  4. Adapter Das Wetter merkwürdiges Verhalten
das wetterneustartnoerror
12 Beiträge 6 Kommentatoren 707 Aufrufe 2 Beobachtet
  • F Offline
    Feinfinger
    Ist dieses Verhaltren des Adapters normal?
    Konfiguriert ist er so, das er alle 54 Minuten das Wetter aktualisiert.
    Für mich sieht es aber so aus, als startet er jede Stunde neu.
    host.ioBroker	2021-05-11 04:00:18.241	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 04:00:00.143	info	instance system.adapter.daswetter.0 started with pid 15619
    host.ioBroker	2021-05-11 03:54:17.090	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 03:54:00.106	info	instance system.adapter.daswetter.0 started with pid 9615
    host.ioBroker	2021-05-11 03:00:24.370	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 03:00:00.379	info	instance system.adapter.daswetter.0 started with pid 20269
    host.ioBroker	2021-05-11 02:54:16.984	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 02:54:00.146	info	instance system.adapter.daswetter.0 started with pid 14242
    host.ioBroker	2021-05-11 02:00:19.366	info	undefined
    host.ioBroker	2021-05-11 02:00:19.366	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 02:00:00.115	info	instance system.adapter.daswetter.0 started with pid 24842
    host.ioBroker	2021-05-11 01:54:18.258	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 01:54:00.139	info	instance system.adapter.daswetter.0 started with pid 18842
    host.ioBroker	2021-05-11 01:00:15.234	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 01:00:00.107	info	instance system.adapter.daswetter.0 started with pid 29516
    host.ioBroker	2021-05-11 00:54:18.214	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    host.ioBroker	2021-05-11 00:54:00.150	info	instance system.adapter.daswetter.0 started with pid 23530
    iob als LXC im Proxmox
    Node.js: v22.19.0
    NPM: 10.9.3
    js-controller 7.0.7
    PeoplesP 1 Antwort Letzte Antwort
    • F Feinfinger
      PeoplesP Offline
      PeoplesP Offline
      Peoples
      @feinfinger
      Der Adapter hat meines Wissens ein shedule oder, d.h. er startet alle 54 Minuten, holt sich die Daten und geht wieder "schlafen".
      F 1 Antwort Letzte Antwort
      • PeoplesP Peoples
        @feinfinger
        Feinfinger
        @peoples
        Alles klar, Danke für die Info.
        Kann ich das Log Level vom host eigentlich auch auf "warn" stellen, oder geht das nur über die Auswahl am oberen Rand der Log Übersicht?
        Node.js: v22.19.0
        NPM: 10.9.3
        js-controller 7.0.7
        • F Feinfinger
          @peoples
          A Online
          A Online
          Ahnungsbefreit
          @feinfinger In der "Instanzen" Ansicht geht das für jeden Adapter separat, wenn der Expertenmodus aktiviert ist. Dort siehst Du dann auch, wie oft der Adapter gestartet wird und kannst das ändern.
          cashC 1 Antwort Letzte Antwort
          • A Ahnungsbefreit
            cashC Offline
            cashC Offline
            cash
            @ahnungsbefreit Der Adapter startet bei Dir zweimal die Stunde einmal zur vollen Stunde und 00 Minuten und einmal bei 54 Minuten. Du solltest den Schedule nochmal überdenken.
            F A 2 Antworten Letzte Antwort
            • cashC cash
              Feinfinger
              schrieb am zuletzt editiert von Feinfinger
              @cash
              Mein Cron sieht so aus
              Oder muss dann hier was anderes eingestellt werden?
              Node.js: v22.19.0
              NPM: 10.9.3
              js-controller 7.0.7
              • F Feinfinger
                @cash
                FredFF Online
                FredFF Online
                FredF
                Most Active Forum Testing
                @feinfinger Mit deinem cron wird jede volle Stunde und alle 54 min die Daten geholt. Also genau so wie du es eingestellt hast
                • FredFF FredF
                  Feinfinger
                  @fredf
                  Wie müsste der Cron denn für alle 54 Min aussehen?
                  Node.js: v22.19.0
                  NPM: 10.9.3
                  js-controller 7.0.7
                  • F Feinfinger
                    @fredf
                    FredFF Online
                    FredFF Online
                    FredF
                    • cashC cash
                      A Online
                      A Online
                      Ahnungsbefreit
                      @cash Ich denke mal, das war nicht für mich....
                      • FredFF FredF
                        Feinfinger
                        @fredf
                        Danke dir :-)
                        Node.js: v22.19.0
                        NPM: 10.9.3
                        js-controller 7.0.7
                        • ostseereiterO Offline
                          ostseereiter
                          Irgendwie haut der Adapter auch nicht richtig hin ich habe auch ein Haufen Warnmeldungen.
                          daswetter.0	2021-05-11 14:46:19.137	error	(13915) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_value": Connection is closed.
                          daswetter.0	2021-05-11 14:46:19.135	error	(13915) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_dir: Cannot check object existence of "daswetter.0.NextHours.
                          daswetter.0	2021-05-11 14:46:19.134	error	(13915) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_dir": Connection is closed.
                          daswetter.0	2021-05-11 14:46:19.132	error	(13915) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_symbol: Cannot check object existence of "daswetter.0.NextHou
                          daswetter.0	2021-05-11 14:46:19.131	error	(13915) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_symbol": Connection is closed.
                          daswetter.0	2021-05-11 14:46:19.129	error	(13915) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_symbolB: Cannot check object existence of "daswetter.0.NextHo
                          daswetter.0	2021-05-11 14:46:19.128	error	(13915) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_14.wind_symbolB": Connection is closed.
                          daswetter.0	2021-05-11 14:46:19.124	error	(13915) exception in await insertIntoList [Error: DB closed]
                          Gruß OSR
                          Plattform
