  4. Probleme mit Serialport bei zwave2
    6.7k
118 Beiträge 5 Kommentatoren 15.0k Aufrufe 2 Beobachtet
  • E Esmax666
    @alcalzone
    ok ist jetzt aktviert
    und auch neu gestartet
    aber immer Driver could not be started
    zwave2.0	2021-05-16 15:32:12.067	error	(17665) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/serial0
    zwave2.0	2021-05-16 15:32:11.921	info	(17665) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi	2021-05-16 15:32:09.511	info	instance system.adapter.zwave2.0 started with pid 17665
    host.raspberrypi	2021-05-16 15:32:07.043	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zwave2.0	2021-05-16 15:32:06.372	info	(5742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zwave2.0	2021-05-16 15:32:06.371	info	(5742) terminating
    zwave2.0	2021-05-16 15:32:06.369	info	(5742) Shutting down driver...
    zwave2.0	2021-05-16 15:32:06.367	info	(5742) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2021-05-16 15:32:06.367	info	stopInstance system.adapter.zwave2.0 send kill signal
    host.raspberrypi	2021-05-16 15:32:06.359	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
    host.raspberrypi	2021-05-16 15:30:27.733	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    ical.0	2021-05-16 15:30:27.198	info	(8661) Terminated (NO_ERROR): Without reason
    @esmax666
    Und wenn du das device direkt anrufst? Unter /dev/ttyAMA0
    Gibt es das Gerät?
    ls -la /dev/ttyAMA0
    sudo -u iobroker groups
    E 1 Antwort Letzte Antwort
      @esmax666
      Gibt es das Gerät?
      ls -la /dev/ttyAMA0
      Esmax666
      schrieb am zuletzt editiert von Esmax666
      @thomas-braun said in Probleme mit Serialport bei zwave2:
      /dev/ttyAMA0
      dann bekomme ich wie davor
      zwave2.0	2021-05-16 15:39:28.776	info	(15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
      host.raspberrypi	2021-05-16 15:39:26.309	info	instance system.adapter.zwave2.0 started with pid 15581
      host.raspberrypi	2021-05-16 15:39:23.743	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zwave2.0	2021-05-16 15:39:23.146	info	(17665) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2021-05-16 15:39:23.145	info	(17665) terminating
      zwave2.0	2021-05-16 15:39:23.143	info	(17665) Shutting down driver...
      host.raspberrypi	2021-05-16 15:39:23.141	info	stopInstance system.adapter.zwave2.0 send kill signal
      zwave2.0	2021-05-16 15:39:23.141	info	(17665) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-05-16 15:39:23.126	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
      und als "debug level" bekomme ich das :
      zwave2.0	2021-05-16 15:41:19.769	info	(24494) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
      zwave2.0	2021-05-16 15:41:19.518	debug	(24494) statesDB connected
      zwave2.0	2021-05-16 15:41:19.517	debug	(24494) States connected to redis: 127.0.0.1:9000
      zwave2.0	2021-05-16 15:41:19.510	debug	(24494) States create User PubSub Client
      zwave2.0	2021-05-16 15:41:19.508	debug	(24494) States create System PubSub Client
      zwave2.0	2021-05-16 15:41:19.501	debug	(24494) Redis States: Use Redis connection: 127.0.0.1:9000
      zwave2.0	2021-05-16 15:41:19.498	debug	(24494) objectDB connected
      zwave2.0	2021-05-16 15:41:19.469	debug	(24494) Objects connected to redis: 127.0.0.1:9001
      zwave2.0	2021-05-16 15:41:19.455	debug	(24494) Objects client initialize lua scripts
      zwave2.0	2021-05-16 15:41:19.453	debug	(24494) Objects create User PubSub Client
      zwave2.0	2021-05-16 15:41:19.451	debug	(24494) Objects create System PubSub Client
      zwave2.0	2021-05-16 15:41:19.448	debug	(24494) Objects client ready ... initialize now
      zwave2.0	2021-05-16 15:41:19.402	debug	(24494) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.raspberrypi	2021-05-16 15:41:17.450	info	instance system.adapter.zwave2.0 started with pid 24494
      host.raspberrypi	2021-05-16 15:41:17.338	info	"system.adapter.zwave2.0" enabled
      host.raspberrypi	2021-05-16 15:41:15.669	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.raspberrypi	2021-05-16 15:41:15.087	info	stopInstance system.adapter.zwave2.0 send kill signal
      zwave2.0	2021-05-16 15:41:15.048	info	(22847) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2021-05-16 15:41:15.046	info	(22847) terminating
      zwave2.0	2021-05-16 15:41:15.044	info	(22847) Shutting down driver...
      zwave2.0	2021-05-16 15:41:15.042	info	(22847) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-05-16 15:41:15.029	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
      host.raspberrypi	2021-05-16 15:41:15.027	info	"system.adapter.zwave2.0" disabled
      zwave2.0	2021-05-16 15:40:59.111	info	(22847) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
      zwave2.0	2021-05-16 15:40:58.808	debug	(22847) statesDB connected
      zwave2.0	2021-05-16 15:40:58.807	debug	(22847) States connected to redis: 127.0.0.1:9000
      zwave2.0	2021-05-16 15:40:58.795	debug	(22847) States create User PubSub Client
      zwave2.0	2021-05-16 15:40:58.794	debug	(22847) States create System PubSub Client
      zwave2.0	2021-05-16 15:40:58.783	debug	(22847) Redis States: Use Redis connection: 127.0.0.1:9000
      zwave2.0	2021-05-16 15:40:58.781	debug	(22847) objectDB connected
      zwave2.0	2021-05-16 15:40:58.751	debug	(22847) Objects connected to redis: 127.0.0.1:9001
      zwave2.0	2021-05-16 15:40:58.737	debug	(22847) Objects client initialize lua scripts
      zwave2.0	2021-05-16 15:40:58.736	debug	(22847) Objects create User PubSub Client
      zwave2.0	2021-05-16 15:40:58.735	debug	(22847) Objects create System PubSub Client
      zwave2.0	2021-05-16 15:40:58.732	debug	(22847) Objects client ready ... initialize now
      zwave2.0	2021-05-16 15:40:58.696	debug	(22847) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.raspberrypi	2021-05-16 15:40:56.599	info	instance system.adapter.zwave2.0 started with pid 22847
      host.raspberrypi	2021-05-16 15:40:56.462	info	"system.adapter.zwave2.0" enabled
      host.raspberrypi	2021-05-16 15:40:50.698	info	instance system.adapter.zwave2.0 terminated with code null ()
      host.raspberrypi	2021-05-16 15:40:50.697	warn	instance system.adapter.zwave2.0 terminated due to SIGTERM
      host.raspberrypi	2021-05-16 15:40:50.626	info	stopInstance system.adapter.zwave2.0 killing pid 22283
      host.raspberrypi	2021-05-16 15:40:49.624	info	stopInstance system.adapter.zwave2.0 send kill signal
      host.raspberrypi	2021-05-16 15:40:49.613	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
      host.raspberrypi	2021-05-16 15:40:49.613	info	"system.adapter.zwave2.0" disabled
      host.raspberrypi	2021-05-16 15:40:49.345	info	instance system.adapter.zwave2.0 started with pid 22283
      host.raspberrypi	2021-05-16 15:40:46.840	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zwave2.0	2021-05-16 15:40:46.228	info	(15581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2021-05-16 15:40:46.226	info	(15581) terminating
      zwave2.0	2021-05-16 15:40:46.225	info	(15581) Shutting down driver...
      zwave2.0	2021-05-16 15:40:46.223	info	(15581) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-05-16 15:40:46.223	info	stopInstance system.adapter.zwave2.0 send kill signal
      host.raspberrypi	2021-05-16 15:40:46.210	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
      • E Esmax666
        /dev/ttyAMA0
        @esmax666
        ls -la /dev/ttyAMA0
          @esmax666
          ls -la /dev/ttyAMA0
          Esmax666
          auch nicht
          zwave2.0	2021-05-16 15:44:27.972	info	(7201) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          host.raspberrypi	2021-05-16 15:44:25.611	info	instance system.adapter.zwave2.0 started with pid 7201
          host.raspberrypi	2021-05-16 15:44:25.529	info	"system.adapter.zwave2.0" enabled
          host.raspberrypi	2021-05-16 15:44:24.965	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          zwave2.0	2021-05-16 15:44:24.304	info	(30224) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zwave2.0	2021-05-16 15:44:24.302	info	(30224) terminating
          zwave2.0	2021-05-16 15:44:24.301	info	(30224) Shutting down driver...
          host.raspberrypi	2021-05-16 15:44:24.299	info	stopInstance system.adapter.zwave2.0 send kill signal
          zwave2.0	2021-05-16 15:44:24.298	info	(30224) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi	2021-05-16 15:44:24.285	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
          host.raspberrypi	2021-05-16 15:44:24.278	info	"system.adapter.zwave2.0" disabled
          zwave2.0	2021-05-16 15:44:11.075	debug	(30224) system.adapter.admin.0: logging true
          zwave2.0	2021-05-16 15:44:06.538	debug	(30224) system.adapter.admin.0: logging false
          • E Esmax666
            auch nicht
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @esmax666 Starte den Adapter mal auf der Konsole, da sieht man ggf. mehr:
            cd /opt/iobroker/node_modules/iobroker.zwave2
            node build/main.js --force --logs
            E 2 Antworten Letzte Antwort
            • AlCalzoneA AlCalzone
              Esmax666
              @alcalzone said in Probleme mit Serialport bei zwave2:
              pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs        2021-05-16 16:43:17.078  - info: zwave2.0 (17697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
              Logging to file:
                      /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
              2021-05-16 16:43:17.235  - error: zwave2.0 (17697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
              ^C2021-05-16 16:43:47.907  - info: zwave2.0 (17697) Shutting down driver...
              2021-05-16 16:43:47.916  - info: zwave2.0 (17697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              • E Esmax666
                Logging to file:
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @esmax666 sagte in Probleme mit Serialport bei zwave2:
                Cannot lock port
                Da greift schon irgendwas anderes auf den Port zu.
                  Cannot lock port
                  @Esmax666
                  sudo lsof /dev/ttyAMA0
                    @Esmax666
                    Esmax666
                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0
                    COMMAND     PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                    hciattach   596     root    3u   CHR 204,64      0t0  135 /dev/ttyAMA0
                    node      25167 iobroker   27uW  CHR 204,64      0t0  135 /dev/ttyAMA0
                    dann
                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ cd /opt/iobroker/node_modules/iobroker.zwave2
                    2021-05-16 17:01:01.719  - info: zwave2.0 (5111) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                    Logging to file:
                    2021-05-16 17:01:01.877  - error: zwave2.0 (5111) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                    ^C2021-05-16 17:01:47.959  - info: zwave2.0 (5111) Shutting down driver...
                    2021-05-16 17:01:47.968  - info: zwave2.0 (5111) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    @AlCalzone
                    wie soll ich port freischalten ? die installation ist neu
                    • E Esmax666
                      dann
                      Logging to file:
                      @AlCalzone
                      Da greift bluetooth schon auf das Gerät zu. Merkwürden...
                      Ich bin jetzt nicht ganz sicher ob /dev/tttyAMA0 nicht doch das falsche Device ist. Oder da die Zuordnung falsch ist. Zieh den stick mal raus, starte neu ohne den Stick und dann schau nochmal nach
                      dmesg -T
                      kurz nachdem du den stick eingesteckt hast.
                        dmesg -T
                        Esmax666
                        @thomas-braun was soll ich dann machen ?
                        • E Esmax666
                          @esmax666 Und deaktiviere den zwave2-Adapter vorerst mal für die ganze Prozedur.
                            Esmax666
                            ohne stick und zwave2 pausiert
                            pi@raspberrypi:~ $ dmesg -T
                            [So Mai 16 17:10:10 2021] Booting Linux on physical CPU 0x0
                            [So Mai 16 17:10:10 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
                            [So Mai 16 17:10:10 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                            [So Mai 16 17:10:10 2021] CPU: div instructions available: patching division code
                            [So Mai 16 17:10:10 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                            [So Mai 16 17:10:10 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
                            [So Mai 16 17:10:10 2021] Memory policy: Data cache writealloc
                            [So Mai 16 17:10:10 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
                            [So Mai 16 17:10:10 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                            [So Mai 16 17:10:10 2021] Zone ranges:
                            [So Mai 16 17:10:10 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                            [So Mai 16 17:10:10 2021]   Normal   empty
                            [So Mai 16 17:10:10 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
                            [So Mai 16 17:10:10 2021] Movable zone start for each node
                            [So Mai 16 17:10:10 2021] Early memory node ranges
                            [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                            [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                            [So Mai 16 17:10:10 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
                            [So Mai 16 17:10:10 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                            [So Mai 16 17:10:10 2021] On node 0 totalpages: 2061056
                            [So Mai 16 17:10:10 2021]   DMA zone: 2304 pages used for memmap
                            [So Mai 16 17:10:10 2021]   DMA zone: 0 pages reserved
                            [So Mai 16 17:10:10 2021]   DMA zone: 196608 pages, LIFO batch:63
                            [So Mai 16 17:10:10 2021]   HighMem zone: 1864448 pages, LIFO batch:63
                            [So Mai 16 17:10:10 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                            [So Mai 16 17:10:10 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                            [So Mai 16 17:10:10 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                            [So Mai 16 17:10:10 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
                            [So Mai 16 17:10:10 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [So Mai 16 17:10:10 2021] Kernel parameter elevator= does not have any effect anymore.
                                                      Please use sysfs to set IO scheduler for individual devices.
                            [So Mai 16 17:10:10 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                            [So Mai 16 17:10:10 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                            [So Mai 16 17:10:10 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
                            [So Mai 16 17:10:10 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
                            [So Mai 16 17:10:10 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem)
                            [So Mai 16 17:10:10 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                            [So Mai 16 17:10:10 2021] ftrace: allocating 33942 entries in 67 pages
                            [So Mai 16 17:10:10 2021] ftrace: allocated 67 pages with 3 groups
                            [So Mai 16 17:10:10 2021] rcu: Hierarchical RCU implementation.
                            [So Mai 16 17:10:10 2021]       Rude variant of Tasks RCU enabled.
                            [So Mai 16 17:10:10 2021]       Tracing variant of Tasks RCU enabled.
                            [So Mai 16 17:10:10 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                            [So Mai 16 17:10:10 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            [So Mai 16 17:10:10 2021] GIC: Using split EOI/Deactivate mode
                            [So Mai 16 17:10:10 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                            [So Mai 16 17:10:10 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                            [So Mai 16 17:10:10 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                            [So Mai 16 17:10:10 2021] bcm2835: system timer (irq = 25)
                            [So Mai 16 17:10:10 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                            [So Mai 16 17:10:10 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                            [So Mai 16 17:10:10 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                            [So Mai 16 17:10:10 2021] Switching to timer-based delay loop, resolution 18ns
                            [So Mai 16 17:10:10 2021] Console: colour dummy device 80x30
                            [So Mai 16 17:10:10 2021] printk: console [tty1] enabled
                            [So Mai 16 17:10:10 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                            [So Mai 16 17:10:10 2021] pid_max: default: 32768 minimum: 301
                            [So Mai 16 17:10:10 2021] LSM: Security Framework initializing
                            [So Mai 16 17:10:10 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            [So Mai 16 17:10:10 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            [So Mai 16 17:10:10 2021] Disabling memory control group subsystem
                            [So Mai 16 17:10:10 2021] CPU: Testing write buffer coherency: ok
                            [So Mai 16 17:10:10 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            [So Mai 16 17:10:10 2021] Setting up static identity map for 0x200000 - 0x20003c
                            [So Mai 16 17:10:10 2021] rcu: Hierarchical SRCU implementation.
                            [So Mai 16 17:10:10 2021] smp: Bringing up secondary CPUs ...
                            [So Mai 16 17:10:10 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            [So Mai 16 17:10:10 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                            [So Mai 16 17:10:10 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                            [So Mai 16 17:10:10 2021] smp: Brought up 1 node, 4 CPUs
                            [So Mai 16 17:10:10 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                            [So Mai 16 17:10:10 2021] CPU: All CPU(s) started in HYP mode.
                            [So Mai 16 17:10:10 2021] CPU: Virtualization extensions available.
                            [So Mai 16 17:10:10 2021] devtmpfs: initialized
                            [So Mai 16 17:10:10 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                            [So Mai 16 17:10:10 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            [So Mai 16 17:10:10 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                            [So Mai 16 17:10:10 2021] pinctrl core: initialized pinctrl subsystem
                            [So Mai 16 17:10:10 2021] NET: Registered protocol family 16
                            [So Mai 16 17:10:10 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                            [So Mai 16 17:10:10 2021] audit: initializing netlink subsys (disabled)
                            [So Mai 16 17:10:10 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                            [So Mai 16 17:10:10 2021] thermal_sys: Registered thermal governor 'step_wise'
                            [So Mai 16 17:10:10 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                            [So Mai 16 17:10:10 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
                            [So Mai 16 17:10:10 2021] Serial: AMBA PL011 UART driver
                            [So Mai 16 17:10:10 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                            [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
                            [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
                            [So Mai 16 17:10:10 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                            [So Mai 16 17:10:10 2021] vgaarb: loaded
                            [So Mai 16 17:10:10 2021] SCSI subsystem initialized
                            [So Mai 16 17:10:10 2021] usbcore: registered new interface driver usbfs
                            [So Mai 16 17:10:10 2021] usbcore: registered new interface driver hub
                            [So Mai 16 17:10:10 2021] usbcore: registered new device driver usb
                            [So Mai 16 17:10:10 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
                            [So Mai 16 17:10:10 2021] clocksource: Switched to clocksource arch_sys_counter
                            [So Mai 16 17:10:11 2021] VFS: Disk quotas dquot_6.6.0
                            [So Mai 16 17:10:11 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                            [So Mai 16 17:10:11 2021] FS-Cache: Loaded
                            [So Mai 16 17:10:11 2021] CacheFiles: Loaded
                            [So Mai 16 17:10:11 2021] NET: Registered protocol family 2
                            [So Mai 16 17:10:11 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                            [So Mai 16 17:10:11 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                            [So Mai 16 17:10:11 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                            [So Mai 16 17:10:11 2021] TCP: Hash tables configured (established 8192 bind 8192)
                            [So Mai 16 17:10:11 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                            [So Mai 16 17:10:11 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                            [So Mai 16 17:10:11 2021] NET: Registered protocol family 1
                            [So Mai 16 17:10:11 2021] RPC: Registered named UNIX socket transport module.
                            [So Mai 16 17:10:11 2021] RPC: Registered udp transport module.
                            [So Mai 16 17:10:11 2021] RPC: Registered tcp transport module.
                            [So Mai 16 17:10:11 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
                            [So Mai 16 17:10:11 2021] PCI: CLS 0 bytes, default 64
                            [So Mai 16 17:10:11 2021] Initialise system trusted keyrings
                            [So Mai 16 17:10:11 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
                            [So Mai 16 17:10:11 2021] zbud: loaded
                            [So Mai 16 17:10:11 2021] FS-Cache: Netfs 'nfs' registered for caching
                            [So Mai 16 17:10:11 2021] NFS: Registering the id_resolver key type
                            [So Mai 16 17:10:11 2021] Key type id_resolver registered
                            [So Mai 16 17:10:11 2021] Key type id_legacy registered
                            [So Mai 16 17:10:11 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                            [So Mai 16 17:10:11 2021] Key type asymmetric registered
                            [So Mai 16 17:10:11 2021] Asymmetric key parser 'x509' registered
                            [So Mai 16 17:10:11 2021] bounce: pool size: 64 pages
                            [So Mai 16 17:10:11 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                            [So Mai 16 17:10:11 2021] io scheduler mq-deadline registered
                            [So Mai 16 17:10:11 2021] io scheduler kyber registered
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                            [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                            [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
                            [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                            [So Mai 16 17:10:11 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                            [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
                            [So Mai 16 17:10:11 2021] PCI: bus0: Fast back to back transfers disabled
                            [So Mai 16 17:10:11 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                            [So Mai 16 17:10:11 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                            [So Mai 16 17:10:11 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
                            [So Mai 16 17:10:11 2021] PCI: bus1: Fast back to back transfers disabled
                            [So Mai 16 17:10:11 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                            [So Mai 16 17:10:11 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                            [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
                            [So Mai 16 17:10:11 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                            [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                            [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                            [So Mai 16 17:10:11 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                            [So Mai 16 17:10:11 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                            [So Mai 16 17:10:11 2021] iproc-rng200 fe104000.rng: hwrng registered
                            [So Mai 16 17:10:11 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                            [So Mai 16 17:10:11 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                            [So Mai 16 17:10:11 2021] brd: module loaded
                            [So Mai 16 17:10:11 2021] loop: module loaded
                            [So Mai 16 17:10:11 2021] Loading iSCSI transport class v2.0-870.
                            [So Mai 16 17:10:11 2021] libphy: Fixed MDIO Bus: probed
                            [So Mai 16 17:10:11 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                            [So Mai 16 17:10:11 2021] libphy: bcmgenet MII bus: probed
                            [So Mai 16 17:10:11 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver r8152
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver lan78xx
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver smsc95xx
                            [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                            [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                            [So Mai 16 17:10:11 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                            [So Mai 16 17:10:11 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            [So Mai 16 17:10:11 2021] usb usb1: Product: xHCI Host Controller
                            [So Mai 16 17:10:11 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                            [So Mai 16 17:10:11 2021] usb usb1: SerialNumber: 0000:01:00.0
                            [So Mai 16 17:10:11 2021] hub 1-0:1.0: USB hub found
                            [So Mai 16 17:10:11 2021] hub 1-0:1.0: 1 port detected
                            [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                            [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                            [So Mai 16 17:10:11 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                            [So Mai 16 17:10:11 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            [So Mai 16 17:10:11 2021] usb usb2: Product: xHCI Host Controller
                            [So Mai 16 17:10:11 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                            [So Mai 16 17:10:11 2021] usb usb2: SerialNumber: 0000:01:00.0
                            [So Mai 16 17:10:11 2021] hub 2-0:1.0: USB hub found
                            [So Mai 16 17:10:11 2021] hub 2-0:1.0: 4 ports detected
                            [So Mai 16 17:10:11 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                            [So Mai 16 17:10:11 2021] dwc_otg: FIQ enabled
                            [So Mai 16 17:10:11 2021] dwc_otg: NAK holdoff enabled
                            [So Mai 16 17:10:11 2021] dwc_otg: FIQ split-transaction FSM enabled
                            [So Mai 16 17:10:11 2021] Module dwc_common_port init
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver uas
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usb-storage
                            [So Mai 16 17:10:11 2021] mousedev: PS/2 mouse device common for all mice
                            [So Mai 16 17:10:11 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                            [So Mai 16 17:10:11 2021] sdhci: Secure Digital Host Controller Interface driver
                            [So Mai 16 17:10:11 2021] sdhci: Copyright(c) Pierre Ossman
                            [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                            [So Mai 16 17:10:11 2021] sdhci-pltfm: SDHCI platform and OF driver helper
                            [So Mai 16 17:10:11 2021] ledtrig-cpu: registered to indicate activity on CPUs
                            [So Mai 16 17:10:11 2021] hid: raw HID events driver (C) Jiri Kosina
                            [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usbhid
                            [So Mai 16 17:10:11 2021] usbhid: USB HID core driver
                            [So Mai 16 17:10:11 2021] Initializing XFRM netlink socket
                            [So Mai 16 17:10:11 2021] NET: Registered protocol family 17
                            [So Mai 16 17:10:11 2021] Key type dns_resolver registered
                            [So Mai 16 17:10:11 2021] Registering SWP/SWPB emulation handler
                            [So Mai 16 17:10:11 2021] registered taskstats version 1
                            [So Mai 16 17:10:11 2021] Loading compiled-in X.509 certificates
                            [So Mai 16 17:10:11 2021] Key type ._fscrypt registered
                            [So Mai 16 17:10:11 2021] Key type .fscrypt registered
                            [So Mai 16 17:10:11 2021] Key type fscrypt-provisioning registered
                            [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
                            [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
                            [So Mai 16 17:10:11 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                            [So Mai 16 17:10:11 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
                            [So Mai 16 17:10:11 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                            [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                            [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                            [So Mai 16 17:10:11 2021] of_cfs_init
                            [So Mai 16 17:10:11 2021] of_cfs_init: OK
                            [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                            [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                            [So Mai 16 17:10:11 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                            [So Mai 16 17:10:11 2021] Waiting for root device PARTUUID=c7534f19-02...
                            [So Mai 16 17:10:11 2021] random: fast init done
                            [So Mai 16 17:10:11 2021] mmc1: new high speed SDIO card at address 0001
                            [So Mai 16 17:10:11 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                            [So Mai 16 17:10:12 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                            [So Mai 16 17:10:12 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                            [So Mai 16 17:10:12 2021] usb 1-1: Product: USB2.0 Hub
                            [So Mai 16 17:10:12 2021] hub 1-1:1.0: USB hub found
                            [So Mai 16 17:10:12 2021] hub 1-1:1.0: 4 ports detected
                            [So Mai 16 17:10:12 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                            [So Mai 16 17:10:12 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
                            [So Mai 16 17:10:12 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            [So Mai 16 17:10:12 2021] usb 2-2: Product: Ultra
                            [So Mai 16 17:10:12 2021] usb 2-2: Manufacturer: SanDisk
                            [So Mai 16 17:10:12 2021] usb 2-2: SerialNumber: 4C530000211114109264
                            [So Mai 16 17:10:12 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
                            [So Mai 16 17:10:12 2021] scsi host0: usb-storage 2-2:1.0
                            [So Mai 16 17:10:13 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
                            [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB)
                            [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write Protect is off
                            [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                            [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
                            [So Mai 16 17:10:13 2021]  sda: sda1 sda2
                            [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
                            [So Mai 16 17:10:13 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            [So Mai 16 17:10:13 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [So Mai 16 17:10:13 2021] devtmpfs: mounted
                            [So Mai 16 17:10:13 2021] Freeing unused kernel memory: 2048K
                            [So Mai 16 17:10:13 2021] Run /sbin/init as init process
                            [So Mai 16 17:10:13 2021]   with arguments:
                            [So Mai 16 17:10:13 2021]     /sbin/init
                            [So Mai 16 17:10:13 2021]     splash
                            [So Mai 16 17:10:13 2021]   with environment:
                            [So Mai 16 17:10:13 2021]     HOME=/
                            [So Mai 16 17:10:13 2021]     TERM=linux
                            [So Mai 16 17:10:13 2021] systemd[1]: System time before build time, advancing clock.
                            [So Mai 16 17:10:13 2021] NET: Registered protocol family 10
                            [So Mai 16 17:10:13 2021] Segment Routing with IPv6
                            [So Mai 16 17:10:13 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                            [So Mai 16 17:10:13 2021] systemd[1]: Detected architecture arm.
                            [So Mai 16 17:10:13 2021] systemd[1]: Set hostname to <raspberrypi>.
                            [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
                            [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
                            [So Mai 16 17:10:14 2021] random: systemd: uninitialized urandom read (16 bytes read)
                            [So Mai 16 17:10:14 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                            [So Mai 16 17:10:14 2021] systemd[1]: Listening on initctl Compatibility Named Pipe.
                            [So Mai 16 17:10:14 2021] systemd[1]: Created slice system-getty.slice.
                            [So Mai 16 17:10:14 2021] systemd[1]: Listening on udev Kernel Socket.
                            [So Mai 16 17:10:14 2021] systemd[1]: Listening on Journal Audit Socket.
                            [So Mai 16 17:10:15 2021] i2c /dev entries driver
                            [So Mai 16 17:10:15 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
                            [So Mai 16 17:10:15 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
                            [So Mai 16 17:10:16 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                            [So Mai 16 17:10:16 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                            [So Mai 16 17:10:16 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                            [So Mai 16 17:10:16 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                            [So Mai 16 17:10:16 2021] mc: Linux media interface: v0.10
                            [So Mai 16 17:10:16 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
                            [So Mai 16 17:10:16 2021] videodev: Linux video capture interface: v2.00
                            [So Mai 16 17:10:16 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                            [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: start
                            [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: installed successfully
                            [So Mai 16 17:10:16 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                            [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                            [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                            [So Mai 16 17:10:16 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            [So Mai 16 17:10:16 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            [So Mai 16 17:10:16 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                            [So Mai 16 17:10:16 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                            [So Mai 16 17:10:17 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                            [So Mai 16 17:10:17 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                            [So Mai 16 17:10:17 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
                            [So Mai 16 17:10:17 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            [So Mai 16 17:10:17 2021] usbcore: registered new interface driver brcmfmac
                            [So Mai 16 17:10:17 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                            [So Mai 16 17:10:17 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
                            [So Mai 16 17:10:17 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                            [So Mai 16 17:10:18 2021] random: crng init done
                            [So Mai 16 17:10:18 2021] random: 7 urandom warning(s) missed due to ratelimiting
                            [So Mai 16 17:10:19 2021] uart-pl011 fe201000.serial: no DMA platform data
                            [So Mai 16 17:10:19 2021] 8021q: 802.1Q VLAN Support v1.8
                            [So Mai 16 17:10:20 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                            [So Mai 16 17:10:20 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                            [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                            [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet eth0: Link is Down
                            [So Mai 16 17:10:22 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:23 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:24 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:24 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                            [So Mai 16 17:10:24 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                            [So Mai 16 17:10:25 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                            [So Mai 16 17:10:26 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:26 2021] Bluetooth: Core ver 2.22
                            [So Mai 16 17:10:26 2021] NET: Registered protocol family 31
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI device and connection manager initialized
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI socket layer initialized
                            [So Mai 16 17:10:26 2021] Bluetooth: L2CAP socket layer initialized
                            [So Mai 16 17:10:26 2021] Bluetooth: SCO socket layer initialized
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI UART driver ver 2.3
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol H4 registered
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Broadcom registered
                            [So Mai 16 17:10:26 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            [So Mai 16 17:10:26 2021] Bluetooth: BNEP filters: protocol multicast
                            [So Mai 16 17:10:26 2021] Bluetooth: BNEP socket layer initialized
                            [So Mai 16 17:10:26 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                            [So Mai 16 17:10:27 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:28 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:29 2021] broken atomic modeset userspace detected, disabling atomic
                            [So Mai 16 17:10:30 2021] Bluetooth: hci0: command 0x1003 tx timeout
                            [So Mai 16 17:10:32 2021] Bluetooth: hci0: command 0x1001 tx timeout
                            [So Mai 16 17:10:34 2021] Bluetooth: hci0: command 0x1009 tx timeout
                            pi@raspberrypi:~ $
                            • E Esmax666
                              pi@raspberrypi:~ $
                              @esmax666
                              Nutzt du bluetooth?
                              Und schalt den Desktop aus!
                              Auch den Remote Desktop, der da läuft.
                              Auf dem Server wird sich per ssh angemeldet.
                              Steck den Stick mal wieder rein und dann schaust du dir die neuen Zeilen in
                              dmesg -T
                              an.
                                @esmax666
                                Nutzt du bluetooth?
                                dmesg -T
                                an.
                                Esmax666
                                @thomas-braun desktop brauche ich
                                bluetooth momentan nicht, habe ich jetzt raus gemacht, aber geht immer nocht nicht
                                port ist aber immer beleg
                                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js -                                                          -force --logs
                                2021-05-16 17:40:02.553  - info: zwave2.0 (9243) starting. Version 1.9.3 in /opt                                                          /iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                Logging to file:
                                2021-05-16 17:40:02.711  - error: zwave2.0 (9243) The Z-Wave driver could not be                                                           started: Error Resource temporarily unavailable Cannot lock port
                                ^C2021-05-16 17:40:24.084  - info: zwave2.0 (9243) Shutting down driver...
                                2021-05-16 17:40:24.092  - info: zwave2.0 (9243) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                lsof: WARNING: can't stat() fuse.xrdp-chansrv file system /home/pi/thinclient_drives
                                      Output information may be incomplete.
                                lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
                                hciattach  586     root    3u   CHR 204,64      0t0  135 /dev/ttyAMA0
                                node      5352 iobroker   27uW  CHR 204,64      0t0  135 /dev/ttyA
                                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ dmesg -T
                                [So Mai 16 17:37:56 2021] Booting Linux on physical CPU 0x0
                                [So Mai 16 17:37:56 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
                                [So Mai 16 17:37:56 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                                [So Mai 16 17:37:56 2021] CPU: div instructions available: patching division code
                                [So Mai 16 17:37:56 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                                [So Mai 16 17:37:56 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
                                [So Mai 16 17:37:56 2021] Memory policy: Data cache writealloc
                                [So Mai 16 17:37:56 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
                                [So Mai 16 17:37:56 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                                [So Mai 16 17:37:56 2021] Zone ranges:
                                [So Mai 16 17:37:56 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                                [So Mai 16 17:37:56 2021]   Normal   empty
                                [So Mai 16 17:37:56 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
                                [So Mai 16 17:37:56 2021] Movable zone start for each node
                                [So Mai 16 17:37:56 2021] Early memory node ranges
                                [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                                [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                                [So Mai 16 17:37:56 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
                                [So Mai 16 17:37:56 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                                [So Mai 16 17:37:56 2021] On node 0 totalpages: 2061056
                                [So Mai 16 17:37:56 2021]   DMA zone: 2304 pages used for memmap
                                [So Mai 16 17:37:56 2021]   DMA zone: 0 pages reserved
                                [So Mai 16 17:37:56 2021]   DMA zone: 196608 pages, LIFO batch:63
                                [So Mai 16 17:37:56 2021]   HighMem zone: 1864448 pages, LIFO batch:63
                                [So Mai 16 17:37:56 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                                [So Mai 16 17:37:56 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                                [So Mai 16 17:37:56 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                [So Mai 16 17:37:56 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
                                [So Mai 16 17:37:56 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [So Mai 16 17:37:56 2021] Kernel parameter elevator= does not have any effect anymore.
                                [So Mai 16 17:37:56 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                                [So Mai 16 17:37:56 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                [So Mai 16 17:37:56 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
                                [So Mai 16 17:37:56 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
                                [So Mai 16 17:37:56 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem)
                                [So Mai 16 17:37:56 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                [So Mai 16 17:37:56 2021] ftrace: allocating 33942 entries in 67 pages
                                [So Mai 16 17:37:56 2021] ftrace: allocated 67 pages with 3 groups
                                [So Mai 16 17:37:56 2021] rcu: Hierarchical RCU implementation.
                                [So Mai 16 17:37:56 2021]       Rude variant of Tasks RCU enabled.
                                [So Mai 16 17:37:56 2021]       Tracing variant of Tasks RCU enabled.
                                [So Mai 16 17:37:56 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                                [So Mai 16 17:37:56 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                [So Mai 16 17:37:56 2021] GIC: Using split EOI/Deactivate mode
                                [So Mai 16 17:37:56 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                                [So Mai 16 17:37:56 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                                [So Mai 16 17:37:56 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                                [So Mai 16 17:37:56 2021] bcm2835: system timer (irq = 25)
                                [So Mai 16 17:37:56 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                [So Mai 16 17:37:56 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                [So Mai 16 17:37:56 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                                [So Mai 16 17:37:56 2021] Switching to timer-based delay loop, resolution 18ns
                                [So Mai 16 17:37:56 2021] Console: colour dummy device 80x30
                                [So Mai 16 17:37:56 2021] printk: console [tty1] enabled
                                [So Mai 16 17:37:56 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                                [So Mai 16 17:37:56 2021] pid_max: default: 32768 minimum: 301
                                [So Mai 16 17:37:56 2021] LSM: Security Framework initializing
                                [So Mai 16 17:37:56 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                [So Mai 16 17:37:56 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                [So Mai 16 17:37:56 2021] Disabling memory control group subsystem
                                [So Mai 16 17:37:56 2021] CPU: Testing write buffer coherency: ok
                                [So Mai 16 17:37:56 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                [So Mai 16 17:37:56 2021] Setting up static identity map for 0x200000 - 0x20003c
                                [So Mai 16 17:37:56 2021] rcu: Hierarchical SRCU implementation.
                                [So Mai 16 17:37:56 2021] smp: Bringing up secondary CPUs ...
                                [So Mai 16 17:37:56 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                [So Mai 16 17:37:56 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                [So Mai 16 17:37:56 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                [So Mai 16 17:37:56 2021] smp: Brought up 1 node, 4 CPUs
                                [So Mai 16 17:37:56 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                                [So Mai 16 17:37:56 2021] CPU: All CPU(s) started in HYP mode.
                                [So Mai 16 17:37:56 2021] CPU: Virtualization extensions available.
                                [So Mai 16 17:37:56 2021] devtmpfs: initialized
                                [So Mai 16 17:37:56 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                                [So Mai 16 17:37:56 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                [So Mai 16 17:37:56 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                [So Mai 16 17:37:56 2021] pinctrl core: initialized pinctrl subsystem
                                [So Mai 16 17:37:56 2021] NET: Registered protocol family 16
                                [So Mai 16 17:37:56 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                                [So Mai 16 17:37:56 2021] audit: initializing netlink subsys (disabled)
                                [So Mai 16 17:37:56 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                                [So Mai 16 17:37:56 2021] thermal_sys: Registered thermal governor 'step_wise'
                                [So Mai 16 17:37:56 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                                [So Mai 16 17:37:56 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                [So Mai 16 17:37:56 2021] Serial: AMBA PL011 UART driver
                                [So Mai 16 17:37:56 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
                                [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
                                [So Mai 16 17:37:56 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                                [So Mai 16 17:37:56 2021] vgaarb: loaded
                                [So Mai 16 17:37:56 2021] SCSI subsystem initialized
                                [So Mai 16 17:37:56 2021] usbcore: registered new interface driver usbfs
                                [So Mai 16 17:37:56 2021] usbcore: registered new interface driver hub
                                [So Mai 16 17:37:56 2021] usbcore: registered new device driver usb
                                [So Mai 16 17:37:56 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
                                [So Mai 16 17:37:56 2021] clocksource: Switched to clocksource arch_sys_counter
                                [So Mai 16 17:37:57 2021] VFS: Disk quotas dquot_6.6.0
                                [So Mai 16 17:37:57 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                                [So Mai 16 17:37:57 2021] FS-Cache: Loaded
                                [So Mai 16 17:37:57 2021] CacheFiles: Loaded
                                [So Mai 16 17:37:57 2021] NET: Registered protocol family 2
                                [So Mai 16 17:37:57 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                [So Mai 16 17:37:57 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                                [So Mai 16 17:37:57 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                [So Mai 16 17:37:57 2021] TCP: Hash tables configured (established 8192 bind 8192)
                                [So Mai 16 17:37:57 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                                [So Mai 16 17:37:57 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                                [So Mai 16 17:37:57 2021] NET: Registered protocol family 1
                                [So Mai 16 17:37:57 2021] RPC: Registered named UNIX socket transport module.
                                [So Mai 16 17:37:57 2021] RPC: Registered udp transport module.
                                [So Mai 16 17:37:57 2021] RPC: Registered tcp transport module.
                                [So Mai 16 17:37:57 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                [So Mai 16 17:37:57 2021] PCI: CLS 0 bytes, default 64
                                [So Mai 16 17:37:57 2021] Initialise system trusted keyrings
                                [So Mai 16 17:37:57 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
                                [So Mai 16 17:37:57 2021] zbud: loaded
                                [So Mai 16 17:37:57 2021] FS-Cache: Netfs 'nfs' registered for caching
                                [So Mai 16 17:37:57 2021] NFS: Registering the id_resolver key type
                                [So Mai 16 17:37:57 2021] Key type id_resolver registered
                                [So Mai 16 17:37:57 2021] Key type id_legacy registered
                                [So Mai 16 17:37:57 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                [So Mai 16 17:37:57 2021] Key type asymmetric registered
                                [So Mai 16 17:37:57 2021] Asymmetric key parser 'x509' registered
                                [So Mai 16 17:37:57 2021] bounce: pool size: 64 pages
                                [So Mai 16 17:37:57 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                                [So Mai 16 17:37:57 2021] io scheduler mq-deadline registered
                                [So Mai 16 17:37:57 2021] io scheduler kyber registered
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                                [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
                                [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                                [So Mai 16 17:37:57 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
                                [So Mai 16 17:37:57 2021] PCI: bus0: Fast back to back transfers disabled
                                [So Mai 16 17:37:57 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                [So Mai 16 17:37:57 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                [So Mai 16 17:37:57 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
                                [So Mai 16 17:37:57 2021] PCI: bus1: Fast back to back transfers disabled
                                [So Mai 16 17:37:57 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                [So Mai 16 17:37:57 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
                                [So Mai 16 17:37:57 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                                [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                                [So Mai 16 17:37:57 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                                [So Mai 16 17:37:57 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
                                [So Mai 16 17:37:57 2021] iproc-rng200 fe104000.rng: hwrng registered
                                [So Mai 16 17:37:57 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                                [So Mai 16 17:37:57 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                [So Mai 16 17:37:57 2021] brd: module loaded
                                [So Mai 16 17:37:57 2021] loop: module loaded
                                [So Mai 16 17:37:57 2021] Loading iSCSI transport class v2.0-870.
                                [So Mai 16 17:37:57 2021] libphy: Fixed MDIO Bus: probed
                                [So Mai 16 17:37:57 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                [So Mai 16 17:37:57 2021] libphy: bcmgenet MII bus: probed
                                [So Mai 16 17:37:57 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver r8152
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver lan78xx
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver smsc95xx
                                [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                                [So Mai 16 17:37:57 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                                [So Mai 16 17:37:57 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [So Mai 16 17:37:57 2021] usb usb1: Product: xHCI Host Controller
                                [So Mai 16 17:37:57 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                [So Mai 16 17:37:57 2021] usb usb1: SerialNumber: 0000:01:00.0
                                [So Mai 16 17:37:57 2021] hub 1-0:1.0: USB hub found
                                [So Mai 16 17:37:57 2021] hub 1-0:1.0: 1 port detected
                                [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                [So Mai 16 17:37:57 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                                [So Mai 16 17:37:57 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [So Mai 16 17:37:57 2021] usb usb2: Product: xHCI Host Controller
                                [So Mai 16 17:37:57 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                [So Mai 16 17:37:57 2021] usb usb2: SerialNumber: 0000:01:00.0
                                [So Mai 16 17:37:57 2021] hub 2-0:1.0: USB hub found
                                [So Mai 16 17:37:57 2021] hub 2-0:1.0: 4 ports detected
                                [So Mai 16 17:37:57 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                [So Mai 16 17:37:57 2021] dwc_otg: FIQ enabled
                                [So Mai 16 17:37:57 2021] dwc_otg: NAK holdoff enabled
                                [So Mai 16 17:37:57 2021] dwc_otg: FIQ split-transaction FSM enabled
                                [So Mai 16 17:37:57 2021] Module dwc_common_port init
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver uas
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usb-storage
                                [So Mai 16 17:37:57 2021] mousedev: PS/2 mouse device common for all mice
                                [So Mai 16 17:37:57 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                [So Mai 16 17:37:57 2021] sdhci: Secure Digital Host Controller Interface driver
                                [So Mai 16 17:37:57 2021] sdhci: Copyright(c) Pierre Ossman
                                [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                                [So Mai 16 17:37:57 2021] sdhci-pltfm: SDHCI platform and OF driver helper
                                [So Mai 16 17:37:57 2021] ledtrig-cpu: registered to indicate activity on CPUs
                                [So Mai 16 17:37:57 2021] hid: raw HID events driver (C) Jiri Kosina
                                [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usbhid
                                [So Mai 16 17:37:57 2021] usbhid: USB HID core driver
                                [So Mai 16 17:37:57 2021] Initializing XFRM netlink socket
                                [So Mai 16 17:37:57 2021] NET: Registered protocol family 17
                                [So Mai 16 17:37:57 2021] Key type dns_resolver registered
                                [So Mai 16 17:37:57 2021] Registering SWP/SWPB emulation handler
                                [So Mai 16 17:37:57 2021] registered taskstats version 1
                                [So Mai 16 17:37:57 2021] Loading compiled-in X.509 certificates
                                [So Mai 16 17:37:57 2021] Key type ._fscrypt registered
                                [So Mai 16 17:37:57 2021] Key type .fscrypt registered
                                [So Mai 16 17:37:57 2021] Key type fscrypt-provisioning registered
                                [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
                                [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                [So Mai 16 17:37:57 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                [So Mai 16 17:37:57 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
                                [So Mai 16 17:37:57 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                [So Mai 16 17:37:57 2021] of_cfs_init
                                [So Mai 16 17:37:57 2021] of_cfs_init: OK
                                [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                [So Mai 16 17:37:57 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                                [So Mai 16 17:37:57 2021] Waiting for root device PARTUUID=c7534f19-02...
                                [So Mai 16 17:37:57 2021] random: fast init done
                                [So Mai 16 17:37:57 2021] mmc1: new high speed SDIO card at address 0001
                                [So Mai 16 17:37:57 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                [So Mai 16 17:37:57 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                [So Mai 16 17:37:57 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                [So Mai 16 17:37:57 2021] usb 1-1: Product: USB2.0 Hub
                                [So Mai 16 17:37:57 2021] hub 1-1:1.0: USB hub found
                                [So Mai 16 17:37:57 2021] hub 1-1:1.0: 4 ports detected
                                [So Mai 16 17:37:58 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                                [So Mai 16 17:37:58 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
                                [So Mai 16 17:37:58 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [So Mai 16 17:37:58 2021] usb 2-2: Product: Ultra
                                [So Mai 16 17:37:58 2021] usb 2-2: Manufacturer: SanDisk
                                [So Mai 16 17:37:58 2021] usb 2-2: SerialNumber: 4C530000211114109264
                                [So Mai 16 17:37:58 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
                                [So Mai 16 17:37:58 2021] scsi host0: usb-storage 2-2:1.0
                                [So Mai 16 17:37:59 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
                                [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB)
                                [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write Protect is off
                                [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                                [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
                                [So Mai 16 17:37:59 2021]  sda: sda1 sda2
                                [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
                                [So Mai 16 17:37:59 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                [So Mai 16 17:37:59 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [So Mai 16 17:37:59 2021] devtmpfs: mounted
                                [So Mai 16 17:37:59 2021] Freeing unused kernel memory: 2048K
                                [So Mai 16 17:37:59 2021] Run /sbin/init as init process
                                [So Mai 16 17:37:59 2021]   with arguments:
                                [So Mai 16 17:37:59 2021]     /sbin/init
                                [So Mai 16 17:37:59 2021]     splash
                                [So Mai 16 17:37:59 2021]   with environment:
                                [So Mai 16 17:37:59 2021]     HOME=/
                                [So Mai 16 17:37:59 2021]     TERM=linux
                                [So Mai 16 17:37:59 2021] systemd[1]: System time before build time, advancing clock.
                                [So Mai 16 17:37:59 2021] NET: Registered protocol family 10
                                [So Mai 16 17:37:59 2021] Segment Routing with IPv6
                                [So Mai 16 17:37:59 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                                [So Mai 16 17:37:59 2021] systemd[1]: Detected architecture arm.
                                [So Mai 16 17:37:59 2021] systemd[1]: Set hostname to <raspberrypi>.
                                [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
                                [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
                                [So Mai 16 17:38:00 2021] random: systemd: uninitialized urandom read (16 bytes read)
                                [So Mai 16 17:38:00 2021] systemd[1]: Created slice User and Session Slice.
                                [So Mai 16 17:38:00 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
                                [So Mai 16 17:38:00 2021] systemd[1]: Listening on Syslog Socket.
                                [So Mai 16 17:38:00 2021] systemd[1]: Listening on udev Kernel Socket.
                                [So Mai 16 17:38:00 2021] systemd[1]: Listening on Journal Socket (/dev/log).
                                [So Mai 16 17:38:01 2021] i2c /dev entries driver
                                [So Mai 16 17:38:01 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
                                [So Mai 16 17:38:01 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
                                [So Mai 16 17:38:02 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                                [So Mai 16 17:38:02 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                                [So Mai 16 17:38:02 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                                [So Mai 16 17:38:02 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                                [So Mai 16 17:38:02 2021] mc: Linux media interface: v0.10
                                [So Mai 16 17:38:02 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] videodev: Linux video capture interface: v2.00
                                [So Mai 16 17:38:02 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
                                [So Mai 16 17:38:02 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: start
                                [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: installed successfully
                                [So Mai 16 17:38:02 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                [So Mai 16 17:38:02 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                [So Mai 16 17:38:02 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                [So Mai 16 17:38:02 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                [So Mai 16 17:38:03 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                [So Mai 16 17:38:03 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                                [So Mai 16 17:38:03 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                                [So Mai 16 17:38:03 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                [So Mai 16 17:38:03 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                [So Mai 16 17:38:03 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
                                [So Mai 16 17:38:03 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                [So Mai 16 17:38:03 2021] usbcore: registered new interface driver brcmfmac
                                [So Mai 16 17:38:03 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                                [So Mai 16 17:38:03 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                [So Mai 16 17:38:05 2021] random: crng init done
                                [So Mai 16 17:38:05 2021] random: 7 urandom warning(s) missed due to ratelimiting
                                [So Mai 16 17:38:05 2021] uart-pl011 fe201000.serial: no DMA platform data
                                [So Mai 16 17:38:05 2021] 8021q: 802.1Q VLAN Support v1.8
                                [So Mai 16 17:38:06 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                                [So Mai 16 17:38:06 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet eth0: Link is Down
                                [So Mai 16 17:38:08 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:09 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:10 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:11 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:12 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                                [So Mai 16 17:38:12 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                                [So Mai 16 17:38:12 2021] Bluetooth: Core ver 2.22
                                [So Mai 16 17:38:12 2021] NET: Registered protocol family 31
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI device and connection manager initialized
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI socket layer initialized
                                [So Mai 16 17:38:12 2021] Bluetooth: L2CAP socket layer initialized
                                [So Mai 16 17:38:12 2021] Bluetooth: SCO socket layer initialized
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI UART driver ver 2.3
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol H4 registered
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Broadcom registered
                                [So Mai 16 17:38:12 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                [So Mai 16 17:38:12 2021] Bluetooth: BNEP filters: protocol multicast
                                [So Mai 16 17:38:12 2021] Bluetooth: BNEP socket layer initialized
                                [So Mai 16 17:38:13 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                [So Mai 16 17:38:13 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:14 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:38:15 2021] broken atomic modeset userspace detected, disabling atomic
                                [So Mai 16 17:41:10 2021] fuse: init (API version 7.32)
                                • E Esmax666
                                  pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
                                  Logging to file:
                                          /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
                                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0
                                  COMMAND    PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                                  @esmax666
                                  Da läuft ja immer noch ein gnome / fuse usw. mit.
                                  sudo raspi-config
                                  Dann dort:
                                  1 System Options       Configure system settings
                                  S5 Boot / Auto Login   Select boot into desktop or to command line
                                  B1 Console             Text console, requiring user to login
                                  E 1 Antwort Letzte Antwort
                                    @esmax666
                                    sudo raspi-config
                                    Dann dort:
                                    Esmax666
                                    #66
                                    @thomas-braun ja, ich brauche Desktop brauche generel
                                    hätte nie gedacht das Desktop probleme macht mit Z wave :/
                                    ist jetzt weg aber geht immer noch nicht ok
                                    [So Mai 16 17:53:13 2021] Booting Linux on physical CPU 0x0
                                    [So Mai 16 17:53:13 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
                                    [So Mai 16 17:53:13 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
                                    [So Mai 16 17:53:13 2021] CPU: div instructions available: patching division cod        e
                                    [So Mai 16 17:53:13 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct        ion cache
                                    [So Mai 16 17:53:13 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
                                    [So Mai 16 17:53:13 2021] Memory policy: Data cache writealloc
                                    [So Mai 16 17:53:13 2021] Reserved memory: created CMA memory pool at 0x00000000        1ec00000, size 256 MiB
                                    [So Mai 16 17:53:13 2021] OF: reserved mem: initialized node linux,cma, compatib        le id shared-dma-pool
                                    [So Mai 16 17:53:13 2021] Zone ranges:
                                    [So Mai 16 17:53:13 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                                    [So Mai 16 17:53:13 2021]   Normal   empty
                                    [So Mai 16 17:53:13 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
                                    [So Mai 16 17:53:13 2021] Movable zone start for each node
                                    [So Mai 16 17:53:13 2021] Early memory node ranges
                                    [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff        ]
                                    [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff        ]
                                    [So Mai 16 17:53:13 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff        ]
                                    [So Mai 16 17:53:13 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000        1ffffffff]
                                    [So Mai 16 17:53:13 2021] On node 0 totalpages: 2061056
                                    [So Mai 16 17:53:13 2021]   DMA zone: 2304 pages used for memmap
                                    [So Mai 16 17:53:13 2021]   DMA zone: 0 pages reserved
                                    [So Mai 16 17:53:13 2021]   DMA zone: 196608 pages, LIFO batch:63
                                    [So Mai 16 17:53:13 2021]   HighMem zone: 1864448 pages, LIFO batch:63
                                    [So Mai 16 17:53:13 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u819        20
                                    [So Mai 16 17:53:13 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                                    [So Mai 16 17:53:13 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                    [So Mai 16 17:53:13 2021] Built 1 zonelists, mobility grouping on.  Total pages:        2058752
                                    [So Mai 16 17:53:13 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:        5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        y1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes r        ootwait quiet splash plymouth.ignore-serial-consoles
                                    [So Mai 16 17:53:13 2021] Kernel parameter elevator= does not have any effect an        ymore.
                                                              Please use sysfs to set IO scheduler for individual de        vices.
                                    [So Mai 16 17:53:13 2021] Dentry cache hash table entries: 131072 (order: 7, 524        288 bytes, linear)
                                    [So Mai 16 17:53:13 2021] Inode-cache hash table entries: 65536 (order: 6, 26214        4 bytes, linear)
                                    [So Mai 16 17:53:13 2021] mem auto-init: stack:off, heap alloc:off, heap free:of        f
                                    [So Mai 16 17:53:13 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000        000018c00000] (64MB)
                                    [So Mai 16 17:53:13 2021] Memory: 7799068K/8244224K available (10240K kernel cod        e, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K c        ma-reserved, 7457792K highmem)
                                    [So Mai 16 17:53:13 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod        es=1
                                    [So Mai 16 17:53:13 2021] ftrace: allocating 33942 entries in 67 pages
                                    [So Mai 16 17:53:13 2021] ftrace: allocated 67 pages with 3 groups
                                    [So Mai 16 17:53:13 2021] rcu: Hierarchical RCU implementation.
                                    [So Mai 16 17:53:13 2021]       Rude variant of Tasks RCU enabled.
                                    [So Mai 16 17:53:13 2021]       Tracing variant of Tasks RCU enabled.
                                    [So Mai 16 17:53:13 2021] rcu: RCU calculated value of scheduler-enlistment dela        y is 10 jiffies.
                                    [So Mai 16 17:53:13 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                    [So Mai 16 17:53:13 2021] GIC: Using split EOI/Deactivate mode
                                    [So Mai 16 17:53:13 2021] random: get_random_bytes called from start_kernel+0x3c        8/0x59c with crng_init=0
                                    [So Mai 16 17:53:13 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr        aps every 2147483647500ns
                                    [So Mai 16 17:53:13 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff        fffff, max_idle_ns: 1911260446275 ns
                                    [So Mai 16 17:53:13 2021] bcm2835: system timer (irq = 25)
                                    [So Mai 16 17:53:13 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                    [So Mai 16 17:53:13 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                    [So Mai 16 17:53:13 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps        every 4398046511102ns
                                    [So Mai 16 17:53:13 2021] Switching to timer-based delay loop, resolution 18ns
                                    [So Mai 16 17:53:13 2021] Console: colour dummy device 80x30
                                    [So Mai 16 17:53:13 2021] printk: console [tty1] enabled
                                    [So Mai 16 17:53:13 2021] Calibrating delay loop (skipped), value calculated usi        ng timer frequency.. 108.00 BogoMIPS (lpj=540000)
                                    [So Mai 16 17:53:13 2021] pid_max: default: 32768 minimum: 301
                                    [So Mai 16 17:53:13 2021] LSM: Security Framework initializing
                                    [So Mai 16 17:53:13 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b        ytes, linear)
                                    [So Mai 16 17:53:13 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8        192 bytes, linear)
                                    [So Mai 16 17:53:13 2021] Disabling memory control group subsystem
                                    [So Mai 16 17:53:13 2021] CPU: Testing write buffer coherency: ok
                                    [So Mai 16 17:53:13 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                    [So Mai 16 17:53:13 2021] Setting up static identity map for 0x200000 - 0x20003c
                                    [So Mai 16 17:53:13 2021] rcu: Hierarchical SRCU implementation.
                                    [So Mai 16 17:53:13 2021] smp: Bringing up secondary CPUs ...
                                    [So Mai 16 17:53:13 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                    [So Mai 16 17:53:13 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                    [So Mai 16 17:53:13 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                    [So Mai 16 17:53:13 2021] smp: Brought up 1 node, 4 CPUs
                                    [So Mai 16 17:53:13 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS)        .
                                    [So Mai 16 17:53:13 2021] CPU: All CPU(s) started in HYP mode.
                                    [So Mai 16 17:53:13 2021] CPU: Virtualization extensions available.
                                    [So Mai 16 17:53:13 2021] devtmpfs: initialized
                                    [So Mai 16 17:53:13 2021] VFP support v0.3: implementor 41 architecture 3 part 4        0 variant 8 rev 0
                                    [So Mai 16 17:53:13 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf        fffffff, max_idle_ns: 19112604462750000 ns
                                    [So Mai 16 17:53:13 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,        linear)
                                    [So Mai 16 17:53:13 2021] pinctrl core: initialized pinctrl subsystem
                                    [So Mai 16 17:53:13 2021] NET: Registered protocol family 16
                                    [So Mai 16 17:53:13 2021] DMA: preallocated 1024 KiB pool for atomic coherent al        locations
                                    [So Mai 16 17:53:13 2021] audit: initializing netlink subsys (disabled)
                                    [So Mai 16 17:53:13 2021] audit: type=2000 audit(0.030:1): state=initialized aud        it_enabled=0 res=1
                                    [So Mai 16 17:53:13 2021] thermal_sys: Registered thermal governor 'step_wise'
                                    [So Mai 16 17:53:13 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
                                    [So Mai 16 17:53:13 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                    [So Mai 16 17:53:13 2021] Serial: AMBA PL011 UART driver
                                    [So Mai 16 17:53:13 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                    [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Attached to firmwar        e from 2021-04-30T13:45:52, variant start
                                    [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7        f29d96450abfc77cd6cf011af1faf1e03e5e56
                                    [So Mai 16 17:53:13 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac        hans=0x1
                                    [So Mai 16 17:53:13 2021] vgaarb: loaded
                                    [So Mai 16 17:53:13 2021] SCSI subsystem initialized
                                    [So Mai 16 17:53:13 2021] usbcore: registered new interface driver usbfs
                                    [So Mai 16 17:53:13 2021] usbcore: registered new interface driver hub
                                    [So Mai 16 17:53:13 2021] usbcore: registered new device driver usb
                                    [So Mai 16 17:53:13 2021] usb_phy_generic phy: supply vcc not found, using dummy        regulator
                                    [So Mai 16 17:53:13 2021] clocksource: Switched to clocksource arch_sys_counter
                                    [So Mai 16 17:53:14 2021] VFS: Disk quotas dquot_6.6.0
                                    [So Mai 16 17:53:14 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40        96 bytes)
                                    [So Mai 16 17:53:14 2021] FS-Cache: Loaded
                                    [So Mai 16 17:53:14 2021] CacheFiles: Loaded
                                    [So Mai 16 17:53:14 2021] NET: Registered protocol family 2
                                    [So Mai 16 17:53:14 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde        r: 0, 6144 bytes, linear)
                                    [So Mai 16 17:53:14 2021] TCP established hash table entries: 8192 (order: 3, 32        768 bytes, linear)
                                    [So Mai 16 17:53:14 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt        es, linear)
                                    [So Mai 16 17:53:14 2021] TCP: Hash tables configured (established 8192 bind 819        2)
                                    [So Mai 16 17:53:14 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li        near)
                                    [So Mai 16 17:53:14 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte        s, linear)
                                    [So Mai 16 17:53:14 2021] NET: Registered protocol family 1
                                    [So Mai 16 17:53:14 2021] RPC: Registered named UNIX socket transport module.
                                    [So Mai 16 17:53:14 2021] RPC: Registered udp transport module.
                                    [So Mai 16 17:53:14 2021] RPC: Registered tcp transport module.
                                    [So Mai 16 17:53:14 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu        le.
                                    [So Mai 16 17:53:14 2021] PCI: CLS 0 bytes, default 64
                                    [So Mai 16 17:53:14 2021] Initialise system trusted keyrings
                                    [So Mai 16 17:53:14 2021] workingset: timestamp_bits=14 max_order=21 bucket_orde        r=7
                                    [So Mai 16 17:53:14 2021] zbud: loaded
                                    [So Mai 16 17:53:14 2021] FS-Cache: Netfs 'nfs' registered for caching
                                    [So Mai 16 17:53:14 2021] NFS: Registering the id_resolver key type
                                    [So Mai 16 17:53:14 2021] Key type id_resolver registered
                                    [So Mai 16 17:53:14 2021] Key type id_legacy registered
                                    [So Mai 16 17:53:14 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register        ing...
                                    [So Mai 16 17:53:14 2021] Key type asymmetric registered
                                    [So Mai 16 17:53:14 2021] Asymmetric key parser 'x509' registered
                                    [So Mai 16 17:53:14 2021] bounce: pool size: 64 pages
                                    [So Mai 16 17:53:14 2021] Block layer SCSI generic (bsg) driver version 0.4 load        ed (major 249)
                                    [So Mai 16 17:53:14 2021] io scheduler mq-deadline registered
                                    [So Mai 16 17:53:14 2021] io scheduler kyber registered
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000        0 ranges:
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb        /pcie@7d500000, using [bus 00-ff]
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f        ffffff -> 0x00c0000000
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bf        ffffff -> 0x0400000000
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS        C)
                                    [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0        0
                                    [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
                                    [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x        63fffffff] (bus address [0xc0000000-0xffffffff])
                                    [So Mai 16 17:53:14 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                    [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
                                    [So Mai 16 17:53:14 2021] PCI: bus0: Fast back to back transfers disabled
                                    [So Mai 16 17:53:14 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                    [So Mai 16 17:53:14 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff        64bit]
                                    [So Mai 16 17:53:14 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
                                    [So Mai 16 17:53:14 2021] PCI: bus1: Fast back to back transfers disabled
                                    [So Mai 16 17:53:14 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6        000fffff]
                                    [So Mai 16 17:53:14 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6        00000fff 64bit]
                                    [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
                                    [So Mai 16 17:53:14 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6        000fffff]
                                    [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                                    [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                                    [So Mai 16 17:53:14 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable        d
                                    [So Mai 16 17:53:14 2021] bcm2835-aux-uart fe215040.serial: there is not valid m        aps for state default
                                    [So Mai 16 17:53:14 2021] iproc-rng200 fe104000.rng: hwrng registered
                                    [So Mai 16 17:53:14 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_s        ize:0x3ff00000(1023 MiB)
                                    [So Mai 16 17:53:14 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe        rs at 0xfe200000
                                    [So Mai 16 17:53:14 2021] brd: module loaded
                                    [So Mai 16 17:53:14 2021] loop: module loaded
                                    [So Mai 16 17:53:14 2021] Loading iSCSI transport class v2.0-870.
                                    [So Mai 16 17:53:14 2021] libphy: Fixed MDIO Bus: probed
                                    [So Mai 16 17:53:14 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                    [So Mai 16 17:53:14 2021] libphy: bcmgenet MII bus: probed
                                    [So Mai 16 17:53:14 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver r8152
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver lan78xx
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver smsc95xx
                                    [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                    [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 1
                                    [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi        on 0x100 quirks 0x0000030000000890
                                    [So Mai 16 17:53:14 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu        ct=0002, bcdDevice= 5.10
                                    [So Mai 16 17:53:14 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
                                    [So Mai 16 17:53:14 2021] usb usb1: Product: xHCI Host Controller
                                    [So Mai 16 17:53:14 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                    [So Mai 16 17:53:14 2021] usb usb1: SerialNumber: 0000:01:00.0
                                    [So Mai 16 17:53:14 2021] hub 1-0:1.0: USB hub found
                                    [So Mai 16 17:53:14 2021] hub 1-0:1.0: 1 port detected
                                    [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 2
                                    [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee        d
                                    [So Mai 16 17:53:14 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu        ct=0003, bcdDevice= 5.10
                                    [So Mai 16 17:53:14 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
                                    [So Mai 16 17:53:14 2021] usb usb2: Product: xHCI Host Controller
                                    [So Mai 16 17:53:14 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                    [So Mai 16 17:53:14 2021] usb usb2: SerialNumber: 0000:01:00.0
                                    [So Mai 16 17:53:14 2021] hub 2-0:1.0: USB hub found
                                    [So Mai 16 17:53:14 2021] hub 2-0:1.0: 4 ports detected
                                    [So Mai 16 17:53:14 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                    [So Mai 16 17:53:14 2021] dwc_otg: FIQ enabled
                                    [So Mai 16 17:53:14 2021] dwc_otg: NAK holdoff enabled
                                    [So Mai 16 17:53:14 2021] dwc_otg: FIQ split-transaction FSM enabled
                                    [So Mai 16 17:53:14 2021] Module dwc_common_port init
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver uas
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usb-storage
                                    [So Mai 16 17:53:14 2021] mousedev: PS/2 mouse device common for all mice
                                    [So Mai 16 17:53:14 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim        er
                                    [So Mai 16 17:53:14 2021] sdhci: Secure Digital Host Controller Interface driver
                                    [So Mai 16 17:53:14 2021] sdhci: Copyright(c) Pierre Ossman
                                    [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri        ng probe
                                    [So Mai 16 17:53:14 2021] sdhci-pltfm: SDHCI platform and OF driver helper
                                    [So Mai 16 17:53:14 2021] ledtrig-cpu: registered to indicate activity on CPUs
                                    [So Mai 16 17:53:14 2021] hid: raw HID events driver (C) Jiri Kosina
                                    [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usbhid
                                    [So Mai 16 17:53:14 2021] usbhid: USB HID core driver
                                    [So Mai 16 17:53:14 2021] Initializing XFRM netlink socket
                                    [So Mai 16 17:53:14 2021] NET: Registered protocol family 17
                                    [So Mai 16 17:53:14 2021] Key type dns_resolver registered
                                    [So Mai 16 17:53:14 2021] Registering SWP/SWPB emulation handler
                                    [So Mai 16 17:53:14 2021] registered taskstats version 1
                                    [So Mai 16 17:53:14 2021] Loading compiled-in X.509 certificates
                                    [So Mai 16 17:53:14 2021] Key type ._fscrypt registered
                                    [So Mai 16 17:53:14 2021] Key type .fscrypt registered
                                    [So Mai 16 17:53:14 2021] Key type fscrypt-provisioning registered
                                    [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: there is not valid maps fo        r state default
                                    [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl        ed
                                    [So Mai 16 17:53:14 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,        base_baud = 0) is a PL011 rev2
                                    [So Mai 16 17:53:14 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, b        ase_baud = 62500000) is a 16550
                                    [So Mai 16 17:53:14 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do        mains driver
                                    [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                    [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                    [So Mai 16 17:53:14 2021] of_cfs_init
                                    [So Mai 16 17:53:14 2021] of_cfs_init: OK
                                    [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                    [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                    [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                    [So Mai 16 17:53:14 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm        c2] using ADMA
                                    [So Mai 16 17:53:14 2021] Waiting for root device PARTUUID=c7534f19-02...
                                    [So Mai 16 17:53:14 2021] random: fast init done
                                    [So Mai 16 17:53:14 2021] mmc1: new high speed SDIO card at address 0001
                                    [So Mai 16 17:53:14 2021] usb 1-1: new high-speed USB device number 2 using xhci        _hcd
                                    [So Mai 16 17:53:14 2021] usb 1-1: New USB device found, idVendor=2109, idProduc        t=3431, bcdDevice= 4.21
                                    [So Mai 16 17:53:14 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser        ialNumber=0
                                    [So Mai 16 17:53:14 2021] usb 1-1: Product: USB2.0 Hub
                                    [So Mai 16 17:53:14 2021] hub 1-1:1.0: USB hub found
                                    [So Mai 16 17:53:14 2021] hub 1-1:1.0: 4 ports detected
                                    [So Mai 16 17:53:15 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 usin        g xhci_hcd
                                    [So Mai 16 17:53:15 2021] usb 2-2: New USB device found, idVendor=0781, idProduc        t=5581, bcdDevice= 1.00
                                    [So Mai 16 17:53:15 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, Ser        ialNumber=3
                                    [So Mai 16 17:53:15 2021] usb 2-2: Product: Ultra
                                    [So Mai 16 17:53:15 2021] usb 2-2: Manufacturer: SanDisk
                                    [So Mai 16 17:53:15 2021] usb 2-2: SerialNumber: 4C530000211114109264
                                    [So Mai 16 17:53:15 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
                                    [So Mai 16 17:53:15 2021] scsi host0: usb-storage 2-2:1.0
                                    [So Mai 16 17:53:16 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra        1.00 PQ: 0 ANSI: 6
                                    [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (        62.1 GB/57.8 GiB)
                                    [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write Protect is off
                                    [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                                    [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: e        nabled, doesn't support DPO or FUA
                                    [So Mai 16 17:53:16 2021]  sda: sda1 sda2
                                    [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
                                    [So Mai 16 17:53:16 2021] EXT4-fs (sda2): mounted filesystem with ordered data m        ode. Opts: (null)
                                    [So Mai 16 17:53:16 2021] VFS: Mounted root (ext4 filesystem) readonly on device        8:2.
                                    [So Mai 16 17:53:16 2021] devtmpfs: mounted
                                    [So Mai 16 17:53:16 2021] Freeing unused kernel memory: 2048K
                                    [So Mai 16 17:53:16 2021] Run /sbin/init as init process
                                    [So Mai 16 17:53:16 2021]   with arguments:
                                    [So Mai 16 17:53:16 2021]     /sbin/init
                                    [So Mai 16 17:53:16 2021]     splash
                                    [So Mai 16 17:53:16 2021]   with environment:
                                    [So Mai 16 17:53:16 2021]     HOME=/
                                    [So Mai 16 17:53:16 2021]     TERM=linux
                                    [So Mai 16 17:53:16 2021] systemd[1]: System time before build time, advancing c        lock.
                                    [So Mai 16 17:53:16 2021] NET: Registered protocol family 10
                                    [So Mai 16 17:53:16 2021] Segment Routing with IPv6
                                    [So Mai 16 17:53:16 2021] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN        UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie        rarchy=hybrid)
                                    [So Mai 16 17:53:16 2021] systemd[1]: Detected architecture arm.
                                    [So Mai 16 17:53:16 2021] systemd[1]: Set hostname to <raspberrypi>.
                                    [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFil        e= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp        .pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
                                    [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9:        PIDFile= references path below legacy directory /var/run/, updating /var/run/xr        dp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file acco        rdingly.
                                    [So Mai 16 17:53:17 2021] random: systemd: uninitialized urandom read (16 bytes        read)
                                    [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Audit Socket.
                                    [So Mai 16 17:53:17 2021] systemd[1]: Reached target Swap.
                                    [So Mai 16 17:53:17 2021] systemd[1]: Created slice User and Session Slice.
                                    [So Mai 16 17:53:17 2021] systemd[1]: Listening on Syslog Socket.
                                    [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Socket.
                                    [So Mai 16 17:53:18 2021] i2c /dev entries driver
                                    [So Mai 16 17:53:18 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
                                    [So Mai 16 17:53:18 2021] systemd-journald[115]: Received request to flush runti        me journal from PID 1
                                    [So Mai 16 17:53:19 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi        alised: Registers at 0xfeb00000 length 0x00010000
                                    [So Mai 16 17:53:19 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem        initialised: Registers at 0xfeb10000 length 0x00001000
                                    [So Mai 16 17:53:19 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi        alised: Registers at 0xfeb20000 length 0x00010000
                                    [So Mai 16 17:53:19 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial        ised: Registers at 0xfeb30000 length 0x00010000
                                    [So Mai 16 17:53:19 2021] vc_sm_cma: module is from the staging directory, the q        uality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive        r
                                    [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: start
                                    [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: installed successfully
                                    [So Mai 16 17:53:19 2021] mc: Linux media interface: v0.10
                                    [So Mai 16 17:53:19 2021] snd_bcm2835: module is from the staging directory, the        quality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835_audio bcm2835_audio: card created with 8 chann        els
                                    [So Mai 16 17:53:19 2021] videodev: Linux video capture interface: v2.00
                                    [So Mai 16 17:53:19 2021] bcm2835_mmal_vchiq: module is from the staging directo        ry, the quality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835_isp: module is from the staging directory, the        quality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe        red as /dev/video13
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist        ered as /dev/video14
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist        ered as /dev/video15
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register        ed as /dev/video16
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m        edia controller
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
                                    [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                    [So Mai 16 17:53:19 2021] bcm2835_codec: module is from the staging directory, t        he quality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835_v4l2: module is from the staging directory, th        e quality is unknown, you have been warned.
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video10
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video11
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video12
                                    [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                    [So Mai 16 17:53:19 2021] cfg80211: Loading compiled-in X.509 certificates for r        egulatory database
                                    [So Mai 16 17:53:20 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                    [So Mai 16 17:53:20 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c        ea7'
                                    [So Mai 16 17:53:20 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
                                    [So Mai 16 17:53:20 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d        on minor 0
                                    [So Mai 16 17:53:20 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4        3455-sdio for chip BCM4345/6
                                    [So Mai 16 17:53:20 2021] usbcore: registered new interface driver brcmfmac
                                    [So Mai 16 17:53:20 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/br        cmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                                    [So Mai 16 17:53:20 2021] [drm] No displays found. Consider forcing hotplug if H        DMI is attached
                                    [So Mai 16 17:53:20 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_        ops [vc4])
                                    [So Mai 16 17:53:20 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor        1
                                    [So Mai 16 17:53:20 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w        l0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                    [So Mai 16 17:53:21 2021] random: crng init done
                                    [So Mai 16 17:53:21 2021] random: 7 urandom warning(s) missed due to ratelimitin        g
                                    [So Mai 16 17:53:22 2021] uart-pl011 fe201000.serial: no DMA platform data
                                    [So Mai 16 17:53:22 2021] 8021q: 802.1Q VLAN Support v1.8
                                    [So Mai 16 17:53:23 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents        :1 across:102396k FS
                                    [So Mai 16 17:53:23 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save en        abled
                                    [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet: configuring instance for e        xternal RGMII (RX delay)
                                    [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet eth0: Link is Down
                                    [So Mai 16 17:53:26 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu        ll - flow control off
                                    [So Mai 16 17:53:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read        y
                                    [So Mai 16 17:53:28 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s        yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_        ms instead
                                    [So Mai 16 17:53:28 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes rea        dy
                                    [So Mai 16 17:53:29 2021] Bluetooth: Core ver 2.22
                                    [So Mai 16 17:53:29 2021] NET: Registered protocol family 31
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI device and connection manager initializ        ed
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI socket layer initialized
                                    [So Mai 16 17:53:29 2021] Bluetooth: L2CAP socket layer initialized
                                    [So Mai 16 17:53:29 2021] Bluetooth: SCO socket layer initialized
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI UART driver ver 2.3
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol H4 registered
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere        d
                                    [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Broadcom registered
                                    [So Mai 16 17:53:29 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                    [So Mai 16 17:53:29 2021] Bluetooth: BNEP filters: protocol multicast
                                    [So Mai 16 17:53:29 2021] Bluetooth: BNEP socket layer initialized
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs
                                    2021-05-16 17:59:39.521  - info: zwave2.0 (30261) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                    Logging to file:
                                    2021-05-16 17:59:39.677  - error: zwave2.0 (30261) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                    • E Esmax666
                                      pi@raspberrypi:~ $ dmesg -T
                                      pi@raspberrypi:~ $
                                      Logging to file:
                                      #67
                                      @esmax666 sagte in Probleme mit Serialport bei zwave2:
                                      [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
                                      [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
                                      Da läuft immer noch Quark mit (Und die service-Datei ist auch falsch). Hast du VNC in raspi-config aktiv? Mach das da aus.
                                      Steck den Stick jetzt mal wieder rein und schau ob / welche Zeilen am Ende von
                                      dmesg -T
                                      neu dazu gekommen sind. Und nimm den EIntrag /dev/ttyAMA0 mal aus der Adapterkonfig raus. Da hab ich einen Denkfehler drin, das ist wohl das Bluetooth-Device.
                                        dmesg -T
                                        Esmax666
                                        #68
                                        @thomas-braun na dann was dann eintragen in serial
                                        @thomas-braun said in Probleme mit Serialport bei zwave2:
                                        wie soll ich das desaktivieren ?
                                        • E Esmax666
                                          #69
                                          Wie/wo hast du es denn aktiviert? Denn in der Grundkonfiguration läuft das nicht mit.
                                          In raspi-config gibt es aber eine Einstellung aus der Ecke:
                                          3 Interface Options   Configure connections to peripherals
                                          P3 VNC                Enable/disable graphical remote access using RealVNC
                                          Stell denn da mal aus, wenn der aktiv sein sollte.
                                          Zum Port: Was passiert wenn du den auf /dev/ttyS0 stellst?
