splash
    [So Mai 16 17:10:13 2021]   with environment:
    [So Mai 16 17:10:13 2021]     HOME=/
    [So Mai 16 17:10:13 2021]     TERM=linux
    [So Mai 16 17:10:13 2021] systemd[1]: System time before build time, advancing clock.
    [So Mai 16 17:10:13 2021] NET: Registered protocol family 10
    [So Mai 16 17:10:13 2021] Segment Routing with IPv6
    [So Mai 16 17:10:13 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [So Mai 16 17:10:13 2021] systemd[1]: Detected architecture arm.
    [So Mai 16 17:10:13 2021] systemd[1]: Set hostname to <raspberrypi>.
    [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
    [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
    [So Mai 16 17:10:14 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [So Mai 16 17:10:14 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [So Mai 16 17:10:14 2021] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [So Mai 16 17:10:14 2021] systemd[1]: Created slice system-getty.slice.
    [So Mai 16 17:10:14 2021] systemd[1]: Listening on udev Kernel Socket.
    [So Mai 16 17:10:14 2021] systemd[1]: Listening on Journal Audit Socket.
    [So Mai 16 17:10:15 2021] i2c /dev entries driver
    [So Mai 16 17:10:15 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
    [So Mai 16 17:10:15 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
    [So Mai 16 17:10:16 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [So Mai 16 17:10:16 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [So Mai 16 17:10:16 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [So Mai 16 17:10:16 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [So Mai 16 17:10:16 2021] mc: Linux media interface: v0.10
    [So Mai 16 17:10:16 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
    [So Mai 16 17:10:16 2021] videodev: Linux video capture interface: v2.00
    [So Mai 16 17:10:16 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: start
    [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: installed successfully
    [So Mai 16 17:10:16 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [So Mai 16 17:10:16 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [So Mai 16 17:10:16 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [So Mai 16 17:10:16 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [So Mai 16 17:10:16 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [So Mai 16 17:10:17 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [So Mai 16 17:10:17 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [So Mai 16 17:10:17 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [So Mai 16 17:10:17 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [So Mai 16 17:10:17 2021] usbcore: registered new interface driver brcmfmac
    [So Mai 16 17:10:17 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [So Mai 16 17:10:17 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [So Mai 16 17:10:17 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [So Mai 16 17:10:18 2021] random: crng init done
    [So Mai 16 17:10:18 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [So Mai 16 17:10:19 2021] uart-pl011 fe201000.serial: no DMA platform data
    [So Mai 16 17:10:19 2021] 8021q: 802.1Q VLAN Support v1.8
    [So Mai 16 17:10:20 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    [So Mai 16 17:10:20 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [So Mai 16 17:10:22 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:23 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:24 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:24 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [So Mai 16 17:10:24 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [So Mai 16 17:10:25 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [So Mai 16 17:10:26 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:26 2021] Bluetooth: Core ver 2.22
    [So Mai 16 17:10:26 2021] NET: Registered protocol family 31
    [So Mai 16 17:10:26 2021] Bluetooth: HCI device and connection manager initialized
    [So Mai 16 17:10:26 2021] Bluetooth: HCI socket layer initialized
    [So Mai 16 17:10:26 2021] Bluetooth: L2CAP socket layer initialized
    [So Mai 16 17:10:26 2021] Bluetooth: SCO socket layer initialized
    [So Mai 16 17:10:26 2021] Bluetooth: HCI UART driver ver 2.3
    [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol H4 registered
    [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Broadcom registered
    [So Mai 16 17:10:26 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [So Mai 16 17:10:26 2021] Bluetooth: BNEP filters: protocol multicast
    [So Mai 16 17:10:26 2021] Bluetooth: BNEP socket layer initialized
    [So Mai 16 17:10:26 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [So Mai 16 17:10:27 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:28 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:29 2021] broken atomic modeset userspace detected, disabling atomic
    [So Mai 16 17:10:30 2021] Bluetooth: hci0: command 0x1003 tx timeout
    [So Mai 16 17:10:32 2021] Bluetooth: hci0: command 0x1001 tx timeout
    [So Mai 16 17:10:34 2021] Bluetooth: hci0: command 0x1009 tx timeout
    pi@raspberrypi:~ $
    • E Esmax666
      pi@raspberrypi:~ $
      @esmax666
      Nutzt du bluetooth?
      Und schalt den Desktop aus!
      Auch den Remote Desktop, der da läuft.
      Auf dem Server wird sich per ssh angemeldet.
      Steck den Stick mal wieder rein und dann schaust du dir die neuen Zeilen in
      dmesg -T
      an.
      E 1 Antwort Letzte Antwort
        @esmax666
        Nutzt du bluetooth?
        dmesg -T
        an.
        Esmax666
        @thomas-braun desktop brauche ich
        bluetooth momentan nicht, habe ich jetzt raus gemacht, aber geht immer nocht nicht
        port ist aber immer beleg
        pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js -                                                          -force --logs
        2021-05-16 17:40:02.553  - info: zwave2.0 (9243) starting. Version 1.9.3 in /opt                                                          /iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
        Logging to file:
                /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
        2021-05-16 17:40:02.711  - error: zwave2.0 (9243) The Z-Wave driver could not be                                                           started: Error Resource temporarily unavailable Cannot lock port
        ^C2021-05-16 17:40:24.084  - info: zwave2.0 (9243) Shutting down driver...
        2021-05-16 17:40:24.092  - info: zwave2.0 (9243) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0
        lsof: WARNING: can't stat() fuse.xrdp-chansrv file system /home/pi/thinclient_drives
              Output information may be incomplete.
        lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
        COMMAND    PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
        hciattach  586     root    3u   CHR 204,64      0t0  135 /dev/ttyAMA0
        node      5352 iobroker   27uW  CHR 204,64      0t0  135 /dev/ttyA
        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ dmesg -T
        [So Mai 16 17:37:56 2021] Booting Linux on physical CPU 0x0
        [So Mai 16 17:37:56 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
        [So Mai 16 17:37:56 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [So Mai 16 17:37:56 2021] CPU: div instructions available: patching division code
        [So Mai 16 17:37:56 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [So Mai 16 17:37:56 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
        [So Mai 16 17:37:56 2021] Memory policy: Data cache writealloc
        [So Mai 16 17:37:56 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        [So Mai 16 17:37:56 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [So Mai 16 17:37:56 2021] Zone ranges:
        [So Mai 16 17:37:56 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        [So Mai 16 17:37:56 2021]   Normal   empty
        [So Mai 16 17:37:56 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
        [So Mai 16 17:37:56 2021] Movable zone start for each node
        [So Mai 16 17:37:56 2021] Early memory node ranges
        [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
        [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
        [So Mai 16 17:37:56 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
        [So Mai 16 17:37:56 2021] On node 0 totalpages: 2061056
        [So Mai 16 17:37:56 2021]   DMA zone: 2304 pages used for memmap
        [So Mai 16 17:37:56 2021]   DMA zone: 0 pages reserved
        [So Mai 16 17:37:56 2021]   DMA zone: 196608 pages, LIFO batch:63
        [So Mai 16 17:37:56 2021]   HighMem zone: 1864448 pages, LIFO batch:63
        [So Mai 16 17:37:56 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        [So Mai 16 17:37:56 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        [So Mai 16 17:37:56 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [So Mai 16 17:37:56 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
        [So Mai 16 17:37:56 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [So Mai 16 17:37:56 2021] Kernel parameter elevator= does not have any effect anymore.
        [So Mai 16 17:37:56 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [So Mai 16 17:37:56 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [So Mai 16 17:37:56 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
        [So Mai 16 17:37:56 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
        [So Mai 16 17:37:56 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem)
        [So Mai 16 17:37:56 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [So Mai 16 17:37:56 2021] ftrace: allocating 33942 entries in 67 pages
        [So Mai 16 17:37:56 2021] ftrace: allocated 67 pages with 3 groups
        [So Mai 16 17:37:56 2021] rcu: Hierarchical RCU implementation.
        [So Mai 16 17:37:56 2021]       Rude variant of Tasks RCU enabled.
        [So Mai 16 17:37:56 2021]       Tracing variant of Tasks RCU enabled.
        [So Mai 16 17:37:56 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [So Mai 16 17:37:56 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [So Mai 16 17:37:56 2021] GIC: Using split EOI/Deactivate mode
        [So Mai 16 17:37:56 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
        [So Mai 16 17:37:56 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [So Mai 16 17:37:56 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [So Mai 16 17:37:56 2021] bcm2835: system timer (irq = 25)
        [So Mai 16 17:37:56 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [So Mai 16 17:37:56 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [So Mai 16 17:37:56 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [So Mai 16 17:37:56 2021] Switching to timer-based delay loop, resolution 18ns
        [So Mai 16 17:37:56 2021] Console: colour dummy device 80x30
        [So Mai 16 17:37:56 2021] printk: console [tty1] enabled
        [So Mai 16 17:37:56 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [So Mai 16 17:37:56 2021] pid_max: default: 32768 minimum: 301
        [So Mai 16 17:37:56 2021] LSM: Security Framework initializing
        [So Mai 16 17:37:56 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [So Mai 16 17:37:56 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [So Mai 16 17:37:56 2021] Disabling memory control group subsystem
        [So Mai 16 17:37:56 2021] CPU: Testing write buffer coherency: ok
        [So Mai 16 17:37:56 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [So Mai 16 17:37:56 2021] Setting up static identity map for 0x200000 - 0x20003c
        [So Mai 16 17:37:56 2021] rcu: Hierarchical SRCU implementation.
        [So Mai 16 17:37:56 2021] smp: Bringing up secondary CPUs ...
        [So Mai 16 17:37:56 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [So Mai 16 17:37:56 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [So Mai 16 17:37:56 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [So Mai 16 17:37:56 2021] smp: Brought up 1 node, 4 CPUs
        [So Mai 16 17:37:56 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [So Mai 16 17:37:56 2021] CPU: All CPU(s) started in HYP mode.
        [So Mai 16 17:37:56 2021] CPU: Virtualization extensions available.
        [So Mai 16 17:37:56 2021] devtmpfs: initialized
        [So Mai 16 17:37:56 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [So Mai 16 17:37:56 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [So Mai 16 17:37:56 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [So Mai 16 17:37:56 2021] pinctrl core: initialized pinctrl subsystem
        [So Mai 16 17:37:56 2021] NET: Registered protocol family 16
        [So Mai 16 17:37:56 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [So Mai 16 17:37:56 2021] audit: initializing netlink subsys (disabled)
        [So Mai 16 17:37:56 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        [So Mai 16 17:37:56 2021] thermal_sys: Registered thermal governor 'step_wise'
        [So Mai 16 17:37:56 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [So Mai 16 17:37:56 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [So Mai 16 17:37:56 2021] Serial: AMBA PL011 UART driver
        [So Mai 16 17:37:56 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
        [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
        [So Mai 16 17:37:56 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [So Mai 16 17:37:56 2021] vgaarb: loaded
        [So Mai 16 17:37:56 2021] SCSI subsystem initialized
        [So Mai 16 17:37:56 2021] usbcore: registered new interface driver usbfs
        [So Mai 16 17:37:56 2021] usbcore: registered new interface driver hub
        [So Mai 16 17:37:56 2021] usbcore: registered new device driver usb
        [So Mai 16 17:37:56 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [So Mai 16 17:37:56 2021] clocksource: Switched to clocksource arch_sys_counter
        [So Mai 16 17:37:57 2021] VFS: Disk quotas dquot_6.6.0
        [So Mai 16 17:37:57 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [So Mai 16 17:37:57 2021] FS-Cache: Loaded
        [So Mai 16 17:37:57 2021] CacheFiles: Loaded
        [So Mai 16 17:37:57 2021] NET: Registered protocol family 2
        [So Mai 16 17:37:57 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [So Mai 16 17:37:57 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [So Mai 16 17:37:57 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [So Mai 16 17:37:57 2021] TCP: Hash tables configured (established 8192 bind 8192)
        [So Mai 16 17:37:57 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [So Mai 16 17:37:57 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [So Mai 16 17:37:57 2021] NET: Registered protocol family 1
        [So Mai 16 17:37:57 2021] RPC: Registered named UNIX socket transport module.
        [So Mai 16 17:37:57 2021] RPC: Registered udp transport module.
        [So Mai 16 17:37:57 2021] RPC: Registered tcp transport module.
        [So Mai 16 17:37:57 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [So Mai 16 17:37:57 2021] PCI: CLS 0 bytes, default 64
        [So Mai 16 17:37:57 2021] Initialise system trusted keyrings
        [So Mai 16 17:37:57 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
        [So Mai 16 17:37:57 2021] zbud: loaded
        [So Mai 16 17:37:57 2021] FS-Cache: Netfs 'nfs' registered for caching
        [So Mai 16 17:37:57 2021] NFS: Registering the id_resolver key type
        [So Mai 16 17:37:57 2021] Key type id_resolver registered
        [So Mai 16 17:37:57 2021] Key type id_legacy registered
        [So Mai 16 17:37:57 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [So Mai 16 17:37:57 2021] Key type asymmetric registered
        [So Mai 16 17:37:57 2021] Asymmetric key parser 'x509' registered
        [So Mai 16 17:37:57 2021] bounce: pool size: 64 pages
        [So Mai 16 17:37:57 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [So Mai 16 17:37:57 2021] io scheduler mq-deadline registered
        [So Mai 16 17:37:57 2021] io scheduler kyber registered
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
        [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [So Mai 16 17:37:57 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
        [So Mai 16 17:37:57 2021] PCI: bus0: Fast back to back transfers disabled
        [So Mai 16 17:37:57 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [So Mai 16 17:37:57 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [So Mai 16 17:37:57 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
        [So Mai 16 17:37:57 2021] PCI: bus1: Fast back to back transfers disabled
        [So Mai 16 17:37:57 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [So Mai 16 17:37:57 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
        [So Mai 16 17:37:57 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
        [So Mai 16 17:37:57 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
        [So Mai 16 17:37:57 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
        [So Mai 16 17:37:57 2021] iproc-rng200 fe104000.rng: hwrng registered
        [So Mai 16 17:37:57 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [So Mai 16 17:37:57 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [So Mai 16 17:37:57 2021] brd: module loaded
        [So Mai 16 17:37:57 2021] loop: module loaded
        [So Mai 16 17:37:57 2021] Loading iSCSI transport class v2.0-870.
        [So Mai 16 17:37:57 2021] libphy: Fixed MDIO Bus: probed
        [So Mai 16 17:37:57 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [So Mai 16 17:37:57 2021] libphy: bcmgenet MII bus: probed
        [So Mai 16 17:37:57 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver r8152
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver lan78xx
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver smsc95xx
        [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
        [So Mai 16 17:37:57 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [So Mai 16 17:37:57 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [So Mai 16 17:37:57 2021] usb usb1: Product: xHCI Host Controller
        [So Mai 16 17:37:57 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [So Mai 16 17:37:57 2021] usb usb1: SerialNumber: 0000:01:00.0
        [So Mai 16 17:37:57 2021] hub 1-0:1.0: USB hub found
        [So Mai 16 17:37:57 2021] hub 1-0:1.0: 1 port detected
        [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [So Mai 16 17:37:57 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        [So Mai 16 17:37:57 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [So Mai 16 17:37:57 2021] usb usb2: Product: xHCI Host Controller
        [So Mai 16 17:37:57 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [So Mai 16 17:37:57 2021] usb usb2: SerialNumber: 0000:01:00.0
        [So Mai 16 17:37:57 2021] hub 2-0:1.0: USB hub found
        [So Mai 16 17:37:57 2021] hub 2-0:1.0: 4 ports detected
        [So Mai 16 17:37:57 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [So Mai 16 17:37:57 2021] dwc_otg: FIQ enabled
        [So Mai 16 17:37:57 2021] dwc_otg: NAK holdoff enabled
        [So Mai 16 17:37:57 2021] dwc_otg: FIQ split-transaction FSM enabled
        [So Mai 16 17:37:57 2021] Module dwc_common_port init
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver uas
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usb-storage
        [So Mai 16 17:37:57 2021] mousedev: PS/2 mouse device common for all mice
        [So Mai 16 17:37:57 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [So Mai 16 17:37:57 2021] sdhci: Secure Digital Host Controller Interface driver
        [So Mai 16 17:37:57 2021] sdhci: Copyright(c) Pierre Ossman
        [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [So Mai 16 17:37:57 2021] sdhci-pltfm: SDHCI platform and OF driver helper
        [So Mai 16 17:37:57 2021] ledtrig-cpu: registered to indicate activity on CPUs
        [So Mai 16 17:37:57 2021] hid: raw HID events driver (C) Jiri Kosina
        [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usbhid
        [So Mai 16 17:37:57 2021] usbhid: USB HID core driver
        [So Mai 16 17:37:57 2021] Initializing XFRM netlink socket
        [So Mai 16 17:37:57 2021] NET: Registered protocol family 17
        [So Mai 16 17:37:57 2021] Key type dns_resolver registered
        [So Mai 16 17:37:57 2021] Registering SWP/SWPB emulation handler
        [So Mai 16 17:37:57 2021] registered taskstats version 1
        [So Mai 16 17:37:57 2021] Loading compiled-in X.509 certificates
        [So Mai 16 17:37:57 2021] Key type ._fscrypt registered
        [So Mai 16 17:37:57 2021] Key type .fscrypt registered
        [So Mai 16 17:37:57 2021] Key type fscrypt-provisioning registered
        [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
        [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [So Mai 16 17:37:57 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        [So Mai 16 17:37:57 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
        [So Mai 16 17:37:57 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [So Mai 16 17:37:57 2021] of_cfs_init
        [So Mai 16 17:37:57 2021] of_cfs_init: OK
        [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [So Mai 16 17:37:57 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [So Mai 16 17:37:57 2021] Waiting for root device PARTUUID=c7534f19-02...
        [So Mai 16 17:37:57 2021] random: fast init done
        [So Mai 16 17:37:57 2021] mmc1: new high speed SDIO card at address 0001
        [So Mai 16 17:37:57 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [So Mai 16 17:37:57 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [So Mai 16 17:37:57 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [So Mai 16 17:37:57 2021] usb 1-1: Product: USB2.0 Hub
        [So Mai 16 17:37:57 2021] hub 1-1:1.0: USB hub found
        [So Mai 16 17:37:57 2021] hub 1-1:1.0: 4 ports detected
        [So Mai 16 17:37:58 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [So Mai 16 17:37:58 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
        [So Mai 16 17:37:58 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [So Mai 16 17:37:58 2021] usb 2-2: Product: Ultra
        [So Mai 16 17:37:58 2021] usb 2-2: Manufacturer: SanDisk
        [So Mai 16 17:37:58 2021] usb 2-2: SerialNumber: 4C530000211114109264
        [So Mai 16 17:37:58 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
        [So Mai 16 17:37:58 2021] scsi host0: usb-storage 2-2:1.0
        [So Mai 16 17:37:59 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
        [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB)
        [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write Protect is off
        [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
        [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
        [So Mai 16 17:37:59 2021]  sda: sda1 sda2
        [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
        [So Mai 16 17:37:59 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [So Mai 16 17:37:59 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [So Mai 16 17:37:59 2021] devtmpfs: mounted
        [So Mai 16 17:37:59 2021] Freeing unused kernel memory: 2048K
        [So Mai 16 17:37:59 2021] Run /sbin/init as init process
        [So Mai 16 17:37:59 2021]   with arguments:
        [So Mai 16 17:37:59 2021]     /sbin/init
        [So Mai 16 17:37:59 2021]     splash
        [So Mai 16 17:37:59 2021]   with environment:
        [So Mai 16 17:37:59 2021]     HOME=/
        [So Mai 16 17:37:59 2021]     TERM=linux
        [So Mai 16 17:37:59 2021] systemd[1]: System time before build time, advancing clock.
        [So Mai 16 17:37:59 2021] NET: Registered protocol family 10
        [So Mai 16 17:37:59 2021] Segment Routing with IPv6
        [So Mai 16 17:37:59 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [So Mai 16 17:37:59 2021] systemd[1]: Detected architecture arm.
        [So Mai 16 17:37:59 2021] systemd[1]: Set hostname to <raspberrypi>.
        [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
        [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
        [So Mai 16 17:38:00 2021] random: systemd: uninitialized urandom read (16 bytes read)
        [So Mai 16 17:38:00 2021] systemd[1]: Created slice User and Session Slice.
        [So Mai 16 17:38:00 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
        [So Mai 16 17:38:00 2021] systemd[1]: Listening on Syslog Socket.
        [So Mai 16 17:38:00 2021] systemd[1]: Listening on udev Kernel Socket.
        [So Mai 16 17:38:00 2021] systemd[1]: Listening on Journal Socket (/dev/log).
        [So Mai 16 17:38:01 2021] i2c /dev entries driver
        [So Mai 16 17:38:01 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
        [So Mai 16 17:38:01 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
        [So Mai 16 17:38:02 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [So Mai 16 17:38:02 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [So Mai 16 17:38:02 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [So Mai 16 17:38:02 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [So Mai 16 17:38:02 2021] mc: Linux media interface: v0.10
        [So Mai 16 17:38:02 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] videodev: Linux video capture interface: v2.00
        [So Mai 16 17:38:02 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
        [So Mai 16 17:38:02 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: start
        [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: installed successfully
        [So Mai 16 17:38:02 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [So Mai 16 17:38:02 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [So Mai 16 17:38:02 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [So Mai 16 17:38:02 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [So Mai 16 17:38:03 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [So Mai 16 17:38:03 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        [So Mai 16 17:38:03 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [So Mai 16 17:38:03 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
        [So Mai 16 17:38:03 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [So Mai 16 17:38:03 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
        [So Mai 16 17:38:03 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [So Mai 16 17:38:03 2021] usbcore: registered new interface driver brcmfmac
        [So Mai 16 17:38:03 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        [So Mai 16 17:38:03 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [So Mai 16 17:38:05 2021] random: crng init done
        [So Mai 16 17:38:05 2021] random: 7 urandom warning(s) missed due to ratelimiting
        [So Mai 16 17:38:05 2021] uart-pl011 fe201000.serial: no DMA platform data
        [So Mai 16 17:38:05 2021] 8021q: 802.1Q VLAN Support v1.8
        [So Mai 16 17:38:06 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
        [So Mai 16 17:38:06 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet eth0: Link is Down
        [So Mai 16 17:38:08 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:09 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:10 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:11 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:12 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
        [So Mai 16 17:38:12 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
        [So Mai 16 17:38:12 2021] Bluetooth: Core ver 2.22
        [So Mai 16 17:38:12 2021] NET: Registered protocol family 31
        [So Mai 16 17:38:12 2021] Bluetooth: HCI device and connection manager initialized
        [So Mai 16 17:38:12 2021] Bluetooth: HCI socket layer initialized
        [So Mai 16 17:38:12 2021] Bluetooth: L2CAP socket layer initialized
        [So Mai 16 17:38:12 2021] Bluetooth: SCO socket layer initialized
        [So Mai 16 17:38:12 2021] Bluetooth: HCI UART driver ver 2.3
        [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol H4 registered
        [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Broadcom registered
        [So Mai 16 17:38:12 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [So Mai 16 17:38:12 2021] Bluetooth: BNEP filters: protocol multicast
        [So Mai 16 17:38:12 2021] Bluetooth: BNEP socket layer initialized
        [So Mai 16 17:38:13 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        [So Mai 16 17:38:13 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:14 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:38:15 2021] broken atomic modeset userspace detected, disabling atomic
        [So Mai 16 17:41:10 2021] fuse: init (API version 7.32)
        • E Esmax666
          Logging to file:
          @esmax666
          Da läuft ja immer noch ein gnome / fuse usw. mit.
          sudo raspi-config
          Dann dort:
          1 System Options       Configure system settings
          S5 Boot / Auto Login   Select boot into desktop or to command line
          B1 Console             Text console, requiring user to login
            @esmax666
            sudo raspi-config
            Dann dort:
            Esmax666
            #66
            @thomas-braun ja, ich brauche Desktop brauche generel
            hätte nie gedacht das Desktop probleme macht mit Z wave :/
            ist jetzt weg aber geht immer noch nicht ok
            [So Mai 16 17:53:13 2021] Booting Linux on physical CPU 0x0
            [So Mai 16 17:53:13 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
            [So Mai 16 17:53:13 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
            [So Mai 16 17:53:13 2021] CPU: div instructions available: patching division cod        e
            [So Mai 16 17:53:13 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct        ion cache
            [So Mai 16 17:53:13 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
            [So Mai 16 17:53:13 2021] Memory policy: Data cache writealloc
            [So Mai 16 17:53:13 2021] Reserved memory: created CMA memory pool at 0x00000000        1ec00000, size 256 MiB
            [So Mai 16 17:53:13 2021] OF: reserved mem: initialized node linux,cma, compatib        le id shared-dma-pool
            [So Mai 16 17:53:13 2021] Zone ranges:
            [So Mai 16 17:53:13 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
            [So Mai 16 17:53:13 2021]   Normal   empty
            [So Mai 16 17:53:13 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
            [So Mai 16 17:53:13 2021] Movable zone start for each node
            [So Mai 16 17:53:13 2021] Early memory node ranges
            [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff        ]
            [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff        ]
            [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff        ]
            [So Mai 16 17:53:13 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000        1ffffffff]
            [So Mai 16 17:53:13 2021] On node 0 totalpages: 2061056
            [So Mai 16 17:53:13 2021]   DMA zone: 2304 pages used for memmap
            [So Mai 16 17:53:13 2021]   DMA zone: 0 pages reserved
            [So Mai 16 17:53:13 2021]   DMA zone: 196608 pages, LIFO batch:63
            [So Mai 16 17:53:13 2021]   HighMem zone: 1864448 pages, LIFO batch:63
            [So Mai 16 17:53:13 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u819        20
            [So Mai 16 17:53:13 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
            [So Mai 16 17:53:13 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
            [So Mai 16 17:53:13 2021] Built 1 zonelists, mobility grouping on.  Total pages:        2058752
            [So Mai 16 17:53:13 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:        5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        y1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes r        ootwait quiet splash plymouth.ignore-serial-consoles
            [So Mai 16 17:53:13 2021] Kernel parameter elevator= does not have any effect an        ymore.
                                      Please use sysfs to set IO scheduler for individual de        vices.
            [So Mai 16 17:53:13 2021] Dentry cache hash table entries: 131072 (order: 7, 524        288 bytes, linear)
            [So Mai 16 17:53:13 2021] Inode-cache hash table entries: 65536 (order: 6, 26214        4 bytes, linear)
            [So Mai 16 17:53:13 2021] mem auto-init: stack:off, heap alloc:off, heap free:of        f
            [So Mai 16 17:53:13 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000        000018c00000] (64MB)
            [So Mai 16 17:53:13 2021] Memory: 7799068K/8244224K available (10240K kernel cod        e, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K c        ma-reserved, 7457792K highmem)
            [So Mai 16 17:53:13 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod        es=1
            [So Mai 16 17:53:13 2021] ftrace: allocating 33942 entries in 67 pages
            [So Mai 16 17:53:13 2021] ftrace: allocated 67 pages with 3 groups
            [So Mai 16 17:53:13 2021] rcu: Hierarchical RCU implementation.
            [So Mai 16 17:53:13 2021]       Rude variant of Tasks RCU enabled.
            [So Mai 16 17:53:13 2021]       Tracing variant of Tasks RCU enabled.
            [So Mai 16 17:53:13 2021] rcu: RCU calculated value of scheduler-enlistment dela        y is 10 jiffies.
            [So Mai 16 17:53:13 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
            [So Mai 16 17:53:13 2021] GIC: Using split EOI/Deactivate mode
            [So Mai 16 17:53:13 2021] random: get_random_bytes called from start_kernel+0x3c        8/0x59c with crng_init=0
            [So Mai 16 17:53:13 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr        aps every 2147483647500ns
            [So Mai 16 17:53:13 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff        fffff, max_idle_ns: 1911260446275 ns
            [So Mai 16 17:53:13 2021] bcm2835: system timer (irq = 25)
            [So Mai 16 17:53:13 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
            [So Mai 16 17:53:13 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
            [So Mai 16 17:53:13 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps        every 4398046511102ns
            [So Mai 16 17:53:13 2021] Switching to timer-based delay loop, resolution 18ns
            [So Mai 16 17:53:13 2021] Console: colour dummy device 80x30
            [So Mai 16 17:53:13 2021] printk: console [tty1] enabled
            [So Mai 16 17:53:13 2021] Calibrating delay loop (skipped), value calculated usi        ng timer frequency.. 108.00 BogoMIPS (lpj=540000)
            [So Mai 16 17:53:13 2021] pid_max: default: 32768 minimum: 301
            [So Mai 16 17:53:13 2021] LSM: Security Framework initializing
            [So Mai 16 17:53:13 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b        ytes, linear)
            [So Mai 16 17:53:13 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8        192 bytes, linear)
            [So Mai 16 17:53:13 2021] Disabling memory control group subsystem
            [So Mai 16 17:53:13 2021] CPU: Testing write buffer coherency: ok
            [So Mai 16 17:53:13 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [So Mai 16 17:53:13 2021] Setting up static identity map for 0x200000 - 0x20003c
            [So Mai 16 17:53:13 2021] rcu: Hierarchical SRCU implementation.
            [So Mai 16 17:53:13 2021] smp: Bringing up secondary CPUs ...
            [So Mai 16 17:53:13 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [So Mai 16 17:53:13 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            [So Mai 16 17:53:13 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            [So Mai 16 17:53:13 2021] smp: Brought up 1 node, 4 CPUs
            [So Mai 16 17:53:13 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS)        .
            [So Mai 16 17:53:13 2021] CPU: All CPU(s) started in HYP mode.
            [So Mai 16 17:53:13 2021] CPU: Virtualization extensions available.
            [So Mai 16 17:53:13 2021] devtmpfs: initialized
            [So Mai 16 17:53:13 2021] VFP support v0.3: implementor 41 architecture 3 part 4        0 variant 8 rev 0
            [So Mai 16 17:53:13 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf        fffffff, max_idle_ns: 19112604462750000 ns
            [So Mai 16 17:53:13 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,        linear)
            [So Mai 16 17:53:13 2021] pinctrl core: initialized pinctrl subsystem
            [So Mai 16 17:53:13 2021] NET: Registered protocol family 16
            [So Mai 16 17:53:13 2021] DMA: preallocated 1024 KiB pool for atomic coherent al        locations
            [So Mai 16 17:53:13 2021] audit: initializing netlink subsys (disabled)
            [So Mai 16 17:53:13 2021] audit: type=2000 audit(0.030:1): state=initialized aud        it_enabled=0 res=1
            [So Mai 16 17:53:13 2021] thermal_sys: Registered thermal governor 'step_wise'
            [So Mai 16 17:53:13 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
            [So Mai 16 17:53:13 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
            [So Mai 16 17:53:13 2021] Serial: AMBA PL011 UART driver
            [So Mai 16 17:53:13 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
            [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Attached to firmwar        e from 2021-04-30T13:45:52, variant start
            [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7        f29d96450abfc77cd6cf011af1faf1e03e5e56
            [So Mai 16 17:53:13 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac        hans=0x1
            [So Mai 16 17:53:13 2021] vgaarb: loaded
            [So Mai 16 17:53:13 2021] SCSI subsystem initialized
            [So Mai 16 17:53:13 2021] usbcore: registered new interface driver usbfs
            [So Mai 16 17:53:13 2021] usbcore: registered new interface driver hub
            [So Mai 16 17:53:13 2021] usbcore: registered new device driver usb
            [So Mai 16 17:53:13 2021] usb_phy_generic phy: supply vcc not found, using dummy        regulator
            [So Mai 16 17:53:13 2021] clocksource: Switched to clocksource arch_sys_counter
            [So Mai 16 17:53:14 2021] VFS: Disk quotas dquot_6.6.0
            [So Mai 16 17:53:14 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40        96 bytes)
            [So Mai 16 17:53:14 2021] FS-Cache: Loaded
            [So Mai 16 17:53:14 2021] CacheFiles: Loaded
            [So Mai 16 17:53:14 2021] NET: Registered protocol family 2
            [So Mai 16 17:53:14 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde        r: 0, 6144 bytes, linear)
            [So Mai 16 17:53:14 2021] TCP established hash table entries: 8192 (order: 3, 32        768 bytes, linear)
            [So Mai 16 17:53:14 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt        es, linear)
            [So Mai 16 17:53:14 2021] TCP: Hash tables configured (established 8192 bind 819        2)
            [So Mai 16 17:53:14 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li        near)
            [So Mai 16 17:53:14 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte        s, linear)
            [So Mai 16 17:53:14 2021] NET: Registered protocol family 1
            [So Mai 16 17:53:14 2021] RPC: Registered named UNIX socket transport module.
            [So Mai 16 17:53:14 2021] RPC: Registered udp transport module.
            [So Mai 16 17:53:14 2021] RPC: Registered tcp transport module.
            [So Mai 16 17:53:14 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu        le.
            [So Mai 16 17:53:14 2021] PCI: CLS 0 bytes, default 64
            [So Mai 16 17:53:14 2021] Initialise system trusted keyrings
            [So Mai 16 17:53:14 2021] workingset: timestamp_bits=14 max_order=21 bucket_orde        r=7
            [So Mai 16 17:53:14 2021] zbud: loaded
            [So Mai 16 17:53:14 2021] FS-Cache: Netfs 'nfs' registered for caching
            [So Mai 16 17:53:14 2021] NFS: Registering the id_resolver key type
            [So Mai 16 17:53:14 2021] Key type id_resolver registered
            [So Mai 16 17:53:14 2021] Key type id_legacy registered
            [So Mai 16 17:53:14 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register        ing...
            [So Mai 16 17:53:14 2021] Key type asymmetric registered
            [So Mai 16 17:53:14 2021] Asymmetric key parser 'x509' registered
            [So Mai 16 17:53:14 2021] bounce: pool size: 64 pages
            [So Mai 16 17:53:14 2021] Block layer SCSI generic (bsg) driver version 0.4 load        ed (major 249)
            [So Mai 16 17:53:14 2021] io scheduler mq-deadline registered
            [So Mai 16 17:53:14 2021] io scheduler kyber registered
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000        0 ranges:
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb        /pcie@7d500000, using [bus 00-ff]
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f        ffffff -> 0x00c0000000
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bf        ffffff -> 0x0400000000
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS        C)
            [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0        0
            [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
            [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x        63fffffff] (bus address [0xc0000000-0xffffffff])
            [So Mai 16 17:53:14 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
            [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
            [So Mai 16 17:53:14 2021] PCI: bus0: Fast back to back transfers disabled
            [So Mai 16 17:53:14 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
            [So Mai 16 17:53:14 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff        64bit]
            [So Mai 16 17:53:14 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
            [So Mai 16 17:53:14 2021] PCI: bus1: Fast back to back transfers disabled
            [So Mai 16 17:53:14 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6        000fffff]
            [So Mai 16 17:53:14 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6        00000fff 64bit]
            [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
            [So Mai 16 17:53:14 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6        000fffff]
            [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
            [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
            [So Mai 16 17:53:14 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable        d
            [So Mai 16 17:53:14 2021] bcm2835-aux-uart fe215040.serial: there is not valid m        aps for state default
            [So Mai 16 17:53:14 2021] iproc-rng200 fe104000.rng: hwrng registered
            [So Mai 16 17:53:14 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_s        ize:0x3ff00000(1023 MiB)
            [So Mai 16 17:53:14 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe        rs at 0xfe200000
            [So Mai 16 17:53:14 2021] brd: module loaded
            [So Mai 16 17:53:14 2021] loop: module loaded
            [So Mai 16 17:53:14 2021] Loading iSCSI transport class v2.0-870.
            [So Mai 16 17:53:14 2021] libphy: Fixed MDIO Bus: probed
            [So Mai 16 17:53:14 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
            [So Mai 16 17:53:14 2021] libphy: bcmgenet MII bus: probed
            [So Mai 16 17:53:14 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver r8152
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver lan78xx
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver smsc95xx
            [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
            [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 1
            [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi        on 0x100 quirks 0x0000030000000890
            [So Mai 16 17:53:14 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu        ct=0002, bcdDevice= 5.10
            [So Mai 16 17:53:14 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
            [So Mai 16 17:53:14 2021] usb usb1: Product: xHCI Host Controller
            [So Mai 16 17:53:14 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
            [So Mai 16 17:53:14 2021] usb usb1: SerialNumber: 0000:01:00.0
            [So Mai 16 17:53:14 2021] hub 1-0:1.0: USB hub found
            [So Mai 16 17:53:14 2021] hub 1-0:1.0: 1 port detected
            [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 2
            [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee        d
            [So Mai 16 17:53:14 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu        ct=0003, bcdDevice= 5.10
            [So Mai 16 17:53:14 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
            [So Mai 16 17:53:14 2021] usb usb2: Product: xHCI Host Controller
            [So Mai 16 17:53:14 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
            [So Mai 16 17:53:14 2021] usb usb2: SerialNumber: 0000:01:00.0
            [So Mai 16 17:53:14 2021] hub 2-0:1.0: USB hub found
            [So Mai 16 17:53:14 2021] hub 2-0:1.0: 4 ports detected
            [So Mai 16 17:53:14 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [So Mai 16 17:53:14 2021] dwc_otg: FIQ enabled
            [So Mai 16 17:53:14 2021] dwc_otg: NAK holdoff enabled
            [So Mai 16 17:53:14 2021] dwc_otg: FIQ split-transaction FSM enabled
            [So Mai 16 17:53:14 2021] Module dwc_common_port init
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver uas
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usb-storage
            [So Mai 16 17:53:14 2021] mousedev: PS/2 mouse device common for all mice
            [So Mai 16 17:53:14 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim        er
            [So Mai 16 17:53:14 2021] sdhci: Secure Digital Host Controller Interface driver
            [So Mai 16 17:53:14 2021] sdhci: Copyright(c) Pierre Ossman
            [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri        ng probe
            [So Mai 16 17:53:14 2021] sdhci-pltfm: SDHCI platform and OF driver helper
            [So Mai 16 17:53:14 2021] ledtrig-cpu: registered to indicate activity on CPUs
            [So Mai 16 17:53:14 2021] hid: raw HID events driver (C) Jiri Kosina
            [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usbhid
            [So Mai 16 17:53:14 2021] usbhid: USB HID core driver
            [So Mai 16 17:53:14 2021] Initializing XFRM netlink socket
            [So Mai 16 17:53:14 2021] NET: Registered protocol family 17
            [So Mai 16 17:53:14 2021] Key type dns_resolver registered
            [So Mai 16 17:53:14 2021] Registering SWP/SWPB emulation handler
            [So Mai 16 17:53:14 2021] registered taskstats version 1
            [So Mai 16 17:53:14 2021] Loading compiled-in X.509 certificates
            [So Mai 16 17:53:14 2021] Key type ._fscrypt registered
            [So Mai 16 17:53:14 2021] Key type .fscrypt registered
            [So Mai 16 17:53:14 2021] Key type fscrypt-provisioning registered
            [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: there is not valid maps fo        r state default
            [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl        ed
            [So Mai 16 17:53:14 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,        base_baud = 0) is a PL011 rev2
            [So Mai 16 17:53:14 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, b        ase_baud = 62500000) is a 16550
            [So Mai 16 17:53:14 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do        mains driver
            [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
            [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
            [So Mai 16 17:53:14 2021] of_cfs_init
            [So Mai 16 17:53:14 2021] of_cfs_init: OK
            [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            [So Mai 16 17:53:14 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm        c2] using ADMA
            [So Mai 16 17:53:14 2021] Waiting for root device PARTUUID=c7534f19-02...
            [So Mai 16 17:53:14 2021] random: fast init done
            [So Mai 16 17:53:14 2021] mmc1: new high speed SDIO card at address 0001
            [So Mai 16 17:53:14 2021] usb 1-1: new high-speed USB device number 2 using xhci        _hcd
            [So Mai 16 17:53:14 2021] usb 1-1: New USB device found, idVendor=2109, idProduc        t=3431, bcdDevice= 4.21
            [So Mai 16 17:53:14 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser        ialNumber=0
            [So Mai 16 17:53:14 2021] usb 1-1: Product: USB2.0 Hub
            [So Mai 16 17:53:14 2021] hub 1-1:1.0: USB hub found
            [So Mai 16 17:53:14 2021] hub 1-1:1.0: 4 ports detected
            [So Mai 16 17:53:15 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 usin        g xhci_hcd
            [So Mai 16 17:53:15 2021] usb 2-2: New USB device found, idVendor=0781, idProduc        t=5581, bcdDevice= 1.00
            [So Mai 16 17:53:15 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, Ser        ialNumber=3
            [So Mai 16 17:53:15 2021] usb 2-2: Product: Ultra
            [So Mai 16 17:53:15 2021] usb 2-2: Manufacturer: SanDisk
            [So Mai 16 17:53:15 2021] usb 2-2: SerialNumber: 4C530000211114109264
            [So Mai 16 17:53:15 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
            [So Mai 16 17:53:15 2021] scsi host0: usb-storage 2-2:1.0
            [So Mai 16 17:53:16 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra        1.00 PQ: 0 ANSI: 6
            [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (        62.1 GB/57.8 GiB)
            [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write Protect is off
            [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
            [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: e        nabled, doesn't support DPO or FUA
            [So Mai 16 17:53:16 2021]  sda: sda1 sda2
            [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
            [So Mai 16 17:53:16 2021] EXT4-fs (sda2): mounted filesystem with ordered data m        ode. Opts: (null)
            [So Mai 16 17:53:16 2021] VFS: Mounted root (ext4 filesystem) readonly on device        8:2.
            [So Mai 16 17:53:16 2021] devtmpfs: mounted
            [So Mai 16 17:53:16 2021] Freeing unused kernel memory: 2048K
            [So Mai 16 17:53:16 2021] Run /sbin/init as init process
            [So Mai 16 17:53:16 2021]   with arguments:
            [So Mai 16 17:53:16 2021]     /sbin/init
            [So Mai 16 17:53:16 2021]     splash
            [So Mai 16 17:53:16 2021]   with environment:
            [So Mai 16 17:53:16 2021]     HOME=/
            [So Mai 16 17:53:16 2021]     TERM=linux
            [So Mai 16 17:53:16 2021] systemd[1]: System time before build time, advancing c        lock.
            [So Mai 16 17:53:16 2021] NET: Registered protocol family 10
            [So Mai 16 17:53:16 2021] Segment Routing with IPv6
            [So Mai 16 17:53:16 2021] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN        UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie        rarchy=hybrid)
            [So Mai 16 17:53:16 2021] systemd[1]: Detected architecture arm.
            [So Mai 16 17:53:16 2021] systemd[1]: Set hostname to <raspberrypi>.
            [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFil        e= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp        .pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
            [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9:        PIDFile= references path below legacy directory /var/run/, updating /var/run/xr        dp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file acco        rdingly.
            [So Mai 16 17:53:17 2021] random: systemd: uninitialized urandom read (16 bytes        read)
            [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Audit Socket.
            [So Mai 16 17:53:17 2021] systemd[1]: Reached target Swap.
            [So Mai 16 17:53:17 2021] systemd[1]: Created slice User and Session Slice.
            [So Mai 16 17:53:17 2021] systemd[1]: Listening on Syslog Socket.
            [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Socket.
            [So Mai 16 17:53:18 2021] i2c /dev entries driver
            [So Mai 16 17:53:18 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
            [So Mai 16 17:53:18 2021] systemd-journald[115]: Received request to flush runti        me journal from PID 1
            [So Mai 16 17:53:19 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi        alised: Registers at 0xfeb00000 length 0x00010000
            [So Mai 16 17:53:19 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem        initialised: Registers at 0xfeb10000 length 0x00001000
            [So Mai 16 17:53:19 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi        alised: Registers at 0xfeb20000 length 0x00010000
            [So Mai 16 17:53:19 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial        ised: Registers at 0xfeb30000 length 0x00010000
            [So Mai 16 17:53:19 2021] vc_sm_cma: module is from the staging directory, the q        uality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive        r
            [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: start
            [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: installed successfully
            [So Mai 16 17:53:19 2021] mc: Linux media interface: v0.10
            [So Mai 16 17:53:19 2021] snd_bcm2835: module is from the staging directory, the        quality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835_audio bcm2835_audio: card created with 8 chann        els
            [So Mai 16 17:53:19 2021] videodev: Linux video capture interface: v2.00
            [So Mai 16 17:53:19 2021] bcm2835_mmal_vchiq: module is from the staging directo        ry, the quality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835_isp: module is from the staging directory, the        quality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe        red as /dev/video13
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist        ered as /dev/video14
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist        ered as /dev/video15
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register        ed as /dev/video16
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m        edia controller
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
            [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
            [So Mai 16 17:53:19 2021] bcm2835_codec: module is from the staging directory, t        he quality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835_v4l2: module is from the staging directory, th        e quality is unknown, you have been warned.
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video10
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video11
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video12
            [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
            [So Mai 16 17:53:19 2021] cfg80211: Loading compiled-in X.509 certificates for r        egulatory database
            [So Mai 16 17:53:20 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
            [So Mai 16 17:53:20 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c        ea7'
            [So Mai 16 17:53:20 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
            [So Mai 16 17:53:20 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d        on minor 0
            [So Mai 16 17:53:20 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4        3455-sdio for chip BCM4345/6
            [So Mai 16 17:53:20 2021] usbcore: registered new interface driver brcmfmac
            [So Mai 16 17:53:20 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/br        cmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
            [So Mai 16 17:53:20 2021] [drm] No displays found. Consider forcing hotplug if H        DMI is attached
            [So Mai 16 17:53:20 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_        ops [vc4])
            [So Mai 16 17:53:20 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor        1
            [So Mai 16 17:53:20 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w        l0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
            [So Mai 16 17:53:21 2021] random: crng init done
            [So Mai 16 17:53:21 2021] random: 7 urandom warning(s) missed due to ratelimitin        g
            [So Mai 16 17:53:22 2021] uart-pl011 fe201000.serial: no DMA platform data
            [So Mai 16 17:53:22 2021] 8021q: 802.1Q VLAN Support v1.8
            [So Mai 16 17:53:23 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents        :1 across:102396k FS
            [So Mai 16 17:53:23 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save en        abled
            [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet: configuring instance for e        xternal RGMII (RX delay)
            [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet eth0: Link is Down
            [So Mai 16 17:53:26 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu        ll - flow control off
            [So Mai 16 17:53:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read        y
            [So Mai 16 17:53:28 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s        yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_        ms instead
            [So Mai 16 17:53:28 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes rea        dy
            [So Mai 16 17:53:29 2021] Bluetooth: Core ver 2.22
            [So Mai 16 17:53:29 2021] NET: Registered protocol family 31
            [So Mai 16 17:53:29 2021] Bluetooth: HCI device and connection manager initializ        ed
            [So Mai 16 17:53:29 2021] Bluetooth: HCI socket layer initialized
            [So Mai 16 17:53:29 2021] Bluetooth: L2CAP socket layer initialized
            [So Mai 16 17:53:29 2021] Bluetooth: SCO socket layer initialized
            [So Mai 16 17:53:29 2021] Bluetooth: HCI UART driver ver 2.3
            [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol H4 registered
            [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere        d
            [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Broadcom registered
            [So Mai 16 17:53:29 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
            [So Mai 16 17:53:29 2021] Bluetooth: BNEP filters: protocol multicast
            [So Mai 16 17:53:29 2021] Bluetooth: BNEP socket layer initialized
            pi@raspberrypi:~ $
            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs
            2021-05-16 17:59:39.521  - info: zwave2.0 (30261) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
            Logging to file:
            2021-05-16 17:59:39.677  - error: zwave2.0 (30261) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
            • E Esmax666
              pi@raspberrypi:~ $ dmesg -T
              pi@raspberrypi:~ $
              Logging to file:
              #67
              @esmax666 sagte in Probleme mit Serialport bei zwave2:
              [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
              [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
              Da läuft immer noch Quark mit (Und die service-Datei ist auch falsch). Hast du VNC in raspi-config aktiv? Mach das da aus.
              Steck den Stick jetzt mal wieder rein und schau ob / welche Zeilen am Ende von
              dmesg -T
              neu dazu gekommen sind. Und nimm den EIntrag /dev/ttyAMA0 mal aus der Adapterkonfig raus. Da hab ich einen Denkfehler drin, das ist wohl das Bluetooth-Device.
                dmesg -T
                Esmax666
                #68
                @thomas-braun na dann was dann eintragen in serial
                @thomas-braun said in Probleme mit Serialport bei zwave2:
                wie soll ich das desaktivieren ?
                • E Esmax666
                  #69
                  Wie/wo hast du es denn aktiviert? Denn in der Grundkonfiguration läuft das nicht mit.
                  In raspi-config gibt es aber eine Einstellung aus der Ecke:
                  3 Interface Options   Configure connections to peripherals
                  P3 VNC                Enable/disable graphical remote access using RealVNC
                  Stell denn da mal aus, wenn der aktiv sein sollte.
                  Zum Port: Was passiert wenn du den auf /dev/ttyS0 stellst?
                  E 1 Antwort Letzte Antwort
                    Esmax666
                    schrieb am zuletzt editiert von Esmax666
                    #70
                    host.raspberrypi	2021-05-16 18:56:17.468	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    zwave2.0	2021-05-16 18:56:16.884	info	(23101) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zwave2.0	2021-05-16 18:56:16.883	info	(23101) terminating
                    zwave2.0	2021-05-16 18:56:16.882	info	(23101) Cleaned everything up!
                    zwave2.0	2021-05-16 18:56:16.882	info	(23101) Resetting node status...
                    zwave2.0	2021-05-16 18:56:16.875	info	(23101) Shutting down driver...
                    host.raspberrypi	2021-05-16 18:56:16.874	info	stopInstance system.adapter.zwave2.0 send kill signal
                    zwave2.0	2021-05-16 18:56:16.873	info	(23101) Got terminate signal TERMINATE_YOURSELF
                    host.raspberrypi	2021-05-16 18:56:16.864	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                    host.raspberrypi	2021-05-16 18:56:16.862	info	"system.adapter.zwave2.0" disabled
                    zwave2.0	2021-05-16 18:56:11.225	info	(23101) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                    zwave2.0	2021-05-16 18:56:10.987	debug	(23101) statesDB connected
                    zwave2.0	2021-05-16 18:56:10.986	debug	(23101) States connected to redis: 127.0.0.1:9000
                    zwave2.0	2021-05-16 18:56:10.978	debug	(23101) States create User PubSub Client
                    zwave2.0	2021-05-16 18:56:10.977	debug	(23101) States create System PubSub Client
                    zwave2.0	2021-05-16 18:56:10.970	debug	(23101) Redis States: Use Redis connection: 127.0.0.1:9000
                    zwave2.0	2021-05-16 18:56:10.967	debug	(23101) objectDB connected
                    zwave2.0	2021-05-16 18:56:10.939	debug	(23101) Objects connected to redis: 127.0.0.1:9001
                    zwave2.0	2021-05-16 18:56:10.925	debug	(23101) Objects client initialize lua scripts
                    zwave2.0	2021-05-16 18:56:10.924	debug	(23101) Objects create User PubSub Client
                    zwave2.0	2021-05-16 18:56:10.923	debug	(23101) Objects create System PubSub Client
                    zwave2.0	2021-05-16 18:56:10.920	debug	(23101) Objects client ready ... initialize now
                    zwave2.0	2021-05-16 18:56:10.885	debug	(23101) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    host.raspberrypi	2021-05-16 18:56:08.964	info	instance system.adapter.zwave2.0 started with pid 23101
                    host.raspberrypi	2021-05-16 18:56:07.922	info	Restart adapter system.adapter.zwave2.0 because enabled
                    host.raspberrypi	2021-05-16 18:56:07.920	info	instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    • E Esmax666
                      Esmax666
                      #71
                      instance war nicht gestartet falls instance gestartet ist bekomme ich das:
                      • E Esmax666
                        #72
                        @esmax666
                        Kannst du bitte durchgängig Text in CodeTags setzen und die Screenshots sparen?
                          @esmax666
                          Esmax666
                          #73
                          @thomas-braun was brauchst du genau ?
                          2021-05-16 19:29:14.147  - info: zwave2.0 (25187) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          Logging to file:
                                  /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
                          2021-05-16 19:29:14.284  - error: zwave2.0 (25187) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                          2021-05-16 19:29:17.956  - warn: zwave2.0 (25187) Got terminate signal. Checking desired PID: 0 vs own PID 25187
                          2021-05-16 19:29:17.998  - warn: zwave2.0 (25187) Got terminate signal. Checking desired PID: 25202 vs own PID 25187
                          2021-05-16 19:29:20.258  - debug: zwave2.0 (25187) object zwave2.0.info changed: {"_id":"zwave2.0.info","type":"channel","common":{"name":"Information"},"native":{},"from":"system.adapter.zwave2.0","ts":1621186160254,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                          2021-05-16 19:29:20.267  - debug: zwave2.0 (25187) object zwave2.0.info.connection changed: {"_id":"zwave2.0.info.connection","type":"state","common":{"role":"indicator.connected","name":"Whether the Z-Wave driver is ready","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621186160262,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                          2021-05-16 19:29:20.277  - debug: zwave2.0 (25187) object zwave2.0.info.inclusion changed: {"_id":"zwave2.0.info.inclusion","type":"state","common":{"role":"state","name":"Which state the inclusion of nodes is in","type":"number","read":true,"write":true,"def":0,"states":{"0":"Idle","1":"Non-secure","2":"Secure"}},"native":{},"from":"system.adapter.zwave2.0","ts":1621186160271,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                          2021-05-16 19:29:20.286  - debug: zwave2.0 (25187) object zwave2.0.info.exclusion changed: {"_id":"zwave2.0.info.exclusion","type":"state","common":{"role":"state","name":"Whether the exclusion of nodes is active","type":"boolean","read":true,"write":true,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621186160280,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                          2021-05-16 19:29:20.296  - debug: zwave2.0 (25187) object zwave2.0.info.healingNetwork changed: {"_id":"zwave2.0.info.healingNetwork","type":"state","common":{"role":"state","name":"Whether a network heal is currently in progress","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621186160290,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                          2021-05-16 19:29:30.203  - warn: zwave2.0 (25187) Got terminate signal. Checking desired PID: 0 vs own PID 25187
                          2021-05-16 19:29:30.225  - warn: zwave2.0 (25187) Got terminate signal. Checking desired PID: 25217 vs own PID 25187
                          ^C2021-05-16 19:29:48.754  - info: zwave2.0 (25187) Shutting down driver...
                          dannach habe ich die instance in wegGUI pausiert und dann habe ich das bekommen:
                          2021-05-16 19:30:42.543  - error: zwave2.0 (25291) adapter disabled
                          2021-05-16 19:30:42.553  - info: zwave2.0 (25291) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          Logging to file:
                          2021-05-16 19:30:49.789  - error: zwave2.0 (25291) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                          2021-05-16 19:30:49.791  - error: zwave2.0 (25291) Restarting the adapter in a second...
                          2021-05-16 19:30:50.794  - info: zwave2.0 (25291) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2021-05-16 19:30:51.323  - info: zwave2.0 (25291) Shutting down driver...
                          Log in Webinterface
                          zwave2.0	2021-05-16 19:30:51.323	info	(25291) Shutting down driver...
                          zwave2.0	2021-05-16 19:30:50.794	info	(25291) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          zwave2.0	2021-05-16 19:30:49.791	error	(25291) Restarting the adapter in a second...
                          zwave2.0	2021-05-16 19:30:49.789	error	(25291) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                          zwave2.0	2021-05-16 19:30:42.553	info	(25291) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 19:30:42.543	error	(25291) adapter disabled
                          host.raspberrypi	2021-05-16 19:30:30.256	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypi	2021-05-16 19:30:29.642	info	stopInstance system.adapter.zwave2.0 send kill signal
                          zwave2.0	2021-05-16 19:30:29.646	info	(25276) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zwave2.0	2021-05-16 19:30:29.645	info	(25276) terminating
                          zwave2.0	2021-05-16 19:30:29.644	info	(25276) Shutting down driver...
                          zwave2.0	2021-05-16 19:30:29.642	info	(25276) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2021-05-16 19:30:29.634	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                          host.raspberrypi	2021-05-16 19:30:29.632	info	"system.adapter.zwave2.0" disabled
                          zwave2.0	2021-05-16 19:30:29.251	info	(25276) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 19:30:29.063	debug	(25276) statesDB connected
                          zwave2.0	2021-05-16 19:30:29.062	debug	(25276) States connected to redis: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:29.054	debug	(25276) States create User PubSub Client
                          zwave2.0	2021-05-16 19:30:29.053	debug	(25276) States create System PubSub Client
                          zwave2.0	2021-05-16 19:30:29.046	debug	(25276) Redis States: Use Redis connection: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:29.043	debug	(25276) objectDB connected
                          zwave2.0	2021-05-16 19:30:29.014	debug	(25276) Objects connected to redis: 127.0.0.1:9001
                          zwave2.0	2021-05-16 19:30:29.001	debug	(25276) Objects client initialize lua scripts
                          zwave2.0	2021-05-16 19:30:28.999	debug	(25276) Objects create User PubSub Client
                          zwave2.0	2021-05-16 19:30:28.998	debug	(25276) Objects create System PubSub Client
                          zwave2.0	2021-05-16 19:30:28.995	debug	(25276) Objects client ready ... initialize now
                          zwave2.0	2021-05-16 19:30:28.959	debug	(25276) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          host.raspberrypi	2021-05-16 19:30:27.032	info	instance system.adapter.zwave2.0 started with pid 25276
                          host.raspberrypi	2021-05-16 19:30:25.992	info	Restart adapter system.adapter.zwave2.0 because enabled
                          host.raspberrypi	2021-05-16 19:30:25.991	info	instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          zwave2.0	2021-05-16 19:30:25.846	info	(25260) Shutting down driver...
                          zwave2.0	2021-05-16 19:30:25.318	info	(25260) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          zwave2.0	2021-05-16 19:30:24.315	error	(25260) Restarting the adapter in a second...
                          zwave2.0	2021-05-16 19:30:24.314	error	(25260) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                          zwave2.0	2021-05-16 19:30:17.136	info	(25260) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 19:30:16.947	debug	(25260) statesDB connected
                          zwave2.0	2021-05-16 19:30:16.946	debug	(25260) States connected to redis: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:16.935	debug	(25260) States create User PubSub Client
                          zwave2.0	2021-05-16 19:30:16.933	debug	(25260) States create System PubSub Client
                          zwave2.0	2021-05-16 19:30:16.923	debug	(25260) Redis States: Use Redis connection: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:16.921	debug	(25260) objectDB connected
                          zwave2.0	2021-05-16 19:30:16.891	debug	(25260) Objects connected to redis: 127.0.0.1:9001
                          zwave2.0	2021-05-16 19:30:16.873	debug	(25260) Objects client initialize lua scripts
                          zwave2.0	2021-05-16 19:30:16.871	debug	(25260) Objects create User PubSub Client
                          zwave2.0	2021-05-16 19:30:16.870	debug	(25260) Objects create System PubSub Client
                          zwave2.0	2021-05-16 19:30:16.867	debug	(25260) Objects client ready ... initialize now
                          zwave2.0	2021-05-16 19:30:16.829	debug	(25260) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          host.raspberrypi	2021-05-16 19:30:14.928	info	instance system.adapter.zwave2.0 started with pid 25260
                          host.raspberrypi	2021-05-16 19:30:13.877	info	Restart adapter system.adapter.zwave2.0 because enabled
                          host.raspberrypi	2021-05-16 19:30:13.877	info	instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          zwave2.0	2021-05-16 19:30:13.806	info	(25245) Shutting down driver...
                          zwave2.0	2021-05-16 19:30:13.292	info	(25245) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          zwave2.0	2021-05-16 19:30:12.289	error	(25245) Restarting the adapter in a second...
                          zwave2.0	2021-05-16 19:30:12.288	error	(25245) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                          host.raspberrypi	2021-05-16 19:30:08.128	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          ical.0	2021-05-16 19:30:07.603	info	(25230) Terminated (NO_ERROR): Without reason
                          zwave2.0	2021-05-16 19:30:05.076	info	(25245) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 19:30:04.824	debug	(25245) statesDB connected
                          zwave2.0	2021-05-16 19:30:04.823	debug	(25245) States connected to redis: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:04.815	debug	(25245) States create User PubSub Client
                          zwave2.0	2021-05-16 19:30:04.814	debug	(25245) States create System PubSub Client
                          zwave2.0	2021-05-16 19:30:04.807	debug	(25245) Redis States: Use Redis connection: 127.0.0.1:9000
                          zwave2.0	2021-05-16 19:30:04.804	debug	(25245) objectDB connected
                          zwave2.0	2021-05-16 19:30:04.776	debug	(25245) Objects connected to redis: 127.0.0.1:9001
                          zwave2.0	2021-05-16 19:30:04.762	debug	(25245) Objects client initialize lua scripts
                          zwave2.0	2021-05-16 19:30:04.761	debug	(25245) Objects create User PubSub Client
                          zwave2.0	2021-05-16 19:30:04.759	debug	(25245) Objects create System PubSub Client
                          zwave2.0	2021-05-16 19:30:04.756	debug	(25245) Objects client ready ... initialize now
                          zwave2.0	2021-05-16 19:30:04.720	debug	(25245) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          host.raspberrypi	2021-05-16 19:30:02.782	info	instance system.adapter.zwave2.0 started with pid 25245
                          Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
                          • E Esmax666
                            Logging to file:
                            Logging to file:
                            Log in Webinterface
                            #74
                            @esmax666
                            Hattest du die letzen Zeilen aus
                            dmesg -T
                            schon gepostet, kurz nachdem der Stick nochmal eingesteckt wurde?
                            • E Esmax666
                              Logging to file:
                              Logging to file:
                              Log in Webinterface
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #75
                              @esmax666 Mach in den Optionen mal das Logfile aus, dann sieht man auf der Konsole mehr.
                              Das heißt vermutlich, dass beim eingestellten Port kein Z-Wave Stick eingesteckt ist.
                              • AlCalzoneA AlCalzone
                                Esmax666
                                #76
                                @alcalzone said in Probleme mit Serialport bei zwave2:
                                das Logfile aus,
                                wie mache ich das `?
                                • E Esmax666
                                  das Logfile aus,
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #77
                                    Esmax666
                                    #78
                                    @alcalzone ist schon aktiviert
                                    • E Esmax666
                                      #79
                                      du sollst es ja ausschalten
                                        Esmax666
                                        #80
                                        @homoran @AlCalzone ach so sorry lol
                                        (mit /dev/ttyS0)
                                        hier falls zwave instance in GUI auf stop ist->
                                        2021-05-16 19:54:23.636  - error: zwave2.0 (25523) adapter disabled
                                        2021-05-16 19:54:23.646  - info: zwave2.0 (25523) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                        19:54:23.726 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                                        19:54:23.730 DRIVER   version 7.4.0
                                        19:54:23.732 CONFIG   version 7.4.0
                                        19:54:23.732 DRIVER
                                        19:54:23.733 DRIVER   starting driver...
                                        19:54:23.761 DRIVER   opening serial port /dev/ttyS0
                                        19:54:23.779 DRIVER   serial port opened
                                        19:54:23.781 SERIAL » [NAK]        (0x15)
                                        19:54:25.287 DRIVER   loading configuration...
                                        19:54:26.427 DRIVER   beginning interview...
                                        19:54:26.428 DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                                              1 registered
                                        19:54:26.429 DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                                              1 registered
                                        19:54:26.430 DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                                              1 registered
                                        19:54:26.432 CNTRLR   beginning interview...
                                        19:54:26.432 CNTRLR   querying version info...
                                        19:54:26.616 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:54:26.619 DRIVER » [REQ] [GetControllerVersion]
                                        19:54:27.629 CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                                              n 100 ms.
                                        19:54:27.732 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:54:27.733 DRIVER » [REQ] [GetControllerVersion]
                                        19:54:28.736 CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                                              n 1100 ms.
                                        19:54:29.840 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:54:29.842 DRIVER » [REQ] [GetControllerVersion]
                                        19:54:30.864 DRIVER   Failed to initialize the driver: Timeout while waiting for an ACK from the con
                                                              troller
                                        2021-05-16 19:54:30.866  - error: zwave2.0 (25523) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                                        2021-05-16 19:54:30.868  - error: zwave2.0 (25523) Restarting the adapter in a second...
                                        19:54:30.871 DRIVER   destroying driver instance...
                                        2021-05-16 19:54:31.871  - info: zwave2.0 (25523) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2021-05-16 19:54:32.400  - info: zwave2.0 (25523) Shutting down driver...
                                        und hier falls instance in GUI gestartet ist:
                                        2021-05-16 19:56:14.392  - info: zwave2.0 (25633) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                        19:56:14.496 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                                        19:56:14.501 DRIVER   version 7.4.0
                                        19:56:14.503 CONFIG   version 7.4.0
                                        19:56:14.504 DRIVER
                                        19:56:14.505 DRIVER   starting driver...
                                        19:56:14.544 DRIVER   opening serial port /dev/ttyS0
                                        19:56:14.566 DRIVER   serial port opened
                                        19:56:14.569 SERIAL » [NAK]        (0x15)
                                        2021-05-16 19:56:14.573  - debug: zwave2.0 (25633) object zwave2.0.info changed: {"_id":"zwave2.0.info","type":"channel","common":{"name":"Information"},"native":{},"from":"system.adapter.zwave2.0","ts":1621187774531,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                                        2021-05-16 19:56:14.574  - debug: zwave2.0 (25633) object zwave2.0.info.connection changed: {"_id":"zwave2.0.info.connection","type":"state","common":{"role":"indicator.connected","name":"Whether the Z-Wave driver is ready","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621187774538,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                                        2021-05-16 19:56:14.575  - debug: zwave2.0 (25633) object zwave2.0.info.inclusion changed: {"_id":"zwave2.0.info.inclusion","type":"state","common":{"role":"state","name":"Which state the inclusion of nodes is in","type":"number","read":true,"write":true,"def":0,"states":{"0":"Idle","1":"Non-secure","2":"Secure"}},"native":{},"from":"system.adapter.zwave2.0","ts":1621187774546,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                                        2021-05-16 19:56:14.581  - debug: zwave2.0 (25633) object zwave2.0.info.exclusion changed: {"_id":"zwave2.0.info.exclusion","type":"state","common":{"role":"state","name":"Whether the exclusion of nodes is active","type":"boolean","read":true,"write":true,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621187774554,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                                        2021-05-16 19:56:14.582  - debug: zwave2.0 (25633) object zwave2.0.info.healingNetwork changed: {"_id":"zwave2.0.info.healingNetwork","type":"state","common":{"role":"state","name":"Whether a network heal is currently in progress","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.zwave2.0","ts":1621187774562,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
                                        19:56:16.080 DRIVER   loading configuration...
                                        19:56:17.195 DRIVER   beginning interview...
                                        19:56:17.197 DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                                              1 registered
                                        19:56:17.198 DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                                              1 registered
                                        19:56:17.198 DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                                              1 registered
                                        19:56:17.200 CNTRLR   beginning interview...
                                        19:56:17.201 CNTRLR   querying version info...
                                        19:56:17.374 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:56:17.377 DRIVER » [REQ] [GetControllerVersion]
                                        19:56:18.385 CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                                              n 100 ms.
                                        19:56:18.488 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:56:18.490 DRIVER » [REQ] [GetControllerVersion]
                                        19:56:19.495 CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                                              n 1100 ms.
                                        19:56:20.598 SERIAL » 0x01030015e9                                                         (5 bytes)
                                        19:56:20.599 DRIVER » [REQ] [GetControllerVersion]
                                        19:56:21.622 DRIVER   Failed to initialize the driver: Timeout while waiting for an ACK from the con
                                                              troller
                                        2021-05-16 19:56:21.623  - error: zwave2.0 (25633) Failed to initialize the driver: Timeout while waiting for an ACK from the controller
                                        2021-05-16 19:56:21.624  - error: zwave2.0 (25633) Restarting the adapter in a second...
                                        19:56:21.626 DRIVER   destroying driver instance...
                                        2021-05-16 19:56:22.627  - info: zwave2.0 (25633) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2021-05-16 19:56:23.188  - info: zwave2.0 (25633) Shutting down driver...
                                        • E Esmax666
                                          (mit /dev/ttyS0)
                                          19:54:23.732 DRIVER
        1 registered
        1 registered
        1 registered
        n 100 ms.
        n 1100 ms.
        troller
                                          19:56:14.504 DRIVER
        1 registered
        1 registered
        1 registered
        n 100 ms.
        n 1100 ms.
        troller
                                          Esmax666
                                          #81
                                          und hier mit /dev/ttyAMA0
                                          Disable:
                                          2021-05-16 19:57:44.914  - error: zwave2.0 (25665) adapter disabled
                                          2021-05-16 19:57:44.924  - info: zwave2.0 (25665) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                          19:57:44.998 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                                          19:57:45.002 DRIVER   version 7.4.0
                                          19:57:45.003 CONFIG   version 7.4.0
                                          19:57:45.004 DRIVER
                                          19:57:45.004 DRIVER   starting driver...
                                          19:57:45.032 DRIVER   opening serial port /dev/ttyAMA0
                                          19:57:45.051 DRIVER   serial port opened
                                          19:57:45.052 SERIAL » [NAK]        (0x15)
                                          ^C2021-05-16 19:58:45.084  - info: zwave2.0 (25665) Shutting down driver...
                                          19:58:45.088 DRIVER   destroying driver instance...
                                          19:58:45.627 DRIVER   serial port errored: Port is not open
                                          2021-05-16 19:58:45.628  - error: zwave2.0 (25665) Port is not open
                                          This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          Error: Port is not open
                                              at unixWrite (/opt/iobroker/node_modules/@serialport/bindings/lib/unix-write.js:25:15)
                                              at /opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:72:7
                                          2021-05-16 19:58:45.640  - error: zwave2.0 (25665) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2021-05-16 19:58:45.641  - error: zwave2.0 (25665) unhandled promise rejection: Port is not open
                                          2021-05-16 19:58:45.642  - error: zwave2.0 (25665) Error: Port is not open
                                          2021-05-16 19:58:45.642  - error: zwave2.0 (25665) Port is not open
                                          2021-05-16 19:58:45.647  - error: zwave2.0 (25665) uncaught exception: Port is not open
                                          2021-05-16 19:58:45.648  - error: zwave2.0 (25665) Error: Port is not open
                                          2021-05-16 19:58:45.649  - error: zwave2.0 (25665) Port is not open
                                          enable
                                          2021-05-16 19:59:07.416  - info: zwave2.0 (25697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                          19:59:07.497 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                                          19:59:07.502 DRIVER   version 7.4.0
                                          19:59:07.503 CONFIG   version 7.4.0
                                          19:59:07.504 DRIVER
                                          19:59:07.505 DRIVER   starting driver...
                                          19:59:07.537 DRIVER   opening serial port /dev/ttyAMA0
                                          19:59:07.559 DRIVER   serial port errored: Error Resource temporarily unavailable Cannot lock port
                                          19:59:07.560 DRIVER   destroying driver instance...
                                          2021-05-16 19:59:07.562  - error: zwave2.0 (25697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                          ^C2021-05-16 20:00:14.265  - info: zwave2.0 (25697) Shutting down driver...
                                          2021-05-16 20:00:14.275  - info: zwave2.0 (25697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
