  4. Deinstallation schlägt fehl / CUL Installation fehlerhaft
10 Beiträge 2 Kommentatoren 1.3k Aufrufe
    Marcolotti
    der zu testzwecken installierte Adapter Wireless MBUS kann nicht mehr deinstalliert werden.
    Außerdem versuche ich seit Tage den CUL-Adapter zum laufen zu bringen.
    Versionen: JS-Controller 0.15.3
    Node: v7.4.0
    Admin: 1.6.11
    Problem 1: Deinstallation WM-BUS
    root@raspberrypi:/opt/iobroker# sudo iobroker del wm-bus
    host.raspberrypi no instances of adapter wm-bus found
    host.raspberrypi Adapter wm-bus cannot be deleted completely, because non-deletable.
    Problem 2: Installation CUL
    root@raspberrypi:/opt/iobroker# sudo iobroker install cul
    npm install iobroker.cul --production --prefix "/opt/iobroker" (System call)
    got /opt/iobroker/node_modules/iobroker.cul/admin
    upload [1] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/index.html index.html text/html
    upload [0] cul.admin /opt/iobroker/node_modules/iobroker.cul/admin/busware.jpg busware.jpg image/jpeg
    Instanz startet nicht:````
    raspberrypi 2017-01-26 12:07:02.625 info host.raspberrypi Restart adapter system.adapter.cul.0 because enabled
    raspberrypi 2017-01-26 12:07:02.622 error host.raspberrypi instance system.adapter.cul.0 terminated with code 1 ()
    raspberrypi 2017-01-26 12:07:00.689 info host.raspberrypi instance system.adapter.cul.0 started with pid 29116
    raspberrypi 2017-01-26 12:06:30.904 info host.raspberrypi Restart adapter system.adapter.cul.0 because enabled
    raspberrypi 2017-01-26 12:06:30.901 error host.raspberrypi instance system.adapter.cul.0 terminated with code 1 ()
    raspberrypi 2017-01-26 12:06:28.203 info host.raspberrypi instance system.adapter.cul.0 started with pid 29100
    Gruß Marco
    P.S. Ich kann auch keine Objekte mehr manuell unter Objekte ändern.
    CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
    • BluefoxB Offline
      BluefoxB Offline
      @Marcolotti:
      Node: v7.4.0
      Admin: 1.6.11
      Gruß Marco
      P.S. Ich kann auch keine Objekte mehr manuell unter Objekte ändern. `
      Was wird bei dir gesagt, wenn du so was aufrufst?
      cd /opt/iobroker
      sudo node /opt/iobroker/node_modules/iobroker.cul/cul.js --logs
        Marcolotti
        root@raspberrypi:/opt/iobroker# sudo node /opt/iobroker/node_modules/iobroker.cu        l/cul.js --logs
        starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.cul, node: v7.4.0
        2017-01-26 13:28:02.492  - info: cul.0 starting. Version 0.2.2 in /opt/iobroker/        node_modules/iobroker.cul, node: v7.4.0
        Cannot open port: Port is not selected
        2017-01-26 13:28:02.540  - error: cul.0 Cannot open port: Port is not selected
        Ich kann den Port aber nicht wählen. :?
          Marcolotti
          Wenn ich den Befehl von dir eingebe und starte, kann ich die Ports auswählen. Der Adapter zeigt Verbunden mit CUL. Stoppe ich das Logging, funktioniert die Auswahl des Ports nicht. :?:
          • BluefoxB Offline
            BluefoxB Offline
            @Marcolotti:
            Wenn ich den Befehl von dir eingebe und starte, kann ich die Ports auswählen. Der Adapter zeigt Verbunden mit CUL. Stoppe ich das Logging, funktioniert die Auswahl des Ports nicht. :?: `
            Kann das sein, dass dein ioBroker nicht als sudo läuft?
            Nämlich nur root darf aus dem seriellem Port lesen.
              Marcolotti
              Ich habe iobroker mit sudo gestartet. Jetzt geht der CUL-Adapter. Kommen auch Daten rein. Nun geht allerdings der RFLINK Adapter nicht mehr. Bei SerialPort steht: Nicht möglich
              Ich glaube, die beiden USB´s mögen sich nicht.
              Gruß Marco
                Marcolotti
                Starte ich mit Sudo geht CUL
                Starte ich ohne Sudo geht RFLink
                Muss ich mich jetzt entscheiden? :) Oder gibt es dafür eine Lösung. :mrgreen:
                  Marcolotti
                  Leider geht bis heute der CUL-Adapter nicht. Wollte es nur nochmal ans Tageslicht bringen. :|
                  • BluefoxB Offline
                    BluefoxB Offline
                    @Marcolotti:
                    Starte ich ohne Sudo geht RFLink `
                    Das verstehe ich nicht. Ohne Sudo darf man auf Serialport nicht zugreifen. Wie geht es denn das?
                      Marcolotti
                      Hallo Bluefox,
                      ich denke, das Hauptproblem bei mir ist, dass nur ein Adapter auf USB bzw. Serial zugreifen kann. Kommt ein 2. Adapter hinzu, kann er nicht mehr auf die Schnittstellen zugreifen.
                      Aus diesem Grunde würde ich um Feedback von den anderen bitten, ob sie zwei verschiedene Adapter laufen haben, die 2 verschiedene USB-Geräte bedienen.
                      Gruß Marco
