  4. Node-Red
  5. String aufteilen
    6.5k
String aufteilen
141 Beiträge 3 Kommentatoren 21.5k Aufrufe 2 Beobachtet
  • H hafo
    @mickym Ich muss da etwas verbockt haben
           "id": "82dfdd05.4d8e1",
           "type": "change",
           "z": "4524d790.7edb8",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "days",
                   "tot": "flow"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1070,
           "y": 1100,
           "wires": [
                   "5317be7b.ef4338"
           "id": "e7dc8e38.b0003",
           "type": "ioBroker out",
           "name": "Tomaten Tage",
           "topic": "0_userdata.0.Bewässerung.Tomaten_Tage",
           "ack": "false",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1980,
           "y": 1100,
           "wires": []
           "id": "4760a6ff.969fe8",
           "type": "split",
           "name": "",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "arraySpltType": "len",
           "stream": false,
           "addname": "",
           "x": 1430,
           "y": 1100,
           "wires": [
                   "29b86736.dbc0f8"
           "id": "cb07faa.5e09e08",
           "type": "join",
           "name": "",
           "mode": "custom",
           "build": "string",
           "property": "payload",
           "propertyType": "msg",
           "key": "topic",
           "joiner": ",",
           "joinerType": "str",
           "accumulate": false,
           "timeout": "",
           "count": "",
           "reduceRight": false,
           "reduceExp": "",
           "reduceInit": "",
           "reduceInitType": "",
           "reduceFixup": "",
           "x": 1790,
           "y": 1100,
           "wires": [
                   "e7dc8e38.b0003",
                   "d22a9254.04dc08"
           "id": "29b86736.dbc0f8",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "true",
                   "fromt": "bool",
                   "to": "1",
                   "tot": "str"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "false",
                   "fromt": "bool",
                   "to": "0",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1610,
           "y": 1100,
           "wires": [
                   "cb07faa.5e09e08"
           "id": "5317be7b.ef4338",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "0_userdata.0.Bewässerung.Tomaten_Tage",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1280,
           "y": 1100,
           "wires": [
                   "4760a6ff.969fe8"
           "id": "d22a9254.04dc08",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "false",
           "statusVal": "",
           "statusType": "auto",
           "x": 1970,
           "y": 1180,
           "wires": []
    Das Debug Nod läuft auch über wenn ich einen anderen Punkt speichere, da sollte dieser Strang doch gar nicht auslösen.
    mickymM Offline
    mickymM Offline
    mickym
    @hafo Unterbrich mal die Verbindung zur iobroker-Out Node und schau ob es dann aufhört. Wenn nicht dann triggert irgendwas anderes dauernd.
    H 2 Antworten Letzte Antwort
    • mickymM mickym
      hafo
      @mickym Das habe ich schon gemacht, bringt keine Änderung
      • H hafo
        @mickym Ja, es läuft auch Rund ohne die out Node. Das hat keinen Einfluss.
        Aus der Split Node kommt dasselbe raus "false"
        mickymM Offline
        mickymM Offline
        mickym
        #66
        @hafo sagte in String aufteilen:
        Dann stimmt was an Deinem Trigger nicht. Der ist mir eh nicht koscher mit dem false und true usw. Im Prinzip sollte das ja ein Button sein. Dann Eingangstrigger stoppen.
        • mickymM mickym
          hafo
          #67
          @mickym Es fängt immer erst nach dem Speichern an und hört erst auf wenn ich den Flow leicht ändere und neu übernehme.
          • H hafo
            mickymM Offline
            mickymM Offline
            mickym
            #68
            @hafo Ja dann feuert was an Deinem Trigger. Mach mal nur 1 Inject Node dran und lös einmal manuell aus mit true und schau, ob dann auch nur 1 Nachricht erzeugt wird.
            H 1 Antwort Letzte Antwort
            • mickymM mickym
              hafo
              #69
              @mickym Interessant, auf diese Art wird der Strang mit dem Change Nod gar nicht ausgelöst.
              • H hafo
                mickymM Offline
                mickymM Offline
                mickym
                #70
                Du triggerst die Inject Node manuell und es kommt gar nichts????
                Dann hänge eine Debug Node an die get Node - da muss ja in jedem Fall was rauskommen?
                • mickymM mickym
                  hafo
                  #71
                  @mickym Die iobroker get Nodes werden ausgelesen, bei den anderen geht nichts
                  • H hafo
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #72
                    @hafo Unterbrich bitte mal die Verbindung von der Trigger Node - so dass nur die Inject Node triggert.
                    • mickymM mickym
                      hafo
                      #73
                      @mickym habe ich gemacht, ändert nichts.
                      Für mich reicht es für heute. Vielen Dank für deinen Einsatz und gute Nacht.
                      • H hafo
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #74
                        @hafo OK - dann halt Schritt für Schritt vorgehen. Die nächste Node wird natürlich nur gefüllt, wenn die Flow Variable gefüllt ist usw.
                        • mickymM mickym
                          hafo
                          #75
                          @mickym müssen die Flows im selben Tab sein? Wenn ich den Tab offen habe in welchem die Variable gebildet wird, wird sie mir angezeigt. Im Tab wo sie ausgelesen werde sollte aber nicht.
                          • H hafo
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #76
                            @hafo Na dann ist es kein Wunder. Ein Flow ist ein Tab und eine Flowvariable gilt nur für einen Flow und somit für einen Tab. Entweder Du bringst Deine Flows auf einen Tab, anderenfalls musst Du halt alles in Globale Variablen speichern. Die haben dann in allen Tabs Gültigkeit.
                            Tipp: Nutze die 4 Icons unten rechts im Hauptfenster um Dich innerhalb eines Flows / Tabs zu bewegen oder um größere Teil Deines Flows zu verschieben oder zu bewegen. Außerdem rufe ich Node red immer aus den Kacheln auf, dann macht sich im Browser ein eigener <tab auf, das bringt auch noch etwas Fläche.
                            • mickymM mickym
                              hafo
                              schrieb am zuletzt editiert von hafo
                              #77
                              @mickym Habe es bereits geändert, ich depp!
                              im vis eingetragen und gespeichert
                              es wird alles übernommen
                              auch mit dem Timer klappts nun
                              • H hafo
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #78
                                @hafo Na super. Dann klappt ja nun alles. Glückwunsch!!!
                                Auf die Idee wäre ich wahrlich erst zuletzt gekommen. Man sollte doch nichts für selbstverständlich nehmen.😉😉😉
                                • mickymM mickym
                                  hafo
                                  #79
                                  @mickym wenn ich etwas falsch mache, dann richtig 💪
                                  vielen Dank für deine Hilfe.
                                  Hier die Dateien falls jemand etwas ähnliches machen möchte.
                                  bew1.json
                                  bew2.json
                                  Ich mache mich nun ans vis, und werde dann den Flow noch mit Sensoren ergänzen.
                                  • mickymM mickym
                                    hafo
                                    #80
                                    @mickym so ganz fertig sind wir leider noch nicht.
                                    Der String wird wild durcheinander gewürfelt. Ich versuche mich gerade am Sort Node, das arbeitet aber nicht so wie ich möchte.
                                    Der Rechner übernimmt teilweise auch falsche Werte. Da muss ich mit meinen Rechner Nodes noch arbeiten.
                                    • H hafo
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #81
                                      @hafo Schau mal in die Kontextdaten, ob da die Tage in der richtigen Reihenfolge stehen.
                                      Wenn nicht würde ich
                                      1. Die Flow Variable bei jedem Neustart von Node-Red neu initialisieren.
                                             "id": "6ba7ea7c.1a0a74",
                                             "type": "inject",
                                             "z": "4922e7ed.227918",
                                             "name": "Init flow Days",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": true,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "{\"1Mo\":false,\"2Di\":false,\"3Mi\":false,\"4Do\":false,\"5Fr\":false,\"6Sa\":false,\"7So\":false}",
                                             "payloadType": "json",
                                             "x": 530,
                                             "y": 2160,
                                             "wires": [
                                                     "6e1e2d6a.21b184"
                                             "id": "6e1e2d6a.21b184",
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "days",
                                                     "pt": "flow",
                                                     "to": "payload",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 750,
                                             "y": 2160,
                                             "wires": [
                                      1. In den JOIN Nodes die Anzahl der Nachrichten bis eine Nachricht versendet wird zwingend auf 7 festlegen.
                                      Ggf. muss man diese Node noch resetten, aber erst mal so schauen, ob das geht.
                                      Das Wichtigste ist aber dass im Flow-Kontext die richtige Reihenfolge steht. Das war zumindest in der letzten Debugausgabe nicht der Fall.
                                      • mickymM mickym
                                               "type": "inject",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": true,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "x": 530,
                                               "y": 2160,
                                               "wires": [
                                                       "6e1e2d6a.21b184"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "days",
                                                       "pt": "flow",
                                                       "to": "payload",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 750,
                                               "y": 2160,
                                               "wires": [
                                        hafo
                                        #82
                                        @mickym Ja, so läufts richtig. 👑
                                        • mickymM mickym
                                                 "type": "inject",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": true,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 530,
                                                 "y": 2160,
                                                 "wires": [
                                                         "6e1e2d6a.21b184"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "days",
                                                         "pt": "flow",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 750,
                                                 "y": 2160,
                                                 "wires": [
                                          hafo
                                          #83
                                          @mickym Ich würde noch gerne bei meinen Rechner aufräumen. Es gibt folgende 4 Operationen:
                                          1. (Number(msg.payload) - 1) * 60;
                                          2. (Number(msg.payload) + Number(msg.min)) * 60000;
                                          3. payload x 60000;
                                          4. Number(msg.payload) + Number(msg.lauf)
                                          Für die Nummer 3 habe ich Testweise den Calculator genommen, die anderen Laufen im Functions Node. Macht es Sinn alle in das Functions Node zu setzen, oder wie macht man das am besten? Mit dem Change Nod habe ich seltsame Resultate erhalten und das Aggregator Node scheint nicht dafür gedacht zu sein.
