  4. Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol
    2.3k
    4.3k
111 Beiträge 6 Kommentatoren 14.5k Aufrufe 7 Beobachtet
  • R Rookie50
    @liv-in-sky
      <variables>
        <variable id="+QRm(=Ejp5.2FwDfrulq">originalText</variable>
        <variable id="]T:/?:QRL;m/1wq*S#7S">suchText</variable>
        <variable id="SoreJ$m[hJ}Vs4{au@E7">tauschText</variable>
        <variable type="cron" id="schedule1">schedule1</variable>
        <variable id="*mH[}F.6Kta#KW;c3jPW">Text</variable>
        <variable id="SqHEqX_`I0]e3Glpt9iD">AnzZeichenSuchtext</variable>
        <variable id="p[!d9g5$d1fizuo7WbDZ">aktualisierung_an</variable>
        <variable id="qbn;e*.QW/TlYV3N%sr=">wertelist_browser</variable>
        <variable id="moB_xt[#isik:YT0=J3/">Stelle</variable>
        <variable id="V!?b;m:_l0eU[qp:2SFO">result</variable>
        <variable id="Y#iAI*FR!oAWI_VKn4tj">Teil_1</variable>
        <variable id="?;zNzBa@_q5|lTMhID_F">Teil_2</variable>
      </variables>
      <block type="on_ext" id="P9gIT)?_8qk=2a=Gyw7i" x="1012" y="-2688">
        <value name="OID0">
          <shadow type="field_oid" id="bUly[J[D=V%*PoJoQnK+">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Library_Folder</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="control" id="Z;;FV%9Jj|I*_609{miP">
            <field name="OID">0_userdata.0.Media.Bluesound.Küche.Library_Folderstring</field>
            <value name="VALUE">
              <block type="lists_getIndex" id=":cJHi4?i)mXdCqll-R:w">
                <mutation statement="false" at="true"></mutation>
                <field name="MODE">GET</field>
                <field name="WHERE">FROM_START</field>
                  <block type="variables_get" id="`GQ])@$OJTDc$}!-8,Em">
                    <field name="VAR" id="qbn;e*.QW/TlYV3N%sr=">wertelist_browser</field>
                  </block>
                </value>
                <value name="AT">
                  <block type="get_value" id="a]Lgdui6,TOK{?|zwGoz">
                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.Library_Folder</field>
                  </block>
                </value>
              </block>
            </value>
          </block>
        </statement>
      </block>
      <block type="procedures_defreturn" id="*?%n[KG5e1!^tNun#Hj5" x="-812" y="-1913">
        <mutation>
          <arg name="originalText" varid="+QRm(=Ejp5.2FwDfrulq"></arg>
          <arg name="suchText" varid="]T:/?:QRL;m/1wq*S#7S"></arg>
          <arg name="tauschText" varid="SoreJ$m[hJ}Vs4{au@E7"></arg>
        </mutation>
        <field name="NAME">changeText</field>
        <statement name="STACK">
          <block type="variables_set" id="LyZ2%lYW+kfm,4)yV8UN">
            <field name="VAR" id="*mH[}F.6Kta#KW;c3jPW">Text</field>
              <block type="variables_get" id="da5*p]}sO:{{|ZE!nhDe">
                <field name="VAR" id="+QRm(=Ejp5.2FwDfrulq">originalText</field>
              </block>
            </value>
            <next>
              <block type="variables_set" id="yx;qp1@1fC(oiG4c5gZt">
                <field name="VAR" id="SqHEqX_`I0]e3Glpt9iD">AnzZeichenSuchtext</field>
                  <block type="text_length" id="Jwz33ARDLc!=8:eDagDD">
                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="RZWm!~Yo4w5)66Gu|Gs_">
                        <field name="TEXT">abc</field>
                      </shadow>
                      <block type="variables_get" id="G2I+np)5qee]q{4)BlN2">
                        <field name="VAR" id="]T:/?:QRL;m/1wq*S#7S">suchText</field>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="eAGK[85W)DRaIaN!oMiH">
                    <field name="VAR" id="moB_xt[#isik:YT0=J3/">Stelle</field>
                      <block type="text_indexOf" id="/@rj}{;VUCJ8O|28^(Hf">
                        <field name="END">FIRST</field>
                          <block type="variables_get" id="}de%ffO*rIt%j6)99pf3">
                          </block>
                        </value>
                        <value name="FIND">
                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="7MprEQxoWq}#3~Xz:32k">
                            <field name="TEXT">%0D%0A</field>
                          </shadow>
                          <block type="variables_get" id="7)r.X1a~Tee1!dAwZy`!">
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="controls_whileUntil" id="4lR}{f])DWKyjt}.(6cc">
                        <field name="MODE">WHILE</field>
                        <value name="BOOL">
                          <block type="logic_compare" id="e`eUWK6kyOU=[/x]M({`">
                            <field name="OP">GT</field>
                            <value name="A">
                              <block type="variables_get" id="}7HLWRwI(SDg1^@=czoV">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="#y,za{r#@s7Ri.U!9v)A">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO">
                          <block type="controls_if" id="PM@Su)b1YOhTZo2qPxB]">
                            <value name="IF0">
                              <block type="logic_compare" id="l,u?h{)Z-u/OozI,.79G">
                                <field name="OP">EQ</field>
                                <value name="A">
                                  <block type="variables_get" id="B/K~z.ANK2);I3(uk4Bh">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="|3~K:6jrHq7oxz=fL:Yz">
                                    <field name="NUM">1</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO0">
                              <block type="comment" id="uN{|N4-0EabDJqYE0]@#">
                                <field name="COMMENT">steht am Textanfang</field>
                                <next>
                                  <block type="variables_set" id="9?Gy,w.t#1pdl^AOxc#Y">
                                    <field name="VAR" id="Y#iAI*FR!oAWI_VKn4tj">Teil_1</field>
                                      <block type="variables_get" id="h(#=bJ`DU%y/Jd9%HR9I">
                                        <field name="VAR" id="SoreJ$m[hJ}Vs4{au@E7">tauschText</field>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <statement name="ELSE">
                              <block type="variables_set" id="{R*X,7K)DA^dq/.~KK7{">
                                  <block type="text_getSubstring" id="Img0opt.EB#)RM-bp~hw">
                                    <mutation at1="false" at2="true"></mutation>
                                    <field name="WHERE1">FIRST</field>
                                    <field name="WHERE2">FROM_START</field>
                                    <value name="STRING">
                                      <block type="variables_get" id="A9h*F{tgJR0y[Q0uv7,=">
                                      </block>
                                    </value>
                                    <value name="AT2">
                                      <block type="math_arithmetic" id="([5R[:8Ywn-thKN@r:~}">
                                        <value name="A">
                                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="u@:!j5WimCjV%fG9hPGs">
                                          </shadow>
                                          <block type="variables_get" id="U0qw,~,2KoaAc37UO{l#">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="DT#zRSRu1.y^|5Z#G37W">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                              <block type="variables_set" id="Else^,?QE9TTS.Y%K]W=">
                                <field name="VAR" id="?;zNzBa@_q5|lTMhID_F">Teil_2</field>
                                  <block type="text_getSubstring" id="e8A7NqY7O!@K(aFlMpV#" inline="false">
                                    <mutation at1="true" at2="false"></mutation>
                                    <field name="WHERE1">FROM_START</field>
                                    <field name="WHERE2">LAST</field>
                                      <block type="variables_get" id="|jU0g8+eIgwn_|IB56)@">
                                      </block>
                                    </value>
                                    <value name="AT1">
                                      <block type="math_arithmetic" id="F#*%;R9ugmwaaas?WBwG">
                                        <field name="OP">ADD</field>
                                        <value name="A">
                                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="8/I%=/~YReHV]Iwo{}(J">
                                          </shadow>
                                          <block type="variables_get" id="R0|a}kx2M~SYjPKS5Cc{">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";Q(aJ::90?0?H;-45cgS">
                                          </shadow>
                                          <block type="variables_get" id="dY33=1IVxkrSH1k1#X6A">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="OcJS!-Ku1vQY4)I+r,gc">
                                      <block type="text_join" id="%%D@nUqB1tt^`?qrUahx">
                                        <value name="ADD0">
                                          <block type="variables_get" id="q]l%0Dpb89BZy1-m[TjM">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="variables_get" id="f~POFU0}K4-w]xVc1?,`">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="variables_get" id="U77~u,Qfmb2g[O19eHoh">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="lao?KUxF77Si~Xc2j%^{">
                                          <block type="text_indexOf" id="[),PN,ZrAW,C/~:K[x[:">
                                              <block type="variables_get" id="6{t:BeVh6=bsQF(zUhYG">
                                              </block>
                                            </value>
                                            <value name="FIND">
                                              <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="{Vd/Su8uk@lo|:3KMi1L">
                                              </shadow>
                                              <block type="variables_get" id="r|~fKkGR#@1@G6_GX`-g">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
        <value name="RETURN">
          <block type="variables_get" id=".*DA-:q/GzURSEPH2ZiQ">
          </block>
        </value>
      </block>
      <block type="on_ext" id="7)?1A[QaPRjBlqqW+o#z" x="63" y="-412">
        <value name="OID0">
          <shadow type="field_oid" id="4Cxg;]3:k%DD08c5=-Js">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Stop</field>
          </shadow>
        </value>
          <block type="request" id="kCp_:n8M$^4`Yd8P/QDy">
            <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
            <field name="WITH_STATEMENT">FALSE</field>
            <field name="LOG">log</field>
            <value name="URL">
              <shadow type="text">
              </shadow>
              <block type="text_join" id="9_6|XmgF-o!/IDX(c5bT">
                <value name="ADD0">
                  <block type="text" id="XwRsM{jew`aTJtH3j?}s">
                    <field name="TEXT">http://</field>
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="z$st~OHffc`QD:JOZ+!#">
                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.IP</field>
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id="n)HC=rU!XSlaCyex#z%X">
                    <field name="TEXT">:11000/Pause</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="ne37.PKv5;,!QHSm_fgN">
                <field name="VAR" id="p[!d9g5$d1fizuo7WbDZ">aktualisierung_an</field>
                  <block type="logic_boolean" id="^YzQSIDrca_7O?HTR[5D">
                  </block>
                </value>
                <next>
                  <block type="control" id="LGr{712ub`##FK*LT#r.">
                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.Album</field>
                      <block type="text" id="7=;d7DVIBgD|pizQtEk.">
                        <field name="TEXT"></field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="{$ky,88PBycJNb_34u?s">
                        <field name="OID">0_userdata.0.Media.Bluesound.Küche.Artist</field>
                          <block type="text" id="4^f/?Q1fD1jKlt#O0|oy">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="qahg%}ZsU))Q7-cK+%u;">
                            <field name="OID">0_userdata.0.Media.Bluesound.Küche.Artwork</field>
                              <block type="text" id="YA@8X!#0E})?=mkC1KOc">
                              </block>
                            </value>
                            <next>
                              <block type="control" id="F9%|.z),+M]!(=ay^L:Q">
                                <field name="OID">0_userdata.0.Media.Bluesound.Küche.Title</field>
                                  <block type="text" id="i]ihlf?FnRJ.N~%W8Z-,">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on_ext" id="Sev=?2(3{D4yq+plvjMb" x="63" y="88">
        <value name="OID0">
          <shadow type="field_oid" id="HXG}[HRqL=^(d;AQ-zEp">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Volume</field>
          </shadow>
        </value>
          <block type="request" id="rbRv}2c3K%4[Y~3W+%pL">
            <value name="URL">
              <shadow type="text" id="VNQ.0-:w3QbzIc?p}Bbc">
              </shadow>
              <block type="text_join" id="HI?xKM3!O/VEYOS$sA^:">
                <mutation items="4"></mutation>
                <value name="ADD0">
                  <block type="text" id="Dt^zH|?[^_G!jhLYd7Qw">
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="h)W?TX7B.zju6}qYF~9t">
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id="UrXJd+5M=e+{(1oLCI3$">
                    <field name="TEXT">:11000/Volume?level=</field>
                  </block>
                </value>
                <value name="ADD3">
                  <block type="get_value" id="-#T/owsH/L#Xb8+@1hlr">
                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.Volume</field>
                  </block>
                </value>
              </block>
            </value>
          </block>
        </statement>
      </block>
      <block type="schedule_create" id="M#X-bGuZ*/4[[Y_2DLIY" x="1063" y="38">
        <field name="NAME">schedule1</field>
        <value name="SCHEDULE">
          <shadow type="field_cron" id="c,H@u,.r`kI)U^y26OW}">
            <field name="CRON">*/5 * * * * *</field>
          </shadow>
        </value>
          <block type="controls_if" id="|}Bar0g=4LVj}p~?ibC_">
            <value name="IF0">
              <block type="logic_compare" id="P1`Z^Sa+AdA:_05UjgTI">
                <value name="A">
                  <block type="variables_get" id="fq,FvKXbM[?m::f~{pf`">
                  </block>
                </value>
                <value name="B">
                  <block type="logic_boolean" id="pvO$luJo~o*uTsXz57QW">
                  </block>
                </value>
              </block>
            </value>
              <block type="request" id=";[0C..zDNuE0%$7?q3}J">
                <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                <field name="WITH_STATEMENT">TRUE</field>
                <field name="LOG"></field>
                <value name="URL">
                  </shadow>
                  <block type="text_join" id="M^0:r7sEc~I%-g]mhk]q">
                    <value name="ADD0">
                      <block type="text" id="q`pSxk|Uhmb22Hh|^V(}">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="-/P7w.rYI!:K2E*|;a/Y">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="8@:guEjO^#pK|*l)[HZ2">
                        <field name="TEXT">:11000/Status</field>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="debug" id="r/4N7uV7PWUR;X4?+@g+">
                    <value name="TEXT">
                      <shadow type="text" id="XY2`wPREgSG^a!QpHSyu">
                      </shadow>
                      <block type="variables_get" id="d:Cig{Qu`#zSo)(h=c;o">
                        <field name="VAR" id="V!?b;m:_l0eU[qp:2SFO">result</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="{/RW2_=Bo)HGCaDG9LK7">
                          <block type="get_attr" id="bxMpbbDzyA@)Od7,Ke`N">
                            <value name="PATH">
                              <shadow type="text" id="(a!y4e1V2!SZjxXP4(fL">
                                <field name="TEXT">Artist</field>
                              </shadow>
                            </value>
                            <value name="OBJECT">
                              <block type="convert_object2json" id="xf:g*Hrm9+OOjr,Xa{f*">
                                <field name="PRETTIFY">TRUE</field>
                                  <block type="variables_get" id=":m@N$w~ih,E,`B~^rLC!">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="debug" id="oU.~e_SdapGq:]WGpET(">
                            <value name="TEXT">
                              </shadow>
                              <block type="get_value" id="%dW84hzqcSzD=*`8@5!e">
                              </block>
                            </value>
                            <next>
                              <block type="control" id="@bZr9b};$oYTUuo4%R}o">
                                  <block type="get_attr" id="MaudAf+f={=+/[@.YiAS">
                                    <value name="PATH">
                                      <shadow type="text" id="w*/DnNB{!-GJ?7JF=7@1">
                                        <field name="TEXT">Title1</field>
                                      </shadow>
                                    </value>
                                      <block type="convert_object2json" id="vL38tFeC9Fzph.st)r)a">
                                          <block type="variables_get" id="uc6Qp:_~K8;|Fl;!e[17">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="control" id="FC5rZB)-,,SatPL;R%ch">
                                      <block type="get_attr" id="v:Pk6%L^{_`O~]iU*]S!">
                                        <value name="PATH">
                                          <shadow type="text" id="s|#2b2/u.A)dmz*70QZ*">
                                            <field name="TEXT">Album</field>
                                          </shadow>
                                        </value>
                                          <block type="convert_object2json" id="h7Mkq]AOylQhBn%a]sqv">
                                              <block type="variables_get" id="AjAH=xR@Sy+}Yf(MpiwJ">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </statement>
      </block>
      <block type="on_ext" id="e]gnXbSiVl)E$noe?^V$" x="63" y="438">
        <value name="OID0">
          <shadow type="field_oid" id="W;X?Hsk#gh2u!0yivk?:">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Play</field>
          </shadow>
        </value>
          <block type="request" id="9UfbJ,`_p{H7tjSb%q;M">
            <value name="URL">
              </shadow>
              <block type="text_join" id="^O)H1tCk)ti#_u@M$j(~">
                <value name="ADD0">
                  <block type="text" id="=0`FHbc*i1d1ymM3ii-i">
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="*]8u~X?t:IE}6s1@08uz">
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id="a]i.p/k]p]pT8-E~@Tg^">
                    <field name="TEXT">:11000/Play</field>
                  </block>
                </value>
              </block>
            </value>
              <block type="debug" id="Kar+l3ay/3e*Z@s^oTw7">
                <value name="TEXT">
                  <shadow type="text" id="*O75M[)TT}j+99P-^:0)">
                    <field name="TEXT">Play</field>
                  </shadow>
                </value>
              </block>
            </statement>
            <next>
              <block type="request" id="{UWL!L(~vcmH5.W[57K}">
                <value name="URL">
                  </shadow>
                  <block type="text_join" id="a6cCA2F/ae.c22c6ll$v">
                    <value name="ADD0">
                      <block type="text" id=",6lF8ga`N1WlxeS}SGB;">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="eR+XA_m4gqepT,.|paZo">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="d2p?+On8z~`f*foMjO,9">
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="6!|3HClkm|e_U}g=bU^x">
                      <block type="logic_boolean" id="Fi2`VF(|]`_5gi8X!JjS">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on_ext" id="Y?Sm41$(D)9#lQ~lJxt$" x="1063" y="788">
        <value name="OID0">
          <shadow type="field_oid" id="qiOnaC5?sd:D8in8LYMK">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Preset-to-Device</field>
          </shadow>
        </value>
          <block type="control" id="cS;^-5MCZ{MKw[a2n+L)">
              <block type="text" id="ve9_p/8=#,{S:X2aBE32">
              </block>
            </value>
            <next>
              <block type="control" id="JIp)0jG4h;z0Q/PS2?j9">
                  <block type="text" id="~*8T!p+x}r~JZvjER)1}">
                  </block>
                </value>
                <next>
                  <block type="control" id="_0I9awCziv3|idO*f=(b">
                      <block type="text" id="$uHD%}no[cYx}x=1UhzM">
                      </block>
                    </value>
                    <next>
                      <block type="control" id=".9nX+#/zx%?D~POpOJqc">
                          <block type="text" id="a3|PsRhd*K:n]h6G2`]_">
                          </block>
                        </value>
                        <next>
                          <block type="request" id="*O+az%+o~^=N^ygHeGdS">
                            <value name="URL">
                              </shadow>
                              <block type="text_join" id="5@#cS:ojO`L5j+whHUZ*">
                                <value name="ADD0">
                                  <block type="text" id="6}?si2ykB!h_3!VCIk+h">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="get_value" id="#$e#XD,1j4e/!EU%IGEb">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="%@wD?j}SO/eaG7VgXg6f">
                                    <field name="TEXT">:11000/Preset?id=</field>
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="get_value" id="]]hMV{`If#iu`uv8.|c+">
                                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.Preset-to-Device</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="Tp[P/O:|Nmlt{-L.!U2Z">
                                  <block type="logic_boolean" id="HtN2V!HPA$KK(~^Sr5H3">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on_ext" id="Wh^g89L2U~Q2P!xB2v(W" x="63" y="1063">
        <value name="OID0">
          <shadow type="field_oid" id="bvV8Mh7ncyI1zYRI%q(Y">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Next</field>
          </shadow>
        </value>
          <block type="request" id="duTZyrhvq`n4~?crd%D=">
            <value name="URL">
              </shadow>
              <block type="text_join" id="ne;5K~2`^_,$c.Mb)jOL">
                <value name="ADD0">
                  <block type="text" id="s-i-RYY[OhkJR/-{`J3%">
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="W)=Wj(2O!B{,RMiQkP%!">
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id=",?q;=).4=knA.uaTSU26">
                    <field name="TEXT">:11000/Skip</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="]5*a-lWq6%KK{%Y$z1q9">
                  <block type="logic_boolean" id="/gLkK^t(eQHTYX%(UG[l">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on_ext" id="`odlrViD:jSax`0iGUX9" x="63" y="1413">
        <value name="OID0">
          <shadow type="field_oid" id="hn^w;}W(5?,1KEHYOWiE">
            <field name="oid">0_userdata.0.Media.Bluesound.Küche.Back</field>
          </shadow>
        </value>
          <block type="request" id=")%1(u2ly{{M%Eh:@^{(*">
            <value name="URL">
              </shadow>
              <block type="text_join" id="-~66J;|qC=wIfjc2k{/n">
                <value name="ADD0">
                  <block type="text" id="aM]4qQ/_SExnce;e-6~Y">
                  </block>
                </value>
                <value name="ADD1">
                  <block type="get_value" id="O,:%%n|zCNfY+VP}oy+2">
                  </block>
                </value>
                <value name="ADD2">
                  <block type="text" id="E}jdV)2|Q[@u*AwZmDEb">
                    <field name="TEXT">:11000/Back</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="wJdQ{R]3qGtM:l:kcQc1">
                  <block type="logic_boolean" id="LdJOUJkyDK:F[axK{#vV">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    liv-in-skyL Offline
    liv-in-skyL Offline
    #76
    @rookie50
    war wohl johnny cash
    habe es so gemacht
     <variables>
       <variable id="/;1~e`5S^.p~]8B6oCfz">x</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="HC,qb9[L^()3b.Z]}1)2" x="1137" y="137">
       <mutation statements="false">
         <arg name="x" varid="/;1~e`5S^.p~]8B6oCfz"></arg>
       </mutation>
       <field name="NAME">bekomme json</field>
       <field name="SCRIPT">dmFyIHBhcnNlciA9IHJlcXVpcmUoJ3htbDJqc29uJyk7DQovL2xldCBteU9iamVjdD0ocGFyc2VyLnRvSnNvbih4bWwpKQ0KbG9nKEpTT04uc3RyaW5naWZ5KHBhcnNlci50b0pzb24oeCkpKTsNCnJldHVybiBwYXJzZXIudG9Kc29uKHgpOw==</field>
     </block>
     <block type="request" id=";[0C..zDNuE0%$7?q3}J" x="1138" y="187">
       <value name="URL">
         </shadow>
           <value name="ADD0">
             </block>
           </value>
           <value name="ADD1">
               <field name="OID">0_userdata.0.Rookie.dieIP</field>
             </block>
           </value>
           <value name="ADD2">
             </block>
           </value>
         </block>
       </value>
           <value name="TEXT">
             </shadow>
             <block type="variables_get" id=":RL^.hCYzk5SpS$2/WJU">
             </block>
           </value>
           <next>
             <block type="debug" id="H(d^udzC$9atILaagZ,(">
               <value name="TEXT">
                 <shadow type="text" id="LrpD,@7BlBuNBl8k)bC`">
                 </shadow>
                 <block type="get_attr" id="`tttnkxJx@Y4N5HYk7U4">
                   <value name="PATH">
                     <shadow type="text" id="lzg@:[A*Pr|`)6M`C7iX">
                       <field name="TEXT">status.artist</field>
                     </shadow>
                   </value>
                     <block type="procedures_callcustomreturn" id="uGTLbegc(}9kqf1Qe3|{">
                       <mutation name="bekomme json">
                         <arg name="x"></arg>
                       </mutation>
                       <value name="ARG0">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="control" id="{/RW2_=Bo)HGCaDG9LK7" disabled="true">
                       <value name="PATH">
                         </shadow>
                       </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="debug" id="oU.~e_SdapGq:]WGpET(" disabled="true">
                       <value name="TEXT">
                         </shadow>
                         </block>
                       </value>
                       <next>
                         <block type="control" id="@bZr9b};$oYTUuo4%R}o" disabled="true">
                               <value name="PATH">
                                 </shadow>
                               </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="control" id="FC5rZB)-,,SatPL;R%ch" disabled="true">
                                   <value name="PATH">
                                     </shadow>
                                   </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    • liv-in-skyL liv-in-sky
      @rookie50 wie bindet man die vis seite in iqontrol ein - habe schon länger nicht damit gearbeitet
      oder willst du kurz bei mir auf den pc drauf gehen
      da_WoodyD Online
      da_WoodyD Online
      #77
      @liv-in-sky sagte in Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol:
      einfach den link als Background URL
      • da_WoodyD da_Woody
        liv-in-skyL Offline
        liv-in-skyL Offline
        #78
        @da_woody
        danke hab es schon https://forum.iobroker.net/post/624607
        da_WoodyD R 2 Antworten Letzte Antwort
          @da_woody
          da_WoodyD Online
          da_WoodyD Online
          #79
          @liv-in-sky 👍 war ein paar std absent... nicht mitbekommen...
          morgen düse ich ja zum @Negalein , seinen 3d-drucker zusammen tackern...
          werd mich dann mal wieder mit den listen und einbinden über vis beschäftigen. auch mit dem mugge ding. hab ja auch eine veritable sammlung auf einem meiner NASen... ;)
            @da_woody
            Rookie50
            schrieb am zuletzt editiert von Rookie50
            #80
            @liv-in-sky ich habe gestern abend noch ein bisschen gestöbert und mir ist eingefallen, dass dieses System ja nicht nur von Bluesound eingesetzt wird :-D Siehe da, bei NAD gibt es sogar eine API Dokumentation:'
            https://nadelectronics.com/wp-content/uploads/2020/12/Custom-Integration-API-v1.0_Dec_2020.pdf
            • R Rookie50
              liv-in-skyL Offline
              liv-in-skyL Offline
              #81
              @rookie50
              wenn sich noch jmd meldet, der das nutzen kann, werd ich es gerne als eigenständigen thred mit beschreibung posten
              habe noch ein - zwei kleine fehler gefunden - müssten wir mal updaten
              bist du eigentlich an der shortcaut version interessiert ? dann müßten wir mehrere files updaten - wenn nicht, ist auch ok - brauche ich dann für mein project
              R 1 Antwort Letzte Antwort
                @rookie50
                Rookie50
                #82
                @liv-in-sky
                wir können das gerne updaten, allerdings können wir das frühstens Morgen machen, heute bin ich komplett ausgebucht. Und gerne auch die Shortcut Version. Macht es doch einfacher ;-)
                LG Rookie
                liv-in-skyL 4 Antworten Letzte Antwort
                • R Rookie50
                  @liv-in-sky
                  LG Rookie
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #83
                  @rookie50 meld dich morgen , wenn du zeit hast - wollte eh noch kleinigkeiten ändern
                  • R Rookie50
                    @liv-in-sky
                    LG Rookie
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #84
                    @rookie50 kannst du mir bitte eine liste mit den ip's deiner lautsprecher geben und dessen name
                    die namen sollten kurz sein - da wenig platz in der tabelle
                    weshalb:
                    • R Rookie50
                      @liv-in-sky
                      LG Rookie
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #85
                      @rookie50
                      neue versionen mit shortcuts
                      view-fuer-vis.txt table-script-mit shortcuts.txt js--mit-shortcuts.txt datenpunkte-import.txt blockly.txt
                      • R Rookie50
                        @liv-in-sky
                        LG Rookie
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #86
                        @rookie50
                        frage nebenbei - hast du etwas in den css tabs im vis editor - wegen "vader" und hintergrund des widgets?
                          @rookie50
                          Rookie50
                          #87
                          @liv-in-sky
                          nein, dass ist alles Standard. Ich kann mir gerade auch nicht erklären, warum die Darstellung bei Dir anders ist.
                          • R Rookie50
                            @liv-in-sky
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #88
                            @rookie50
                            hast du heute mal zeit - ich habe ein problem, wobei ich play aufrufen müßte bzw - könntest du mir mal ein beispiel dafür geben
                            ist das ein richtiger aufruf - syntax mäßig gesehen?
                            http://192.168.101.107:11000/Add?&service=LocalMusic&playnow=-1&file=/var/mnt/192.168.101.20-musicAlben/2raumwohnung/Achtung Fertig/05 - Bye bye bye.mp3
                            oder gehört zwischen musicAlben ein "/"
                            ich frage daher, weil, wenn ich die daten abfrage kommt zurück
                            und das verarbeite ich - oder muss ich daran etwas verändern
                            der rote pfeil ist der eigentliche pad
                              @rookie50
                              Rookie50
                              #89
                              @liv-in-sky said in Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol:
                              könntest
                              Hi, ich war gestern den ganzen Tag unterwegs :-o und heute mal das Wetter genossen.
                              Was für ein sch... Ist mir noch gar nicht aufgefallen. Es wird tatsächlich so zurück geliefert. Natürlich muss da ein "/" zwischen, sonst wird nicht zur Play Queue hinzugefügt. Habe ich gerade getestet.
                              liv-in-skyL 3 Antworten Letzte Antwort
                              • R Rookie50
                                könntest
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #90
                                @rookie50 ok - sollte ich reinbekommen
                                • R Rookie50
                                  könntest
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #91
                                  @rookie50
                                  noch ne frage
                                  was wolltest du noch abfragen außer presets
                                  • R Rookie50
                                    könntest
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #92
                                    @rookie50
                                    bitte testen - wird das gespiel ?
                                    http://192.168.101.107:11000/Add?&service=LocalMusic&playnow=-1&file=%2Fvar%2Fmnt%2F192.168.101.20-music%2FAlben%2FAdel%20Tawil%2FLieder%2F102%20wenn_du_liebst.mp3
                                    http://192.168.101.107:11000/Add?&service=LocalMusic&playnow=-1&file=%2Fvar%2Fmnt%2F192.168.101.20-music%2FBestof%2FChristina%20Aguilera%2FStripped%2FChristina%20Aguilera%20-%2005%20-%20Primer%20Amor%20Interlude%20.mp3
                                    http://192.168.101.107:11000/Add?&service=LocalMusic&playnow=-1&file=%2Fvar%2Fmnt%2F192.168.101.20-music%2FBestof%2FChristina%20Aguilera%2FStripped%2FChristina%20Aguilera%20-%2003%20-%20Walk%20Away%20.mp3
                                      @rookie50
                                      Rookie50
                                      #93
                                      @liv-in-sky Hi, sorry, ich war nicht länger im Forum. Nein wurde nicht gespielt, da ein Leerzeichen zwischen "Best of" fehlt. Ich verstehe gerade noch nicht, warum der String falsch in dem Song Attribut mitgeteilt wird.
                                      Ich werde morgen Nachmittag nochmal Wireshark anwerfen. Morgen früh muss ich erstmal mit meinem Vater zu einer AugenOP
                                      • R Rookie50
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #94
                                        @rookie50
                                        dad geht vor - meld dich einfach
                                        irgendwie sieht das wie ein bug aus - kann aber nicht sein, da ja sonst die songs nicht spielen sollten
                                        ich habe nur das problem, das ich an dieser stelle nicht weiß - bzw nur sehr umständlich - ob in best of ein leerzeichen reinkommt - denn es wäre nicht gut, auf genau best of zu suchen - es könnte ja mal ein anderer ordner angelegt werden, der auch ein leerzeichen hat und dann nicht best of heißt
                                          @rookie50
                                          Rookie50
                                          #95
                                          @liv-in-sky
                                          sodele, ich habe nun etwas etwas nachgeforscht. Du musst keine "/" oder " " ersetzen sondern nur den "fn" Wert nach "file=" schreiben:
                                          Gibt
                                          <addsong id="4534" count="0" length="0"/>
                                          zurück. Count gibt in dem Fall an, wieviel Titel zur Play Queue hinzugefügt werden und length an welcher Position den Queue.
                                          Einen Pfad zur Play Queue hinzufügen funktioniert ja:
                                          http://192.168.101.107:11000/Add?&service=LocalMusic&path=//192.168.101.20/music/Best of/Christina Aguilera/Stripped
                                          Die Antwort:
                                          <addsong id="4535" count="20" length="20"/>
                                          20 Songs hinzugefügt und der letzte Song hat Position 20 in der Queue.
                                          Wenn wir nun eine einzelne Datei hinzufügen, nehmen wir den Wert aus den "fn" Feld:
                                          http://192.168.101.107:11000/Add?&service=LocalMusic&file=/var/mnt/192.168.101.20-musicBestof/Christina Aguilera/Stripped/Christina Aguilera - 01 - Stripped Intro .mp3
                                          Die Datei wird hinzugefügt und die Antwort lautet:'
                                          <addsong id="4536" count="1" length="21"/>
                                          count=1 eine Datei, length=21 Position 21 der Queue.
                                          Ich hoffe, dass diese Erkenntnis es etwas einfacher macht, einzelne Dateien zu spielen.
